Выкладываем сюда новые МОНСТРЫ, Ищем и выкладываем хотя бы ссылки:BlackStorm,Suprema,Titanium,OnlyYou
сообщение 27.12.2007, 23:30
Нашел еще 2 монстра для наших РОКЕРОВ ЕДВА
Заморачиваться не будем - и так понятно-что нового мало-стандартный набор функций Калейдоскопа + со всего понемногу
- так как на революцию не претендуют-выкладываю в одной теме оба.
Монстры забугорные - отзывы положительные.
1) Titanium Edition
Автор mati77
Оригинал темы ТУТ
This FW is based on ROKR Ultimate by ilove3d (R564_G_12.01.48P).
This is dedicated to English and Spanish users (the name of extra applications are automatically adapted to English or Spanish language).
it also includes a reflash for those that want functions of kaledoiscope
The main advantages are:
• Applications of FW ROKR Extreme 2 (Phoneware man, rokr.lin) • Possibility to change the voice commands easily!!! You should put on the file command that is in this package, inside the folder my_favor. You can edit the "command" file whit notepad ++ (included too) and change what the man says
• Correction of media player. Now it is possible to see all type of signs!!! It has also a softer displacement in the menus
• The alarm clock sounds although you are in silence or vibrate profile
• You can use the radio without earphones!!
• Reading of messages
• Synchronization with Motorola Phone Tools
• APMD's that are in my favor are mounted automatically at the beginning (you should rename it to apmd)
• Intel Xcale was modified. Now you can choice for 7 APMD, including underclocking and overclocking
• Corrected the separator in the adressbook when it orders for last name
• Application to rename pictures with graphic menu (fotoren)
• The brightness isn't modified when you makes overcloking/underclocking
• Camera with zoom up to 8x at 640*480 px
• Posibility to enable or disable the increased user dictionary easily (see PD2)
• Very good batery life The reflash with kaledoiscope adds the following functions:
• Software keylock (by C + *)
• Copy/Paste function
• Multitasking for ezx-application
• Icons in submenus
• ilaunch bar Important: the reflash removes the synchronization with Motorola Phone Tools Other characteristics:
• ilove3d Kernel v1 • Apmd 104/208/312
• Utilities (Print screen, Phoneware man, System Info, Intel Xscale, Restart, Lights control, Desktop visuals, LinkSYS, SD manager, Refresh, Fotoren, Open with)
• Stock Sounds of system
• Stock Bootimage
• MotoID working and stock games
• Descompresor of rar; zip; tar; tar.gz files
• My_FAVOR automatically executes: apmd, command (for the voice commands), myfont.ttf, ezx_volumetable.cfg
Important: it is recommendable to install the file R564_G_12.01.48P.shx in the second bootloader for compatibility reasons.
This file installs 850-1900Mhz 1800MHz bands. If the operator of your country works in the frequencies 900-1800MHz 1900MHz you can install the flex with the corresponding bands included in this package.
PD1: Inside the package there are attached some apmd's, so you can make permanent overcloking/underclocking putting them in the folder my_favor. This FW comes with an apmd in my_favor created by my with the intention of improving stability/speed. Obviously you can remove it or put anyone you want
PD2: there is a patch for user who want increased user dictionary. You must copy the file "diccionario" inside the folder My_favor and then restart, to enable or disable this function. If you have any incompatibility, you have to eliminate it and restart to return to the previos small user dictionay
Изображение Изображение Изображение Изображение Изображение Изображение Изображение Изображение Изображение
СКАЧАТЬ TITANIUM EDITION
Рефлеш Калейдоскопа
РУСИФИКАТОР smile.gif ))
НУ что мы видим:
1. Возможность изменять голосовое управление - нам мало интересно-хотя некоторые на инглише юзают
2. Некие изменения в медиаплейере-более плавное перемещение по спискам - и просмотр новых расширений
3. Исправлен будильник-теперь он работает даже когда стиль бесшумный и вибра
4. Радио без наушников-бойан
5. Синхронизация с Motorola Phone Tools (Обратите внимание-кому нехватало)
6. Добавлены несколько APMD
7. В адресной книге какой-то баг с фамилиями исправлен smile.gif ) -потестим
8. Фоторенеймер-тоже байан
9. Изменения в камере- 8-кратный зум при 640*480
10. Возможность редактировать Итап
11. Автор утверждает -что показатели батареи очень хороши
Ну и ессно-рефлеш Калейдоскопа добавляет вкусноти
• Блокировка клавы (C + *)
• функция Копи/Паст
• Многозадачность
• Изображения в подменю
• ilaunch
НО при прошитии рефлеша -синхронизация с Motorola Phone Tools прекращается.
Что еще имеется на борту:
• ilove3d Ядро v1
• Apmd 104/208/312
• Утилиты (Print screen, Phoneware man, System Info, Intel Xscale, Restart, Lights control, Desktop visuals, LinkSYS, SD manager, Refresh, Fotoren, Open with)
• MotoID
• Разархиватор rar; zip; tar; tar.gz
• при помещении в папку My_FAVOR автоматически выполняются: apmd, command (for the voice commands), myfont.ttf, ezx_volumetable.cfg И т.д.
2) ONLY FOR YOU V3 От камрада (страшно сказать) vanhieumai (minhemthoi) - Социалистическая Республика ВьетНАм
Оригинал темы
You can share the firmware only if you:
1. Especially credit the Kaleidoscope firmware for the binaries
2. Provide link to the Kaleidoscope motofan.ru thread That's fair enough Smiley thank you very much!
i can shared the link here. this is ONLY YOU V3 mixed Kaleidoscope with ONLY YOU (SELF V2) review: - LP All in One. default only English, you can install your language by using file manager to click *.ins file.
Please Reboot after install.
More lang in here This LP still have a BUG with phone talking.
If you don't like it, you can reflash another LP.
- All Eq Presets Enabled
- Lots of media: pictures, rigntones - New big font (9.88Mb) by ThreeSearch from vllp.sourceforge.net
- Standart Z6 skin mod; Aten: one of the most perfect themes made by softmetal; Crystal blue: Ilove3d mades this theme, with many peoples help, and the CrystalSVG icons Smiley
- iTune_ext3_MultiKey kernel (when you hold itune key, it'll show Kill Process)
- Tool Box: SnapShot, Phoneware Man (MPKG Manager, JAVA Domain, SoftRename), System Status, ScreenSaver, Setup Timeout, Testboot, Powerup Notify, LinSYS, SD Manager, Refesh Phone.
- My_FAVOR folder: you can put apmd, ezx_volumetable.cfg, myfont.ttf, issue.net, ui_sounds folder into this folder then reboot to overclock, change volume, change font, change telnet welcome screen, sound system...
- with rokr.lin can extract many file type of package: ins, mtf, tar.gz, rar, zip...
- click & load / extract / install: ( sure, it's GUI too )
New Features:
- O.c Included (default 415Mhz)
- iLaunch and Task Manager
- copy/paste function
- icon in submenu
- keypad locksoft (C + *) ...
still have some small bug: talking phone not work, Z6 icon.
(you can fix it by install another LP and use another theme Grin) sorry because i'm still a noob, i just mix all i have, we need. please forgive me :'(
Credit: - Especially credit the Kaleidoscope firmware for the binaries «Kaleidoscope» - новый Монстр на Е2 от комьюнити motofan.ru
- Especially credit the SELF V2 firmware http://moto.it168.com/viewthread.php?tid=1...%3D1&page=1 I would say thanks to ILove3D, Lasly , hobbit19, dimichxp, whitemoto and others developers of kaleidoscope, SELF V2....
Очень приятно, что чувак не просто указывает, что ипользует фичи Калейдоскопа, но даже ссылку на мотофан выложил! И даже благодарности камрадам!
Изображение Изображение Изображение Изображение Изображение Изображение Изображение Изображение Изображение Изображение Изображение
Скачать:
http://www.gigasize.com/get.php/3195654720...Y_YOU_V3_OC.zip
зеркала:
http://www.4shared.com/file/24922950/62f0a..._YOU_V3_OC.html
http://www.maxishare.net/en/file/2910/-E2-...-V3-OC-zip.html
http://www.hotlinkfiles.com/files/414444_r...U%20V3%20OC.zip
Русификатор тот же.
Переводить даже не стану-тут и так все понятно.
Последнее: монстры выложены в ознакомительных и ковырятельных целях. Нубов просьба не флудить!
Сообщение отредактировал AstaRoth - 8.8.2008, 6:02
AstaRoth   Выкладываем сюда новые МОНСТРЫ   27.12.2007, 23:30
Criz@liS   отличий от калейдоскопа - минимум... Нафиг они так...   28.12.2007, 0:36
AstaRoth   Criz@liS, все таки наличие функций Калейдоскопа не...   28.12.2007, 6:29
DDSH   отзывы были хорошие на оба - поэтому и выложил. ...   28.12.2007, 15:01
AstaRoth   Кому надо: картинки и мелодии от ВьетНАМского ...   28.12.2007, 18:36
ATHLON64   Кто знает, где лежит файл веб сессий оператора и к...   9.1.2008, 20:58
Ubiyca   ATHLON64, поидее тут: ezxlocal/download/appwrite/N...   9.1.2008, 21:21
kobr   А каких именно расширений?   12.5.2008, 22:51
Krab1   С максом2 не сравниться :) ни одна из прош... :)))...   12.5.2008, 23:31
eXeTeR   С максом2 не сравниться :) ни одна из прош... :))...   13.5.2008, 14:59
AstaRoth   попросил бы в теме про монстры впредь не допуска...   13.5.2008, 18:46
MoToR-RuleZZZZ!   eXeTeR, у меня вопрос,так как у тебя Titanium,скаж...   16.5.2008, 17:36
eXeTeR   eXeTeR, у меня вопрос,так как у тебя Titanium,ска...   16.5.2008, 18:33
†Freedom†   шился на титанум.быстренько бегает.   18.5.2008, 10:53
eXeTeR   шился на титанум.быстренько бегает. я давным дав...   18.5.2008, 19:00
AstaRoth   Давно никто видимо не лазит по буржуйским сайтам.....   18.7.2008, 22:12
Av3LaR   Оба являются FW Латиноамериканцы, первый из Mati77...   19.7.2008, 1:57
moned   Сидел довольно долго на Black Storm. Ничего в нем ...   19.7.2008, 8:08
Йа Санёг   Кто-нибудь Suprema ставил? Будьте добры киньте ски...   19.7.2008, 8:59
AstaRoth   Камрады - я что зря тему создавал? Давайте не буде...   19.7.2008, 10:22
Йа Санёг   Поставил таки Suprema, пока посижу на нем для разн...   19.7.2008, 16:27
aTsEtOn   А я ставить эти монстры не буду, ибо к латиноамери...   19.7.2008, 17:15
-=Strelok=-   Скинь пожалуйста это приложение, если не сложно ...   19.7.2008, 20:42
Йа Санёг   Я б с радостью, ток с моим инетом я даже картинки ...   19.7.2008, 22:23
-=Strelok=-   Разобрал Suprema ezxcodeс'ом вроде всё собрал ...   20.7.2008, 8:02
VITEK1987   А что насчёт скинов ? :(   20.7.2008, 11:32
AstaRoth   Йа Санёг, ленг обычный и не встанет -так как Supre...   20.7.2008, 20:43
uxobryux   Прошился второй супремой... Проц разогнан 208/312...   21.7.2008, 8:54
BALU   дайте скин на тему висты отдельно как на скринах с...   21.7.2008, 16:24
uxobryux   За время тестирования никаких глюков не замечено, ...   23.7.2008, 5:49
Av3LaR   Ну я рекомендую также более 1 FW, что я один утра ...   28.7.2008, 4:27
AstaRoth   Av3LaR, напиши адрес вашего сайта - зайдем -псмотр...   28.7.2008, 8:29
Av3LaR   Надеюсь, вы меня понимаете. Я использую Google буд...   28.7.2008, 14:51
mEASYn   я не очень понял, что там за прозрачный баланс с т...   28.7.2008, 18:23
uxobryux   Официальный сайт http://graphiclatino.foroactivo.c...   28.7.2008, 18:37
AstaRoth   Камрады - млин-чесн слово ненарадуюсь-у нас Аргент...   28.7.2008, 21:16
wink   AstaRoth, как скачаешь, SuperКролик'а выложи b...   29.7.2008, 5:06
uxobryux   Прошился... Меню 3*3. Прошивка обладает дикой поме...   29.7.2008, 8:33
eXeTeR   # - Включает в себя 5 сочетанием кожи # - Цвет кож...   30.7.2008, 13:58
eXeTeR   Еще один монстр от китайчегов Оригинал топика [ur...   30.7.2008, 14:19
AstaRoth   http://www.aktaeon.com/ -тут Бета Ревивала , ко...   31.7.2008, 18:25
eXeTeR   [url=http://www.aktaeon.com/]http://www.aktaeon.c...   1.8.2008, 10:54
PhoeniX-7   при всем уважении к тебе ты бы не мог ввыложить с...   1.8.2008, 17:21
Morrow   при всем уважении к тебе ты бы не мог ввыложить с...   7.8.2008, 9:51
2life   Мне удавалось! :) И не только монстра, но и в...   7.8.2008, 10:49
MoToR-RuleZZZZ!   Прошился на Зина2.Вроде норм, только проги там все...   1.8.2008, 18:22
Av3LaR   микропрограммы не являются новыми, они были освобо...   3.8.2008, 22:18
MoToR-RuleZZZZ!   Нет, так тож не русифицируется :(   4.8.2008, 14:17
IRAN   2life, описал бы его малость что ли   7.8.2008, 12:22
2life   Только поставил. Вот отписываюсь: - Сделана на о...   7.8.2008, 12:42
MoToR-RuleZZZZ!   Только поставил. Вот отписываюсь: - Сделана на ...   7.8.2008, 13:22
moned   Народ, у китайцев интересный монстр нашёл как я по...   8.8.2008, 21:21
kobr   Morrow, Ты бы объяснил,в чём они нас обогнали,оче...   8.8.2008, 22:33
MoToR-RuleZZZZ!   moned, ты не мог бы кинуть прямую ссылку на этот м...   8.8.2008, 22:37
DDSH   ее не было, нет и не будет   9.8.2008, 8:01
moned   Ещё один монстр - http://moto.it168.com/thread-361...   9.8.2008, 22:08
AstaRoth   © нашел там Ezine2 http://i252.photobuc...   11.8.2008, 22:24
Vadimchik   Поставил себе Ezine2. Монстр довльно шустрий наве...   12.8.2008, 13:55
tim apple   Vadimchik, что скажеш об этом ?   20.8.2008, 7:46
Vadimchik   tim apple ну это я не понял что оно значит, 3-D ...   20.8.2008, 10:01
antoffka   А где скин взять Freedom не подскажете?   14.11.2008, 16:34
Slim_Shady   привет. если у кого то есть монстр Супрема выложит...   14.11.2008, 21:51
AstaRoth   ROKR Elysion 49P http://dc46.4shared.com/img...   16.11.2008, 10:27
sasha26   И чё за монстр? отпишите кто поставил как впечатле...   16.11.2008, 11:14
AstaRoth   ROKR E2 DIY+(V2.0) from THEY2008 Оригинал у Вь...   16.11.2008, 17:23
sasha26   Никак немогу сккачать ROKR E2 DIY+(V2.0) from THEY...   17.11.2008, 14:21
sorcer333   Поставил ROKR Elysion 49P, ничего особенного,звук ...   18.11.2008, 12:02
sasha26   Поставил себе ROKR E2 DIY+. Пока на ней посижу пар...   19.11.2008, 16:17
AstaRoth   sasha26, есть ли фичи каллейдоскопа? (диспетчер за...   20.11.2008, 8:07
sasha26   AstaRoth, я влючал и выключал линк сис толку О. :a...   20.11.2008, 13:05
AstaRoth   E2 Legend: The Tyrant Predecessor http://img5...   29.12.2008, 9:41
Semen.tdvd   монстр не очень понравился....медленный... тормоз...   29.12.2008, 22:19
Constant   а скин из него кто выложит? ) или уже есть где-то?   30.12.2008, 8:04
Semen.tdvd   Constant, https://forum.motofan.ru/index.php?act=A...   30.12.2008, 12:59
GreY_FoX   Нашел какого-то монстра, вроде ничем сильно не отл...   15.2.2009, 13:56
AstaRoth   Монстр: 09.02.07_Kaleidoscope_Patriotism_AP+BP ...   18.2.2009, 17:02
-=Strelok=-   Монстр: [FW] Zero 4AP--Tyrano Series Источник] Ска...   25.3.2009, 9:16
-=Strelok=-   Кто затестит отпишитесь - с мну +)   30.3.2009, 19:48
GreY_FoX   Кто затестит отпишитесь - с мну +) последние с...   30.3.2009, 20:51
Kirill111111   :ph34r: чем?   31.3.2009, 7:32
sasha26   [FW] Zero 4AP--Tyrano Series я шил себе такой :P ....   31.3.2009, 18:54
AstaRoth   Я прошивал БП- ничего не изменилось- так что относ...   31.3.2009, 19:07
sorcer333   поставил себе MP Rokr Gsmmod Normal 29.01, море г...   5.4.2009, 17:06
sasha26   sorcer333, а где ты такой монстр нашол? кинь ссылк...   5.4.2009, 19:06
PItBuLL   sasha26, а ты на предидущую страницу не пробывал з...   5.4.2009, 19:37
sorcer333   sasha26, лучше не ставь   7.4.2009, 9:23
AstaRoth   http://modmymoto.com/forums/showthread.php?t=48132...   9.6.2009, 21:54
sorcer333   Поставил его себе, понравился скоростью. Баг нашел...   14.6.2009, 9:13
sorcer333   Вроде не плохой монстр http://www.gsmmasters.com.b...   18.6.2009, 18:15
antoffka   http://www.gsmmasters.com.br/forums/showthread.php...   19.6.2009, 20:47
Snowboy   прошил португальский монср немогу русифицировать. ...   2.7.2009, 5:23
sorcer333   Я просто шил русский лэнг   2.7.2009, 5:40
T3D   Snowboy, ты хотел папку /usr/language перезаписать...   2.7.2009, 5:40
sorcer333   Вот еще один монстр http://webfile.ru/3747068. Сюд...   2.7.2009, 5:54
Snowboy   Vilogite pliz rusifikator kotoriy mogno prohit che...   3.7.2009, 22:04
BALU   вот лови руссик к едва R564_G_12.02.46P_gsm_sumat...   4.7.2009, 7:05
Snowboy   Есть у кого-нибудь программа heapsize как в монсре...   5.7.2009, 6:53
PItBuLL   Snowboy, вот.   5.7.2009, 8:03
eXeTeR   [FW] Zero 4AP--Tyrano Series - очень хороший монст...   6.7.2009, 16:41
2 страниц V  1 2 >
Выкладываем сюда новые МОНСТРЫ, Ищем и выкладываем хотя бы ссылки:BlackStorm,Suprema,Titanium,OnlyYou · Motorola ROKR E2, A910, A910i, E895 · Forum
Текстовая версия Сейчас: 11.8.2025, 23:30
