23 страниц V < 1 2 3 > »
Elektro255 V0.4 alpha 4 mod (4xR), 44R,46R,49R,79R
elektro255
сообщение 23.9.2006, 12:06 Закрепленное сообщение!
Из: Poland, Siedlce
Пользователь №: 53 130
09-04-2007
V0.4a4 Alpha: http://elektro255.ovh.org
08-04-2007
V0.4a3 Alpha: http://elektro255.ovh.org
07-04-2007
V0.4a2 44R Alpha: http://elektro255.ovh.org
20-12-2006
V0.3 79R Final mod: http://elektro255.ovh.org
27-11-2006
v0.3 for 49R Final mod http://elektro255.ovh.org/
26-11-2006
V0.3 46R Final mod: http://elektro255.ovh.org
НА Е1 Rokr с бутом 0А02 (оригинальный) НЕ ПОСТАВИТЕ БЕЗ Т.П.!
V0.4 alpha 4
Changes:
- Fixed problem with display timeout (fullscreen clock) when SMS/CALL received
Features:
- 4xR and 7xR MIX (use with 4xR flex)
- unlimited Video recording
- keypad automatic lock
- low battery alarm can be turned off or depend on ring style.
- Scheduled Ring Styles (ring style and funlight style can change automatically on given time and week day)
- flashlight shortcut (##)
- extra menu (shortcut *1 [shortcut is only for testing later will be changed])
- automatic menu enter, without sim card (emergency calls working too)
- new Java methods
- settings are stored on files
- no simlock checking
- Volume-bar sound can be turned off
- multiple menus (every skin can have one mma_ucp)
- Ported patches:
o SMS report significantly turned ON
o more folders in OBEX via BT
o removed unused folders from TransFlash
o Java have access to system files
o increased iTap user dictionary size
o no delete incall on SIM replace
o Bluetooth time changed to 3 minutes
o reordered camera store menu (store only is first)
o SMS alert is using default ringtone
OLD versions(V0.1-0.3):
Firmware changes:
- firmware based on 46R from StarterXP MP
- FULL SW access from Java
- LUMA&CHROMA tables moved to memory - now you can change JPEG compresion from Java
- StarterXP flex
- added dualboot
Flasher changes:
- if you have PDS_4013 flasher will no recreate this
Personalization tool changes:
- first version for 0.3_46R SW mod
- changing splash screen
- changing font (you can use *.fnt or *.smg CG4 files)
- you can turn on, turn off menu access without sim cart
- changing my shortcuts
Новая версия V0.4 alpha 4
Изменения:
- Устранена проблема с таймаутом дисплея(полноэкранные часы) при приеме смс/звонка
Новое:
- Прошивка создана как микс 4xR и 7xR (флекс 4xR ) В 44R она переименована для совместимости! Она близко не лежит к 44R на самом деле!
- Безлимитная запись видео (64мб макс как в 6х7х)
- Автоблок клавиатуры
- Звук разряженой батареи можно выключать или задать стилем оповещения(?).
- Расписание стилей оповещения (стиль оповещения и фанлайтмогут менятся автоматически по времени и дням недели)
- Фонарик по (##)
- Дополнительное меню (метка *1 [только для теста, после может изменится])
- Автоматический вход в меню без сим-карты (аварийные звонки работают)
- Новые методы в Яве (не от 79R, а новые)
- Настройки хранятся в файлах
- Не проверяется лоченость ПДС на симку (работает с лоченым пдс)
- Звук изменения громкости можно отключить
- Мультименю (каждый скин может иметь собственный мма_уцп)
- Портированы патчи:
o Оповещение о доставке SMS всегда вкл.
o больше папок доступно по OBEX из блютуза
o удалены неиспользуемые папки с флешки
o Полный доступ к системным файлам из явы
o увеличен размер пользовательского словаря iTap
o не удалыются последние вызовы при смене сим
o Время обнаружения блютуза - 3 минуты
o Меню сохранения видеозаписи (просто сохранить - первым пунктом)
o при приходе SMS играет "мелодия на смс", а не установленная на этого пользователя
Для версий 0.1-0.3
Изменения в прошивке:
- Создана на базе монстра StarterXP 46R
- Полный доступ к прошивке (симы, озу) из явы
- Таблицы сжатия фотографий перенесены в озу - теперь из явы можно управлять качеством фотографий (сжатием)
- флекс StarterXP
- добавлен дуалбут
Изменения флешера:
-Если ПДС версии 4013 (373 платформа), ПДС не пересоздается.
Изменения персонализации (Personalization tool):
- впервые для мода использована 46 прошивка
- замена заставки (на включение?)
- замена шрифта (лангпак, CG4)
- можно вкл. и выкл. доступ к меню без сим-карты
- изменен ярлык (копирайт?)
Для работы Personalization tool требуется положить в папку программы несжатый бинарный бэкап (32 мегабайта) под именем SW.bin
Прекращаем флудить, типа а когда выйдет новая версия, и.т.д.и.т.п, или придётся наказывать!
тему почистил, архив по 1 декабря тут:
Прикрепленный файл MotoFan_ru_electro.zip   ( 66.56 килобайт ) Кол-во скачиваний: 3904
Сообщение отредактировал elektro255 - 9.4.2007, 12:21
BackgaMan
сообщение 26.10.2006, 19:34
Мотоумелец
Пользователь №: 61 651
Модель телефона: E-398 Htc-p3300
Цитата(krotE398. @ Четверг, 26 Октября 2006, 23:07)
Плизз, кто скачал можно ли залить в другое место? С сайта автора (респект ему) обе ссылки с мини оперой не дружат!
Вот кому ещё надо скачиваем здесь!
elektro255
сообщение 26.10.2006, 20:25
Из: Poland, Siedlce
постоянно включённый отчёт о доставке не всем нужен. (((
if i add this option i will make settings for turn on turn of this feature
Если это реально, пожалуйста, увеличь количество SMS, которые могут храниться в телефоне.
make more than 178 SMS can be difictual, but maybe possible to make 255 but more than 255 can be impossible to do :)
Ага, понял, просто нельзя изменять цыфровую подпись, тогда второй вопрос - а дуал-бут присутствует? Всем спасибо за ответы.
is not dual-boot in my SW, but you can install this
elektro255
сообщение 27.10.2006, 14:57
Из: Poland, Siedlce
я добавил на стороне cсылки к файлам SHX (fulfalsh,reflash)
elektro255
сообщение 27.10.2006, 19:34
Из: Poland, Siedlce
Парни у меня вопрос...Как включить что бы постоянно был отчёт о доставке(как я понял он тут присутствует,но,я отправляю смс,а отчёт не приходит)
it wil be in future SW versions. This SW is stable version of v0.2b so doesn't have nothing new
elektro255
сообщение 28.10.2006, 8:39
Из: Poland, Siedlce
elektro255, when I made full reset with this SW my phone did not start any more...
So it's a bug obviously...
And also I got some trobbles with external GPRS internet - it doesn't work at all...
all this bugs depends on flex, i don't have time to make flex, so i making only CG1 and adding my flex :) If you will you can use any flex for 4xR (motosymbian MPX398 ... ), or you can make monsterpacks based on my CG1, so please give me only bugs from CG1 not flex
about 178 sms storage:
just fill seem 0144 by FF and fill all records of seem 007D by FF, then phone should store 178 SMS (if one SMS is not longer than one record of SEEM 007D)
about *#06# and *#9999# codes
i'm replaced code of this functions by my code because this functions is useless for normal user
For another feauters in yours flex use plugin for MV or my Java app
Сообщение отредактировал BackgaMan - 28.11.2006, 19:24
Monty
сообщение 29.10.2006, 8:33
Пользователь №: 62 436
Модель телефона: v3x и htc gene
я так понимаю очередной релиз ?!
Elektro255_baby_mod
http://202.44.71.148/eoffice/e398/ipb/inde...?showtopic=5198
Monty
сообщение 30.10.2006, 6:55
я тоже сначала поставил 1 и 3 части, и тоже все работало, и так же не было MV...
После каких-то манипуляций пропала автоблокировка, и ничего нельзя было сделать. Вообщем перепрошил полностью, кроме ленга, и теперь наслаждаюсь, все прекрасно работает....!!!
elektro255
сообщение 30.10.2006, 10:29
Из: Poland, Siedlce
http://elektro255.ovh.org/ website upadate
Archy
сообщение 30.10.2006, 11:02
Пользователь №: 40 468
Модель телефона: E1-L6-L7e-U9, iPhone
Прошивка: M-S1.5RC3 L7e_01.0AR
Archy, так в том ДРМ что автор с прошей выложил ведь тоже не отображаются буквы в точке доступа...только цыфры. Хотя у меня давно готов файл вебсессий и я просто его заливаю - но дело ведь в этом глюке, который буду устранять...
Так у него как раз ДРМ от 70-й серии. Проверь - зашей мой дрм от симбы 1.5бета :) Споришь ещё зачем-то...
Tim2005, неужели с лэнгом от 42 точно не глючит - просто как-то залил от 48-заводской лэнг на 42 - так итап русс и не работал... Об этом подробно писал в теме о создании укр итапа. И флекс, говоришь...это тогда хорошо...А как насчет общего сброса? - гибнет тело или заводится потом?Тоже 42 сейчас у меня - вот и интересуюсь.
Любой монстр гибнет при общем сбросе. Не забывайте форум читать!
Итапп отлично работает на НОРМАЛЬНОМ лэнге к 48-49 прошивке (опять-таки, проверь на симбовом)
Вопрос. При прошивании только cg1,3 сколько смсов влазит? 178? И как дела обстоят с "безлимитным вход-исход списком"?
Всё это есть или надо-таки какие-то симы править?
shayah
сообщение 30.10.2006, 16:07
Из: Казань
Пользователь №: 55 722
Модель телефона: Nokia N82
X3MAL, значит так: заходишь в плагин synergy, ставишь курсор на "Автоблок клавы", нажимаешь джойстик, затем джойстик вверх (вот тут то и должна появиться галочка на пункте "Автоблок"), затем снова наводишь выделение на пункт "автоблок" и жмешь отправить (кнопка "отправить" должна залипнуть), через секунду другую снова жмешь джойстик вверх. Все можешь выходить из плагина, автоблок работает.
elektro255
сообщение 30.10.2006, 20:07
Из: Poland, Siedlce
Elektro255,какие еще функции/особенности ты намереваешься добавить в следующии версии своей прошивки если они будут?
I don't know time will show
Алекс75
сообщение 31.10.2006, 19:03
Мото-реаниматор
Пользователь №: 30 882
Модель телефона: XT502
Прошивка: Android 2.2
Кстати может кто в курсе,просто если честно лениво сидеть сравнивать 0032_0001 с моим родным симом работает только автоблок(фонарик не работает) с 0032_0001 от elektro255 обе функции доступны.Собственно вопрос где активируетсядеактивируется) фонарик в seem 0032_0001? <_<
elektro255
сообщение 1.11.2006, 12:32
Из: Poland, Siedlce
Тема превращается в тему про флекс, я думаю elektro255, не для того старался, что бы его напрягали вопросами которые уже были неоднократно обсуждены на форуме, я считаю такие вопросы флудом (про время съёмки видео и т.п) давайте не засорять тему.
я есть за
~Gangs2er~
сообщение 7.11.2006, 16:48
MotoSkinner
Пользователь №: 93 787
Модель телефона: (M) E398
Прошивка: У вас такой нету))
Вот перевёл на досуге, на русский, ява приложение Sinergi от Electro255.
Скачать Sinerj на русском
elektro255
сообщение 8.11.2006, 17:30
Из: Poland, Siedlce
undo patches for *#06#
BackgaMan
сообщение 12.11.2006, 15:19
Мотоумелец
Цитата(Doktor Кот @ Воскресенье, 12 Ноября 2006, 18:12)
Люди, а эту прошивку можно поставить на оригинальный E1?
Прежде эту тему почитай Прошивка Оригинального Rokr E1 С Бутом 0а.02
elektro255
сообщение 23.11.2006, 12:09
Из: Poland, Siedlce
I''m back (exams passed) :D
new beta http://elektro255.ovh.org/
~Gangs2er~
сообщение 24.11.2006, 6:26
MotoSkinner
Переведите пожалусто вот это:
Цитата(elektro255 @ Суббота, 23 Сентября 2006, 15:06)
23-11-2006 New beta v0.3b is avaible
V0.2
Change log:
- fixed bug with mainmenu access in java aplets
- now kyeypad autolock working full stable
- fast menu access without SIM card by pressing *5
- fixed bug with flashlight (when writing SMS flashalight will no turn on)
- new java plugin in MV to change extra feauters settings
- new flex (updated MV, only stable skins, 178 SMS storage, unlimited calls history...)
- SW now is tested and it is FULL STABLE
- fixed bugs in Flasher.exe, removed all files from program dir, and decreased size of exe file to 247kB
И вот это:
Цитата(elektro255 @ Пятница, 24 Ноября 2006, 0:18)
I used "cut empty bytes" in FB so i will upload right file later
lv333
сообщение 24.11.2006, 8:06
Из: Украина, Киев
Пользователь №: 45 916
Прошивка: СМ 10
Первая часть уже переводилась, страницы полистай, это относится к версии 0.2 которая не бета.
А вторая в свободном, переводе конечно, :) звучит примерно так:
Я использовал "вырезать пустые байты" (прим. для тех кто не знает такая функция есть в флешбекапе), потом загружу правильные файлы.
Bent
сообщение 24.11.2006, 8:25
MoTo Marvellous
Пользователь №: 63 874
ну что непонятного-косяченно собрал или выложил прошивку человек...исправит и выложит нормальную версию...ждём.
Вот изменения v0.3b
Change log:
working *#06# (but no *5)
now you can change SW name
you can change boot splash screen (except website adress on bottom)
you can change JPEG compression (quality) on camera from Java (I will make java app to do this) [later I will make changing of mp4 video bitrate when recording]
Тут в принципе и переводить не нужно кто хотя бы немного знает англ. язык всё поймёт :) Ну а так вообще переведите кто силён.
lv333
сообщение 24.11.2006, 9:09
Из: Украина, Киев
Прошивка: СМ 10
Вот изменения v0.3b
Change log:
Для тех кто с английским вообще не дружит :) http://www.promt.ru/
Собственно вот без коррекций как есть :)
Регистрация изменения: работа * *06 * (но Номер *5) теперь Вы можете изменить КОРОТКОВОЛНОВОЕ название, Вы можете изменить экран всплеска ботинка (кроме адреса вебсайта на основании), Вы можете изменить сжатие JPEG (качество) на камере из Явы (я сделаю явское приложение, чтобы сделать это) [позже, я сделаю изменение mp4 видео bitrate, делая запись]
elektro255
сообщение 24.11.2006, 10:02
Из: Poland, Siedlce
http://rapidshare.com/files/4612313/elektr...eflash.rar.html anybody can test this reflash ?
juicedddd
сообщение 26.11.2006, 11:40
Из: Сыктывкар
Пользователь №: 77 458
Модель телефона: ~E398~
Прошивка: Dream a reality_79R
Меняем Bootscreen в прошивке R373_0.2(49R)-=elektro255=-
34 ПОСТ
elektro255
сообщение 26.11.2006, 12:24
Из: Poland, Siedlce
new SW will be today :) maybe at 7-11pm GMT+001
now I'm making personalization program :)
Screen from develop: http://img134.imageshack.us/my.php?image=programeh6.jpg
elektro255
сообщение 26.11.2006, 20:12
Из: Poland, Siedlce
вы дождались :D
Today I'm very tired so I uploading SW without Java apps and plugins. Later I will make plugin for iTunes and MV 0.32 and app to change quantization tables.
Firmware changes:
- StarterXP flex
- added dualboot
Flasher changes:
About boot screen change:
You can change boot screen except link to my website on bottom.
About LUMA&CHROMA tables:
Luma & chroma tables is at 0x127E5040.
You can't turn off quantization compression because camera shows "File to big"
Quantization tables you can find here: http://www.impulseadventure.com/photo/jpeg...on.html?src1=77
About full acces from Java:
I'm added JMP intrstruction from JAVA:
public static void jmp(int address)
where parameter is adress to any procedure on flash or RAM.
If you will JMP to procedure in Thumb code you must add 1 to adress, if you will make jump to ARM cde don't increment.
All procedures must have reurn (BX LR).
If you making another jump from procedure you must save linkregister on stack PUSH {LR}.
This function is only for assembler programmers, or somebody who want teach ASM for ARM processors :)
To upload your code to RAM you can use Writebyte() from my lib, your code can use RAM to swap data between Java and ASM code.
Utility of this function:
You can use this for ultra fast low level calculations in Java :)
You can execute any exists procedure with any parameters (very usefull for discovering new motorola procedures)
You can make ASM compiler for ARM processor :D
You can inject and execute any code by Java (for example to erase and flash NV memory in phone :P)
zolookas
сообщение 26.11.2006, 21:01
Пользователь №: 43 073
Прошивка: R373_G_0E.30.49R
Зеркало
Rapishare:
http://rapidshare.com/files/4946318/elektr....3_46R.rar.html
Fastshare:
http://www.FastShare.org/download/elektro2...od_v0.3_46R.rar
Megaupload:
http://www.megaupload.com/?d=PNCVRJ7E
Elektro255, i've enabled flash menu (by the way it's access, not acces)
And *5 opens IMEI, not menu.
Anyway congrats on new version clap;applo
elektro255
сообщение 27.11.2006, 13:57
Из: Poland, Siedlce
Electro255 всего лишь сказал что 46 р ему просто понравилась :) но дальнейшие модификации будут на 49 р
v0.3 on 49R will be today :) and maybe later for 79R I maked SW for 46R because i like StarterXP MP :) I'm using only exists flexes because for me making flex is very boring
zolookas
сообщение 27.11.2006, 16:10
Цитата(p00p0k @ Tuesday, 28 November 2006, 4:36)
Ребят ну в конце то концов кто прошился! Выложите яву с него!
http://slil.ru/23478111
elektro255
сообщение 27.11.2006, 16:40
Из: Poland, Siedlce
http://elektro255.ovh.org/final.php v0.3 for 49R
~Gangs2er~
сообщение 27.11.2006, 18:07
MotoSkinner
Я прошил только рефлэш, потверждаю всё работает, тело не умерло!!! Шил 3м флэш бэкапом.
Народ, кто проьётся монстром выложите яву!!!
ЗЫ: Ощутил как прибавилась скорость с прошлого рефлэша, воще улёёёт!!! :)
Больше ничё нового не заметил!
p00p0k, прога выдаёт какую то ошибку sw.bin not fownd.
ТЕ надо конвертить прошиву в bin чтоли? Кто разобрался в проге, объясните как её юзать! :)
JaneAir
сообщение 27.11.2006, 18:27
Пользователь №: 101 260
Прошивка: R373_G_OE.30.48R
Поставил я этот монстр(49R) и заметил,что когда фотка сохраняется,то получается что-то вроде вот этого:
P.S Где настраивается качество картинки?
p00p0k
сообщение 27.11.2006, 18:59
Пользователь №: 95 690
Прошивка: electro255
Вот ссылка на моснтр: rapidshare.com
Подробности во время прошивки фул-флешем через Flasher
21:26:00 BOOT verion: 07D0
21:26:00 SW Version: R373_0.2 (49R)-=elektro255=-
21:26:00 Sending loader
21:26:02 Reading PDS
21:26:09 Unpacking PDS
21:26:12 PDS update skipped
21:28:30 Sending loader
21:28:32 Erasing flash. It can take 5 minutes.
21:33:44 Sending SW
21:37:33 --==Finished==--
Все в порядке!
Java-плиложения забираем в прикреплённых файлах!
Там АБСОЛЮТНО вся Java с этого монстра!
А я же сейчас откатываюсь и прошиваюсь рефлешем
с последующей установкой
всех Java-приложений с фул-флеша!
Между прочим! ТАКОЙ скорости я не видал НИ ГДЕ просто улёёёёт!
~Gangs2er~,
Для начало надо скинуть прошивку в папку с файлом Flasher чтобы он обнаружил прошивку.... А потом шейся!
elektro255
сообщение 27.11.2006, 19:30
Из: Poland, Siedlce
Personalization tool workin only with binary full backup (make backup and then copy this backup as SW.bin to program directory)
in 49R i'm maked one mistake because in my code is wrong Luma offset, patch to fix that:
deleted
after this patch luma and chroma tables is at 0x127E5040
StrIk3r
сообщение 27.11.2006, 19:44
Из: Великий Новгород
Пользователь №: 53 936
Модель телефона: E398@ROKR_E1_iTunes
Прошивка: R373...49R
elektro255,
patch not fixed problem with foto
StrIk3r
сообщение 27.11.2006, 20:00
elektro255,
[Patch_Code]
********:04040404040404040404040404040404040404040404040404040404040404040404040404040404040404040404040404040404040404041b182023202c2c3a
may be you did error in offset
it is default bits for Luma_Qtable, but foto too bad :(
elektro255
сообщение 27.11.2006, 20:02
Из: Poland, Siedlce
i forget to decrese adressz by 80000 in patch code :D
good patch code is :
[Patch_Info]
Description=change LUMA offset
Author=elektro255
Version=1.0
[Patch_Code]
B9D7F8: 127E5040
StrIk3r
сообщение 27.11.2006, 20:10
Вот патч
я еще сам не успел проверить
Прикрепленный файл 49R_JPEGPC_LUMA_QTABLE.zip   ( 265 байт ) Кол-во скачиваний: 33
Amenti
сообщение 27.11.2006, 20:11
Из: Беларусь, Гомель
Пользователь №: 43 607
Модель телефона: e398 с дыркой под ТП
Прошивка: симба 1.5b
просто создайте файл с расширением .fpa. Запишите в него эти сторочки
[Patch_Info]
Author=elektro255
Version=1.0
[Patch_Code]
B9D7F8: 127E5040
и примените.
Фотки становятся номальными.
А видео у меня тело еще ни разу так не снимало!!!!! Респект!!!!
StrIk3r
сообщение 27.11.2006, 20:26
Раньше у меня намного фоты были лучше а сейчас все замылиные какие-то
Прикладываю как было на 48 со своим патчем на фото
electro255 why did you replace only 4 bits in your patch for foto
once upone a time I replaced all 64 bits for 48r
sorry for my english
Dimka
сообщение 27.11.2006, 22:01
МотоКовырятель
Из: Волгоград
Пользователь №: 39 255
elektro255! How it works? And as it to use. Explain more in detail.
Текстовая версия Сейчас: 2.8.2025, 18:41
