23 страниц V « < 19 20 21 22 23 >
Elektro255 V0.4 alpha 4 mod (4xR), 44R,46R,49R,79R
elektro255
сообщение 23.9.2006, 12:06 Закрепленное сообщение!
Из: Poland, Siedlce
Пользователь №: 53 130
09-04-2007
V0.4a4 Alpha: http://elektro255.ovh.org
08-04-2007
V0.4a3 Alpha: http://elektro255.ovh.org
07-04-2007
V0.4a2 44R Alpha: http://elektro255.ovh.org
20-12-2006
V0.3 79R Final mod: http://elektro255.ovh.org
27-11-2006
v0.3 for 49R Final mod http://elektro255.ovh.org/
26-11-2006
V0.3 46R Final mod: http://elektro255.ovh.org
НА Е1 Rokr с бутом 0А02 (оригинальный) НЕ ПОСТАВИТЕ БЕЗ Т.П.!
V0.4 alpha 4
Changes:
- Fixed problem with display timeout (fullscreen clock) when SMS/CALL received
Features:
- 4xR and 7xR MIX (use with 4xR flex)
- unlimited Video recording
- keypad automatic lock
- low battery alarm can be turned off or depend on ring style.
- Scheduled Ring Styles (ring style and funlight style can change automatically on given time and week day)
- flashlight shortcut (##)
- extra menu (shortcut *1 [shortcut is only for testing later will be changed])
- automatic menu enter, without sim card (emergency calls working too)
- new Java methods
- settings are stored on files
- no simlock checking
- Volume-bar sound can be turned off
- multiple menus (every skin can have one mma_ucp)
- Ported patches:
o SMS report significantly turned ON
o more folders in OBEX via BT
o removed unused folders from TransFlash
o Java have access to system files
o increased iTap user dictionary size
o no delete incall on SIM replace
o Bluetooth time changed to 3 minutes
o reordered camera store menu (store only is first)
o SMS alert is using default ringtone
OLD versions(V0.1-0.3):
Firmware changes:
- firmware based on 46R from StarterXP MP
- FULL SW access from Java
- LUMA&CHROMA tables moved to memory - now you can change JPEG compresion from Java
- StarterXP flex
- added dualboot
Flasher changes:
- if you have PDS_4013 flasher will no recreate this
Personalization tool changes:
- first version for 0.3_46R SW mod
- changing splash screen
- changing font (you can use *.fnt or *.smg CG4 files)
- you can turn on, turn off menu access without sim cart
- changing my shortcuts
Новая версия V0.4 alpha 4
Изменения:
- Устранена проблема с таймаутом дисплея(полноэкранные часы) при приеме смс/звонка
Новое:
- Прошивка создана как микс 4xR и 7xR (флекс 4xR ) В 44R она переименована для совместимости! Она близко не лежит к 44R на самом деле!
- Безлимитная запись видео (64мб макс как в 6х7х)
- Автоблок клавиатуры
- Звук разряженой батареи можно выключать или задать стилем оповещения(?).
- Расписание стилей оповещения (стиль оповещения и фанлайтмогут менятся автоматически по времени и дням недели)
- Фонарик по (##)
- Дополнительное меню (метка *1 [только для теста, после может изменится])
- Автоматический вход в меню без сим-карты (аварийные звонки работают)
- Новые методы в Яве (не от 79R, а новые)
- Настройки хранятся в файлах
- Не проверяется лоченость ПДС на симку (работает с лоченым пдс)
- Звук изменения громкости можно отключить
- Мультименю (каждый скин может иметь собственный мма_уцп)
- Портированы патчи:
o Оповещение о доставке SMS всегда вкл.
o больше папок доступно по OBEX из блютуза
o удалены неиспользуемые папки с флешки
o Полный доступ к системным файлам из явы
o увеличен размер пользовательского словаря iTap
o не удалыются последние вызовы при смене сим
o Время обнаружения блютуза - 3 минуты
o Меню сохранения видеозаписи (просто сохранить - первым пунктом)
o при приходе SMS играет "мелодия на смс", а не установленная на этого пользователя
Для версий 0.1-0.3
Изменения в прошивке:
- Создана на базе монстра StarterXP 46R
- Полный доступ к прошивке (симы, озу) из явы
- Таблицы сжатия фотографий перенесены в озу - теперь из явы можно управлять качеством фотографий (сжатием)
- флекс StarterXP
- добавлен дуалбут
Изменения флешера:
-Если ПДС версии 4013 (373 платформа), ПДС не пересоздается.
Изменения персонализации (Personalization tool):
- впервые для мода использована 46 прошивка
- замена заставки (на включение?)
- замена шрифта (лангпак, CG4)
- можно вкл. и выкл. доступ к меню без сим-карты
- изменен ярлык (копирайт?)
Для работы Personalization tool требуется положить в папку программы несжатый бинарный бэкап (32 мегабайта) под именем SW.bin
Прекращаем флудить, типа а когда выйдет новая версия, и.т.д.и.т.п, или придётся наказывать!
тему почистил, архив по 1 декабря тут:
Прикрепленный файл MotoFan_ru_electro.zip   ( 66.56 килобайт ) Кол-во скачиваний: 3902
Сообщение отредактировал elektro255 - 9.4.2007, 12:21
CrazZZyBuNNy
сообщение 13.8.2007, 10:11
Пользователь №: 130 578
Модель телефона: у398
HDD Repaired New mod is comming (elf loader and moto SDK) - последнее что написано на сайте
VkD
сообщение 14.8.2007, 4:22
Пользователь №: 64 617
Прошивка: MS 1.5b
Подскажите, в моде 0.4a сохраняются файлы, присланные через ММС??? smile.gif
Crazy Fast
сообщение 14.8.2007, 6:49
Пользователь №: 53 855
Модель телефона: E398&3250 Silver
Прошивка: 42R&Symbian 9.1
Народ. Прив Всем!! Я тут слышал от одного человека что перенесли классы BT с L7..и сделал это Electro255, и мол это уже не новость даже..
Добавлено позже (14.8.2007, 9:51):
Просто уже полгода со смартом хожу, перестал следить за мото-новостями! smile.gif
Добавлено позже (14.8.2007, 9:52):
Хотя Е398 ещё есть)) Бабуля с ним гоняет ))
neonaft
сообщение 14.8.2007, 7:00
Из: Брянск
Пользователь №: 101 454
Модель телефона: V3x, L7, E398, V535
Прошивка: Пробовал всё
Crazy Fast, Хотелось бы мне поговорить с твоим человеком biggrin.gif может он перенес biggrin.gif
Я ничего подобного к сожалению не встречал sad.gif по-моему, просто байка чья-то thumbdown.gif
Valeo
сообщение 14.8.2007, 8:07
Going eternally
Из: Україна. м. Чернігів
Пользователь №: 46 805
Модель телефона: 1
Дата поощрения/наказания
Это по моему - сказки.
Trentemoller
сообщение 17.8.2007, 1:26
Из: Армавир
Пользователь №: 105 953
Прошивка: R373_G_0E.30.49R
Написано на сайте электро:
I decided to suspend R373 mods. I'm making Motorola Firmware Universal Patcher (MPatcher) what can make firmwares patching more universal, also my old R373 mod will be rewritten to patch so maybe this can work on other platform (R452D, R4513 etc).
MPatcher is small Java application, patches are in Java class files, but don't worry I will give a lot of examples how to make patch and compile to *.class.
Я решил приостанавливать R373 mods. Я делаю для Motorola Микропрограммный Универсальный Patcher (MPatcher), что может делать ПО более пропатченной, также мой старый R373 mod будет переписан, так возможно это может работать на другой платформе (R452D, R4513 и т.д.)
MPatcher - маленькая ява программма, патчи находятся в файлах класса Ява, но не волнуют, что я буду давать много примеров, как делать патч и буду собирать к *.class.
Сообщение отредактировал Trentemoller - 17.8.2007, 1:36
VkD
сообщение 17.8.2007, 9:10
Прошивка: MS 1.5b
Trentemoller,
Если быть точнее...
Я решил приостановить мод 373.. Я делаю Универсальный патчер Прошивок Моторола (МПатчер), который сделает патчинг прошивок более универсальным, так что мой старый 373 мод будет переписан для патченья, возможно это будет работать и на других платформах (R452D, R4513 и т.д.)
MPatcher - маленькая ява программма, патчи находятся в файлах класса Ява, но не волнуйтесь, я буду давать много примеров, как сделать патч скомпилить его в *.class.
Скоро появятся первые скрины... smile.gif)
electro255
а что с предыдущими планами (elf-loader etc)?? Они будут реализованы? Ждем-с smile.gif)
CHEATER
сообщение 17.8.2007, 11:54
Из: Г.Иркутск
Пользователь №: 65 448
Прошивка: S_blank_49R
VkD, не "переписан для патченья" а переписан в патч (для установки поверх предыдущей версии...
Почему же всетаки JAVA ****.class'ы , а не долгожданные эльфы ?!?!?!?! И потом непонятно придется ли менять родную R373 на какуюто зломудреную R4513 от С698R ... Если мне не изменяет память , то на R4513 не поддерживаются скины , флэшки не видит , и нет возможности сменить DRM (OH B CG1 ЗАШИТ)...
Также :
Цитата:
Сообщение от Elektro255
Все изменения , которые он провел - будут применяться как патч на уже имеющуюся прошиву (49R или 46v04a4 ???) - это есьть непоньятна !
Придется судя по всему либо грузить стандартную прошу , и потом догружать эти ява патчи , либо отказаться от корелетов(чтобы патчи прога сама грузила)...
Резюме : Куча неясностей и непонятностей ! Если кто нибудь в контакте с Электро - плииз распишите что да как...
deadmoto
сообщение 17.8.2007, 16:14
Главный Новостник
Из: Омск
Пользователь №: 49 284
Модель телефона: Motorola
Прошивка: Motorola Original
CHEATER, читай оригинал со словарём)
По сути электромод будет представлять из себя универсальный патчер (для всех платформ!!! не только для Е398\Е1) и судя по всему в ява-классах будут компилиться сами патчи, а ява-приложение будет только выполнять эти классы...
sadface
сообщение 18.8.2007, 9:34
Пользователь №: 110 110
Модель телефона: Z6 + Kingston 2GB
Прошивка: 44R + PE
CHEATER,
4513 - это платформа не от с698р.
Doktor Кот
сообщение 21.8.2007, 15:10
Из: Красноярск
Пользователь №: 94 751
Прошивка: Electro_R373...49R
На сайте появилась первая тест версия МР патчера... Для запуска надо на комп установить Java Runtime 2. Потестил... Прога содержит штук 10 патчей, причем очень старых которые уже давно есть в теме "Патчи для Е1". Патчей для апгрейта любой проши до электромода пока что нет, программа пока что бесполезна! Я вообще не понимаю, нафига Электро переделывает патчи в ява классы, это же бессмысленно! Fpa рулит с flashbackUp! Его хоть редактировать можно, а ява классы нет! Короче, судите сами, но мне кажется, что электро фигней занимается!
Valeo
сообщение 21.8.2007, 15:18
Going eternally
Модель телефона: 1
MPatcher v1.0 TEST
Цитата(elektro255 @ Сегодня, 14:29)
Сегодня я в сети ICQ на весь день
Сообщение отредактировал Valeo - 21.8.2007, 15:19
CrazZZyBuNNy
сообщение 21.8.2007, 18:19
22:11:28 The black list for example can be realized?
22:11:57 By means of this program
Сегодня elektro255
22:12:13 yes
так что вкусненького должно это принести много
Сообщение отредактировал CrazZZyBuNNy - 21.8.2007, 18:19
goods
сообщение 21.8.2007, 19:41
Пользователь №: 91 380
Модель телефона: E398 + 1Gb
Прошивка: DaR
igorrius
сообщение 3.9.2007, 18:56
Пользователь №: 56 062
Прошивка: 49r
всем здрасте.
извиняюсь, может отстал от жизни?
автору сообщили о багах, которые нужно исправить, таких как:
1. невозможность сохранять файл, принятый по ммс
2. проблема с базой мелодий. у меня постоянно пропадает мелодия на звонок.
обычные способы решения проблемы не помогают( все бесшумные плюс удаление базы)
до того как перешел на флеш от Электро такого не было.
Огромная просьба, кто шурупает англицкий, донести до автора сию инфу, если этого еще не было сделано.
у меня версия 03
neonaft
сообщение 4.9.2007, 4:30
Из: Брянск
igorrius,
Эту проблему вряд ли кто-то исправлять будет sad.gif Электро вроде как больше не выпускает моды sad.gif
Это проблема только у тебя очень стабильна wink.gif Вроде тебе писали по этому поводу cool.gif
MIXIK
сообщение 4.9.2007, 9:42
Пользователь №: 145 536
Модель телефона: rokr e1
Прошивка: неиз.
Почему на electro255 не идут ява игры, не запускаются
пишет ошибка приложения
neonaft
сообщение 4.9.2007, 10:06
Из: Брянск
MIXIK,
На каком именно моде?
dimandos
сообщение 4.9.2007, 10:09
Пользователь №: 143 003
Модель телефона: E 398
Прошивка: Мрх398 De Luxe
это из-за скинов у тебя, у меня тоже самое было. в программе skinner4moto убери галку легкий скин.
igorrius
сообщение 4.9.2007, 19:03
Прошивка: 49r
Цитата(neonaft @ 4.9.2007, 7:30) *
igorrius,
а во- вторых я не зря грешу на флеш от Электро. когда у меня стояла обычная прошива 49 без флеша от Электро проблем не было.
а теперь проблема есть стабильно и ничего не помогает....
все бесшумные плюс удаление базы не помогает.
может кто то посоветует еще что то попробовать сделать?
neonaft
сообщение 5.9.2007, 4:23
Из: Брянск
Может просто пока у тебя не стоял мод электро - всё было нормально с железом, а теперь просто нет? Попробуй другую прошивку, другой мод - если там такая же проблема - разберись с телефоном wink.gif
А не на прошивку греши!
=BazOOka=
сообщение 6.9.2007, 11:34
Пользователь №: 107 478
Модель телефона: rokr e2
Прошивка: 4AP
igorrius, прошей другой флекс (например Stalker XP или New Standart)
igorrius
сообщение 9.9.2007, 13:57
Прошивка: 49r
у меня как раз нью стандарт и стоит.
и еще такая проблема есть:
МВ при попытке переименовать файл перезагружает телефон.
тут обсуждали данную проблему( прямая ссылка)
типа как пришли к выводу что флеш от Электро виноват.
если это так- прошу передать Электро этот баг
=BazOOka=
сообщение 9.9.2007, 16:17
Прошивка: 4AP
QUOTE(igorrius @ Today, 17:57)
он приостановил работы над модами
а стандартный попробуй (с 49R заводской)
PhoeniX-7
сообщение 23.9.2007, 15:51
Из: Ростов-на-Дону
Пользователь №: 39 038
Прошивка: MAXX E2 II 4AP
Может такую проблему уже обсуждали, но я в поиске не нашёл, а перечитывать всё терпения не хватило...
У меня стоит Elektro255 V0.4a4 (46R). При работе Jimm'a и Оперы телефон часто перезагружается. Как я понял перезагрузка происходит в любой яве, которая что-то качает из интернета. Это можно исправить? А то невозможно нормально лазить по сайтам в Опере..
AlexKooper
сообщение 11.10.2007, 13:22
Из: Йошкар-Ола
Пользователь №: 47 140
Прошивка: AlexKooper mod v.47
PhoeniX-7, Это известный глюк этой версии мода при работе с гпрс. Не обязательно явой, можно сидеть с компа через тел и он также будет периодически перезагружаться.
Volodya-kg
сообщение 6.11.2007, 14:03
Пользователь №: 149 687
Прошивка: 49r
Скажите, почему на 49r Electro255 Life Final при загрузке некоторых больших mp3 файлов телефон их не воспроизводит? Пишет, что другой формат. Размер mp3 которые он не читает - больше 8 Mb
Andrey89
сообщение 6.11.2007, 15:53
Пользователь №: 76 807
Модель телефона: E398 + Z6
Прошивка: SkyMoto (49R EM)
Volodya-kg, возможно из-за того что качество больше чем 192 кбит'а/сек ... поставь пачт на воспроизведение 320, патч можешь найти в этой теме Патчи Для 49r
Сообщение отредактировал Andrey89 - 6.11.2007, 15:53
Doktor Кот
сообщение 12.11.2007, 0:20
Из: Красноярск
Кто нибудь знает, как избавиться от бага с ммс? На моде 0.3 файлы-вложения не сохраняются в телефон!
neonaft
сообщение 12.11.2007, 8:21
Из: Брянск
Doktor Кот, Никак, это вроде под силу только самому Электро. Но он больше не пишет моды sad.gif
Родничок
сообщение 13.11.2007, 12:34
Из: Ростов-на-Дону
Пользователь №: 148 695
Модель телефона: E398;Mpx200;C650
Прошивка: DeLuxe + WM6.1
Довольный)
neonaft
сообщение 13.11.2007, 12:42
Из: Брянск
Родничок, А с сайта Электро не качается?
Родничок
сообщение 13.11.2007, 18:19
Из: Ростов-на-Дону
Довольный)
sad.gif Не получаетсяneonaft,
Пишет The requested URL was not found on this server.
Сообщение отредактировал Родничок - 13.11.2007, 18:22
neonaft
сообщение 14.11.2007, 4:59
Из: Брянск
Родничок, Проверил, ссылка на рапиду - всё скачивается! Может что то не так делаешь?
Родничок
сообщение 14.11.2007, 11:16
Из: Ростов-на-Дону
Довольный)
Дай несколько ссылок, может из-за того, что на рапиде?
xaBaz
сообщение 22.11.2007, 18:05
Из: Kharkov [at] UA
Пользователь №: 134 260
Модель телефона: many
Прошивка: Crossflashing_
Что сделал elektro255, чтобы дать доступ к RAM из Явы?
сообщение 3.12.2007, 13:21
а 4 модна р49 можно ставить на 49р мод3? и как откатится назад? unsure.gif stink.gif
Яуген
сообщение 3.12.2007, 18:25
Пользователь №: 101 871
Claus398, можно. Откатится - ставь опять поверху третий мод
Ap)(
сообщение 17.12.2007, 8:22
Пользователь №: 82 135
Модель телефона: RoverPC G6
Прошивка: Windows Mobile 6.0
1. Подскажите плз, какой из модов Electro самый стабильный?
1a. И патчи для каких прошивок к нему подходят?
2. Какие именно патчи подходят к Elektro255 V0.4a4 (46R) ? Т.е. для каких прошивок? 46R?
3. Конкретнее: кто-нибудь смог подружить мод от электро с эльфами? Пытался сгенерить и поставить патч для 46R, тел в результате отказался включаться. У меня Elektro255 V0.4a4 (46R)
neonaft
сообщение 18.12.2007, 6:25
Из: Брянск
49R E.M.-0.3 самый стабильный, на него есть больше всего патчей.
ДЛя V0.4a4 (46R) патчи портируются отдельно и от обычной 46 по-моему не подходят
Текстовая версия Сейчас: 18.7.2025, 16:59
