23 страниц V « < 18 19 20 21 22 > »
Elektro255 V0.4 alpha 4 mod (4xR), 44R,46R,49R,79R
elektro255
сообщение 23.9.2006, 12:06 Закрепленное сообщение!
Из: Poland, Siedlce
Пользователь №: 53 130
09-04-2007
V0.4a4 Alpha: http://elektro255.ovh.org
08-04-2007
V0.4a3 Alpha: http://elektro255.ovh.org
07-04-2007
V0.4a2 44R Alpha: http://elektro255.ovh.org
20-12-2006
V0.3 79R Final mod: http://elektro255.ovh.org
27-11-2006
v0.3 for 49R Final mod http://elektro255.ovh.org/
26-11-2006
V0.3 46R Final mod: http://elektro255.ovh.org
НА Е1 Rokr с бутом 0А02 (оригинальный) НЕ ПОСТАВИТЕ БЕЗ Т.П.!
V0.4 alpha 4
Changes:
- Fixed problem with display timeout (fullscreen clock) when SMS/CALL received
Features:
- 4xR and 7xR MIX (use with 4xR flex)
- unlimited Video recording
- keypad automatic lock
- low battery alarm can be turned off or depend on ring style.
- Scheduled Ring Styles (ring style and funlight style can change automatically on given time and week day)
- flashlight shortcut (##)
- extra menu (shortcut *1 [shortcut is only for testing later will be changed])
- automatic menu enter, without sim card (emergency calls working too)
- new Java methods
- settings are stored on files
- no simlock checking
- Volume-bar sound can be turned off
- multiple menus (every skin can have one mma_ucp)
- Ported patches:
o SMS report significantly turned ON
o more folders in OBEX via BT
o removed unused folders from TransFlash
o Java have access to system files
o increased iTap user dictionary size
o no delete incall on SIM replace
o Bluetooth time changed to 3 minutes
o reordered camera store menu (store only is first)
o SMS alert is using default ringtone
OLD versions(V0.1-0.3):
Firmware changes:
- firmware based on 46R from StarterXP MP
- FULL SW access from Java
- LUMA&CHROMA tables moved to memory - now you can change JPEG compresion from Java
- StarterXP flex
- added dualboot
Flasher changes:
- if you have PDS_4013 flasher will no recreate this
Personalization tool changes:
- first version for 0.3_46R SW mod
- changing splash screen
- changing font (you can use *.fnt or *.smg CG4 files)
- you can turn on, turn off menu access without sim cart
- changing my shortcuts
Новая версия V0.4 alpha 4
Изменения:
- Устранена проблема с таймаутом дисплея(полноэкранные часы) при приеме смс/звонка
Новое:
- Прошивка создана как микс 4xR и 7xR (флекс 4xR ) В 44R она переименована для совместимости! Она близко не лежит к 44R на самом деле!
- Безлимитная запись видео (64мб макс как в 6х7х)
- Автоблок клавиатуры
- Звук разряженой батареи можно выключать или задать стилем оповещения(?).
- Расписание стилей оповещения (стиль оповещения и фанлайтмогут менятся автоматически по времени и дням недели)
- Фонарик по (##)
- Дополнительное меню (метка *1 [только для теста, после может изменится])
- Автоматический вход в меню без сим-карты (аварийные звонки работают)
- Новые методы в Яве (не от 79R, а новые)
- Настройки хранятся в файлах
- Не проверяется лоченость ПДС на симку (работает с лоченым пдс)
- Звук изменения громкости можно отключить
- Мультименю (каждый скин может иметь собственный мма_уцп)
- Портированы патчи:
o Оповещение о доставке SMS всегда вкл.
o больше папок доступно по OBEX из блютуза
o удалены неиспользуемые папки с флешки
o Полный доступ к системным файлам из явы
o увеличен размер пользовательского словаря iTap
o не удалыются последние вызовы при смене сим
o Время обнаружения блютуза - 3 минуты
o Меню сохранения видеозаписи (просто сохранить - первым пунктом)
o при приходе SMS играет "мелодия на смс", а не установленная на этого пользователя
Для версий 0.1-0.3
Изменения в прошивке:
- Создана на базе монстра StarterXP 46R
- Полный доступ к прошивке (симы, озу) из явы
- Таблицы сжатия фотографий перенесены в озу - теперь из явы можно управлять качеством фотографий (сжатием)
- флекс StarterXP
- добавлен дуалбут
Изменения флешера:
-Если ПДС версии 4013 (373 платформа), ПДС не пересоздается.
Изменения персонализации (Personalization tool):
- впервые для мода использована 46 прошивка
- замена заставки (на включение?)
- замена шрифта (лангпак, CG4)
- можно вкл. и выкл. доступ к меню без сим-карты
- изменен ярлык (копирайт?)
Для работы Personalization tool требуется положить в папку программы несжатый бинарный бэкап (32 мегабайта) под именем SW.bin
Прекращаем флудить, типа а когда выйдет новая версия, и.т.д.и.т.п, или придётся наказывать!
тему почистил, архив по 1 декабря тут:
Прикрепленный файл MotoFan_ru_electro.zip   ( 66.56 килобайт ) Кол-во скачиваний: 3902
Сообщение отредактировал elektro255 - 9.4.2007, 12:21
Bagir
сообщение 20.5.2007, 20:39
Из: Углич
Пользователь №: 101 396
Прошивка: R373_G_0E.30.49R
Братцы, Выложите в доступное место рефлеш v0.3 for 49R Final mod желательно чтобы флешбекапом прошить.
Я всю тему проглядел, но не нашел не одной рабочей ссылки. С рапиды качать не хочет. Другие ссылки тоже дохлые. На сайте http://elektro255.ovh.org/ тоже взять не получается, там ссылка на рапиду, а с нее качать не хочет.
r.o.m.a.N
сообщение 26.5.2007, 3:47
Motoroma
Пользователь №: 95 283
Прошивка: 49R 4.4.4
Вот ссылки на Elektro255_mod_v0.4 для некоторых неродивых юзеров, которым лень по страничке глазами пройтись
slil.ru
rapidshare.ru
megaupload.com
turboupload.com
sendspace.com
getfile.biz
mytempdir.com
Добавлено позже (26.5.2007, 8:54):
Bagir,
Поставь третий мод, там багов с инетом и синезубом нет, а фонарь есть. smile.gif
Сообщение отредактировал r.o.m.a.N - 26.5.2007, 4:26
konstantin90
сообщение 8.6.2007, 5:05
Пользователь №: 115 201
Прошивка: R373_G_0E.30.4 8R
дайте пожалуйста ссылку на v0.3 for 49R Final mod! А то на электро не по русски всё фиг разберёшься!!!!!!!!!!
gunghost
сообщение 8.6.2007, 6:56
Пользователь №: 71 735
Прошивка: Всегда самая лудшая
Лови ссылку. Рапида .
Сообщение отредактировал gunghost - 8.6.2007, 6:57
N i K o N
сообщение 8.6.2007, 17:47
Пользователь №: 44 060
Прошивка: 30.49
Не знаю как у всех но у меня никаких глюков на 4 моде не возникало. Единственное только то что не входит в меню веб-сессии.
r.o.m.a.N
сообщение 8.6.2007, 21:31
Motoroma
Прошивка: 49R 4.4.4
Seem-ы друг мой, seem-ы
В 32 симе через p2kAE бит 377 вкл.
Или
Сообщение отредактировал r.o.m.a.N - 9.6.2007, 3:54
r.o.m.a.N
сообщение 15.6.2007, 13:36
Motoroma
Прошивка: 49R 4.4.4
Вот только сеодня в настройках включил автоблок, а он не пашет... думал мож из-за патча какого. Прошил CG1 без патчей - не пашет sad.gif
Dukatt
сообщение 17.6.2007, 9:53
Пользователь №: 95 937
Модель телефона: Rokr E1
Прошивка: Dream a reality v1.1
да не спешите вы перепрыгивать пока еще рано там дорабатывать и дорабатывать
граф де ла Фер
сообщение 17.6.2007, 13:29
Из: г. Краснодар
Пользователь №: 100 076
Модель телефона: e398 => RAZR DROID XT912
Dukatt,
а что дорабатывать? это мы, пользователи-тестеры и должны говорить, выявлять недостатки, помогать. Ведь чем больше людей, тем больше недостатков за более короткое время можно обнаружить, таким образом дав понять авторам, на что нужно обратить внимание. wink.gif
MELOMAN
сообщение 17.6.2007, 22:22
Пользователь №: 60 957
Модель телефона: E398+1GB micro SD
Прошивка: elektro v0.4a4
граф де ла Фер,
Ты прав чем больше нас тем болле легче выявить и устранить проблему
deadmoto
сообщение 18.6.2007, 0:52
Главный Новостник
Из: Омск
Пользователь №: 49 284
Модель телефона: Motorola
Прошивка: Motorola Original
граф де ла Фер, \\про электромод 0.4 альфа\\ ты думаешь автор сам не замечает этих багов?)))
Dukatt
сообщение 18.6.2007, 19:12
о том что дорабатывать уже 52 страницы написано просто какой смысл иметь глючную прошу если можно подождать немного может Электро пока занят (вроде Экзамены)
r.o.m.a.N
сообщение 19.6.2007, 12:46
Motoroma
Прошивка: 49R 4.4.4
Несомненно плюсов больше чем минусов!
DjJOY
сообщение 22.6.2007, 15:28
Пользователь №: 96 482
Народ,спасите!Поставил монстра!Очень клёвый!Даже некоторые баги не испортили впечатление!Но вот такой ужас: комп перестал видеть тело в любых режимах.Потключаю,а мне пишет НЕИЗВЕСТНОЕ УСТРОЙСТВО.Если кто знает причину,пишите на waper2005@mail.ru Просьба к модераторам не удалять плиз!
AsteriXQ
сообщение 22.6.2007, 15:35
Из: Уфа
Пользователь №: 97 671
Модель телефона: Moto E398
Прошивка: Mpx 398 De luxe
ваще не в тему, а так: похоже проводок тупит
DjJOY
сообщение 22.6.2007, 15:44
Не,я два провода перепробовал,к 3 компам подключал,эфект один и тот же.
AsteriXQ
сообщение 22.6.2007, 16:00
Из: Уфа
тогда контакты запылились, или контакта нет
вскрой тел и посмоти
DjJOY
сообщение 22.6.2007, 16:29
Чисто визуально всё чисто и припаяно.А как по-другому проверить?
=BazOOka=
сообщение 22.6.2007, 20:09
Пользователь №: 107 478
Модель телефона: rokr e2
Прошивка: 4AP
QUOTE(DjJOY @ Yesterday, 20:29)
ПРойдись по ним тампоном, смоченным спиртом. Это несложно. Если не поможет, то пропаяй.
MELOMAN
сообщение 22.6.2007, 20:21
DjJOY,
протри все спиртом только не используй железные обекты
Tehnoos
сообщение 22.6.2007, 20:28
Из: ЯНАО г. Ноябрьск
Пользователь №: 121 093
Модель телефона: E398, Razr V3, N73
Прошивка: 49R
Я до сих пор не понял как 4 альфу поставить. Через 2,62 создаю прошивку, он мне пишет Размер файла несоответствует выбранной вами модели телефона. Как это, че это не понятно. sad.gif Объясните пожалуйста как 4 альфу поставить. Вроде все 52 стр. прочитал, ответа не нашел.
Сообщение отредактировал Tehnoos - 22.6.2007, 20:36
Cudesnik
сообщение 22.6.2007, 21:46
Пользователь №: 103 977
Tehnoos,
Шей RSD Lite 3.7, либо F&B последней версии - 3,х
Tehnoos
сообщение 23.6.2007, 5:40
Прошивка: 49R
Чем шить я знаю. Но там ведь bin файл, а не shx. В этом вся проблема. Не знаю как shx сделать. Через ФБ 2,62 попытался, но он пишет Размер файла несоответствует выбранной вами модели телефона. Так как все таки прошить?
AsteriXQ
сообщение 23.6.2007, 8:09
Из: Уфа
ваще то с прошикой шла прога, её запускаешь и прошиваешь, но сначало ждешь пока напишет Connect
AsteriXQ
сообщение 26.6.2007, 6:39
Из: Уфа
народ, а чё в этой проше кол-во смс-ок мала ? у меня 50 и он уже грит типо "нету места"
или как нить это дело можно исправить ?
N i K o N
сообщение 26.6.2007, 16:21
Прошивка: 30.49
Вопрос почему когда громкость стоит на 7 то при входящем звонке(со вставленной в телефон гарнитурой) играют громче чем без гарнитуры(проверял когда при вызове выдернул гарнитуру чтобы ответить) что это глюк или что?
MELOMAN
сообщение 28.6.2007, 15:31
AsteriXQ,
это исправляется симами смотри в соответс. тему
Киська
сообщение 28.6.2007, 15:49
Женькина :)
Пользователь №: 134 568
Модель телефона: Iphone 4
AsteriXQ, https://motofan.ru/board/index.php?showtopic=49059
RomkO
сообщение 2.7.2007, 20:14
Пользователь №: 138 095
Прошивка: elektro_mod_v0.4a4
У меня вопрос: я поставил "elektro mod updater v0.4alpha4" на "MotoWalkman 49r EM", но когда
мне звонят то мелодия не повторяется, тоесть мелодия проигрывается только один раз,
тоже дело во время вибро режима, он вибрирует только раз. Пробовал ставить на New_Standart_by_Aleks75_Release
но все тоже самое. Плиз подскажите как это исправить.
r.o.m.a.N
сообщение 2.7.2007, 23:20
Motoroma
Прошивка: 49R 4.4.4
RomkO,
Глюк данного мода (вернее альфа мода, надеемся в финальной версии этого не будет)
Uran_90
сообщение 9.7.2007, 5:29
Из: Волгоград
Пользователь №: 95 416
(r.o.m.a.N)RomkO,
А она будет??? Альфа 4 уже пол года здесь весит. Вообще походу щас стало модно начинать делать хорошую прошу чтобы впоследствии забросить. Сначала MotoSymbian, теперь вот electro. Грустно всё это sad.gif .
Сообщение отредактировал Uran_90 - 9.7.2007, 5:29
Яуген
сообщение 9.7.2007, 10:25
Пользователь №: 101 871
Uran_90, это не проша, а только рефлеш, в который электро добавляет разняе фичи, и никто ее еще не забросил smile.gif
Uran_90
сообщение 9.7.2007, 15:54
Из: Волгоград
Сообщение отредактировал elektro255 - 9.4.2007, 16:21
Я в курсе что это рефлешь, просто оговорился. Глянь на дату его последнего появления здесь. Это по твоему как называется.
З.Ы. если я не прав - переубедите
З.З.Ы. Сорри за оффтоп
VkD
сообщение 9.7.2007, 16:22
Пользователь №: 64 617
Прошивка: MS 1.5b
Uran_90,
Go to http://elektro255.ovh.org/
My HDD burned sad.gif on backup I have only very old sources, so my mods are suspended to time when HDD will be repiaired (if not I will have to stop making new firmwares)
-mak-
сообщение 15.7.2007, 9:21
Из: Город-герой Волгоград
Пользователь №: 56 604
Модель телефона: qtek s200
09-07-2007 - mods suspended
My HDD burned on backup I have only very old sources, so my mods are suspended to time when HDD will be repiaired (if not I will have to stop making new firmwares)
эх, жаль, а у меня вирусом все исходники новых скинов поело, эх придется тоже забросить моддинг...
По теме: никто не сравнивал четвертую альфу на 49 и 46?
zolookas
сообщение 17.7.2007, 10:31
Пользователь №: 43 073
QUOTE(http://elektro255.ovh.org)
HDD Repaired smile.gif New mod is comming (elf loader and moto SDK)
Elektro255 продолжает моддинг.
vertalet
сообщение 22.7.2007, 18:44
Из: России, Костромы
Пользователь №: 106 588
Модель телефона: 398, Nokia 6120
Прошивка: MotoSymba 79, 3.83
Парни объясните что это такое
. И кто может связаться с elektro255 чтоб узнать о выходе новой версии.
Напиши ему в личку или в аську, данные есть!
Сообщение отредактировал BackgaMan - 23.7.2007, 10:07
HUNTER_ok
сообщение 31.7.2007, 0:46
Из: Заозерный webstream :D
Пользователь №: 106 065
Модель телефона: SE W810i
vertalet, Если судить по названию то moto SDK это компилятор в исходный язык для телефона а эльфы это и есть эти программы, которым для загрузки нужен elf loader
LigaLayz777
сообщение 3.8.2007, 11:58
Из: Рязань
Пользователь №: 141 919
Модель телефона: E398&E8+ZN5+Milestone
Прошивка: <BLACK ANGEL V3.0>
MONSTOID
Респект автору но почему на четвертом моде в интернете телефон перезагружается?
AsteriXQ
сообщение 3.8.2007, 12:28
Из: Уфа
Это глюк не исправим пока что.
Вобчем перешёл я обратно на 49Р, Mpx398 самый зашибатый, я его под себя настроил терь ваще отпад!!!
Текстовая версия Сейчас: 18.7.2025, 10:45
