23 страниц V « < 21 22 23
Elektro255 V0.4 alpha 4 mod (4xR), 44R,46R,49R,79R
elektro255
сообщение 23.9.2006, 12:06 Закрепленное сообщение!
Из: Poland, Siedlce
Пользователь №: 53 130
09-04-2007
V0.4a4 Alpha: http://elektro255.ovh.org
08-04-2007
V0.4a3 Alpha: http://elektro255.ovh.org
07-04-2007
V0.4a2 44R Alpha: http://elektro255.ovh.org
20-12-2006
V0.3 79R Final mod: http://elektro255.ovh.org
27-11-2006
v0.3 for 49R Final mod http://elektro255.ovh.org/
26-11-2006
V0.3 46R Final mod: http://elektro255.ovh.org
НА Е1 Rokr с бутом 0А02 (оригинальный) НЕ ПОСТАВИТЕ БЕЗ Т.П.!
V0.4 alpha 4
Changes:
- Fixed problem with display timeout (fullscreen clock) when SMS/CALL received
Features:
- 4xR and 7xR MIX (use with 4xR flex)
- unlimited Video recording
- keypad automatic lock
- low battery alarm can be turned off or depend on ring style.
- Scheduled Ring Styles (ring style and funlight style can change automatically on given time and week day)
- flashlight shortcut (##)
- extra menu (shortcut *1 [shortcut is only for testing later will be changed])
- automatic menu enter, without sim card (emergency calls working too)
- new Java methods
- settings are stored on files
- no simlock checking
- Volume-bar sound can be turned off
- multiple menus (every skin can have one mma_ucp)
- Ported patches:
o SMS report significantly turned ON
o more folders in OBEX via BT
o removed unused folders from TransFlash
o Java have access to system files
o increased iTap user dictionary size
o no delete incall on SIM replace
o Bluetooth time changed to 3 minutes
o reordered camera store menu (store only is first)
o SMS alert is using default ringtone
OLD versions(V0.1-0.3):
Firmware changes:
- firmware based on 46R from StarterXP MP
- FULL SW access from Java
- LUMA&CHROMA tables moved to memory - now you can change JPEG compresion from Java
- StarterXP flex
- added dualboot
Flasher changes:
- if you have PDS_4013 flasher will no recreate this
Personalization tool changes:
- first version for 0.3_46R SW mod
- changing splash screen
- changing font (you can use *.fnt or *.smg CG4 files)
- you can turn on, turn off menu access without sim cart
- changing my shortcuts
Новая версия V0.4 alpha 4
Изменения:
- Устранена проблема с таймаутом дисплея(полноэкранные часы) при приеме смс/звонка
Новое:
- Прошивка создана как микс 4xR и 7xR (флекс 4xR ) В 44R она переименована для совместимости! Она близко не лежит к 44R на самом деле!
- Безлимитная запись видео (64мб макс как в 6х7х)
- Автоблок клавиатуры
- Звук разряженой батареи можно выключать или задать стилем оповещения(?).
- Расписание стилей оповещения (стиль оповещения и фанлайтмогут менятся автоматически по времени и дням недели)
- Фонарик по (##)
- Дополнительное меню (метка *1 [только для теста, после может изменится])
- Автоматический вход в меню без сим-карты (аварийные звонки работают)
- Новые методы в Яве (не от 79R, а новые)
- Настройки хранятся в файлах
- Не проверяется лоченость ПДС на симку (работает с лоченым пдс)
- Звук изменения громкости можно отключить
- Мультименю (каждый скин может иметь собственный мма_уцп)
- Портированы патчи:
o Оповещение о доставке SMS всегда вкл.
o больше папок доступно по OBEX из блютуза
o удалены неиспользуемые папки с флешки
o Полный доступ к системным файлам из явы
o увеличен размер пользовательского словаря iTap
o не удалыются последние вызовы при смене сим
o Время обнаружения блютуза - 3 минуты
o Меню сохранения видеозаписи (просто сохранить - первым пунктом)
o при приходе SMS играет "мелодия на смс", а не установленная на этого пользователя
Для версий 0.1-0.3
Изменения в прошивке:
- Создана на базе монстра StarterXP 46R
- Полный доступ к прошивке (симы, озу) из явы
- Таблицы сжатия фотографий перенесены в озу - теперь из явы можно управлять качеством фотографий (сжатием)
- флекс StarterXP
- добавлен дуалбут
Изменения флешера:
-Если ПДС версии 4013 (373 платформа), ПДС не пересоздается.
Изменения персонализации (Personalization tool):
- впервые для мода использована 46 прошивка
- замена заставки (на включение?)
- замена шрифта (лангпак, CG4)
- можно вкл. и выкл. доступ к меню без сим-карты
- изменен ярлык (копирайт?)
Для работы Personalization tool требуется положить в папку программы несжатый бинарный бэкап (32 мегабайта) под именем SW.bin
Прекращаем флудить, типа а когда выйдет новая версия, и.т.д.и.т.п, или придётся наказывать!
тему почистил, архив по 1 декабря тут:
Прикрепленный файл MotoFan_ru_electro.zip   ( 66.56 килобайт ) Кол-во скачиваний: 3905
Сообщение отредактировал elektro255 - 9.4.2007, 12:21
Garibaldi
сообщение 15.6.2008, 6:04
Из: Оренбург
Пользователь №: 131 311
Модель телефона: E398/Е770v
Прошивка: 49R_EM_ADVANCED/E1P
Цитата(Metalor @ Вчера, 19:44)
Как я понял нельзя заменить строку ареса сайта электро,
да, ее нельзя убрать. Электро сам говорил об этом:
you can change boot splash screen (except website address on bottom)
сообщение 16.8.2008, 7:39
Вы можете отблагодарить автора нажатием кнопки
Samy
сообщение 2.10.2008, 17:26
Из: ZT Coast
Пользователь №: 106 414
Модель телефона: E1 (07D0)
Прошивка: Dar2.x.
Откуда можно скачать V0.3 79R. Ну оч надо! На оф сайте не пашет(
Very Evil D.R.O.N
сообщение 10.2.2009, 8:52
Из: 71/Lost heaven
Пользователь №: 189 573
Модель телефона: HTC EVO 3D
Прошивка: крайний сток)
With HTC Sense =)
Всвязи с окончанием разработки новых модов камрадом elektro255 в мае прошлого года (хотя на самом деле намного раньшэ...) тема ЕМ потеряла свою актуальность...
___ ___ ___ ___ ___ ___ ___ ___ ___ ___ ___
Как платформа ЕМ v4a4 использовалась в нескольких монстрах, таких как , CustomSeries, ELIT 1.0,MOTO UNLiMiTED,Psi Phon v0.2,TurboZ_FE. найти их в иНете сейчаз практически нереально, потому пару из них слил на свой файлобменник, кому интересно - забирайте, ссылки: CustomSeriesPack , ELIT 1.0 .
Баг с ребутом при работе ЖПРС был исправлен камрадом Мачо - сцилко на автопатч непомню, потому прикрепляю в аттаче.
Прикрепленный файл GPRS_ON__elektro255_v0.4alpha4__x46.rar   ( 14.21 килобайт ) Кол-во скачиваний: 190
Список портированных патчей можно увидеть здесь , а собссно взять их отсюда за што отдельное спасибо камраду juiceddddd.
Поддержка эльфов - реализованна.
Патче и Либа v5.6 ELFPack v1.0 for [elektro255 v0.4alpha4] x46 с отключением по 0 и поиском на дисках C и B.
Сообщение отредактировал Very Evil D.R.O.N - 10.2.2009, 9:38
Freser1
сообщение 31.8.2009, 3:57
Пользователь №: 143 815
Модель телефона: E-398
Прошивка: Dar2...
Не пойму почему мод 46r v0.4 забросили, ведъ Мачо исправил баг с интернетом,ведъ многие мечтали на 4_ х иметь безлимитное видео, батарею держит хорошо, если кто хочет сделать монстр заслуживающий внимания должен взять именно этот рефлеш, портировать на него не достающие патчи и будет хоть какая то альтернатива Д.Р. , не в обиду Мачо.
AlexKooper
сообщение 31.8.2009, 5:04
Из: Йошкар-Ола
Пользователь №: 47 140
Прошивка: AlexKooper mod v.47
Freser1, так електромод давну уже повторили патчами, разве что люма-хрома таблицы в озу не перенесли. Да ещё безлимитное видео на 4х пока ен сделал. Но Мачо даже на 79 видео обрезал, так что делаем вывод - далеко ен всем оно надо.
Freser1
сообщение 31.8.2009, 7:54
Прошивка: Dar2...
Ну не знаю, по моему она посимпотичней чем 49 и батарею держит не плохо, лучше чем в Д.Р.
AlexKooper
сообщение 31.8.2009, 9:01
Из: Йошкар-Ола
что эта на базе 4х, что ДАР на базе 4х, 49 в обоих нету. А какая симпатичность может быть у рифлешей? Ума не приложу, графика же вся в дрм да флексах. Буткартинка не считается, её поменять можно (причём в электромоде ещё и копирайт автора требуется оставлять)
Freser1
сообщение 31.8.2009, 11:26
Прошивка: Dar2...
Посимпотичней по функционалу заложенному в неё, чем просто 49 или 42 и батарею держит лучше, во всяком случае у меня.
Metalor
сообщение 21.1.2011, 21:21
Из: Минск <BEL>
Пользователь №: 151 548
Может у кого-нибудь остались ещё файлы?
Залейте в первый пост, пожалуйста, очень нужно - нигде в сети рабочих ссылок не найти.
Извиняюсь, нашёл на e398mod всё сразу.
Сообщение отредактировал Metalor - 21.1.2011, 22:37
JIeXuH
сообщение 9.7.2012, 20:51
Из: Донецк
Пользователь №: 128 387
Прошивка: AGENT 1.1/49r
Где скачать чистую v0.3 for 49R Final mod
yoursit
сообщение 6.4.2013, 7:05
Пользователь №: 241 501
Модель телефона: 80293272796
Текстовая версия Сейчас: 4.9.2025, 22:21
