Elektro255 V0.4 alpha 4 mod (4xR), 44R,46R,49R,79R
elektro255
сообщение 23.9.2006, 12:06
Из: Poland, Siedlce
Пользователь №: 53 130
Прошивка: elektro255 :)
09-04-2007
V0.4a4 Alpha: http://elektro255.ovh.org
08-04-2007
V0.4a3 Alpha: http://elektro255.ovh.org
07-04-2007
V0.4a2 44R Alpha: http://elektro255.ovh.org
20-12-2006
V0.3 79R Final mod: http://elektro255.ovh.org
27-11-2006
v0.3 for 49R Final mod http://elektro255.ovh.org/
26-11-2006
V0.3 46R Final mod: http://elektro255.ovh.org
НА Е1 Rokr с бутом 0А02 (оригинальный) НЕ ПОСТАВИТЕ БЕЗ Т.П.!
V0.4 alpha 4
Changes:
- Fixed problem with display timeout (fullscreen clock) when SMS/CALL received
Features:
- 4xR and 7xR MIX (use with 4xR flex)
- unlimited Video recording
- keypad automatic lock
- low battery alarm can be turned off or depend on ring style.
- Scheduled Ring Styles (ring style and funlight style can change automatically on given time and week day)
- flashlight shortcut (##)
- extra menu (shortcut *1 [shortcut is only for testing later will be changed])
- automatic menu enter, without sim card (emergency calls working too)
- new Java methods
- settings are stored on files
- no simlock checking
- Volume-bar sound can be turned off
- multiple menus (every skin can have one mma_ucp)
- Ported patches:
o SMS report significantly turned ON
o more folders in OBEX via BT
o removed unused folders from TransFlash
o Java have access to system files
o increased iTap user dictionary size
o no delete incall on SIM replace
o Bluetooth time changed to 3 minutes
o reordered camera store menu (store only is first)
o SMS alert is using default ringtone
OLD versions(V0.1-0.3):
Firmware changes:
- firmware based on 46R from StarterXP MP
- FULL SW access from Java
- LUMA&CHROMA tables moved to memory - now you can change JPEG compresion from Java
- StarterXP flex
- added dualboot
Flasher changes:
- if you have PDS_4013 flasher will no recreate this
Personalization tool changes:
- first version for 0.3_46R SW mod
- changing splash screen
- changing font (you can use *.fnt or *.smg CG4 files)
- you can turn on, turn off menu access without sim cart
- changing my shortcuts
Новая версия V0.4 alpha 4
Изменения:
- Устранена проблема с таймаутом дисплея(полноэкранные часы) при приеме смс/звонка
Новое:
- Прошивка создана как микс 4xR и 7xR (флекс 4xR ) В 44R она переименована для совместимости! Она близко не лежит к 44R на самом деле!
- Безлимитная запись видео (64мб макс как в 6х7х)
- Автоблок клавиатуры
- Звук разряженой батареи можно выключать или задать стилем оповещения(?).
- Расписание стилей оповещения (стиль оповещения и фанлайтмогут менятся автоматически по времени и дням недели)
- Фонарик по (##)
- Дополнительное меню (метка *1 [только для теста, после может изменится])
- Автоматический вход в меню без сим-карты (аварийные звонки работают)
- Новые методы в Яве (не от 79R, а новые)
- Настройки хранятся в файлах
- Не проверяется лоченость ПДС на симку (работает с лоченым пдс)
- Звук изменения громкости можно отключить
- Мультименю (каждый скин может иметь собственный мма_уцп)
- Портированы патчи:
o Оповещение о доставке SMS всегда вкл.
o больше папок доступно по OBEX из блютуза
o удалены неиспользуемые папки с флешки
o Полный доступ к системным файлам из явы
o увеличен размер пользовательского словаря iTap
o не удалыются последние вызовы при смене сим
o Время обнаружения блютуза - 3 минуты
o Меню сохранения видеозаписи (просто сохранить - первым пунктом)
o при приходе SMS играет "мелодия на смс", а не установленная на этого пользователя
Для версий 0.1-0.3
Изменения в прошивке:
- Создана на базе монстра StarterXP 46R
- Полный доступ к прошивке (симы, озу) из явы
- Таблицы сжатия фотографий перенесены в озу - теперь из явы можно управлять качеством фотографий (сжатием)
- флекс StarterXP
- добавлен дуалбут
Изменения флешера:
-Если ПДС версии 4013 (373 платформа), ПДС не пересоздается.
Изменения персонализации (Personalization tool):
- впервые для мода использована 46 прошивка
- замена заставки (на включение?)
- замена шрифта (лангпак, CG4)
- можно вкл. и выкл. доступ к меню без сим-карты
- изменен ярлык (копирайт?)
Для работы Personalization tool требуется положить в папку программы несжатый бинарный бэкап (32 мегабайта) под именем SW.bin
Прекращаем флудить, типа а когда выйдет новая версия, и.т.д.и.т.п, или придётся наказывать!
тему почистил, архив по 1 декабря тут:
Прикрепленный файл MotoFan_ru_electro.zip   ( 66.56 килобайт ) Кол-во скачиваний: 3902
Сообщение отредактировал elektro255 - 9.4.2007, 12:21
elektro255   Elektro255 V0.4 alpha 4 mod (4xR)   23.9.2006, 12:06
OzMorderer   Может ктонибудь выложить прошивку с ленгом, патчам...   1.12.2006, 12:59
Bent   StrIk3r, хочу что бы ты ответил лично... В общем т...   1.12.2006, 13:23
Ovip   StrIk3r, спасибо за патчи! запатчил второй - ...   1.12.2006, 13:41
StrIk3r   Bent, По поводу патча для фото: Патч содержит в ...   1.12.2006, 14:36
Unlimit   StrIk3r, После прошивки фулфлешеи по верх 0.2v фот...   1.12.2006, 15:01
StrIk3r   Unlimit, воспользуйся вот этим патчем p00p0k UN...   1.12.2006, 15:11
p00p0k   StrIk3r UNSORTED_FOTOPATCH.zip этим патчить или ca...   1.12.2006, 15:34
Bent   Добавил на наш сайт RadioComm v.9.2.3 Качаем с Ро...   1.12.2006, 16:53
F-ext   sori pf OFF TOP но всё же важно !!! e...   3.12.2006, 14:43
Raziel_sh   p00p0k, посмотрел все 4 фотки c левой стороны , ...   1.12.2006, 18:35
Алекс75   StrIk3r, Самый прикол в том что Radiocomm 9.1.1 не...   1.12.2006, 21:02
Алекс75   AndreyD, Метод русского тыка конечно хорошо,но ис...   1.12.2006, 22:36
optima   Алекс на   2.12.2006, 0:30
Crestopher   Короче ребят, пока вес фоток не увеличится в 2-3 р...   2.12.2006, 2:30
Bent   Алекс75, Быть может стоит попробовать Radiocomm 9...   2.12.2006, 2:58
optima   Я определял Radiocomm 9.2.3, просто надо включить...   2.12.2006, 9:41
N E O 78   А можно ли прошить этот MP если у меня 30.46 и не ...   2.12.2006, 6:39
sasha.z.666   N E O 78, нет. Нельзя. Убьешь тело. Делай ТП и ста...   2.12.2006, 8:46
andrikus   Подскажите, пожалуста, каким DRM можно шиться (у м...   2.12.2006, 9:00
Алекс75   andrikus, Можешь смело шить любой дрм 42-49 думаю...   2.12.2006, 9:14
Bent   Собственно вот две фотки одна сделана с пачем от e...   2.12.2006, 10:55
_TRANE_   p00p0k, Сэнкс за обьяснение теперь подскажи какой ...   2.12.2006, 11:34
juicedddd   Обьясните пожалуйста чем 0.3 отличается от 0.2, кр...   2.12.2006, 11:42
Bent   juicedddd, Вверху же написали...это наверно главно...   2.12.2006, 12:02
_TRANE_   Bent, извини, ну а всё таки откуда мона скачать F...   2.12.2006, 12:14
AndreyD   Bent, т.е. сначала fix от электро, а потом UNSORTE...   2.12.2006, 14:23
Bent   AndreyD, сначала FIX потом UNSORTED.И программу дл...   2.12.2006, 14:36
Frensis   Я так скажу, парни!То что скорость значительно...   2.12.2006, 15:32
ReLeFNIQ   А скажите как исправитъ чтоб Когда у меня присляют...   2.12.2006, 18:47
Sanyok_   ReLeFNIQ, вот так Самые Известные Проблемы И Их Ре...   2.12.2006, 19:15
BackgaMan   Посмотри эту тему Прием Всех Файлов   2.12.2006, 19:18
ReLeFNIQ   Спасибо но скажи пожалуйста где ето точно описано...   2.12.2006, 19:32
Nogay   StrIk3r, нужно ли устанавливать ява-прогу после тв...   2.12.2006, 20:04
StrIk3r   Nogay, как хочешь !   2.12.2006, 20:21
Nogay   StrIk3r, ну ты посоветуй. Качество фотки будет луч...   2.12.2006, 20:47
AndreyD   прога эта ни какой роли не играет........ пока.....   2.12.2006, 20:51
Umka85   Вот Frozen выложил Рефлеш + патч, для тех, у кого ...   2.12.2006, 23:20
Bent   ReLeFNIQ, пожалуйста тебе конкретика: Для включени...   3.12.2006, 3:18
Niko_First   Выложите пожалуйста фулфлеш 49r v0.3, с офсайта не...   3.12.2006, 5:34
p00p0k   Вкладываю на райпидшару и на вебфайл! Жди...   3.12.2006, 6:57
Ovip   http://www.webfile.ru/1219134 вот держи на webfil...   3.12.2006, 7:13
p00p0k   А вот теперь пришло время всех шокировать! Во...   3.12.2006, 7:19
Bent   p00p0k, Ну и что?У меня такое же хорошее качество....   3.12.2006, 8:13
Алекс75   Народ...опрос на засыпку(просто уже упарился переб...   3.12.2006, 9:20
Ratmagor   Алекс75, Ася поменяла протокол и старые jimm...   3.12.2006, 12:16
p00p0k   Алекс75, У меня всё прекрасно работает! Приче...   3.12.2006, 13:45
Bkmzv3   на этом монстре:меню->служебное->Instant Mas...   3.12.2006, 16:09
~Gangs2er~   ToAll: для тех кто ещё не знает, я сделал нескольк...   3.12.2006, 17:45
Сергей_Motofan   Люди. Тут такая проблема. Я постоянно слежу за мал...   3.12.2006, 17:56
pes_voiny   2 all: Почему при запуске программы Personalize вы...   3.12.2006, 18:34
p00p0k   Было где то на страницах упомянуто, что работать ...   3.12.2006, 19:07
Nogay   Не только iTunes. Можно ещё пользоваться ява-играм...   3.12.2006, 19:12
juicedddd   Мануал по созданию патч для смены Bootscreen в про...   3.12.2006, 20:22
Bent   F-ext, Благодарю за твою бдительность.Файл был ...   4.12.2006, 5:42
EXmaloy   А как ставить эту прошивку. Там прилагается Fleshe...   4.12.2006, 6:53
Doktor Кот   Всем привет! Кто нибудь может пожалуйста вылож...   4.12.2006, 7:03
HUNTER_ok   Doktor Кот, Уже выкладывали! Тему почитай. Вот...   4.12.2006, 7:18
juicedddd   EXmaloy, можно поставить с помощью FlashBackup, я...   4.12.2006, 7:26
EXmaloy   Я пробовал поставить Флэш бэкапом, он на стирании ...   4.12.2006, 7:28
HUNTER_ok   EXmaloy, Стирание памяти идёт около пяти минут.   4.12.2006, 7:36
EXmaloy   Ой перепутал, у меня ничем не получается прошить, ...   4.12.2006, 7:58
Doktor Кот   Hunter_ok, нигде не могу найти! А рефлеш на 49...   4.12.2006, 8:39
juicedddd   EXmaloy, В FlashBackup 2.62 есть вкладка "со...   4.12.2006, 9:25
EXmaloy   Понял, спасибо!   4.12.2006, 9:34
Jordon   ПОдскажите какой сим надо править чтобы получая ja...   4.12.2006, 10:28
Trentemoller   Jordon, В p2kTools 0.8.6 зайди other features...   4.12.2006, 13:25
Jordon   это не мне надо- парень просил ему посмотреть- мне...   4.12.2006, 13:45
ATeapot   Прошился 3-й версией, все радует кроме голосовых м...   4.12.2006, 18:20
human83   Во встроенном hex-редакторе (в P2KTools) считыва...   4.12.2006, 20:48
Bkmzv3   Люди , ответьте пожалуйста на 294 пост <_<   4.12.2006, 18:22
Chili89   Пробовал ставить два патча для камеры.Не один не п...   4.12.2006, 20:07
pes_voiny   2 all: Почему у меня не работает фонарик по ## ???...   5.12.2006, 8:30
ATeapot   human83 огромное спасибо за такой исчерпывающий от...   5.12.2006, 11:32
igorrius   Включение/Выключение звука разряженной батареи Дл...   5.12.2006, 13:48
Trentemoller   igorrius, Этот оффсет надо искать через p2kSeem, ...   5.12.2006, 21:08
igorrius   Есть у меня такая. Я не знаю, как в ней искать...   6.12.2006, 4:59
AlexKooper   igorrius, посмотри проблемы и решения, я там в как...   6.12.2006, 6:06
pes_voiny   Ответьте плиз на мой 185-й пост???   6.12.2006, 6:38
Bent   pes_voiny, У всех работает,а у тебя нет...соответс...   6.12.2006, 7:18
Doktor Кот   Привет, народ! Я уже второй раз буду просить п...   6.12.2006, 12:47
StrIk3r   Doktor Кот, а зачем тебе этот флекс? Прошив флекс ...   6.12.2006, 13:58
_TRANE_   Поставил я эту прошу, уже хожу 4 дня всё норма. То...   6.12.2006, 14:20
AndreyD   а 49-ый рефлеш можно заливать на 46R ?   6.12.2006, 15:01
Trentemoller   AndreyD, Можно, только предварительно сделай бэка...   6.12.2006, 15:24
ATeapot   Помогите пожалуйста. Поставил 3-ю версию ивозникла...   6.12.2006, 15:57
_TRANE_   ATeapot, на патч поставь и радуйся!   6.12.2006, 15:59
ATeapot   _TRANE_ огромное спасибо счас попробую. А чем его ...   6.12.2006, 16:01
BackgaMan   FlashBackup   6.12.2006, 16:23
_TRANE_   Help!!! Please!!! :( :( ...   6.12.2006, 16:47
Nogay   Выложите кто-нибудь Flasher. :)   6.12.2006, 18:09
BackgaMan   RE: Elektro255 V0.4 alpha 4 mod (4xR)   6.12.2006, 19:11
Nogay   BackgaMan, спасибо :). Ты не знаешь каким ФБ желат...   6.12.2006, 19:20
_TRANE_   Nogay, вообще тот который я выложил elektro255 сов...   6.12.2006, 19:29
Nogay   BackgaMan, при открытии Flashera выходит ошибка. М...   6.12.2006, 19:49
Trentemoller   _TRANE_, Это все делается через p2ktools 0.8.6. С...   6.12.2006, 20:57
Мачо   Проблема . Телефон расрывает GPRS сессию при прос...   7.12.2006, 9:14
dynamite   Стоял MotoWalkman49R_EM_by_Maxval_&_LexusRX400...   7.12.2006, 12:37
9 страниц V < 1 2 3 4 > »
Текстовая версия Сейчас: 19.7.2025, 7:28
