23 страниц V « < 18 19 20 21 > »
Elektro255 V0.4 alpha 4 mod (4xR), 44R,46R,49R,79R
elektro255
сообщение 23.9.2006, 12:06 Закрепленное сообщение!
Из: Poland, Siedlce
Пользователь №: 53 130
09-04-2007
V0.4a4 Alpha: http://elektro255.ovh.org
08-04-2007
V0.4a3 Alpha: http://elektro255.ovh.org
07-04-2007
V0.4a2 44R Alpha: http://elektro255.ovh.org
20-12-2006
V0.3 79R Final mod: http://elektro255.ovh.org
27-11-2006
v0.3 for 49R Final mod http://elektro255.ovh.org/
26-11-2006
V0.3 46R Final mod: http://elektro255.ovh.org
НА Е1 Rokr с бутом 0А02 (оригинальный) НЕ ПОСТАВИТЕ БЕЗ Т.П.!
V0.4 alpha 4
Changes:
- Fixed problem with display timeout (fullscreen clock) when SMS/CALL received
Features:
- 4xR and 7xR MIX (use with 4xR flex)
- unlimited Video recording
- keypad automatic lock
- low battery alarm can be turned off or depend on ring style.
- Scheduled Ring Styles (ring style and funlight style can change automatically on given time and week day)
- flashlight shortcut (##)
- extra menu (shortcut *1 [shortcut is only for testing later will be changed])
- automatic menu enter, without sim card (emergency calls working too)
- new Java methods
- settings are stored on files
- no simlock checking
- Volume-bar sound can be turned off
- multiple menus (every skin can have one mma_ucp)
- Ported patches:
o SMS report significantly turned ON
o more folders in OBEX via BT
o removed unused folders from TransFlash
o Java have access to system files
o increased iTap user dictionary size
o no delete incall on SIM replace
o Bluetooth time changed to 3 minutes
o reordered camera store menu (store only is first)
o SMS alert is using default ringtone
OLD versions(V0.1-0.3):
Firmware changes:
- firmware based on 46R from StarterXP MP
- FULL SW access from Java
- LUMA&CHROMA tables moved to memory - now you can change JPEG compresion from Java
- StarterXP flex
- added dualboot
Flasher changes:
- if you have PDS_4013 flasher will no recreate this
Personalization tool changes:
- first version for 0.3_46R SW mod
- changing splash screen
- changing font (you can use *.fnt or *.smg CG4 files)
- you can turn on, turn off menu access without sim cart
- changing my shortcuts
Новая версия V0.4 alpha 4
Изменения:
- Устранена проблема с таймаутом дисплея(полноэкранные часы) при приеме смс/звонка
Новое:
- Прошивка создана как микс 4xR и 7xR (флекс 4xR ) В 44R она переименована для совместимости! Она близко не лежит к 44R на самом деле!
- Безлимитная запись видео (64мб макс как в 6х7х)
- Автоблок клавиатуры
- Звук разряженой батареи можно выключать или задать стилем оповещения(?).
- Расписание стилей оповещения (стиль оповещения и фанлайтмогут менятся автоматически по времени и дням недели)
- Фонарик по (##)
- Дополнительное меню (метка *1 [только для теста, после может изменится])
- Автоматический вход в меню без сим-карты (аварийные звонки работают)
- Новые методы в Яве (не от 79R, а новые)
- Настройки хранятся в файлах
- Не проверяется лоченость ПДС на симку (работает с лоченым пдс)
- Звук изменения громкости можно отключить
- Мультименю (каждый скин может иметь собственный мма_уцп)
- Портированы патчи:
o Оповещение о доставке SMS всегда вкл.
o больше папок доступно по OBEX из блютуза
o удалены неиспользуемые папки с флешки
o Полный доступ к системным файлам из явы
o увеличен размер пользовательского словаря iTap
o не удалыются последние вызовы при смене сим
o Время обнаружения блютуза - 3 минуты
o Меню сохранения видеозаписи (просто сохранить - первым пунктом)
o при приходе SMS играет "мелодия на смс", а не установленная на этого пользователя
Для версий 0.1-0.3
Изменения в прошивке:
- Создана на базе монстра StarterXP 46R
- Полный доступ к прошивке (симы, озу) из явы
- Таблицы сжатия фотографий перенесены в озу - теперь из явы можно управлять качеством фотографий (сжатием)
- флекс StarterXP
- добавлен дуалбут
Изменения флешера:
-Если ПДС версии 4013 (373 платформа), ПДС не пересоздается.
Изменения персонализации (Personalization tool):
- впервые для мода использована 46 прошивка
- замена заставки (на включение?)
- замена шрифта (лангпак, CG4)
- можно вкл. и выкл. доступ к меню без сим-карты
- изменен ярлык (копирайт?)
Для работы Personalization tool требуется положить в папку программы несжатый бинарный бэкап (32 мегабайта) под именем SW.bin
Прекращаем флудить, типа а когда выйдет новая версия, и.т.д.и.т.п, или придётся наказывать!
тему почистил, архив по 1 декабря тут:
Прикрепленный файл MotoFan_ru_electro.zip   ( 66.56 килобайт ) Кол-во скачиваний: 3902
Сообщение отредактировал elektro255 - 9.4.2007, 12:21
novis
сообщение 14.4.2007, 14:47
Из: г.Ижевск
Пользователь №: 76 691
Прошивка: 79r
Уважаемый elektro.
Реально ли сделать на е398 функцию как на simens'ах "виртуальный" multisim. Что бы иметь в памяти несколько sim'ок разных сотовых операторов и переключаться между ними?
спасибо.
om2804
сообщение 14.4.2007, 15:45
МотоКодер
Из: Архангельск
Пользователь №: 95 055
Прошивка: DaR
Цитата(sader @ 14.4.2007, 0:16) *
Скажите пожалуйста, сейчас короткое нажатие кнопки гарнитуры переключает на следущую песню, а длинное - перемотка. Можно ли сделать так, чтобы при коротком нажатии ставилась пауза, при длинном - следущуая песня?
у некоторых iTuns'ов при коротком нажатии джостик вверх ставится пауза , при длинном - следущуая песня. Так что назначай кнопке гарнитуры джостик вверх
NeoShaMAN
сообщение 14.4.2007, 18:44
Из: Великий Новгород
Пользователь №: 118 943
Модель телефона: Sony Xperia Z2 D6503
Прошивка: 6.0.1
такой вопрос, а тут с ММС всё в порядке?
Dimarik090
сообщение 15.4.2007, 7:35
Пользователь №: 121 546
Модель телефона: E398+microsd 512
Прошивка: 49r
Кто тестил,фишка с 2мя мма_уцп точно работает,если да,то как???!!
San3k
сообщение 15.4.2007, 8:47
Пользователь №: 108 480
Модель телефона: Nokia 5310; E398
млин... все работает, открыть мануал от электро чтоли трудно?..
берешь mma_ucp, смотришь какой по счету скин (Личные настройки->Облочка раб. стола), если скин там первый - переименовываешь mma_ucp в mma_ucp0 и заливаешь его в a:\mobile\system\
если скин второй, то нужно mma_ucp1
елси скин третий - mma_ucp2 и так далее.
Яуген
сообщение 15.4.2007, 11:08
Пользователь №: 101 871
AsteriXQ, скачивай прошу, разархивируй, открой фб3, там в разделе чтения данный бэкап сделай, а потом в разделе запись данных выбирай эту прошу и нажимай запись. А вообще надо юзать поиск, мануалы на форуме есть
AsteriXQ
сообщение 15.4.2007, 11:52
Из: Уфа
Пользователь №: 97 671
Модель телефона: Moto E398
Прошивка: Mpx 398 De luxe
Цитата(dARkN3sS @ 15.4.2007, 17:08) *
Качаешь вот этот архив, разархивируешь, переключаешь тело, в архиве лежит программа называется UPDATER запускаешь её, сначала будет написанно Disconnect, подожди немного, прога напишет синим шрифтом Что-то про переключение в P2K-mode, зател тело переведётся в бут-режим и в прогу зелёнм шрифтом будет написанно Connect потом просто нажимаешь Update и спокойно ждёшь пока тело прошивается.
Можно чуть прощё, переводишь тело в бут, вребаешь USB, потом включаешь UPDATER, прога должна сразу написать Connect, жмякаешь кнопку update в проге и ждёшь...
Главное чтобы программа и прошивка лежали в одной папке!
Прошивка называется update.BIN
спс. тока у меня не пашет прошивка, прошивается, но после перезагрузки меняется тока начальная заставка и всё.
Яуген - прошивать то я умею.
Сообщение отредактировал AsteriXQ - 15.4.2007, 11:52
Acceptor
сообщение 15.4.2007, 12:00
Пользователь №: 131 036
Прошивка: Electro255 mod 0.3
AsteriXQ, так и надо это не полная проша, а только CG1... Все скины, настройки и т.д. остаётся как у тя было раньше.. А всё что она изменяет написано в 1 посте smile.gif
AsteriXQ
сообщение 15.4.2007, 12:15
Из: Уфа
спс.
romak
сообщение 15.4.2007, 12:21
Пользователь №: 68 003
Модель телефона: motorolaE398
Прошивка: R373
прошился electro mod 0.4а.4 далее пропатчил, но у меня при любои коннекте с нетом тело уходит в ребут!!!!че делать?подскажите??? sad.gif sad.gif sad.gif
AsteriXQ
сообщение 15.4.2007, 13:19
Из: Уфа
прошился, ваще не каких имоций, как будто не чо и небыло...
AleksX
сообщение 15.4.2007, 13:52
Из: Пермь
Пользователь №: 68 183
Модель телефона: L7e,Nokia 5700
Прошивка: Mpx398 De Luxe
У меня вообще на моде 4а4 не работает клава..Кроме кнопки вкл. 0 и #.. sad.gif Хотя прошился симбой 1.5 на ней все работает..
San3k
сообщение 15.4.2007, 15:36
А ты чего хотел? Это мод - он добавляет новые возможности, а не какие-нибудь графические элементы...
sadface
сообщение 15.4.2007, 18:09
Пользователь №: 110 110
Модель телефона: Z6 + Kingston 2GB
Прошивка: 44R + PE
romak,
Ждать пока этот баг уберут. У меня точно так же, я именно по этому на 0.3 откатился
Acceptor
сообщение 16.4.2007, 7:32
Прошился, вроде норм...
Замеченные баги:
1)На 15 минуте тел ушёл в ребут, но сейчас норм (22 часа непрерывно работает...)
2)При подключении Jimm ушёл в ребут (при повторной попытке подключается, но отказывается принимать и отсылать сообщения)
В целом: Electro255 - молодец, с такими шагами наша 398 скоро станет смартом clap.gif
AsteriXQ
сообщение 16.4.2007, 9:00
Из: Уфа
Цитата(Acceptor @ 16.4.2007, 13:32) *
оффтоп: чё ща мод ?
goods
сообщение 16.4.2007, 9:55
Пользователь №: 91 380
Модель телефона: E398 + 1Gb
Прошивка: DaR
Я еле скачал( качал по ссылке 09-04-2007)думал она будет 49r а после того как поставил она оказась 79r…. На ней не работал эквалайзер…… sad.gif sad.gif Подскажите плз где скачать 49r?
Сообщение отредактировал goods - 16.4.2007, 10:11
=BazOOka=
сообщение 16.4.2007, 11:01
Пользователь №: 107 478
Модель телефона: rokr e2
Прошивка: 4AP
QUOTE(goods @ Today, 13:55)
om2804
сообщение 16.4.2007, 13:21
МотоКодер
Из: Архангельск
Прошивка: DaR
elektro255, narrate in detail about java method jmp. give me class with jmp. I Beg pardon for my english
elektro255, расскажи подробнее о ява методе jmp. Дай класс с jmp. C версией V0.4a4 jmp в классе нет.
Acceptor
сообщение 16.4.2007, 17:32
оффтоп: чё ща мод ?
Да эт я так про будущее ))
ЗЫ С инетом ваще никак не разобраться???
deadmoto
сообщение 16.4.2007, 18:25
Главный Новостник
Из: Омск
Пользователь №: 49 284
Модель телефона: Motorola
Прошивка: Motorola Original
Acceptor, похоже нет))) Все глюки на самом деле из за памяти... Её не просто мало - её свободной просто нет!
Вот электро и мучается... Просто его модификации используют уже занятые адреса памяти вот оно накладываетсяи не работает ни то ни другое...
P.S. Если бы с памятью было всё так просто - был бы у нас уже доступ к БТ из явы) Классы в прошивку вставить то можно, но памяти не хватает оперативной... Её всего то 8 мб...
P.P.S А чтобы узнать куда в память что кинуть электро приходится снимать дамп через яву, поэтому в каждой прошивке он и добавляет классы чтения памяти...
P.P.P.S. А память из явы снимается 1мб=7 часов....
Uran_90
сообщение 17.4.2007, 12:31
Из: Волгоград
Пользователь №: 95 416
Красиво написано, а как это всё сделать?
1. Проша отображается как 46r.
2.видео записывается 1,5 мин.
3.автоблока в основных настройках нет.
4. как задать звук батареи стилем оповещения?
5. как сделать расписание стилей оповещения.
Заранее спасибо за ответы. Просьба сильно не ругать.
San3k
сообщение 17.4.2007, 13:22
1 - это для совместимости, как было сказано неоднократно
2 - ты точно на флешку видео пишешь? (если точно, то помоему, не помню точно, электро писал, что проблема может быть из-за флекса...)
3 - он в доп. меню от электро (вместо меню Технология)
4 - в том же доп. меню
5 - на сайте электро есть personalization tool - скачай и настраивай себе расписание
Цитата(JUST CJ @ 17.4.2007, 17:18) *
У меня проблема с установкой королетов на 0.4а мод,делаю все по инструкциям,но королеты не хотят запускаться...прошу помощи!
Я устанавлил просто через MotoMidMan без всяких инструкций, и все норм. =)
Сообщение отредактировал San3k - 17.4.2007, 13:26
r.o.m.a.N
сообщение 19.4.2007, 12:17
Motoroma
Пользователь №: 95 283
Прошивка: 49R 4.4.4
Млин, еще один глюк, который был в 2, 3 и 4 моде (по крайней мере у меня) .Если свернуть яву при его начальной загрузке (например при появлении надписи "Gameloft") красной кнопой,и не выбирать пункт "Свернуть" а снова нажать красную кнопку, то в 30-40% случаях зайти снова в игры НИКАК не получится (помогает только перезагрузка) и все королеты тупят по полной или не запускаются
Elektro_255If roll up java under his(its) bootstrap (for instance at appearance inscription "Gameloft") red button,and not to choose point "to Roll up" but once again press redden button then in 30-40% event to call at back into plays AT ALL is not got (helps only rebooting)
Вот, если кому нужно, русификатор меню от электро(незнаю, мож уже выкладывал кто) (ставить только FB 3 версии!)
Прикрепленный файл ________________________.zip   ( 2.7 килобайт ) Кол-во скачиваний: 138
Добавлено позже (19.4.2007, 16:38):
MELOMAN,
Вот и вот (1 и 2 части CG1)
Добавлено позже (19.4.2007, 17:05):
Где-то читал, что для видео на 64 Mb нужен то ли сим 4A, то ли 4E. Если у кого видео на 64 метра, дайте плз эти симы shuffle.gif
Сообщение отредактировал r.o.m.a.N - 19.4.2007, 12:33
Timik
сообщение 19.4.2007, 16:26
Пользователь №: 100 902
Прошивка: даже не знаю теперь
MELOMAN,
Спасибо за патч, почему-то у меня после него умер тел. пишет в буте MEM_MAP Blank и т.д... придется опять все поновой делать.. mad.gif PS - ставил 3 флеш..ом
Bagir
сообщение 20.5.2007, 20:39
Из: Углич
Пользователь №: 101 396
Прошивка: R373_G_0E.30.49R
Братцы, Выложите в доступное место рефлеш v0.3 for 49R Final mod желательно чтобы флешбекапом прошить.
Я всю тему проглядел, но не нашел не одной рабочей ссылки. С рапиды качать не хочет. Другие ссылки тоже дохлые. На сайте http://elektro255.ovh.org/ тоже взять не получается, там ссылка на рапиду, а с нее качать не хочет.
r.o.m.a.N
сообщение 26.5.2007, 3:47
Motoroma
Прошивка: 49R 4.4.4
Вот ссылки на Elektro255_mod_v0.4 для некоторых неродивых юзеров, которым лень по страничке глазами пройтись
slil.ru
rapidshare.ru
megaupload.com
turboupload.com
sendspace.com
getfile.biz
mytempdir.com
Добавлено позже (26.5.2007, 8:54):
Bagir,
Поставь третий мод, там багов с инетом и синезубом нет, а фонарь есть. smile.gif
Сообщение отредактировал r.o.m.a.N - 26.5.2007, 4:26
konstantin90
сообщение 8.6.2007, 5:05
Пользователь №: 115 201
Прошивка: R373_G_0E.30.4 8R
дайте пожалуйста ссылку на v0.3 for 49R Final mod! А то на электро не по русски всё фиг разберёшься!!!!!!!!!!
gunghost
сообщение 8.6.2007, 6:56
Пользователь №: 71 735
Прошивка: Всегда самая лудшая
Лови ссылку. Рапида .
Сообщение отредактировал gunghost - 8.6.2007, 6:57
N i K o N
сообщение 8.6.2007, 17:47
Пользователь №: 44 060
Прошивка: 30.49
Не знаю как у всех но у меня никаких глюков на 4 моде не возникало. Единственное только то что не входит в меню веб-сессии.
r.o.m.a.N
сообщение 8.6.2007, 21:31
Motoroma
Прошивка: 49R 4.4.4
Seem-ы друг мой, seem-ы
В 32 симе через p2kAE бит 377 вкл.
Или
Сообщение отредактировал r.o.m.a.N - 9.6.2007, 3:54
r.o.m.a.N
сообщение 15.6.2007, 13:36
Motoroma
Прошивка: 49R 4.4.4
Вот только сеодня в настройках включил автоблок, а он не пашет... думал мож из-за патча какого. Прошил CG1 без патчей - не пашет sad.gif
Dukatt
сообщение 17.6.2007, 9:53
Пользователь №: 95 937
Модель телефона: Rokr E1
Прошивка: Dream a reality v1.1
да не спешите вы перепрыгивать пока еще рано там дорабатывать и дорабатывать
граф де ла Фер
сообщение 17.6.2007, 13:29
Из: г. Краснодар
Пользователь №: 100 076
Модель телефона: e398 => RAZR DROID XT912
Dukatt,
а что дорабатывать? это мы, пользователи-тестеры и должны говорить, выявлять недостатки, помогать. Ведь чем больше людей, тем больше недостатков за более короткое время можно обнаружить, таким образом дав понять авторам, на что нужно обратить внимание. wink.gif
MELOMAN
сообщение 17.6.2007, 22:22
Пользователь №: 60 957
Модель телефона: E398+1GB micro SD
Прошивка: elektro v0.4a4
граф де ла Фер,
Ты прав чем больше нас тем болле легче выявить и устранить проблему
deadmoto
сообщение 18.6.2007, 0:52
Главный Новостник
Из: Омск
граф де ла Фер, \\про электромод 0.4 альфа\\ ты думаешь автор сам не замечает этих багов?)))
Dukatt
сообщение 18.6.2007, 19:12
о том что дорабатывать уже 52 страницы написано просто какой смысл иметь глючную прошу если можно подождать немного может Электро пока занят (вроде Экзамены)
r.o.m.a.N
сообщение 19.6.2007, 12:46
Motoroma
Прошивка: 49R 4.4.4
Несомненно плюсов больше чем минусов!
DjJOY
сообщение 22.6.2007, 15:28
Пользователь №: 96 482
Народ,спасите!Поставил монстра!Очень клёвый!Даже некоторые баги не испортили впечатление!Но вот такой ужас: комп перестал видеть тело в любых режимах.Потключаю,а мне пишет НЕИЗВЕСТНОЕ УСТРОЙСТВО.Если кто знает причину,пишите на waper2005@mail.ru Просьба к модераторам не удалять плиз!
AsteriXQ
сообщение 22.6.2007, 15:35
Из: Уфа
ваще не в тему, а так: похоже проводок тупит
Текстовая версия Сейчас: 22.7.2025, 12:12
