the way to port patch from this phone to another phone !
anhvu2875
сообщение 23.2.2008, 13:07
Пользователь №: 152 593
someone can show me where can i learn how to port patch from phone to another phone , such as V3i patch to K1 patch ! thanks to all !
сообщение 23.2.2008, 13:40
Translate this subject matter
МегаFAQ по Созданию, Портированию и Применению Патчей ! только в этой теме !
anhvu2875
сообщение 23.2.2008, 15:34
QUOTE(Osta @ 23.2.2008, 13:40) *
thank u very very much Osta ! i really need this !
anhvu2875
сообщение 24.2.2008, 0:37
Osta , i follow that guide and i also can find new offset for K1 from L7e patch , but after i apply that patch , my K1 just boot on with white screen !
and do i need add '' 0 '' to offset ! such as when i have 1452C offset , do i have to add '' 0 '' to become 0001452C ?!
сообщение 25.2.2008, 8:53
You want that we have found or itself to learn?
anhvu2875
сообщение 25.2.2008, 11:13
QUOTE(Osta @ 25.2.2008, 8:53) *
Semseddin
сообщение 29.2.2008, 20:18
Из: Turkiye
Пользователь №: 109 141
Модель телефона: Semseddin
Прошивка: Razr2 V8
Hello all,
@Osta,
I also want to learn to port patches but google translate doesn't translate the russian guide well. This's a risky process and if we do anything wrong caused by wrong or missing translation, We may say goodbye to phone.
I hope you or some other member of Motofan family could write an english guide for porting patches.
Greetings, Semseddin.
anhvu2875
сообщение 3.3.2008, 10:58
yeah , i did it thanks to all !
Scalar
сообщение 4.3.2008, 22:34
МотоЙожег
Из: Буржуевск
Пользователь №: 27 766
Модель телефона: C 350/380/650 V535
Прошивка: R999_FF.FF_FF.FFR
"How to port patchs"
With this instruction you can port any easy patch.
Needed Soft: SHXCodec and any HEX-editor (WinHex for example)
We have two firmwares :
1) Already Pathed Firmware
2) Firmware , needs to be patched
Open any patch file (*.fpa) in text-editor , you can see that all patches have two main blocks:
[Patch_Info]
and
[Patch_Code]
in [Patch_Code] section we can see offsets and data, must be writed to this offsets in firmware.
for example path
[Patch_Code]
004BDFE4: AABBCCF0F1F2F3
will find offset 0x4BDFE4 in firmware and overwrite existing data with 7 bytes (AA BB CC F0 F1 F2 F3).
but we can't apply this patch to any other firmware, because it has different offset for this data.
So we must port this patch:
1) Open "Already Pathed" firmware file in SHXCodec, and separate it to code groups.
After that you can find Code Groups smg files in the firmware directory.
2)Open CG1 smg file in Hex-Editor, go to our offset 0x4BDFE4.
You can see 7 bytes at our offset : E3 50 00 0E 0A 00 00 - it is our pattern;
IPB Image
3) Open "needs to be patched" firmware in SHXCodec, separate it to code groups, and open CG1 in
HEX-Editor
4) Find our pattern in file , look at offset , and write it into PathFile
for example, if you find our pattern at offset 459F1C :
[Patch_Code]
00459F1C:AABBCCF0F1F2F3
Сообщение отредактировал Scalar - 4.3.2008, 22:36
Semseddin
сообщение 5.3.2008, 3:36
Из: Turkiye
Прошивка: Razr2 V8
Thanks friend. It's going to be very helpful.
the way to port patch from this phone to another phone ! · For English speaking members · Forum
Текстовая версия Сейчас: 28.7.2025, 1:48
