23 страниц V « < 8 9 10 11 > »
Elektro255 V0.4 alpha 4 mod (4xR), 44R,46R,49R,79R
elektro255
сообщение 23.9.2006, 12:06 Закрепленное сообщение!
Из: Poland, Siedlce
Пользователь №: 53 130
09-04-2007
V0.4a4 Alpha: http://elektro255.ovh.org
08-04-2007
V0.4a3 Alpha: http://elektro255.ovh.org
07-04-2007
V0.4a2 44R Alpha: http://elektro255.ovh.org
20-12-2006
V0.3 79R Final mod: http://elektro255.ovh.org
27-11-2006
v0.3 for 49R Final mod http://elektro255.ovh.org/
26-11-2006
V0.3 46R Final mod: http://elektro255.ovh.org
НА Е1 Rokr с бутом 0А02 (оригинальный) НЕ ПОСТАВИТЕ БЕЗ Т.П.!
V0.4 alpha 4
Changes:
- Fixed problem with display timeout (fullscreen clock) when SMS/CALL received
Features:
- 4xR and 7xR MIX (use with 4xR flex)
- unlimited Video recording
- keypad automatic lock
- low battery alarm can be turned off or depend on ring style.
- Scheduled Ring Styles (ring style and funlight style can change automatically on given time and week day)
- flashlight shortcut (##)
- extra menu (shortcut *1 [shortcut is only for testing later will be changed])
- automatic menu enter, without sim card (emergency calls working too)
- new Java methods
- settings are stored on files
- no simlock checking
- Volume-bar sound can be turned off
- multiple menus (every skin can have one mma_ucp)
- Ported patches:
o SMS report significantly turned ON
o more folders in OBEX via BT
o removed unused folders from TransFlash
o Java have access to system files
o increased iTap user dictionary size
o no delete incall on SIM replace
o Bluetooth time changed to 3 minutes
o reordered camera store menu (store only is first)
o SMS alert is using default ringtone
OLD versions(V0.1-0.3):
Firmware changes:
- firmware based on 46R from StarterXP MP
- FULL SW access from Java
- LUMA&CHROMA tables moved to memory - now you can change JPEG compresion from Java
- StarterXP flex
- added dualboot
Flasher changes:
- if you have PDS_4013 flasher will no recreate this
Personalization tool changes:
- first version for 0.3_46R SW mod
- changing splash screen
- changing font (you can use *.fnt or *.smg CG4 files)
- you can turn on, turn off menu access without sim cart
- changing my shortcuts
Новая версия V0.4 alpha 4
Изменения:
- Устранена проблема с таймаутом дисплея(полноэкранные часы) при приеме смс/звонка
Новое:
- Прошивка создана как микс 4xR и 7xR (флекс 4xR ) В 44R она переименована для совместимости! Она близко не лежит к 44R на самом деле!
- Безлимитная запись видео (64мб макс как в 6х7х)
- Автоблок клавиатуры
- Звук разряженой батареи можно выключать или задать стилем оповещения(?).
- Расписание стилей оповещения (стиль оповещения и фанлайтмогут менятся автоматически по времени и дням недели)
- Фонарик по (##)
- Дополнительное меню (метка *1 [только для теста, после может изменится])
- Автоматический вход в меню без сим-карты (аварийные звонки работают)
- Новые методы в Яве (не от 79R, а новые)
- Настройки хранятся в файлах
- Не проверяется лоченость ПДС на симку (работает с лоченым пдс)
- Звук изменения громкости можно отключить
- Мультименю (каждый скин может иметь собственный мма_уцп)
- Портированы патчи:
o Оповещение о доставке SMS всегда вкл.
o больше папок доступно по OBEX из блютуза
o удалены неиспользуемые папки с флешки
o Полный доступ к системным файлам из явы
o увеличен размер пользовательского словаря iTap
o не удалыются последние вызовы при смене сим
o Время обнаружения блютуза - 3 минуты
o Меню сохранения видеозаписи (просто сохранить - первым пунктом)
o при приходе SMS играет "мелодия на смс", а не установленная на этого пользователя
Для версий 0.1-0.3
Изменения в прошивке:
- Создана на базе монстра StarterXP 46R
- Полный доступ к прошивке (симы, озу) из явы
- Таблицы сжатия фотографий перенесены в озу - теперь из явы можно управлять качеством фотографий (сжатием)
- флекс StarterXP
- добавлен дуалбут
Изменения флешера:
-Если ПДС версии 4013 (373 платформа), ПДС не пересоздается.
Изменения персонализации (Personalization tool):
- впервые для мода использована 46 прошивка
- замена заставки (на включение?)
- замена шрифта (лангпак, CG4)
- можно вкл. и выкл. доступ к меню без сим-карты
- изменен ярлык (копирайт?)
Для работы Personalization tool требуется положить в папку программы несжатый бинарный бэкап (32 мегабайта) под именем SW.bin
Прекращаем флудить, типа а когда выйдет новая версия, и.т.д.и.т.п, или придётся наказывать!
тему почистил, архив по 1 декабря тут:
Прикрепленный файл MotoFan_ru_electro.zip   ( 66.56 килобайт ) Кол-во скачиваний: 3902
Сообщение отредактировал elektro255 - 9.4.2007, 12:21
Doktor Кот
сообщение 30.12.2006, 11:27
Из: Красноярск
Пользователь №: 94 751
Прошивка: Electro_R373...49R
Все! Проблема с блютуз решена! Hunter'ok направил мои предположения в нужное направление. Спасибо и + ему! Но тут еще одна штучка. Я конечно понимаю, что об этом где-то спрашивали... Что нужно сделать, чтоб когда принимаешь по блютуз файлы, можно было выбрать куда сохранять: в телефон или на флешку?
bigserg555
сообщение 30.12.2006, 20:45
MotoSportsMen
Из: Рязань
Пользователь №: 53 831
Модель телефона: LG
Прошивка: Меняю как перчатки)
Doktor Кот,
1. Выбора устройства хранения при закачке через Bluetooth
Описание: позволяет выбрать устройство хранения полученных через блютуз файлов
Как включить:
открываем СИМ 0032_0001 находим слева 0A0 и меняем всю строчку на 00 06 00 00 00 40 40 00 00 00 00 00 00 00 00 26
Doktor Кот
сообщение 31.12.2006, 3:33
Из: Красноярск
bigserg555, спасибо! Лови плюс.
Сообщение отредактировал Doktor Кот - 31.12.2006, 3:57
Doktor Кот
сообщение 31.12.2006, 9:27
Из: Красноярск
Подскажите пожалуйста, почему ICQ встроеная в прошиву не хочет подключаться? Все настроил: номер, пароль, gprs apn. Но она не включается! В чем проблема?
Kepa
сообщение 31.12.2006, 9:57
Из: Уфа
Пользователь №: 86 486
Модель телефона: Qtec S100
Прошивка: HTCMAG_ROM_RUS_O2
Господа Форумчане...Всех с Наступающим Новым Годом Свиньи.....!!!
Подскажите пожалуйста....вот у меня с смс напряг...сохраняет только от силы 50шт....
Стоит у меня MPX 49R + Electro 49R (reflash)
Где-то я читал что функция сохранения большого кол-ва смс включается в p2kae включением какой-то галочки!!!
-=electro255=- большое спасибо за проделанную работу.....
BackgaMan
сообщение 31.12.2006, 10:09
Мотоумелец
Пользователь №: 61 651
Модель телефона: E-398 Htc-p3300
Смотри здесь Для программы P2k Advanced Editor Расшифровка seem'ов (0032_0001)
Kepa
сообщение 31.12.2006, 11:03
Из: Уфа
Ты меня конечно извини.....за назойливость и за флуд...но прочитав весь пост не нашел подхлодящего пункта....ткни носом пожалуйста!!!!!! с меня +
deadmoto
сообщение 31.12.2006, 14:42
Главный Новостник
Из: Омск
Пользователь №: 49 284
Модель телефона: Motorola
Прошивка: Motorola Original
Kepa, тебе нужно залить в телефон вот это
Doktor Кот
сообщение 1.1.2007, 3:24
Из: Красноярск
Люди, столкнулся с проблемой! EMS из сообщений не сохраняются в телефон! Сохранение обрывается на какой-то стадии! (когда выбираешь устройство хранения для сохранения, почему то не появляется окно для ввода имени сохраняемого файла. Начинает сохранять и сохранение обрывается!) В чем проблема?
Сообщение отредактировал Doktor Кот - 1.1.2007, 13:02
Дагестан
сообщение 1.1.2007, 19:31
Из: Россия
Пользователь №: 97 197
Модель телефона: E1, L7, W510, Z3
А как заставить работать Senergy_tools на 79R? (Проша MPX398 79R, рефлеш elektro255 79R) и ещё как сделать, чтоб на ## был фонарь? На 49 работало а на 79 не хочет... Особо не бейте, если я повторяюсь... Всю тему облазить через GPRS не очень реально!.. Заранее всем спасибо.
deadmoto
сообщение 1.1.2007, 21:11
Главный Новостник
Из: Омск
Дагестан, пока никак, жди когда сделают под 79-ю, и спрашивай лучше в теме про приложение а не про прошивку.
Zinok
сообщение 2.1.2007, 8:38
Пользователь №: 64 685
Модель телефона: C380
Прошивка: d.23r
zian
сообщение 3.1.2007, 16:05
Пользователь №: 69 818
Прошивка: Electro (49r)
С наступившим всех! У меня такая вот беда - в медиа картинках показываются файлы изображений не только из папки аудио на флехе, но и вообще из любой папки на флехе. Заметил случайно - обычно юзаю мв, создал папку скинов для мв на флехе и увидел их в картинках. Это что фичи от электро? Проверьте может у кого тоже так. Для инфы - проша на 49r, патчи на клавиши разблок, вход в опкод, флекс свой, шрифт мелкий, стоит последний мв с плагинами.
Пиши по-русски.Устное Предупреждение.
Сообщение отредактировал Bent - 4.1.2007, 16:53
SkyFox
сообщение 3.1.2007, 16:16
Пользователь №: 111 477
Модель телефона: 398
Прошивка: 49r
Цитата(zian @ Среда, 3 Января 2007, 18:05)
С наступившим всех! У меня такая вот хрень - в медиа картинках показываются файлы изображений не только из папки аудио на флехе, но и вообще из любой папки на флехе. Заметил случайно - обычно юзаю мв, создал папку скинов для мв на флехе и увидел их в картинках. Это чё фичи от электро? Проверьте может у кого тоже так. Для инфы - проша на 49r, патчи на клавиши разблок, вход в опкод, флекс свой, шрифт мелкий, стоит последний мв с плагинами.
поставь папке атрибут скрытый и ко всем файлам
Amenti
сообщение 4.1.2007, 12:16
Из: Беларусь, Гомель
Пользователь №: 43 607
Модель телефона: e398 с дыркой под ТП
Прошивка: симба 1.5b
Люди... такая проблема.. если принимать файл по блютузу и телефон автоматом заблокируется... то файл нельзя сохранить?? как поправить?? всегда жать джойстик чтоб не блокировался??
Яуген
сообщение 4.1.2007, 16:09
Пользователь №: 101 871
Amenti, просто тел потом разблокируй и все!! ниче не прервется!
ka4aZ
сообщение 4.1.2007, 19:17
Пользователь №: 86 625
После прошивки elektro255 49r у меня стала быстро сажаться батарея и дня не выдерживает
ka4aZ
сообщение 4.1.2007, 19:28
а что такое цикл ?
Цикл-Это когда садишь батарею в "ноль" и заряжаешь до полного и так раза 2-3 надо сделать.Только сажать батарею надо не в экстримальном режиме(т.е. специально),а так как ты обычно пользуешься телефоном.
Сообщение отредактировал Bent - 4.1.2007, 19:35
Doktor Кот
сообщение 5.1.2007, 2:39
Из: Красноярск
Люди, а почему на полной проше 49R от Электро не работает SMSBackup в МВ? Kjava_sms_access вроде активирована. А при восстановлении смс, МВ пишет "Неизвестная ошибка". В чем может быть проблема?
abatsk
сообщение 5.1.2007, 20:16
Пользователь №: 77 083
Модель телефона: Samsung i9003
Прошивка: Android
зашел на сайт Электро. Хотел скачать на базе 79. Нету файла. Пропал. украли... залейте кто-нибудь в другое место плиз. С меня куча плюсов.
Кстате, батарея у меня тоже в асе час держит. Не более!
ApxuBatop
сообщение 5.1.2007, 20:56
Мото-Художник
Пользователь №: 65 512
Модель телефона: iphone 5
Прошивка: от Е398
abatsk,
Amenti
сообщение 6.1.2007, 6:33
а ты сам-то пробовал?? сначала попробуй разблокировать тело после приема файла, а потом пиши!!
принятого файла нет даже в папке tmp.
66_ЛЁХА_99
сообщение 6.1.2007, 10:17
Пользователь №: 108 652
Модель телефона: Motorola ZN5
Прошивка: R6637 G 81 03 0ER
Кто-нибудь знает, как с помощью компа можно отключить автоблокировку на electro 79R ???
Chobat
сообщение 6.1.2007, 15:05
Пользователь №: 67 893
Прошивка: ***Chobat_Flex***
Дайт е кто ссылку плиз на прошиву это Electro на 49R! ТОлько прямую плиз, а то так не качаеться!
MotoMixon
сообщение 6.1.2007, 15:47
Из: г.Казань
Пользователь №: 90 411
Модель телефона: Milestone xt720
Прошивка: Android 2.1
серобуромалиновый с продресью
Я пробовал, проверял, у меня все вроде ок! При приеме если блокируется, то просто беру и разблокирую а прием дельше идет. А если уже принял, то аворазблокировка и идет просмотор или прослушивание принятого файла, потом сохраняю и вот когда выхожу на рабочий стол то он сразу же автоматом блокируется! У меня Elektro.v0.2. 49R
deadmoto
сообщение 6.1.2007, 18:40
Главный Новостник
Из: Омск
Chobat, прямых ссылок НЕТ. Все прошивки лежат на файл-хостингах и не поддерживают мэнеджеры закачек. Качай браузером.
Chobat
сообщение 7.1.2007, 11:18
Камрады, помогите, не знаю чё делать! Прошил Электро первый раз- всё нормально, а потом решил сменить картинку, и шрифт! Ну всё поменял, сохранил, прошил!(менял в проге комплектной)После прошивки экраном он не моргнул, и не включился, при попытке прошивки пишет 13:10:25 BOOT verion: 8C64 !!!
А на другую прошу во флэшбэкапе пишет возможно память стёрта, продолжить? Отвечаю ДА, но прошивка не идёт! Помогите плиз!И ещё после прошивки этой прошей фотки галимо снимались, побовал поставить патч Olympus E300 по моему, всё равно!
RXLexus
сообщение 7.1.2007, 12:22
Пользователь №: 115 240
Прошивка: electro v0.3
У меня до применения патча тоже фотки плохие были, а патч ставил вот этот BIG_SIZE_FOTO_WITH_FIX. После него все норм стало снимать. Прикрепляю его..
Прикрепленный файл BIG_SIZE_FOTO_WITH_FIX.zip   ( 397 байт ) Кол-во скачиваний: 129
E1fAngE1
сообщение 7.1.2007, 16:03
Пользователь №: 65 065
Модель телефона: e398 +1gb +PortaPro
Прошивка: 48R
На сайте elektro255 лежит рефлеш на базе 49r,
Как я понял основные фичи включаются через яву,
Я видел кто-то выкладывал в первых постах, она подойдёт?
Или лучше использовать яву "сторонних производителей", которую можно
найти в соответствующем разделе?
Сервы поддерживают докачку?
Заранее спасиб за ответы...
ps: сорри, если повторяюсь...
Snag
сообщение 7.1.2007, 16:41
Из: Украина г.Сумы
Пользователь №: 73 562
Модель телефона: ZINE 5, MING
Прошивка: zine evo/iris
вот держи:
Прикрепленный файл ______Elektro255.rar   ( 194.36 килобайт ) Кол-во скачиваний: 93
Doktor Кот
сообщение 7.1.2007, 16:53
Из: Красноярск
E1fAngE1, загляни в эту тему: Synerj_tools 2.3 Там разрабатывается спец прога для прошивки от Электро! Там же и скачать ее можно!
E1fAngE1
сообщение 7.1.2007, 18:25
Прошивка: 48R
Snag, старый знакомый... Хе-хе smile.gif у меня уже есть это...
Doktor Kot, спасибо, я там уже был, я хотел уточнить может там нет каких-то фич...
Меня больше интересует, поддерживают серверы докачку или нет?
BackgaMan
сообщение 8.1.2007, 10:17
Мотоумелец
Цитата(Basyak333 @ Понедельник, 8 Января 2007, 12:04)
Извиняюсь за  !
Но я щас очень занят,так что прошу ссылку для закачки версии для 49р!
P.S:пост удалю!
вот http://slil.ru/23703033
Basyak333
сообщение 8.1.2007, 10:23
Пользователь №: 87 941
Модель телефона: Nokia 6120c
Прошивка: Navigator
BackgaMan, если не ошибаюсь версия 0.2 а не 0.3
ссылка битая!
Ссылка не битая, проверял. Попробуй от сюда http://ifolder.ru/816052
Сообщение отредактировал BackgaMan - 8.1.2007, 16:46
Doktor Кот
сообщение 8.1.2007, 15:07
Из: Красноярск
Народ, у кого нибудь на полной прошивке работает SMSBackup в MV? А то у меня не хочет работать!
horrorplace
сообщение 8.1.2007, 16:48
Пользователь №: 96 207
Прошивка: Mpx398 De Luxe
скажите плиз, что лучше поставить 49 или 79? где быстрее и стабильнее? извиняюсь если уже повторяюсь в вопросе.. smile.gif
=BazOOka=
сообщение 8.1.2007, 16:59
Пользователь №: 107 478
Модель телефона: rokr e2
Прошивка: 4AP
Хочу поставить этого монстра но чтоб ДРМ не менялся. Че надо делать чтоб заново ДРМ не шить?
павлеГ
сообщение 8.1.2007, 20:58
Пользователь №: 115 271
попробуй реп студио....сотри всё нафиг...создай поновой пдс и залей рабочий бэкап после этого...или монстр...
naykava
сообщение 9.1.2007, 9:04
Пользователь №: 74 301
Прошивка: 49R_em0.3_ns+my edit
Цитата(EGR @ Вторник, 9 Января 2007, 9:13)
Извините! Но можно прошить этот мод на mpx398! И еще вопрос его прошивать как патч FB ом?
Не совсем понятен вопрос...
Если прошиваешь полный монстерпак, то можно прошивать поверх любой 42R-49R прошивки.
Если хочешь прошить поверх mpx398, чтобы mpx398 осталась, а добавились только оригинальные фичи от electro255, тогда шей только CG1 u CG3 группы из прошивки (или рефлеш)
P. S. По моему мнению, для этих "делов" лучше использовать PST
_Тyшkан_
сообщение 9.1.2007, 10:33
Из: Орёл
Пользователь №: 81 333
Прошивка: CS_WITHIN_by_Тушкан
Как заменить бутсплешь в cg1 на 49r от электро?
Я заметил, что Welcome и Hellomoto картинки остались нетронутыми, значит электро придумал новый оффсет, куда и запихнул свой бутсплешь??
Текстовая версия Сейчас: 28.7.2025, 1:45
