23 страниц V « < 19 20 21 22 > »
Elektro255 V0.4 alpha 4 mod (4xR), 44R,46R,49R,79R
elektro255
сообщение 23.9.2006, 12:06 Закрепленное сообщение!
Из: Poland, Siedlce
Пользователь №: 53 130
09-04-2007
V0.4a4 Alpha: http://elektro255.ovh.org
08-04-2007
V0.4a3 Alpha: http://elektro255.ovh.org
07-04-2007
V0.4a2 44R Alpha: http://elektro255.ovh.org
20-12-2006
V0.3 79R Final mod: http://elektro255.ovh.org
27-11-2006
v0.3 for 49R Final mod http://elektro255.ovh.org/
26-11-2006
V0.3 46R Final mod: http://elektro255.ovh.org
НА Е1 Rokr с бутом 0А02 (оригинальный) НЕ ПОСТАВИТЕ БЕЗ Т.П.!
V0.4 alpha 4
Changes:
- Fixed problem with display timeout (fullscreen clock) when SMS/CALL received
Features:
- 4xR and 7xR MIX (use with 4xR flex)
- unlimited Video recording
- keypad automatic lock
- low battery alarm can be turned off or depend on ring style.
- Scheduled Ring Styles (ring style and funlight style can change automatically on given time and week day)
- flashlight shortcut (##)
- extra menu (shortcut *1 [shortcut is only for testing later will be changed])
- automatic menu enter, without sim card (emergency calls working too)
- new Java methods
- settings are stored on files
- no simlock checking
- Volume-bar sound can be turned off
- multiple menus (every skin can have one mma_ucp)
- Ported patches:
o SMS report significantly turned ON
o more folders in OBEX via BT
o removed unused folders from TransFlash
o Java have access to system files
o increased iTap user dictionary size
o no delete incall on SIM replace
o Bluetooth time changed to 3 minutes
o reordered camera store menu (store only is first)
o SMS alert is using default ringtone
OLD versions(V0.1-0.3):
Firmware changes:
- firmware based on 46R from StarterXP MP
- FULL SW access from Java
- LUMA&CHROMA tables moved to memory - now you can change JPEG compresion from Java
- StarterXP flex
- added dualboot
Flasher changes:
- if you have PDS_4013 flasher will no recreate this
Personalization tool changes:
- first version for 0.3_46R SW mod
- changing splash screen
- changing font (you can use *.fnt or *.smg CG4 files)
- you can turn on, turn off menu access without sim cart
- changing my shortcuts
Новая версия V0.4 alpha 4
Изменения:
- Устранена проблема с таймаутом дисплея(полноэкранные часы) при приеме смс/звонка
Новое:
- Прошивка создана как микс 4xR и 7xR (флекс 4xR ) В 44R она переименована для совместимости! Она близко не лежит к 44R на самом деле!
- Безлимитная запись видео (64мб макс как в 6х7х)
- Автоблок клавиатуры
- Звук разряженой батареи можно выключать или задать стилем оповещения(?).
- Расписание стилей оповещения (стиль оповещения и фанлайтмогут менятся автоматически по времени и дням недели)
- Фонарик по (##)
- Дополнительное меню (метка *1 [только для теста, после может изменится])
- Автоматический вход в меню без сим-карты (аварийные звонки работают)
- Новые методы в Яве (не от 79R, а новые)
- Настройки хранятся в файлах
- Не проверяется лоченость ПДС на симку (работает с лоченым пдс)
- Звук изменения громкости можно отключить
- Мультименю (каждый скин может иметь собственный мма_уцп)
- Портированы патчи:
o Оповещение о доставке SMS всегда вкл.
o больше папок доступно по OBEX из блютуза
o удалены неиспользуемые папки с флешки
o Полный доступ к системным файлам из явы
o увеличен размер пользовательского словаря iTap
o не удалыются последние вызовы при смене сим
o Время обнаружения блютуза - 3 минуты
o Меню сохранения видеозаписи (просто сохранить - первым пунктом)
o при приходе SMS играет "мелодия на смс", а не установленная на этого пользователя
Для версий 0.1-0.3
Изменения в прошивке:
- Создана на базе монстра StarterXP 46R
- Полный доступ к прошивке (симы, озу) из явы
- Таблицы сжатия фотографий перенесены в озу - теперь из явы можно управлять качеством фотографий (сжатием)
- флекс StarterXP
- добавлен дуалбут
Изменения флешера:
-Если ПДС версии 4013 (373 платформа), ПДС не пересоздается.
Изменения персонализации (Personalization tool):
- впервые для мода использована 46 прошивка
- замена заставки (на включение?)
- замена шрифта (лангпак, CG4)
- можно вкл. и выкл. доступ к меню без сим-карты
- изменен ярлык (копирайт?)
Для работы Personalization tool требуется положить в папку программы несжатый бинарный бэкап (32 мегабайта) под именем SW.bin
Прекращаем флудить, типа а когда выйдет новая версия, и.т.д.и.т.п, или придётся наказывать!
тему почистил, архив по 1 декабря тут:
Прикрепленный файл MotoFan_ru_electro.zip   ( 66.56 килобайт ) Кол-во скачиваний: 3902
Сообщение отредактировал elektro255 - 9.4.2007, 12:21
DjJOY
сообщение 22.6.2007, 15:44
Пользователь №: 96 482
Не,я два провода перепробовал,к 3 компам подключал,эфект один и тот же.
AsteriXQ
сообщение 22.6.2007, 16:00
Из: Уфа
Пользователь №: 97 671
Модель телефона: Moto E398
Прошивка: Mpx 398 De luxe
тогда контакты запылились, или контакта нет
вскрой тел и посмоти
DjJOY
сообщение 22.6.2007, 16:29
Чисто визуально всё чисто и припаяно.А как по-другому проверить?
=BazOOka=
сообщение 22.6.2007, 20:09
Пользователь №: 107 478
Модель телефона: rokr e2
Прошивка: 4AP
QUOTE(DjJOY @ Yesterday, 20:29)
ПРойдись по ним тампоном, смоченным спиртом. Это несложно. Если не поможет, то пропаяй.
MELOMAN
сообщение 22.6.2007, 20:21
Пользователь №: 60 957
Модель телефона: E398+1GB micro SD
Прошивка: elektro v0.4a4
DjJOY,
протри все спиртом только не используй железные обекты
Tehnoos
сообщение 22.6.2007, 20:28
Из: ЯНАО г. Ноябрьск
Пользователь №: 121 093
Модель телефона: E398, Razr V3, N73
Прошивка: 49R
Я до сих пор не понял как 4 альфу поставить. Через 2,62 создаю прошивку, он мне пишет Размер файла несоответствует выбранной вами модели телефона. Как это, че это не понятно. sad.gif Объясните пожалуйста как 4 альфу поставить. Вроде все 52 стр. прочитал, ответа не нашел.
Сообщение отредактировал Tehnoos - 22.6.2007, 20:36
Cudesnik
сообщение 22.6.2007, 21:46
Пользователь №: 103 977
Прошивка: R373_G_0E.30.49R
Tehnoos,
Шей RSD Lite 3.7, либо F&B последней версии - 3,х
Tehnoos
сообщение 23.6.2007, 5:40
Прошивка: 49R
Чем шить я знаю. Но там ведь bin файл, а не shx. В этом вся проблема. Не знаю как shx сделать. Через ФБ 2,62 попытался, но он пишет Размер файла несоответствует выбранной вами модели телефона. Так как все таки прошить?
AsteriXQ
сообщение 23.6.2007, 8:09
Из: Уфа
ваще то с прошикой шла прога, её запускаешь и прошиваешь, но сначало ждешь пока напишет Connect
AsteriXQ
сообщение 26.6.2007, 6:39
Из: Уфа
народ, а чё в этой проше кол-во смс-ок мала ? у меня 50 и он уже грит типо "нету места"
или как нить это дело можно исправить ?
N i K o N
сообщение 26.6.2007, 16:21
Пользователь №: 44 060
Прошивка: 30.49
Вопрос почему когда громкость стоит на 7 то при входящем звонке(со вставленной в телефон гарнитурой) играют громче чем без гарнитуры(проверял когда при вызове выдернул гарнитуру чтобы ответить) что это глюк или что?
MELOMAN
сообщение 28.6.2007, 15:31
AsteriXQ,
это исправляется симами смотри в соответс. тему
Киська
сообщение 28.6.2007, 15:49
Женькина :)
Пользователь №: 134 568
Модель телефона: Iphone 4
AsteriXQ, https://motofan.ru/board/index.php?showtopic=49059
RomkO
сообщение 2.7.2007, 20:14
Пользователь №: 138 095
Прошивка: elektro_mod_v0.4a4
У меня вопрос: я поставил "elektro mod updater v0.4alpha4" на "MotoWalkman 49r EM", но когда
мне звонят то мелодия не повторяется, тоесть мелодия проигрывается только один раз,
тоже дело во время вибро режима, он вибрирует только раз. Пробовал ставить на New_Standart_by_Aleks75_Release
но все тоже самое. Плиз подскажите как это исправить.
r.o.m.a.N
сообщение 2.7.2007, 23:20
Motoroma
Пользователь №: 95 283
Прошивка: 49R 4.4.4
RomkO,
Глюк данного мода (вернее альфа мода, надеемся в финальной версии этого не будет)
Uran_90
сообщение 9.7.2007, 5:29
Из: Волгоград
Пользователь №: 95 416
(r.o.m.a.N)RomkO,
А она будет??? Альфа 4 уже пол года здесь весит. Вообще походу щас стало модно начинать делать хорошую прошу чтобы впоследствии забросить. Сначала MotoSymbian, теперь вот electro. Грустно всё это sad.gif .
Сообщение отредактировал Uran_90 - 9.7.2007, 5:29
Яуген
сообщение 9.7.2007, 10:25
Пользователь №: 101 871
Uran_90, это не проша, а только рефлеш, в который электро добавляет разняе фичи, и никто ее еще не забросил smile.gif
Uran_90
сообщение 9.7.2007, 15:54
Из: Волгоград
Сообщение отредактировал elektro255 - 9.4.2007, 16:21
Я в курсе что это рефлешь, просто оговорился. Глянь на дату его последнего появления здесь. Это по твоему как называется.
З.Ы. если я не прав - переубедите
З.З.Ы. Сорри за оффтоп
VkD
сообщение 9.7.2007, 16:22
Пользователь №: 64 617
Прошивка: MS 1.5b
Uran_90,
Go to http://elektro255.ovh.org/
My HDD burned sad.gif on backup I have only very old sources, so my mods are suspended to time when HDD will be repiaired (if not I will have to stop making new firmwares)
-mak-
сообщение 15.7.2007, 9:21
Из: Город-герой Волгоград
Пользователь №: 56 604
Модель телефона: qtek s200
09-07-2007 - mods suspended
My HDD burned on backup I have only very old sources, so my mods are suspended to time when HDD will be repiaired (if not I will have to stop making new firmwares)
эх, жаль, а у меня вирусом все исходники новых скинов поело, эх придется тоже забросить моддинг...
По теме: никто не сравнивал четвертую альфу на 49 и 46?
zolookas
сообщение 17.7.2007, 10:31
Пользователь №: 43 073
QUOTE(http://elektro255.ovh.org)
HDD Repaired smile.gif New mod is comming (elf loader and moto SDK)
Elektro255 продолжает моддинг.
vertalet
сообщение 22.7.2007, 18:44
Из: России, Костромы
Пользователь №: 106 588
Модель телефона: 398, Nokia 6120
Прошивка: MotoSymba 79, 3.83
Парни объясните что это такое
. И кто может связаться с elektro255 чтоб узнать о выходе новой версии.
Напиши ему в личку или в аську, данные есть!
Сообщение отредактировал BackgaMan - 23.7.2007, 10:07
HUNTER_ok
сообщение 31.7.2007, 0:46
Из: Заозерный webstream :D
Пользователь №: 106 065
Модель телефона: SE W810i
vertalet, Если судить по названию то moto SDK это компилятор в исходный язык для телефона а эльфы это и есть эти программы, которым для загрузки нужен elf loader
LigaLayz777
сообщение 3.8.2007, 11:58
Из: Рязань
Пользователь №: 141 919
Модель телефона: E398&E8+ZN5+Milestone
Прошивка: <BLACK ANGEL V3.0>
MONSTOID
Респект автору но почему на четвертом моде в интернете телефон перезагружается?
AsteriXQ
сообщение 3.8.2007, 12:28
Из: Уфа
Это глюк не исправим пока что.
Вобчем перешёл я обратно на 49Р, Mpx398 самый зашибатый, я его под себя настроил терь ваще отпад!!!
CrazZZyBuNNy
сообщение 13.8.2007, 10:11
Пользователь №: 130 578
Модель телефона: у398
HDD Repaired New mod is comming (elf loader and moto SDK) - последнее что написано на сайте
VkD
сообщение 14.8.2007, 4:22
Прошивка: MS 1.5b
Подскажите, в моде 0.4a сохраняются файлы, присланные через ММС??? smile.gif
Crazy Fast
сообщение 14.8.2007, 6:49
Пользователь №: 53 855
Модель телефона: E398&3250 Silver
Прошивка: 42R&Symbian 9.1
Народ. Прив Всем!! Я тут слышал от одного человека что перенесли классы BT с L7..и сделал это Electro255, и мол это уже не новость даже..
Добавлено позже (14.8.2007, 9:51):
Просто уже полгода со смартом хожу, перестал следить за мото-новостями! smile.gif
Добавлено позже (14.8.2007, 9:52):
Хотя Е398 ещё есть)) Бабуля с ним гоняет ))
neonaft
сообщение 14.8.2007, 7:00
Из: Брянск
Пользователь №: 101 454
Модель телефона: V3x, L7, E398, V535
Прошивка: Пробовал всё
Crazy Fast, Хотелось бы мне поговорить с твоим человеком biggrin.gif может он перенес biggrin.gif
Я ничего подобного к сожалению не встречал sad.gif по-моему, просто байка чья-то thumbdown.gif
Valeo
сообщение 14.8.2007, 8:07
Going eternally
Из: Україна. м. Чернігів
Пользователь №: 46 805
Модель телефона: 1
Дата поощрения/наказания
Это по моему - сказки.
Trentemoller
сообщение 17.8.2007, 1:26
Из: Армавир
Пользователь №: 105 953
Написано на сайте электро:
I decided to suspend R373 mods. I'm making Motorola Firmware Universal Patcher (MPatcher) what can make firmwares patching more universal, also my old R373 mod will be rewritten to patch so maybe this can work on other platform (R452D, R4513 etc).
MPatcher is small Java application, patches are in Java class files, but don't worry I will give a lot of examples how to make patch and compile to *.class.
Я решил приостанавливать R373 mods. Я делаю для Motorola Микропрограммный Универсальный Patcher (MPatcher), что может делать ПО более пропатченной, также мой старый R373 mod будет переписан, так возможно это может работать на другой платформе (R452D, R4513 и т.д.)
MPatcher - маленькая ява программма, патчи находятся в файлах класса Ява, но не волнуют, что я буду давать много примеров, как делать патч и буду собирать к *.class.
Сообщение отредактировал Trentemoller - 17.8.2007, 1:36
VkD
сообщение 17.8.2007, 9:10
Прошивка: MS 1.5b
Trentemoller,
Если быть точнее...
Я решил приостановить мод 373.. Я делаю Универсальный патчер Прошивок Моторола (МПатчер), который сделает патчинг прошивок более универсальным, так что мой старый 373 мод будет переписан для патченья, возможно это будет работать и на других платформах (R452D, R4513 и т.д.)
MPatcher - маленькая ява программма, патчи находятся в файлах класса Ява, но не волнуйтесь, я буду давать много примеров, как сделать патч скомпилить его в *.class.
Скоро появятся первые скрины... smile.gif)
electro255
а что с предыдущими планами (elf-loader etc)?? Они будут реализованы? Ждем-с smile.gif)
CHEATER
сообщение 17.8.2007, 11:54
Из: Г.Иркутск
Пользователь №: 65 448
Прошивка: S_blank_49R
VkD, не "переписан для патченья" а переписан в патч (для установки поверх предыдущей версии...
Почему же всетаки JAVA ****.class'ы , а не долгожданные эльфы ?!?!?!?! И потом непонятно придется ли менять родную R373 на какуюто зломудреную R4513 от С698R ... Если мне не изменяет память , то на R4513 не поддерживаются скины , флэшки не видит , и нет возможности сменить DRM (OH B CG1 ЗАШИТ)...
Также :
Цитата:
Сообщение от Elektro255
Все изменения , которые он провел - будут применяться как патч на уже имеющуюся прошиву (49R или 46v04a4 ???) - это есьть непоньятна !
Придется судя по всему либо грузить стандартную прошу , и потом догружать эти ява патчи , либо отказаться от корелетов(чтобы патчи прога сама грузила)...
Резюме : Куча неясностей и непонятностей ! Если кто нибудь в контакте с Электро - плииз распишите что да как...
deadmoto
сообщение 17.8.2007, 16:14
Главный Новостник
Из: Омск
Пользователь №: 49 284
Модель телефона: Motorola
Прошивка: Motorola Original
CHEATER, читай оригинал со словарём)
По сути электромод будет представлять из себя универсальный патчер (для всех платформ!!! не только для Е398\Е1) и судя по всему в ява-классах будут компилиться сами патчи, а ява-приложение будет только выполнять эти классы...
sadface
сообщение 18.8.2007, 9:34
Пользователь №: 110 110
Модель телефона: Z6 + Kingston 2GB
Прошивка: 44R + PE
CHEATER,
4513 - это платформа не от с698р.
Doktor Кот
сообщение 21.8.2007, 15:10
Из: Красноярск
Пользователь №: 94 751
Прошивка: Electro_R373...49R
На сайте появилась первая тест версия МР патчера... Для запуска надо на комп установить Java Runtime 2. Потестил... Прога содержит штук 10 патчей, причем очень старых которые уже давно есть в теме "Патчи для Е1". Патчей для апгрейта любой проши до электромода пока что нет, программа пока что бесполезна! Я вообще не понимаю, нафига Электро переделывает патчи в ява классы, это же бессмысленно! Fpa рулит с flashbackUp! Его хоть редактировать можно, а ява классы нет! Короче, судите сами, но мне кажется, что электро фигней занимается!
Valeo
сообщение 21.8.2007, 15:18
Going eternally
Модель телефона: 1
MPatcher v1.0 TEST
Цитата(elektro255 @ Сегодня, 14:29)
Сегодня я в сети ICQ на весь день
Сообщение отредактировал Valeo - 21.8.2007, 15:19
CrazZZyBuNNy
сообщение 21.8.2007, 18:19
22:11:28 The black list for example can be realized?
22:11:57 By means of this program
Сегодня elektro255
22:12:13 yes
так что вкусненького должно это принести много
Сообщение отредактировал CrazZZyBuNNy - 21.8.2007, 18:19
goods
сообщение 21.8.2007, 19:41
Пользователь №: 91 380
Модель телефона: E398 + 1Gb
Прошивка: DaR
igorrius
сообщение 3.9.2007, 18:56
Пользователь №: 56 062
Прошивка: 49r
всем здрасте.
извиняюсь, может отстал от жизни?
автору сообщили о багах, которые нужно исправить, таких как:
1. невозможность сохранять файл, принятый по ммс
2. проблема с базой мелодий. у меня постоянно пропадает мелодия на звонок.
обычные способы решения проблемы не помогают( все бесшумные плюс удаление базы)
до того как перешел на флеш от Электро такого не было.
Огромная просьба, кто шурупает англицкий, донести до автора сию инфу, если этого еще не было сделано.
у меня версия 03
Текстовая версия Сейчас: 22.7.2025, 18:09
