23 страниц V « < 12 13 14 15 > »
Elektro255 V0.4 alpha 4 mod (4xR), 44R,46R,49R,79R
elektro255
сообщение 23.9.2006, 12:06 Закрепленное сообщение!
Из: Poland, Siedlce
Пользователь №: 53 130
09-04-2007
V0.4a4 Alpha: http://elektro255.ovh.org
08-04-2007
V0.4a3 Alpha: http://elektro255.ovh.org
07-04-2007
V0.4a2 44R Alpha: http://elektro255.ovh.org
20-12-2006
V0.3 79R Final mod: http://elektro255.ovh.org
27-11-2006
v0.3 for 49R Final mod http://elektro255.ovh.org/
26-11-2006
V0.3 46R Final mod: http://elektro255.ovh.org
НА Е1 Rokr с бутом 0А02 (оригинальный) НЕ ПОСТАВИТЕ БЕЗ Т.П.!
V0.4 alpha 4
Changes:
- Fixed problem with display timeout (fullscreen clock) when SMS/CALL received
Features:
- 4xR and 7xR MIX (use with 4xR flex)
- unlimited Video recording
- keypad automatic lock
- low battery alarm can be turned off or depend on ring style.
- Scheduled Ring Styles (ring style and funlight style can change automatically on given time and week day)
- flashlight shortcut (##)
- extra menu (shortcut *1 [shortcut is only for testing later will be changed])
- automatic menu enter, without sim card (emergency calls working too)
- new Java methods
- settings are stored on files
- no simlock checking
- Volume-bar sound can be turned off
- multiple menus (every skin can have one mma_ucp)
- Ported patches:
o SMS report significantly turned ON
o more folders in OBEX via BT
o removed unused folders from TransFlash
o Java have access to system files
o increased iTap user dictionary size
o no delete incall on SIM replace
o Bluetooth time changed to 3 minutes
o reordered camera store menu (store only is first)
o SMS alert is using default ringtone
OLD versions(V0.1-0.3):
Firmware changes:
- firmware based on 46R from StarterXP MP
- FULL SW access from Java
- LUMA&CHROMA tables moved to memory - now you can change JPEG compresion from Java
- StarterXP flex
- added dualboot
Flasher changes:
- if you have PDS_4013 flasher will no recreate this
Personalization tool changes:
- first version for 0.3_46R SW mod
- changing splash screen
- changing font (you can use *.fnt or *.smg CG4 files)
- you can turn on, turn off menu access without sim cart
- changing my shortcuts
Новая версия V0.4 alpha 4
Изменения:
- Устранена проблема с таймаутом дисплея(полноэкранные часы) при приеме смс/звонка
Новое:
- Прошивка создана как микс 4xR и 7xR (флекс 4xR ) В 44R она переименована для совместимости! Она близко не лежит к 44R на самом деле!
- Безлимитная запись видео (64мб макс как в 6х7х)
- Автоблок клавиатуры
- Звук разряженой батареи можно выключать или задать стилем оповещения(?).
- Расписание стилей оповещения (стиль оповещения и фанлайтмогут менятся автоматически по времени и дням недели)
- Фонарик по (##)
- Дополнительное меню (метка *1 [только для теста, после может изменится])
- Автоматический вход в меню без сим-карты (аварийные звонки работают)
- Новые методы в Яве (не от 79R, а новые)
- Настройки хранятся в файлах
- Не проверяется лоченость ПДС на симку (работает с лоченым пдс)
- Звук изменения громкости можно отключить
- Мультименю (каждый скин может иметь собственный мма_уцп)
- Портированы патчи:
o Оповещение о доставке SMS всегда вкл.
o больше папок доступно по OBEX из блютуза
o удалены неиспользуемые папки с флешки
o Полный доступ к системным файлам из явы
o увеличен размер пользовательского словаря iTap
o не удалыются последние вызовы при смене сим
o Время обнаружения блютуза - 3 минуты
o Меню сохранения видеозаписи (просто сохранить - первым пунктом)
o при приходе SMS играет "мелодия на смс", а не установленная на этого пользователя
Для версий 0.1-0.3
Изменения в прошивке:
- Создана на базе монстра StarterXP 46R
- Полный доступ к прошивке (симы, озу) из явы
- Таблицы сжатия фотографий перенесены в озу - теперь из явы можно управлять качеством фотографий (сжатием)
- флекс StarterXP
- добавлен дуалбут
Изменения флешера:
-Если ПДС версии 4013 (373 платформа), ПДС не пересоздается.
Изменения персонализации (Personalization tool):
- впервые для мода использована 46 прошивка
- замена заставки (на включение?)
- замена шрифта (лангпак, CG4)
- можно вкл. и выкл. доступ к меню без сим-карты
- изменен ярлык (копирайт?)
Для работы Personalization tool требуется положить в папку программы несжатый бинарный бэкап (32 мегабайта) под именем SW.bin
Прекращаем флудить, типа а когда выйдет новая версия, и.т.д.и.т.п, или придётся наказывать!
тему почистил, архив по 1 декабря тут:
Прикрепленный файл MotoFan_ru_electro.zip   ( 66.56 килобайт ) Кол-во скачиваний: 3902
Сообщение отредактировал elektro255 - 9.4.2007, 12:21
SANYO_K
сообщение 20.3.2007, 0:58
Пользователь №: 64 324
Модель телефона: ROKR E1 (E398)
Прошивка: elektro255!!! 49r
What about SMSBackUp? Does it work on this version of 79r?
Doktor Кот
сообщение 20.3.2007, 2:14
Из: Красноярск
Пользователь №: 94 751
Прошивка: Electro_R373...49R
Вот, вот, без SMSBackUp я даже и не подумаю эту прошивку ставить. Да и глюков в ней много.
66_ЛЁХА_99
сообщение 20.3.2007, 3:13
Пользователь №: 108 652
Модель телефона: Motorola ZN5
Прошивка: R6637 G 81 03 0ER
iTap в русском шрифте не работает, он есть, но никаких слов не знает!!! Устанавливал другие лэнги, но ничего не меняется sad.gif
При попытке назначить на клавишу джойстик вверх будильник, телефон переходит в ребут unsure.gif
Вправо поставил стили оповещений, но там так и осталась основная настройка, после перезагрузки всё стало как надо stink.gif
Сообщение отредактировал 66_ЛЁХА_99 - 20.3.2007, 3:19
Bent
сообщение 20.3.2007, 5:39
MoTo Marvellous
Пользователь №: 63 874
Собственно, считаю лучшим модом был 0.2 Final, остальные 0.3 и теперь уже 0.4 черезчур навороченные и по моему убеждению половину функций, если не больше вообще не нужно...
79R проигрышный вариант, большинство пользователей не будет ставить мод 0.4, максимум поставят и откатятся.
P.S. Хотя уже с полгода пользуюсь стандартной 49R подредактированной под себя и меня всё устраивает...
Сообщение отредактировал Bent - 20.3.2007, 5:40
Vadim Velikii
сообщение 20.3.2007, 5:59
Пользователь №: 102 604
Модель телефона: ROKR_E398, v360, v8
Прошивка: 49E.m.
Вот-вот! На 49R мод 0.3 можно было эффект вибрации во время проигрывания музыки включить/выключить, и звук мгновенно менялся, а теперь для этого приходится телефон перезагружать!
И вообще, есть те, кому нравятся 7хRпрошивки, и есть те, кому нравится 4xR.
Мне нравится 49я. Так что присоединяюсь ко всем, кто просит сделать мод на 49R!
Сообщение отредактировал Vadim Velikii - 20.3.2007, 10:52
kemre
сообщение 20.3.2007, 7:25
Пользователь №: 121 096
Прошивка: LP 49R
а если тока рефлеш зашить, будет ли новая "Технология" работать?
Халдей
сообщение 20.3.2007, 7:26
Пользователь №: 42 573
Модель телефона: mpx220
Прошивка: 351 sp2
Мне мод понравился, так как телефон старый я рад хоть что то на него делают новое, несмотря на то что большинство фич я неиспользую
Trentemoller
сообщение 20.3.2007, 9:39
Из: Армавир
Пользователь №: 105 953
Прошивка: R373_G_0E.30.49R
Bent,
Полностью тебя поддерживаю, 0.2 мод был самый удачный, в плане качества. В 0.3 были странные глюки с камерой, поставил, посмотрел и откатился сразу же обратно на 0.2. Про 0.4 говорить пока ниче небуду, т.к. это альфа версия еще очень сырая и недоработанная. Чтож будем просить electro, чтобы убирал все стандартные и нестандартные глюки с 0.4 мода или просить сделать его на базе 49r.
_TRANE_
сообщение 20.3.2007, 11:58
MOTOmeloMAN
Из: New_Oskol_City(Бел.Область)
Пользователь №: 104 202
Модель телефона: E398+KOSS The PLUG
Прошивка: MPX 398 DeLuXe
Парни чё вым всем так не нравится 79r раньше я был на 49r (elektro mod 0.3b) но недели 2 назад поставил симбу 79r и чё? АФИГЕЕНННАЯ ПРОША даже если на 79r если вам не нравится что звук тихий то отредактируйте Gain,Param_table через MV и звук по громкости и качеству звучания такой же как и на
49r ,но +анлим видео+скорость.Тем более что elektro сказал, что батарею держит как на 49r!!!
=BazOOka=
сообщение 20.3.2007, 12:20
Пользователь №: 107 478
Модель телефона: rokr e2
Прошивка: 4AP
QUOTE(_TRANE_ @ 20.3.2007, 14:58) *
Кому что но 49R хочется! Можно долго спорить и сравнивать эти 2 базы и каждый будет доказывать что одна лучше другой... Вопрос в том будет ли 49 или нет?
HUNTER_ok
сообщение 20.3.2007, 12:26
Из: Заозерный webstream :D
Пользователь №: 106 065
Модель телефона: SE W810i
Я тоже потдерживаю TRANE'а, 79R прошивка во многом рулит, MS RC3 лучший из монстров, который я устанавливал. Tim2005 говорил, что в ней есть новые классы для корелетов. Масса преимуществ. Да ведь новая прошивка должна быть лучше.
Сообщение отредактировал HUNTER_ok - 20.3.2007, 12:26
Valeo
сообщение 20.3.2007, 14:54
Going eternally
Из: Україна. м. Чернігів
Пользователь №: 46 805
Модель телефона: 1
Дата поощрения/наказания
Т.е. мнение автора вас не интересует?
Цитата(elektro255 @ Вчера, 15:13)
не будет 49R, теперь только я буду заниматься 79R (звук дастся сделать)
Сообщение отредактировал Valeo - 20.3.2007, 14:57
=BazOOka=
сообщение 20.3.2007, 16:49
Прошивка: 4AP
Valeo, а вдруг electro255 над нами сжалится и все-таки сделает 49? unsure.gif
San3k
сообщение 20.3.2007, 18:00
Пользователь №: 108 480
Модель телефона: Nokia 5310; E398
Прошился - доволен. Для альфа-версии очень даже ничего. Скорость высокая (особенно с пониженными таймингами), звук отличный. Короче почти всё ОК, жду бету smile.gif
DarkNeo
сообщение 20.3.2007, 20:09
Пользователь №: 93 559
Модель телефона: Nokia 6680
всё же....что делать с этим:
Elektro255 V0.4 alpha mod
без GPRS не могу...откатился на v0.3..
Мачо
сообщение 21.3.2007, 7:58
Из: Киров
Пользователь №: 8 569
Прошивка: Dream A Reality 2.0
Попробуйте залить сертификаты от T_mobile может пойдёт gprs
gunghost
сообщение 21.3.2007, 12:27
Пользователь №: 71 735
Прошивка: Всегда самая лудшая
Это как?
v_leon
сообщение 21.3.2007, 12:31
МотоДизайнер
Из: Россия, Бийск
Пользователь №: 47 326
Модель телефона: e398 v3i v220 vtW740
Прошивка: mpx
Медиавьювер отказался восстанавливать справочник. Сказал, что файл бэкапа отсутствует. Попробовал раскидать бэкап во все места, где он (теоретически может находится) не помогло. Без справочника как-то грустно стало. Когда еще и ЖПРС не захотел работать я еще раз с тоской прошелся по новому меню, попереключал фичи и откатился на v 0.2... Буду ждать стабильной версии... Хотелось бы таки на 49r... sad.gif
А в целом, фичи интересные и уместные.
PS может кто-нибудь шапку поправит? Electro похоже не до этого...
_TRANE_
сообщение 21.3.2007, 14:32
MOTOmeloMAN
А когда примерно выйдет BETA ?
=BazOOka=
сообщение 21.3.2007, 15:07
Прошивка: 4AP
QUOTE(_TRANE_ @ 21.3.2007, 17:32) *
Ну в первом же посте написано:
QUOTE
Никто кроме electro255 не знает (а может и он тоже не знает)! Если не терпится знать, пиши в личку.
_26_
сообщение 21.3.2007, 19:06
Пользователь №: 90 123
Модель телефона: E 398
Прошивка: Electro255_mod_v_0.2
установи МВ с сайта - все будет нормально работать.
Без инета плохо - откатываюсь
screamer2k
сообщение 21.3.2007, 19:54
Пользователь №: 62 070
Модель телефона: L7e
Прошивка: без RSA
да... что инета нет это жестоко... кстати, сегодня нашёл такие глюки - проверьте, есть ли у кого. попробуйте поменять Базовые клавиши - вверх-вниз-влево-вправо. телефон 4 раза уходил в перезагрузку. в чём проблема-не пойму. потом, когда мне удалось всё настроить, телефон САМ ИХ СБРОСИЛ! thumbdown.gif
=BazOOka=
сообщение 21.3.2007, 20:03
Прошивка: 4AP
screamer2k, глюк с базовыми клавишами у кого-то тоже был:
QUOTE
При попытке изменить базовую клавишу вверх - тело тоже перезагружается.
Сообщение отредактировал bazooka47 - 21.3.2007, 20:04
сильвер398
сообщение 21.3.2007, 22:06
Из: Донецк
Пользователь №: 114 125
Модель телефона: Nokia 5700
поддерживаю всех кто за 49R!последний симбиан-супер,несмотря на глюки!звук на ней даж лучше чем на49R!но вот батарея меня просто достала-откатился на 49R electro255!этот мод качать пока не стану-без инета ну никак не могу как и все остальные мотофановцы!
linxun
сообщение 22.3.2007, 1:22
Пользователь №: 108 892
Модель телефона: MOTO V3I
Прошивка: R47A_G_08_D9.3DR
elektro255
Menu "Engineering" to Chinese?
Сергей_Motofan
сообщение 22.3.2007, 7:52
Из: г. Оренбург
Пользователь №: 85 146
Прошивка: CM 12.1 5.1.1
..::MotoLife::..
Прошивка классная, звук тож настроен отлично!!! clap.gif clap.gif Но без аси я себе жизни не представляю... sad.gif Откатываюсь на 0.2 thumbsup.gif
San3k
сообщение 23.3.2007, 16:38
Электро255 писал, что батарея будет держать как на 49R... А у меня она продержалась всего один день... (на v0.3 у меня держал примерно 2.5-3 дня)
juicedddd
сообщение 23.3.2007, 17:09
Из: Сыктывкар
Пользователь №: 77 458
Модель телефона: ~E398~
Прошивка: Dream a reality_79R
Патчи для этой проши ~~~Тема~~~
nsk_modder
сообщение 23.3.2007, 20:12
Из: Новодвинск
Пользователь №: 92 444
Модель телефона: Z6
Прошивка: Самосбор
ВСЕМ СЕМ ВСЕМ у кого нет выбора места хранения принятого файла.
Делаем так открываем П2Ктулз выбираем сим редактор прописаваем в поле num 0032 rec 0001
жмем считать из телефона там появится таблица с кучей крякозяблов. выбираем по вертикали 0А0 по горизонтали 0Е и на пересечении выбираем квадратик снимаем галочку с второго бита. жмем записать в телефон и радуемся жизни. Эскиз прикрепляю что должно выйти
Сообщение отредактировал Crazy Modder - 23.3.2007, 20:20
San3k
сообщение 24.3.2007, 10:16
Сегодня на сайте elektro255 появился баг-трекер...
Lup
сообщение 25.3.2007, 7:21
Пользователь №: 102 082
Модель телефона: L7;L9
Прошивка: А фто это? О_о
У меня с английским плохо! Ну что там с ДЖПРс не кто не придумал как исправить этот баг? Блин я так понял что ДЖПРс то работает, а вот ДЖПРс и ява как раз доит сбой!
=BazOOka=
сообщение 25.3.2007, 9:28
Прошивка: 4AP
Lup, напиши что спросить, я переведу.
Lup
сообщение 25.3.2007, 9:53
http://elektro255.ovh.org/bugtracker/
вот тут чё то написано про то что ЖПРС не работает. Может там написано как исправить? ph34r.gif
Добавлено позже (25.3.2007, 14:25):
Valeo
сообщение 25.3.2007, 10:29
Going eternally
Модель телефона: 1
Цитата(Lup @ Сегодня, 10:53)
Выложите пожалуста описание чего новго в новой версии
Пост 466
=BazOOka=
сообщение 25.3.2007, 14:39
Прошивка: 4AP
О GPRS: в багтрекере отписывались что это из-за прав java.
O java: (из багтрекера)
QUOTE
ok, in this weekend i will temporarily restore oryginal permissions
ОК, на этих выходных я перезалью оригинальные права.
Ждите.
Lup
сообщение 25.3.2007, 18:02
ок спасибо. Ребят, отпишитесь как там чё нового появиться. =) просто я не бельмес эти иностранные языки, русский то плохо знаю smile.gif
igorrius
сообщение 28.3.2007, 11:23
Пользователь №: 56 062
Прошивка: 49r
здравствуйте!
очень прошу проверить следующую вещь:
в папку джава к играм на флеху закинте не установленное ява приложение, затем в списке игр флехи внизу выберите " установить новое" и выберите скопированный вами джар файл, по идее он должен установиться.
но у меня на 49 Электро 02 пишет не верный файл....
а функция это нужная, поэтому прошу проверить, может на какой то версии работает.
Valeo
сообщение 28.3.2007, 20:09
Going eternally
Модель телефона: 1
Подтверждаю - v3 (монстр new_standart_by_Алекс75) - установил только 2 игрухи вышеописанным образом. Все работает. Игры устанавливаются и соответсвенно запускаются.
mutacipa
сообщение 29.3.2007, 11:19
Из: г. Мариуполь
Пользователь №: 93 127
Модель телефона: E1
Прошивка: Mpx398_DeLuxe
Но какие то глюки:
1. Нет доступа к файловой системе sad.gif Только с корелета.
2. Не редактируется назначения клавиш(а можно редактировать это с компьютера и чем?)
Было бы круто если то меню "ТЕСТ РЕЖИМ" можно было б назначить на кнопку "ВЫКЛ".
igorrius
сообщение 30.3.2007, 8:53
Прошивка: 49r
на монстрах от Электро нормально принимаются ммс?
дело в том , что с некоторыми монстрами на флеше от Электро идет сим для приема ммс...
кто знает, с чем это связано?
я на одном из таких монстров сейчас, хоть сим и ставил, а ммс принять не могу.... sad.gif
а с монстрами от электро такого сима и нет... прошу проверить прием ммс
и еще маленький вопросик забыл..:
есть ли какая то принципиальная разница между версиями монстров от Элктро(02 03 04а)?
я имею ввиду в плане применения патчей.
если я сейчас сижу на монстре с флешем от Эектро 02 версии, и применил патч для улучшения
фотоснимков из одноименной темы ветки о патчах, то смогу ли я применить этот же патч к той же 49, но уже с флешем
03 от Электро?
Сообщение отредактировал igorrius - 31.3.2007, 9:39
Текстовая версия Сейчас: 23.7.2025, 2:58
