23 страниц V « < 20 21 22 23 >
Elektro255 V0.4 alpha 4 mod (4xR), 44R,46R,49R,79R
elektro255
сообщение 23.9.2006, 12:06 Закрепленное сообщение!
Из: Poland, Siedlce
Пользователь №: 53 130
09-04-2007
V0.4a4 Alpha: http://elektro255.ovh.org
08-04-2007
V0.4a3 Alpha: http://elektro255.ovh.org
07-04-2007
V0.4a2 44R Alpha: http://elektro255.ovh.org
20-12-2006
V0.3 79R Final mod: http://elektro255.ovh.org
27-11-2006
v0.3 for 49R Final mod http://elektro255.ovh.org/
26-11-2006
V0.3 46R Final mod: http://elektro255.ovh.org
НА Е1 Rokr с бутом 0А02 (оригинальный) НЕ ПОСТАВИТЕ БЕЗ Т.П.!
V0.4 alpha 4
Changes:
- Fixed problem with display timeout (fullscreen clock) when SMS/CALL received
Features:
- 4xR and 7xR MIX (use with 4xR flex)
- unlimited Video recording
- keypad automatic lock
- low battery alarm can be turned off or depend on ring style.
- Scheduled Ring Styles (ring style and funlight style can change automatically on given time and week day)
- flashlight shortcut (##)
- extra menu (shortcut *1 [shortcut is only for testing later will be changed])
- automatic menu enter, without sim card (emergency calls working too)
- new Java methods
- settings are stored on files
- no simlock checking
- Volume-bar sound can be turned off
- multiple menus (every skin can have one mma_ucp)
- Ported patches:
o SMS report significantly turned ON
o more folders in OBEX via BT
o removed unused folders from TransFlash
o Java have access to system files
o increased iTap user dictionary size
o no delete incall on SIM replace
o Bluetooth time changed to 3 minutes
o reordered camera store menu (store only is first)
o SMS alert is using default ringtone
OLD versions(V0.1-0.3):
Firmware changes:
- firmware based on 46R from StarterXP MP
- FULL SW access from Java
- LUMA&CHROMA tables moved to memory - now you can change JPEG compresion from Java
- StarterXP flex
- added dualboot
Flasher changes:
- if you have PDS_4013 flasher will no recreate this
Personalization tool changes:
- first version for 0.3_46R SW mod
- changing splash screen
- changing font (you can use *.fnt or *.smg CG4 files)
- you can turn on, turn off menu access without sim cart
- changing my shortcuts
Новая версия V0.4 alpha 4
Изменения:
- Устранена проблема с таймаутом дисплея(полноэкранные часы) при приеме смс/звонка
Новое:
- Прошивка создана как микс 4xR и 7xR (флекс 4xR ) В 44R она переименована для совместимости! Она близко не лежит к 44R на самом деле!
- Безлимитная запись видео (64мб макс как в 6х7х)
- Автоблок клавиатуры
- Звук разряженой батареи можно выключать или задать стилем оповещения(?).
- Расписание стилей оповещения (стиль оповещения и фанлайтмогут менятся автоматически по времени и дням недели)
- Фонарик по (##)
- Дополнительное меню (метка *1 [только для теста, после может изменится])
- Автоматический вход в меню без сим-карты (аварийные звонки работают)
- Новые методы в Яве (не от 79R, а новые)
- Настройки хранятся в файлах
- Не проверяется лоченость ПДС на симку (работает с лоченым пдс)
- Звук изменения громкости можно отключить
- Мультименю (каждый скин может иметь собственный мма_уцп)
- Портированы патчи:
o Оповещение о доставке SMS всегда вкл.
o больше папок доступно по OBEX из блютуза
o удалены неиспользуемые папки с флешки
o Полный доступ к системным файлам из явы
o увеличен размер пользовательского словаря iTap
o не удалыются последние вызовы при смене сим
o Время обнаружения блютуза - 3 минуты
o Меню сохранения видеозаписи (просто сохранить - первым пунктом)
o при приходе SMS играет "мелодия на смс", а не установленная на этого пользователя
Для версий 0.1-0.3
Изменения в прошивке:
- Создана на базе монстра StarterXP 46R
- Полный доступ к прошивке (симы, озу) из явы
- Таблицы сжатия фотографий перенесены в озу - теперь из явы можно управлять качеством фотографий (сжатием)
- флекс StarterXP
- добавлен дуалбут
Изменения флешера:
-Если ПДС версии 4013 (373 платформа), ПДС не пересоздается.
Изменения персонализации (Personalization tool):
- впервые для мода использована 46 прошивка
- замена заставки (на включение?)
- замена шрифта (лангпак, CG4)
- можно вкл. и выкл. доступ к меню без сим-карты
- изменен ярлык (копирайт?)
Для работы Personalization tool требуется положить в папку программы несжатый бинарный бэкап (32 мегабайта) под именем SW.bin
Прекращаем флудить, типа а когда выйдет новая версия, и.т.д.и.т.п, или придётся наказывать!
тему почистил, архив по 1 декабря тут:
Прикрепленный файл MotoFan_ru_electro.zip   ( 66.56 килобайт ) Кол-во скачиваний: 3902
Сообщение отредактировал elektro255 - 9.4.2007, 12:21
neonaft
сообщение 4.9.2007, 4:30
Из: Брянск
Пользователь №: 101 454
Модель телефона: V3x, L7, E398, V535
Прошивка: Пробовал всё
igorrius,
Цитата(igorrius @ Вчера, 22:56)
1. невозможность сохранять файл, принятый по ммс
Эту проблему вряд ли кто-то исправлять будет sad.gif Электро вроде как больше не выпускает моды sad.gif
2. проблема с базой мелодий. у меня постоянно пропадает мелодия на звонок.
обычные способы решения проблемы не помогают( все бесшумные плюс удаление базы)
Это проблема только у тебя очень стабильна wink.gif Вроде тебе писали по этому поводу cool.gif
MIXIK
сообщение 4.9.2007, 9:42
Пользователь №: 145 536
Модель телефона: rokr e1
Прошивка: неиз.
Почему на electro255 не идут ява игры, не запускаются
пишет ошибка приложения
neonaft
сообщение 4.9.2007, 10:06
Из: Брянск
MIXIK,
На каком именно моде?
dimandos
сообщение 4.9.2007, 10:09
Пользователь №: 143 003
Модель телефона: E 398
Прошивка: Мрх398 De Luxe
это из-за скинов у тебя, у меня тоже самое было. в программе skinner4moto убери галку легкий скин.
igorrius
сообщение 4.9.2007, 19:03
Пользователь №: 56 062
Прошивка: 49r
Цитата(neonaft @ 4.9.2007, 7:30) *
igorrius,
а во- вторых я не зря грешу на флеш от Электро. когда у меня стояла обычная прошива 49 без флеша от Электро проблем не было.
а теперь проблема есть стабильно и ничего не помогает....
все бесшумные плюс удаление базы не помогает.
может кто то посоветует еще что то попробовать сделать?
neonaft
сообщение 5.9.2007, 4:23
Из: Брянск
Может просто пока у тебя не стоял мод электро - всё было нормально с железом, а теперь просто нет? Попробуй другую прошивку, другой мод - если там такая же проблема - разберись с телефоном wink.gif
А не на прошивку греши!
=BazOOka=
сообщение 6.9.2007, 11:34
Пользователь №: 107 478
Модель телефона: rokr e2
Прошивка: 4AP
igorrius, прошей другой флекс (например Stalker XP или New Standart)
igorrius
сообщение 9.9.2007, 13:57
Прошивка: 49r
у меня как раз нью стандарт и стоит.
и еще такая проблема есть:
МВ при попытке переименовать файл перезагружает телефон.
тут обсуждали данную проблему( прямая ссылка)
типа как пришли к выводу что флеш от Электро виноват.
если это так- прошу передать Электро этот баг
=BazOOka=
сообщение 9.9.2007, 16:17
Прошивка: 4AP
QUOTE(igorrius @ Today, 17:57)
он приостановил работы над модами
а стандартный попробуй (с 49R заводской)
PhoeniX-7
сообщение 23.9.2007, 15:51
Из: Ростов-на-Дону
Пользователь №: 39 038
Прошивка: MAXX E2 II 4AP
Может такую проблему уже обсуждали, но я в поиске не нашёл, а перечитывать всё терпения не хватило...
У меня стоит Elektro255 V0.4a4 (46R). При работе Jimm'a и Оперы телефон часто перезагружается. Как я понял перезагрузка происходит в любой яве, которая что-то качает из интернета. Это можно исправить? А то невозможно нормально лазить по сайтам в Опере..
AlexKooper
сообщение 11.10.2007, 13:22
Из: Йошкар-Ола
Пользователь №: 47 140
Прошивка: AlexKooper mod v.47
PhoeniX-7, Это известный глюк этой версии мода при работе с гпрс. Не обязательно явой, можно сидеть с компа через тел и он также будет периодически перезагружаться.
Volodya-kg
сообщение 6.11.2007, 14:03
Пользователь №: 149 687
Прошивка: 49r
Скажите, почему на 49r Electro255 Life Final при загрузке некоторых больших mp3 файлов телефон их не воспроизводит? Пишет, что другой формат. Размер mp3 которые он не читает - больше 8 Mb
Andrey89
сообщение 6.11.2007, 15:53
Пользователь №: 76 807
Модель телефона: E398 + Z6
Прошивка: SkyMoto (49R EM)
Volodya-kg, возможно из-за того что качество больше чем 192 кбит'а/сек ... поставь пачт на воспроизведение 320, патч можешь найти в этой теме Патчи Для 49r
Сообщение отредактировал Andrey89 - 6.11.2007, 15:53
Doktor Кот
сообщение 12.11.2007, 0:20
Из: Красноярск
Пользователь №: 94 751
Прошивка: Electro_R373...49R
Кто нибудь знает, как избавиться от бага с ммс? На моде 0.3 файлы-вложения не сохраняются в телефон!
neonaft
сообщение 12.11.2007, 8:21
Из: Брянск
Doktor Кот, Никак, это вроде под силу только самому Электро. Но он больше не пишет моды sad.gif
Родничок
сообщение 13.11.2007, 12:34
Из: Ростов-на-Дону
Пользователь №: 148 695
Модель телефона: E398;Mpx200;C650
Прошивка: DeLuxe + WM6.1
Довольный)
neonaft
сообщение 13.11.2007, 12:42
Из: Брянск
Родничок, А с сайта Электро не качается?
Родничок
сообщение 13.11.2007, 18:19
Из: Ростов-на-Дону
Довольный)
sad.gif Не получаетсяneonaft,
Пишет The requested URL was not found on this server.
Сообщение отредактировал Родничок - 13.11.2007, 18:22
neonaft
сообщение 14.11.2007, 4:59
Из: Брянск
Родничок, Проверил, ссылка на рапиду - всё скачивается! Может что то не так делаешь?
Родничок
сообщение 14.11.2007, 11:16
Из: Ростов-на-Дону
Довольный)
Дай несколько ссылок, может из-за того, что на рапиде?
xaBaz
сообщение 22.11.2007, 18:05
Из: Kharkov [at] UA
Пользователь №: 134 260
Модель телефона: many
Прошивка: Crossflashing_
Что сделал elektro255, чтобы дать доступ к RAM из Явы?
сообщение 3.12.2007, 13:21
а 4 модна р49 можно ставить на 49р мод3? и как откатится назад? unsure.gif stink.gif
Яуген
сообщение 3.12.2007, 18:25
Пользователь №: 101 871
Claus398, можно. Откатится - ставь опять поверху третий мод
Ap)(
сообщение 17.12.2007, 8:22
Пользователь №: 82 135
Модель телефона: RoverPC G6
Прошивка: Windows Mobile 6.0
1. Подскажите плз, какой из модов Electro самый стабильный?
1a. И патчи для каких прошивок к нему подходят?
2. Какие именно патчи подходят к Elektro255 V0.4a4 (46R) ? Т.е. для каких прошивок? 46R?
3. Конкретнее: кто-нибудь смог подружить мод от электро с эльфами? Пытался сгенерить и поставить патч для 46R, тел в результате отказался включаться. У меня Elektro255 V0.4a4 (46R)
neonaft
сообщение 18.12.2007, 6:25
Из: Брянск
49R E.M.-0.3 самый стабильный, на него есть больше всего патчей.
ДЛя V0.4a4 (46R) патчи портируются отдельно и от обычной 46 по-моему не подходят
Motohobiman
сообщение 25.3.2008, 4:59
Из: Ukraina
Пользователь №: 81 710
Прошивка: Слава Украине!
Вечный мотодроллер;)
Форумчане,извините за вопрос,но почему Электро255 перестал кодить и я так понял все рефлеши 0.4 глючат ?
MARKyxa
сообщение 25.3.2008, 7:47
(/\/\)otoModer
Из: Города грехов
Пользователь №: 158 437
Прошивка: IOS
In progress
Motohobiman,
Motohobiman
сообщение 25.3.2008, 12:07
Из: Ukraina
А почему нет монстров на базе 0.4 и все используют 0.3?
MARKyxa
сообщение 25.3.2008, 15:37
(/\/\)otoModer
Из: Города грехов
Прошивка: IOS
In progress
Motohobiman,
Добавлено позже (26.3.2008, 1:38):
да и 49р считают более стабильной, и звук на ней самый лучший
DDA-E398
сообщение 27.3.2008, 21:09
Из: Нижегородская обл.
Пользователь №: 166 356
Модель телефона: E2, A910, Е398, ATRIX2
Прошивка: разные
Роботаю...
Ну этот мод очень сырой.Я его как-то ставил и вот что заметил:через пять минут в нете перезагруз,в меню жутко тормозит,глюк с ммс так и остался.Зачем выкладывать монстрпак с такими серьёзными багами?Я лично смысла не вижу.А доработки или новых модов от электро не ожидается
MARKyxa
сообщение 28.3.2008, 3:36
(/\/\)otoModer
Из: Города грехов
Прошивка: IOS
In progress
DDA-E398,
Ну не знаю даже, пробовал эти рефлеши, вроде все было норм elektro255, респект за это smile.gif
DDA-E398
сообщение 7.5.2008, 13:25
Прошивка: разные
Роботаю...
Я не принижаю заслуги электро.Я сам год сидел на его моде но баг есть баг и не нужно это скрывать.
MARKyxa
сообщение 7.5.2008, 15:47
(/\/\)otoModer
Из: Города грехов
Прошивка: IOS
In progress
DDA-E398,
сырой не сырой, надо иметь уважение к автору, он и так сделал практически невозможное smile.gif
midi
сообщение 25.5.2008, 14:37
Из: Нижний Новгород
Пользователь №: 172 629
Модель телефона: E398 (development)
Прошивка: 49R Blue Classic
Я скачал v0.4alpha4.rar с сайта elektro255
там лежат:
v0.4a4(doc) /я понимаю папка с документацией/
LDR.bin
update.bin
UPDATER.exe
Мне этого достаточно для апдейта мода? У меня стоит мод v0.3.
При запуске UPDATER.exe пишется "v0.4 alpha 3 update (update only E398 phones with R373...4xR flex)" (возможно просто опечатка)
И внизу надпись Disconnected
На нажатие Update пишет Телефон не подсоединен.
Как правильно обновиться?
П.С. Сильно не бейте если написал не туда.
Сообщение отредактировал midi - 25.5.2008, 14:38
r.o.m.a.N
сообщение 25.5.2008, 15:23
Motoroma
Пользователь №: 95 283
Прошивка: 49R 4.4.4
midi,
Другим софтом переведи тел в p2k режим, потом запускай UPDATER.exe и шей
midi
сообщение 25.5.2008, 15:43
Из: Нижний Новгород
Цитата(r.o.m.a.N @ 25.5.2008, 19:23) *
midi,
Запускаю P2K Tools 3.0.8.864
Выбираю P2K режим...
Статус - P2K Connected
Если этого достаточно, то UPDATER.exe по прежнему говорит что не подключен. (((
r.o.m.a.N
сообщение 25.5.2008, 16:54
Motoroma
Прошивка: 49R 4.4.4
Тогда попробуй тел во флеше подключить
midi
сообщение 25.5.2008, 17:12
Из: Нижний Новгород
Во флеше изначально подключал - эффекта нет.
Прям даже не знаю... Может программа под Win XP SP3 не хочет работать ph34r.gif
Вроде там выкладывали раньше отдельно CG1 и CG3 группы... может остались у кого?
Я к тому что-бы заменить в Flash&Backup у моей текущей прошивки и прошить все это.
r.o.m.a.N
сообщение 25.5.2008, 20:19
Motoroma
Прошивка: 49R 4.4.4
midi,
Только что проверил, коннектится в п2к режиме (винда сп3) Попробуй дрова заново поставить, предварительно удалив старые
midi
сообщение 25.5.2008, 22:33
Из: Нижний Новгород
r.o.m.a.N,
Спасибо, после танцев с переустановкой драйверов все-таки прошел коннект и все зашилось... Буду тестить )))
П.С. С меня + )))
Сообщение отредактировал midi - 27.5.2008, 13:33
Текстовая версия Сейчас: 23.7.2025, 5:10
