Activate Edge On R479 (v3i To V3ie Conversion)
ArcherIV
сообщение 20.1.2007, 13:37
Пользователь №: 117 990
Модель телефона: RAZR V3i @ V3ie
Прошивка: 12345
This is really easy to follow. This great, great discovery was achieved by alfun9
There are very few steps, all of them are very easy to follow.
Remember that this firmware is only to be installed in the Motorola RAZR V3i non iTunes (R479) if your V3i has iTunes (R47A) you will kill your phone.
1) First, reflash your phone with this firmware: R4441D_G_08.01.03R (http://www.mfteam.eu/firmware/v3i/Reflash/R4441D_G_08.01.03R_reflash_mlp_mdrm_DC.rar)
Dont worry about using this one, i and many others ahve used it in our V3i R479 and everythings OK.
Avoid using another verson of this firmware series (R4441D_G_08.02.03R) because it wont let you reflash any other firmware version to your phone. The version im linking you to has no restrictions. However, thi firmware rocks. It's stable, reasonable fast...
2) Then, backup everything in your phone: pictures, tones, videos, phonebooks, SEEMs, etc EXCEPT SEEM 0032_0001. If you do it, you'll lose the EDGE drive and you'll have to do it all over again.
3) Flex your phone with this China Mobile branded flex: GSVSLQAET678HB054_DC (http://rapidshare.com/files/11777297/GSVSLQAET678HB054_DC.sbf.html)
And you're done. Now, you have to debrand your phone (remove all the China Mobile contents) if you want to.... wont take you more than 5-10 minutes.
Be sure not to use your previous seem 0032, if you do it, you'll lose the EDGE drive and you'll have to do it all over again.
I've bee using this for a few hours.... things load considerably fast, and Opera Mini is a killer.
Add-on:
Motorola MIDLets Manager wont recognize the phone, so you have to do a little edit to the programs scripts. Open motomidman.ini and ad to Mode2 = R4441D should look like this
Mode2 = R4513 R4515 R3511 R479 R47A R4517 R478 R444LH2 R44419 R3512 R4441D
and you are done!
MOTORуль
сообщение 10.6.2007, 14:55
Пользователь №: 129 242
Модель телефона: К3(black)+V3i
Прошивка: My MR'ка
Кто-нибудь, переведите этот мануал на русский, а то я хреново перевожу, а только писать немного умею(
Somebody, translate this manual on russian please! As I badly translate from the English language(
Сообщение отредактировал MOTORуль - 10.6.2007, 16:53
=BazOOka=
сообщение 11.6.2007, 7:38
Пользователь №: 107 478
Модель телефона: rokr e2
Прошивка: 4AP
ArcherIV, thanks for tutorial. I've translated it to Russian below.
Активация EDGE на R479 (переделка v3i на V3ie)
Это действительно легко сделать. Это великое открытие принадлежит alfun9
Всего несколько шагов, которые легко выполнить.
Помните, что эта прошивка устанавливается только на Motorola RAZR V3i без iTunes (R479), если у Вас V3i с iTunes (R47A), то Вы убьете свой телефон.
1) Прошейте свой телефон прошивкой R4441D_G_08.01.03R (взять можно тут - http://www.mfteam.eu/firmware/v3i/Reflash/...mlp_mdrm_DC.rar)
Не волнуйтесь об использовании этой прошивки, я и многие другие её использовали на V3i R479 и все нормально.
Избегайте другой версии этой прошивки (R4441D_G_08.02.03R), так как она не позволит Вам сменить себя в дальнейшем. Прошивка, на которую я дал ссылку не имеет ограничений. Она стабильная и быстрая.
2) Затем сохраните все на телефоне: картинки, мелодии, видео, телефонную книгу, симы, КРОМЕ SEEM 0032_0001, ecли Вы это сделаете, то потеряете EDGE и Вам придется все делать заново.
3) Прошейте свой телефон флексом от China Mobile GSVSLQAET678HB054_DC (взять можно тут http://rapidshare.com/files/11777297/GSVSL...B054_DC.sbf.htm)
Вы все сделали. Теперь просто верните все на свои места (удалите контент от China Mobile) если Вы хотите... Это займет всего лишь 10-15 минут.
НЕ используйте свой предыдущий сим 0032_0001, иначе Вы потеряете EDGE и Вам придеться повторить все операции снова!
Я на себе испробовал этот мануал, все грузится намного быстрее, Opera мини - просто убийца.
Дополнение:
Motorola MIDLets Manager не будет распознавать Ваш телефон, поэтому Вы должны немножко отредактировать программные скрипты. Откройте motomidman.ini и добавьте к "Mode2" R4441D, так чтобы получилось примерно следующее:
Все! Вы это сделали!
Фунтик
сообщение 23.2.2008, 9:04
Из: Россия, Омск
Пользователь №: 43 914
Модель телефона: V3i
Прошивка: 0A.52 ;)
эмм.. оно чтоли на бут 0A.52 ставится? о_О
mihaus
сообщение 21.8.2008, 18:27
Пользователь №: 179 643
Модель телефона: v3i
Прошивка: R4441D_G_08.01.03R
Что кроме меня так не сделал?
Всё работает...
Сейчас гляну есть ли теперь ёж...
mR.gnomE
сообщение 7.4.2009, 5:09
Из: [KZ] Astana
Пользователь №: 193 087
Модель телефона: Motorola ROKR EM35
Прошивка: Mod by Chacha_Ivanov
Уважаемые, будьте добры, перезалейте на другой файл сервер(нарпимер на айфолдер)...нужен флекс, а на работе скачать не могу! sad.gif
Спасибо!
mR.gnomE
сообщение 7.4.2009, 10:11
Из: [KZ] Astana
Перлил на япапку, может каму пригодица GSVSLQAET678HB054_DC.sbf
Activate Edge On R479 (v3i To V3ie Conversion) · For English speaking members · Forum
Текстовая версия Сейчас: 24.8.2025, 6:56
