23 страниц V « < 6 7 8 9 > »
Elektro255 V0.4 alpha 4 mod (4xR), 44R,46R,49R,79R
elektro255
сообщение 23.9.2006, 12:06 Закрепленное сообщение!
Из: Poland, Siedlce
Пользователь №: 53 130
09-04-2007
V0.4a4 Alpha: http://elektro255.ovh.org
08-04-2007
V0.4a3 Alpha: http://elektro255.ovh.org
07-04-2007
V0.4a2 44R Alpha: http://elektro255.ovh.org
20-12-2006
V0.3 79R Final mod: http://elektro255.ovh.org
27-11-2006
v0.3 for 49R Final mod http://elektro255.ovh.org/
26-11-2006
V0.3 46R Final mod: http://elektro255.ovh.org
НА Е1 Rokr с бутом 0А02 (оригинальный) НЕ ПОСТАВИТЕ БЕЗ Т.П.!
V0.4 alpha 4
Changes:
- Fixed problem with display timeout (fullscreen clock) when SMS/CALL received
Features:
- 4xR and 7xR MIX (use with 4xR flex)
- unlimited Video recording
- keypad automatic lock
- low battery alarm can be turned off or depend on ring style.
- Scheduled Ring Styles (ring style and funlight style can change automatically on given time and week day)
- flashlight shortcut (##)
- extra menu (shortcut *1 [shortcut is only for testing later will be changed])
- automatic menu enter, without sim card (emergency calls working too)
- new Java methods
- settings are stored on files
- no simlock checking
- Volume-bar sound can be turned off
- multiple menus (every skin can have one mma_ucp)
- Ported patches:
o SMS report significantly turned ON
o more folders in OBEX via BT
o removed unused folders from TransFlash
o Java have access to system files
o increased iTap user dictionary size
o no delete incall on SIM replace
o Bluetooth time changed to 3 minutes
o reordered camera store menu (store only is first)
o SMS alert is using default ringtone
OLD versions(V0.1-0.3):
Firmware changes:
- firmware based on 46R from StarterXP MP
- FULL SW access from Java
- LUMA&CHROMA tables moved to memory - now you can change JPEG compresion from Java
- StarterXP flex
- added dualboot
Flasher changes:
- if you have PDS_4013 flasher will no recreate this
Personalization tool changes:
- first version for 0.3_46R SW mod
- changing splash screen
- changing font (you can use *.fnt or *.smg CG4 files)
- you can turn on, turn off menu access without sim cart
- changing my shortcuts
Новая версия V0.4 alpha 4
Изменения:
- Устранена проблема с таймаутом дисплея(полноэкранные часы) при приеме смс/звонка
Новое:
- Прошивка создана как микс 4xR и 7xR (флекс 4xR ) В 44R она переименована для совместимости! Она близко не лежит к 44R на самом деле!
- Безлимитная запись видео (64мб макс как в 6х7х)
- Автоблок клавиатуры
- Звук разряженой батареи можно выключать или задать стилем оповещения(?).
- Расписание стилей оповещения (стиль оповещения и фанлайтмогут менятся автоматически по времени и дням недели)
- Фонарик по (##)
- Дополнительное меню (метка *1 [только для теста, после может изменится])
- Автоматический вход в меню без сим-карты (аварийные звонки работают)
- Новые методы в Яве (не от 79R, а новые)
- Настройки хранятся в файлах
- Не проверяется лоченость ПДС на симку (работает с лоченым пдс)
- Звук изменения громкости можно отключить
- Мультименю (каждый скин может иметь собственный мма_уцп)
- Портированы патчи:
o Оповещение о доставке SMS всегда вкл.
o больше папок доступно по OBEX из блютуза
o удалены неиспользуемые папки с флешки
o Полный доступ к системным файлам из явы
o увеличен размер пользовательского словаря iTap
o не удалыются последние вызовы при смене сим
o Время обнаружения блютуза - 3 минуты
o Меню сохранения видеозаписи (просто сохранить - первым пунктом)
o при приходе SMS играет "мелодия на смс", а не установленная на этого пользователя
Для версий 0.1-0.3
Изменения в прошивке:
- Создана на базе монстра StarterXP 46R
- Полный доступ к прошивке (симы, озу) из явы
- Таблицы сжатия фотографий перенесены в озу - теперь из явы можно управлять качеством фотографий (сжатием)
- флекс StarterXP
- добавлен дуалбут
Изменения флешера:
-Если ПДС версии 4013 (373 платформа), ПДС не пересоздается.
Изменения персонализации (Personalization tool):
- впервые для мода использована 46 прошивка
- замена заставки (на включение?)
- замена шрифта (лангпак, CG4)
- можно вкл. и выкл. доступ к меню без сим-карты
- изменен ярлык (копирайт?)
Для работы Personalization tool требуется положить в папку программы несжатый бинарный бэкап (32 мегабайта) под именем SW.bin
Прекращаем флудить, типа а когда выйдет новая версия, и.т.д.и.т.п, или придётся наказывать!
тему почистил, архив по 1 декабря тут:
Прикрепленный файл MotoFan_ru_electro.zip   ( 66.56 килобайт ) Кол-во скачиваний: 3902
Сообщение отредактировал elektro255 - 9.4.2007, 12:21
Kepa
сообщение 19.12.2006, 8:21
Из: Уфа
Пользователь №: 86 486
Модель телефона: Qtec S100
Прошивка: HTCMAG_ROM_RUS_O2
Zagoralsanya,
будет автоблок, фонарик (##),замена бут картинки!!!!!
Zagoralsanya
сообщение 19.12.2006, 8:49
Из: г. Омск
Пользователь №: 84 851
Модель телефона: Sony Ericsson M600i
Прошивка: Other
Kepa, а доступ к RAM?
HUNTER_ok
сообщение 19.12.2006, 10:38
Из: Заозерный webstream :D
Пользователь №: 106 065
Модель телефона: SE W810i
а доступ к RAM?
Zagoralsanya, Будет всё, что есть в моде, от которого ставишь рефлеш.
Т.к. ты заменяешь только основной код прошивки, а графическое оформление и файлы не трогаешь.
Zagoralsanya
сообщение 19.12.2006, 12:04
Из: г. Омск
Прошивка: Other
Цитата(HUNTER_ok @ Пятница, 15 Декабря 2006, 13:23)
pdr, Вот рефлеш.
http://filez.rutv.info/swel255_0.3_49R_reflash.rar
На будующее: в любом решлеше включены кодовые группы CG1 и CG3.
А можно этот рефлэш по верх 48р ставить?
KLIMER
сообщение 19.12.2006, 12:13
Пользователь №: 78 315
Прошивка: MS 1.5_79R
Zagoralsanya, конечно можно!
Chili89
сообщение 19.12.2006, 14:05
Из: Питер
Пользователь №: 51 289
Модель телефона: E 398
Прошивка: 373 R48
Ставил два патча не идин не помог.
Фото получаются такие:
(_Light_)
сообщение 19.12.2006, 17:48
Из: Latvia
Пользователь №: 48 530
Модель телефона: K3, E398, е1000, V6
та же ситуация, результат одинаковый
Bent
сообщение 20.12.2006, 3:34
MoTo Marvellous
Пользователь №: 63 874
Chili89, (_Light_), а вы ставили оригинальный патч от electro255?Если нет то перепрошейтесь и сразу ставьте его.
X3MAL
сообщение 20.12.2006, 11:04
Из: Украина, Александрия
Пользователь №: 79 325
Модель телефона: MotoMing
Прошивка: Antarex Mod 14R
Я так сразу сделал и проблем пока что не было (поплевал через левое плече :) )
HUNTER_ok
сообщение 20.12.2006, 13:40
Меня просили разобраться в звуковых патчах.
В общем я не разобрался. Не совсем понимаю технологию. Видимо здесь не простое смещение в прошивке.
Если никто не разберёться, то стучитесь к автору программы SysSound, т.е. к Vassio.
Zagoralsanya
сообщение 20.12.2006, 16:10
Из: г. Омск
Прошивка: Other
ребята, а может кто значки уровня сигнала сети из дрм выложить? а то я только рефлеш качал. вообщем буду благодарен .
elektro255
сообщение 20.12.2006, 21:35
Из: Poland, Siedlce
20-12-2006 - Final mod v0.3 for 79R
Firmware changes:
* have all functions from v0.3 49R, and unlimited video recording from 79R
* added buttons what making patches for FlashBackup
danger86
сообщение 20.12.2006, 21:56
Пользователь №: 72 895
Модель телефона: E1
HUNTER_ok,
[from X3MAL:]
Спасибо за заботу, но уже не нужно, там всё работает. Это Va-Bank по ходу что- то не так делал.
SANYO_K
сообщение 20.12.2006, 22:38
Пользователь №: 64 324
Модель телефона: ROKR E1 (E398)
Прошивка: elektro255!!! 49r
Сейчас 79r скачаю. Глянуть разве что ,потому что думая ,что с 49 по скорости она вряд ли сравнится. На 49r бенч выжимал макс 44. elektro255 MegaMotoRESPECT !!!
Zagoralsanya
сообщение 21.12.2006, 6:50
Из: г. Омск
Прошивка: Other
Bent, А там что значки уровня сигнала не такие как на 4 изображении? На том что в закреп. посте.
Хотел те что на изображении :(
Bent
сообщение 21.12.2006, 6:54
MoTo Marvellous
Zagoralsanya, ё-маё говорить же надо :) Я то подумал ты про v0.3 говоришь,а те что на скрине это v.0.2
Zagoralsanya
сообщение 21.12.2006, 7:12
Из: г. Омск
Прошивка: Other
79R кто протестил? отпишитесь пожалуйста. В частности меня интересует звук.
SANYO_K, скачал 79R?
сообщение 21.12.2006, 8:12
Пользователь №: 38 507
Модель телефона: motorola E398
У меня стоит мод 0.3 от електро255 и флекс MPX398 и вот такой вопрос. (Телефон Е398)
До этого содинялся через GPRS на ПК, загрузка страниц шла приличная около 4-5КБ/с.
Сейчас после прошивки попробывал законектиться (и не раз в разные дни) скорость вообще маленькая и не постоянная. УЖАС. Не уж то проблема в прошивке может быть или проблема в операторе ... просто совпало.
Никто не сталкнулся с такой проблемой?
Zagoralsanya
сообщение 21.12.2006, 10:47
Из: г. Омск
Прошивка: Other
79R кто протестил?
zolookas
сообщение 21.12.2006, 11:50
Пользователь №: 43 073
Прошивка: R373_G_0E.30.49R
Elektro255, personalization utilty for 79R has font bug:
elektro255
сообщение 21.12.2006, 14:25
Из: Poland, Siedlce
font is only "fast" prewiev :)
ApxuBatop
сообщение 21.12.2006, 14:57
Мото-Художник
Пользователь №: 65 512
Модель телефона: iphone 5
Прошивка: от Е398
clap;applo clap;applo clap;applo
My dreams become true! :) Thx a lot! rolleyes.gif Ready to test it...
Poltorash
сообщение 22.12.2006, 0:12
Из: г.Тверь
Пользователь №: 47 989
Модель телефона: E398 + 512mb
Прошивка: 373_79r+руки.
Столкнулся с класным багом. Не ставятся звуки в наст. звонка на СМС и в будильнике.. только родные типа "Внимание"
Bent
сообщение 22.12.2006, 3:27
MoTo Marvellous
Poltorash, Через p2ktools нажми кнопочку FixMelodyDB--Все бессшумные--перезагрузи телефон.
Zagoralsanya
сообщение 22.12.2006, 3:45
Из: г. Омск
Прошивка: Other
У меня всё в порядке. Скорей всего у тебя оператор плохо работает.... (иногда бывает тоже, я купил симки 4-х операторов и если один не справляется с поставкой жпрс то я вставляю другую сим)))
А так вот координально ни чего не изменилось. Вот и сейчас через жпрс сижу)))
go-blin
сообщение 22.12.2006, 4:18
Из: Башкирия,Октябрьский
Пользователь №: 48 665
Модель телефона: i900
Прошивка: WM6.5.3
Ну кто скачал 79 отпишитесь? Вопрос будет ли работать mv на новой проше? Выключается ли эффект вибрации?
ApxuBatop
сообщение 22.12.2006, 7:02
Мото-Художник
Прошивка: от Е398
About 79r: CG1 is great, but the flex is not so. As for me, i prefer standart. Thats why i flashed my flex back. But the flashlight didn't work. What's the matter? I need to activate something in SEEMS? I'm sorry, if i repeat somebodies question...
Да все работает уже давно. Как устанавливать корелеты смотри Патч Отмены Подписей Корелетов + Полномочия Java Будут вопросы - обращайся.
go-blin
сообщение 22.12.2006, 7:21
Прошивка: WM6.5.3
Да как установить я знаю, я имел ввиду плагины, не надо будет переписывать, ведь на 46 не все плагины работали?
Fizmat-Ramzes
сообщение 22.12.2006, 7:34
Из: Майкоп Республика Адыгея
Пользователь №: 86 578
Прошивка: By Elektro255
На конец-то на 79R выпустил clap;applo , Elektro255-молодец, MegaRespect тебе, пока глюков не обнаружено, да кстати монстр построен по-моему на MPX-79, если я не ошибаюсь. Я ставил MPX-79, только видеокамера у меня, с большими глюками работала включил, а выключить не как, только акум дергать, а здесь все нормально!!!!
ЗЫ: кто-то спрашивал про эффект вибрации, да он выключается норм.
ksey
сообщение 22.12.2006, 7:50
Пользователь №: 90 539
Прошивка: elektro255_mod_v0.3
Шил и полного монстра,и CG1с CG3 на R373_49R_&_Art_FleX_6--при редактировании 5-6 записей справочника подряд-тело перегружается.Никто не сталкивался?
Chili89
сообщение 22.12.2006, 12:18
Из: Питер
Прошивка: 373 R48
Да,действительно поставил этот патч и все стало нормально
Спасибо!
Всегда пожалуйста :)
Сообщение отредактировал Bent - 23.12.2006, 3:27
Zagoralsanya
сообщение 22.12.2006, 13:37
Из: г. Омск
Прошивка: Other
Звук то как на 79? много хуже 49?
Fizmat-Ramzes
сообщение 22.12.2006, 15:07
Звук норм.Не каких тресков и прочих гадостей не наблюдаю. Эффект вибры отключается из меню.
ApxuBatop
сообщение 22.12.2006, 16:24
Мото-Художник
Прошивка: от Е398
Oh, i understood, how to enable flashlight on my flex! It needed to turn on
SEEM 0032_0001, Offset 37 h/55d, Bit 1 (Abs.Bit 441): SHORTCUT_SW_HW_VERSION_AVAILABLE
Tells if (*#9999#) is available
All, у кого были проблемы с фонариком на собственном флексе, включите вышеуказанный бит.
Ну и здесь не все работают... :( Надеюсь будет отдельная версия для 79R :)
volkenturbo
сообщение 22.12.2006, 23:25
Из: Брест,Белоруссия
Пользователь №: 97 378
Модель телефона: NOKIA E90
Возникли у меня две проблемы с модом ELEKTRO255 V3:Не могу регулировать громкость через Р2К ТооLS(не считывает,пишет везде ноль),и не могу поставить свою мелодию на включение\выключение(только на этом монстре,на других без проблем).Подскажите что-нибудь.....
Устное Предупреждение:Не создавай отдельных тем,спрашивай всё в этой теме
Сообщение отредактировал Bent - 23.12.2006, 3:43
Vanich777
сообщение 23.12.2006, 10:05
~motoman~
Из: г. Хабаровск
Пользователь №: 41 249
Модель телефона: E398 ===> E1
Прошивка: Elektro255 V0.4 a.3
Помогите, не работает MV на 79r, патч для отмены проверки подписи корелетов поставил, при загрузке вудает "фаил поврежден".
ApxuBatop
сообщение 23.12.2006, 10:51
Мото-Художник
Прошивка: от Е398
В jad пишешь точный размер jar файла, копируешь эти 2 файла на флешку и устанавливаешь с телефона.
Vanich777
сообщение 23.12.2006, 11:19
~motoman~
Из: г. Хабаровск
Спасибо, лови +! :)
ApxuBatop
сообщение 23.12.2006, 12:13
Мото-Художник
Прошивка: от Е398
Vanich777,
Кстати. У кого проблемы с правами явы на 79R - загляните сюда: Патч Отмены Подписей Корелетов + Полномочия Java (#588849)
Chili89
сообщение 23.12.2006, 15:21
Из: Питер
Прошивка: 373 R48
Заметил что,на R49 иногда при зорядки не гаснет подсведка,пока не поставиш блок клавы!
Текстовая версия Сейчас: 22.7.2025, 12:13
