Elektro255 V0.4 alpha 4 mod (4xR), 44R,46R,49R,79R
elektro255
сообщение 23.9.2006, 12:06
Из: Poland, Siedlce
Пользователь №: 53 130
Прошивка: elektro255 :)
09-04-2007
V0.4a4 Alpha: http://elektro255.ovh.org
08-04-2007
V0.4a3 Alpha: http://elektro255.ovh.org
07-04-2007
V0.4a2 44R Alpha: http://elektro255.ovh.org
20-12-2006
V0.3 79R Final mod: http://elektro255.ovh.org
27-11-2006
v0.3 for 49R Final mod http://elektro255.ovh.org/
26-11-2006
V0.3 46R Final mod: http://elektro255.ovh.org
НА Е1 Rokr с бутом 0А02 (оригинальный) НЕ ПОСТАВИТЕ БЕЗ Т.П.!
V0.4 alpha 4
Changes:
- Fixed problem with display timeout (fullscreen clock) when SMS/CALL received
Features:
- 4xR and 7xR MIX (use with 4xR flex)
- unlimited Video recording
- keypad automatic lock
- low battery alarm can be turned off or depend on ring style.
- Scheduled Ring Styles (ring style and funlight style can change automatically on given time and week day)
- flashlight shortcut (##)
- extra menu (shortcut *1 [shortcut is only for testing later will be changed])
- automatic menu enter, without sim card (emergency calls working too)
- new Java methods
- settings are stored on files
- no simlock checking
- Volume-bar sound can be turned off
- multiple menus (every skin can have one mma_ucp)
- Ported patches:
o SMS report significantly turned ON
o more folders in OBEX via BT
o removed unused folders from TransFlash
o Java have access to system files
o increased iTap user dictionary size
o no delete incall on SIM replace
o Bluetooth time changed to 3 minutes
o reordered camera store menu (store only is first)
o SMS alert is using default ringtone
OLD versions(V0.1-0.3):
Firmware changes:
- firmware based on 46R from StarterXP MP
- FULL SW access from Java
- LUMA&CHROMA tables moved to memory - now you can change JPEG compresion from Java
- StarterXP flex
- added dualboot
Flasher changes:
- if you have PDS_4013 flasher will no recreate this
Personalization tool changes:
- first version for 0.3_46R SW mod
- changing splash screen
- changing font (you can use *.fnt or *.smg CG4 files)
- you can turn on, turn off menu access without sim cart
- changing my shortcuts
Новая версия V0.4 alpha 4
Изменения:
- Устранена проблема с таймаутом дисплея(полноэкранные часы) при приеме смс/звонка
Новое:
- Прошивка создана как микс 4xR и 7xR (флекс 4xR ) В 44R она переименована для совместимости! Она близко не лежит к 44R на самом деле!
- Безлимитная запись видео (64мб макс как в 6х7х)
- Автоблок клавиатуры
- Звук разряженой батареи можно выключать или задать стилем оповещения(?).
- Расписание стилей оповещения (стиль оповещения и фанлайтмогут менятся автоматически по времени и дням недели)
- Фонарик по (##)
- Дополнительное меню (метка *1 [только для теста, после может изменится])
- Автоматический вход в меню без сим-карты (аварийные звонки работают)
- Новые методы в Яве (не от 79R, а новые)
- Настройки хранятся в файлах
- Не проверяется лоченость ПДС на симку (работает с лоченым пдс)
- Звук изменения громкости можно отключить
- Мультименю (каждый скин может иметь собственный мма_уцп)
- Портированы патчи:
o Оповещение о доставке SMS всегда вкл.
o больше папок доступно по OBEX из блютуза
o удалены неиспользуемые папки с флешки
o Полный доступ к системным файлам из явы
o увеличен размер пользовательского словаря iTap
o не удалыются последние вызовы при смене сим
o Время обнаружения блютуза - 3 минуты
o Меню сохранения видеозаписи (просто сохранить - первым пунктом)
o при приходе SMS играет "мелодия на смс", а не установленная на этого пользователя
Для версий 0.1-0.3
Изменения в прошивке:
- Создана на базе монстра StarterXP 46R
- Полный доступ к прошивке (симы, озу) из явы
- Таблицы сжатия фотографий перенесены в озу - теперь из явы можно управлять качеством фотографий (сжатием)
- флекс StarterXP
- добавлен дуалбут
Изменения флешера:
-Если ПДС версии 4013 (373 платформа), ПДС не пересоздается.
Изменения персонализации (Personalization tool):
- впервые для мода использована 46 прошивка
- замена заставки (на включение?)
- замена шрифта (лангпак, CG4)
- можно вкл. и выкл. доступ к меню без сим-карты
- изменен ярлык (копирайт?)
Для работы Personalization tool требуется положить в папку программы несжатый бинарный бэкап (32 мегабайта) под именем SW.bin
Прекращаем флудить, типа а когда выйдет новая версия, и.т.д.и.т.п, или придётся наказывать!
тему почистил, архив по 1 декабря тут:
Прикрепленный файл MotoFan_ru_electro.zip   ( 66.56 килобайт ) Кол-во скачиваний: 3902
Сообщение отредактировал elektro255 - 9.4.2007, 12:21
elektro255   Elektro255 V0.4 alpha 4 mod (4xR)   23.9.2006, 12:06
AlexKooper   Rokr E1 Sw Modfore398 By Elektro255 V0.2beta Если...   23.9.2006, 14:19
Stalker.mg   Я перезалил http://slil.ru/23157161 проверьте кто ...   23.9.2006, 16:20
elektro255   this is Firmware for E398 (SW.BIN full backup, aft...   23.9.2006, 18:26
elektro255   SW name IS ORYGINAL :) for P2K programs :) i...   23.9.2006, 19:11
bigserg555   Aspirin2002, ну вот же http://slil.ru/23157161   23.9.2006, 22:32
Stalker.mg   Делал как lv333, то есть старым флеш бекапом собра...   24.9.2006, 9:49
elektro255   this files is using by my programm (loaders and R...   24.9.2006, 9:50
Stalker.mg   Выкладываю кодовые группы, если у кого нет возможн...   24.9.2006, 10:08
Aspirin2002   Ява была в посте №28 Собственно вот   24.9.2006, 10:17
bigserg555   abatsk, автоматическую блокировку клавиатуры включ...   24.9.2006, 13:57
elektro255   I used motosymbian 1.4, about flex first i must m...   24.9.2006, 19:49
SharkExE   Ну что можно сказать, все патчи (корелеты, мидлеты...   27.9.2006, 9:28
Алекс75   Вы вот тут завели разговор подойдут или нет патчи ...   28.9.2006, 19:02
Алекс75   scool, Все зависит от того какой у тебя бут в теле...   8.10.2006, 11:57
abatsk   А когда я прошил CG1 и CG3 так у меня фонарик раб...   8.10.2006, 12:08
elektro255   you don't understand, there is no one address...   11.10.2006, 5:20
Bent   Stranger, расскажу :) Берёшь FlashBackup 2.62---С...   11.10.2006, 9:40
elektro255   java not woking because file J2MEST is broken and ...   11.10.2006, 10:49
Stalker.mg   CG3 http://www.webfile.ru/1145828 http://www.rapid...   11.10.2006, 10:57
Stalker.mg   ORA, Можно, но лучше еще и cg3 заменить CG3 http:...   11.10.2006, 14:30
Алекс75   elektro255, At me one more question... It Is poss...   11.10.2006, 16:59
Bent   SharkExE, Вот пожалуйста :) MV целиком и полностью...   12.10.2006, 8:25
ORA   Bezumniy, Установи яву от электро и включи в ней ...   12.10.2006, 11:55
Archy   Не ругаемся и стараемся быть повежливее друг с дру...   13.10.2006, 19:45
elektro255   кто-нить знает, когда выйде доработанная версия? ...   15.10.2006, 8:00
elektro255   final version will be in next week because in this...   19.10.2006, 7:45
elektro255   21:09:16 BOOT verion: 8C5C (bad bo...   26.10.2006, 17:50
Stalker.mg   ~Gangs2er~, перевод приблизительный, не дословный ...   26.10.2006, 18:06
ORA   Список изменений: -Исправлен глюк с выходом в гла...   26.10.2006, 18:10
elektro255   я не знаю проверь приложение   26.10.2006, 18:22
BackgaMan   Удалил ни чего не произошло!   26.10.2006, 18:40
BackgaMan   Вот кому ещё надо скачиваем здесь!   26.10.2006, 19:34
elektro255   if i add this option i will make settings for tur...   26.10.2006, 20:25
elektro255   я добавил на стороне cсылки к файлам SHX (fulfals...   27.10.2006, 14:57
elektro255   it wil be in future SW versions. This SW is stab...   27.10.2006, 19:34
elektro255   all this bugs depends on flex, i don't have...   28.10.2006, 8:39
Monty   я так понимаю очередной релиз ?! Elektro255_ba...   29.10.2006, 8:33
Monty   я тоже сначала поставил 1 и 3 части, и тоже все ра...   30.10.2006, 6:55
elektro255   http://elektro255.ovh.org/ website upadate   30.10.2006, 10:29
Archy   Так у него как раз ДРМ от 70-й серии. Проверь - з...   30.10.2006, 11:02
shayah   X3MAL, значит так: заходишь в плагин synergy, став...   30.10.2006, 16:07
elektro255   I don't know time will show   30.10.2006, 20:07
Алекс75   Кстати может кто в курсе,просто если честно лениво...   31.10.2006, 19:03
elektro255   я есть за   1.11.2006, 12:32
~Gangs2er~   Вот перевёл на досуге, на русский, ява приложение ...   7.11.2006, 16:48
elektro255   undo patches for *#06#   8.11.2006, 17:30
BackgaMan   Прежде эту тему почитай Прошивка Оригинального Ro...   12.11.2006, 15:19
elektro255   I''m back (exams passed) :D new beta http...   23.11.2006, 12:09
~Gangs2er~   Переведите пожалусто вот это: И вот это:   24.11.2006, 6:26
lv333   Первая часть уже переводилась, страницы полистай...   24.11.2006, 8:06
Bent   ну что непонятного-косяченно собрал или выложил пр...   24.11.2006, 8:25
lv333   Для тех кто с английским вообще не дружит :) htt...   24.11.2006, 9:09
elektro255   http://rapidshare.com/files/4612313/elektr...eflas...   24.11.2006, 10:02
juicedddd   Меняем Bootscreen в прошивке R373_0.2(49R)-=elektr...   26.11.2006, 11:40
elektro255   new SW will be today :) maybe at 7-11pm GMT+001 no...   26.11.2006, 12:24
elektro255   вы дождались :D V0.3 46R Final mod: http://elektr...   26.11.2006, 20:12
zolookas   Зеркало Rapishare: http://rapidshare.com/files/49...   26.11.2006, 21:01
elektro255   v0.3 on 49R will be today :) and maybe later for...   27.11.2006, 13:57
elektro255   http://elektro255.ovh.org/final.php v0.3 for 49R   27.11.2006, 16:40
~Gangs2er~   Я прошил только рефлэш, потверждаю всё работает, т...   27.11.2006, 18:07
JaneAir   Поставил я этот монстр(49R) и заметил,что когда фо...   27.11.2006, 18:27
p00p0k   Вот ссылка на моснтр: rapidshare.com Подробности ...   27.11.2006, 18:59
elektro255   Personalization tool workin only with binary full ...   27.11.2006, 19:30
StrIk3r   elektro255, patch not fixed problem with foto   27.11.2006, 19:44
StrIk3r   elektro255, [Patch_Code] ********:040...   27.11.2006, 20:00
elektro255   i forget to decrese adressz by 80000 in patch code...   27.11.2006, 20:02
StrIk3r   Вот патч я еще сам не успел проверить   27.11.2006, 20:10
Amenti   просто создайте файл с расширением .fpa. Запишите ...   27.11.2006, 20:11
StrIk3r   Раньше у меня намного фоты были лучше а сейчас все...   27.11.2006, 20:26
Dimka   elektro255! How it works? And as it to use. E...   27.11.2006, 22:01
syzspectroom   вот зеркала http://rapidshare.com/files/5097921/el...   27.11.2006, 23:14
Мачо   Сенсор (камера) И Работа С Ним elektro255, в про...   28.11.2006, 7:14
*НеХеR*   Это опять я! Так и не удается докачать рефлэш....   28.11.2006, 7:29
motobaltazor   0017c700.rar p.s. Пользовался "winhex'о...   28.11.2006, 11:48
elektro255   JPEG Quantization fix & tool & comparison ...   28.11.2006, 21:37
Фин   Народ Сори за !!!!!!...   28.11.2006, 22:47
Bent   Crestopher, У меня Касперский 6.0,сегодня обновил ...   29.11.2006, 3:59
motobaltazor   zerrow, на сайте elektro лежит патч, который долже...   29.11.2006, 12:20
*НеХеR*   Мдя.. И это пишет человек с рейтингом 13 bigsmil...   29.11.2006, 14:25
StrIk3r   Вот нашел адреса которые использует [b]electro255 ...   29.11.2006, 18:55
Bent   Вот вам для 49R... Алекс75 , я делал так,в папку ...   30.11.2006, 9:03
gendos@xaker.ru   Господа, только сейчас заметил, что перестала рабо...   30.11.2006, 9:59
Nogay   У меня в ява-приложении на 4-ке фотки фесят 65кб, ...   30.11.2006, 13:23
Fizmat-Ramzes   че-то я не понял, как пользоваться этой явой. Захо...   30.11.2006, 14:01
p00p0k   Ovip, 0032_001 вот тебе правленный сим, без всяки...   30.11.2006, 15:33
Raziel_sh   я сам 0.3 beta не ставил,но интересно,может кто-ни...   30.11.2006, 16:46
StrIk3r   И так давайте прежде чам разбирать качество фотосн...   30.11.2006, 16:50
Ovip   т.е. чтобы узнать какая у тебя камера надо скач...   1.12.2006, 10:38
StrIk3r   p00p0k, AGILENT ADCM2700 62   30.11.2006, 19:22
Fizmat-Ramzes   StrIk3r, У меня камера на теле, как на твоем, мо...   30.11.2006, 20:18
A.06   elektro255, could you make a patch which will play...   1.12.2006, 12:22
_TRANE_   Пипл,Ахтунг. У меня ща стоит STM RELOAD(48r), но я...   1.12.2006, 12:34
9 страниц V  1 2 3 > »
Текстовая версия Сейчас: 18.7.2025, 20:41
