23 страниц V « < 14 15 16 17 > »
Elektro255 V0.4 alpha 4 mod (4xR), 44R,46R,49R,79R
elektro255
сообщение 23.9.2006, 12:06 Закрепленное сообщение!
Из: Poland, Siedlce
Пользователь №: 53 130
09-04-2007
V0.4a4 Alpha: http://elektro255.ovh.org
08-04-2007
V0.4a3 Alpha: http://elektro255.ovh.org
07-04-2007
V0.4a2 44R Alpha: http://elektro255.ovh.org
20-12-2006
V0.3 79R Final mod: http://elektro255.ovh.org
27-11-2006
v0.3 for 49R Final mod http://elektro255.ovh.org/
26-11-2006
V0.3 46R Final mod: http://elektro255.ovh.org
НА Е1 Rokr с бутом 0А02 (оригинальный) НЕ ПОСТАВИТЕ БЕЗ Т.П.!
V0.4 alpha 4
Changes:
- Fixed problem with display timeout (fullscreen clock) when SMS/CALL received
Features:
- 4xR and 7xR MIX (use with 4xR flex)
- unlimited Video recording
- keypad automatic lock
- low battery alarm can be turned off or depend on ring style.
- Scheduled Ring Styles (ring style and funlight style can change automatically on given time and week day)
- flashlight shortcut (##)
- extra menu (shortcut *1 [shortcut is only for testing later will be changed])
- automatic menu enter, without sim card (emergency calls working too)
- new Java methods
- settings are stored on files
- no simlock checking
- Volume-bar sound can be turned off
- multiple menus (every skin can have one mma_ucp)
- Ported patches:
o SMS report significantly turned ON
o more folders in OBEX via BT
o removed unused folders from TransFlash
o Java have access to system files
o increased iTap user dictionary size
o no delete incall on SIM replace
o Bluetooth time changed to 3 minutes
o reordered camera store menu (store only is first)
o SMS alert is using default ringtone
OLD versions(V0.1-0.3):
Firmware changes:
- firmware based on 46R from StarterXP MP
- FULL SW access from Java
- LUMA&CHROMA tables moved to memory - now you can change JPEG compresion from Java
- StarterXP flex
- added dualboot
Flasher changes:
- if you have PDS_4013 flasher will no recreate this
Personalization tool changes:
- first version for 0.3_46R SW mod
- changing splash screen
- changing font (you can use *.fnt or *.smg CG4 files)
- you can turn on, turn off menu access without sim cart
- changing my shortcuts
Новая версия V0.4 alpha 4
Изменения:
- Устранена проблема с таймаутом дисплея(полноэкранные часы) при приеме смс/звонка
Новое:
- Прошивка создана как микс 4xR и 7xR (флекс 4xR ) В 44R она переименована для совместимости! Она близко не лежит к 44R на самом деле!
- Безлимитная запись видео (64мб макс как в 6х7х)
- Автоблок клавиатуры
- Звук разряженой батареи можно выключать или задать стилем оповещения(?).
- Расписание стилей оповещения (стиль оповещения и фанлайтмогут менятся автоматически по времени и дням недели)
- Фонарик по (##)
- Дополнительное меню (метка *1 [только для теста, после может изменится])
- Автоматический вход в меню без сим-карты (аварийные звонки работают)
- Новые методы в Яве (не от 79R, а новые)
- Настройки хранятся в файлах
- Не проверяется лоченость ПДС на симку (работает с лоченым пдс)
- Звук изменения громкости можно отключить
- Мультименю (каждый скин может иметь собственный мма_уцп)
- Портированы патчи:
o Оповещение о доставке SMS всегда вкл.
o больше папок доступно по OBEX из блютуза
o удалены неиспользуемые папки с флешки
o Полный доступ к системным файлам из явы
o увеличен размер пользовательского словаря iTap
o не удалыются последние вызовы при смене сим
o Время обнаружения блютуза - 3 минуты
o Меню сохранения видеозаписи (просто сохранить - первым пунктом)
o при приходе SMS играет "мелодия на смс", а не установленная на этого пользователя
Для версий 0.1-0.3
Изменения в прошивке:
- Создана на базе монстра StarterXP 46R
- Полный доступ к прошивке (симы, озу) из явы
- Таблицы сжатия фотографий перенесены в озу - теперь из явы можно управлять качеством фотографий (сжатием)
- флекс StarterXP
- добавлен дуалбут
Изменения флешера:
-Если ПДС версии 4013 (373 платформа), ПДС не пересоздается.
Изменения персонализации (Personalization tool):
- впервые для мода использована 46 прошивка
- замена заставки (на включение?)
- замена шрифта (лангпак, CG4)
- можно вкл. и выкл. доступ к меню без сим-карты
- изменен ярлык (копирайт?)
Для работы Personalization tool требуется положить в папку программы несжатый бинарный бэкап (32 мегабайта) под именем SW.bin
Прекращаем флудить, типа а когда выйдет новая версия, и.т.д.и.т.п, или придётся наказывать!
тему почистил, архив по 1 декабря тут:
Прикрепленный файл MotoFan_ru_electro.zip   ( 66.56 килобайт ) Кол-во скачиваний: 3902
Сообщение отредактировал elektro255 - 9.4.2007, 12:21
razernov
сообщение 7.4.2007, 16:24
Пользователь №: 58 661
Модель телефона: v9x
Прошивка: R2633121ER_9E.03.39R
1)Какие разультаты показывает бэнчмарк2 на этой прошивке?
2)как держит батарея?
3)реально ли снять ограничение на размер картинки 640*480 в стандартном просмотрщике?
1)how many points jbenchmark2 takes on in this firmware?
2)how long is accumulator life?
3)is it real to remove restriction on image size which phone can open(not in MV or PhoneManager)?
Сообщение отредактировал razernov - 7.4.2007, 16:45
San3k
сообщение 7.4.2007, 17:08
Пользователь №: 108 480
Модель телефона: Nokia 5310; E398
JBenchmark2: 37
Details:
Image manipulation: 29
Text: 116
Sprites: 70
3D Transform: 6
User interface: 47
PS мне показалось, что видео больше тормозит, чем на alpha1... но совсем чуть-чуть
Сообщение отредактировал San3k - 7.4.2007, 17:10
kemre
сообщение 7.4.2007, 17:22
Пользователь №: 121 096
Прошивка: LP 49R
заметили что видео сохраняет практически мгновенно?!
кстати еле нашел меню"Технология"
*1
~Gangs2er~
сообщение 7.4.2007, 17:24
MotoSkinner
Пользователь №: 93 787
Модель телефона: (M) E398
Прошивка: У вас такой нету))
Кто прошил, скажите инет работает?
=BazOOka=
сообщение 7.4.2007, 17:33
Пользователь №: 107 478
Модель телефона: rokr e2
Прошивка: 4AP
QUOTE(~Gangs2er~ @ Today, 21:24)
Должен. electro255 написал, что все баги исправлены.
San3k
сообщение 7.4.2007, 17:39
У меня через стандартный браузер работает, а вот через оперу мини, которая идет с модом - нет, тел перезагружается, х3 почему...
Vadim Velikii
сообщение 7.4.2007, 18:39
Пользователь №: 102 604
Модель телефона: ROKR_E398, v360, v8
Прошивка: 49E.m.
1.Видео по сравнению с alpha1 и 49R mod v0.3 стало заметно тормозить(сравнивал с другим Е398). sad.gif
2.При попытке первые два раза войти из видеокамеры в "просмотр видео" телефон два раза зависал, но после этого этот глюк исчез сам собой!
В остальном - вроде супер, видео сохраняется мгновенно, и мечта иметь анлим видео7xR вместе со звуком 4xR (ну и с модами от Электро, я без них телефон уже не представляю), наконец-то сбылась!
elektro255, спасибо!
Сообщение отредактировал Vadim Velikii - 7.4.2007, 18:56
Trentemoller
сообщение 7.4.2007, 19:04
Из: Армавир
Пользователь №: 105 953
Прошивка: R373_G_0E.30.49R
Я непойму, почему elektro неможет сделать свой мод на основе 49r, добавлять и модернизировать только ее? Почему, что в ней не так? Что в ней нет такого, что есть в 44r, 46r или 79r? Вроде самая последняя и самая стабильная прошивка! Я бы это не писал, если бы патчи можно было так легко портировать с проши на прошу! Это единственное, что меня затрагивает!!! sad.gif
Сообщение отредактировал Trentemoller - 7.4.2007, 19:05
Wattie
сообщение 7.4.2007, 19:14
Пользователь №: 58 537
Прошивка: 43R
Mirror: Software Mod by Elektro255 0.4a2 for Motorola E398
SANYO_K
сообщение 7.4.2007, 21:33
Пользователь №: 64 324
Модель телефона: ROKR E1 (E398)
Прошивка: elektro255!!! 49r
Замечен баг... Иногда при переключении на флешку пропадает подсветка и включатеся только если выходишь на рабочий стол.
Сообщение отредактировал SANYO_K - 8.4.2007, 0:21
k293
сообщение 7.4.2007, 22:23
Пользователь №: 129 403
Прошивка: motowalkman
как я понял этот мод ставится на 49г ?
San3k
сообщение 8.4.2007, 4:20
elektro255, keypad automatic lock works incorrect, it locks, though I listen music, watch video, etc. Изображение
Stalker 1988
сообщение 8.4.2007, 5:45
MotoArhangel
Из: Алтайский край
Пользователь №: 85 312
Прошивка: CM10 & MIUI
Ну вот и вернулся =)
Парни подскажите стоит ли ставить этого монстра или немного подождать до выхода финальной версии. Если ставить то на какой платформе
V0.4a2 44R Alpha
20-12-2006
V0.3 79R
27-11-2006
v0.3 for 49R
26-11-2006
V0.3 46R
Какая лучше?
San3k
сообщение 8.4.2007, 6:01
V0.4a2 44R Alpha
20-12-2006
V0.3 79R
27-11-2006
v0.3 for 49R
26-11-2006
V0.3 46R
Какая лучше?
Если хочешь поставить финал (последняя стабильная версия, то качай v0.3 for 49R), но у меня стоит v0.4a2 =)
=BazOOka=
сообщение 8.4.2007, 6:33
Прошивка: 4AP
Stalker 1988, лучше немного подожди. Или ставь V0.3. на 49R
Neomoto
сообщение 8.4.2007, 10:13
Из: Белгород
Пользователь №: 72 604
Модель телефона: MotoZINE ZN5
Прошивка: sym X beta
electro же писал:
this is not 44R (name is set to 44R for programms compatuibility and core apps are from 44R) this is MIX.
Это НЕ 44R. Имя установлено на 44R для программной совестимости и приложения ядра(вроде так) из 44R. Это смесь 49R, 79R и переписанного ядра ОС от Vilko. Похожее делали для v360 и L7 - смесь ACR и AER.
=BazOOka=
сообщение 8.4.2007, 13:20
Прошивка: 4AP
QUOTE(k293 @ Today, 2:23)
Не обязательно. Можно ставить на любую 4хR.
Mario7
сообщение 8.4.2007, 16:44
Пользователь №: 91 640
Модель телефона: С380&Е398
Прошивка: Volcanur & Deluxe
Кто разобрался как Альфа 3 ставить?
Добавлено позже (8.4.2007, 19:51):
А всё разобрался просто подождать нужно было. А какие патчи подойдут к этой прошивки?
MotoMixon
сообщение 8.4.2007, 17:04
Из: г.Казань
Пользователь №: 90 411
Модель телефона: Milestone xt720
Прошивка: Android 2.1
серобуромалиновый с продресью
Извените, кому не лень будет описать альфа3? Желательно по подробней, просто есть интерес в ней покопаться! biggrin.gif
=BazOOka=
сообщение 8.4.2007, 17:37
Прошивка: 4AP
QUOTE(Mario7 @ Today, 20:44)
Если ты про Alpha3, то никакие! Вот же описание с сайта electro255:
QUOTE
Don't use Java plugins from old mods, and don't apply any patches, if you need any patch send e-mail.
"Не используйте ява-плагины со старых модов и не применяйте никаких патчей! Если вам нужен какой-либо патч, пошлите мне е-mail"
Сообщение отредактировал =BazOOka= - 8.4.2007, 17:39
Trentemoller
сообщение 8.4.2007, 18:20
Из: Армавир
Исправлена красная кнопка подсвечивает контроль(управление)
Исправлен выход перерыва показа подсветки контроль(управление)
Если файлы srs.bin, set.bin не существуют, программное обеспечение создаст
Звук Бруска объема может быть вкл\выкл
Многократные структуры меню
Обновленная низкая тревога батареи (теперь vibe и зависит от кольца, работает)
Добавленным некоторые методы в Ява
Некоторые патчи - установлены (много BT папок, Ява имеет доступ к файлам системы, никакой проверки simlock)
Я сделал SW updater, чтобы модернизировать только CG1, так что флекс, не будет изменен.
Не используйте Ява plugins от старого mods, и не примените патчи, если Вы нуждаетесь в любой заплате, посылайте электронную почту.
Переводил через промт, подправил как мог!
Что обозначает это "more BT folders, Java have access to system files" ?, а то через промт неочень понятно!
И объясните стоит ли шить вообще эту прошивку?
Сообщение отредактировал Trentemoller - 8.4.2007, 18:25
=BazOOka=
сообщение 8.4.2007, 18:24
Прошивка: 4AP
Trentemoller, я "вручную" перевел:
Изменения:
- Исправлен контроль подсветки красной кнопкой (?)
- Исправлен выход дисплея из неактивного состояния
- Если файлы srs.bin, set.bin не существуют, они будут созжаны
- Звук при изменении громкости можно включать\выключать
- Мультиструктура меню
- Обновлен сигнал о севшей батарее (не зависит от стиля звонка)
- Добавлены некоторые методы Java
- Некоторые патчи применены
При прошивке ваш флекс не изменится (обновится только CG1)
ORA
сообщение 8.4.2007, 20:10
Из: Ижевск
Пользователь №: 91 715
Прошивка: R373_0.2b(49R)
Side
сообщение 8.4.2007, 20:12
Из: Мурманск
Пользователь №: 81 705
Модель телефона: V535, EM30
Не совсем правильно, должно быть так:
- Обновлен сигнал о севшей батарее (теперь работают новые режимы: вибро и в зависимости от текущего стиля звонка)
Означает: открыт доступ ко всем папкам берез BlueTooth (OBEX), Java имеет доступ к системным файлам.
Trentemoller
сообщение 8.4.2007, 20:24
Из: Армавир
Итак, пошли вопросы:
Что такое "мультиструктура меню"???
elektro255,
Вот патчи, если можно, портируй их на 44r!
Here patch`s, if it is possible port all of them on 44r!
And please, give offset for bootscreen!
Сообщение отредактировал Trentemoller - 8.4.2007, 20:25
Double-dragon
сообщение 8.4.2007, 21:06
Из: Саратовская, Балаково
Пользователь №: 84 351
Модель телефона: RAZR2 V8 2Gb
Прошивка: R601_G_80.54.60R
Цитата(Vadim Velikii @ 20.3.2007, 9:59) *
И вообще, есть те, кому нравятся 7хRпрошивки, и есть те, кому нравится 4xR.
А есть те, кому 6FR!
А есть мод для этой? Может и на Е1 пойдёт...
Timik
сообщение 9.4.2007, 4:14
Пользователь №: 100 902
Прошивка: даже не знаю теперь
Скачал а2, и а3, прошил.. сразу возникла куча вопросов... А как сделать чтобы при входящем звонке и смс голели не часы, а вызывающий абонент? и еще, как включать и выключать автоблокировку клавиатуры?... Дайте кто нибудь на это творение подходящие патчи.. И чего там еще такого интересного, чего я не увидел?
Добавлено позже (9.4.2007, 8:19):
Trentemoller, твои патчи точно подходят?
Добавлено позже (9.4.2007, 8:47):
Вот еще какя ерунда - какой бы я лэнг не ставил, iTap все равно остается тупым!!! Что делать не знаю..
AleksX
сообщение 9.4.2007, 5:17
Из: Пермь
Пользователь №: 68 183
Модель телефона: L7e,Nokia 5700
Прошивка: Mpx398 De Luxe
Да по поводу iTap я поставил от MPX398 всё равно тупит хотя на MPX не тупил.. sad.gif
VkD
сообщение 9.4.2007, 5:34
Пользователь №: 64 617
Прошивка: MS 1.5b
Подскажите, в новой проше можно будет сохранять картинки из ММС?
У меня сейчас New_Standart на базе Elektro255 Mod 0.3 49R
На нем вроде бы говорят, что нельзя сохранять...
R373_49r(elektro255_mod)_new_standart_by_aleks75
Slavasiv
сообщение 9.4.2007, 6:14
Пользователь №: 109 157
Прошивка: Elektro
Анимации тормозят сильно на 0.3 моде всё нормально было а здесь тормозят как в 1 альфе так и в 3
yurybol
сообщение 9.4.2007, 7:26
Из: Ростовская область.
Пользователь №: 12 235
Прошивка: Надеюсь поменять
У меня проблема такого плана:
Я использую телефон в связке блютус-gprs-комп. Через какое-то время после подключения связь автоматически обрывается. Этот эффект наблюдается и на 1 и на 2 альфе.
Как решить данную проблему?
Trentemoller
сообщение 9.4.2007, 8:20
Из: Армавир
В каком смысле точно подходят? Я попросил elektro, чтобы он их портировал с 49r на 44r!
SharkExE
сообщение 9.4.2007, 8:22
Из: Пермь
Пользователь №: 46 933
Модель телефона: SE w810i
Прошивка: R4DB005
yurybol,
у всех такая проблема, хотя это даже не проблема, а фитча мотороловских телефонов. Через пять минут после последней активности сети GPRS тел обрывает связь.
AlexKooper
сообщение 9.4.2007, 8:46
Из: Йошкар-Ола
Пользователь №: 47 140
Прошивка: AlexKooper mod v.47
SharkExE, так вроде в нетмониторе настройка есть gprsautodettach или как-то так...
Бес
сообщение 9.4.2007, 9:10
Оптимист
Из: Омск
Пользователь №: 92 409
это, наверное, то что обещал elektro255 - каждому скину свой файл мма_уцп!!!
V0.4a changes :
On develop are (maybe available on beta version):
multiple menu structures (you can add to each skin mma_ucp/dcp file, if file not exists skin will use original mma)
Timik
сообщение 9.4.2007, 9:13
А, ну тогда все нормально
волкOFF
сообщение 9.4.2007, 10:12
Из: Нижний Новгород
Пользователь №: 118 524
Модель телефона: E-398
Прошивка: Moto-Symbian RC3
а как поменять язык? когда захожу в настройки дальше в Lenguage телефон вылетает в меню!!! че делать? sad.gif
Timik
сообщение 9.4.2007, 10:13
кто-нибудь, скажите что нужно чтоб iTap был нормальный?
San3k
сообщение 9.4.2007, 10:25
elektro255, how I can change display timeout to 60 or 120 seconds? There is 1 min and 2 min in settings. If I select 1 min, display timeout will be 20 sec; if I select 2 min, timeout will be 40 sec.
sorry for my bad english
elektro255
сообщение 9.4.2007, 10:31
Из: Poland, Siedlce
San3k, SEEM 0032 byte 0x75 bit 5 set to 0 , 1min-20sek 2-40 5-60 10-120sek
Сообщение отредактировал elektro255 - 9.4.2007, 10:34
Текстовая версия Сейчас: 22.7.2025, 9:59
