23 страниц V « < 7 8 9 10 > »
Elektro255 V0.4 alpha 4 mod (4xR), 44R,46R,49R,79R
elektro255
сообщение 23.9.2006, 12:06 Закрепленное сообщение!
Из: Poland, Siedlce
Пользователь №: 53 130
09-04-2007
V0.4a4 Alpha: http://elektro255.ovh.org
08-04-2007
V0.4a3 Alpha: http://elektro255.ovh.org
07-04-2007
V0.4a2 44R Alpha: http://elektro255.ovh.org
20-12-2006
V0.3 79R Final mod: http://elektro255.ovh.org
27-11-2006
v0.3 for 49R Final mod http://elektro255.ovh.org/
26-11-2006
V0.3 46R Final mod: http://elektro255.ovh.org
НА Е1 Rokr с бутом 0А02 (оригинальный) НЕ ПОСТАВИТЕ БЕЗ Т.П.!
V0.4 alpha 4
Changes:
- Fixed problem with display timeout (fullscreen clock) when SMS/CALL received
Features:
- 4xR and 7xR MIX (use with 4xR flex)
- unlimited Video recording
- keypad automatic lock
- low battery alarm can be turned off or depend on ring style.
- Scheduled Ring Styles (ring style and funlight style can change automatically on given time and week day)
- flashlight shortcut (##)
- extra menu (shortcut *1 [shortcut is only for testing later will be changed])
- automatic menu enter, without sim card (emergency calls working too)
- new Java methods
- settings are stored on files
- no simlock checking
- Volume-bar sound can be turned off
- multiple menus (every skin can have one mma_ucp)
- Ported patches:
o SMS report significantly turned ON
o more folders in OBEX via BT
o removed unused folders from TransFlash
o Java have access to system files
o increased iTap user dictionary size
o no delete incall on SIM replace
o Bluetooth time changed to 3 minutes
o reordered camera store menu (store only is first)
o SMS alert is using default ringtone
OLD versions(V0.1-0.3):
Firmware changes:
- firmware based on 46R from StarterXP MP
- FULL SW access from Java
- LUMA&CHROMA tables moved to memory - now you can change JPEG compresion from Java
- StarterXP flex
- added dualboot
Flasher changes:
- if you have PDS_4013 flasher will no recreate this
Personalization tool changes:
- first version for 0.3_46R SW mod
- changing splash screen
- changing font (you can use *.fnt or *.smg CG4 files)
- you can turn on, turn off menu access without sim cart
- changing my shortcuts
Новая версия V0.4 alpha 4
Изменения:
- Устранена проблема с таймаутом дисплея(полноэкранные часы) при приеме смс/звонка
Новое:
- Прошивка создана как микс 4xR и 7xR (флекс 4xR ) В 44R она переименована для совместимости! Она близко не лежит к 44R на самом деле!
- Безлимитная запись видео (64мб макс как в 6х7х)
- Автоблок клавиатуры
- Звук разряженой батареи можно выключать или задать стилем оповещения(?).
- Расписание стилей оповещения (стиль оповещения и фанлайтмогут менятся автоматически по времени и дням недели)
- Фонарик по (##)
- Дополнительное меню (метка *1 [только для теста, после может изменится])
- Автоматический вход в меню без сим-карты (аварийные звонки работают)
- Новые методы в Яве (не от 79R, а новые)
- Настройки хранятся в файлах
- Не проверяется лоченость ПДС на симку (работает с лоченым пдс)
- Звук изменения громкости можно отключить
- Мультименю (каждый скин может иметь собственный мма_уцп)
- Портированы патчи:
o Оповещение о доставке SMS всегда вкл.
o больше папок доступно по OBEX из блютуза
o удалены неиспользуемые папки с флешки
o Полный доступ к системным файлам из явы
o увеличен размер пользовательского словаря iTap
o не удалыются последние вызовы при смене сим
o Время обнаружения блютуза - 3 минуты
o Меню сохранения видеозаписи (просто сохранить - первым пунктом)
o при приходе SMS играет "мелодия на смс", а не установленная на этого пользователя
Для версий 0.1-0.3
Изменения в прошивке:
- Создана на базе монстра StarterXP 46R
- Полный доступ к прошивке (симы, озу) из явы
- Таблицы сжатия фотографий перенесены в озу - теперь из явы можно управлять качеством фотографий (сжатием)
- флекс StarterXP
- добавлен дуалбут
Изменения флешера:
-Если ПДС версии 4013 (373 платформа), ПДС не пересоздается.
Изменения персонализации (Personalization tool):
- впервые для мода использована 46 прошивка
- замена заставки (на включение?)
- замена шрифта (лангпак, CG4)
- можно вкл. и выкл. доступ к меню без сим-карты
- изменен ярлык (копирайт?)
Для работы Personalization tool требуется положить в папку программы несжатый бинарный бэкап (32 мегабайта) под именем SW.bin
Прекращаем флудить, типа а когда выйдет новая версия, и.т.д.и.т.п, или придётся наказывать!
тему почистил, архив по 1 декабря тут:
Прикрепленный файл MotoFan_ru_electro.zip   ( 66.56 килобайт ) Кол-во скачиваний: 3902
Сообщение отредактировал elektro255 - 9.4.2007, 12:21
Trentemoller
сообщение 23.12.2006, 18:24
Из: Армавир
Пользователь №: 105 953
Прошивка: R373_G_0E.30.49R
Chili89,
У меня лично такое бывает через раз и еще когда телефон стоит в режиме ожидания самавольно включается подсветка дисплея и не гаснет, лечится также вкл/выкл блок. клавы!
Beaumont
сообщение 23.12.2006, 20:07
Миротворец
Из: г. Москва
Пользователь №: 39 110
Прошивка: R373_G_0E.30.79R
Так-с.
Насколько мне известно в прошивках от elektro255 есть такой глюк, при смене языка (быстрой), тело уходит в ребут: поскольку на двойное нажатие решетки стоит фонарь. Так вот, может попросить его сделать на фонарь двойное меню?
Спрашиваю это пока не у Самого :) , поскольку может я просто не знаю решения проблемы, а оно уже давно есть?
*A_L_E_X*
сообщение 23.12.2006, 20:53
Из: 26 Rus
Пользователь №: 87 412
Модель телефона: NOKIA 3250/5700
Народ как убрать автоматическую блокировку клавы??? blink.gif blink.gif blink.gif
На 79r
Vanich777
сообщение 23.12.2006, 23:42
~motoman~
Из: г. Хабаровск
Пользователь №: 41 249
Модель телефона: E398 ===> E1
Прошивка: Elektro255 V0.4 a.3
Люди , уменя видео и музыка не проигрываются на этой прошивке. Что делать?
Trentemoller
сообщение 23.12.2006, 23:48
Из: Армавир
*A_L_E_X*,
Отключить - SEEM 004A_0001 offset 0x91 bit 1
_26_
сообщение 24.12.2006, 10:11
Пользователь №: 90 123
Модель телефона: E 398
Прошивка: Electro255_mod_v_0.2
Так вроде в его проге можно было самому выбирать, каким нажатием включить фонарь. Но у меня и так в ребут не уходил при быстром нажатии.
Chili89
сообщение 24.12.2006, 11:46
Из: Питер
Пользователь №: 51 289
Прошивка: 373 R48
Цитата(Trentemoller @ Суббота, 23 Декабря 2006, 23:24)
Chili89,
Так у меня все так же!
Flan
сообщение 24.12.2006, 15:35
Из: Уфа
Пользователь №: 54 940
Прошивка: R373_G_0E.30.48 and Snake flex
У меня пропал режим авиа! как быть? <_<
HUNTER_ok
сообщение 24.12.2006, 15:48
Из: Заозерный webstream :D
Пользователь №: 106 065
Модель телефона: SE W810i
Flan, Покопайся через специальные проги в mma_ucp и mma_dcp файлах(это файлы меню), в них ты можешь добавить режим авиа.
BackgaMan
сообщение 24.12.2006, 16:01
Мотоумелец
Пользователь №: 61 651
Модель телефона: E-398 Htc-p3300
Попробуй занова прошей
ApxuBatop
сообщение 24.12.2006, 18:15
Мото-Художник
Пользователь №: 65 512
Модель телефона: iphone 5
Прошивка: от Е398
Поставь и вибро режиме с помощью п2кае уровень громкости клавы 1. Или нажми параметры -> назад.
Lindemann
сообщение 25.12.2006, 19:12
Из: Майкоп
Пользователь №: 84 149
Модель телефона: iphone 11
BackgaMan
сообщение 25.12.2006, 19:24
Мотоумелец
Цитата(Lindemann @ Понедельник, 25 Декабря 2006, 21:12)
А где 49r ?
В первом посте :)
_TRANE_
сообщение 25.12.2006, 19:31
MOTOmeloMAN
Из: New_Oskol_City(Бел.Область)
Пользователь №: 104 202
Модель телефона: E398+KOSS The PLUG
Прошивка: MPX 398 DeLuXe
народ,а если я на elektro255 vo.3b(49r,FULLFLASH) поставлю Flex от MPX398 то все вкусности от elektro255 останутся(Автоблок,Фонарик)?
А ещё вопрсик.А если прошьюсь ленгом со шрифтом MPX398 проша не слетит,я имею в виду шрифты будут нормально отображаться?
Не слетит.В некоторых скинах,нужно подправлять скин под 11 пунктов меню,делается всё это в Skins Manager v0.41.05A Хватит спрашивать всё подряд,прошивать можно всё,кроме CG1 и CG3
Сообщение отредактировал Bent - 27.12.2006, 6:11
__Sergey__
сообщение 25.12.2006, 20:31
Из: Орёл
Пользователь №: 40 953
Прошивка: 48R
_TRANE_, да.
go-blin
сообщение 26.12.2006, 6:07
Из: Башкирия,Октябрьский
Пользователь №: 48 665
Модель телефона: i900
Прошивка: WM6.5.3
ДА нет фонарик у меня не работает!(на 79г)
Народ выложите 004е ии 004а у кого работает фонарь плиз!
ApxuBatop
сообщение 26.12.2006, 15:06
Мото-Художник
Прошивка: от Е398
А 2 страницы назад слабо пролистать? <_< ( Elektro255 V0.3 Final Mod (#642634) )
hijacker
сообщение 26.12.2006, 20:49
Пользователь №: 59 345
Модель телефона: Motorola™ Е398
Прошивка: mpx 398
А где можна качнуть 79r а то на оффсайте нету...
Motorik
сообщение 27.12.2006, 3:23
Из: г. Ясный
Пользователь №: 15 670
Модель телефона: Мото G6
Пока только рефлеш отсюда
Kerill
сообщение 27.12.2006, 8:23
Из: г.Елабуга
Пользователь №: 62 756
Заметил такой глюк:
Недавно [милиция] пробивали телефоны, и обнаружили что при наборе *#06# телефон непоказывает [IMEI]
Посмотри тут Elektro255 V0.3 Final Mod (#647132) Если не подойдет - просим electro выложить новую версию IMEI_undo
P.S. Просьба не употреблять в этой теме сленг "мусора" "тел" "имей" и т.п., автор (Electro255) может его не понять либо понять не правильно.
Сообщение отредактировал Bent - 27.12.2006, 12:24
_Skyline_
сообщение 27.12.2006, 10:30
Из: Вологодская обл. г.Череповец
Пользователь №: 108 759
Модель телефона: E398=>E1
Прошивка: sky_edit
уменя какойто странный глюк , прошил я 79r и когда пытаюсь в мелодии войти то пишет подожите и так можэт целый день( вся мультимедиа не работает) , был русский язык после смены п.о. английский и не хочет в смену языка входить!!!
mutacipa
сообщение 27.12.2006, 10:37
Из: г. Мариуполь
Пользователь №: 93 127
Модель телефона: E1
Прошивка: Mpx398_DeLuxe
А как тогда на телефоне проверять IMEI? У меня 49 прошивка
Bent
сообщение 27.12.2006, 11:30
MoTo Marvellous
Пользователь №: 63 874
mutacipa,Я прикрепил патчи отката,что бы IMEI показывался,если не подходит-значит берёшь Personalize 49R и убираешь галочку с Enable(Menu Fast Acces shortcut) и прошиваешь,небудет быстрого меню когда нет симки,зато IMEI показывать будет.На худой конец пользуйся плагином в MV-Synerj там есть функция "Показать IMEI"
Качайте...
Сообщение отредактировал Bent - 27.12.2006, 12:26
Kerill
сообщение 27.12.2006, 12:14
Из: г.Елабуга
Патч который находится на этой ссылке некачается, пишет ошибка...
См. выше я выложил :)
Сообщение отредактировал Bent - 27.12.2006, 12:25
_Skyline_
сообщение 27.12.2006, 14:01
Прошивка: sky_edit
люди выложите пожайлуста ссылку на флекс для 79r , и на необходимые патчи на него.
mutacipa
сообщение 27.12.2006, 15:27
Из: г. Мариуполь
Модель телефона: E1
Bent, спасибо за патчи! Всё работает теперь :) Вот интересно, а зачем автор убрал стандартный код для проверки IMEI? Это было с чем то связано? Или просто?
Всегда пожалуйста :)
Сообщение отредактировал Bent - 28.12.2006, 3:06
Doktor Кот
сообщение 27.12.2006, 15:57
Из: Красноярск
Пользователь №: 94 751
Прошивка: Electro_R373...49R
Всем привет! Кто нибудь объясните пожалуйста, как прошивать это чудо от электро255! Этот бэкап нужно чтоль преобразовать в монстр через Flashbackup 2.63? Если да, то потом какой Flashbackup'ом нужно прошивать этого монстра: 2.63 или 3.0.058? Или можно этот бэкап из архива можно просто прошить Flasher'ом? И еще, всю ли прошу можно на телефон ставить, или какие-то CG ставить нельзя? Кто ответит, тому "+".
HUNTER_ok
сообщение 27.12.2006, 16:02
Doktor Кот, Шей рефлеш этой прошивке, поверх той, которая у тебя стоит. Остануться файлы, графическое оформление, и языковой пакет нетронутым.
mutacipa, Это сочетание клавиш заменяло *5(запуск телефона без симки)
mutacipa
сообщение 27.12.2006, 16:13
Из: г. Мариуполь
Модель телефона: E1
HUNTER_ok, ясно :)
Doktor Кот
сообщение 27.12.2006, 16:33
Из: Красноярск
Hunter'ok, то есть из этого бэкапа нужно сделать рефлеш через Flashbackup 2.63? (качать еще и рефлеш через мобилу я не хочу, дорого.). И какой программой его лучше прошить?
_Skyline_
сообщение 27.12.2006, 16:57
Прошивка: sky_edit
люди будет унас нормальный монстр на 79r? никак с ним совладать немогу!!!
mutacipa
сообщение 27.12.2006, 17:15
Из: г. Мариуполь
Модель телефона: E1
_Skyline_ хотелось бы тоже :) А то вот поставил я это рефлеш, так хорошо что беккап был :) Не входит ни в смс, не открывается камеры, ява тож не работает, не открывает мелодии и итюнс тоже(ставил патч, но он не работает и мне влом было разбираться). Думаю стоит монстра ждать
AlexKooper
сообщение 27.12.2006, 20:15
Из: Йошкар-Ола
Пользователь №: 47 140
Прошивка: AlexKooper mod v.47
_Skyline_, mutacipa, возьмите флекс с любого монстра на 79 прошивке и будет вам счастье. А рефлешь6х7х всегда с флексом 4х глючит.
mutacipa
сообщение 27.12.2006, 21:56
Из: г. Мариуполь
Модель телефона: E1
AlexKooper, спасибо за совет, но флекс не нужен уже - случайно нашёл и скачал весь монстр на 79r.
Кому надо вот ссылка http://www.e398mod.com/content/view/409/30/ там также и на 46r и на 49r лежат
Srg
сообщение 28.12.2006, 7:13
Пользователь №: 57 579
Модель телефона: Moto E398
Прошивка: R373_49R
v0.3 for 49R
Может кто-то тоже такое заметил...
После запуска и закрытия некоторых ява приложений (закономерности не обнаружил) пропадает дата. Появляется только после перезагрузки тела... blink.gif
Конечно, не очень напрягает, но может как-то это лечится?
Уважай русский язык.Устное предупреждение.
Сообщение отредактировал Bent - 4.1.2007, 16:37
_Skyline_
сообщение 28.12.2006, 9:38
Прошивка: sky_edit
AlexKooper, спасибо за совет сам до этого не додумался .
mutacipa, спасибо за ссылку.
а вот ещё спросить забыл как номер флекса для 79r что бы у нас тут его скачать??
всех с наступающим новым 2007 годом! хотьбы в следующем году нам компания моторола свинью не подложила....
Пиши по-русски.Устное предупреждение.
Сообщение отредактировал Bent - 4.1.2007, 16:40
mutacipa
сообщение 28.12.2006, 9:54
Из: г. Мариуполь
Модель телефона: E1
Вот вчера поставил прошивку 79, так вот нтересно почему нет перемотки видео? Говорили что как бы есть sad.gif
HUNTER_ok
сообщение 28.12.2006, 10:20
mutacipa, Это было на очень старой прошивки r373_12I_prebuild(step2), которую мы ставим при переходе на 373 платформу. А на 79r только неограниченная съёмка видео.
mutacipa
сообщение 28.12.2006, 17:16
Из: г. Мариуполь
Модель телефона: E1
Сейчас вот стоит у меня прошива 79r, так что-то не работает интернет(ни стандартный браузер, ни опера)... настройки автоматические, присланные оператором.... Пишет "сервер данных не доступен" sad.gif Опера вообще не конектится(настраивал так: создал настройку Java Session, ввёл туда apn и ip) и нифига sad.gif А всё остальное работает smile.gif
И ещё, после использонавия Synerj_tools_2.2(просто зашёл в приложение и вышел) телефон перезагружается sad.gif
HUNTER_ok
сообщение 29.12.2006, 6:54
mutacipa, У меня просто выход командой перезагрузки выполняется.
На 49R она просто выключает приложение, а на 79R(видимо electro255 всё сделал) она ребутит телефон.
(Выходи из мидлета на красную кнопку, исправлю этот глюк в следующей версии)
Текстовая версия Сейчас: 22.7.2025, 6:02
