23 страниц V « < 2 3 4 5 > »
Elektro255 V0.4 alpha 4 mod (4xR), 44R,46R,49R,79R
elektro255
сообщение 23.9.2006, 12:06 Закрепленное сообщение!
Из: Poland, Siedlce
Пользователь №: 53 130
09-04-2007
V0.4a4 Alpha: http://elektro255.ovh.org
08-04-2007
V0.4a3 Alpha: http://elektro255.ovh.org
07-04-2007
V0.4a2 44R Alpha: http://elektro255.ovh.org
20-12-2006
V0.3 79R Final mod: http://elektro255.ovh.org
27-11-2006
v0.3 for 49R Final mod http://elektro255.ovh.org/
26-11-2006
V0.3 46R Final mod: http://elektro255.ovh.org
НА Е1 Rokr с бутом 0А02 (оригинальный) НЕ ПОСТАВИТЕ БЕЗ Т.П.!
V0.4 alpha 4
Changes:
- Fixed problem with display timeout (fullscreen clock) when SMS/CALL received
Features:
- 4xR and 7xR MIX (use with 4xR flex)
- unlimited Video recording
- keypad automatic lock
- low battery alarm can be turned off or depend on ring style.
- Scheduled Ring Styles (ring style and funlight style can change automatically on given time and week day)
- flashlight shortcut (##)
- extra menu (shortcut *1 [shortcut is only for testing later will be changed])
- automatic menu enter, without sim card (emergency calls working too)
- new Java methods
- settings are stored on files
- no simlock checking
- Volume-bar sound can be turned off
- multiple menus (every skin can have one mma_ucp)
- Ported patches:
o SMS report significantly turned ON
o more folders in OBEX via BT
o removed unused folders from TransFlash
o Java have access to system files
o increased iTap user dictionary size
o no delete incall on SIM replace
o Bluetooth time changed to 3 minutes
o reordered camera store menu (store only is first)
o SMS alert is using default ringtone
OLD versions(V0.1-0.3):
Firmware changes:
- firmware based on 46R from StarterXP MP
- FULL SW access from Java
- LUMA&CHROMA tables moved to memory - now you can change JPEG compresion from Java
- StarterXP flex
- added dualboot
Flasher changes:
- if you have PDS_4013 flasher will no recreate this
Personalization tool changes:
- first version for 0.3_46R SW mod
- changing splash screen
- changing font (you can use *.fnt or *.smg CG4 files)
- you can turn on, turn off menu access without sim cart
- changing my shortcuts
Новая версия V0.4 alpha 4
Изменения:
- Устранена проблема с таймаутом дисплея(полноэкранные часы) при приеме смс/звонка
Новое:
- Прошивка создана как микс 4xR и 7xR (флекс 4xR ) В 44R она переименована для совместимости! Она близко не лежит к 44R на самом деле!
- Безлимитная запись видео (64мб макс как в 6х7х)
- Автоблок клавиатуры
- Звук разряженой батареи можно выключать или задать стилем оповещения(?).
- Расписание стилей оповещения (стиль оповещения и фанлайтмогут менятся автоматически по времени и дням недели)
- Фонарик по (##)
- Дополнительное меню (метка *1 [только для теста, после может изменится])
- Автоматический вход в меню без сим-карты (аварийные звонки работают)
- Новые методы в Яве (не от 79R, а новые)
- Настройки хранятся в файлах
- Не проверяется лоченость ПДС на симку (работает с лоченым пдс)
- Звук изменения громкости можно отключить
- Мультименю (каждый скин может иметь собственный мма_уцп)
- Портированы патчи:
o Оповещение о доставке SMS всегда вкл.
o больше папок доступно по OBEX из блютуза
o удалены неиспользуемые папки с флешки
o Полный доступ к системным файлам из явы
o увеличен размер пользовательского словаря iTap
o не удалыются последние вызовы при смене сим
o Время обнаружения блютуза - 3 минуты
o Меню сохранения видеозаписи (просто сохранить - первым пунктом)
o при приходе SMS играет "мелодия на смс", а не установленная на этого пользователя
Для версий 0.1-0.3
Изменения в прошивке:
- Создана на базе монстра StarterXP 46R
- Полный доступ к прошивке (симы, озу) из явы
- Таблицы сжатия фотографий перенесены в озу - теперь из явы можно управлять качеством фотографий (сжатием)
- флекс StarterXP
- добавлен дуалбут
Изменения флешера:
-Если ПДС версии 4013 (373 платформа), ПДС не пересоздается.
Изменения персонализации (Personalization tool):
- впервые для мода использована 46 прошивка
- замена заставки (на включение?)
- замена шрифта (лангпак, CG4)
- можно вкл. и выкл. доступ к меню без сим-карты
- изменен ярлык (копирайт?)
Для работы Personalization tool требуется положить в папку программы несжатый бинарный бэкап (32 мегабайта) под именем SW.bin
Прекращаем флудить, типа а когда выйдет новая версия, и.т.д.и.т.п, или придётся наказывать!
тему почистил, архив по 1 декабря тут:
Прикрепленный файл MotoFan_ru_electro.zip   ( 66.56 килобайт ) Кол-во скачиваний: 3902
Сообщение отредактировал elektro255 - 9.4.2007, 12:21
Fizmat-Ramzes
сообщение 30.11.2006, 14:01
Из: Майкоп Республика Адыгея
Пользователь №: 86 578
Прошивка: By Elektro255
че-то я не понял, как пользоваться этой явой. Захожу в Jpeg_tables, уровень компрессии стоит на Best, переставляю, нажимаю ОК и прога выключается, разницы в размере фото нет, что до, что после этой процедуры. Объясните, может я что не то делаю?
off_topic; как вернуть на кнопку фотокамеры саму фотокамеру, Р2к menu editor не помогает, там нельзя назначить фотокамеру.
p00p0k
сообщение 30.11.2006, 15:33
Пользователь №: 95 690
Прошивка: electro255
Ovip,
0032_001 вот тебе правленный сим, без всяких ик-портов и т.п.
Залей и все!
А вот прога:
Прикрепленный файл Personalize.rar   ( 334.37 килобайт ) Кол-во скачиваний: 219
StrIk3r,
Последняя фотография симпатичная =)
Это фотки с мотора или нет? что то слишком хорошее качество! Я такого давно не видал! Мало верится что это E398 фотки!
И что мне делать? Какие таблицы? И че с этими таблицами делать? Объясни по порядку и выложи все что надо!
Raziel_sh
сообщение 30.11.2006, 16:46
Пользователь №: 37 511
Модель телефона: Em30, Defy +
я сам 0.3 beta не ставил,но интересно,может кто-нибудь сказать зачем elektro255 тогда вообще делал что-то , для того чтобы менять качество фото,если как я понял на наил. настройках фотки получаются такими же допустим как у меня сейчас на 0.2 beta,(т.е. макс. размер у меня сейчас где-то 75 kb,это когда всё хорошо освещенно и много объектов).Вот если бы при максимальном качестве фотки сохранялись с наименьшим сжатием , тогда было бы понятно,а так получается что только уменьшать можно,как я понял :)
ммм...понял из следующего поста,что надо просто найти ограничение снимка и всё будет офигенно clap;applo
Сообщение отредактировал Raziel_sh - 30.11.2006, 17:17
StrIk3r
сообщение 30.11.2006, 16:50
Из: Великий Новгород
Пользователь №: 53 936
Модель телефона: E398@ROKR_E1_iTunes
Прошивка: R373...49R
И так давайте прежде чам разбирать качество фотоснимков
выясним у кого какая камера
Вот инструкция написанная KQ_44
Рабочий инструмент:
RadioComm v9 (4.4 Mb)
требует: Microsoft’s .NET Framework v1.1 (23 Mb).
1. Для начала ну просто НЕОБХОДИМО узнать тип своей камеры:
Запусткаете RadioComm, подключаете тело.
В теле запускаете видоискатель для инициализации железа.
На вкладке GSM 3, внизу слева область - TST_CAMERA.
В списке выбираете "Camera Detect" и жмете кнопку "Set".
В поле "Response" - название в 16-ричном виде.
Например у меня 4D4943524F4E20534F433336302038323361
т.е. MICRON SOC360 823a
2. Далее необходимо знать по каким адресам лежат таблицы квантования:
Всего таких таблиц в прошивке (CG1 - первая кодовая группа) 5 пар, т.е. 10 штук, но как я понял electro255 использует
только 1 пару таблиц (JPEGPC_LUMA_QTABLE и JPEGPC_CHROMA_QTABLE)
Начальные адреса этих таблиц в 49R:
00A05AAA - LUMA_QTABLE
00A05AEA - CHROMA_QTABLE
Найти их можно так:
Открыть любой hex editor и воспользоваться поиском по офсету
Идут эти таблицы друг за другом
Выделенные значения - это те значения которые нам предстоит изменять.
3. Изменение таблиц:
Теперь когда мы знаем где находятся таблицы мы можем их изменять
Смело идем по ссылке http://www.impulseadventure.com/photo/jpeg...on.html?src1=77
и выбираем понравившиеся таблицы, но нужно учесть что числа в таблицы записаны не в том порядке
как хотелось бы.
Существует определенный алгоритм:
чтобы вписать числа из готовой таблицы в нашу необходимо
переписывать их двигаясь по красной кривой линии из левого верхнего угла
в правый нижний, причем числа в нашу таблицу нужно вписывать в hex, т.е.
7=07
10=0А
15=0F
23=17 и т.д.
4. Создание патча:
Создаем патч при помощи любого текстового редактора при сохранении подписав расширение *.FPA
[Patch_Code]
00A05AAA:******
00A05AEA:******
Где ******** это ваши 64 байта (64*2=128) т.е. необходимо заменить 128 байт в CG1.SMG.
После этого прошиваетесь этим патчем.
Как ставить патчи объеснять не буду, сами разберетесь
Вся проблема в локе на размер получаемого фотоснимка ~80kb, возможно этот размер задан в симах а возможно и в прошивке так что остается копать копать и еще раз копать.
StrIk3r
сообщение 30.11.2006, 19:22
p00p0k,
AGILENT ADCM2700 62
StrIk3r
сообщение 30.11.2006, 19:42
Цитата(p00p0k @ Четверг, 30 Ноября 2006, 22:26)
StrIk3r,
А как ты узнал? Лучше бы ты объяснил во избежании будущего флуда,
Все равно спасибо тебе!
Создай новый фаил в хекс редакторе и запиши эти цифры, в текстовом поле увидишь результат
Fizmat-Ramzes
сообщение 30.11.2006, 20:18
StrIk3r,
У меня камера на теле, как на твоем, можешь выложить готовый patch?
Ovip
сообщение 1.12.2006, 10:38
Пользователь №: 85 143
Модель телефона: e790
Прошивка: 48 ща 49 щью =)
Цитата(StrIk3r @ Четверг, 30 Ноября 2006, 20:50)
Рабочий инструмент:
т.е. чтобы узнать какая у тебя камера надо скачать 28 мб??? А подешевле никак???
Microsoft’s .NET Framework v1.1 можно найти на диске с дистрибутивом Windows XP, в папке DOTNETFX. И пригодится он не только для радиокомма, а для многих новых прог, которые написаны с использованием этой .NET технологии.Достаточно набрать в яндексе "требуется установленный NET Framework ". Кроме того, можно скачать более раннюю версию радиокомма, которая нет.фреймворк не требует
Сообщение отредактировал AlexKooper - 1.12.2006, 11:00
A.06
сообщение 1.12.2006, 12:22
Пользователь №: 60 599
Модель телефона: e398 white
Прошивка: r373_g_oe.30.48r
elektro255, could you make a patch which will play next song after playing previous in standard player ?
_TRANE_
сообщение 1.12.2006, 12:34
MOTOmeloMAN
Из: New_Oskol_City(Бел.Область)
Пользователь №: 104 202
Модель телефона: E398+KOSS The PLUG
Прошивка: MPX 398 DeLuXe
Пипл,Ахтунг.
У меня ща стоит STM RELOAD(48r), но я очень сильно
хочу Rokr E1 Sw Modfore398 By Elektro255 V0.3 (49r).
Я собираюсь качать ФулФлэш, пидскажите пожалуйста
что надо сделать перед прошивкой (Шить CG1
,CG3 или не надо и др.) и как ваще выглядет эта проша
Это монстерПАК или нет? Ах да чуть не забыл там есть русский
язык или нет и если нет то как и какой его вшить?
ЗЫ:+ ГАРАНТИРУЮ!!!
clap;applo clap;applo clap;applo
StrIk3r
сообщение 1.12.2006, 12:45
Цитата(p00p0k @ Пятница, 1 Декабря 2006, 15:31)
StrIk3r,
А твои патчи пойдут на мою камеру?
Если нет сможешь ли ты слепить мне хороший патч?
Поистечении 29 дней верну должок!
Да конечно подойдут
только не забывай бекапить сг1, название камеры мне нужно что бы сравнить качество фоток
когда пропатчишься выложи парочку фоток
OzMorderer
сообщение 1.12.2006, 12:59
Из: Рязань
Пользователь №: 97 363
Прошивка: mpx398
Может ктонибудь выложить прошивку с ленгом, патчами, и всякими фишками? Плиз!!!
Bent
сообщение 1.12.2006, 13:23
MoTo Marvellous
Пользователь №: 63 874
StrIk3r, хочу что бы ты ответил лично...
В общем так ставил я FullFlash--потом ставил патч от electro255(самый последний,безглючный)--качество было хорошее фоток---далее я поставил твой патч(камера у меня такая же как и у тебя проверил в радиокоме)---поставил ява-приложение от electro255(сжатие фоток) стояло там у меня качество BEST(сколько бы не пытался изменить на 4 или 10-всё по боку не меняет) и фотки стали стрёмные...по другому и не скажешь кубики,пиксели и всё в этом роде...написал я в строгой последовательности как и делал.
Сейчас я залил стандартную CG1(ещё присутствует косяк с фото когда сохраняешь),так вот вопрос:В какой последовательности мне патчить её,и чем?Какими патчами или патчем?Нужно ли ставить ява-приложение от electro255?
Заранее благодарю за ответ.В идеале у нас должны быть одинаковые фото по качеству(конечно это зависит от некоторых факторов но всё таки...)
p00p0k
Всмылсе? Как сравнить? По названию?
Нет конечно.Он имеет ввиду сравнить как снимают разные камеры,вот у тебя такая то камера,а у меня другая вот и сравнить как они снимают,так сказать какая лучше.Ну и по названию то же у каждой камеры разное название :)
Ovip
сообщение 1.12.2006, 13:41
StrIk3r,
спасибо за патчи! запатчил второй - честно никакой разницы :( точнее минимальная и то не уверен что из-за патча (фотки думаю нету смысла выкладывать)
вопрос: Стоит ли прошиться вторым?
и еще: ЧО ЗА ПУНКТ В СМС "НОВОЕ ПИСЬМО"??? ОН МЕНЯ БЕСИТ ЧО-ТО angry.gif КАК УБРАТЬ, ПЛЗ, И СТОИТ ЛИ??? А ТО МАЛО ЛИ...(МОЖЕТ ИЗ НЕГО БЕСПЛАТНО ОТПРАВЛЯЮТСЯ-ШУЧУ КОНЕШ, НО ВСЕ ЖЕ) :)
StrIk3r
сообщение 1.12.2006, 14:36
Bent,
По поводу патча для фото:
Патч содержит в себе данные таблиц квантования, применив патч ты тем самым изменяешь свои стандартные таблицы! После патча это так сказать ОРИГИНАЛ, однако после того как ты воспользуешься приложением от elektro255 использоваться будут совершенно другие таблицы, данные которых будут находиться в RAM, ОРИГИНАЛ ты сможешь вернуть только перезагрузкой тела, или добавь в ява класс свои настроики и скомпилируй в приложение!
Я разговривал с elektro255 он сказал что примерно через неделю обновит приложение с возможность использования своих таблиц которые будут краниться на карте памяти! Как только он это сделает я выложу таблицу что бы можно было делать черно-белые фотографии.
И все же StrIk3r, я очень ценю твои труды но не мог бы ты всетёки слепить мне патчик?
Патч предназначен для всех, ничего страшного не будет если ты прошьешься им, но я хочу посмотреть какие будут фотографии полученные с разных камер, будут ли это глобальные изменения или же незаметные!
И Какой же лучше ставить патч? 1-ый или 2-ой?
Ставить рекомендую второй
P.S. Торопился, так что извините если не ответил на чей нибудь вопрос!
Unlimit
сообщение 1.12.2006, 15:01
Пользователь №: 93 764
Модель телефона: Nokia N73
Прошивка: Symbian OS v9.1
StrIk3r, После прошивки фулфлешеи по верх 0.2v фотки были по 60кб, но были какимито фиолетовыми (как и у всех по моему), после применения вот этого патча,
[Patch_Info]
Description=change LUMA
offset
Author=elektro255
Version=1.0
[Patch_Code]
B9D7F8:127E5040
фотки стали очень хорошего качества по 70кб. Поссле некоторых манипуляций с пошивкой, пришлось откатится на 0.2v, после повторной прошивки и установки патча фотки стали чётнобелыми по 10кб (цветные фоткаются при очень хорошем освещении и то через раз). Как это объяснить?
Камера у меня AGILENT ADCM2700 61
Сообщение отредактировал Unlimit - 1.12.2006, 15:02
StrIk3r
сообщение 1.12.2006, 15:11
Unlimit,
воспользуйся вот этим патчем
p00p0k
UNSORTED_FOTOPATCH.zip
p00p0k
сообщение 1.12.2006, 15:34
StrIk3r
UNSORTED_FOTOPATCH.zip этим патчить или canon_digital_ixus_800_is__superfine_.zip
Я ника немогу понять!
Спасибо за разъяснение!
Сообщение отредактировал p00p0k - 1.12.2006, 15:48
Bent
сообщение 1.12.2006, 16:53
MoTo Marvellous
Добавил на наш сайт RadioComm v.9.2.3 Качаем с Родного Мотофана :)
Сообщение отредактировал Bent - 4.12.2006, 14:51
Raziel_sh
сообщение 1.12.2006, 18:35
p00p0k,
=\ Мда-а-а! Даже сказать нечего... Каково ваше мнение? Я в шоке....
посмотрел все 4 фотки c левой стороны , и честно кроме разного размера особого улучшения качества не заметил.
off_topic;
и ты кстати перепутал подпись "правая" с "левая" ..надо вездё наоборот :)
Алекс75
сообщение 1.12.2006, 21:02
Мото-реаниматор
Пользователь №: 30 882
Модель телефона: XT502
Прошивка: Android 2.2
StrIk3r,
Самый прикол в том что Radiocomm 9.1.1 не определяет тип моей камеры)))
В нехе NOT DETECTED :)
Значит только методом тыка?
P.S.Кто знает какая камера используется на оригинальном Е1???Или какой софтиной это можно определить?А то как то даже не задавался вопросом по этому поводу)))
Сообщение отредактировал Алекс75 - 1.12.2006, 21:05
Алекс75
сообщение 1.12.2006, 22:36
Мото-реаниматор
AndreyD,
а какая разница какая камера ? если патчи ставятся на любую ...
Метод русского тыка конечно хорошо,но использовать именно те параметры которые подходят именно для этой камеры значительно сэкономит время)
Bent,Выложи плиз еще раз Personalize для 49R :)
optima
сообщение 2.12.2006, 0:30
Пользователь №: 16 563
Прошивка: 82R;wm6,5;4BR
Алекс на
Прикрепленный файл Personalize49.rar   ( 334.37 килобайт ) Кол-во скачиваний: 335
Crestopher
сообщение 2.12.2006, 2:30
Пользователь №: 68 705
Модель телефона: E1
Короче ребят, пока вес фоток не увеличится в 2-3 раза, сравнивать качество нечего! Всё это фуфло. Увеличивайте лимит в ~80kb, а там уже можно будет и квантами баловаться. А пока от того что вы сейчас по 100 раз перепатчиваете толку столько же, сколько от шамана бьющего в бубен. zootaz; И нечего флуд разводить.
Bent
сообщение 2.12.2006, 2:58
MoTo Marvellous
Алекс75,
Быть может стоит попробовать Radiocomm 9.0.0?Шанс конечно не велик но всё таки.
optima выложил прогу :) Качай.
Мне кажется на Rokr так же как и на е398 телефон один,а камеры разные.
N E O 78
сообщение 2.12.2006, 6:39
Из: Запорожье
Пользователь №: 97 977
Модель телефона: Atrix 4g
А можно ли прошить этот MP если у меня 30.46 и не модифицированый E1 (ТП не делал)?
sasha.z.666
сообщение 2.12.2006, 8:46
Из: Северобайкальск, Бурятия
Пользователь №: 70 914
Прошивка: 373_g_0e.30.79r
N E O 78, нет. Нельзя. Убьешь тело. Делай ТП и ставь. А вообще юзай поиск в следующий раз.
andrikus
сообщение 2.12.2006, 9:00
Пользователь №: 53 840
Прошивка: 1ER
Подскажите, пожалуста, каким DRM можно шиться (у меня стоит V0.3 46r), а то обычная графика немного напрягает?? :)
Алекс75
сообщение 2.12.2006, 9:14
Мото-реаниматор
andrikus,
Можешь смело шить любой дрм 42-49 думаю и дрм для 6FR и выше тоже прокатит(я шил на 48R дрм с монстра на 6FR все было ок),но во избежании проблем советую лучше все таки шить любой дрм для 42-49
Удачи
optima
сообщение 2.12.2006, 9:41
Цитата(Bent @ Суббота, 2 Декабря 2006, 2:58)
Алекс75,
Я определял Radiocomm 9.2.3, просто надо включить камеру.
Bent
сообщение 2.12.2006, 10:55
MoTo Marvellous
Собственно вот две фотки одна сделана с пачем от electro255 а другая патчем от StrIk3r (UNSORTED_FOTOPATCH)
Фотки не чем практически не отличаются,только весом немного и всё(разница в 6 килобайт)...я ожидал большего эффекта.
_TRANE_
сообщение 2.12.2006, 11:34
MOTOmeloMAN
p00p0k, Сэнкс за обьяснение теперь подскажи какой патч для камеры лучше поставить? drink_drunks;
слыште парни а откуда мона скачать FULLFLASH electro255 SW mod 03b (49r) а то с его офиц. сайта чёто не качает? blink.gif
juicedddd
сообщение 2.12.2006, 11:42
Из: Сыктывкар
Пользователь №: 77 458
Модель телефона: ~E398~
Прошивка: Dream a reality_79R
Обьясните пожалуйста чем 0.3 отличается от 0.2, кроме того что можно менять степень сжатия из ява ???
Есть ли какие нибудь другие значимые изменения ???
Bent
сообщение 2.12.2006, 12:02
MoTo Marvellous
juicedddd, Вверху же написали...это наверно главное отличие,в v.0.2 так не сделаешь(кроме бутсплеша его можно заменить но нудно)...я пытался :)
Ну и от себя добавлю что скорость отличная,прошивка стабильна-ни одного перезагруза,немного попарится с фото и будет всё в шоколаде,плюс сжатие фоток.
Вот собственно и всё.
_TRANE_,
слыште парни
Нормальным языком выражайся.Не в подъезде стоишь.
На данный момент этот лучший UNSORTED_FOTOPATCH by StrIk3r
_TRANE_
сообщение 2.12.2006, 12:14
MOTOmeloMAN
Bent, извини, ну а всё таки откуда мона скачать FULLFLASH electro255 SW mod 03b (49r) а то с его офиц. сайта чёто не качает?
AndreyD
сообщение 2.12.2006, 14:23
Пользователь №: 80 023
Прошивка: 49R
Bent, т.е. сначала fix от электро, а потом UNSORTED_FOTOPATCH by StrIk3r? или сразу после прошивки UNSORTED?
Bent
сообщение 2.12.2006, 14:36
MoTo Marvellous
AndreyD, сначала FIX потом UNSORTED.И программу для сжатия от electro255 не ставь-иначе такая фигня будет с фотками...качество будет плохое - почему? StrIk3r объяснил на страницах раньше :)
Frensis
сообщение 2.12.2006, 15:32
Пользователь №: 99 380
Прошивка: MotoWalkman49R
Я так скажу, парни!То что скорость значительно (!) выше это да, большущий +!Хочу заметить что видео при просмотре не тормозит, что оч приятно. clap;applo elektro,тебе респект very big!И всем остальным кто приложил усилия lol.gif lol.gif
ReLeFNIQ
сообщение 2.12.2006, 18:47
Пользователь №: 70 179
Модель телефона: Motorola e398(E1)
Прошивка: R373_G_OE.30.48R
А скажите как исправитъ чтоб Когда у меня присляют файлики по блутуут у меня сохраняет сразу в памяти телефона!!!Как изправитъ ето?I can't chose where to save files comming from bluetooh, i can't choose in TransFlash..>And also when I install games It doesn't ask me where to save the game..Срочно надо как изправитъ ето и возможно ли....СПАСИБО!!
Sanyok_
сообщение 2.12.2006, 19:15
MotoTeam
Из: Кременчуг Украина
Пользователь №: 48 061
Прошивка: пока 13 ведро :)
ReLeFNIQ, вот так Самые Известные Проблемы И Их Решение (#362976)
Текстовая версия Сейчас: 1.8.2025, 9:02
