23 страниц V « < 12 13 14 15 > »
Elektro255 V0.4 alpha 4 mod (4xR), 44R,46R,49R,79R
elektro255
сообщение 23.9.2006, 12:06 Закрепленное сообщение!
Из: Poland, Siedlce
Пользователь №: 53 130
09-04-2007
V0.4a4 Alpha: http://elektro255.ovh.org
08-04-2007
V0.4a3 Alpha: http://elektro255.ovh.org
07-04-2007
V0.4a2 44R Alpha: http://elektro255.ovh.org
20-12-2006
V0.3 79R Final mod: http://elektro255.ovh.org
27-11-2006
v0.3 for 49R Final mod http://elektro255.ovh.org/
26-11-2006
V0.3 46R Final mod: http://elektro255.ovh.org
НА Е1 Rokr с бутом 0А02 (оригинальный) НЕ ПОСТАВИТЕ БЕЗ Т.П.!
V0.4 alpha 4
Changes:
- Fixed problem with display timeout (fullscreen clock) when SMS/CALL received
Features:
- 4xR and 7xR MIX (use with 4xR flex)
- unlimited Video recording
- keypad automatic lock
- low battery alarm can be turned off or depend on ring style.
- Scheduled Ring Styles (ring style and funlight style can change automatically on given time and week day)
- flashlight shortcut (##)
- extra menu (shortcut *1 [shortcut is only for testing later will be changed])
- automatic menu enter, without sim card (emergency calls working too)
- new Java methods
- settings are stored on files
- no simlock checking
- Volume-bar sound can be turned off
- multiple menus (every skin can have one mma_ucp)
- Ported patches:
o SMS report significantly turned ON
o more folders in OBEX via BT
o removed unused folders from TransFlash
o Java have access to system files
o increased iTap user dictionary size
o no delete incall on SIM replace
o Bluetooth time changed to 3 minutes
o reordered camera store menu (store only is first)
o SMS alert is using default ringtone
OLD versions(V0.1-0.3):
Firmware changes:
- firmware based on 46R from StarterXP MP
- FULL SW access from Java
- LUMA&CHROMA tables moved to memory - now you can change JPEG compresion from Java
- StarterXP flex
- added dualboot
Flasher changes:
- if you have PDS_4013 flasher will no recreate this
Personalization tool changes:
- first version for 0.3_46R SW mod
- changing splash screen
- changing font (you can use *.fnt or *.smg CG4 files)
- you can turn on, turn off menu access without sim cart
- changing my shortcuts
Новая версия V0.4 alpha 4
Изменения:
- Устранена проблема с таймаутом дисплея(полноэкранные часы) при приеме смс/звонка
Новое:
- Прошивка создана как микс 4xR и 7xR (флекс 4xR ) В 44R она переименована для совместимости! Она близко не лежит к 44R на самом деле!
- Безлимитная запись видео (64мб макс как в 6х7х)
- Автоблок клавиатуры
- Звук разряженой батареи можно выключать или задать стилем оповещения(?).
- Расписание стилей оповещения (стиль оповещения и фанлайтмогут менятся автоматически по времени и дням недели)
- Фонарик по (##)
- Дополнительное меню (метка *1 [только для теста, после может изменится])
- Автоматический вход в меню без сим-карты (аварийные звонки работают)
- Новые методы в Яве (не от 79R, а новые)
- Настройки хранятся в файлах
- Не проверяется лоченость ПДС на симку (работает с лоченым пдс)
- Звук изменения громкости можно отключить
- Мультименю (каждый скин может иметь собственный мма_уцп)
- Портированы патчи:
o Оповещение о доставке SMS всегда вкл.
o больше папок доступно по OBEX из блютуза
o удалены неиспользуемые папки с флешки
o Полный доступ к системным файлам из явы
o увеличен размер пользовательского словаря iTap
o не удалыются последние вызовы при смене сим
o Время обнаружения блютуза - 3 минуты
o Меню сохранения видеозаписи (просто сохранить - первым пунктом)
o при приходе SMS играет "мелодия на смс", а не установленная на этого пользователя
Для версий 0.1-0.3
Изменения в прошивке:
- Создана на базе монстра StarterXP 46R
- Полный доступ к прошивке (симы, озу) из явы
- Таблицы сжатия фотографий перенесены в озу - теперь из явы можно управлять качеством фотографий (сжатием)
- флекс StarterXP
- добавлен дуалбут
Изменения флешера:
-Если ПДС версии 4013 (373 платформа), ПДС не пересоздается.
Изменения персонализации (Personalization tool):
- впервые для мода использована 46 прошивка
- замена заставки (на включение?)
- замена шрифта (лангпак, CG4)
- можно вкл. и выкл. доступ к меню без сим-карты
- изменен ярлык (копирайт?)
Для работы Personalization tool требуется положить в папку программы несжатый бинарный бэкап (32 мегабайта) под именем SW.bin
Прекращаем флудить, типа а когда выйдет новая версия, и.т.д.и.т.п, или придётся наказывать!
тему почистил, архив по 1 декабря тут:
Прикрепленный файл MotoFan_ru_electro.zip   ( 66.56 килобайт ) Кол-во скачиваний: 3902
Сообщение отредактировал elektro255 - 9.4.2007, 12:21
Сергей_Motofan
сообщение 22.3.2007, 7:52
Из: г. Оренбург
Пользователь №: 85 146
Прошивка: CM 12.1 5.1.1
..::MotoLife::..
Прошивка классная, звук тож настроен отлично!!! clap.gif clap.gif Но без аси я себе жизни не представляю... sad.gif Откатываюсь на 0.2 thumbsup.gif
San3k
сообщение 23.3.2007, 16:38
Пользователь №: 108 480
Модель телефона: Nokia 5310; E398
Электро255 писал, что батарея будет держать как на 49R... А у меня она продержалась всего один день... (на v0.3 у меня держал примерно 2.5-3 дня)
juicedddd
сообщение 23.3.2007, 17:09
Из: Сыктывкар
Пользователь №: 77 458
Модель телефона: ~E398~
Прошивка: Dream a reality_79R
Патчи для этой проши ~~~Тема~~~
nsk_modder
сообщение 23.3.2007, 20:12
Из: Новодвинск
Пользователь №: 92 444
Модель телефона: Z6
Прошивка: Самосбор
ВСЕМ СЕМ ВСЕМ у кого нет выбора места хранения принятого файла.
Делаем так открываем П2Ктулз выбираем сим редактор прописаваем в поле num 0032 rec 0001
жмем считать из телефона там появится таблица с кучей крякозяблов. выбираем по вертикали 0А0 по горизонтали 0Е и на пересечении выбираем квадратик снимаем галочку с второго бита. жмем записать в телефон и радуемся жизни. Эскиз прикрепляю что должно выйти
Сообщение отредактировал Crazy Modder - 23.3.2007, 20:20
San3k
сообщение 24.3.2007, 10:16
Сегодня на сайте elektro255 появился баг-трекер...
Lup
сообщение 25.3.2007, 7:21
Пользователь №: 102 082
Модель телефона: L7;L9
Прошивка: А фто это? О_о
У меня с английским плохо! Ну что там с ДЖПРс не кто не придумал как исправить этот баг? Блин я так понял что ДЖПРс то работает, а вот ДЖПРс и ява как раз доит сбой!
=BazOOka=
сообщение 25.3.2007, 9:28
Пользователь №: 107 478
Модель телефона: rokr e2
Прошивка: 4AP
Lup, напиши что спросить, я переведу.
Lup
сообщение 25.3.2007, 9:53
http://elektro255.ovh.org/bugtracker/
вот тут чё то написано про то что ЖПРС не работает. Может там написано как исправить? ph34r.gif
Добавлено позже (25.3.2007, 14:25):
Valeo
сообщение 25.3.2007, 10:29
Going eternally
Из: Україна. м. Чернігів
Пользователь №: 46 805
Модель телефона: 1
Дата поощрения/наказания
Цитата(Lup @ Сегодня, 10:53)
Выложите пожалуста описание чего новго в новой версии
Пост 466
Elektro255 V0.4 alpha mod
=BazOOka=
сообщение 25.3.2007, 14:39
Прошивка: 4AP
О GPRS: в багтрекере отписывались что это из-за прав java.
O java: (из багтрекера)
QUOTE
ok, in this weekend i will temporarily restore oryginal permissions
ОК, на этих выходных я перезалью оригинальные права.
Ждите.
Lup
сообщение 25.3.2007, 18:02
ок спасибо. Ребят, отпишитесь как там чё нового появиться. =) просто я не бельмес эти иностранные языки, русский то плохо знаю smile.gif
igorrius
сообщение 28.3.2007, 11:23
Пользователь №: 56 062
Прошивка: 49r
здравствуйте!
очень прошу проверить следующую вещь:
в папку джава к играм на флеху закинте не установленное ява приложение, затем в списке игр флехи внизу выберите " установить новое" и выберите скопированный вами джар файл, по идее он должен установиться.
но у меня на 49 Электро 02 пишет не верный файл....
а функция это нужная, поэтому прошу проверить, может на какой то версии работает.
Valeo
сообщение 28.3.2007, 20:09
Going eternally
Модель телефона: 1
Подтверждаю - v3 (монстр new_standart_by_Алекс75) - установил только 2 игрухи вышеописанным образом. Все работает. Игры устанавливаются и соответсвенно запускаются.
mutacipa
сообщение 29.3.2007, 11:19
Из: г. Мариуполь
Пользователь №: 93 127
Модель телефона: E1
Прошивка: Mpx398_DeLuxe
Но какие то глюки:
1. Нет доступа к файловой системе sad.gif Только с корелета.
2. Не редактируется назначения клавиш(а можно редактировать это с компьютера и чем?)
Было бы круто если то меню "ТЕСТ РЕЖИМ" можно было б назначить на кнопку "ВЫКЛ".
igorrius
сообщение 30.3.2007, 8:53
Прошивка: 49r
на монстрах от Электро нормально принимаются ммс?
дело в том , что с некоторыми монстрами на флеше от Электро идет сим для приема ммс...
кто знает, с чем это связано?
я на одном из таких монстров сейчас, хоть сим и ставил, а ммс принять не могу.... sad.gif
а с монстрами от электро такого сима и нет... прошу проверить прием ммс
и еще маленький вопросик забыл..:
есть ли какая то принципиальная разница между версиями монстров от Элктро(02 03 04а)?
я имею ввиду в плане применения патчей.
если я сейчас сижу на монстре с флешем от Эектро 02 версии, и применил патч для улучшения
фотоснимков из одноименной темы ветки о патчах, то смогу ли я применить этот же патч к той же 49, но уже с флешем
03 от Электро?
Сообщение отредактировал igorrius - 31.3.2007, 9:39
mr.Voland
сообщение 1.4.2007, 0:13
Из: Краснодар
Пользователь №: 89 811
Модель телефона: iPhone3G16Gb
Прошивка: iOS4GM
igorrius, у меня elektromod v0.2, замечательно принемает и отправляет MMS, а также EMS. С чем связано, что у некоторых не работает MMS, я так думаю где-то при сборке допущена ошибка.
Насколько я знаю seem ставится для увилечения размера MMS + патч и в DNP файле надо прописать максимальные 500Кб(поюзай тему, там всё подробно расписано)
Координальной разницы между v0.2 и v0.3 нет, на них патчи одинаковые, я устанавливал себе патч для улучшения фотоснимков второй, т.к писали, что он лудший и всё прекрасно работает. Но моё личное мнение, что mod v0.2 более удачный и стабильный, если сравнивать с v0.3. А вот Elektro255 V0.4 alpha mod, он не только от v0.2 и v0.3, но и от тойже 79R elektromoda, очень даже отличается и у меня есть предчуствие, что комрад elektro_255 его наворотит круто thumbsup.gif , лишь бы не торопился и у него хватало время и терпение довести его до Relisa. smile.gif
Сергей_Motofan
сообщение 1.4.2007, 12:37
Из: г. Оренбург
..::MotoLife::..
Небольшой вопросик: В версии 0.2 от elektro255 при входе в мелодии или видео (но не запуская файлы) можно было регулировать громкость! А в других версиях этой фичи я не заметил! Как же это реализовать?? очень удобно!
Яуген
сообщение 1.4.2007, 13:55
Пользователь №: 101 871
Сергей_Motofan, а никак smile.gif Эта фича патолько во второй версии мода smile.gif
DIMM_an
сообщение 1.4.2007, 16:21
Из: Вишера. Пермский край
Пользователь №: 97 220
Модель телефона: Motorola E2!
Прошивка: MAXX IV
За любой кипишь,кроме голодовки!
самое навороченое было бы внедрение JSR82. Вот это было бы реально круто. да вообще крутого мона придумать многа. новые классы в яву. кто то что то о прогах грил которые напрямую к процу обращаются.. филы.. или силы.. от сименса короче.. Только реализуется сложно довольно. Я вот смотрю на электро и его моды. И думаю. А моторола случаем что думает о его рефлешах.. ну пусть даже мотосимбу возьмем. её бы в руки мотороле. они б новое тело выпустили. Motosymbian ГГ. не внатуре.. Первый раз пишу в этой теме.. и оффтоп один. Хоть поблагодарю АФФТАРА за все его труды по выжиманию из арм 66 мгц всего чо мона. Чего нет в самсунгах за 12000 рублей.(имею ввиду функциональность)
Valeo
сообщение 2.4.2007, 20:09
Going eternally
Модель телефона: 1
Хмммм..... в сборке чего? Дело то в том, что ММС прекрасно принимаются и отправляются. Проблема в сохраненнии картинки к примеру. Выбираешь сохранить и ничего не происходит. Проверь на ЕМ V2.
Угу...... так и помог бы "аффтару" по внедрению и "филов" и "силов".
VkD
сообщение 3.4.2007, 8:17
Пользователь №: 64 617
Прошивка: MS 1.5b
ph34r.gif что-то самого электро у нас не видно...
Timik
сообщение 3.4.2007, 12:50
Пользователь №: 100 902
Прошивка: даже не знаю теперь
Скачал я это тварение... боюсь что придется откатиться, из за отсутствия доступа к жпрс из явы. Это очень большой минус, может кто знает как это исправить...
kobr
сообщение 3.4.2007, 20:55
Из: Израиль
Пользователь №: 44 899
Модель телефона: rokr E2!
Прошивка: Casseopeya©
Да в новом моде вообще с жопорезом беда,даже в вап не заходит.Ну и там,сям глюки.Вобщем-то ничего новго в нём нет кроме добавления некоторых пунктов из синерджи,в меню телефона....
rem xxx
сообщение 4.4.2007, 9:15
Из: Бассейна
Пользователь №: 39 153
Модель телефона: c650/v220/L6/E398
Прошивка: самая новая
Вот чёпишут про Gprs на сайте electro255
by D@rkNeo the 25/03/07 - 00:19
NiKSY...I think, that it caused by first discovered bug - with Java permissions. GPRS is working OK, when you connect your phone to PC....but in Java apps GPRS is broken. So...there was no need to add a new bug to Bugtracker..
Bug WebSession not edit Homepage REPLY
by momo the 25/03/07 - 00:41
I have can not to print the letter , it gives can print individual the number
I something the way corrects to give it has can to elect printing , thank
gprs not works REPLY
by tuyie78 the 25/03/07 - 11:45
this cause by no java,certificate permission
dont know REPLY
by NiKSY the 25/03/07 - 18:17
I really dont know why, but its not working...
Bug 10 marked as a duplicate of this bug REPLY
by System the 25/03/07 - 21:39
Bug <a href="view_bug.php?bug_id=10" style="text-decoration: line-through;">10</a> has been marked as a duplicate of this bug.
=BazOOka=
сообщение 4.4.2007, 11:02
Прошивка: 4AP
rem xxx, но здесь не написано решение проблемы.
rem xxx
сообщение 4.4.2007, 11:05
Из: Бассейна
=BazOOka=,
Я не разбираюсьв английском, просто думал что тут есть что то полезное!
Кстати а что там нгаписано?
=BazOOka=
сообщение 4.4.2007, 11:07
Прошивка: 4AP
Раздумья на тему что это из-за прав java-приложений. Это они обосновали на том, что когда коннектишь мобилу к ПК, то ЖПРС работает.
волкOFF
сообщение 4.4.2007, 11:34
Из: Нижний Новгород
Пользователь №: 118 524
Модель телефона: E-398
Прошивка: Moto-Symbian RC3
это мне так кажется или в новой версии стал быстрее работать блютуз???
Timik
сообщение 4.4.2007, 11:50
Яуген
сообщение 4.4.2007, 11:59
волкOFF, классы блютуза он в новую версию не толкал, поэтому быстрее он стать никак не мог! smile.gif
rem xxx
сообщение 4.4.2007, 13:12
Из: Бассейна
=BazOOka=,
Значит надокаким то образом зделать это(в смысле что баботало) только как ?
=BazOOka=
сообщение 4.4.2007, 14:10
Прошивка: 4AP
QUOTE(rem xxx @ Today, 17:12)
Там решения не написано. Подождать electro255 с бетой пока нужно. Он наверное в ней выявленные баги устранит...
San3k
сообщение 7.4.2007, 9:58
Changes:
- 4xR with unlimited Video recording (4xR,7xR MIX [use with 4xR flex])
- fixed all reported bugs
- 20,40,60,120 second screen timeot
Изменения:
- 4xR с безлимитной видеосъёмкой (4xR,7xR MIX [флекс от 4xR])
- исправлены все найденые баги
- Активность дисплея 20, 40, 60 и 120 секунд
Сообщение отредактировал San3k - 7.4.2007, 10:17
=BazOOka=
сообщение 7.4.2007, 10:09
Прошивка: 4AP
QUOTE(San3k @ Today, 13:58)
- время подсветки 20, 40, 60 и 120 секунд
Мне кажется, что это стоит перевести как "время активности экрана", а не время подсветки.
BackgaMan
сообщение 7.4.2007, 11:44
Мотоумелец
Пользователь №: 61 651
Модель телефона: E-398 Htc-p3300
Меня интересует только на 44R?
Сообщение отредактировал BackgaMan - 7.4.2007, 11:48
screamer2k
сообщение 7.4.2007, 12:06
Пользователь №: 62 070
Модель телефона: L7e
Прошивка: без RSA
BackgaMan, а какая разница-то? по ходу Электро просто намешал 49 с 79, щас качаю прошьюсь, отпишусь
таакс я чёта не понял. кто скачивал? у меня архив битый получился. у меня одного так??
Сообщение отредактировал screamer2k - 7.4.2007, 12:13
Сергей_Motofan
сообщение 7.4.2007, 12:28
Из: г. Оренбург
..::MotoLife::..
Только смирился с тем что прошивка на базе 79R и вот тебе новость - теперь она на 44R stink.gif Первый раз такую прошу вижу (на 44R)... За безлимитное видео на 4xR прошах респект!!! Ждем 79R или 49R с безлимитным видео и работающим жопорезом.... clap.gif
San3k
сообщение 7.4.2007, 12:46
Короче первое впечатление не очень... флекс беспонтовый, звук заточен под выкл. эффект вибры, да и не очень он и хорош... Радует только то что электро исправил все найденые баги smile.gif а флекс и все остальное нужно подбирать под себя
ЗЫ видео безлимитное smile.gif - круто!
Сообщение отредактировал San3k - 7.4.2007, 12:50
kemre
сообщение 7.4.2007, 12:48
Пользователь №: 121 096
Прошивка: LP 49R
я прошил!! Флекс здесь от New_standart_by_Alex75!
видео и вправду анлимит! щас буду яву тестить
elektro255
сообщение 7.4.2007, 12:55
Из: Poland, Siedlce
не будет 49R ни 79R ни другой, v0.4a2 то MIX 79R, 4xR и OS от Vilko, в той версии достоинства всех версий
Текстовая версия Сейчас: 25.7.2025, 3:52
