23 страниц V « < 8 9 10 11 > »
Elektro255 V0.4 alpha 4 mod (4xR), 44R,46R,49R,79R
elektro255
сообщение 23.9.2006, 12:06 Закрепленное сообщение!
Из: Poland, Siedlce
Пользователь №: 53 130
09-04-2007
V0.4a4 Alpha: http://elektro255.ovh.org
08-04-2007
V0.4a3 Alpha: http://elektro255.ovh.org
07-04-2007
V0.4a2 44R Alpha: http://elektro255.ovh.org
20-12-2006
V0.3 79R Final mod: http://elektro255.ovh.org
27-11-2006
v0.3 for 49R Final mod http://elektro255.ovh.org/
26-11-2006
V0.3 46R Final mod: http://elektro255.ovh.org
НА Е1 Rokr с бутом 0А02 (оригинальный) НЕ ПОСТАВИТЕ БЕЗ Т.П.!
V0.4 alpha 4
Changes:
- Fixed problem with display timeout (fullscreen clock) when SMS/CALL received
Features:
- 4xR and 7xR MIX (use with 4xR flex)
- unlimited Video recording
- keypad automatic lock
- low battery alarm can be turned off or depend on ring style.
- Scheduled Ring Styles (ring style and funlight style can change automatically on given time and week day)
- flashlight shortcut (##)
- extra menu (shortcut *1 [shortcut is only for testing later will be changed])
- automatic menu enter, without sim card (emergency calls working too)
- new Java methods
- settings are stored on files
- no simlock checking
- Volume-bar sound can be turned off
- multiple menus (every skin can have one mma_ucp)
- Ported patches:
o SMS report significantly turned ON
o more folders in OBEX via BT
o removed unused folders from TransFlash
o Java have access to system files
o increased iTap user dictionary size
o no delete incall on SIM replace
o Bluetooth time changed to 3 minutes
o reordered camera store menu (store only is first)
o SMS alert is using default ringtone
OLD versions(V0.1-0.3):
Firmware changes:
- firmware based on 46R from StarterXP MP
- FULL SW access from Java
- LUMA&CHROMA tables moved to memory - now you can change JPEG compresion from Java
- StarterXP flex
- added dualboot
Flasher changes:
- if you have PDS_4013 flasher will no recreate this
Personalization tool changes:
- first version for 0.3_46R SW mod
- changing splash screen
- changing font (you can use *.fnt or *.smg CG4 files)
- you can turn on, turn off menu access without sim cart
- changing my shortcuts
Новая версия V0.4 alpha 4
Изменения:
- Устранена проблема с таймаутом дисплея(полноэкранные часы) при приеме смс/звонка
Новое:
- Прошивка создана как микс 4xR и 7xR (флекс 4xR ) В 44R она переименована для совместимости! Она близко не лежит к 44R на самом деле!
- Безлимитная запись видео (64мб макс как в 6х7х)
- Автоблок клавиатуры
- Звук разряженой батареи можно выключать или задать стилем оповещения(?).
- Расписание стилей оповещения (стиль оповещения и фанлайтмогут менятся автоматически по времени и дням недели)
- Фонарик по (##)
- Дополнительное меню (метка *1 [только для теста, после может изменится])
- Автоматический вход в меню без сим-карты (аварийные звонки работают)
- Новые методы в Яве (не от 79R, а новые)
- Настройки хранятся в файлах
- Не проверяется лоченость ПДС на симку (работает с лоченым пдс)
- Звук изменения громкости можно отключить
- Мультименю (каждый скин может иметь собственный мма_уцп)
- Портированы патчи:
o Оповещение о доставке SMS всегда вкл.
o больше папок доступно по OBEX из блютуза
o удалены неиспользуемые папки с флешки
o Полный доступ к системным файлам из явы
o увеличен размер пользовательского словаря iTap
o не удалыются последние вызовы при смене сим
o Время обнаружения блютуза - 3 минуты
o Меню сохранения видеозаписи (просто сохранить - первым пунктом)
o при приходе SMS играет "мелодия на смс", а не установленная на этого пользователя
Для версий 0.1-0.3
Изменения в прошивке:
- Создана на базе монстра StarterXP 46R
- Полный доступ к прошивке (симы, озу) из явы
- Таблицы сжатия фотографий перенесены в озу - теперь из явы можно управлять качеством фотографий (сжатием)
- флекс StarterXP
- добавлен дуалбут
Изменения флешера:
-Если ПДС версии 4013 (373 платформа), ПДС не пересоздается.
Изменения персонализации (Personalization tool):
- впервые для мода использована 46 прошивка
- замена заставки (на включение?)
- замена шрифта (лангпак, CG4)
- можно вкл. и выкл. доступ к меню без сим-карты
- изменен ярлык (копирайт?)
Для работы Personalization tool требуется положить в папку программы несжатый бинарный бэкап (32 мегабайта) под именем SW.bin
Прекращаем флудить, типа а когда выйдет новая версия, и.т.д.и.т.п, или придётся наказывать!
тему почистил, архив по 1 декабря тут:
Прикрепленный файл MotoFan_ru_electro.zip   ( 66.56 килобайт ) Кол-во скачиваний: 3902
Сообщение отредактировал elektro255 - 9.4.2007, 12:21
_Skyline_
сообщение 29.12.2006, 8:15
Из: Вологодская обл. г.Череповец
Пользователь №: 108 759
Модель телефона: E398=>E1
Прошивка: sky_edit
mutacipa, у тебя какой лэнг?? просто ни один яз.пакет на ней не хочет работать кроме того что стоял изночально в монстре elektro255_mod_v0.2_49R. да я разочаровался в этом монстре глюк на глюке!!
1.- при смене шрифта через Personalize на входе в папки виснет и все надписи пропадают или все в каких-то каракулях.
снял видео 12 секунд сохранял минут 5...
эта прошивка перспективна только после доработок......
HUNTER_ok
сообщение 29.12.2006, 8:32
Из: Заозерный webstream :D
Пользователь №: 106 065
Модель телефона: SE W810i
_Skyline_, Там картинка шрифта только для просмотра.
А шрифт менять: скачивать любой ленг под 49R(79R) прошивку с изменённым шрифтом и прошивай.
_Skyline_
сообщение 29.12.2006, 8:41
Прошивка: sky_edit
HUNTER_ok,все шрифты перекачал !!! текст исчезает......... лэнг поменять нереально!!!
о да забыл сказать флэшер довёл моего мотора до ТП, сейчас сижу и фигнёй маюсь с ним разобранным.. smile.gif
Сообщение отредактировал Bent - 4.1.2007, 16:43
HUNTER_ok
сообщение 29.12.2006, 12:03
Поставил себе 79R mod.
Нашел кучу глюков.
Ставиться это проша корректно только поверх монстра на базе 79r.
Фонарик у меня так и не получилось включить.
Да и вообще вы ставите эту прошивку только ради бесконечного видео?
ApxuBatop
сообщение 29.12.2006, 13:05
Мото-Художник
Пользователь №: 65 512
Модель телефона: iphone 5
Прошивка: от Е398
Я еще ради звука ставлю... родного... Ну еще ради скорости; возможной работы камеры, папок аудио/картинки/видео и Itunes (на многих прошах все повисает в этот момент)...
SEEM 0032_0001, Offset 37 h/55d, Bit 1 (Abs.Bit 441): SHORTCUT_SW_HW_VERSION_AVAILABLE
Tells if (*#9999#) is available
mutacipa
сообщение 29.12.2006, 14:23
Из: г. Мариуполь
Пользователь №: 93 127
Модель телефона: E1
Прошивка: Mpx398_DeLuxe
_Skyline_,
ленг стоит от New_Standart_By_Alex72, ДРМ от 42 стандартного 42r... После того как громкость клавы поставил на ноль, то страшно начал глючить телефон( не выключалась и висла камера, плейеры глючили.... стал хуже звук...
А на счёт жпрс не могу понять.... Внезапно заработал smile.gif (причём это не неполадки были оператора).... Вдруг бац и заработал smile.gif
HUNTER_ok
сообщение 29.12.2006, 15:41
mutacipa, Не мучайся, откатывайся на 49R. На неё и больше патчей и она стабильнее, тем более я прогу только под неё пишу. Думаю подождите пока electro255 устранит баги или выпустит новую версию, тогда ещё раз попробуешь.
Doktor Кот
сообщение 29.12.2006, 16:10
Из: Красноярск
Пользователь №: 94 751
Прошивка: Electro_R373...49R
Люди, у меня проблема! Когда я принимаю файлы по блютуз, телефон в ребут выходит! В чем может быть проблема? Я правда еще поставил 3 патча: блок на двойное нажатие меню, передача 26 расширений через картинки и полный доступ к файловой системе телефона из ява. Помогите, кто знает! И еще один глюк: когда в МВ сохраняешь плейлист на английском, телефон опять в ребут уходит! В чем проблема? У меня стоит v0.3 R373...49R Final.
Сообщение отредактировал Doktor Кот - 29.12.2006, 16:55
mutacipa
сообщение 29.12.2006, 16:29
Из: г. Мариуполь
Модель телефона: E1
HUNTER_ok,
да ладно, ещё поиграюсь.... smile.gif Но если ещё один глюк, то сразу на 49r evil_2.gif
HUNTER_ok
сообщение 29.12.2006, 16:49
Doktor Кот, Ты на electro255 mod 46R? А то возможно, тот кто портировал патчи ошибся, и поэтому у тебя глюк. У себя ничего подобного не наблюдал.
Doktor Кот
сообщение 29.12.2006, 17:00
Из: Красноярск
Humter'ok, у меня 49R. А патчи взял от монстра на базе этой проши от Алекса75. Еще глюк в МВ нашел (см. выше). В чем может быть проблема?
ApxuBatop
сообщение 29.12.2006, 17:15
Мото-Художник
Прошивка: от Е398
79R fullflash mirror: http://rapidshare.com/files/9419353/elektr....3_79R.rar.html
Doktor Кот
сообщение 29.12.2006, 17:37
Из: Красноярск
=) Проша только 2 часа стоит, а уже столько багов нашел! Еще я обнаружил, что когда сообщение сохраняешь в черновик, от него остаются только знаки препинания! Попробую патчи откатить. Если не поможет, то уже не знаю что делать =(
Torm Ozz
сообщение 29.12.2006, 18:20
Из: Липецк
Пользователь №: 101 540
Модель телефона: E398-E1,V360,V3x,L9
Прошивка: 79R,ACR,E6P,04R
Нет никаких глюков! Ставил рефлешь elektro255_mod_v0.3_79R на патченную 79R с флексом от MotoSymbian 1.4 на 70R. Фонарик работает, автоблокировка работает, плагины MediaViewer с мода на 49R работают и Sinergy 2.2 тоже работает (во всяком случае бекапит и восстанавливает без проблем). Все включается и отключается как и положено, в общем за неделю пользования никаких отказов. Просто на 79R приложения с полным доступом и корелеты надо ставить не так как на другие прошивки, об этом писалось неоднократно. И рефлеши от 6BR-79R не работают с флексами от 4xR, на сороковые надо ставить полного монстра!
mutacipa
сообщение 29.12.2006, 20:43
Из: г. Мариуполь
Модель телефона: E1
Всё, откатился я на заводскую 49r... Надоело мне эта байда 79 mad.gif Что то мне кажется что накрылся бутлоадер....
Пиши по-русски не коверкай язык.Устное Предупреждение.
Сообщение отредактировал Bent - 4.1.2007, 16:46
BackgaMan
сообщение 29.12.2006, 20:58
Мотоумелец
Пользователь №: 61 651
Модель телефона: E-398 Htc-p3300
Цитата(mutacipa @ Пятница, 29 Декабря 2006, 22:43)
Всё, откатился я на заводскую 49r... Надоело мне эта байда 79  Чёт мне кажется что накрылся бутлоадер....
Качай бутлоадер и прошей ПСТ и будет тебе бутлоадер, такое бывает и монстр здесь не причём!
Прикрепленный файл Boot_Loader.rar   ( 42.12 килобайт ) Кол-во скачиваний: 81
mutacipa
сообщение 29.12.2006, 21:03
Из: г. Мариуполь
Модель телефона: E1
BackgaMan,
а бутлоадер 07.D0 можно без ТП шить?
Doktor Кот
сообщение 30.12.2006, 3:15
Из: Красноярск
Люди, ПОМОГИТЕ! Я востановил бэкап без всяких патчей, но проблемы остались! Единственно решил проблему с смс, уникод в П2КТулс надо поставить. С МВ тоже решил проблему. Но с блютуз я никак не могу разобраться. Опять телефон выходит в ребут, когда ПРИНИМАЮ файлы по блютуз. Может надо тоже что-нибудь в симах активировать? И еще у меня ИнстантМессенгер не хочет никуда подключатся! Помогите ПОЖАЛУЙСТА! Поставлю ПЛЮСЫ за действительно ПОМОГАЮЩУЮ помощь =)
Сообщение отредактировал Doktor Кот - 30.12.2006, 7:09
dsedelnikov
сообщение 30.12.2006, 8:03
Пользователь №: 70 385
Прошивка: elektro255_v0.2_49R
Вопрос.
Рефлеш electro255 49r V2.0. Выставляю 2 будильника. Первый – выключен, второй – включен. Выключаю телефон. Когда наступает время срабатывания первого будильника зажигается экран, подсветка клавиш, но сам будильник не звенит. Все это продолжает гореть, пока не передернешь батарею. Второй будильник при этом срабатывает. Если установлен один будильник – все работает как надо.
Никто не знает, где и что можно подправить?
Будильник по умолчанию работает на выключеном теле, база мелодий работает нормально. На обоих будильниках одна и та же мелодия.
HUNTER_ok
сообщение 30.12.2006, 9:09
Doktor Кот, Мой тебе совет:
1. Если ты залил бутлоадер 07.D0, то ты можешь шить любой монстр для 398.
2. Прошил бы какой нибудь монстр на 49R прошиве(например:Mpx398).
3. Поставил поверх него рефлеш 49R mod.
4. Поставишь патчи и всё будет норм.
А эти проблемы у тебя видимо из-за PDS(наверное ты что-то некоректно сделал при ТП),
верни назад и попробуй ещё раз сделать ТП.
Doktor Кот
сообщение 30.12.2006, 11:27
Из: Красноярск
Все! Проблема с блютуз решена! Hunter'ok направил мои предположения в нужное направление. Спасибо и + ему! Но тут еще одна штучка. Я конечно понимаю, что об этом где-то спрашивали... Что нужно сделать, чтоб когда принимаешь по блютуз файлы, можно было выбрать куда сохранять: в телефон или на флешку?
bigserg555
сообщение 30.12.2006, 20:45
MotoSportsMen
Из: Рязань
Пользователь №: 53 831
Модель телефона: LG
Прошивка: Меняю как перчатки)
Doktor Кот,
1. Выбора устройства хранения при закачке через Bluetooth
Описание: позволяет выбрать устройство хранения полученных через блютуз файлов
Как включить:
открываем СИМ 0032_0001 находим слева 0A0 и меняем всю строчку на 00 06 00 00 00 40 40 00 00 00 00 00 00 00 00 26
Doktor Кот
сообщение 31.12.2006, 3:33
Из: Красноярск
bigserg555, спасибо! Лови плюс.
Сообщение отредактировал Doktor Кот - 31.12.2006, 3:57
Doktor Кот
сообщение 31.12.2006, 9:27
Из: Красноярск
Подскажите пожалуйста, почему ICQ встроеная в прошиву не хочет подключаться? Все настроил: номер, пароль, gprs apn. Но она не включается! В чем проблема?
Kepa
сообщение 31.12.2006, 9:57
Из: Уфа
Пользователь №: 86 486
Модель телефона: Qtec S100
Прошивка: HTCMAG_ROM_RUS_O2
Господа Форумчане...Всех с Наступающим Новым Годом Свиньи.....!!!
Подскажите пожалуйста....вот у меня с смс напряг...сохраняет только от силы 50шт....
Стоит у меня MPX 49R + Electro 49R (reflash)
Где-то я читал что функция сохранения большого кол-ва смс включается в p2kae включением какой-то галочки!!!
-=electro255=- большое спасибо за проделанную работу.....
BackgaMan
сообщение 31.12.2006, 10:09
Мотоумелец
Смотри здесь Для программы P2k Advanced Editor Расшифровка seem'ов (0032_0001)
Kepa
сообщение 31.12.2006, 11:03
Из: Уфа
Ты меня конечно извини.....за назойливость и за флуд...но прочитав весь пост не нашел подхлодящего пункта....ткни носом пожалуйста!!!!!! с меня +
deadmoto
сообщение 31.12.2006, 14:42
Главный Новостник
Из: Омск
Пользователь №: 49 284
Модель телефона: Motorola
Прошивка: Motorola Original
Kepa, тебе нужно залить в телефон вот это
Doktor Кот
сообщение 1.1.2007, 3:24
Из: Красноярск
Люди, столкнулся с проблемой! EMS из сообщений не сохраняются в телефон! Сохранение обрывается на какой-то стадии! (когда выбираешь устройство хранения для сохранения, почему то не появляется окно для ввода имени сохраняемого файла. Начинает сохранять и сохранение обрывается!) В чем проблема?
Сообщение отредактировал Doktor Кот - 1.1.2007, 13:02
Дагестан
сообщение 1.1.2007, 19:31
Из: Россия
Пользователь №: 97 197
Модель телефона: E1, L7, W510, Z3
А как заставить работать Senergy_tools на 79R? (Проша MPX398 79R, рефлеш elektro255 79R) и ещё как сделать, чтоб на ## был фонарь? На 49 работало а на 79 не хочет... Особо не бейте, если я повторяюсь... Всю тему облазить через GPRS не очень реально!.. Заранее всем спасибо.
deadmoto
сообщение 1.1.2007, 21:11
Главный Новостник
Из: Омск
Дагестан, пока никак, жди когда сделают под 79-ю, и спрашивай лучше в теме про приложение а не про прошивку.
Zinok
сообщение 2.1.2007, 8:38
Пользователь №: 64 685
Модель телефона: C380
Прошивка: d.23r
zian
сообщение 3.1.2007, 16:05
Пользователь №: 69 818
Прошивка: Electro (49r)
С наступившим всех! У меня такая вот беда - в медиа картинках показываются файлы изображений не только из папки аудио на флехе, но и вообще из любой папки на флехе. Заметил случайно - обычно юзаю мв, создал папку скинов для мв на флехе и увидел их в картинках. Это что фичи от электро? Проверьте может у кого тоже так. Для инфы - проша на 49r, патчи на клавиши разблок, вход в опкод, флекс свой, шрифт мелкий, стоит последний мв с плагинами.
Пиши по-русски.Устное Предупреждение.
Сообщение отредактировал Bent - 4.1.2007, 16:53
SkyFox
сообщение 3.1.2007, 16:16
Пользователь №: 111 477
Модель телефона: 398
Прошивка: 49r
Цитата(zian @ Среда, 3 Января 2007, 18:05)
С наступившим всех! У меня такая вот хрень - в медиа картинках показываются файлы изображений не только из папки аудио на флехе, но и вообще из любой папки на флехе. Заметил случайно - обычно юзаю мв, создал папку скинов для мв на флехе и увидел их в картинках. Это чё фичи от электро? Проверьте может у кого тоже так. Для инфы - проша на 49r, патчи на клавиши разблок, вход в опкод, флекс свой, шрифт мелкий, стоит последний мв с плагинами.
поставь папке атрибут скрытый и ко всем файлам
Amenti
сообщение 4.1.2007, 12:16
Из: Беларусь, Гомель
Пользователь №: 43 607
Модель телефона: e398 с дыркой под ТП
Прошивка: симба 1.5b
Люди... такая проблема.. если принимать файл по блютузу и телефон автоматом заблокируется... то файл нельзя сохранить?? как поправить?? всегда жать джойстик чтоб не блокировался??
Яуген
сообщение 4.1.2007, 16:09
Пользователь №: 101 871
Amenti, просто тел потом разблокируй и все!! ниче не прервется!
ka4aZ
сообщение 4.1.2007, 19:17
Пользователь №: 86 625
После прошивки elektro255 49r у меня стала быстро сажаться батарея и дня не выдерживает
ka4aZ
сообщение 4.1.2007, 19:28
а что такое цикл ?
Цикл-Это когда садишь батарею в "ноль" и заряжаешь до полного и так раза 2-3 надо сделать.Только сажать батарею надо не в экстримальном режиме(т.е. специально),а так как ты обычно пользуешься телефоном.
Сообщение отредактировал Bent - 4.1.2007, 19:35
Doktor Кот
сообщение 5.1.2007, 2:39
Из: Красноярск
Люди, а почему на полной проше 49R от Электро не работает SMSBackup в МВ? Kjava_sms_access вроде активирована. А при восстановлении смс, МВ пишет "Неизвестная ошибка". В чем может быть проблема?
abatsk
сообщение 5.1.2007, 20:16
Пользователь №: 77 083
Модель телефона: Samsung i9003
Прошивка: Android
зашел на сайт Электро. Хотел скачать на базе 79. Нету файла. Пропал. украли... залейте кто-нибудь в другое место плиз. С меня куча плюсов.
Кстате, батарея у меня тоже в асе час держит. Не более!
Текстовая версия Сейчас: 22.7.2025, 1:03
