|L7e MP| "RHYTHM OF LIFE (iTUNES)" зарубежный патченный монстр, прошивать его ТОЛЬКО после снятия RSA !
сообщение 13.3.2008, 14:23
Сам не тестил (поэтому делайте бекапы в том числе и PDS !!) нашел на
http://www.modmymoto.com/forums/showthread.php?t=62290 Для тех кому скучно
скриншот http://www.freewebs.com/rhmotozone/cover.jpg
RHYTHM OF LIFE (iTUNES) MP
on
R452D_G_08.01.0AR
Flex:
GSTHAWAIIHGIN082
DRM :r452d_g_08.02.06r_drm0101
1) Video camera resolution is set to CIF (352x288) by default (no need to enter menu and set resolution there).
Quality settings are also unlocked and you can save videos to the phone memory (not only memory card) when capturing at that resolution.
2) Lots of patches from Motofan are applied: recent calls lists are not cleared after changing sim card;
entering main menu by pressing Menu and * in different situations (e.g., while transferring files via bluetooth);
web sessions can be set as default by pressing the send key; redialling interval changed to 7 seconds instead of 1 min;
voice recorder does not send regular beeps to the other party; keypad lights can be switched on/off from the menu;
‘battery low’ sound interval increased 5 times (for people with good memory); reduced ‘keypad locked’ window so the clock is now visible
(skin must place the clock in the upper portion of the display); different ringtones for calls and messages from a contact;
modified and extended keypad layout for entering symbols; usb charging can be enabled/disabled from the menu;
changed zoom levels in the picture viewer; optimised video fast forwarding/rewinding during playback.
3) Alarm clock: Alarms can be enabled/disabled using the send key. Alarm is not disabled after going off, it will remain on for the next day
(it can be disabled only from the alarm clock menu). Snooze interval changed to 5 minutes instead of 8.
Both alarm names and times are displayed in the list.
4) Java:
Java Heap increased up to 1400K which has a positive effect on applications like Opera or Jimm;
Java apps can run while usb cable is connected; corelets are visible in the application lists; java signature verifications are removed
(no need to replace certificates, just set java permissions to ‘Never ask’). Java apps have access to the phone file system (including system files),
corelets have access to some seems, kjava folder is visible in OBEX mode. The Itunes works !
You can send java apps via bluetooth or copy them to phone memory/memory card using the send key.
Short press of the voice key selects storage devices. DRM protection when downloading content is removed.
5) Vibro "Point" at a raising of a tube of the subscriber. Vibro "Point" at connection on BlueTooth.
Skins :
1) Win Xp
2) ipod
3) w880
4) Walkman Milk
Java Applications :
1) iTUNES
2) Opera Mini 2.0
3) Mig33 Plus !
4) Asphalt 2 v1.0.2 (Games)
5) File Protect
Extra :
1) keypads Lights Are on.
2) Record Video In Mp4
3) Funlight are Enable
4) Engineering Menu Avaiable
5) Multimedia Sound Is Loud And Clear
6) New iTUNES Bootscreen
7) iTUNES Icon In Multimedia
8) Sms store in Sim
9) Call Guard
при прошитии рекомендую снять галочку с прошития ленгпака
т.к. скорее всего нерусский стоит.
ссылка для скачивания ==>>> https://motofan.ru/firmware/?action=view&id=1097
Pieeer
сообщение 13.3.2008, 16:05
Из: Нижний Новгород
Пользователь №: 120 756
Модель телефона: l7e, E2, Е3
Прошивка: 0AR, Maxx E2
сообщение 13.3.2008, 16:37
Цитата(Pieeer @ Сегодня, 18:05)
Поддержим наших производителей!!)))
они на моём рефлеше :-)) основаны
beat_lis
сообщение 13.3.2008, 18:27
Пользователь №: 124 357
Модель телефона: V3x
Прошивка: LifeTec for V3x V2
Только хотел сказать, неуспел :-) Это же почти полная копия...Время покажет...
JKmoto
сообщение 13.3.2008, 19:11
Пользователь №: 111 708
Модель телефона: RIZR Z3
Прошивка: HYBRID v0.3
Osta респект, и уважуха,
а "разработчикам" монстра позор, своего они ничего в монстр не внесли или монстр делался по мануалу по использованию SHXcodec? - Разбираем файл прошивки, бросаем в папочку дрм скачаный с какого то сайта, ленг в етуже папочку, в другую папочку разбираем файл рефлеша от Osta (кстати, Osta а у тебя разрешение на использование твоего рефлеша в "монстре"спрашивали?), все файлики из етой папочки кидаем в нашу первую папочку, собираем файл прошивки, прошиваем монстр, устанавливаем скины, заливаем чужые симы (наверно самий сложний етап в разработке етого "монстра") и ставим https://forum.motofan.ru/index.php?showforum=146 iTunеs, сливаем бекап монстра и сохраняем монстр в формате SHX."Монстр" готов.
сообщение 14.3.2008, 7:09
не сильно , но ребята хорошие , зря вы их хаете. :-)
прошу отписыватся в теме только по данному монстру.
Kirillos
сообщение 14.3.2008, 11:46
Из: Питера
Пользователь №: 161 627
Модель телефона: Motor l7e
Прошивка: new style v2.1
Сообщение отредактировал Kirillos - 14.3.2008, 11:47
сообщение 14.3.2008, 12:49
Цитата(Kirillos @ Сегодня, 13:46)
а где ссылка на скачку?
закинул к нам на сайт , качайте ->> https://motofan.ru/firmware/?action=view&id=1097
Kirillos
сообщение 14.3.2008, 12:52
Из: Питера
а реально как нибудь сделать ее русской?
сообщение 14.3.2008, 12:58
а ты напиши, что в ней не-русского , может скажем как переделать
Offset
сообщение 14.3.2008, 15:29
Leo
Пользователь №: 126 712
Прошивка: 2BR
Osta, он думает про ленг наверно!
Kirillos, просто не шей CG4..как и сказал Osta в конце своего поста с монстром spiteful.gif
Hornor
сообщение 26.3.2008, 6:42
Пользователь №: 131 634
Извинити что не в тему написал
у меня проблема хотел скачать прошивку на сайте http://www.modmymoto.com
по ссылке http://www.modmymoto.com/forums/downloads....ile&id=8701 как нажимаю кнопку скачать выходит такая шляпа:
XXXXXX, you do not have permission to access this page. This could be due to one of several reasons:
Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system?
If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation.
в английском я не силен (
jamp
сообщение 26.3.2008, 7:04
Из: Донбасс
Пользователь №: 108 557
Модель телефона: L6+L7e
Прошивка: R452D_G_08.01.0AR
Hornor,
Нужно быть зарегестрированным на этом сайте, качай с мотофана.
ALEX 911
сообщение 27.3.2008, 17:11
Из: Минска
Пользователь №: 156 858
Модель телефона: Motorola L7e => L9
Прошивка: >>NewStyle© v2.1<<
Поставил недавно этот патченный монстр и действительно
Art
сообщение 4.4.2008, 14:08
Walk of life
Из: Череповец
Пользователь №: 53 496
Модель телефона: Moto Z Force
хорошо
хочу сказать, что даже и основано на рефлеше Осты, но рефлеш то совершенно другой, 06R. Портировать патчи не так то просто. Рефлеш как знаю новый, уже интересно smile.gif и айтюнс на вид цивильный а не то что у нас валяется. поставлю, и отпишусь smile.gif
Сообщение отредактировал Art-21 - 4.4.2008, 14:14
сообщение 4.4.2008, 14:11
это почему же?
Art
сообщение 4.4.2008, 18:40
Walk of life
Из: Череповец
хорошо
твой OAR. Этот по заявкам 06R. smile.gif вот и всё. сорри если что не так, и если я в чёмто ошибся.
Сообщение отредактировал Art-21 - 4.4.2008, 18:44
Barsik_s_L7e
сообщение 4.4.2008, 18:47
Из: Каменск-Уральский
Пользователь №: 160 949
Прошивка: NewStyle2+Elfs
Art-21 ну как успехи?? И всё таки OAR или 06R? И стоит ли вообще его ставить?
Сообщение отредактировал Barsik_s_L7e - 4.4.2008, 18:49
Offset
сообщение 4.4.2008, 19:04
Leo
Прошивка: 2BR
Barsik_s_L7e, инет анлим? Хочется экстрима?-качай, но толку от этого монстра не вижу! разве что скины(уже давно всё есть в инете) ДРМ?-тоже есть в инете. больше там ничего интересного нет! и монстр всё же на OAR! так как мы все знаем что рефлеш от Осты на OAR, и только на этой прошивке! Как всегда от буржуев ничего путного ждать нельзя...
Сообщение отредактировал Motovelo - 4.4.2008, 19:15
сообщение 5.4.2008, 7:18
по каким ещё заявкам ? чёт ты это.. температуришь видать...
я прекрасно знаю автора этого монстра , общались на модмимото
тебя наверное смутила строка , что drm от прошивки 02.06R ? вот тут
RHYTHM OF LIFE (iTUNES) MP on R452D_G_08.01.0AR
Flex: GSTHAWAIIHGIN082
ну что ж ... бывает. и I-tunes наш мотофановский :-) перевели некоторые слова на англ.+скины на него (на Итюнс)
Art
сообщение 5.4.2008, 12:22
Walk of life
Из: Череповец
хорошо
Сообщение отредактировал Art-21 - 5.4.2008, 12:36
Barsik_s_L7e
сообщение 5.4.2008, 17:44
Понял Art-21, ставить не буду... инет анлим, угадал) И спасибо за тест, а то точно скачал бы...
wanted90
сообщение 16.6.2008, 17:16
Из: Тольятти
Пользователь №: 160 168
Модель телефона: v3i+E398+L7+L7E
Прошивка: <new style v 2.1>
Barsik_s_L7e,
а я скачал и поставил.....
Сообщение отредактировал wanted90 - 16.6.2008, 17:16
TitMan
сообщение 6.8.2008, 18:50
Пользователь №: 102 580
Прошивка: 42r
как скачать ....нажимаю на ссылку скачать а страница перегружается??? Или посоветуйте хорошего монстра с iTunes и доступом к ФС... а то по поиску ничего не находит! Просто все говорят есть лучше монстры, но не могу найти ...Пожалуйста помогите!
Сообщение отредактировал TitMan - 6.8.2008, 19:32
сообщение 7.8.2008, 6:04
для модели L7e или какой?
вот так качай
сообщение 16.8.2008, 7:26
Цитата(TitMan @ Вчера, 20:08)
Да для L7E!
с Итюнсом для l7e один монстр |L7e MP| X-Moto v1.4 for L7e
сначало нужно снять рса
Цитата(TitMan @ Вчера, 23:35)
Не могу скачать ...Нажимаю ссылку, отвечаю Да!, и перезагружается страница!
прямая ссылка https://motofan.ru/files/firmware/X-Moto_v1.4.rar
Demonskii2
сообщение 8.9.2008, 17:37
Пользователь №: 170 964
Модель телефона: motorola l7e
а как и какой прогой монстра залить А?
bob55
сообщение 8.9.2008, 18:01
МОТО-ДЕД
Из: Орел Россия
Пользователь №: 141 970
Прошивка: NewStyle© v2.1
Demonskii2, тебе это надо? Небось и RSA ещё не снимал. Экстрима захотелось, а потом изучать тему по поднятию убитых тел?
Сообщение отредактировал bob55 - 8.9.2008, 18:04
dimson_1990
сообщение 4.11.2008, 8:26
Пользователь №: 173 990
Помогите!! поставил эту прошивку, залитие на телефон прошло успешно вот только телефон вообще не включаеться даже подсветка не загораеться((((что делать??? до неё стоял вот этот монстр NewStyle v2.1
DeCo793
сообщение 4.11.2008, 9:56
Пользователь №: 178 471
Модель телефона: MotoSLVR L7е
Прошивка: FlexNewStyle 2.1
dimson_1990, Тебе поможет только ТП как я понял у них бут другой.
dimson_1990
сообщение 4.11.2008, 14:28
Спасибо))) всё получилось
qurert
сообщение 12.3.2011, 13:02
Пользователь №: 183 532
Модель телефона: L7-e, E-398, C-650
у меня не получается изменить настройки звука, даже прошить не получается, при прошивке нажимаю переход во flash-режим, телефон ребутится???
сообщение 12.3.2011, 16:54
не настроен FB и к тому же наверное не снята РСА?
qurert
сообщение 13.3.2011, 6:17
нет ,рса снята, у меня стоит уже эта прошивка, просто я хочу перепрошиться на другую (x-moto), а не получается ,ребутится мобила
Сообщение отредактировал qurert - 13.3.2011, 6:17
сообщение 13.3.2011, 9:05
перейдите через софт-ТП
|L7e MP| "RHYTHM OF LIFE (iTUNES)" зарубежный патченный монстр, прошивать его ТОЛЬКО после снятия RSA ! · Кастомные прошивки для Motorola RIZR Z3, KRZR K1, W490, W510, ROKR W6, SLVR L7e, L7i, L7x, L71, L72, L9 · Forum
> Быстрый ответ
Текстовая версия Сейчас: 24.8.2025, 6:54
