23 страниц V « < 13 14 15 16 > »
Elektro255 V0.4 alpha 4 mod (4xR), 44R,46R,49R,79R
elektro255
сообщение 23.9.2006, 12:06 Закрепленное сообщение!
Из: Poland, Siedlce
Пользователь №: 53 130
09-04-2007
V0.4a4 Alpha: http://elektro255.ovh.org
08-04-2007
V0.4a3 Alpha: http://elektro255.ovh.org
07-04-2007
V0.4a2 44R Alpha: http://elektro255.ovh.org
20-12-2006
V0.3 79R Final mod: http://elektro255.ovh.org
27-11-2006
v0.3 for 49R Final mod http://elektro255.ovh.org/
26-11-2006
V0.3 46R Final mod: http://elektro255.ovh.org
НА Е1 Rokr с бутом 0А02 (оригинальный) НЕ ПОСТАВИТЕ БЕЗ Т.П.!
V0.4 alpha 4
Changes:
- Fixed problem with display timeout (fullscreen clock) when SMS/CALL received
Features:
- 4xR and 7xR MIX (use with 4xR flex)
- unlimited Video recording
- keypad automatic lock
- low battery alarm can be turned off or depend on ring style.
- Scheduled Ring Styles (ring style and funlight style can change automatically on given time and week day)
- flashlight shortcut (##)
- extra menu (shortcut *1 [shortcut is only for testing later will be changed])
- automatic menu enter, without sim card (emergency calls working too)
- new Java methods
- settings are stored on files
- no simlock checking
- Volume-bar sound can be turned off
- multiple menus (every skin can have one mma_ucp)
- Ported patches:
o SMS report significantly turned ON
o more folders in OBEX via BT
o removed unused folders from TransFlash
o Java have access to system files
o increased iTap user dictionary size
o no delete incall on SIM replace
o Bluetooth time changed to 3 minutes
o reordered camera store menu (store only is first)
o SMS alert is using default ringtone
OLD versions(V0.1-0.3):
Firmware changes:
- firmware based on 46R from StarterXP MP
- FULL SW access from Java
- LUMA&CHROMA tables moved to memory - now you can change JPEG compresion from Java
- StarterXP flex
- added dualboot
Flasher changes:
- if you have PDS_4013 flasher will no recreate this
Personalization tool changes:
- first version for 0.3_46R SW mod
- changing splash screen
- changing font (you can use *.fnt or *.smg CG4 files)
- you can turn on, turn off menu access without sim cart
- changing my shortcuts
Новая версия V0.4 alpha 4
Изменения:
- Устранена проблема с таймаутом дисплея(полноэкранные часы) при приеме смс/звонка
Новое:
- Прошивка создана как микс 4xR и 7xR (флекс 4xR ) В 44R она переименована для совместимости! Она близко не лежит к 44R на самом деле!
- Безлимитная запись видео (64мб макс как в 6х7х)
- Автоблок клавиатуры
- Звук разряженой батареи можно выключать или задать стилем оповещения(?).
- Расписание стилей оповещения (стиль оповещения и фанлайтмогут менятся автоматически по времени и дням недели)
- Фонарик по (##)
- Дополнительное меню (метка *1 [только для теста, после может изменится])
- Автоматический вход в меню без сим-карты (аварийные звонки работают)
- Новые методы в Яве (не от 79R, а новые)
- Настройки хранятся в файлах
- Не проверяется лоченость ПДС на симку (работает с лоченым пдс)
- Звук изменения громкости можно отключить
- Мультименю (каждый скин может иметь собственный мма_уцп)
- Портированы патчи:
o Оповещение о доставке SMS всегда вкл.
o больше папок доступно по OBEX из блютуза
o удалены неиспользуемые папки с флешки
o Полный доступ к системным файлам из явы
o увеличен размер пользовательского словаря iTap
o не удалыются последние вызовы при смене сим
o Время обнаружения блютуза - 3 минуты
o Меню сохранения видеозаписи (просто сохранить - первым пунктом)
o при приходе SMS играет "мелодия на смс", а не установленная на этого пользователя
Для версий 0.1-0.3
Изменения в прошивке:
- Создана на базе монстра StarterXP 46R
- Полный доступ к прошивке (симы, озу) из явы
- Таблицы сжатия фотографий перенесены в озу - теперь из явы можно управлять качеством фотографий (сжатием)
- флекс StarterXP
- добавлен дуалбут
Изменения флешера:
-Если ПДС версии 4013 (373 платформа), ПДС не пересоздается.
Изменения персонализации (Personalization tool):
- впервые для мода использована 46 прошивка
- замена заставки (на включение?)
- замена шрифта (лангпак, CG4)
- можно вкл. и выкл. доступ к меню без сим-карты
- изменен ярлык (копирайт?)
Для работы Personalization tool требуется положить в папку программы несжатый бинарный бэкап (32 мегабайта) под именем SW.bin
Прекращаем флудить, типа а когда выйдет новая версия, и.т.д.и.т.п, или придётся наказывать!
тему почистил, архив по 1 декабря тут:
Прикрепленный файл MotoFan_ru_electro.zip   ( 66.56 килобайт ) Кол-во скачиваний: 3902
Сообщение отредактировал elektro255 - 9.4.2007, 12:21
VkD
сообщение 3.4.2007, 8:17
Пользователь №: 64 617
Прошивка: MS 1.5b
ph34r.gif что-то самого электро у нас не видно...
Timik
сообщение 3.4.2007, 12:50
Пользователь №: 100 902
Прошивка: даже не знаю теперь
Скачал я это тварение... боюсь что придется откатиться, из за отсутствия доступа к жпрс из явы. Это очень большой минус, может кто знает как это исправить...
kobr
сообщение 3.4.2007, 20:55
Из: Израиль
Пользователь №: 44 899
Модель телефона: rokr E2!
Прошивка: Casseopeya©
Да в новом моде вообще с жопорезом беда,даже в вап не заходит.Ну и там,сям глюки.Вобщем-то ничего новго в нём нет кроме добавления некоторых пунктов из синерджи,в меню телефона....
rem xxx
сообщение 4.4.2007, 9:15
Из: Бассейна
Пользователь №: 39 153
Модель телефона: c650/v220/L6/E398
Прошивка: самая новая
Вот чёпишут про Gprs на сайте electro255
by D@rkNeo the 25/03/07 - 00:19
NiKSY...I think, that it caused by first discovered bug - with Java permissions. GPRS is working OK, when you connect your phone to PC....but in Java apps GPRS is broken. So...there was no need to add a new bug to Bugtracker..
Bug WebSession not edit Homepage REPLY
by momo the 25/03/07 - 00:41
I have can not to print the letter , it gives can print individual the number
I something the way corrects to give it has can to elect printing , thank
gprs not works REPLY
by tuyie78 the 25/03/07 - 11:45
this cause by no java,certificate permission
dont know REPLY
by NiKSY the 25/03/07 - 18:17
I really dont know why, but its not working...
Bug 10 marked as a duplicate of this bug REPLY
by System the 25/03/07 - 21:39
Bug <a href="view_bug.php?bug_id=10" style="text-decoration: line-through;">10</a> has been marked as a duplicate of this bug.
=BazOOka=
сообщение 4.4.2007, 11:02
Пользователь №: 107 478
Модель телефона: rokr e2
Прошивка: 4AP
rem xxx, но здесь не написано решение проблемы.
rem xxx
сообщение 4.4.2007, 11:05
Из: Бассейна
=BazOOka=,
Я не разбираюсьв английском, просто думал что тут есть что то полезное!
Кстати а что там нгаписано?
=BazOOka=
сообщение 4.4.2007, 11:07
Прошивка: 4AP
Раздумья на тему что это из-за прав java-приложений. Это они обосновали на том, что когда коннектишь мобилу к ПК, то ЖПРС работает.
волкOFF
сообщение 4.4.2007, 11:34
Из: Нижний Новгород
Пользователь №: 118 524
Модель телефона: E-398
Прошивка: Moto-Symbian RC3
это мне так кажется или в новой версии стал быстрее работать блютуз???
Timik
сообщение 4.4.2007, 11:50
Яуген
сообщение 4.4.2007, 11:59
Пользователь №: 101 871
волкOFF, классы блютуза он в новую версию не толкал, поэтому быстрее он стать никак не мог! smile.gif
rem xxx
сообщение 4.4.2007, 13:12
Из: Бассейна
=BazOOka=,
Значит надокаким то образом зделать это(в смысле что баботало) только как ?
=BazOOka=
сообщение 4.4.2007, 14:10
Прошивка: 4AP
QUOTE(rem xxx @ Today, 17:12)
Там решения не написано. Подождать electro255 с бетой пока нужно. Он наверное в ней выявленные баги устранит...
San3k
сообщение 7.4.2007, 9:58
Пользователь №: 108 480
Модель телефона: Nokia 5310; E398
Changes:
- 4xR with unlimited Video recording (4xR,7xR MIX [use with 4xR flex])
- fixed all reported bugs
- 20,40,60,120 second screen timeot
Изменения:
- 4xR с безлимитной видеосъёмкой (4xR,7xR MIX [флекс от 4xR])
- исправлены все найденые баги
- Активность дисплея 20, 40, 60 и 120 секунд
Сообщение отредактировал San3k - 7.4.2007, 10:17
=BazOOka=
сообщение 7.4.2007, 10:09
Прошивка: 4AP
QUOTE(San3k @ Today, 13:58)
- время подсветки 20, 40, 60 и 120 секунд
Мне кажется, что это стоит перевести как "время активности экрана", а не время подсветки.
BackgaMan
сообщение 7.4.2007, 11:44
Мотоумелец
Пользователь №: 61 651
Модель телефона: E-398 Htc-p3300
Меня интересует только на 44R?
Сообщение отредактировал BackgaMan - 7.4.2007, 11:48
screamer2k
сообщение 7.4.2007, 12:06
Пользователь №: 62 070
Модель телефона: L7e
Прошивка: без RSA
BackgaMan, а какая разница-то? по ходу Электро просто намешал 49 с 79, щас качаю прошьюсь, отпишусь
таакс я чёта не понял. кто скачивал? у меня архив битый получился. у меня одного так??
Сообщение отредактировал screamer2k - 7.4.2007, 12:13
Сергей_Motofan
сообщение 7.4.2007, 12:28
Из: г. Оренбург
Пользователь №: 85 146
Прошивка: CM 12.1 5.1.1
..::MotoLife::..
Только смирился с тем что прошивка на базе 79R и вот тебе новость - теперь она на 44R stink.gif Первый раз такую прошу вижу (на 44R)... За безлимитное видео на 4xR прошах респект!!! Ждем 79R или 49R с безлимитным видео и работающим жопорезом.... clap.gif
San3k
сообщение 7.4.2007, 12:46
Короче первое впечатление не очень... флекс беспонтовый, звук заточен под выкл. эффект вибры, да и не очень он и хорош... Радует только то что электро исправил все найденые баги smile.gif а флекс и все остальное нужно подбирать под себя
ЗЫ видео безлимитное smile.gif - круто!
Сообщение отредактировал San3k - 7.4.2007, 12:50
kemre
сообщение 7.4.2007, 12:48
Пользователь №: 121 096
Прошивка: LP 49R
я прошил!! Флекс здесь от New_standart_by_Alex75!
видео и вправду анлимит! щас буду яву тестить
elektro255
сообщение 7.4.2007, 12:55
Из: Poland, Siedlce
не будет 49R ни 79R ни другой, v0.4a2 то MIX 79R, 4xR и OS от Vilko, в той версии достоинства всех версий
San3k
сообщение 7.4.2007, 13:00
ЗЫ у меня стали громко щелкать динамики, когда я листаю джойстиком, у меня у одного так? Это даже с выключеным звуком клавиатуры.
Люди, а какие в OS от Vilko фичи есть?
Сообщение отредактировал San3k - 7.4.2007, 13:06
=BazOOka=
сообщение 7.4.2007, 13:03
Прошивка: 4AP
Please, write in details what is "faster OS core by Vilko"?
QUOTE(San3k @ Today, 17:00)
Отключи эффект вибрацией.
Сообщение отредактировал =BazOOka= - 7.4.2007, 13:04
San3k
сообщение 7.4.2007, 13:10
он у меня и так выключен, это не из-за этого...
kemre
сообщение 7.4.2007, 13:11
Прошивка: LP 49R
San3k, у меня тож самое!
elektro255
сообщение 7.4.2007, 13:24
Из: Poland, Siedlce
=BazOOka=, Vilko just fully rewritten (optymalized) VRTX (Real Time OS for ARM)
San3k
сообщение 7.4.2007, 13:31
elektro255, can you delete Volume-change-sound in next version of your mod?
___________________
Кстати, а какие сюда нужны настройки звука? для 49R или именно для 44R?
Сообщение отредактировал San3k - 7.4.2007, 13:43
kemre
сообщение 7.4.2007, 13:47
Прошивка: LP 49R
блин, а че так подсветка работает странно? при входящем звонке у меня из ждущего режима не выходит, только часы загораются и все!!
+видео сохраняет ОЧЕНЬ быстро!!
novis
сообщение 7.4.2007, 14:01
Из: г.Ижевск
Пользователь №: 76 691
Прошивка: 79r
кто скажет, а какие сюда патчи подходят? нужны новые или от 49r или 79r подойдут?
elektro255
Из: Poland, Siedlce
1B187C: 46C046C065A020EEE0062900D0CE206146C046C0
patch code to disable Volume-change-sound for v0.4a2
Undo code:
1B187C: F1EEFE6865A020EEE0062900D0CE2061F1EEFE60
=BazOOka=
сообщение 7.4.2007, 14:03
Прошивка: 4AP
QUOTE(elektro255 @ Today, 17:24)
And another question: from which reflash must I use gain_table.bin & param_table.bin? Can I use not from 44R, but 48R, for example?
And the question about patches. There is very few patches for 44R. From which another reflashes can I use the patches?
Сообщение отредактировал =BazOOka= - 7.4.2007, 14:05
San3k
сообщение 7.4.2007, 14:15
=BazOOka=, я поставил knd sound release 49R, вроде бы нормально работает
elektro255, thanks
Сообщение отредактировал San3k - 7.4.2007, 14:16
elektro255
сообщение 7.4.2007, 14:56
Из: Poland, Siedlce
никакое патчи , all addresses are moved so if you need any patch send me e-mail or send request on bugtracker and I will add this in next mod
display timeout app is not updating backlight on exit now I reapired that so soon will be alpha 3 smile.gif
any 4xR for example 49R
Сообщение отредактировал elektro255 - 7.4.2007, 14:57
=BazOOka=
сообщение 7.4.2007, 15:39
Прошивка: 4AP
elektro255, thank you again. Excuse me for my importunity. But why did you choose 44R (with moved adresses in addition)? It'll be hard to make patch for this, I suppose...
San3k
Прошил лэнгпак и дрм и телефон сдох sad.gif Пишет Code Corrupt
Пришлось заново перепрошивать...
elektro255
сообщение 7.4.2007, 16:05
Из: Poland, Siedlce
this is not 44R (name is set to 44R for programms compatuibility and core apps are from 44R) this is MIX.
I'm not patching firmware in HEX editor, but linking so all my mods will have different offsets.
For that I made special method in Java to get offsets (splashscreen, gain_table etc.). This allows to make Java plugins compatible with all new mods.
To all Java programmers ! Before edit any table in RAM, you have to read offset !
razernov
сообщение 7.4.2007, 16:24
Пользователь №: 58 661
Модель телефона: v9x
Прошивка: R2633121ER_9E.03.39R
1)Какие разультаты показывает бэнчмарк2 на этой прошивке?
2)как держит батарея?
3)реально ли снять ограничение на размер картинки 640*480 в стандартном просмотрщике?
1)how many points jbenchmark2 takes on in this firmware?
2)how long is accumulator life?
3)is it real to remove restriction on image size which phone can open(not in MV or PhoneManager)?
Сообщение отредактировал razernov - 7.4.2007, 16:45
San3k
сообщение 7.4.2007, 17:08
JBenchmark2: 37
Details:
Image manipulation: 29
Text: 116
Sprites: 70
3D Transform: 6
User interface: 47
PS мне показалось, что видео больше тормозит, чем на alpha1... но совсем чуть-чуть
Сообщение отредактировал San3k - 7.4.2007, 17:10
kemre
сообщение 7.4.2007, 17:22
Прошивка: LP 49R
заметили что видео сохраняет практически мгновенно?!
кстати еле нашел меню"Технология"
*1
~Gangs2er~
сообщение 7.4.2007, 17:24
MotoSkinner
Пользователь №: 93 787
Модель телефона: (M) E398
Прошивка: У вас такой нету))
Кто прошил, скажите инет работает?
=BazOOka=
сообщение 7.4.2007, 17:33
Прошивка: 4AP
QUOTE(~Gangs2er~ @ Today, 21:24)
Должен. electro255 написал, что все баги исправлены.
Текстовая версия Сейчас: 21.7.2025, 0:56
