23 страниц V « < 9 10 11 12 > »
Elektro255 V0.4 alpha 4 mod (4xR), 44R,46R,49R,79R
elektro255
сообщение 23.9.2006, 12:06 Закрепленное сообщение!
Из: Poland, Siedlce
Пользователь №: 53 130
09-04-2007
V0.4a4 Alpha: http://elektro255.ovh.org
08-04-2007
V0.4a3 Alpha: http://elektro255.ovh.org
07-04-2007
V0.4a2 44R Alpha: http://elektro255.ovh.org
20-12-2006
V0.3 79R Final mod: http://elektro255.ovh.org
27-11-2006
v0.3 for 49R Final mod http://elektro255.ovh.org/
26-11-2006
V0.3 46R Final mod: http://elektro255.ovh.org
НА Е1 Rokr с бутом 0А02 (оригинальный) НЕ ПОСТАВИТЕ БЕЗ Т.П.!
V0.4 alpha 4
Changes:
- Fixed problem with display timeout (fullscreen clock) when SMS/CALL received
Features:
- 4xR and 7xR MIX (use with 4xR flex)
- unlimited Video recording
- keypad automatic lock
- low battery alarm can be turned off or depend on ring style.
- Scheduled Ring Styles (ring style and funlight style can change automatically on given time and week day)
- flashlight shortcut (##)
- extra menu (shortcut *1 [shortcut is only for testing later will be changed])
- automatic menu enter, without sim card (emergency calls working too)
- new Java methods
- settings are stored on files
- no simlock checking
- Volume-bar sound can be turned off
- multiple menus (every skin can have one mma_ucp)
- Ported patches:
o SMS report significantly turned ON
o more folders in OBEX via BT
o removed unused folders from TransFlash
o Java have access to system files
o increased iTap user dictionary size
o no delete incall on SIM replace
o Bluetooth time changed to 3 minutes
o reordered camera store menu (store only is first)
o SMS alert is using default ringtone
OLD versions(V0.1-0.3):
Firmware changes:
- firmware based on 46R from StarterXP MP
- FULL SW access from Java
- LUMA&CHROMA tables moved to memory - now you can change JPEG compresion from Java
- StarterXP flex
- added dualboot
Flasher changes:
- if you have PDS_4013 flasher will no recreate this
Personalization tool changes:
- first version for 0.3_46R SW mod
- changing splash screen
- changing font (you can use *.fnt or *.smg CG4 files)
- you can turn on, turn off menu access without sim cart
- changing my shortcuts
Новая версия V0.4 alpha 4
Изменения:
- Устранена проблема с таймаутом дисплея(полноэкранные часы) при приеме смс/звонка
Новое:
- Прошивка создана как микс 4xR и 7xR (флекс 4xR ) В 44R она переименована для совместимости! Она близко не лежит к 44R на самом деле!
- Безлимитная запись видео (64мб макс как в 6х7х)
- Автоблок клавиатуры
- Звук разряженой батареи можно выключать или задать стилем оповещения(?).
- Расписание стилей оповещения (стиль оповещения и фанлайтмогут менятся автоматически по времени и дням недели)
- Фонарик по (##)
- Дополнительное меню (метка *1 [только для теста, после может изменится])
- Автоматический вход в меню без сим-карты (аварийные звонки работают)
- Новые методы в Яве (не от 79R, а новые)
- Настройки хранятся в файлах
- Не проверяется лоченость ПДС на симку (работает с лоченым пдс)
- Звук изменения громкости можно отключить
- Мультименю (каждый скин может иметь собственный мма_уцп)
- Портированы патчи:
o Оповещение о доставке SMS всегда вкл.
o больше папок доступно по OBEX из блютуза
o удалены неиспользуемые папки с флешки
o Полный доступ к системным файлам из явы
o увеличен размер пользовательского словаря iTap
o не удалыются последние вызовы при смене сим
o Время обнаружения блютуза - 3 минуты
o Меню сохранения видеозаписи (просто сохранить - первым пунктом)
o при приходе SMS играет "мелодия на смс", а не установленная на этого пользователя
Для версий 0.1-0.3
Изменения в прошивке:
- Создана на базе монстра StarterXP 46R
- Полный доступ к прошивке (симы, озу) из явы
- Таблицы сжатия фотографий перенесены в озу - теперь из явы можно управлять качеством фотографий (сжатием)
- флекс StarterXP
- добавлен дуалбут
Изменения флешера:
-Если ПДС версии 4013 (373 платформа), ПДС не пересоздается.
Изменения персонализации (Personalization tool):
- впервые для мода использована 46 прошивка
- замена заставки (на включение?)
- замена шрифта (лангпак, CG4)
- можно вкл. и выкл. доступ к меню без сим-карты
- изменен ярлык (копирайт?)
Для работы Personalization tool требуется положить в папку программы несжатый бинарный бэкап (32 мегабайта) под именем SW.bin
Прекращаем флудить, типа а когда выйдет новая версия, и.т.д.и.т.п, или придётся наказывать!
тему почистил, архив по 1 декабря тут:
Прикрепленный файл MotoFan_ru_electro.zip   ( 66.56 килобайт ) Кол-во скачиваний: 3902
Сообщение отредактировал elektro255 - 9.4.2007, 12:21
ApxuBatop
сообщение 5.1.2007, 20:56
Мото-Художник
Пользователь №: 65 512
Модель телефона: iphone 5
Прошивка: от Е398
abatsk,
Amenti
сообщение 6.1.2007, 6:33
Из: Беларусь, Гомель
Пользователь №: 43 607
Модель телефона: e398 с дыркой под ТП
Прошивка: симба 1.5b
Цитата(Яуген @ Четверг, 4 Января 2007, 17:09)
Amenti, просто тел потом разблокируй и все!! ниче не прервется!
а ты сам-то пробовал?? сначала попробуй разблокировать тело после приема файла, а потом пиши!!
принятого файла нет даже в папке tmp.
66_ЛЁХА_99
сообщение 6.1.2007, 10:17
Пользователь №: 108 652
Модель телефона: Motorola ZN5
Прошивка: R6637 G 81 03 0ER
Кто-нибудь знает, как с помощью компа можно отключить автоблокировку на electro 79R ???
Chobat
сообщение 6.1.2007, 15:05
Пользователь №: 67 893
Прошивка: ***Chobat_Flex***
Дайт е кто ссылку плиз на прошиву это Electro на 49R! ТОлько прямую плиз, а то так не качаеться!
MotoMixon
сообщение 6.1.2007, 15:47
Из: г.Казань
Пользователь №: 90 411
Модель телефона: Milestone xt720
Прошивка: Android 2.1
серобуромалиновый с продресью
Я пробовал, проверял, у меня все вроде ок! При приеме если блокируется, то просто беру и разблокирую а прием дельше идет. А если уже принял, то аворазблокировка и идет просмотор или прослушивание принятого файла, потом сохраняю и вот когда выхожу на рабочий стол то он сразу же автоматом блокируется! У меня Elektro.v0.2. 49R
deadmoto
сообщение 6.1.2007, 18:40
Главный Новостник
Из: Омск
Пользователь №: 49 284
Прошивка: Motorola Original
Chobat, прямых ссылок НЕТ. Все прошивки лежат на файл-хостингах и не поддерживают мэнеджеры закачек. Качай браузером.
Chobat
сообщение 7.1.2007, 11:18
Камрады, помогите, не знаю чё делать! Прошил Электро первый раз- всё нормально, а потом решил сменить картинку, и шрифт! Ну всё поменял, сохранил, прошил!(менял в проге комплектной)После прошивки экраном он не моргнул, и не включился, при попытке прошивки пишет 13:10:25 BOOT verion: 8C64 !!!
А на другую прошу во флэшбэкапе пишет возможно память стёрта, продолжить? Отвечаю ДА, но прошивка не идёт! Помогите плиз!И ещё после прошивки этой прошей фотки галимо снимались, побовал поставить патч Olympus E300 по моему, всё равно!
RXLexus
сообщение 7.1.2007, 12:22
Пользователь №: 115 240
Прошивка: electro v0.3
У меня до применения патча тоже фотки плохие были, а патч ставил вот этот BIG_SIZE_FOTO_WITH_FIX. После него все норм стало снимать. Прикрепляю его..
Прикрепленный файл BIG_SIZE_FOTO_WITH_FIX.zip   ( 397 байт ) Кол-во скачиваний: 129
E1fAngE1
сообщение 7.1.2007, 16:03
Пользователь №: 65 065
Модель телефона: e398 +1gb +PortaPro
Прошивка: 48R
На сайте elektro255 лежит рефлеш на базе 49r,
Как я понял основные фичи включаются через яву,
Я видел кто-то выкладывал в первых постах, она подойдёт?
Или лучше использовать яву "сторонних производителей", которую можно
найти в соответствующем разделе?
Сервы поддерживают докачку?
Заранее спасиб за ответы...
ps: сорри, если повторяюсь...
Snag
сообщение 7.1.2007, 16:41
Из: Украина г.Сумы
Пользователь №: 73 562
Модель телефона: ZINE 5, MING
Прошивка: zine evo/iris
вот держи:
Прикрепленный файл ______Elektro255.rar   ( 194.36 килобайт ) Кол-во скачиваний: 93
Doktor Кот
сообщение 7.1.2007, 16:53
Из: Красноярск
Пользователь №: 94 751
Прошивка: Electro_R373...49R
E1fAngE1, загляни в эту тему: Synerj_tools 2.3 Там разрабатывается спец прога для прошивки от Электро! Там же и скачать ее можно!
E1fAngE1
сообщение 7.1.2007, 18:25
Прошивка: 48R
Snag, старый знакомый... Хе-хе smile.gif у меня уже есть это...
Doktor Kot, спасибо, я там уже был, я хотел уточнить может там нет каких-то фич...
Меня больше интересует, поддерживают серверы докачку или нет?
BackgaMan
сообщение 8.1.2007, 10:17
Мотоумелец
Пользователь №: 61 651
Модель телефона: E-398 Htc-p3300
Цитата(Basyak333 @ Понедельник, 8 Января 2007, 12:04)
Извиняюсь за  !
Но я щас очень занят,так что прошу ссылку для закачки версии для 49р!
P.S:пост удалю!
вот http://slil.ru/23703033
Basyak333
сообщение 8.1.2007, 10:23
Пользователь №: 87 941
Модель телефона: Nokia 6120c
Прошивка: Navigator
BackgaMan, если не ошибаюсь версия 0.2 а не 0.3
ссылка битая!
Ссылка не битая, проверял. Попробуй от сюда http://ifolder.ru/816052
Сообщение отредактировал BackgaMan - 8.1.2007, 16:46
Doktor Кот
сообщение 8.1.2007, 15:07
Из: Красноярск
Народ, у кого нибудь на полной прошивке работает SMSBackup в MV? А то у меня не хочет работать!
horrorplace
сообщение 8.1.2007, 16:48
Пользователь №: 96 207
Прошивка: Mpx398 De Luxe
скажите плиз, что лучше поставить 49 или 79? где быстрее и стабильнее? извиняюсь если уже повторяюсь в вопросе.. smile.gif
=BazOOka=
сообщение 8.1.2007, 16:59
Пользователь №: 107 478
Модель телефона: rokr e2
Прошивка: 4AP
Хочу поставить этого монстра но чтоб ДРМ не менялся. Че надо делать чтоб заново ДРМ не шить?
павлеГ
сообщение 8.1.2007, 20:58
Пользователь №: 115 271
попробуй реп студио....сотри всё нафиг...создай поновой пдс и залей рабочий бэкап после этого...или монстр...
naykava
сообщение 9.1.2007, 9:04
Пользователь №: 74 301
Прошивка: 49R_em0.3_ns+my edit
Цитата(EGR @ Вторник, 9 Января 2007, 9:13)
Извините! Но можно прошить этот мод на mpx398! И еще вопрос его прошивать как патч FB ом?
Не совсем понятен вопрос...
Если прошиваешь полный монстерпак, то можно прошивать поверх любой 42R-49R прошивки.
Если хочешь прошить поверх mpx398, чтобы mpx398 осталась, а добавились только оригинальные фичи от electro255, тогда шей только CG1 u CG3 группы из прошивки (или рефлеш)
P. S. По моему мнению, для этих "делов" лучше использовать PST
_Тyшkан_
сообщение 9.1.2007, 10:33
Из: Орёл
Пользователь №: 81 333
Прошивка: CS_WITHIN_by_Тушкан
Как заменить бутсплешь в cg1 на 49r от электро?
Я заметил, что Welcome и Hellomoto картинки остались нетронутыми, значит электро придумал новый оффсет, куда и запихнул свой бутсплешь??
naykava
сообщение 9.1.2007, 11:07
Замена бутсплеша. Мануал см. пост ниже, а также внутри архива. (Сам пробовал, работает, хотя и лень было...)
Прикрепленный файл ________________.rar   ( 276.94 килобайт ) Кол-во скачиваний: 51
_Тyшkан_
сообщение 9.1.2007, 12:10
Из: Орёл
CODEAt me one more question... It Is possible to put skins from a disk "b"??? It considerably will save an empty seat in CG2. For example on V635 the disk for loading java simply varied in all references with "a" on "b" but with skins such it is impossible
This will be very dangerous, when you replaced TF phone will not start without skins
А что если в телефоне оставить 1 основной скин, который будет загружаться при отсутствии TF? А остальные сбросить на флеху?
elektro255 What if we have just 1 general skin, that will be load if TF is changed? The rest of them we could keep on oer TF`s.
naykava,
извини, но это совсем не то. У тебя в архиве прога и патч для востанновления трупов. Мне же надо мануал или оффсет для motobootscrnreplacer.
about *#06# and *#9999# codes
i'm replaced code of this functions by my code because this functions is useless for normal user
*#06# is working on my phone (your cg1, my flex), but *#9999# isnt working... thats a pitty for me...really sad.gif
naykava
сообщение 9.1.2007, 14:10
Цитата(_Тyшkан_ @ Вторник, 9 Января 2007, 13:10)
naykava,
Вот мануал к вышеозначенному вложению:
[OFF]Для того чтобы сменить картинку нужна прога Motorola Bootscreen Replacer (moto_boot_scrn_repl_2.zip + мануал по работе с прогой в архиве) и патч, который прикреплен в архиве с прогой (Восстановление_трупа_после_патча.zip). Для замены бутсплеша необходимо с помощью проги создать патч с необходимой вам картинкой а затем есть 2 варианта.
1.Применить сначала этот патч, после чего получаем труп, затем вынимаем акум, зажимаем # * и вставляем акум, т.е. переключаем в бут режим и применяем второй патч (Восстановление_трупа_после_патча.zip). После чего включаем телефон уже со своей картинкой.
2.После создания своего патча со своей картинкой открываем патч в блокноте и ниже строчки с картинкой добавляем строчку из патча для восстановления. Обязательно ниже а не выше!!!
Вот и все. За "раскопку" данных методов огромное спасибо juicedddd,а так же автору проги OvZ
Удачи[/OFF]
Dart Moto
сообщение 11.1.2007, 11:55
Из: XS™
Пользователь №: 99 608
Модель телефона: XS™
Прошивка: XS™
Добрый день! Дайте пожалуйста симы с проши от електро255. (Seem 32, Seem 4E, Seem 4A)
Qwest
сообщение 11.1.2007, 14:59
Из: Краснодар
Пользователь №: 47 049
Модель телефона: E798 (E398) 48R
Люди, подскажите плиииз, на монстре от электро 79р у всех не сохраняются смс или только у меня? Ставил полного монстро через Флешер что в комплекте, и заметил что при смене симки пропадают смс!
Пробавал ставить блок на СМС (меню-блокировать) не помогает! Просто очень не удобно, когда пользуешся адаптером для 2-х симок!
Не бейте сильно, если вопрос обсуждался раньше!!!
Заранее СПАСИБО!!!
_Тyшkан_
сообщение 11.1.2007, 16:11
Из: Орёл
Keypad autoblock:
SEEM 004A_0001 adres 0x91 bit 1 (1-autolock enabled 0-autolock disabled)
Low Battery Sound:
SEEM 004A_0001 adres 0x91 bit 0 (1-sound enabled 0-sound disabled)
[OFF]Что-то не нашел я такого у себя. В аттачу мой 4а сим, тому кто мне активирует эти две фичи будет +.[/OFF]
Qwest,
посмотри в опциях, скорее всего у тебя смс на симкарте хранятся. Когда ты меняешь симку на другую, то смски остаются на старой. ИМХО
PATRON2002
сообщение 11.1.2007, 18:18
Из: Ростов-на-Дону
Пользователь №: 72 038
Прошивка: Symbian 9.2 3Dr
Люди дайте плиззз ссылку на 49ю...........
BackgaMan
сообщение 11.1.2007, 18:32
Мотоумелец
На предедущей странице смотри.
Qwest
сообщение 12.1.2007, 9:27
Из: Краснодар
_Тyшkан_
Нет, в том то и дело, когда ставлю на сим, все остается! я пробовал ставить сохранение в симах (в телефон) и через меню (в настройках сообщений) не помогает. Просто я не могу понять, это у всех так или только у меня!?
naykava
сообщение 12.1.2007, 12:12
В p2ktools 0.8.6 - скр.настр.- сообщения проверь следующие строки:
1. Хранить SMS только на SIM-карте - убери галочку
2. Удалять СМС при смене СИМ-карты - убери галочку
Если таких строк у тебя нет, тогда распакуй прикрепленный файл в корень p2ktools, заменив старый, и перезапусти прогу.
А также в телефоне: сообщ.-софт.клав.-настройка сообщ.-(автоочистка-нет)настройка сообщ.(изм.)-сохранить в: телефон.
Прикрепленный файл other_features__SnowArt_v1.7_.zip   ( 8.27 килобайт ) Кол-во скачиваний: 89
Qwest
сообщение 12.1.2007, 13:33
Из: Краснодар
naykava
Спасибки тебе, все получилось!!! =) Просто у меня было включено удаление при смене симки!!! Жаль что не могу поставить +, мало постов пока! =( Но большое человеческое СПАСИБО!!!
dsedelnikov
сообщение 13.1.2007, 20:39
Пользователь №: 70 385
Прошивка: elektro255_v0.2_49R
Может кто проверял: на прошивках от электро работают ли пункты меню "темы", IM и т.д.?
А то возиться напрасно нет желания
deadmoto
сообщение 14.1.2007, 9:16
Главный Новостник
Из: Омск
dsedelnikov, зачем они тебе??? Если надо - включи, не надо выключи... 5 кнопок нажать...
Эти настройки есть в P2K Menu Editor'e...
dsedelnikov
сообщение 14.1.2007, 10:33
deadmoto,
спасибо, знаю.
Doktor Кот
сообщение 14.1.2007, 12:58
Из: Красноярск
Всем здрасте! А почему в проше от Электро в настройках настаивается интелект - клавиша для фотокамеры, а не которая с левой нижней стороны? Как это поправить? А еще как на этой проше дуалбут запустить? Еще хочу спросить, какая проша от Электро самая хорошая, самая стабильная и новее: 79R или 49R?
deadmoto
сообщение 14.1.2007, 17:19
Главный Новостник
Из: Омск
Запускаем P2K Tools > Seem Editor > 005b_0001
Находим строку 010... По этой строке столбец 05 это кнопка слева, 06 - кнопка справа...
В архиве найдёшь значения клавиш... У меня 010х05 стоит 42, 010х06 стоит 3F...
Желаю удачи, пробуй...
После некоторых раздумий... Если всё же поставиш на инт.клавишу корелет(код 42), то он будет вызываться из любого места в телефонеsmile.gif Т.е. аналог такой же кнопки не Е1...
Я тебе сейчас -2 дам Запрещено выпрашивать рейтинг
Сообщение отредактировал deadmoto - 15.1.2007, 7:08
Bent
сообщение 15.1.2007, 5:17
MoTo Marvellous
Пользователь №: 63 874
Doktor Кот,
Зажимаешь "Зелёную кнопку" и буквально на секунду(отрывистым движением) нажимаешь "Красную"(Зелёную держишь всё время,не отпуская) Само собой проделывать это в выключенном состоянии.
На мой взгляд лучше 49R79R много заморочек(хотя,сейчас посмотрим что там за RC3 выйдет),НО на 79R безлимитное видео.
AgentSlash
сообщение 15.1.2007, 12:35
Из: Ukraine, Kyiv
Пользователь №: 46 621
Модель телефона: HTC Touch Diamond
Цитата(Doktor Кот @ Воскресенье, 14 Января 2007, 14:58)
.......Еще хочу спросить, какая проша от Электро самая хорошая, самая стабильная и новее: 79R или 49R?
Всё таки 79 получше будет. Токо ставить тебе лучше не голую електровскую прошу, а какой нить настроеный и пропатченый монстрик. Советую подождать симбу от Арчи (RC3).
Doktor Кот
сообщение 15.1.2007, 15:38
Из: Красноярск
Deadmoto, спасибо! Помог! лови + И за отзывы спасибо всем! Еще столкнулся с такой проблемой: изначально на проше от Электро стоит 2 скина: WindowsXp_olive и просто WindoаsXp. Заметил, что эти два скина - полные. WindowsXp_olive - это главный скин, мне он не нравится и я его удалил. И теперь когда я заливаю какой-нибудь другой скин, больший по размеру чем скин WindowsXp, этот скин (а он конечно же неполный) становится главным и пропадают пункты меню! А как сделать родной скин Windowsxp - главным?
BackgaMan
сообщение 15.1.2007, 17:29
Мотоумелец
ММА попробуй от этого скина закинь.
Текстовая версия Сейчас: 21.7.2025, 20:48
