[Software] 1.2 version of the stroke input method has been to support memory function (5.19 update)
Strokes, input, memory, function
This procedure has been to provide the installation package, install the program to download and use instructions, see:
http://club.ccmove.com/nclub/topicdisplay-...-1018755-1.html+ ^ - V, c-Z7 (! _8 P
5.16 update
1. Candidate background map areas using the word. # V: N K9 X "V,)
! H6 z! W. T7 (
2. Update character frequency mobilization of associative memory and function, now has real-time mobilized.: P3 N) j9 d $ C + W6?
1? + V5 B1 E; b; _
3. Large-scale reduction of memory occupation. Only input method is displayed in the occupied about memory.
4. To support arbitrary data files stored, it must be revised / ezx_user/download/AppWrite/Setup/foxime.cfg4 ^ 0 e (D * K! H2 M! J2 g
0 e $ R7 G +? * F8 | t
5. To support the candidate word color settings, details see symbols.txt: h * ^ 8 [8 r9 b1 [! R: y
Thanks again for cold heroes offer Lenovo wins and the provision of stroke order to adjust thesaurus library, these are the heroes of the effort, without his hard work
Pay none of this input method. Thank you!
# I / S0 s + o / y5 X
1 |% g: T5 t; K "(. (0 r
Please indicate the source of the quote reproduced!
2.27 Update: 4 L "u) S) l # C0 y. G
1. To allow libStrokeIME.so stored in any location, no longer limited to * B & X; x7 m8 C) z & e-k K
2. The first row of the first and fifth words no longer appear association user created characters .1 t & D% ~ / A. b 'C) P5 c
Version 1.1 Update:
1. Support the button pressed, the Move select other keys function. If pressed the wrong button, without releasing the button
The case can also be moved to want to press the button on the let go, to complete the right click function. + `']' E; o6 ^ 0 A0 i
2. 1.0 version of the association, the will to think of punctuation marks to go, this version has been amended. "I 'N6 v2 z-N: ^ / B0 ~% z
3. To allow a long press Backspace key to generate a continuous regression function.; U '~ (| $]) r
4. Font and procedures separately, the perfect solution to large-capacity model crash problem; also solve the storage to
Phone memory, the memory is full of problems caused. O6 \: q2 i1 l9 V,)
Note, in the high-capacity mode, not to use input method, or still hang in the .7 R8 r: V2 n% _ * H *? &? 4 v
% R: G-t / K3 (# q5 D / ^: C-q / a
5. Shorten the stroke display area, the two sides were added word association functions.
Such as the input of the "joint", then click the strokes, "horizontal", the second row still shows "horizontal" started to write the word.
But the first row shows the first and five words, "Union" at the beginning of the second word is "horizontal" started to write the word
Such as "think" and "common" words. + I, `% y $ ^" ^ - V2 J: O4 e5 `
Version 1.1 Installation Instructions:
1. This version of all documents except libStrokeIME.so documents, must be placed in the other
/ Mmc/mmca1/.system/QTDownLoad/StrokeIME / directory
If you do not want to put into this directory, your own changes through ultraedit libStrokeIME.so. V * h; v0 a / M7 [(H / F
The path (to find / mmc/mmca1, found in change, I have left some behind empty 0,! \ ")) @% S (N # A + t (W
Note that changes must be in binary mode, do not forget the path to the last one /); p3 A (J: C6 I5 S
$ H) `'L6 U & y8 U & I0 p
2. LibStrokeIME.so file can be placed into any directory, defaults to / ezxlocal / download /, * \, i Q, L K4 g5]
If it is not stored in the default location, modify the binding statement. Not brush machine users must make changes to run.lin
Document binding statement 4 B6 A-g0 p & O ((4 F% i
3. Bound to use the following statement:
Copy the following line to startup.txt or startup1.txt any document, you can restart your phone. Note only one line on it.
Line 1:5 H7 P. P1 I% o "o-B% |
mount - bind / ezxlocal / download / libStrokeIME.so / usr / lib / ezx / lib / inputmethods / libnumberboard.so! [, s! D-o0 t) G ") $ [
Line 2:8 O3 Y E4 Z) m
mount - bind / ezxlocal / download / libStrokeIME.so / usr / language / inputmethods / libzhuyinboard.so) K: D X3 J% w $ A9 I k + d
Line 3:
mount - bind / ezxlocal / download / libStrokeIME.so / usr / language / inputmethods / libpinyinboard.so: i 'l # t "^ - y
If you copy the first line, then the numeric keypad is replaced by stroke input method
If you copy the second line, then the phonetic input method has been replaced by stroke input method
If the copy is the third line, the Pinyin input method strokes input method instead of being
: J! T # l, N J (| * U / i
Files must be stored according to my location, or can not run!
8 K4 H6 I) I: v! F + B6 W
* H9 W # Z E8] 5 V "_ a: V; h
This input method is suitable for brush-off machines TX, did not brush off machine for TX, I give a solution: 3 f (G / w%? + F7 z,) 5 n1 n
Download StrokeIME_Bind.rar, extract the installation. Reboot every time the phone can click the software.
Note: You must use any input method software needed before the click, or can not bind.
; P-d * q & O5 C4 v1 d. m "y
Principle: The phone does not start immediately after the load input method, you must wait until a need for input method support software 9 l5 [2 T8 U $ n7 a / l% M3 b
Run only when the load input method. Input method will not be unloaded once loaded. Therefore, we must start immediately after the binding
Input Caixing. # [2 Y0 o9 N0 X # O. q, X, Z6 f + G *)
: C6? 'N + j: w6 R @ 3 F)
1. Death does not need the battery, points [procedure] -> [run]: / B $ O7] * j0 | + r4 F
Input cmd Enter (n. K6 j (E0 s4 X
Enter telnet mobile IP address
In the telnet window, type reboot Enter to restart the phone.
8 K3 k8 v! E4 H6 O # D
2. My phone is E6 R533_G_11.11.04P version can be run without virtual memory.% W & d.)) t 'n! `8 c
: T / z; F4) 9 q
3. The input method starts loading a 417K file into memory, if the phone itself does not exist in memory and software
Will not crash. In my machine, start Task Manager shows 49%, stroke input method is displayed after running
51%.
: D & @. _2 ~ 4 z p9 ~ 'G / u
4. If you use the input result in the machine can not start or crashes, please join the SD card in the startup file in the binding
You can delete the resume statement .6 i + g (a4 R4 d% Z, R4 m
4 [, N3 _-Z * t # T # e1 U) D
% K; m3 E (a & s9 Y + l-R @
After several days of effort, finally completed the stroke input method, first of all, or would like to thank the various quarters about CCMOVIE
XDJM, thank you for providing many valuable suggestions, thank you for your support, thank you for the flowers and applause, thank you! 9 (0 I. E1 l5 X9 l4 T-l) D
Special thanks should also win in this cold, lqg2118, okg2910, dream Butterfly 1, and TX, precisely because
Their efforts for many days, to complete the characters commonly used for the adjustment of 3500, express our heartfelt thanks!% B S! (#? 'N' `- t
Thank you also to airomand and cool magic wolf provide the interface, thank you.
. Y * N3 V) R. i2 Q% ^; I7 e * I8 v
: X-c. a5 w, R
This is free software, free dissemination and use, but not for commercial purposes, shall not put anything in the package advertising information!: ("E) z6 @ 6 p-W7] 8 P
This procedure applies to E6, A1200, E680
1. Features:
1. Stroke input .3 l (m9 X * v, A
Generated by the corresponding input character strokes.
Stroke Description: 0 Q / \ $ R4 l3 e. _. v
a. "horizontal" and "put" are considered horizontal, a0 Y # c-E2 F
b. "vertical" and "Jue" are counted vertical, such as "straight," the second tranche of the same strokes are vertical
c. "Pie" and other right-to left-handed strokes are considered, Y 'B7 s! n "R-p! _ K
d. "dish", etc. are off point from left to right strokes
e. Other strokes are counted off & G-i-) - Z $ E-T; A
Tip: In the stroke input, press up "flip key" to display commonly used symbols.
Click the stroke display area to clear the current input of all strokes
f. m) E! w8) 5 x * \ 's2 b
2. Association functions. (D:) / d "W1 [4 z $ M
Enter the word by stroke or association, the association area will display the current word with the word may be .5 j4 E 'z8 (1 T3 j' o
In the absence of association, or when, or flip to the end, the show frequently used symbols.
Tip: Lenovo, press up "flip key" to display commonly used symbols.
3. Word frequency mobilization .- L "a8 s,` 1) 3? "D + T3 D # W
Select Lenovo words, the system will adjust the order of the word.
4. Term memory.
Lenovo entered by typing a word or after entering a character with a stroke, the system will remember the word.
The next input / word association, it will automatically display the word. In the first input word and press the backspace key, the system & K6 R; ^ # P; p0 F 'p
Word of this new office will be canceled to prevent the misuse lose .. | 3 i!]) O / F "n5 F% Z
1 P * Z6 F, H "b-p0 @) p * Z
Note: The flip is a cycle. CapLock and fairly and Page Down Shift 1 j (`(W; s: P
6. Text input.
The following characters can be entered through the up / page down to select the word page., C1 M # Z8 D3 a
qwertyuiop <- page up
asdfghjkl; <- default at this location) ^ 5 f0 j + U7 c. k8 U5 u! r 'o3 b
zxcvbnm,. / <- scroll down. ~ 0 e5 F, @ 7 S: c; W, N
7. Symbol input.
The following characters can be entered through the up / page down to select the word page .- R. l% C! P, M & (: d3 m
| <- Page up
:;,.?/~`!<- The default in this location 9 z: p0 d1 d /]) B-g: t0 g
#$%^&*+-=_ <- Scroll down! \ $ Y + e6] 5) 9 E1 `
;] 1 S 'V & @% g / I # H
) A2] 3 K:] & Q. Q. \ / X2 B # j
Note: The flip is a cycle. CapLock and Shift can enter the following Chinese symbols 2 U! Z * D * tc! B s, h
. F, u * Z2 B, b; E # \ 9 b (k: F
§ ч <- up next page% L / G * \) j # P6 m / B
:;,. ? , ~ *! ◎ <- default at this location
# Ґ% ... ※ Ч+-=- <- Page Down
8. Symbol Input 2.
The following characters can be entered through the up / page down to select the word page .- ^ 2 U-) # R 'M (t # P-aa
Note: The next page is invalid. CapLock and Shift can be entered as the Chinese symbol 2 k "k0 m: n + H, B! M # q: a-)% q3 z8`
4 ^ - \ - c-G5 m
2. Custom; q (N # A "(" @;) (l. _
1. Custom interface.
The program supports custom interface. Users can modify InputW_Stroke_Entry.gif, InputW_Stroke_Entry_Ext.gif
To modify the button style and color. But do not move the location of the main button, the image size and do not move .6 y. h; i0 S $ M + E3 d
Have a good picture I do not forget to send a.! (; R: j7 q * c, o
2 | # r5 j9 S4 I "K * w
2. Custom symbol keyboard .0 `/ y4 J4 N / f" O-U
Keyboard symbol [number] [letter] [Symbol 1] [symbols 2] corresponds to the content is customizable .2 R! R! T4 y0 p1 C1 e5 K0]
You can modify Symbols.txt customize number / letter / symbol. Files can be prepared using windows Notepad. H0 t4 a (A / b0 P3 Q
Note: You must save the plain text (ansi), can not be utf8 or unicode., V8 \ 6 U * o: U7 p / A
* D "V. N9 F-? 2 ^
Symbols.txt definitions: * l / U; N0 s $ N & q
The first line corresponds to [number] key content
The second line corresponds to [number] keys to press Shift or CapLock the content of state
The third line corresponds to [letter] key to the contents of the G / y "F1 M4 I
Fourth line corresponds to [letter] key or press the Shift the contents of the state CapLock
Fifth row corresponds to [sign a] key content
Corresponding to the sixth row [symbol 1] key or press the Shift the contents of the state CapLock
Corresponding to the seventh row [symbol 2] key contents of the 7 N! F7 W% l & |
Eighth row corresponds to [symbol 2] press the Shift key or CapLock state the contents of the) i. j + `(` 8 K0 c5 ^ +? 3 j
Ninth line corresponds to the default of 10 punctuation marks. # P + C; I n9 (/ M. i! ^, I-l
10th behavior when the candidate is not selected the word color, format: RRGGBB, such as the FF0000 for the red 3 _ + (/ ~% | 9 O 's3 w; x
Word of the selected candidates for the 11th time behavior of the color, format: RRGGBB, such as blue 0000FF
Note: The line of the contents of not more than 255 characters (127 characters)
# B # j2 Z + f 'l! F $ x * T
3. The main interface input
* S3 l9 O; h0 J8 y7 D% I, f $ H! H
File Description:
1. Foxbh_XX.fpkg: stroke input method of the installation process will produce fpkg extracting file to install through foxsetup. For beginners fool of installation.
2. BHIME_XX.rar: Advanced users can use this package to install their own hand, without having to download foxbh_xx.rar
; L9) 2 M0 L0 Z5 W7)
Users can directly A1200 E6 version
/ W "M ~ 2 y% M8 l: u7 | 3 g * a
V 'O4 [: P #? # Z #]: V: M
