23 страниц V « < 9 10 11 12 > »
Elektro255 V0.4 alpha 4 mod (4xR), 44R,46R,49R,79R
elektro255
сообщение 23.9.2006, 12:06 Закрепленное сообщение!
Из: Poland, Siedlce
Пользователь №: 53 130
09-04-2007
V0.4a4 Alpha: http://elektro255.ovh.org
08-04-2007
V0.4a3 Alpha: http://elektro255.ovh.org
07-04-2007
V0.4a2 44R Alpha: http://elektro255.ovh.org
20-12-2006
V0.3 79R Final mod: http://elektro255.ovh.org
27-11-2006
v0.3 for 49R Final mod http://elektro255.ovh.org/
26-11-2006
V0.3 46R Final mod: http://elektro255.ovh.org
НА Е1 Rokr с бутом 0А02 (оригинальный) НЕ ПОСТАВИТЕ БЕЗ Т.П.!
V0.4 alpha 4
Changes:
- Fixed problem with display timeout (fullscreen clock) when SMS/CALL received
Features:
- 4xR and 7xR MIX (use with 4xR flex)
- unlimited Video recording
- keypad automatic lock
- low battery alarm can be turned off or depend on ring style.
- Scheduled Ring Styles (ring style and funlight style can change automatically on given time and week day)
- flashlight shortcut (##)
- extra menu (shortcut *1 [shortcut is only for testing later will be changed])
- automatic menu enter, without sim card (emergency calls working too)
- new Java methods
- settings are stored on files
- no simlock checking
- Volume-bar sound can be turned off
- multiple menus (every skin can have one mma_ucp)
- Ported patches:
o SMS report significantly turned ON
o more folders in OBEX via BT
o removed unused folders from TransFlash
o Java have access to system files
o increased iTap user dictionary size
o no delete incall on SIM replace
o Bluetooth time changed to 3 minutes
o reordered camera store menu (store only is first)
o SMS alert is using default ringtone
OLD versions(V0.1-0.3):
Firmware changes:
- firmware based on 46R from StarterXP MP
- FULL SW access from Java
- LUMA&CHROMA tables moved to memory - now you can change JPEG compresion from Java
- StarterXP flex
- added dualboot
Flasher changes:
- if you have PDS_4013 flasher will no recreate this
Personalization tool changes:
- first version for 0.3_46R SW mod
- changing splash screen
- changing font (you can use *.fnt or *.smg CG4 files)
- you can turn on, turn off menu access without sim cart
- changing my shortcuts
Новая версия V0.4 alpha 4
Изменения:
- Устранена проблема с таймаутом дисплея(полноэкранные часы) при приеме смс/звонка
Новое:
- Прошивка создана как микс 4xR и 7xR (флекс 4xR ) В 44R она переименована для совместимости! Она близко не лежит к 44R на самом деле!
- Безлимитная запись видео (64мб макс как в 6х7х)
- Автоблок клавиатуры
- Звук разряженой батареи можно выключать или задать стилем оповещения(?).
- Расписание стилей оповещения (стиль оповещения и фанлайтмогут менятся автоматически по времени и дням недели)
- Фонарик по (##)
- Дополнительное меню (метка *1 [только для теста, после может изменится])
- Автоматический вход в меню без сим-карты (аварийные звонки работают)
- Новые методы в Яве (не от 79R, а новые)
- Настройки хранятся в файлах
- Не проверяется лоченость ПДС на симку (работает с лоченым пдс)
- Звук изменения громкости можно отключить
- Мультименю (каждый скин может иметь собственный мма_уцп)
- Портированы патчи:
o Оповещение о доставке SMS всегда вкл.
o больше папок доступно по OBEX из блютуза
o удалены неиспользуемые папки с флешки
o Полный доступ к системным файлам из явы
o увеличен размер пользовательского словаря iTap
o не удалыются последние вызовы при смене сим
o Время обнаружения блютуза - 3 минуты
o Меню сохранения видеозаписи (просто сохранить - первым пунктом)
o при приходе SMS играет "мелодия на смс", а не установленная на этого пользователя
Для версий 0.1-0.3
Изменения в прошивке:
- Создана на базе монстра StarterXP 46R
- Полный доступ к прошивке (симы, озу) из явы
- Таблицы сжатия фотографий перенесены в озу - теперь из явы можно управлять качеством фотографий (сжатием)
- флекс StarterXP
- добавлен дуалбут
Изменения флешера:
-Если ПДС версии 4013 (373 платформа), ПДС не пересоздается.
Изменения персонализации (Personalization tool):
- впервые для мода использована 46 прошивка
- замена заставки (на включение?)
- замена шрифта (лангпак, CG4)
- можно вкл. и выкл. доступ к меню без сим-карты
- изменен ярлык (копирайт?)
Для работы Personalization tool требуется положить в папку программы несжатый бинарный бэкап (32 мегабайта) под именем SW.bin
Прекращаем флудить, типа а когда выйдет новая версия, и.т.д.и.т.п, или придётся наказывать!
тему почистил, архив по 1 декабря тут:
Прикрепленный файл MotoFan_ru_electro.zip   ( 66.56 килобайт ) Кол-во скачиваний: 3902
Сообщение отредактировал elektro255 - 9.4.2007, 12:21
naykava
сообщение 9.1.2007, 11:07
Пользователь №: 74 301
Прошивка: 49R_em0.3_ns+my edit
Цитата(_Тyшkан_ @ Вторник, 9 Января 2007, 11:33)
Как заменить бутсплешь в cg1 на 49r от электро?
Я заметил, что Welcome и Hellomoto картинки остались нетронутыми, значит электро придумал новый оффсет, куда и запихнул свой бутсплешь??
Замена бутсплеша. Мануал см. пост ниже, а также внутри архива. (Сам пробовал, работает, хотя и лень было...)
Прикрепленный файл ________________.rar   ( 276.94 килобайт ) Кол-во скачиваний: 51
_Тyшkан_
сообщение 9.1.2007, 12:10
Из: Орёл
Пользователь №: 81 333
Прошивка: CS_WITHIN_by_Тушкан
CODEAt me one more question... It Is possible to put skins from a disk "b"??? It considerably will save an empty seat in CG2. For example on V635 the disk for loading java simply varied in all references with "a" on "b" but with skins such it is impossible
This will be very dangerous, when you replaced TF phone will not start without skins
А что если в телефоне оставить 1 основной скин, который будет загружаться при отсутствии TF? А остальные сбросить на флеху?
elektro255 What if we have just 1 general skin, that will be load if TF is changed? The rest of them we could keep on oer TF`s.
naykava,
извини, но это совсем не то. У тебя в архиве прога и патч для востанновления трупов. Мне же надо мануал или оффсет для motobootscrnreplacer.
about *#06# and *#9999# codes
i'm replaced code of this functions by my code because this functions is useless for normal user
*#06# is working on my phone (your cg1, my flex), but *#9999# isnt working... thats a pitty for me...really sad.gif
naykava
сообщение 9.1.2007, 14:10
Цитата(_Тyшkан_ @ Вторник, 9 Января 2007, 13:10)
naykava,
Вот мануал к вышеозначенному вложению:
[OFF]Для того чтобы сменить картинку нужна прога Motorola Bootscreen Replacer (moto_boot_scrn_repl_2.zip + мануал по работе с прогой в архиве) и патч, который прикреплен в архиве с прогой (Восстановление_трупа_после_патча.zip). Для замены бутсплеша необходимо с помощью проги создать патч с необходимой вам картинкой а затем есть 2 варианта.
1.Применить сначала этот патч, после чего получаем труп, затем вынимаем акум, зажимаем # * и вставляем акум, т.е. переключаем в бут режим и применяем второй патч (Восстановление_трупа_после_патча.zip). После чего включаем телефон уже со своей картинкой.
2.После создания своего патча со своей картинкой открываем патч в блокноте и ниже строчки с картинкой добавляем строчку из патча для восстановления. Обязательно ниже а не выше!!!
Вот и все. За "раскопку" данных методов огромное спасибо juicedddd,а так же автору проги OvZ
Удачи[/OFF]
Dart Moto
сообщение 11.1.2007, 11:55
Из: XS™
Пользователь №: 99 608
Модель телефона: XS™
Прошивка: XS™
Добрый день! Дайте пожалуйста симы с проши от електро255. (Seem 32, Seem 4E, Seem 4A)
Qwest
сообщение 11.1.2007, 14:59
Из: Краснодар
Пользователь №: 47 049
Модель телефона: E798 (E398) 48R
Люди, подскажите плиииз, на монстре от электро 79р у всех не сохраняются смс или только у меня? Ставил полного монстро через Флешер что в комплекте, и заметил что при смене симки пропадают смс!
Пробавал ставить блок на СМС (меню-блокировать) не помогает! Просто очень не удобно, когда пользуешся адаптером для 2-х симок!
Не бейте сильно, если вопрос обсуждался раньше!!!
Заранее СПАСИБО!!!
_Тyшkан_
сообщение 11.1.2007, 16:11
Из: Орёл
Keypad autoblock:
SEEM 004A_0001 adres 0x91 bit 1 (1-autolock enabled 0-autolock disabled)
Low Battery Sound:
SEEM 004A_0001 adres 0x91 bit 0 (1-sound enabled 0-sound disabled)
[OFF]Что-то не нашел я такого у себя. В аттачу мой 4а сим, тому кто мне активирует эти две фичи будет +.[/OFF]
Qwest,
посмотри в опциях, скорее всего у тебя смс на симкарте хранятся. Когда ты меняешь симку на другую, то смски остаются на старой. ИМХО
PATRON2002
сообщение 11.1.2007, 18:18
Из: Ростов-на-Дону
Пользователь №: 72 038
Модель телефона: Nokia 6120c
Прошивка: Symbian 9.2 3Dr
Люди дайте плиззз ссылку на 49ю...........
BackgaMan
сообщение 11.1.2007, 18:32
Мотоумелец
Пользователь №: 61 651
Модель телефона: E-398 Htc-p3300
На предедущей странице смотри.
Qwest
сообщение 12.1.2007, 9:27
Из: Краснодар
_Тyшkан_
Нет, в том то и дело, когда ставлю на сим, все остается! я пробовал ставить сохранение в симах (в телефон) и через меню (в настройках сообщений) не помогает. Просто я не могу понять, это у всех так или только у меня!?
naykava
сообщение 12.1.2007, 12:12
В p2ktools 0.8.6 - скр.настр.- сообщения проверь следующие строки:
1. Хранить SMS только на SIM-карте - убери галочку
2. Удалять СМС при смене СИМ-карты - убери галочку
Если таких строк у тебя нет, тогда распакуй прикрепленный файл в корень p2ktools, заменив старый, и перезапусти прогу.
А также в телефоне: сообщ.-софт.клав.-настройка сообщ.-(автоочистка-нет)настройка сообщ.(изм.)-сохранить в: телефон.
Прикрепленный файл other_features__SnowArt_v1.7_.zip   ( 8.27 килобайт ) Кол-во скачиваний: 89
Qwest
сообщение 12.1.2007, 13:33
Из: Краснодар
naykava
Спасибки тебе, все получилось!!! =) Просто у меня было включено удаление при смене симки!!! Жаль что не могу поставить +, мало постов пока! =( Но большое человеческое СПАСИБО!!!
dsedelnikov
сообщение 13.1.2007, 20:39
Пользователь №: 70 385
Прошивка: elektro255_v0.2_49R
Может кто проверял: на прошивках от электро работают ли пункты меню "темы", IM и т.д.?
А то возиться напрасно нет желания
deadmoto
сообщение 14.1.2007, 9:16
Главный Новостник
Из: Омск
Пользователь №: 49 284
Модель телефона: Motorola
Прошивка: Motorola Original
dsedelnikov, зачем они тебе??? Если надо - включи, не надо выключи... 5 кнопок нажать...
Эти настройки есть в P2K Menu Editor'e...
dsedelnikov
сообщение 14.1.2007, 10:33
deadmoto,
спасибо, знаю.
Doktor Кот
сообщение 14.1.2007, 12:58
Из: Красноярск
Пользователь №: 94 751
Прошивка: Electro_R373...49R
Всем здрасте! А почему в проше от Электро в настройках настаивается интелект - клавиша для фотокамеры, а не которая с левой нижней стороны? Как это поправить? А еще как на этой проше дуалбут запустить? Еще хочу спросить, какая проша от Электро самая хорошая, самая стабильная и новее: 79R или 49R?
deadmoto
сообщение 14.1.2007, 17:19
Главный Новостник
Из: Омск
Запускаем P2K Tools > Seem Editor > 005b_0001
Находим строку 010... По этой строке столбец 05 это кнопка слева, 06 - кнопка справа...
В архиве найдёшь значения клавиш... У меня 010х05 стоит 42, 010х06 стоит 3F...
Желаю удачи, пробуй...
После некоторых раздумий... Если всё же поставиш на инт.клавишу корелет(код 42), то он будет вызываться из любого места в телефонеsmile.gif Т.е. аналог такой же кнопки не Е1...
Я тебе сейчас -2 дам Запрещено выпрашивать рейтинг
Сообщение отредактировал deadmoto - 15.1.2007, 7:08
Bent
сообщение 15.1.2007, 5:17
MoTo Marvellous
Пользователь №: 63 874
Doktor Кот,
Зажимаешь "Зелёную кнопку" и буквально на секунду(отрывистым движением) нажимаешь "Красную"(Зелёную держишь всё время,не отпуская) Само собой проделывать это в выключенном состоянии.
На мой взгляд лучше 49R79R много заморочек(хотя,сейчас посмотрим что там за RC3 выйдет),НО на 79R безлимитное видео.
AgentSlash
сообщение 15.1.2007, 12:35
Из: Ukraine, Kyiv
Пользователь №: 46 621
Модель телефона: HTC Touch Diamond
Цитата(Doktor Кот @ Воскресенье, 14 Января 2007, 14:58)
.......Еще хочу спросить, какая проша от Электро самая хорошая, самая стабильная и новее: 79R или 49R?
Всё таки 79 получше будет. Токо ставить тебе лучше не голую електровскую прошу, а какой нить настроеный и пропатченый монстрик. Советую подождать симбу от Арчи (RC3).
Doktor Кот
сообщение 15.1.2007, 15:38
Из: Красноярск
Deadmoto, спасибо! Помог! лови + И за отзывы спасибо всем! Еще столкнулся с такой проблемой: изначально на проше от Электро стоит 2 скина: WindowsXp_olive и просто WindoаsXp. Заметил, что эти два скина - полные. WindowsXp_olive - это главный скин, мне он не нравится и я его удалил. И теперь когда я заливаю какой-нибудь другой скин, больший по размеру чем скин WindowsXp, этот скин (а он конечно же неполный) становится главным и пропадают пункты меню! А как сделать родной скин Windowsxp - главным?
BackgaMan
сообщение 15.1.2007, 17:29
Мотоумелец
ММА попробуй от этого скина закинь.
Bent
сообщение 16.1.2007, 4:51
MoTo Marvellous
Doktor Кот,
Открываешь через p2ktools папку со скином,выделяешь все файлы внутри папки Windowsxp,ставишь им атрибут - "Системный",перезагружаешься.
PATRON2002
сообщение 17.1.2007, 20:04
Из: Ростов-на-Дону
Дайте плиззз патч для передачи ЯВЫ по блютузу через папку видео....
deadmoto
сообщение 17.1.2007, 20:52
Главный Новостник
Из: Омск
PATRON2002, Держи...
PATRON2002
сообщение 18.1.2007, 18:03
Из: Ростов-на-Дону
Глюк с отправкой смс! Поставил более мелкий шрифт..........И почемуто когда отправляешь смс,то получателю приходят только знаки припинания.Да и на родном ленге смс не отправляются. А латинские буквы доходят нормально.
*НеХеR*
сообщение 18.1.2007, 20:58
Пользователь №: 74 787
Прошивка: 2.3.4
PATRON2002,
Ну уже не раз писали по всему мотофану, в п2к тулзе, в "скрытых настройках" включи "юникод в смс" и все.. если что не ясно, то поищи по форуму.
go-blin
сообщение 22.1.2007, 17:40
Из: Башкирия,Октябрьский
Пользователь №: 48 665
Модель телефона: i900
Прошивка: WM6.5.3
Мне кажется, что тема переходит во флуд. Дайте патч, дайте ленг. Все необходимое для доводки находится в соответствующих темах. Пора чистить!
Ты сам то не флуди,твоё сообщение по твоему информативное? Не волнуйся,когда нужно почистим.
Сообщение отредактировал Bent - 23.1.2007, 7:05
RXLexus
сообщение 23.1.2007, 18:53
Пользователь №: 115 240
Прошивка: electro v0.3
Подскажите, как фойти в меню опкодов? Просто хочу восстановить утерянные вх-исх вызовы.. через опеод прочитал на форуме делается. Вот что пишут...
"Делается через опкоды 47 - 421(422) - 1- 0 - 2 - 255255 - перегруз."
Bent
сообщение 24.1.2007, 5:55
MoTo Marvellous
RXLexus, Войти так: Меню + 048263 + * или Меню + 0
Maxval
сообщение 25.1.2007, 18:03
Из: Perm
Пользователь №: 67 892
Модель телефона: E 398
Прошивка: MotoWalkman49R EM
I just done reversing both 46R and 49R elektro's MP with manually applied RSA patch ... I found that elektro really did something to the firmware CG1 area. I hope these files works on ROKR as it did on E398.
NOTE : these files might brick your phone since it was fully patched from the original elektro's MP manually. Both files do not contain a language pack. Please make a backup before flashing. Flash these at your own risk.
1) elektro's v0.3 46R for E1 with RSA patch (46R fullflash excluding LP)
2)elektro's v0.3 49R for E1 with RSA patch и еще одна ссыла
3) elektro's v0.3 flexlash (extracted from v0.3 49R) -> if you just want the flex.
All files are in .shx format and can be flash using any flasher software you have.
If these files are worthless (bricking the phone,etc), I will remove them as soon as possible.
regards
note : all credits should go to the MP makers for their passion on making such wonderful MPs. I am just trying to help others enjoying their work.
цитата aze2learn с motomodders
gadzellist
сообщение 27.1.2007, 20:26
Из: ростов-на-дону
Пользователь №: 111 586
Модель телефона: e 1
Прошивка: New Standart
поставил прошивку,и на некоторых ява приложениях на карте памяти стало писать что 'приложение истекло.проверьте дату и время в исходныхнастройках' что нужно сделать,чтобы заработало????
-mak-
сообщение 28.1.2007, 6:08
Из: Город-герой Волгоград
Пользователь №: 56 604
Модель телефона: qtek s200
regards
Сделана CG1 от электро портирована для оригинального РОКР Е1, написано, что тестовая версия, кто не боится - пусть пробует, шьется чем угодно. Прошивка не содержит лэнга
Если работает - сообщите
РАБОТАЕТ. Протестировано Don Omar. С неё можно слезть обратно стандартным монстром для Е1 (полным)
Сообщение отредактировал AlexKooper - 2.2.2007, 11:23
Neo31337
сообщение 1.2.2007, 19:20
Из: Зеон
Пользователь №: 115 765
Модель телефона: RokR E1 без ТП
Прошивка: Elektro 255 49R
Ждем тестов очень!!! На всяк случай скачайте ато вдруг им взбредет файл удалить...
czShaDoW
сообщение 7.2.2007, 21:29
Пользователь №: 117 034
Прошивка: Mpx_e398[Final]_49R
Помогите сделать с помощью опкодов на рокр е1 60 исх и вхд, заранее спасибо!
Valeo
сообщение 7.2.2007, 21:31
Going eternally
Из: Україна. м. Чернігів
Пользователь №: 46 805
Модель телефона: 1
Дата поощрения/наказания
Включение отображения 60 входящих/исходящих вызовов через опкод
60 Входящих
Bxoдим в мeню "Opcode"
жмем
Meню
затем 048263*
Bвoдим знaчeния:
Opcode "47" "OK"
Field 1 "80" "OK"
Field 2 "1" "OK"
Field 3 "143" "OK"
Field 4 "1" "OK"
Field 5 (D) "060" "OK" (понятно, что 060 - это 60 вызовов, можно 020 - будет 20 вызовов)
->Oтkaт: Field 5 (D) "010" "OK"
Results
F1 : 0 перезагрузка телефона
60 Исходящих
Opcode "47" "OK"
Field 1 "80" "OK"
Field 2 "1" "OK"
Field 3 "147" "OK"
Field 4 "1" "OK"
Results
Neo31337
сообщение 8.2.2007, 8:56
Из: Зеон
Все я поставил! все отлично работает даже СИГ ЭРРОР не дало! Смею заметить что у меня РокР Е1 без ТП! фонарик потестил. Скины мне не нравятся но я их заменю ДРМ тоже так себе надо бует доделать вид отправки сообщений тид итп. Мне лично нравяться с 2Pac Революшн Мода. Ждите постов от меня как потестю выдам результаты. Шиться мона без проблем, не забывая о бекапе.
Doktor Кот
сообщение 8.2.2007, 10:18
Из: Красноярск
Чет от Электро ничего не слышно и не видно! Кто нить знает, когда что нибудь новенькое Электро выдаст?
deadmoto
сообщение 8.2.2007, 13:35
Главный Новостник
Из: Омск
Doktor Кот, следующее скорее всего будет в т.ц. на V360.
X3MAL
сообщение 8.2.2007, 16:52
Из: Украина, Александрия
Пользователь №: 79 325
Модель телефона: MotoMing
Прошивка: Antarex Mod 14R
А при прошивке Е1 на него также можна будет патчи ставить?
Яуген
сообщение 8.2.2007, 17:04
Пользователь №: 101 871
X3MAL, он только для е398:)
Maxval
сообщение 8.2.2007, 19:06
Из: Perm
X3MAL,
можно, только скачай версию для е1
Текстовая версия Сейчас: 26.7.2025, 23:32
