23 страниц V « < 17 18 19 20 > »
Elektro255 V0.4 alpha 4 mod (4xR), 44R,46R,49R,79R
elektro255
сообщение 23.9.2006, 12:06 Закрепленное сообщение!
Из: Poland, Siedlce
Пользователь №: 53 130
09-04-2007
V0.4a4 Alpha: http://elektro255.ovh.org
08-04-2007
V0.4a3 Alpha: http://elektro255.ovh.org
07-04-2007
V0.4a2 44R Alpha: http://elektro255.ovh.org
20-12-2006
V0.3 79R Final mod: http://elektro255.ovh.org
27-11-2006
v0.3 for 49R Final mod http://elektro255.ovh.org/
26-11-2006
V0.3 46R Final mod: http://elektro255.ovh.org
НА Е1 Rokr с бутом 0А02 (оригинальный) НЕ ПОСТАВИТЕ БЕЗ Т.П.!
V0.4 alpha 4
Changes:
- Fixed problem with display timeout (fullscreen clock) when SMS/CALL received
Features:
- 4xR and 7xR MIX (use with 4xR flex)
- unlimited Video recording
- keypad automatic lock
- low battery alarm can be turned off or depend on ring style.
- Scheduled Ring Styles (ring style and funlight style can change automatically on given time and week day)
- flashlight shortcut (##)
- extra menu (shortcut *1 [shortcut is only for testing later will be changed])
- automatic menu enter, without sim card (emergency calls working too)
- new Java methods
- settings are stored on files
- no simlock checking
- Volume-bar sound can be turned off
- multiple menus (every skin can have one mma_ucp)
- Ported patches:
o SMS report significantly turned ON
o more folders in OBEX via BT
o removed unused folders from TransFlash
o Java have access to system files
o increased iTap user dictionary size
o no delete incall on SIM replace
o Bluetooth time changed to 3 minutes
o reordered camera store menu (store only is first)
o SMS alert is using default ringtone
OLD versions(V0.1-0.3):
Firmware changes:
- firmware based on 46R from StarterXP MP
- FULL SW access from Java
- LUMA&CHROMA tables moved to memory - now you can change JPEG compresion from Java
- StarterXP flex
- added dualboot
Flasher changes:
- if you have PDS_4013 flasher will no recreate this
Personalization tool changes:
- first version for 0.3_46R SW mod
- changing splash screen
- changing font (you can use *.fnt or *.smg CG4 files)
- you can turn on, turn off menu access without sim cart
- changing my shortcuts
Новая версия V0.4 alpha 4
Изменения:
- Устранена проблема с таймаутом дисплея(полноэкранные часы) при приеме смс/звонка
Новое:
- Прошивка создана как микс 4xR и 7xR (флекс 4xR ) В 44R она переименована для совместимости! Она близко не лежит к 44R на самом деле!
- Безлимитная запись видео (64мб макс как в 6х7х)
- Автоблок клавиатуры
- Звук разряженой батареи можно выключать или задать стилем оповещения(?).
- Расписание стилей оповещения (стиль оповещения и фанлайтмогут менятся автоматически по времени и дням недели)
- Фонарик по (##)
- Дополнительное меню (метка *1 [только для теста, после может изменится])
- Автоматический вход в меню без сим-карты (аварийные звонки работают)
- Новые методы в Яве (не от 79R, а новые)
- Настройки хранятся в файлах
- Не проверяется лоченость ПДС на симку (работает с лоченым пдс)
- Звук изменения громкости можно отключить
- Мультименю (каждый скин может иметь собственный мма_уцп)
- Портированы патчи:
o Оповещение о доставке SMS всегда вкл.
o больше папок доступно по OBEX из блютуза
o удалены неиспользуемые папки с флешки
o Полный доступ к системным файлам из явы
o увеличен размер пользовательского словаря iTap
o не удалыются последние вызовы при смене сим
o Время обнаружения блютуза - 3 минуты
o Меню сохранения видеозаписи (просто сохранить - первым пунктом)
o при приходе SMS играет "мелодия на смс", а не установленная на этого пользователя
Для версий 0.1-0.3
Изменения в прошивке:
- Создана на базе монстра StarterXP 46R
- Полный доступ к прошивке (симы, озу) из явы
- Таблицы сжатия фотографий перенесены в озу - теперь из явы можно управлять качеством фотографий (сжатием)
- флекс StarterXP
- добавлен дуалбут
Изменения флешера:
-Если ПДС версии 4013 (373 платформа), ПДС не пересоздается.
Изменения персонализации (Personalization tool):
- впервые для мода использована 46 прошивка
- замена заставки (на включение?)
- замена шрифта (лангпак, CG4)
- можно вкл. и выкл. доступ к меню без сим-карты
- изменен ярлык (копирайт?)
Для работы Personalization tool требуется положить в папку программы несжатый бинарный бэкап (32 мегабайта) под именем SW.bin
Прекращаем флудить, типа а когда выйдет новая версия, и.т.д.и.т.п, или придётся наказывать!
тему почистил, архив по 1 декабря тут:
Прикрепленный файл MotoFan_ru_electro.zip   ( 66.56 килобайт ) Кол-во скачиваний: 3902
Сообщение отредактировал elektro255 - 9.4.2007, 12:21
Trentemoller
сообщение 12.4.2007, 19:05
Из: Армавир
Пользователь №: 105 953
Прошивка: R373_G_0E.30.49R
~Gangs2er~,
В мелодии и картинки незаходит и на 0.2 моде. Насчет 0.3 незнаю, непробывал!
X3M-pro,
Нужно исправить 2 главных бага, это-сделать анимацию быструю и убрать треск перемещении по меню!
Timik
сообщение 12.4.2007, 19:08
Пользователь №: 100 902
Прошивка: даже не знаю теперь
Да, по поводу iTap, я уже что только не пробовал..как не работал так и не работает..
Добавлено позже (12.4.2007, 23:59):
[/b]Короче список багов, которые по любому надо исправить:
[b]1. iTap, без него вообще никак.
2. Ускорить анимацию.
3. Убрать щелчки.
4. Убрать ребуты при включенном Jimm или MIP и при использовании телефона как модема.
5. Сделать нормальное отображение заряда батареи и работу эквалайзера в MV.
6. Изначально поменять включение меню с *1 на *#, (чтоб меньше вопросов было)..
Это я написал только в пользу создания монстра..чтоб не собирать по всей теме.. надеюсь меня поймут..
[/b]
om2804
сообщение 12.4.2007, 20:14
МотоКодер
Из: Архангельск
Пользователь №: 95 055
Прошивка: DaR
*# не подходит, т. к. есть ещё *#06# и *#9999#
Зачем вобще это нужно. Достаточно в меню добавить Технология, а на неё можно и быструю метку поставить
Timik
сообщение 12.4.2007, 20:16
om2804,
om2804,
Ну или так, это неосновная проблема..
sader
сообщение 12.4.2007, 20:17
Из: Р-ка Карелия, г. Сегежа
Пользователь №: 117 834
Только сейчас заметил: щелчки при перемещении по меню пропали (хотя вчера ещё были). Только как я это сделал не знаю...
X3M-pro
сообщение 12.4.2007, 20:31
Пользователь №: 95 971
Модель телефона: E398 +512Mb
И когда же примерно появится версия с исправлениями выше перечисленых неудобств????
afon4ik
сообщение 12.4.2007, 21:02
Пользователь №: 117 290
Вы мне объясните (я просто очень плохо секу во всех этих прошивках). Как сделать прошивку на базе eletro255_v4? Я пробывал так, сначала ставил v4_alpha1 и потом с помощью флэш бэкапа наверх из другой прошивы ставил CG2, CG4, CG15 тоесть флекс, лэнгпак и DRM, всё бы хорошо, но появился такой лаг, что когда заходишь в языки и пытаешься выбрать нужный, оно выкидывает в главное меню...
Может кто подскажет, что нужно правильно делать, а тчо нельзя..?
deadmoto
сообщение 13.4.2007, 2:50
Главный Новостник
Из: Омск
Пользователь №: 49 284
Модель телефона: Motorola
Прошивка: Motorola Original
om2804, ты скажи чесно - ты пробовал юзать комбинацию *#? Когда ты набираешь *# нужно ждать еще почти 2 секунды чтоб попасть в меню электро)))
yurybol
сообщение 13.4.2007, 9:17
Из: Ростовская область.
Пользователь №: 12 235
Прошивка: Надеюсь поменять
Кстати, ребутов нету нету, если стоят флекс, дрм и ленг от MPX49R монстра.
По крайней мере, при использовании gprs модема...
ЗЫЗЫ. На 52 минуте - облом %( и пошел перезагружаться.
Сообщение отредактировал yurybol - 13.4.2007, 9:33
Prometeius
сообщение 13.4.2007, 10:00
Пользователь №: 121 989
Модель телефона: V360
Прошивка: ACR
elektro255,
В патче send files via BT косяк. При приеме файлов более 70 Kb телефон в конце приема перезагружается. Файлы до 70 Kb принимаются нормально.
om2804
сообщение 13.4.2007, 11:38
МотоКодер
Из: Архангельск
Прошивка: DaR
Полный доступ к системным файлам из явы работает хоть на каком нибудь моде? Пробовал v2 и alfa 4 - без результатно
Timik
сообщение 13.4.2007, 11:41
Prometeius
сообщение 13.4.2007, 11:47
Прошивка: ACR
om2804,
У меня на последнем моде работает. И из Mini Comandera, и из MediaViewera.
All,
Проверьте патч на передачу файлов через BT. У всех при приеме файлов размером более 70 Kb ребутится?
nekr
сообщение 13.4.2007, 11:54
Пользователь №: 103 477
Прошивка: от всего по маленьку
а как отменить уведомления о доставки смс???
sader
сообщение 13.4.2007, 16:32
Я тоже пробовал в MV удалить mma_upc - не удаляет.
Сергей_Motofan
сообщение 13.4.2007, 17:07
Из: г. Оренбург
Пользователь №: 85 146
Прошивка: CM 12.1 5.1.1
..::MotoLife::..
nekr,
Необходимо применить патч отката!!
elektro255
сообщение 13.4.2007, 20:10
Из: Poland, Siedlce
http://rapidshare.com/files/25746741/fullb...0.4a4_.rar.html
my full backup can, you check this slow animation ? because I don't have 1 frame per second i have about 6 FPS
Сообщение отредактировал elektro255 - 13.4.2007, 20:11
sader
сообщение 13.4.2007, 21:16
Скажите пожалуйста, сейчас короткое нажатие кнопки гарнитуры переключает на следущую песню, а длинное - перемотка. Можно ли сделать так, чтобы при коротком нажатии ставилась пауза, при длинном - следущуая песня?
Denis_chel
сообщение 14.4.2007, 3:57
Из: Челябинск
Пользователь №: 84 929
Прошивка: Dream a reality
У меня такой баг: при установке в будильнике оповещения на вибро- оно срабатывает всего один раз и замолкает. У всех так?
=BazOOka=
сообщение 14.4.2007, 4:13
Пользователь №: 107 478
Модель телефона: rokr e2
Прошивка: 4AP
QUOTE(sader @ Today, 1:16)
Вроде нет, так как предложенные тобой функции - с разных клавиш, а та что сейчас- от одной (джойстик вправо). Но можешь пробовать прогой MenuEditor
novis
сообщение 14.4.2007, 14:47
Из: г.Ижевск
Пользователь №: 76 691
Прошивка: 79r
Уважаемый elektro.
Реально ли сделать на е398 функцию как на simens'ах "виртуальный" multisim. Что бы иметь в памяти несколько sim'ок разных сотовых операторов и переключаться между ними?
спасибо.
om2804
сообщение 14.4.2007, 15:45
МотоКодер
Из: Архангельск
Прошивка: DaR
у некоторых iTuns'ов при коротком нажатии джостик вверх ставится пауза , при длинном - следущуая песня. Так что назначай кнопке гарнитуры джостик вверх
NeoShaMAN
сообщение 14.4.2007, 18:44
Из: Великий Новгород
Пользователь №: 118 943
Модель телефона: Sony Xperia Z2 D6503
Прошивка: 6.0.1
такой вопрос, а тут с ММС всё в порядке?
Dimarik090
сообщение 15.4.2007, 7:35
Пользователь №: 121 546
Модель телефона: E398+microsd 512
Прошивка: 49r
Кто тестил,фишка с 2мя мма_уцп точно работает,если да,то как???!!
San3k
сообщение 15.4.2007, 8:47
Пользователь №: 108 480
Модель телефона: Nokia 5310; E398
млин... все работает, открыть мануал от электро чтоли трудно?..
берешь mma_ucp, смотришь какой по счету скин (Личные настройки->Облочка раб. стола), если скин там первый - переименовываешь mma_ucp в mma_ucp0 и заливаешь его в a:\mobile\system\
если скин второй, то нужно mma_ucp1
елси скин третий - mma_ucp2 и так далее.
Яуген
сообщение 15.4.2007, 11:08
Пользователь №: 101 871
AsteriXQ, скачивай прошу, разархивируй, открой фб3, там в разделе чтения данный бэкап сделай, а потом в разделе запись данных выбирай эту прошу и нажимай запись. А вообще надо юзать поиск, мануалы на форуме есть
AsteriXQ
сообщение 15.4.2007, 11:52
Из: Уфа
Пользователь №: 97 671
Модель телефона: Moto E398
Прошивка: Mpx 398 De luxe
Цитата(dARkN3sS @ 15.4.2007, 17:08) *
Качаешь вот этот архив, разархивируешь, переключаешь тело, в архиве лежит программа называется UPDATER запускаешь её, сначала будет написанно Disconnect, подожди немного, прога напишет синим шрифтом Что-то про переключение в P2K-mode, зател тело переведётся в бут-режим и в прогу зелёнм шрифтом будет написанно Connect потом просто нажимаешь Update и спокойно ждёшь пока тело прошивается.
Можно чуть прощё, переводишь тело в бут, вребаешь USB, потом включаешь UPDATER, прога должна сразу написать Connect, жмякаешь кнопку update в проге и ждёшь...
Главное чтобы программа и прошивка лежали в одной папке!
Прошивка называется update.BIN
спс. тока у меня не пашет прошивка, прошивается, но после перезагрузки меняется тока начальная заставка и всё.
Яуген - прошивать то я умею.
Сообщение отредактировал AsteriXQ - 15.4.2007, 11:52
Acceptor
сообщение 15.4.2007, 12:00
Пользователь №: 131 036
Прошивка: Electro255 mod 0.3
AsteriXQ, так и надо это не полная проша, а только CG1... Все скины, настройки и т.д. остаётся как у тя было раньше.. А всё что она изменяет написано в 1 посте smile.gif
AsteriXQ
сообщение 15.4.2007, 12:15
Из: Уфа
спс.
romak
сообщение 15.4.2007, 12:21
Пользователь №: 68 003
Модель телефона: motorolaE398
Прошивка: R373
прошился electro mod 0.4а.4 далее пропатчил, но у меня при любои коннекте с нетом тело уходит в ребут!!!!че делать?подскажите??? sad.gif sad.gif sad.gif
AsteriXQ
сообщение 15.4.2007, 13:19
Из: Уфа
прошился, ваще не каких имоций, как будто не чо и небыло...
AleksX
сообщение 15.4.2007, 13:52
Из: Пермь
Пользователь №: 68 183
Модель телефона: L7e,Nokia 5700
Прошивка: Mpx398 De Luxe
У меня вообще на моде 4а4 не работает клава..Кроме кнопки вкл. 0 и #.. sad.gif Хотя прошился симбой 1.5 на ней все работает..
San3k
сообщение 15.4.2007, 15:36
А ты чего хотел? Это мод - он добавляет новые возможности, а не какие-нибудь графические элементы...
sadface
сообщение 15.4.2007, 18:09
Пользователь №: 110 110
Модель телефона: Z6 + Kingston 2GB
Прошивка: 44R + PE
romak,
Ждать пока этот баг уберут. У меня точно так же, я именно по этому на 0.3 откатился
Acceptor
сообщение 16.4.2007, 7:32
Прошился, вроде норм...
Замеченные баги:
1)На 15 минуте тел ушёл в ребут, но сейчас норм (22 часа непрерывно работает...)
2)При подключении Jimm ушёл в ребут (при повторной попытке подключается, но отказывается принимать и отсылать сообщения)
В целом: Electro255 - молодец, с такими шагами наша 398 скоро станет смартом clap.gif
AsteriXQ
сообщение 16.4.2007, 9:00
Из: Уфа
Цитата(Acceptor @ 16.4.2007, 13:32) *
оффтоп: чё ща мод ?
goods
сообщение 16.4.2007, 9:55
Пользователь №: 91 380
Модель телефона: E398 + 1Gb
Прошивка: DaR
Я еле скачал( качал по ссылке 09-04-2007)думал она будет 49r а после того как поставил она оказась 79r…. На ней не работал эквалайзер…… sad.gif sad.gif Подскажите плз где скачать 49r?
Сообщение отредактировал goods - 16.4.2007, 10:11
=BazOOka=
сообщение 16.4.2007, 11:01
Прошивка: 4AP
QUOTE(goods @ Today, 13:55)
om2804
сообщение 16.4.2007, 13:21
МотоКодер
Из: Архангельск
Прошивка: DaR
elektro255, narrate in detail about java method jmp. give me class with jmp. I Beg pardon for my english
elektro255, расскажи подробнее о ява методе jmp. Дай класс с jmp. C версией V0.4a4 jmp в классе нет.
Acceptor
сообщение 16.4.2007, 17:32
оффтоп: чё ща мод ?
Да эт я так про будущее ))
ЗЫ С инетом ваще никак не разобраться???
Текстовая версия Сейчас: 21.7.2025, 5:05
