23 страниц V « < 17 18 19 20 > »
Elektro255 V0.4 alpha 4 mod (4xR), 44R,46R,49R,79R
elektro255
сообщение 23.9.2006, 12:06 Закрепленное сообщение!
Из: Poland, Siedlce
Пользователь №: 53 130
09-04-2007
V0.4a4 Alpha: http://elektro255.ovh.org
08-04-2007
V0.4a3 Alpha: http://elektro255.ovh.org
07-04-2007
V0.4a2 44R Alpha: http://elektro255.ovh.org
20-12-2006
V0.3 79R Final mod: http://elektro255.ovh.org
27-11-2006
v0.3 for 49R Final mod http://elektro255.ovh.org/
26-11-2006
V0.3 46R Final mod: http://elektro255.ovh.org
НА Е1 Rokr с бутом 0А02 (оригинальный) НЕ ПОСТАВИТЕ БЕЗ Т.П.!
V0.4 alpha 4
Changes:
- Fixed problem with display timeout (fullscreen clock) when SMS/CALL received
Features:
- 4xR and 7xR MIX (use with 4xR flex)
- unlimited Video recording
- keypad automatic lock
- low battery alarm can be turned off or depend on ring style.
- Scheduled Ring Styles (ring style and funlight style can change automatically on given time and week day)
- flashlight shortcut (##)
- extra menu (shortcut *1 [shortcut is only for testing later will be changed])
- automatic menu enter, without sim card (emergency calls working too)
- new Java methods
- settings are stored on files
- no simlock checking
- Volume-bar sound can be turned off
- multiple menus (every skin can have one mma_ucp)
- Ported patches:
o SMS report significantly turned ON
o more folders in OBEX via BT
o removed unused folders from TransFlash
o Java have access to system files
o increased iTap user dictionary size
o no delete incall on SIM replace
o Bluetooth time changed to 3 minutes
o reordered camera store menu (store only is first)
o SMS alert is using default ringtone
OLD versions(V0.1-0.3):
Firmware changes:
- firmware based on 46R from StarterXP MP
- FULL SW access from Java
- LUMA&CHROMA tables moved to memory - now you can change JPEG compresion from Java
- StarterXP flex
- added dualboot
Flasher changes:
- if you have PDS_4013 flasher will no recreate this
Personalization tool changes:
- first version for 0.3_46R SW mod
- changing splash screen
- changing font (you can use *.fnt or *.smg CG4 files)
- you can turn on, turn off menu access without sim cart
- changing my shortcuts
Новая версия V0.4 alpha 4
Изменения:
- Устранена проблема с таймаутом дисплея(полноэкранные часы) при приеме смс/звонка
Новое:
- Прошивка создана как микс 4xR и 7xR (флекс 4xR ) В 44R она переименована для совместимости! Она близко не лежит к 44R на самом деле!
- Безлимитная запись видео (64мб макс как в 6х7х)
- Автоблок клавиатуры
- Звук разряженой батареи можно выключать или задать стилем оповещения(?).
- Расписание стилей оповещения (стиль оповещения и фанлайтмогут менятся автоматически по времени и дням недели)
- Фонарик по (##)
- Дополнительное меню (метка *1 [только для теста, после может изменится])
- Автоматический вход в меню без сим-карты (аварийные звонки работают)
- Новые методы в Яве (не от 79R, а новые)
- Настройки хранятся в файлах
- Не проверяется лоченость ПДС на симку (работает с лоченым пдс)
- Звук изменения громкости можно отключить
- Мультименю (каждый скин может иметь собственный мма_уцп)
- Портированы патчи:
o Оповещение о доставке SMS всегда вкл.
o больше папок доступно по OBEX из блютуза
o удалены неиспользуемые папки с флешки
o Полный доступ к системным файлам из явы
o увеличен размер пользовательского словаря iTap
o не удалыются последние вызовы при смене сим
o Время обнаружения блютуза - 3 минуты
o Меню сохранения видеозаписи (просто сохранить - первым пунктом)
o при приходе SMS играет "мелодия на смс", а не установленная на этого пользователя
Для версий 0.1-0.3
Изменения в прошивке:
- Создана на базе монстра StarterXP 46R
- Полный доступ к прошивке (симы, озу) из явы
- Таблицы сжатия фотографий перенесены в озу - теперь из явы можно управлять качеством фотографий (сжатием)
- флекс StarterXP
- добавлен дуалбут
Изменения флешера:
-Если ПДС версии 4013 (373 платформа), ПДС не пересоздается.
Изменения персонализации (Personalization tool):
- впервые для мода использована 46 прошивка
- замена заставки (на включение?)
- замена шрифта (лангпак, CG4)
- можно вкл. и выкл. доступ к меню без сим-карты
- изменен ярлык (копирайт?)
Для работы Personalization tool требуется положить в папку программы несжатый бинарный бэкап (32 мегабайта) под именем SW.bin
Прекращаем флудить, типа а когда выйдет новая версия, и.т.д.и.т.п, или придётся наказывать!
тему почистил, архив по 1 декабря тут:
Прикрепленный файл MotoFan_ru_electro.zip   ( 66.56 килобайт ) Кол-во скачиваний: 3902
Сообщение отредактировал elektro255 - 9.4.2007, 12:21
=BazOOka=
сообщение 11.4.2007, 14:56
Пользователь №: 107 478
Модель телефона: rokr e2
Прошивка: 4AP
QUOTE(sader @ Today, 18:40)
Спасибо, а то я весь телефон перерыл - не мог найти. И ещё вопрос: почему у меня не идут почти все игры с флешки, установленные до перепрошивки?
Что пишут при запуске?
sader
сообщение 11.4.2007, 17:29
Из: Р-ка Карелия, г. Сегежа
Пользователь №: 117 834
Пишет, что какое-то время у приложения истекло, надо проверить дату в основных настройках, ну или что-то вроде этого...
Side
сообщение 11.4.2007, 18:06
Из: Мурманск
Пользователь №: 81 705
Модель телефона: V535, EM30
У тебя до этого была 79r ? Для нее несколько другой принцип установки Java.
Скорее всего у тебя эти игры поставлены с атрибутом signed и подписью, это работает только на патченой 79, а на этой прошивке (судя по рекомендуемому флексу она на базе 4x) вызывает описанную тобой ошибку т.к. подпись то левая.
Попробуй снять атрибут signed с помощью Moto Midlets Manager, если не поможет то только переустанавливать.
Rahim
сообщение 11.4.2007, 20:16
Из: Баку
Пользователь №: 103 929
Прошивка: почти ФранкейштейН
привет.
я скачал последную версию v0.4a4. толко updater у меня не открывается . толко внизу зависает и все. и srs_editor тоже открывается и зависает внизу.
SAM398
сообщение 11.4.2007, 20:37
Пользователь №: 93 560
Модель телефона: Nokia 6681
Столкнулся с такой проблемой. Тело E398, проша была electro255 v.02 49R. Зарядил полностью, решил прошить electro255 v.04а4. Прошил без проблем. Через пару дней разрядился аккумулятор, поставил заряжать на ночь. Утром просыпаюсь, на теле "Зарядка закончена". В информаторе смотрю напряжение и не верю, 2.10 В mad.gif Через Senerjy посмотрел - тоже самое. Взял тестер, померил - в норме, 4.10 В. Странно. Вот уже вечер, весь день то звонил, то через GPRS в инет лазил, а все равно показывает 2.10 В. Что посоветуете? Залить бэкап? Или в чем-то еще дело?
Как кто-то уже упоминал частые перезагрузки тела при использовании GPRS+комп или просто GPRS+Jimm(или opera mini), и конечно же треск при перемещении по меню.
sader
сообщение 11.4.2007, 21:07
Спасибо! С играми наконец-то разобрался, но тут же возник другой вопрос: какой для MV нужен SoundEditor? (SE из 0.4a2 показывает почти все значения равными 255 ( или 254))
ARMAGEDON1988
сообщение 11.4.2007, 21:26
Пользователь №: 75 249
Модель телефона: 6233
Извините у меня щас стоит прошывка MotoWalkman49R_EM_by_Maxval_&_LexusRX400 как мне сюда поставить V0.4a4 и дайте пажалусто сылку штоб скачать ето прошу. sad.gif
gunghost
сообщение 12.4.2007, 3:11
Пользователь №: 71 735
Прошивка: Всегда самая лудшая
Смотри в шапке ссылку. Качаешь 09-04-2007 - V0.4 alpha 4 (4xR, 7xR MIX). Запускаешь опдейтер и шьёшь. clap.gif
MotoFan666
сообщение 12.4.2007, 3:57
Пользователь №: 88 072
Модель телефона: HTC Desire
Прошивка: Android 2.2
Хм..
вломак читать всю тему...спрошу так...
влил себе альфу4 , и пытаюсь проверить баланс ( *102# ), но после набора *1 он входит в какоето спец-меню....
как быть?
lexus2000
сообщение 12.4.2007, 5:33
Пользователь №: 56 309
Цитата(MotoFan666 @ 12.4.2007, 6:57) *
Хм..
как быть?
Electro 2555 сделал это временно для теста. поэтому если тебе это очень нужно изменить, то поставть патч, о его сделал 9.04.2007 (см его сайт). вот ссылка на его патчи патч для отмены и также описание Patches:
Send files via BT **FIXED**
change lock/unlock keypad shortcut
change *1 shortcut (if you have *1xxxx network codes)
change skins folder to /a/mobile/skins
Перевод:
патчи:
Отправка файлов через Блютуф **Исправлено**
изменение кл комбинации на блокировку\разблокировку клавиатуры
изменение клавиатурной комбинации *1 (если вы используйте код *1ХХХ)
изменение папки для скинов на /a/mobile/skins
Side
сообщение 12.4.2007, 9:05
Из: Мурманск
SAM398,
electro255 писал что с 3 и 4 альфой нельзя использовать старые java программы и модули MV. Они скорее всего будут показывать неправильные значения или вообще можно что-нибуть испортить, связано это с тем что адреса в памяти поменялись. Остается ждать final мода.
Сообщение отредактировал Side - 12.4.2007, 9:05
deadmoto
сообщение 12.4.2007, 10:54
Главный Новостник
Из: Омск
Пользователь №: 49 284
Модель телефона: Motorola
Прошивка: Motorola Original
elektro255, thereis one interesting bug:
Alerts dissapear when phone is idle more then 1-2 hour and then phone don't play any sounds or vibrate.
And about strange sound that appears when writing text - i like it))) but it will be better if it will be turned on or off constantly)))
kipish89
сообщение 12.4.2007, 11:02
Пользователь №: 100 309
Модель телефона: Motorola V3
Прошивка: R374_G_0E.42.17R
Вчера поставил альфу4...так вот: Стили оповещения не меняются т.е. стоит у меня стиль На улице, ставлю вибро-вызов, но ничего кроме картинки возле батарейки не меняется...так и остается На улице... С инетом конектится, но иногда почему то опера подвисает sad.gif
om2804
сообщение 12.4.2007, 12:09
МотоКодер
Из: Архангельск
Пользователь №: 95 055
Прошивка: DaR
1) iTap превратился в T9. Используется только пользовательский словарь, а из встроенного в леге ничего не берет.
2) При использовании тела в качестве модема периодически уходит в ребут
3) На счет полного доступа к системным файлам из ява: пробовал удалить системный файл MiniCommander'ом - "Невозможно удалить"
Сообщение отредактировал om2804 - 12.4.2007, 12:26
Unlimit
сообщение 12.4.2007, 13:34
Пользователь №: 93 764
Модель телефона: Nokia N73
Прошивка: Symbian OS v9.1
Так и будет показывать 2.10 В, потому что в этой прошивке изменились адреса которые показывают напряжение. elektro255 писал же что все старые ява-проги не будут работать на этой прошивке.
BackgaMan
сообщение 12.4.2007, 15:31
Мотоумелец
Пользователь №: 61 651
Модель телефона: E-398 Htc-p3300
Цитата(MotoFan666 @ Сегодня, 7:57)
Хм..
как быть?
Я делаю так, нажимаю звездочку выдерживаю небольшую паузу секунд 5 и набираю дальше wink.gif
=BazOOka=
сообщение 12.4.2007, 16:05
Прошивка: 4AP
А я просто "Баланс" в справочнике написал и его вызываю (у меня тоже *102#)
kemre
сообщение 12.4.2007, 18:31
Пользователь №: 121 096
Прошивка: LP 49R
дак поставьте патч на смену комбинации *1 на *# и все.
X3M-pro
сообщение 12.4.2007, 18:40
Пользователь №: 95 971
Модель телефона: E398 +512Mb
Читаю тему и смотрю, что еще довольно много вопросов вознтикает после установки этого патча, вот и хочу спросить скоро ли выйдет финальная версия, в которой будут исправлены баги??? shades.gif
~Gangs2er~
сообщение 12.4.2007, 18:51
MotoSkinner
Пользователь №: 93 787
Модель телефона: (M) E398
Прошивка: У вас такой нету))
Elektro255. Как быть с itap? Он не одного слова не запоминает! Так, и по поводу работы тела без сим карты, всё работаит, только в мелодии и картинки не заходит.
Trentemoller
сообщение 12.4.2007, 19:05
Из: Армавир
Пользователь №: 105 953
Прошивка: R373_G_0E.30.49R
~Gangs2er~,
В мелодии и картинки незаходит и на 0.2 моде. Насчет 0.3 незнаю, непробывал!
X3M-pro,
Нужно исправить 2 главных бага, это-сделать анимацию быструю и убрать треск перемещении по меню!
Timik
сообщение 12.4.2007, 19:08
Пользователь №: 100 902
Прошивка: даже не знаю теперь
Да, по поводу iTap, я уже что только не пробовал..как не работал так и не работает..
Добавлено позже (12.4.2007, 23:59):
[/b]Короче список багов, которые по любому надо исправить:
[b]1. iTap, без него вообще никак.
2. Ускорить анимацию.
3. Убрать щелчки.
4. Убрать ребуты при включенном Jimm или MIP и при использовании телефона как модема.
5. Сделать нормальное отображение заряда батареи и работу эквалайзера в MV.
6. Изначально поменять включение меню с *1 на *#, (чтоб меньше вопросов было)..
Это я написал только в пользу создания монстра..чтоб не собирать по всей теме.. надеюсь меня поймут..
[/b]
om2804
сообщение 12.4.2007, 20:14
МотоКодер
Из: Архангельск
Прошивка: DaR
*# не подходит, т. к. есть ещё *#06# и *#9999#
Зачем вобще это нужно. Достаточно в меню добавить Технология, а на неё можно и быструю метку поставить
Timik
сообщение 12.4.2007, 20:16
om2804,
om2804,
Ну или так, это неосновная проблема..
sader
сообщение 12.4.2007, 20:17
Только сейчас заметил: щелчки при перемещении по меню пропали (хотя вчера ещё были). Только как я это сделал не знаю...
X3M-pro
сообщение 12.4.2007, 20:31
И когда же примерно появится версия с исправлениями выше перечисленых неудобств????
afon4ik
сообщение 12.4.2007, 21:02
Пользователь №: 117 290
Вы мне объясните (я просто очень плохо секу во всех этих прошивках). Как сделать прошивку на базе eletro255_v4? Я пробывал так, сначала ставил v4_alpha1 и потом с помощью флэш бэкапа наверх из другой прошивы ставил CG2, CG4, CG15 тоесть флекс, лэнгпак и DRM, всё бы хорошо, но появился такой лаг, что когда заходишь в языки и пытаешься выбрать нужный, оно выкидывает в главное меню...
Может кто подскажет, что нужно правильно делать, а тчо нельзя..?
deadmoto
сообщение 13.4.2007, 2:50
Главный Новостник
Из: Омск
om2804, ты скажи чесно - ты пробовал юзать комбинацию *#? Когда ты набираешь *# нужно ждать еще почти 2 секунды чтоб попасть в меню электро)))
yurybol
сообщение 13.4.2007, 9:17
Из: Ростовская область.
Пользователь №: 12 235
Прошивка: Надеюсь поменять
Кстати, ребутов нету нету, если стоят флекс, дрм и ленг от MPX49R монстра.
По крайней мере, при использовании gprs модема...
ЗЫЗЫ. На 52 минуте - облом %( и пошел перезагружаться.
Сообщение отредактировал yurybol - 13.4.2007, 9:33
Prometeius
сообщение 13.4.2007, 10:00
Пользователь №: 121 989
Модель телефона: V360
Прошивка: ACR
elektro255,
В патче send files via BT косяк. При приеме файлов более 70 Kb телефон в конце приема перезагружается. Файлы до 70 Kb принимаются нормально.
om2804
сообщение 13.4.2007, 11:38
МотоКодер
Из: Архангельск
Прошивка: DaR
Полный доступ к системным файлам из явы работает хоть на каком нибудь моде? Пробовал v2 и alfa 4 - без результатно
Timik
сообщение 13.4.2007, 11:41
Prometeius
сообщение 13.4.2007, 11:47
Прошивка: ACR
om2804,
У меня на последнем моде работает. И из Mini Comandera, и из MediaViewera.
All,
Проверьте патч на передачу файлов через BT. У всех при приеме файлов размером более 70 Kb ребутится?
nekr
сообщение 13.4.2007, 11:54
Пользователь №: 103 477
Прошивка: от всего по маленьку
а как отменить уведомления о доставки смс???
sader
сообщение 13.4.2007, 16:32
Я тоже пробовал в MV удалить mma_upc - не удаляет.
Сергей_Motofan
сообщение 13.4.2007, 17:07
Из: г. Оренбург
Пользователь №: 85 146
Прошивка: CM 12.1 5.1.1
..::MotoLife::..
nekr,
Необходимо применить патч отката!!
elektro255
сообщение 13.4.2007, 20:10
Из: Poland, Siedlce
http://rapidshare.com/files/25746741/fullb...0.4a4_.rar.html
my full backup can, you check this slow animation ? because I don't have 1 frame per second i have about 6 FPS
Сообщение отредактировал elektro255 - 13.4.2007, 20:11
sader
сообщение 13.4.2007, 21:16
Скажите пожалуйста, сейчас короткое нажатие кнопки гарнитуры переключает на следущую песню, а длинное - перемотка. Можно ли сделать так, чтобы при коротком нажатии ставилась пауза, при длинном - следущуая песня?
Denis_chel
сообщение 14.4.2007, 3:57
Из: Челябинск
Пользователь №: 84 929
Прошивка: Dream a reality
У меня такой баг: при установке в будильнике оповещения на вибро- оно срабатывает всего один раз и замолкает. У всех так?
=BazOOka=
сообщение 14.4.2007, 4:13
Прошивка: 4AP
QUOTE(sader @ Today, 1:16)
Вроде нет, так как предложенные тобой функции - с разных клавиш, а та что сейчас- от одной (джойстик вправо). Но можешь пробовать прогой MenuEditor
Текстовая версия Сейчас: 22.7.2025, 6:00
