R564_g_12.00.45p Ilove3d Ix
Wattie
сообщение 26.1.2007, 18:33
Пользователь №: 58 537
Прошивка: 43R
Autopower On and Off functions. Many C programs in bin (crontab available), busybox and all features from previous versions
R564_G_12.00.45P ilove3d IX for Motorola ROKR E2
Kirill111111
сообщение 26.1.2007, 19:04
Пользователь №: 22 010
Модель телефона: ROKR E2
Прошивка: DarkShadow 4AP
whitemoto, а как на счет того же самого в новых версия монстра???
Nuvolari
сообщение 26.1.2007, 20:41
Из: Нижний Новгород
Пользователь №: 97 162
Модель телефона: Milestone+Z8+ZN5+VE66
Да скин очень понравился.
Вот описание прошивки
automatic poweron poweroff function: ( by tomlih from moto.it168.com )
you need to use "not-only-vibrate" profile, for the key poweron/off program is alertprocess
usage:
creat alarm named "poweron" or "poweroff" , and it will poweron/poweroff at the time you set
*** you should not disturbe when the phone is alarming the "poweron"/"poweroff"
*** the phone will reboot before poweron/poweroff, it's normal, do not disturbe too
*** you can use "Silence.mid" to make the automatic poweron/off silently
*** the default snoozetime is 1 minutes, donnt change it for automatic poweron/off function
contains the newest busybox 1.4, and in /bin there're very large number of telnet commands
about 2xx commands.
defaultly "Alienware" skin ( by arpin520 from moto.it168.com )
cool and very perfect one.
also have the classic Orange and Black ones.
unKnown/
My_FAVOR:
myfont.ttf to change font
ezx_volumetable.cfg to change volumetable
ui_start_up_mono.wav to change powerup sound(defaultly I made it silence)
My_SKIN:
skin links to /ezxlocal/download/appwrite/skin
setuptheme links to /ezxlocal/download/appwrite/setuptheme
My_BORDER:
you can copy your own *.png borders to take photo
I changed the defaultly font to FZ+E6 font ( by Hello36 from moto.it168.com )
there's LinkSYS in "office tools", you can make a link to rootfs in filemanager
click to link, click again to delete the link
autorun scripts: you can see it in ( use Ultraedit, or gedit )
etc/rc.d/rc2.d/S68fay
ezxlocal/autorun.txt
busybox & /bin commands:
W e l c o m e t o T e l n e t
OS: MontaVista® Linux® Consumer Electronics Edition 3.1
Firmware: ilove3d--45P--IX
Kernel: 2.4.20_mvlcee31-mainstone_pxa27x/armv5tel
(none) login: root
BusyBox v1.4.0 (2007-01-22 18:25:29 CST) multi-call binary
Seregarz
сообщение 26.1.2007, 22:02
Из: Киев, Украина
Пользователь №: 21 434
Модель телефона: C650+ROKR E2
Прошивка: Калейдоскоп
Кто скачал, как впечатления, стоит качать по dial-up? Что хорошего/плохого?
kpot_
сообщение 26.1.2007, 22:20
Из: СПб
Пользователь №: 48 071
Модель телефона: Mozart7
Прошивка: MAXX
Менюшка красивая, анимированная, вроде все шустро работает. В предустановленных есть линксис (для меня - это круто, потому как до сих пор не научился самбовать тел smile.gif)
Можно ставить свои рамки, свои скины - для этого есть папки в "Нераспознанных"
Музыку пока не слушал, поздно уже. Может, позже отпишусь.
А пока мой приговор: качать только тем, кому не жалко трафа (или анлим)
whitemoto
сообщение 27.1.2007, 0:44
Пользователь №: 63 052
Прошивка: pre
Kirill111111,
там слишком заморочена активация этих будильников, чтобы нормально юзать
дерните с этой проши скин и busybox (если он весит не меньше 900kb!!, в противном случае идет оптимизация по размеру, соответственно медленнее работает, и поэтому будет сомнительно использовать busybox как замену большинству стандартных приложений)
kpot_
сообщение 28.1.2007, 13:12
Из: СПб
Прошивка: MAXX
Скин - Скины Для Е2 (#685539)
Busybox, 730 кб -
gorod
сообщение 28.1.2007, 15:01
Из: Горький
Пользователь №: 46 782
вообще бы полный перевод
kpot_
сообщение 28.1.2007, 15:48
Из: СПб
Прошивка: MAXX
Функция автоматического включения и выключения (будильника?)
Необходимо использовать любой стиль оповещения, кроме "только вибрация"
Как использовать: создать 2 будильника с названиями "poweron" и "poweroff", и они включатся и выключатся в то время, которое поставишь.
***не трогать телефон, когда включается будильник.
***телефон перезагрузится перед тем, как зазвонит этот будильник - это типо нормально )
***в качестве звонка оповещения будильника можно поставить "Silence.mid" - и будильник будет звонить бесшумно ( blink.gif )
***стандартное "дремать" - 1 минута. Не менять для автовключения и автовыключения будильника.
Содержит новейший busybox 1.4, и в папке /bin имеется большой список телнет команд.
От 200 =)
Скин "ALienware", а также оранжевый и черный.
Папки в ФМ--Нераспознанное:
My_FAVOR:
myfont.ttf - чтобы поменять шрифт.
ezx_volumetable.cfg - понятно
ui_start_up_mono.wav - чтобы поменять мелодию запуска телефона.
My_SKIN:
2 папки - "skin" и "setuptheme" (в скин - папку скина, в сетап тем - файл *.chm)
My_BORDER:
Сюда можно положить рамки для фоток в формате png
Также чувак поменял шрифт на английский язык. На русском не работает smile.gif
Добавлено мпкг "LinkSYS" в Офсиных средствах. Это понятно что такое.
Скрипты авторана по адресам:
Все, не бейте сильно. Перевод любительский )
Сообщение отредактировал 3au4uK - 28.1.2007, 18:22
Kirill111111
сообщение 28.1.2007, 16:39
Fedot_tork
сообщение 29.1.2007, 11:46
Проказник
Пользователь №: 95 684
Модель телефона: zn5
Прошивка: *#0000#
Kirill111111,
это программа в мпкг, ты можешь её отдельно скачать.
ПРОСЬБА! Кто на этой прошивке, выложите пожалуйста все файлы находящиеся по адресу
ezx_user\download\appwrite\alarmclock
попробую втырнуть фичу включения выключения в будильнике на 46 прошу
kpot_
сообщение 29.1.2007, 12:02
Из: СПб
Прошивка: MAXX
Вотъ.
Злодей
сообщение 29.1.2007, 12:03
Из: Чебоксары
Пользователь №: 51 069
Модель телефона: Мото Зайн
Прошивка: 7fr
На этой проше не работает поиск мультимедиа, как исправить?
whitemoto
сообщение 29.1.2007, 12:04
Прошивка: pre
и busybox!
find / | grep busybox
уже на линуксе, статично почти) , так что скоро основательно прошей займусь
kpot_
сообщение 29.1.2007, 12:09
Из: СПб
Прошивка: MAXX
Не работает, да. Но можно по другому обновить:
Нажать на боковую кнопу "Play" - откроется список альбомов. Нажать назад - окроется список мультимедия. Там можно обновить, что тебе нужно smile.gif
reclama
сообщение 29.1.2007, 18:23
Пользователь №: 116 294
Прошивка: 45P ilove3d IX
Прошился сегодня R564_G_12.00.45P ilove3d IX
Очень трудно разглядеть в каком состоянии батарея, толи один, толи два
Я, правда, не понял смысл вкл. и выкл. будильника если б телефона
kryck
сообщение 29.1.2007, 20:43
Пользователь №: 105 209
Модель телефона: Motorola Rokr E2
Прошивка: Public_beta1
Извените, кто-нить объясните мне что такое этот busybox.. Это чтото с линуксом связано?
kpot_
сообщение 29.1.2007, 21:26
Из: СПб
Прошивка: MAXX
Заметил на этой прошивке, что когда слушаешь музыку, при перемотке песня не останавлевается, а начинает играть с перемотанного времени.
reclama
сообщение 29.1.2007, 21:43
Также замечено состояние аккумулятора в основном меню - три кубика, а когда заходишь, к примеру, слушать радио или мп3, то один кубик не закрашен, когда идешь обратно в меню все на месте.
kpot_
сообщение 29.1.2007, 21:54
Из: СПб
Прошивка: MAXX
Ну не знаю, я скин поменял и теперь вместо значка аккумулятора - покебол biggrin.gif
VeRT RoKR
сообщение 30.1.2007, 6:33
Пользователь №: 116 097
Модель телефона: RoKR E2
Прошивка: стабильная
alo33
сообщение 30.1.2007, 8:39
Из: Ульяновск
Пользователь №: 26 053
Модель телефона: Defy+
Прошивка: 4.5.1-134_DFP-231
Вот на этом сайте написано какое приложение что делает http://www.mvista.com/devrocket/index.html
Если вкратце то busybox=Multiple shell commands in a single executable(Выполнение множества shell-комманд в одном скрипте)
kryck
сообщение 30.1.2007, 9:42
alo33
сообщение 2.2.2007, 14:28
Из: Ульяновск
Как я понял это и есть вкл/выкл телефона по расписанию через будильник
MixXxer
сообщение 7.2.2007, 6:45
Из: Беларусь
Пользователь №: 106 007
Модель телефона: MotoROKR E8
А русский надо ставить отдельно?
VeRT RoKR
сообщение 7.2.2007, 6:56
R564_g_12.00.45p Ilove3d Ix · Motorola ROKR E2, A910, A910i, E895 · Forum
Текстовая версия Сейчас: 12.9.2025, 6:28
