Can someone help me here? I'm going to use my phone as a test subject.
![]() Can Anyone Help Me With An Accurate Translation?, V3i R479 conversion to R47A |
ArcherIV |
![]() Новичок ![]() Группа: Пользователи Сообщений: 6 Регистрация: 20.1.2007 Пользователь №: 117 990 Модель телефона: RAZR V3i @ V3ie Прошивка: 12345 Рейтинг: 0 ![]() |
Dart Moto |
![]() Опытный ![]() ![]() ![]() Группа: Пользователи Сообщений: 119 Регистрация: 18.9.2006 Из: XS™ Пользователь №: 99 608 Модель телефона: XS™ Прошивка: XS™ Рейтинг: 49.5 ![]() |
Give me a link please
Пользователю запрещено создавать сообщения |
linxun |
Новичок ![]() Группа: Пользователи Сообщений: 24 Регистрация: 30.11.2006 Пользователь №: 108 892 Модель телефона: MOTO V3I Прошивка: R47A_G_08_D9.3DR Рейтинг: 2.6 ![]() |
GUIDE: R479 > R47A
Supshow: http://www.motox.info/showthread.php?t=35941 Цитата R479 > R47A The manual is being published here at MotoX under author's permission. For advanced users only! Use this at your own risk! Author of the manual: GandjaFuzz (motofan.ru). Translation: yours truly. What we need: R47A firmware and my patches. 1) Preparing the firmware 2) Flashing the modified firmware 3) Change PDS component seems 1) *First we remove RSA (detailed information can be found in this thread. *Apply the "RUN_PHONE" patch to the CG1 (in SMG format). The software will indicate that it has overwritten 32 bytes after patching. If you see this message, you did it the right way. *We now have to enable an ability to write PDS component seems to phone. THE CODE WILL VARY DEPENDING ON FIRMWARE VERSION! Here is an example (the code in your particular case may look different): Find the following string in CG 1 Code: 00 00 00 00 00 00 00 00 00 AB 00 0When you find it you will see a similar code (example is based on R47A...D8.A1R, log taken from ID) Code: ROM:100BA010 10 0D 64 8B 00 00 00 00 00 00 00 00 00 AB 00 00 dЛ.........л.. ROM:100BA020 10 0D 64 8B 00 00 00 00 00 00 00 00 02 30 00 00 dЛ........0.. ROM:100BA030 10 0D 64 8B 00 00 00 00 00 00 00 00 02 31 00 00 dЛ........1.. ROM:100BA040 10 0D 64 8B 00 00 00 00 00 00 00 00 03 5A 00 00 dЛ........Z.. ROM:100BA050 10 0D 64 F7 00 00 00 00 00 00 00 00 03 5B 00 00 dў........[.. ROM:100BA060 10 0D 64 F7 00 00 00 00 00 00 00 00 03 59 00 00 dў........Y.. ROM:100BA070 10 0D 64 F7 00 00 00 00 00 00 00 00 03 5C 00 00 dў........\.. ROM:100BA080 10 0D 64 F7 00 00 00 00 00 00 00 00 03 71 00 00 dў........q.. ROM:100BA090 10 0D 64 F7 00 00 00 00 00 00 00 00 01 C1 00 00 dў........+.. ROM:100BA0A0 10 0D 63 DB 00 00 00 00 00 00 00 00 01 BB 00 00 c-........¬.. ROM:100BA0B0 10 0D 64 8B 10 0D 64 39 00 00 00 00 02 9C 00 00 dЛd9....Ь..lets view the first line of the code Code: 10 0D 64 8B 00 00 00 00 00 00 00 00 00 AB 00 00The first 4 bytes - 10 0D 64 8B - represent a link to the function that allows us writing the seem 00 AB Same for the other lines, i.e. the code indicates that I can overwrite seems 00 AB, 02 30, 02 31, 03 5A..., while the remaining seems cannot be overwritten... To enable seem writing we edit the code, i.e. change the link from "disable write" to "enable write": 10 0D 64 F7 - to - 10 0D 64 8B. Same for the remaining seems, including seem 01 BB. When done editing the code should look like this: Code: ROM:100BA010 10 0D 64 8B 00 00 00 00 00 00 00 00 00 AB 00 00 dЛ.........л.. ROM:100BA020 10 0D 64 8B 00 00 00 00 00 00 00 00 02 30 00 00 dЛ........0.. ROM:100BA030 10 0D 64 8B 00 00 00 00 00 00 00 00 02 31 00 00 dЛ........1.. ROM:100BA040 10 0D 64 8B 00 00 00 00 00 00 00 00 03 5A 00 00 dЛ........Z.. ROM:100BA050 10 0D 64 8B 00 00 00 00 00 00 00 00 03 5B 00 00 dў........[.. ROM:100BA060 10 0D 64 8B 00 00 00 00 00 00 00 00 03 59 00 00 dў........Y.. ROM:100BA070 10 0D 64 8B 00 00 00 00 00 00 00 00 03 5C 00 00 dў........\.. ROM:100BA080 10 0D 64 8B 00 00 00 00 00 00 00 00 03 71 00 00 dў........q.. ROM:100BA090 10 0D 64 8B 00 00 00 00 00 00 00 00 01 C1 00 00 dў........+.. ROM:100BA0A0 10 0D 63 8B 00 00 00 00 00 00 00 00 01 BB 00 00 c-........¬.. ROM:100BA0B0 10 0D 64 8B 10 0D 64 39 00 00 00 00 02 9C 00 00 dЛd9....Ь..We now can overwrite seems. Once again, this is only an example for firmware version R47A...D8.A1R, the code will look different for other versions, i.e. links to "disable write" and "enable write" functions will be different. We have successfully patched CG 1 and can now generate a reflash. 2) Flash the SHX file with RSD Lite. 3) The phone starts and we replace the two seems (download link for the seems is below) with P2K Manager of other P2K program. YOU NOW HAVE A FULL-FLEDGED V3i iTunes PHONE. P.S. The "RUN_PHONE" patch can be also used for unbricking the phones: just insert a PDS sample, add the bootloader, apply patch to CG 1, remove RSA, and flash the file. P.P.S. APPLYING THE PATCH IS A MUST WHEN YOU INSTALL ANY DIFFERENT FIRMWARE VERSION, OTHERWISE YOUR PHONE WILL BE BRICKED! P.P.P.S. Seem replacement procedure is needed only once in order to modify PDS. P.P.P.P.S. I would like to thank the following testers Supshow and Shen. Special thanks to our guru Vilko for stimulating me to enhance my knowledge!!! RUN_PHONE patch Seems for iTunes [disclaimer: This manual is NOT to be published outside of MotoX! The manual is being published here at MotoX under author's permission.] __________________ www.motox.info http://rapidshare.com/files/12810208/Dmatts3n-updated.exe |
Текстовая версия | Сейчас: 13.9.2025, 18:13 |
