23 страниц V « < 13 14 15 16 > »
Elektro255 V0.4 alpha 4 mod (4xR), 44R,46R,49R,79R
elektro255
сообщение 23.9.2006, 12:06 Закрепленное сообщение!
Из: Poland, Siedlce
Пользователь №: 53 130
09-04-2007
V0.4a4 Alpha: http://elektro255.ovh.org
08-04-2007
V0.4a3 Alpha: http://elektro255.ovh.org
07-04-2007
V0.4a2 44R Alpha: http://elektro255.ovh.org
20-12-2006
V0.3 79R Final mod: http://elektro255.ovh.org
27-11-2006
v0.3 for 49R Final mod http://elektro255.ovh.org/
26-11-2006
V0.3 46R Final mod: http://elektro255.ovh.org
НА Е1 Rokr с бутом 0А02 (оригинальный) НЕ ПОСТАВИТЕ БЕЗ Т.П.!
V0.4 alpha 4
Changes:
- Fixed problem with display timeout (fullscreen clock) when SMS/CALL received
Features:
- 4xR and 7xR MIX (use with 4xR flex)
- unlimited Video recording
- keypad automatic lock
- low battery alarm can be turned off or depend on ring style.
- Scheduled Ring Styles (ring style and funlight style can change automatically on given time and week day)
- flashlight shortcut (##)
- extra menu (shortcut *1 [shortcut is only for testing later will be changed])
- automatic menu enter, without sim card (emergency calls working too)
- new Java methods
- settings are stored on files
- no simlock checking
- Volume-bar sound can be turned off
- multiple menus (every skin can have one mma_ucp)
- Ported patches:
o SMS report significantly turned ON
o more folders in OBEX via BT
o removed unused folders from TransFlash
o Java have access to system files
o increased iTap user dictionary size
o no delete incall on SIM replace
o Bluetooth time changed to 3 minutes
o reordered camera store menu (store only is first)
o SMS alert is using default ringtone
OLD versions(V0.1-0.3):
Firmware changes:
- firmware based on 46R from StarterXP MP
- FULL SW access from Java
- LUMA&CHROMA tables moved to memory - now you can change JPEG compresion from Java
- StarterXP flex
- added dualboot
Flasher changes:
- if you have PDS_4013 flasher will no recreate this
Personalization tool changes:
- first version for 0.3_46R SW mod
- changing splash screen
- changing font (you can use *.fnt or *.smg CG4 files)
- you can turn on, turn off menu access without sim cart
- changing my shortcuts
Новая версия V0.4 alpha 4
Изменения:
- Устранена проблема с таймаутом дисплея(полноэкранные часы) при приеме смс/звонка
Новое:
- Прошивка создана как микс 4xR и 7xR (флекс 4xR ) В 44R она переименована для совместимости! Она близко не лежит к 44R на самом деле!
- Безлимитная запись видео (64мб макс как в 6х7х)
- Автоблок клавиатуры
- Звук разряженой батареи можно выключать или задать стилем оповещения(?).
- Расписание стилей оповещения (стиль оповещения и фанлайтмогут менятся автоматически по времени и дням недели)
- Фонарик по (##)
- Дополнительное меню (метка *1 [только для теста, после может изменится])
- Автоматический вход в меню без сим-карты (аварийные звонки работают)
- Новые методы в Яве (не от 79R, а новые)
- Настройки хранятся в файлах
- Не проверяется лоченость ПДС на симку (работает с лоченым пдс)
- Звук изменения громкости можно отключить
- Мультименю (каждый скин может иметь собственный мма_уцп)
- Портированы патчи:
o Оповещение о доставке SMS всегда вкл.
o больше папок доступно по OBEX из блютуза
o удалены неиспользуемые папки с флешки
o Полный доступ к системным файлам из явы
o увеличен размер пользовательского словаря iTap
o не удалыются последние вызовы при смене сим
o Время обнаружения блютуза - 3 минуты
o Меню сохранения видеозаписи (просто сохранить - первым пунктом)
o при приходе SMS играет "мелодия на смс", а не установленная на этого пользователя
Для версий 0.1-0.3
Изменения в прошивке:
- Создана на базе монстра StarterXP 46R
- Полный доступ к прошивке (симы, озу) из явы
- Таблицы сжатия фотографий перенесены в озу - теперь из явы можно управлять качеством фотографий (сжатием)
- флекс StarterXP
- добавлен дуалбут
Изменения флешера:
-Если ПДС версии 4013 (373 платформа), ПДС не пересоздается.
Изменения персонализации (Personalization tool):
- впервые для мода использована 46 прошивка
- замена заставки (на включение?)
- замена шрифта (лангпак, CG4)
- можно вкл. и выкл. доступ к меню без сим-карты
- изменен ярлык (копирайт?)
Для работы Personalization tool требуется положить в папку программы несжатый бинарный бэкап (32 мегабайта) под именем SW.bin
Прекращаем флудить, типа а когда выйдет новая версия, и.т.д.и.т.п, или придётся наказывать!
тему почистил, архив по 1 декабря тут:
Прикрепленный файл MotoFan_ru_electro.zip   ( 66.56 килобайт ) Кол-во скачиваний: 3902
Сообщение отредактировал elektro255 - 9.4.2007, 12:21
San3k
сообщение 7.4.2007, 13:00
Пользователь №: 108 480
Модель телефона: Nokia 5310; E398
Цитата(elektro255 @ 7.4.2007, 16:55) *
не будет 49R ни 79R ни другой, v0.4a2 то MIX 79R, 4xR и OS от Vilko, в той версии достоинства всех версий
ЗЫ у меня стали громко щелкать динамики, когда я листаю джойстиком, у меня у одного так? Это даже с выключеным звуком клавиатуры.
Люди, а какие в OS от Vilko фичи есть?
Сообщение отредактировал San3k - 7.4.2007, 13:06
=BazOOka=
сообщение 7.4.2007, 13:03
Пользователь №: 107 478
Модель телефона: rokr e2
Прошивка: 4AP
Please, write in details what is "faster OS core by Vilko"?
QUOTE(San3k @ Today, 17:00)
Отключи эффект вибрацией.
Сообщение отредактировал =BazOOka= - 7.4.2007, 13:04
San3k
сообщение 7.4.2007, 13:10
он у меня и так выключен, это не из-за этого...
kemre
сообщение 7.4.2007, 13:11
Пользователь №: 121 096
Прошивка: LP 49R
San3k, у меня тож самое!
elektro255
сообщение 7.4.2007, 13:24
Из: Poland, Siedlce
=BazOOka=, Vilko just fully rewritten (optymalized) VRTX (Real Time OS for ARM)
San3k
сообщение 7.4.2007, 13:31
elektro255, can you delete Volume-change-sound in next version of your mod?
___________________
Кстати, а какие сюда нужны настройки звука? для 49R или именно для 44R?
Сообщение отредактировал San3k - 7.4.2007, 13:43
kemre
сообщение 7.4.2007, 13:47
Прошивка: LP 49R
блин, а че так подсветка работает странно? при входящем звонке у меня из ждущего режима не выходит, только часы загораются и все!!
+видео сохраняет ОЧЕНЬ быстро!!
novis
сообщение 7.4.2007, 14:01
Из: г.Ижевск
Пользователь №: 76 691
Прошивка: 79r
кто скажет, а какие сюда патчи подходят? нужны новые или от 49r или 79r подойдут?
elektro255
Из: Poland, Siedlce
1B187C: 46C046C065A020EEE0062900D0CE206146C046C0
patch code to disable Volume-change-sound for v0.4a2
Undo code:
1B187C: F1EEFE6865A020EEE0062900D0CE2061F1EEFE60
=BazOOka=
сообщение 7.4.2007, 14:03
Прошивка: 4AP
QUOTE(elektro255 @ Today, 17:24)
And another question: from which reflash must I use gain_table.bin & param_table.bin? Can I use not from 44R, but 48R, for example?
And the question about patches. There is very few patches for 44R. From which another reflashes can I use the patches?
Сообщение отредактировал =BazOOka= - 7.4.2007, 14:05
San3k
сообщение 7.4.2007, 14:15
=BazOOka=, я поставил knd sound release 49R, вроде бы нормально работает
elektro255, thanks
Сообщение отредактировал San3k - 7.4.2007, 14:16
elektro255
сообщение 7.4.2007, 14:56
Из: Poland, Siedlce
никакое патчи , all addresses are moved so if you need any patch send me e-mail or send request on bugtracker and I will add this in next mod
display timeout app is not updating backlight on exit now I reapired that so soon will be alpha 3 smile.gif
any 4xR for example 49R
Сообщение отредактировал elektro255 - 7.4.2007, 14:57
=BazOOka=
сообщение 7.4.2007, 15:39
Прошивка: 4AP
elektro255, thank you again. Excuse me for my importunity. But why did you choose 44R (with moved adresses in addition)? It'll be hard to make patch for this, I suppose...
San3k
Прошил лэнгпак и дрм и телефон сдох sad.gif Пишет Code Corrupt
Пришлось заново перепрошивать...
elektro255
сообщение 7.4.2007, 16:05
Из: Poland, Siedlce
this is not 44R (name is set to 44R for programms compatuibility and core apps are from 44R) this is MIX.
I'm not patching firmware in HEX editor, but linking so all my mods will have different offsets.
For that I made special method in Java to get offsets (splashscreen, gain_table etc.). This allows to make Java plugins compatible with all new mods.
To all Java programmers ! Before edit any table in RAM, you have to read offset !
razernov
сообщение 7.4.2007, 16:24
Пользователь №: 58 661
Модель телефона: v9x
Прошивка: R2633121ER_9E.03.39R
1)Какие разультаты показывает бэнчмарк2 на этой прошивке?
2)как держит батарея?
3)реально ли снять ограничение на размер картинки 640*480 в стандартном просмотрщике?
1)how many points jbenchmark2 takes on in this firmware?
2)how long is accumulator life?
3)is it real to remove restriction on image size which phone can open(not in MV or PhoneManager)?
Сообщение отредактировал razernov - 7.4.2007, 16:45
San3k
сообщение 7.4.2007, 17:08
JBenchmark2: 37
Details:
Image manipulation: 29
Text: 116
Sprites: 70
3D Transform: 6
User interface: 47
PS мне показалось, что видео больше тормозит, чем на alpha1... но совсем чуть-чуть
Сообщение отредактировал San3k - 7.4.2007, 17:10
kemre
сообщение 7.4.2007, 17:22
Прошивка: LP 49R
заметили что видео сохраняет практически мгновенно?!
кстати еле нашел меню"Технология"
*1
~Gangs2er~
сообщение 7.4.2007, 17:24
MotoSkinner
Пользователь №: 93 787
Модель телефона: (M) E398
Прошивка: У вас такой нету))
Кто прошил, скажите инет работает?
=BazOOka=
сообщение 7.4.2007, 17:33
Прошивка: 4AP
QUOTE(~Gangs2er~ @ Today, 21:24)
Должен. electro255 написал, что все баги исправлены.
San3k
сообщение 7.4.2007, 17:39
У меня через стандартный браузер работает, а вот через оперу мини, которая идет с модом - нет, тел перезагружается, х3 почему...
Vadim Velikii
сообщение 7.4.2007, 18:39
Пользователь №: 102 604
Модель телефона: ROKR_E398, v360, v8
Прошивка: 49E.m.
1.Видео по сравнению с alpha1 и 49R mod v0.3 стало заметно тормозить(сравнивал с другим Е398). sad.gif
2.При попытке первые два раза войти из видеокамеры в "просмотр видео" телефон два раза зависал, но после этого этот глюк исчез сам собой!
В остальном - вроде супер, видео сохраняется мгновенно, и мечта иметь анлим видео7xR вместе со звуком 4xR (ну и с модами от Электро, я без них телефон уже не представляю), наконец-то сбылась!
elektro255, спасибо!
Сообщение отредактировал Vadim Velikii - 7.4.2007, 18:56
Trentemoller
сообщение 7.4.2007, 19:04
Из: Армавир
Пользователь №: 105 953
Прошивка: R373_G_0E.30.49R
Я непойму, почему elektro неможет сделать свой мод на основе 49r, добавлять и модернизировать только ее? Почему, что в ней не так? Что в ней нет такого, что есть в 44r, 46r или 79r? Вроде самая последняя и самая стабильная прошивка! Я бы это не писал, если бы патчи можно было так легко портировать с проши на прошу! Это единственное, что меня затрагивает!!! sad.gif
Сообщение отредактировал Trentemoller - 7.4.2007, 19:05
Wattie
сообщение 7.4.2007, 19:14
Пользователь №: 58 537
Прошивка: 43R
Mirror: Software Mod by Elektro255 0.4a2 for Motorola E398
SANYO_K
сообщение 7.4.2007, 21:33
Пользователь №: 64 324
Модель телефона: ROKR E1 (E398)
Прошивка: elektro255!!! 49r
Замечен баг... Иногда при переключении на флешку пропадает подсветка и включатеся только если выходишь на рабочий стол.
Сообщение отредактировал SANYO_K - 8.4.2007, 0:21
k293
сообщение 7.4.2007, 22:23
Пользователь №: 129 403
Прошивка: motowalkman
как я понял этот мод ставится на 49г ?
San3k
сообщение 8.4.2007, 4:20
elektro255, keypad automatic lock works incorrect, it locks, though I listen music, watch video, etc. Изображение
Stalker 1988
сообщение 8.4.2007, 5:45
MotoArhangel
Из: Алтайский край
Пользователь №: 85 312
Прошивка: CM10 & MIUI
Ну вот и вернулся =)
Парни подскажите стоит ли ставить этого монстра или немного подождать до выхода финальной версии. Если ставить то на какой платформе
V0.4a2 44R Alpha
20-12-2006
V0.3 79R
27-11-2006
v0.3 for 49R
26-11-2006
V0.3 46R
Какая лучше?
San3k
сообщение 8.4.2007, 6:01
V0.4a2 44R Alpha
20-12-2006
V0.3 79R
27-11-2006
v0.3 for 49R
26-11-2006
V0.3 46R
Какая лучше?
Если хочешь поставить финал (последняя стабильная версия, то качай v0.3 for 49R), но у меня стоит v0.4a2 =)
=BazOOka=
сообщение 8.4.2007, 6:33
Прошивка: 4AP
Stalker 1988, лучше немного подожди. Или ставь V0.3. на 49R
Neomoto
сообщение 8.4.2007, 10:13
Из: Белгород
Пользователь №: 72 604
Модель телефона: MotoZINE ZN5
Прошивка: sym X beta
electro же писал:
Это НЕ 44R. Имя установлено на 44R для программной совестимости и приложения ядра(вроде так) из 44R. Это смесь 49R, 79R и переписанного ядра ОС от Vilko. Похожее делали для v360 и L7 - смесь ACR и AER.
=BazOOka=
сообщение 8.4.2007, 13:20
Прошивка: 4AP
QUOTE(k293 @ Today, 2:23)
Не обязательно. Можно ставить на любую 4хR.
Mario7
сообщение 8.4.2007, 16:44
Пользователь №: 91 640
Модель телефона: С380&Е398
Прошивка: Volcanur & Deluxe
Кто разобрался как Альфа 3 ставить?
Добавлено позже (8.4.2007, 19:51):
А всё разобрался просто подождать нужно было. А какие патчи подойдут к этой прошивки?
MotoMixon
сообщение 8.4.2007, 17:04
Из: г.Казань
Пользователь №: 90 411
Модель телефона: Milestone xt720
Прошивка: Android 2.1
серобуромалиновый с продресью
Извените, кому не лень будет описать альфа3? Желательно по подробней, просто есть интерес в ней покопаться! biggrin.gif
=BazOOka=
сообщение 8.4.2007, 17:37
Прошивка: 4AP
QUOTE(Mario7 @ Today, 20:44)
Если ты про Alpha3, то никакие! Вот же описание с сайта electro255:
QUOTE
Don't use Java plugins from old mods, and don't apply any patches, if you need any patch send e-mail.
"Не используйте ява-плагины со старых модов и не применяйте никаких патчей! Если вам нужен какой-либо патч, пошлите мне е-mail"
Сообщение отредактировал =BazOOka= - 8.4.2007, 17:39
Trentemoller
сообщение 8.4.2007, 18:20
Из: Армавир
Исправлена красная кнопка подсвечивает контроль(управление)
Исправлен выход перерыва показа подсветки контроль(управление)
Если файлы srs.bin, set.bin не существуют, программное обеспечение создаст
Звук Бруска объема может быть вкл\выкл
Многократные структуры меню
Обновленная низкая тревога батареи (теперь vibe и зависит от кольца, работает)
Добавленным некоторые методы в Ява
Некоторые патчи - установлены (много BT папок, Ява имеет доступ к файлам системы, никакой проверки simlock)
Я сделал SW updater, чтобы модернизировать только CG1, так что флекс, не будет изменен.
Не используйте Ява plugins от старого mods, и не примените патчи, если Вы нуждаетесь в любой заплате, посылайте электронную почту.
Переводил через промт, подправил как мог!
Что обозначает это "more BT folders, Java have access to system files" ?, а то через промт неочень понятно!
И объясните стоит ли шить вообще эту прошивку?
Сообщение отредактировал Trentemoller - 8.4.2007, 18:25
=BazOOka=
сообщение 8.4.2007, 18:24
Прошивка: 4AP
Trentemoller, я "вручную" перевел:
Изменения:
- Исправлен контроль подсветки красной кнопкой (?)
- Исправлен выход дисплея из неактивного состояния
- Если файлы srs.bin, set.bin не существуют, они будут созжаны
- Звук при изменении громкости можно включать\выключать
- Мультиструктура меню
- Обновлен сигнал о севшей батарее (не зависит от стиля звонка)
- Добавлены некоторые методы Java
- Некоторые патчи применены
При прошивке ваш флекс не изменится (обновится только CG1)
ORA
сообщение 8.4.2007, 20:10
Из: Ижевск
Пользователь №: 91 715
Прошивка: R373_0.2b(49R)
Side
сообщение 8.4.2007, 20:12
Из: Мурманск
Пользователь №: 81 705
Модель телефона: V535, EM30
Не совсем правильно, должно быть так:
- Обновлен сигнал о севшей батарее (теперь работают новые режимы: вибро и в зависимости от текущего стиля звонка)
Означает: открыт доступ ко всем папкам берез BlueTooth (OBEX), Java имеет доступ к системным файлам.
Trentemoller
сообщение 8.4.2007, 20:24
Из: Армавир
Итак, пошли вопросы:
Что такое "мультиструктура меню"???
elektro255,
Вот патчи, если можно, портируй их на 44r!
Here patch`s, if it is possible port all of them on 44r!
And please, give offset for bootscreen!
Сообщение отредактировал Trentemoller - 8.4.2007, 20:25
Текстовая версия Сейчас: 23.7.2025, 22:08
