23 страниц V < 1 2 3 4 > »
Elektro255 V0.4 alpha 4 mod (4xR), 44R,46R,49R,79R
elektro255
сообщение 23.9.2006, 12:06 Закрепленное сообщение!
Из: Poland, Siedlce
Пользователь №: 53 130
09-04-2007
V0.4a4 Alpha: http://elektro255.ovh.org
08-04-2007
V0.4a3 Alpha: http://elektro255.ovh.org
07-04-2007
V0.4a2 44R Alpha: http://elektro255.ovh.org
20-12-2006
V0.3 79R Final mod: http://elektro255.ovh.org
27-11-2006
v0.3 for 49R Final mod http://elektro255.ovh.org/
26-11-2006
V0.3 46R Final mod: http://elektro255.ovh.org
НА Е1 Rokr с бутом 0А02 (оригинальный) НЕ ПОСТАВИТЕ БЕЗ Т.П.!
V0.4 alpha 4
Changes:
- Fixed problem with display timeout (fullscreen clock) when SMS/CALL received
Features:
- 4xR and 7xR MIX (use with 4xR flex)
- unlimited Video recording
- keypad automatic lock
- low battery alarm can be turned off or depend on ring style.
- Scheduled Ring Styles (ring style and funlight style can change automatically on given time and week day)
- flashlight shortcut (##)
- extra menu (shortcut *1 [shortcut is only for testing later will be changed])
- automatic menu enter, without sim card (emergency calls working too)
- new Java methods
- settings are stored on files
- no simlock checking
- Volume-bar sound can be turned off
- multiple menus (every skin can have one mma_ucp)
- Ported patches:
o SMS report significantly turned ON
o more folders in OBEX via BT
o removed unused folders from TransFlash
o Java have access to system files
o increased iTap user dictionary size
o no delete incall on SIM replace
o Bluetooth time changed to 3 minutes
o reordered camera store menu (store only is first)
o SMS alert is using default ringtone
OLD versions(V0.1-0.3):
Firmware changes:
- firmware based on 46R from StarterXP MP
- FULL SW access from Java
- LUMA&CHROMA tables moved to memory - now you can change JPEG compresion from Java
- StarterXP flex
- added dualboot
Flasher changes:
- if you have PDS_4013 flasher will no recreate this
Personalization tool changes:
- first version for 0.3_46R SW mod
- changing splash screen
- changing font (you can use *.fnt or *.smg CG4 files)
- you can turn on, turn off menu access without sim cart
- changing my shortcuts
Новая версия V0.4 alpha 4
Изменения:
- Устранена проблема с таймаутом дисплея(полноэкранные часы) при приеме смс/звонка
Новое:
- Прошивка создана как микс 4xR и 7xR (флекс 4xR ) В 44R она переименована для совместимости! Она близко не лежит к 44R на самом деле!
- Безлимитная запись видео (64мб макс как в 6х7х)
- Автоблок клавиатуры
- Звук разряженой батареи можно выключать или задать стилем оповещения(?).
- Расписание стилей оповещения (стиль оповещения и фанлайтмогут менятся автоматически по времени и дням недели)
- Фонарик по (##)
- Дополнительное меню (метка *1 [только для теста, после может изменится])
- Автоматический вход в меню без сим-карты (аварийные звонки работают)
- Новые методы в Яве (не от 79R, а новые)
- Настройки хранятся в файлах
- Не проверяется лоченость ПДС на симку (работает с лоченым пдс)
- Звук изменения громкости можно отключить
- Мультименю (каждый скин может иметь собственный мма_уцп)
- Портированы патчи:
o Оповещение о доставке SMS всегда вкл.
o больше папок доступно по OBEX из блютуза
o удалены неиспользуемые папки с флешки
o Полный доступ к системным файлам из явы
o увеличен размер пользовательского словаря iTap
o не удалыются последние вызовы при смене сим
o Время обнаружения блютуза - 3 минуты
o Меню сохранения видеозаписи (просто сохранить - первым пунктом)
o при приходе SMS играет "мелодия на смс", а не установленная на этого пользователя
Для версий 0.1-0.3
Изменения в прошивке:
- Создана на базе монстра StarterXP 46R
- Полный доступ к прошивке (симы, озу) из явы
- Таблицы сжатия фотографий перенесены в озу - теперь из явы можно управлять качеством фотографий (сжатием)
- флекс StarterXP
- добавлен дуалбут
Изменения флешера:
-Если ПДС версии 4013 (373 платформа), ПДС не пересоздается.
Изменения персонализации (Personalization tool):
- впервые для мода использована 46 прошивка
- замена заставки (на включение?)
- замена шрифта (лангпак, CG4)
- можно вкл. и выкл. доступ к меню без сим-карты
- изменен ярлык (копирайт?)
Для работы Personalization tool требуется положить в папку программы несжатый бинарный бэкап (32 мегабайта) под именем SW.bin
Прекращаем флудить, типа а когда выйдет новая версия, и.т.д.и.т.п, или придётся наказывать!
тему почистил, архив по 1 декабря тут:
Прикрепленный файл MotoFan_ru_electro.zip   ( 66.56 килобайт ) Кол-во скачиваний: 3902
Сообщение отредактировал elektro255 - 9.4.2007, 12:21
BackgaMan
сообщение 12.11.2006, 15:19
Мотоумелец
Пользователь №: 61 651
Модель телефона: E-398 Htc-p3300
Цитата(Doktor Кот @ Воскресенье, 12 Ноября 2006, 18:12)
Люди, а эту прошивку можно поставить на оригинальный E1?
Прежде эту тему почитай Прошивка Оригинального Rokr E1 С Бутом 0а.02
elektro255
сообщение 23.11.2006, 12:09
Из: Poland, Siedlce
I''m back (exams passed) :D
new beta http://elektro255.ovh.org/
~Gangs2er~
сообщение 24.11.2006, 6:26
MotoSkinner
Пользователь №: 93 787
Модель телефона: (M) E398
Прошивка: У вас такой нету))
Переведите пожалусто вот это:
Цитата(elektro255 @ Суббота, 23 Сентября 2006, 15:06)
23-11-2006 New beta v0.3b is avaible
V0.2
Change log:
- fixed bug with mainmenu access in java aplets
- now kyeypad autolock working full stable
- fast menu access without SIM card by pressing *5
- fixed bug with flashlight (when writing SMS flashalight will no turn on)
- new java plugin in MV to change extra feauters settings
- new flex (updated MV, only stable skins, 178 SMS storage, unlimited calls history...)
- SW now is tested and it is FULL STABLE
- fixed bugs in Flasher.exe, removed all files from program dir, and decreased size of exe file to 247kB
И вот это:
Цитата(elektro255 @ Пятница, 24 Ноября 2006, 0:18)
I used "cut empty bytes" in FB so i will upload right file later
lv333
сообщение 24.11.2006, 8:06
Из: Украина, Киев
Пользователь №: 45 916
Прошивка: СМ 10
Первая часть уже переводилась, страницы полистай, это относится к версии 0.2 которая не бета.
А вторая в свободном, переводе конечно, :) звучит примерно так:
Я использовал "вырезать пустые байты" (прим. для тех кто не знает такая функция есть в флешбекапе), потом загружу правильные файлы.
Bent
сообщение 24.11.2006, 8:25
MoTo Marvellous
Пользователь №: 63 874
ну что непонятного-косяченно собрал или выложил прошивку человек...исправит и выложит нормальную версию...ждём.
Вот изменения v0.3b
Change log:
working *#06# (but no *5)
now you can change SW name
you can change boot splash screen (except website adress on bottom)
you can change JPEG compression (quality) on camera from Java (I will make java app to do this) [later I will make changing of mp4 video bitrate when recording]
Тут в принципе и переводить не нужно кто хотя бы немного знает англ. язык всё поймёт :) Ну а так вообще переведите кто силён.
lv333
сообщение 24.11.2006, 9:09
Из: Украина, Киев
Прошивка: СМ 10
Вот изменения v0.3b
Change log:
Для тех кто с английским вообще не дружит :) http://www.promt.ru/
Собственно вот без коррекций как есть :)
Регистрация изменения: работа * *06 * (но Номер *5) теперь Вы можете изменить КОРОТКОВОЛНОВОЕ название, Вы можете изменить экран всплеска ботинка (кроме адреса вебсайта на основании), Вы можете изменить сжатие JPEG (качество) на камере из Явы (я сделаю явское приложение, чтобы сделать это) [позже, я сделаю изменение mp4 видео bitrate, делая запись]
elektro255
сообщение 24.11.2006, 10:02
Из: Poland, Siedlce
http://rapidshare.com/files/4612313/elektr...eflash.rar.html anybody can test this reflash ?
juicedddd
сообщение 26.11.2006, 11:40
Из: Сыктывкар
Пользователь №: 77 458
Модель телефона: ~E398~
Прошивка: Dream a reality_79R
Меняем Bootscreen в прошивке R373_0.2(49R)-=elektro255=-
34 ПОСТ
elektro255
сообщение 26.11.2006, 12:24
Из: Poland, Siedlce
new SW will be today :) maybe at 7-11pm GMT+001
now I'm making personalization program :)
Screen from develop: http://img134.imageshack.us/my.php?image=programeh6.jpg
elektro255
сообщение 26.11.2006, 20:12
Из: Poland, Siedlce
вы дождались :D
Today I'm very tired so I uploading SW without Java apps and plugins. Later I will make plugin for iTunes and MV 0.32 and app to change quantization tables.
Firmware changes:
- StarterXP flex
- added dualboot
Flasher changes:
About boot screen change:
You can change boot screen except link to my website on bottom.
About LUMA&CHROMA tables:
Luma & chroma tables is at 0x127E5040.
You can't turn off quantization compression because camera shows "File to big"
Quantization tables you can find here: http://www.impulseadventure.com/photo/jpeg...on.html?src1=77
About full acces from Java:
I'm added JMP intrstruction from JAVA:
public static void jmp(int address)
where parameter is adress to any procedure on flash or RAM.
If you will JMP to procedure in Thumb code you must add 1 to adress, if you will make jump to ARM cde don't increment.
All procedures must have reurn (BX LR).
If you making another jump from procedure you must save linkregister on stack PUSH {LR}.
This function is only for assembler programmers, or somebody who want teach ASM for ARM processors :)
To upload your code to RAM you can use Writebyte() from my lib, your code can use RAM to swap data between Java and ASM code.
Utility of this function:
You can use this for ultra fast low level calculations in Java :)
You can execute any exists procedure with any parameters (very usefull for discovering new motorola procedures)
You can make ASM compiler for ARM processor :D
You can inject and execute any code by Java (for example to erase and flash NV memory in phone :P)
zolookas
сообщение 26.11.2006, 21:01
Пользователь №: 43 073
Прошивка: R373_G_0E.30.49R
Зеркало
Rapishare:
http://rapidshare.com/files/4946318/elektr....3_46R.rar.html
Fastshare:
http://www.FastShare.org/download/elektro2...od_v0.3_46R.rar
Megaupload:
http://www.megaupload.com/?d=PNCVRJ7E
Elektro255, i've enabled flash menu (by the way it's access, not acces)
And *5 opens IMEI, not menu.
Anyway congrats on new version clap;applo
elektro255
сообщение 27.11.2006, 13:57
Из: Poland, Siedlce
Electro255 всего лишь сказал что 46 р ему просто понравилась :) но дальнейшие модификации будут на 49 р
v0.3 on 49R will be today :) and maybe later for 79R I maked SW for 46R because i like StarterXP MP :) I'm using only exists flexes because for me making flex is very boring
zolookas
сообщение 27.11.2006, 16:10
Цитата(p00p0k @ Tuesday, 28 November 2006, 4:36)
Ребят ну в конце то концов кто прошился! Выложите яву с него!
http://slil.ru/23478111
elektro255
сообщение 27.11.2006, 16:40
Из: Poland, Siedlce
http://elektro255.ovh.org/final.php v0.3 for 49R
~Gangs2er~
сообщение 27.11.2006, 18:07
MotoSkinner
Я прошил только рефлэш, потверждаю всё работает, тело не умерло!!! Шил 3м флэш бэкапом.
Народ, кто проьётся монстром выложите яву!!!
ЗЫ: Ощутил как прибавилась скорость с прошлого рефлэша, воще улёёёт!!! :)
Больше ничё нового не заметил!
p00p0k, прога выдаёт какую то ошибку sw.bin not fownd.
ТЕ надо конвертить прошиву в bin чтоли? Кто разобрался в проге, объясните как её юзать! :)
JaneAir
сообщение 27.11.2006, 18:27
Пользователь №: 101 260
Прошивка: R373_G_OE.30.48R
Поставил я этот монстр(49R) и заметил,что когда фотка сохраняется,то получается что-то вроде вот этого:
P.S Где настраивается качество картинки?
p00p0k
сообщение 27.11.2006, 18:59
Пользователь №: 95 690
Прошивка: electro255
Вот ссылка на моснтр: rapidshare.com
Подробности во время прошивки фул-флешем через Flasher
21:26:00 BOOT verion: 07D0
21:26:00 SW Version: R373_0.2 (49R)-=elektro255=-
21:26:00 Sending loader
21:26:02 Reading PDS
21:26:09 Unpacking PDS
21:26:12 PDS update skipped
21:28:30 Sending loader
21:28:32 Erasing flash. It can take 5 minutes.
21:33:44 Sending SW
21:37:33 --==Finished==--
Все в порядке!
Java-плиложения забираем в прикреплённых файлах!
Там АБСОЛЮТНО вся Java с этого монстра!
А я же сейчас откатываюсь и прошиваюсь рефлешем
с последующей установкой
всех Java-приложений с фул-флеша!
Между прочим! ТАКОЙ скорости я не видал НИ ГДЕ просто улёёёёт!
~Gangs2er~,
Для начало надо скинуть прошивку в папку с файлом Flasher чтобы он обнаружил прошивку.... А потом шейся!
elektro255
сообщение 27.11.2006, 19:30
Из: Poland, Siedlce
Personalization tool workin only with binary full backup (make backup and then copy this backup as SW.bin to program directory)
in 49R i'm maked one mistake because in my code is wrong Luma offset, patch to fix that:
deleted
after this patch luma and chroma tables is at 0x127E5040
StrIk3r
сообщение 27.11.2006, 19:44
Из: Великий Новгород
Пользователь №: 53 936
Модель телефона: E398@ROKR_E1_iTunes
Прошивка: R373...49R
elektro255,
patch not fixed problem with foto
StrIk3r
сообщение 27.11.2006, 20:00
elektro255,
[Patch_Code]
********:04040404040404040404040404040404040404040404040404040404040404040404040404040404040404040404040404040404040404041b182023202c2c3a
may be you did error in offset
it is default bits for Luma_Qtable, but foto too bad :(
elektro255
сообщение 27.11.2006, 20:02
Из: Poland, Siedlce
i forget to decrese adressz by 80000 in patch code :D
good patch code is :
[Patch_Info]
Description=change LUMA offset
Author=elektro255
Version=1.0
[Patch_Code]
B9D7F8: 127E5040
StrIk3r
сообщение 27.11.2006, 20:10
Вот патч
я еще сам не успел проверить
Прикрепленный файл 49R_JPEGPC_LUMA_QTABLE.zip   ( 265 байт ) Кол-во скачиваний: 33
Amenti
сообщение 27.11.2006, 20:11
Из: Беларусь, Гомель
Пользователь №: 43 607
Модель телефона: e398 с дыркой под ТП
Прошивка: симба 1.5b
просто создайте файл с расширением .fpa. Запишите в него эти сторочки
[Patch_Info]
Author=elektro255
Version=1.0
[Patch_Code]
B9D7F8: 127E5040
и примените.
Фотки становятся номальными.
А видео у меня тело еще ни разу так не снимало!!!!! Респект!!!!
StrIk3r
сообщение 27.11.2006, 20:26
Раньше у меня намного фоты были лучше а сейчас все замылиные какие-то
Прикладываю как было на 48 со своим патчем на фото
electro255 why did you replace only 4 bits in your patch for foto
once upone a time I replaced all 64 bits for 48r
sorry for my english
Dimka
сообщение 27.11.2006, 22:01
МотоКовырятель
Из: Волгоград
Пользователь №: 39 255
elektro255! How it works? And as it to use. Explain more in detail.
syzspectroom
сообщение 27.11.2006, 23:14
Пользователь №: 74 826
Прошивка: R373_G_0E.30.48R
вот зеркала http://rapidshare.com/files/5097921/elektr...od_v0.3_49R.rar
http://www.webfile.ru/1211181
http://ifolder.ru/518489
http://www.megaupload.com/?d=Z6H693XV
http://www.upload.com.ua/get/777872319/
Мачо
сообщение 28.11.2006, 7:14
Из: Киров
Пользователь №: 8 569
Прошивка: Dream A Reality 2.0
Сенсор (камера) И Работа С Ним
elektro255, в прошивке несколько таблиц квантования. в той теме всё расписано.
*НеХеR*
сообщение 28.11.2006, 7:29
Пользователь №: 74 787
Прошивка: 2.3.4
Это опять я! Так и не удается докачать рефлэш.. качать заново накладно очень. Поэтому просьба: кто качал рефлеш по ссылке с сайта электро, откройте сам рар архив с помощью какого нить хекс редактора и скопируйте блок, начиная с 0017с700 по 001FD390
и выложите его плиз где нибудь. Очень надо.
З.Ы. + не пожалею
motobaltazor
сообщение 28.11.2006, 11:48
Пользователь №: 101 001
Прошивка: 49R
З.Ы. + не пожалею
0017c700.rar
p.s.
Пользовался "winhex'ом 13.5"
elektro255
сообщение 28.11.2006, 21:37
Из: Poland, Siedlce
JPEG Quantization fix & tool & comparison (for 49R only)
Simple Java application to change quantization tables in memory. (source included)
New FIX for camera foto quality (to apply use FlashBackup v2.6x)
An little comparison of different tables.
http://elektro255.ovh.org/files/JPEQ_Quantization.rar
Ктулху
сообщение 28.11.2006, 22:47
Moto К†улху
Из: Свердловская область
Пользователь №: 26 696
Модель телефона: Motorola Dyna-Tac
Народ Сори за Прикрепленное изображение !!!!!!!
но рейтинг elektro255 мона повышать не на английском а на родном ему польском языке ;)
Сцылка на переводчик ;)
Bent
сообщение 29.11.2006, 3:59
MoTo Marvellous
Crestopher, У меня Касперский 6.0,сегодня обновил базы вирусов---вирусов он не нашёл.
Теперь бы очень хотелось узнать что даёт эта программа которую выложил electro255 и как ей пользоватся?
P.S. кстати по умолчанию в прошивке выключен Юни-код в СМС...вообще ужас...ребята включайте его или будут приходить и уходить пустые смс :)
Вот правленный seem 32(без всяких ик-портов и т.д.)
Сообщение отредактировал Bent - 29.11.2006, 8:27
motobaltazor
сообщение 29.11.2006, 10:17
Прошивка: 49R
Цитата(Stranger @ Среда, 29 Ноября 2006, 11:06)
Выложите, пожалуйста, рефлеш 49r(версия 0.3). На сайте elektro255 хоть и есть ссылка, но по ней файл недоступен.
Вот выложил рефлеш на рапиду:
elektro255_mod_v0.3_49R_reflash.rar
motobaltazor
сообщение 29.11.2006, 12:20
Прошивка: 49R
zerrow, на сайте elektro лежит патч, который должен исправить глюк с фотками. Вот ссылка на него: fix_jpg_bug.rar
*НеХеR*
сообщение 29.11.2006, 14:25
Прошивка: 2.3.4
т.к. обычными прогами его не прошьёшь он с расширение *BIN
Мдя.. И это пишет человек с рейтингом 13 bigsmile; . Тот же самый фб 2.62 его прошьет.
ну да ладно..
Ну так кто нить ответит, как поставить через прогу Personalize фонарик на # и красная кнопка
Кстати кто какой уровень сжатия выставляет в яве ?
думаю все у кого есть флешка (даже не важно какого размера) ставят максимальное качество снимков = минимальное сжатие.. ИМХО
Сообщение отредактировал *НеХеR* - 29.11.2006, 14:29
StrIk3r
сообщение 29.11.2006, 18:55
Вот нашел адреса которые использует electro255 для изменения качества фотоснимков:
00A05AAA - LUMA_QTABLE
00A05AEA - CHROMA_QTABLE
Что бы проэкспериментировать необходимо написать патч вида:
[Patch_Info]
Description=JPEG quality
Author=your name
Version=your version
[Patch_Code]
00A05AAA:******
00A05AEA:******
Где ******** это ваши 64 байта (64*2=128) т.е. необходимо заменить 128 байт в CG1.SMG.
Ссылку на сайт с таблицами квантования уже писали в этой теме таблицы можно взять оттуда,
вся проблема в локе на размер получаемого фотоснимка ~80kb, возможно этот размер задан в симах а возможно и в прошивке так что остается копать копать и еще раз копать
optima
сообщение 29.11.2006, 22:44
Пользователь №: 16 563
Прошивка: 82R;wm6,5;4BR
Цитата(Алекс75 @ Среда, 29 Ноября 2006, 21:34)
Я что то не совсем догоняю насчет Personalization....Она не запускается выдает ошибку типо прошивка не поддерживается...Я закинул в папку с прогой свой фулл переименовал его в SW после чего стала вылетать другая ошибка,наконец я вытащил из фулл бекапа CG1 и попробовал снова запустить прогу в результате чего - ошибка приложения.Кто нить пользовался Personalization,если да то как?
Только что разобрался. Автор немного ошибся и выложил Personalization для 46R. SW от 46R открыл без проблем.
Bent
сообщение 30.11.2006, 9:03
MoTo Marvellous
Вот вам для 49R...
Алекс75 , я делал так,в папку с программой закинул свой бекап(расширении BIN) переименовал его в SW,запустил прогу всё сделал и прошил Flasher
gendos@xaker.ru
сообщение 30.11.2006, 9:59
Из: Угадай по аватару
Пользователь №: 16 679
Модель телефона: С651&RAZRV3&E398
Прошивка: GendosMonsterpack
Господа, только сейчас заметил, что перестала работать фотокамера.Изображение
Пишет что-то типа: обращение к камере невозможно.
Кто нибудь сталкивался или нет.
Откат на бекпы не помогает. Ставить пробовал разные версии прош от Elektro
Nogay
сообщение 30.11.2006, 13:23
Из: Фёдоровка, Сургутский район
Пользователь №: 83 007
Прошивка: Mpx398 De Luxe
У меня в ява-приложении на 4-ке фотки фесят 65кб, а на 11-ти весят 40кб. Т.е. до 4-ки качество увеличивается, а после 4-ки ухудшается.
off_topic; Извините, какие симы надо править чтобы в фотокамере была не экспозиция, а яркость?
Текстовая версия Сейчас: 2.8.2025, 1:33
