23 страниц V « < 7 8 9 10 > »
Elektro255 V0.4 alpha 4 mod (4xR), 44R,46R,49R,79R
elektro255
сообщение 23.9.2006, 12:06 Закрепленное сообщение!
Из: Poland, Siedlce
Пользователь №: 53 130
09-04-2007
V0.4a4 Alpha: http://elektro255.ovh.org
08-04-2007
V0.4a3 Alpha: http://elektro255.ovh.org
07-04-2007
V0.4a2 44R Alpha: http://elektro255.ovh.org
20-12-2006
V0.3 79R Final mod: http://elektro255.ovh.org
27-11-2006
v0.3 for 49R Final mod http://elektro255.ovh.org/
26-11-2006
V0.3 46R Final mod: http://elektro255.ovh.org
НА Е1 Rokr с бутом 0А02 (оригинальный) НЕ ПОСТАВИТЕ БЕЗ Т.П.!
V0.4 alpha 4
Changes:
- Fixed problem with display timeout (fullscreen clock) when SMS/CALL received
Features:
- 4xR and 7xR MIX (use with 4xR flex)
- unlimited Video recording
- keypad automatic lock
- low battery alarm can be turned off or depend on ring style.
- Scheduled Ring Styles (ring style and funlight style can change automatically on given time and week day)
- flashlight shortcut (##)
- extra menu (shortcut *1 [shortcut is only for testing later will be changed])
- automatic menu enter, without sim card (emergency calls working too)
- new Java methods
- settings are stored on files
- no simlock checking
- Volume-bar sound can be turned off
- multiple menus (every skin can have one mma_ucp)
- Ported patches:
o SMS report significantly turned ON
o more folders in OBEX via BT
o removed unused folders from TransFlash
o Java have access to system files
o increased iTap user dictionary size
o no delete incall on SIM replace
o Bluetooth time changed to 3 minutes
o reordered camera store menu (store only is first)
o SMS alert is using default ringtone
OLD versions(V0.1-0.3):
Firmware changes:
- firmware based on 46R from StarterXP MP
- FULL SW access from Java
- LUMA&CHROMA tables moved to memory - now you can change JPEG compresion from Java
- StarterXP flex
- added dualboot
Flasher changes:
- if you have PDS_4013 flasher will no recreate this
Personalization tool changes:
- first version for 0.3_46R SW mod
- changing splash screen
- changing font (you can use *.fnt or *.smg CG4 files)
- you can turn on, turn off menu access without sim cart
- changing my shortcuts
Новая версия V0.4 alpha 4
Изменения:
- Устранена проблема с таймаутом дисплея(полноэкранные часы) при приеме смс/звонка
Новое:
- Прошивка создана как микс 4xR и 7xR (флекс 4xR ) В 44R она переименована для совместимости! Она близко не лежит к 44R на самом деле!
- Безлимитная запись видео (64мб макс как в 6х7х)
- Автоблок клавиатуры
- Звук разряженой батареи можно выключать или задать стилем оповещения(?).
- Расписание стилей оповещения (стиль оповещения и фанлайтмогут менятся автоматически по времени и дням недели)
- Фонарик по (##)
- Дополнительное меню (метка *1 [только для теста, после может изменится])
- Автоматический вход в меню без сим-карты (аварийные звонки работают)
- Новые методы в Яве (не от 79R, а новые)
- Настройки хранятся в файлах
- Не проверяется лоченость ПДС на симку (работает с лоченым пдс)
- Звук изменения громкости можно отключить
- Мультименю (каждый скин может иметь собственный мма_уцп)
- Портированы патчи:
o Оповещение о доставке SMS всегда вкл.
o больше папок доступно по OBEX из блютуза
o удалены неиспользуемые папки с флешки
o Полный доступ к системным файлам из явы
o увеличен размер пользовательского словаря iTap
o не удалыются последние вызовы при смене сим
o Время обнаружения блютуза - 3 минуты
o Меню сохранения видеозаписи (просто сохранить - первым пунктом)
o при приходе SMS играет "мелодия на смс", а не установленная на этого пользователя
Для версий 0.1-0.3
Изменения в прошивке:
- Создана на базе монстра StarterXP 46R
- Полный доступ к прошивке (симы, озу) из явы
- Таблицы сжатия фотографий перенесены в озу - теперь из явы можно управлять качеством фотографий (сжатием)
- флекс StarterXP
- добавлен дуалбут
Изменения флешера:
-Если ПДС версии 4013 (373 платформа), ПДС не пересоздается.
Изменения персонализации (Personalization tool):
- впервые для мода использована 46 прошивка
- замена заставки (на включение?)
- замена шрифта (лангпак, CG4)
- можно вкл. и выкл. доступ к меню без сим-карты
- изменен ярлык (копирайт?)
Для работы Personalization tool требуется положить в папку программы несжатый бинарный бэкап (32 мегабайта) под именем SW.bin
Прекращаем флудить, типа а когда выйдет новая версия, и.т.д.и.т.п, или придётся наказывать!
тему почистил, архив по 1 декабря тут:
Прикрепленный файл MotoFan_ru_electro.zip   ( 66.56 килобайт ) Кол-во скачиваний: 3902
Сообщение отредактировал elektro255 - 9.4.2007, 12:21
_Skyline_
сообщение 27.12.2006, 10:30
Из: Вологодская обл. г.Череповец
Пользователь №: 108 759
Модель телефона: E398=>E1
Прошивка: sky_edit
уменя какойто странный глюк , прошил я 79r и когда пытаюсь в мелодии войти то пишет подожите и так можэт целый день( вся мультимедиа не работает) , был русский язык после смены п.о. английский и не хочет в смену языка входить!!!
mutacipa
сообщение 27.12.2006, 10:37
Из: г. Мариуполь
Пользователь №: 93 127
Модель телефона: E1
Прошивка: Mpx398_DeLuxe
А как тогда на телефоне проверять IMEI? У меня 49 прошивка
Bent
сообщение 27.12.2006, 11:30
MoTo Marvellous
Пользователь №: 63 874
mutacipa,Я прикрепил патчи отката,что бы IMEI показывался,если не подходит-значит берёшь Personalize 49R и убираешь галочку с Enable(Menu Fast Acces shortcut) и прошиваешь,небудет быстрого меню когда нет симки,зато IMEI показывать будет.На худой конец пользуйся плагином в MV-Synerj там есть функция "Показать IMEI"
Качайте...
Сообщение отредактировал Bent - 27.12.2006, 12:26
Kerill
сообщение 27.12.2006, 12:14
Из: г.Елабуга
Пользователь №: 62 756
Патч который находится на этой ссылке некачается, пишет ошибка...
См. выше я выложил :)
Сообщение отредактировал Bent - 27.12.2006, 12:25
_Skyline_
сообщение 27.12.2006, 14:01
Прошивка: sky_edit
люди выложите пожайлуста ссылку на флекс для 79r , и на необходимые патчи на него.
mutacipa
сообщение 27.12.2006, 15:27
Из: г. Мариуполь
Модель телефона: E1
Bent, спасибо за патчи! Всё работает теперь :) Вот интересно, а зачем автор убрал стандартный код для проверки IMEI? Это было с чем то связано? Или просто?
Всегда пожалуйста :)
Сообщение отредактировал Bent - 28.12.2006, 3:06
Doktor Кот
сообщение 27.12.2006, 15:57
Из: Красноярск
Пользователь №: 94 751
Прошивка: Electro_R373...49R
Всем привет! Кто нибудь объясните пожалуйста, как прошивать это чудо от электро255! Этот бэкап нужно чтоль преобразовать в монстр через Flashbackup 2.63? Если да, то потом какой Flashbackup'ом нужно прошивать этого монстра: 2.63 или 3.0.058? Или можно этот бэкап из архива можно просто прошить Flasher'ом? И еще, всю ли прошу можно на телефон ставить, или какие-то CG ставить нельзя? Кто ответит, тому "+".
HUNTER_ok
сообщение 27.12.2006, 16:02
Из: Заозерный webstream :D
Пользователь №: 106 065
Модель телефона: SE W810i
Doktor Кот, Шей рефлеш этой прошивке, поверх той, которая у тебя стоит. Остануться файлы, графическое оформление, и языковой пакет нетронутым.
mutacipa, Это сочетание клавиш заменяло *5(запуск телефона без симки)
mutacipa
сообщение 27.12.2006, 16:13
Из: г. Мариуполь
Модель телефона: E1
HUNTER_ok, ясно :)
Doktor Кот
сообщение 27.12.2006, 16:33
Из: Красноярск
Hunter'ok, то есть из этого бэкапа нужно сделать рефлеш через Flashbackup 2.63? (качать еще и рефлеш через мобилу я не хочу, дорого.). И какой программой его лучше прошить?
_Skyline_
сообщение 27.12.2006, 16:57
Прошивка: sky_edit
люди будет унас нормальный монстр на 79r? никак с ним совладать немогу!!!
mutacipa
сообщение 27.12.2006, 17:15
Из: г. Мариуполь
Модель телефона: E1
_Skyline_ хотелось бы тоже :) А то вот поставил я это рефлеш, так хорошо что беккап был :) Не входит ни в смс, не открывается камеры, ява тож не работает, не открывает мелодии и итюнс тоже(ставил патч, но он не работает и мне влом было разбираться). Думаю стоит монстра ждать
AlexKooper
сообщение 27.12.2006, 20:15
Из: Йошкар-Ола
Пользователь №: 47 140
Прошивка: AlexKooper mod v.47
_Skyline_, mutacipa, возьмите флекс с любого монстра на 79 прошивке и будет вам счастье. А рефлешь6х7х всегда с флексом 4х глючит.
mutacipa
сообщение 27.12.2006, 21:56
Из: г. Мариуполь
Модель телефона: E1
AlexKooper, спасибо за совет, но флекс не нужен уже - случайно нашёл и скачал весь монстр на 79r.
Кому надо вот ссылка http://www.e398mod.com/content/view/409/30/ там также и на 46r и на 49r лежат
Srg
сообщение 28.12.2006, 7:13
Пользователь №: 57 579
Модель телефона: Moto E398
Прошивка: R373_49R
v0.3 for 49R
Может кто-то тоже такое заметил...
После запуска и закрытия некоторых ява приложений (закономерности не обнаружил) пропадает дата. Появляется только после перезагрузки тела... blink.gif
Конечно, не очень напрягает, но может как-то это лечится?
Уважай русский язык.Устное предупреждение.
Сообщение отредактировал Bent - 4.1.2007, 16:37
_Skyline_
сообщение 28.12.2006, 9:38
Прошивка: sky_edit
AlexKooper, спасибо за совет сам до этого не додумался .
mutacipa, спасибо за ссылку.
а вот ещё спросить забыл как номер флекса для 79r что бы у нас тут его скачать??
всех с наступающим новым 2007 годом! хотьбы в следующем году нам компания моторола свинью не подложила....
Пиши по-русски.Устное предупреждение.
Сообщение отредактировал Bent - 4.1.2007, 16:40
mutacipa
сообщение 28.12.2006, 9:54
Из: г. Мариуполь
Модель телефона: E1
Вот вчера поставил прошивку 79, так вот нтересно почему нет перемотки видео? Говорили что как бы есть sad.gif
HUNTER_ok
сообщение 28.12.2006, 10:20
mutacipa, Это было на очень старой прошивки r373_12I_prebuild(step2), которую мы ставим при переходе на 373 платформу. А на 79r только неограниченная съёмка видео.
mutacipa
сообщение 28.12.2006, 17:16
Из: г. Мариуполь
Модель телефона: E1
Сейчас вот стоит у меня прошива 79r, так что-то не работает интернет(ни стандартный браузер, ни опера)... настройки автоматические, присланные оператором.... Пишет "сервер данных не доступен" sad.gif Опера вообще не конектится(настраивал так: создал настройку Java Session, ввёл туда apn и ip) и нифига sad.gif А всё остальное работает smile.gif
И ещё, после использонавия Synerj_tools_2.2(просто зашёл в приложение и вышел) телефон перезагружается sad.gif
HUNTER_ok
сообщение 29.12.2006, 6:54
mutacipa, У меня просто выход командой перезагрузки выполняется.
На 49R она просто выключает приложение, а на 79R(видимо electro255 всё сделал) она ребутит телефон.
(Выходи из мидлета на красную кнопку, исправлю этот глюк в следующей версии)
_Skyline_
сообщение 29.12.2006, 8:15
Прошивка: sky_edit
mutacipa, у тебя какой лэнг?? просто ни один яз.пакет на ней не хочет работать кроме того что стоял изночально в монстре elektro255_mod_v0.2_49R. да я разочаровался в этом монстре глюк на глюке!!
1.- при смене шрифта через Personalize на входе в папки виснет и все надписи пропадают или все в каких-то каракулях.
снял видео 12 секунд сохранял минут 5...
эта прошивка перспективна только после доработок......
HUNTER_ok
сообщение 29.12.2006, 8:32
_Skyline_, Там картинка шрифта только для просмотра.
А шрифт менять: скачивать любой ленг под 49R(79R) прошивку с изменённым шрифтом и прошивай.
_Skyline_
сообщение 29.12.2006, 8:41
Прошивка: sky_edit
HUNTER_ok,все шрифты перекачал !!! текст исчезает......... лэнг поменять нереально!!!
о да забыл сказать флэшер довёл моего мотора до ТП, сейчас сижу и фигнёй маюсь с ним разобранным.. smile.gif
Сообщение отредактировал Bent - 4.1.2007, 16:43
HUNTER_ok
сообщение 29.12.2006, 12:03
Поставил себе 79R mod.
Нашел кучу глюков.
Ставиться это проша корректно только поверх монстра на базе 79r.
Фонарик у меня так и не получилось включить.
Да и вообще вы ставите эту прошивку только ради бесконечного видео?
ApxuBatop
сообщение 29.12.2006, 13:05
Мото-Художник
Пользователь №: 65 512
Модель телефона: iphone 5
Прошивка: от Е398
Я еще ради звука ставлю... родного... Ну еще ради скорости; возможной работы камеры, папок аудио/картинки/видео и Itunes (на многих прошах все повисает в этот момент)...
SEEM 0032_0001, Offset 37 h/55d, Bit 1 (Abs.Bit 441): SHORTCUT_SW_HW_VERSION_AVAILABLE
Tells if (*#9999#) is available
mutacipa
сообщение 29.12.2006, 14:23
Из: г. Мариуполь
Модель телефона: E1
_Skyline_,
ленг стоит от New_Standart_By_Alex72, ДРМ от 42 стандартного 42r... После того как громкость клавы поставил на ноль, то страшно начал глючить телефон( не выключалась и висла камера, плейеры глючили.... стал хуже звук...
А на счёт жпрс не могу понять.... Внезапно заработал smile.gif (причём это не неполадки были оператора).... Вдруг бац и заработал smile.gif
HUNTER_ok
сообщение 29.12.2006, 15:41
mutacipa, Не мучайся, откатывайся на 49R. На неё и больше патчей и она стабильнее, тем более я прогу только под неё пишу. Думаю подождите пока electro255 устранит баги или выпустит новую версию, тогда ещё раз попробуешь.
Doktor Кот
сообщение 29.12.2006, 16:10
Из: Красноярск
Люди, у меня проблема! Когда я принимаю файлы по блютуз, телефон в ребут выходит! В чем может быть проблема? Я правда еще поставил 3 патча: блок на двойное нажатие меню, передача 26 расширений через картинки и полный доступ к файловой системе телефона из ява. Помогите, кто знает! И еще один глюк: когда в МВ сохраняешь плейлист на английском, телефон опять в ребут уходит! В чем проблема? У меня стоит v0.3 R373...49R Final.
Сообщение отредактировал Doktor Кот - 29.12.2006, 16:55
mutacipa
сообщение 29.12.2006, 16:29
Из: г. Мариуполь
Модель телефона: E1
HUNTER_ok,
да ладно, ещё поиграюсь.... smile.gif Но если ещё один глюк, то сразу на 49r evil_2.gif
HUNTER_ok
сообщение 29.12.2006, 16:49
Doktor Кот, Ты на electro255 mod 46R? А то возможно, тот кто портировал патчи ошибся, и поэтому у тебя глюк. У себя ничего подобного не наблюдал.
Doktor Кот
сообщение 29.12.2006, 17:00
Из: Красноярск
Humter'ok, у меня 49R. А патчи взял от монстра на базе этой проши от Алекса75. Еще глюк в МВ нашел (см. выше). В чем может быть проблема?
ApxuBatop
сообщение 29.12.2006, 17:15
Мото-Художник
Прошивка: от Е398
79R fullflash mirror: http://rapidshare.com/files/9419353/elektr....3_79R.rar.html
Doktor Кот
сообщение 29.12.2006, 17:37
Из: Красноярск
=) Проша только 2 часа стоит, а уже столько багов нашел! Еще я обнаружил, что когда сообщение сохраняешь в черновик, от него остаются только знаки препинания! Попробую патчи откатить. Если не поможет, то уже не знаю что делать =(
Torm Ozz
сообщение 29.12.2006, 18:20
Из: Липецк
Пользователь №: 101 540
Модель телефона: E398-E1,V360,V3x,L9
Прошивка: 79R,ACR,E6P,04R
Нет никаких глюков! Ставил рефлешь elektro255_mod_v0.3_79R на патченную 79R с флексом от MotoSymbian 1.4 на 70R. Фонарик работает, автоблокировка работает, плагины MediaViewer с мода на 49R работают и Sinergy 2.2 тоже работает (во всяком случае бекапит и восстанавливает без проблем). Все включается и отключается как и положено, в общем за неделю пользования никаких отказов. Просто на 79R приложения с полным доступом и корелеты надо ставить не так как на другие прошивки, об этом писалось неоднократно. И рефлеши от 6BR-79R не работают с флексами от 4xR, на сороковые надо ставить полного монстра!
mutacipa
сообщение 29.12.2006, 20:43
Из: г. Мариуполь
Модель телефона: E1
Всё, откатился я на заводскую 49r... Надоело мне эта байда 79 mad.gif Что то мне кажется что накрылся бутлоадер....
Пиши по-русски не коверкай язык.Устное Предупреждение.
Сообщение отредактировал Bent - 4.1.2007, 16:46
BackgaMan
сообщение 29.12.2006, 20:58
Мотоумелец
Пользователь №: 61 651
Модель телефона: E-398 Htc-p3300
Цитата(mutacipa @ Пятница, 29 Декабря 2006, 22:43)
Всё, откатился я на заводскую 49r... Надоело мне эта байда 79  Чёт мне кажется что накрылся бутлоадер....
Качай бутлоадер и прошей ПСТ и будет тебе бутлоадер, такое бывает и монстр здесь не причём!
Прикрепленный файл Boot_Loader.rar   ( 42.12 килобайт ) Кол-во скачиваний: 81
mutacipa
сообщение 29.12.2006, 21:03
Из: г. Мариуполь
Модель телефона: E1
BackgaMan,
а бутлоадер 07.D0 можно без ТП шить?
Doktor Кот
сообщение 30.12.2006, 3:15
Из: Красноярск
Люди, ПОМОГИТЕ! Я востановил бэкап без всяких патчей, но проблемы остались! Единственно решил проблему с смс, уникод в П2КТулс надо поставить. С МВ тоже решил проблему. Но с блютуз я никак не могу разобраться. Опять телефон выходит в ребут, когда ПРИНИМАЮ файлы по блютуз. Может надо тоже что-нибудь в симах активировать? И еще у меня ИнстантМессенгер не хочет никуда подключатся! Помогите ПОЖАЛУЙСТА! Поставлю ПЛЮСЫ за действительно ПОМОГАЮЩУЮ помощь =)
Сообщение отредактировал Doktor Кот - 30.12.2006, 7:09
dsedelnikov
сообщение 30.12.2006, 8:03
Пользователь №: 70 385
Прошивка: elektro255_v0.2_49R
Вопрос.
Рефлеш electro255 49r V2.0. Выставляю 2 будильника. Первый – выключен, второй – включен. Выключаю телефон. Когда наступает время срабатывания первого будильника зажигается экран, подсветка клавиш, но сам будильник не звенит. Все это продолжает гореть, пока не передернешь батарею. Второй будильник при этом срабатывает. Если установлен один будильник – все работает как надо.
Никто не знает, где и что можно подправить?
Будильник по умолчанию работает на выключеном теле, база мелодий работает нормально. На обоих будильниках одна и та же мелодия.
HUNTER_ok
сообщение 30.12.2006, 9:09
Doktor Кот, Мой тебе совет:
1. Если ты залил бутлоадер 07.D0, то ты можешь шить любой монстр для 398.
2. Прошил бы какой нибудь монстр на 49R прошиве(например:Mpx398).
3. Поставил поверх него рефлеш 49R mod.
4. Поставишь патчи и всё будет норм.
А эти проблемы у тебя видимо из-за PDS(наверное ты что-то некоректно сделал при ТП),
верни назад и попробуй ещё раз сделать ТП.
Текстовая версия Сейчас: 29.7.2025, 4:48
