8 страниц V « < 6 7 8
Elfs by motoedy[China], new:more elfs 05.09.2009
Campanula
сообщение 15.8.2008, 1:58 Закрепленное сообщение!
Пользователь №: 176 749
Welcome to China motoedy smile.gif www.motoedy.cn
http://translation2.paralink.com + http://translate.google.com/translate_t
newHITMOUSE by hantao
1,2,3,4,5,6,7,8,9
Exit: Red
Author: om2804 tim apple Editorer: 四夕 & 林子 L7E/L9: lpktool
Thanks to om2804 tim apple
new LRCPlayer_DesktopshowLRC_1.3
Прикрепленный файл LRCPlayer_DesktopshowLRC_1.3.rar   ( 480.3 килобайт ) Кол-во скачиваний: 881
[Updated 09-08-01]
Lin LRCPlayer_ modified version V1.3
[+] Add lyrics contour, in BG_LRC.CFG color profile settings in the settings to add "show the outline of the lyrics" set;
[+] When did the lyrics, the screen does not display lyrics and other non-related tips;
[+] To remove the panel in the A site or C site settings, the program will automatically determine which disk;
[+] LRCPlayer.lng documents are updated, LRCPlayer.cfg document changes to the original part used to re-configure the settings (such as the use of IT to start, etc.);
[Updated 09-07-30]
Lin LRCPlayer_ modified version V1.2
[+] Amendment can not be deployed for panel icon panel issues;
[+] When a song did not amend the LRC, the desktop display lyrics on a problem;
[+] Icon shows a high degree determines the number of rows and a high of 20 for his party, would like to show you a few lines of lyrics
[+] Can call with the panel and different icons and configuration, will be on the panel BG_LRC.CFG and BG_LRC.GIF document under the folder DeskTopFile; not call the default program directory;
[+] In setting a "desktop display the lyrics" and "show-screen lyrics when Changliang" choice;
~ 12.06.2009 ~
[LRCPlayer 1.3]
Hard-won source ah
* Based on modifications made to Tunes3.9
* Play button changes the interface is as follows:
123, respectively, for the side and so on, flash, screen
5 for the current playlist
8 on
7 players on the grounds to the lyrics of the skin interface interface
9 on the grounds the lyrics to the player skin interface interface
* Reduce the volume
# Increase the volume
0 to mute
Other operations with Tunes3.9
still lrc.cfg address for GBK encoding, LRCPlayer.cfg the last 2 bytes in order to initiate a 16-band event code
new Memorandum_Simplify the locking version
Прикрепленный файл Memorandum_Simplify_the_locking_version.zip   ( 9.92 килобайт ) Кол-во скачиваний: 556
new HDautoplay1.5
Прикрепленный файл HDautoplay1.5.zip   ( 2.48 килобайт ) Кол-во скачиваний: 513
Its working principle: plug in your headphones to monitor the incident code, and monitor the core event code (0404, that is, start-up events LRCPLayer.elf/Tunes.elf, when you start the event of LRCPlayer/Tunes.elf code changes, so please direct HEX to 0404 start for your event LRCPlayer/Tunes.elf code), auto-play button to use the simulation
To work only on the desktop
Lock Application--->Headset
Locked--->autoplay
Unlocked---> unautoplay
maybe only for 79R
RamEdit :
Redmenu_mod (ELF&SRC)
gif:L"*.gif"
CODE
Ring Styles=0936
ZtxtEdit=file://a/MotoCmd/Ztxtedit.elf
CODE
For 79R:
Power off=17
Silent power off=0000
Reset=0001
Switch in BOOT=0003
Unload Java=1806
MachoSettings=0973
Tunes=1889
MotoCMD1.8=0985
OPcode=2011
Personalise=0942
Initial Setup=0943
Message=1025
Video Camera=1021
Camera=1019
Bluetooch=1789
USB Settings=1022
Alarm Clock=1001
Datebook=8378
Skins=3237
Shortcuts=0929
Ring Styles=0936
pp_lrc_1.7.1
Прикрепленный файл ppplayerv1.7.zip   ( 135.61 килобайт ) Кол-во скачиваний: 816
* Revision of the map in support of GBK, shows in simplified and traditional Chinese \ Sun Wen \ text of the stick ..
* Cancel version of the patch did not play ... GBK's patch map, garbled show ..
* Some small bug amendment ..
* Only version of the patch
This version of the six, to see the name of the folder you know the type:
If, desktop_walkman, on behalf of the desktop that shows the time, the interface for the walkman
The rest and so on (Note: iris for the past Xiaoyu's colorful interface)
Another: a patch version of the map for migration 0x10c3e800 (increase has been offset start-CG1), non-offset this, please make its own decisions
Revised: 16 hexeditor (such as UltraEdit32, etc.) to open elf, search 0x10c3e800, replace your address migration
PP_reader_1.1
Прикрепленный файл ppreader_no_patch.zip   ( 26.93 килобайт ) Кол-во скачиваний: 526
Прикрепленный файл pp_reader_v1.1.zip   ( 98.57 килобайт ) Кол-во скачиваний: 622
Increase:
1, to support the GBK code, that can display traditional.
2, in the setting / folder under map.set document offset patch, the hex address of the patch + CG1 address, I provided a patch for the use of 398. 398 can not use the default for 0x10C3E800.
3, at the right point in time to read software code to open the menu option to resolve the utf_8 file to open in the first few garbled.
1, the English word would be forcibly cut off, did not get
2, does not support L7E ...
3, to replace paper map, the size of 47k.
Patch file also changed, and 398 in place are adequate.
Other models to find your own! ! !
After the test, did not play in the system memory of the 398 patch can not run on non-patch version! ! !
Color Clock
1.6
Прикрепленный файл Color_T_v1.6.zip   ( 9.53 килобайт ) Кол-во скачиваний: 601
Color_T v1.3
Прикрепленный файл Color_T_v1.3.zip   ( 69.38 килобайт ) Кол-во скачиваний: 701
Author: Kalvinxp (bimonthly)
Source: EDY Прикрепленное изображениеПрикрепленное изображениеПрикрепленное изображение
0 1 2 3 4 5 ... F
0x00000000 XX XX XX bond packages
0x00000010 XX XX clock line coordinates of the clock ordinate
0x00000020 XX XX XX hours of high color
0x00000030 XX XX XX hours of low color
0x00000040 XX XX XX isolation: the color
0x00000050 XX XX XX high-minute color
0x00000060 XX XX XX low-minute color
0x00000070 XX XX XX XX XX XX this line of the first byte as a font type, 2 bytes for the border or shadow (0 without any results,Plus 1 frame, plus 2 after the shadow of the shadow of the former plus 3); the first 3-5 bytes for the effect of color ,No. 6 bytes for the digital space
PS: XX on behalf of a byte
ElfOpen2.4.1
Прикрепленный файл ElfOpen_2.4.1.zip   ( 27.14 килобайт ) Кол-во скачиваний: 673
thanks for om2804!
mma_ucp:
Phone book
Dialling services ---- Quick dial, voice dial, and attribution for (Fixed dial), Incall setup, RecentCall, Call Forward
Message
Security
ELF & JAVA procedures ---- JAVA procedures, MOTO Manager (AIM), ELF (mixing machine), FELX procedures (WEB shortcut), SEEM editor (Mobile QQ), HEX editor (themes)
Access to the network ---- browser, StoredPages,WebHistory,GotoURL,BRWSetup,WebSessions
Multimedia---- Sounds,Pictures,Video,ITUNES,Camera,VideoCamera
Tools ---- alarm clock, DateBook, calculator, voice record, data backup tools (IM), SIM APP
settings----Personalize,IntlSetup,JAVAtools,CarSetting,PhoneStatus,FEM
MMRingStyle
Shortcuts
Connection ---- Bluetooth, USBSetting, sync, network, airpin mode, headset
03FC instant messaging (IM)
03D1 (chat room)
03DF (AIM)
03ED (WEB shortcut)
03DE (themes)
03D9 (Mobile QQ)
039A (fixed dial-up)
Please use P2KTOOL hidden settings
The more open, and then put mma_ucp
The MMA for the E398. Other models, a separate production ~
new
Backupsms
Прикрепленный файл backupsms__09_08_31.zip   ( 14.28 килобайт ) Кол-во скачиваний: 495
CODE
IN1=0x04E6
IN2=0x04E7
OUT1=0x07CD
OUT2=
PATH=file://b/backups/
CODE
[SMST]
app=/b/Elf/MotoCmd/smsv.elf
type=id
09-08-31
Amendments to the multi-page copies of reading support. (Known Bug: Unable to get part of the recipient)
Skin.elf
CODE
[SKI]
app=/b/Elf/MotoCmd/Skin.elf
type=id
new
Auto change skin when you startup your phone
Skins in dick a
Skins in dick c
Please add to AutoRun
PP_DnpEditor:
Прикрепленный файл PP_DnpEditor.elf   ( 19.44 килобайт ) Кол-во скачиваний: 784
UnRAR/Un7z:
CODE
[RAR]
app=/b/Elf/MotoCmd/unrar.elf
CODE
[7z]
app=/b/Elf/MotoCmd/un7z.elf
6Elfs only for 79R
Gomeno(Lock Application --> JAVA APPS)
flashlight on VOICE + VOICE :
Lockvideo(Lock Application --> Headset)
Screener picture:
newPlug-in for MotoCMD: ConfigEditor oт 林子 English Verson by Last1left
Прикрепленный файл ConfigEditor_eng.zip   ( 8.35 килобайт ) Кол-во скачиваний: 521
для редактирования файлов: .res .ini .menu .lng.run
CODE
[INI]
app=/a/Elf/MotoCmd/ConfigEditor.elf
[MENU]
[RES]
[LNG]
[RUN]
new DEC HEX BIN Converter oт 林子 English Verson by Last1left
Прикрепленный файл NumBasis_eng.zip   ( 6.38 килобайт ) Кол-во скачиваний: 438
new Motocmd2.0
QUOTE(Fenja @ 1.9.2009, 17:43) *
Campanula, in what of difference between MotoCmd.elf, MotoCmd-DDRM.elf, MotoCmd-DXDRM.elf?
CODE
MotoCmd.elf don't need Icons
MotoCmd-DDRM.elf is old Verson
Please use MotoCmd-DXDRM.elf
Icons for MotoCmd
Please add in your DRM!(CG15)
695                 mp3.amr .m4a .mid
696                 device
697                 dir
698                 txt .umd .doc .lng .lrc .smst
699                 elf
700                 exe
701                 html
703                 jad
704                 jar
705                 main
706                 null
707                 rar
708                 sys
709                 video.3gp .mp4
710                 zip
711                 ini .cfg .set .run .lib .rlt .rm .pat
712                 mei .jc
713                  Waiting..
CODE
Register=0x03DC
Map=110F0824
Sytem=0;Hidden system files: 0/no 1/yes
ReadLast=1;Read last open Folder: 0/no 1/yes
ChangeType=1;Scroll Display file names : 0/no 1/yes
UseZipBrowser=1;ZIP Browser Switch:1 use MotoCmdZIP, 0 use MotoCmd Plug-in(UnZip.elf)
BookDir=/a/Elf/MotoCmd/bmk/Ebook.txt;file of BookDir
AutoDir=/a/Elf/MotoCmd/AutoRun.elf;file of AutoRUN
DrmDir=/a/Elf/MotoCmd/Adddrm.elf;file of Adddrm
HexDir=/a/Elf/MotoCmd/HexEditor.elf;file of HexDir
TxtDir=/a/Elf/MotoCmd/Ztxtedit.elf;file of TXTEdit
[MEI]
app=/a/Elf/MotoCmd/ElfInstaller.elf
[JC]
app=/a/Elf/MotoCmd/Jc.elf
[GIF]
app=/a/Elf/MotoCmd/Iv.elf
AutoRun for MotoCmd2.0, No AutoRun
Adddrm for MotoCmd2.0,Plaese Add to AutoRun
Example:b/Moto/Drm/Green/329-336.gif
Open MotoCmd2.0,You can Long press 0,Then Press Menu,Update battery pack.
QUOTE
map is our Chinese Transcoding
For example:
Map=110F0824 ,This is a patch of gb2uc. It's used to gbk to uc
UnZip.elf PP_lrc.elf LRCPlayer.elf MotoCmd.elf ....must to use this patch (Map=10C3E800)
ZtxtEdit.elf use 3 maps
1:patch (Map=110F0824) :gbk to uc
2:gb2big5.map : gb to big5
3:uc2gbk.map : :uc to gbk ,This is used to edit txt.
Russian friends, British friends ,Do not need to use maps....
give you the src of ZtxtEdit , MotoCmd2.0.0.1 and LRCPlayer1.4
Прикрепленный файл motocmd2.0_scr.rar   ( 165.03 килобайт ) Кол-во скачиваний: 443
Спасибо всем разработчикам эльфпака и эльфов!
Сообщение отредактировал Campanula - 6.9.2009, 6:55
Прикрепленный файл ElfOpen_2.3.1.zip   ( 33.39 килобайт ) Кол-во скачиваний: 547
Прикрепленный файл ElfOpen_2.3.zip   ( 32.16 килобайт ) Кол-во скачиваний: 356
Прикрепленный файл LRCplayer_1.1.zip   ( 179.46 килобайт ) Кол-во скачиваний: 547
Прикрепленный файл Color_T_1.1.zip   ( 81.69 килобайт ) Кол-во скачиваний: 734
Прикрепленный файл Color_T_v1.2.zip   ( 68.73 килобайт ) Кол-во скачиваний: 509
Прикрепленный файл LRCplayer_1.2.1.zip   ( 363.82 килобайт ) Кол-во скачиваний: 858
Прикрепленный файл LRCplayer_1.2.zip   ( 189.02 килобайт ) Кол-во скачиваний: 978
Прикрепленный файл LRCPlayer_1.3.zip   ( 440.51 килобайт ) Кол-во скачиваний: 436
Прикрепленный файл backupsms__09_6_20.zip   ( 13.7 килобайт ) Кол-во скачиваний: 424
Прикрепленный файл Memorandum_V1.0.zip   ( 18.46 килобайт ) Кол-во скачиваний: 468
Прикрепленный файл backupsms__09_6_23.zip   ( 15.07 килобайт ) Кол-во скачиваний: 435
Прикрепленный файл Memorandum_V1.1.zip   ( 176 килобайт ) Кол-во скачиваний: 581
Z.d.u.n.e.X
сообщение 10.11.2009, 16:51
Из: Poland
Пользователь №: 186 451
Модель телефона: LG GT540
Прошивка: Android
CallFilter v1.0 by Lin
[2009-11-04]
Manager call management
+ info in CallFilter.txt (will be create automatically in elf folder)
CFG:
1 byte:
CODE
3 This phone is invalid
17 what you call the phone number is empty
20 This number is limited to
21 You call the time being no one answered the phone
24 This phone does not exist
26 Please check the status of network services
28 Network busy
2 byte:
CODE
0 - ignore numbers from CallFilert.ini file
1 - accept numbers from CallFilert.ini file, ignore rest
3-5 byte: exit, default= 9+8+7
INI:
here write numbers
XX555444333
XX-country
enjoy
Cкачать:
CallFilter.zip
bill_kevin
сообщение 3.12.2009, 23:16
Из: Guatemala
Пользователь №: 210 479
Модель телефона: Life II EP1&EP2
Прошивка: 49R
someone can help me:
need this:
the shadow is a patch or elf
RomeRo_001
сообщение 4.12.2009, 4:23
Из: Ульяновск
Пользователь №: 208 490
Прошивка: ---------
bill_kevin,
It is necessary to edit langpack
VEX
сообщение 4.12.2009, 12:14
Из: Нижний Новгород
Пользователь №: 156 303
Модель телефона: e398,V3,T190,L7
Прошивка: R373_44R_v2.8
bill_kevin, this elf Color_Dial-up ,change the color of the dialing digits(Warning - conflicts with the patch "new type of dialing"
Прикрепленный файл Color_Dial_up_v1.0.zip   ( 8.4 килобайт ) Кол-во скачиваний: 131
Сообщение отредактировал VEX - 4.12.2009, 12:18
Z.d.u.n.e.X
Из: Poland
Прошивка: Android
Yeah you should change font ID 05.
bill_kevin
сообщение 4.12.2009, 16:14
Из: Guatemala
Прошивка: 49R
RomeRo_001
VEX
Z.d.u.n.e.X
Thanks you are the best
Edit:
sorry someone can helpme i have ElfOpen_2.4.1 and i have a problem:
03FC;file//b/elf/ElistElflist.elf!
03DE;file//b/elf/Fun/EBlock.elf!
039A;file//b/elf/Hitmouse.elf!
0406;file//b/elf/Backuper.elf! **** Arplane mode
03D1;file//b/elf/Skinmaganer! **** Chat
and in the Last my phone restarts
Only happens with the last 2
Сообщение отредактировал bill_kevin - 5.12.2009, 17:45
zema00
сообщение 5.12.2009, 21:54
Пользователь №: 201 595
Модель телефона: v3r
Прошивка: d3r
You could give source codes screener.elf? / Thanks
Z.d.u.n.e.X
сообщение 5.12.2009, 22:07
Из: Poland
Прошивка: Android
@bill some places not work you should try some other.
oniech
сообщение 26.12.2009, 22:57
Из: Indonesia
Пользователь №: 188 975
Модель телефона: Е398
Прошивка: E398@Rokr oprekerz
@Vex give me Undo patch New type for dialling 49r and 79r please!for work that elf.
VEX
сообщение 27.12.2009, 10:03
Из: Нижний Новгород
oniech,
Прикрепленный файл New_type_of_dialing_79_UNDO.zip   ( 768 байт ) Кол-во скачиваний: 89
oniech
сообщение 28.12.2009, 6:26
Из: Indonesia
Thanx @vex.you have that undo patch for work that elf on DAR 2x.test 10?
urapek!
сообщение 6.4.2010, 8:28
Пользователь №: 192 937
Прошивка: DAR_1.3_79R
Somebody give me please ppplayer english version :cry
baat
сообщение 6.4.2010, 8:35
Самый Наглый
Группа: В отставке
Из: Дом, милый дом...
Пользователь №: 83 674
Прошивка: какая уж есть...
сообщение 6.4.2010, 9:47
ищу людей для "прочесывания" китайцев в поисках эльфов
как чесать можно приглядеться сюда
Штурмуем китайские сайты
и сюда
Штурмуем kutaйckuе сайты
и по аналогии действовать
каждый новый эльф +5 от меня лично и +? от благодарных пользователей
описание на русском обязательно , скрин по возможности
.:Rene:.
сообщение 7.4.2010, 10:05
Пользователь №: 215 885
Модель телефона: l7e
Прошивка: Extremoto 2.0
I got a problem with lrcplayer (1.3) on my l7e
the lyric just display in 1 line so i can't read the whole sentence
EX: I'm the one who want to love you more
Display: I'm the one who want
i can't create playlist with lrc 1.1 & 1.2 & they reboot my phone when im tryin to enter Fbrowser
BTW, ani skin not work even though ive tried lot tunes version, how can i use ani skin with l7e?
Сообщение отредактировал .:Rene:. - 7.4.2010, 11:51
SaniaZ
сообщение 27.5.2010, 17:35
Из: Могилёв
Пользователь №: 146 897
Модель телефона: L7 U8230
Прошивка: ACR_RB Cyanogen 7
Вот нашел на motoedy.cn несколько эльфов, сам не запускал. Переводил в google.
AutoClearIE 1.2
описание
Ps:自己经常用手机上网,每次上网都要手动清理一下浏览器,觉得很麻烦,看了很多大大们的源码,山寨出了这个程序(本人无C基础)。
功能:自动清除上网产生的垃圾缓存文件、历史记录及Cookie等临时文件.
说明:
1.需要加入自动运行
2.增加配置文本文件:AutoClearIE.ini 格式为:Event=0CE5、后面为触发事件代码(16进制),方便修改,置格式也很简单,直接为事件代码即可,如0CE5。配置文件和程序放同一目录下
3.关于事件、想更好的实现自动清除上网垃圾的效果,事件最为重要,我选用的是当手机退出浏览器后,手机显示使用流量窗口事件作为触发事件,只要是关于浏览器退出时能触发的事件都可以,看各位自己,我只提供个R4515_D3R的退出浏览器显示流量窗口事件,事件代码为3301(十进制)、0CE5(16进制)、另如果没有开启退出浏览器退出显示消耗流量功能的需要使用P2ktools开启。
4.清除文件目录 :
/c/mobile/mib/cache/
/c/mobile/mib/gen/
/c/mobile/mib/cookies/
5.已解决缓存文件清除问题,预定义清除200个cfi_le_num文件和20个F_file_num以及20个B_file_num文件,已满足清除需求数。
6.增加提示音文件,名为AutoClearIE.mp3,放程序同目录下
7.R4515_D3R测试通过,其它请自行测试。
Ps: часто используемые мобильного Интернета, каждый из них должен вручную очистки интернет-браузер, думаю, много хлопот и читал много большим источником их, коттедж из программы (у меня нет никаких оснований C).
Особенности: автоматическое удаление мусора генерируется Интернет кэш-файлы, историю, печенья и других временных файлов.
Описание:
1. Потребность быть добавлены автоматически
2. Увеличение текстового файла конфигурации: AutoClearIE.ini формат: Событие = 0CE5, за код триггера событий (16 HEX), чтобы содействовать переменам, домашний вид очень простой, прямой код для события, может быть, как 0CE5. Конфигурационных файлов и программ, в том же каталоге
3. В случае, автоматически снимать лучше влияние Интернета спам, наиболее важные события, я решил выйти из браузера, когда телефон за окном дисплей помощью потока событий, как вызвать события, до тех пор, когда на браузер вызвать событие может увидеть вас лично, я только R4515_D3R закрыть окно браузера отображения потока событий, код события 3301 (в десятичной системе), 0CE5 (16 Hex), а другой оказался, если браузер не выходит из потока показать потребления функции необходимо использовать P2ktools открытым.
4. Очистите файл каталога:
/ C / мобильного / MIB / кэш /
/ C / мобильного / MIB / GEN /
/ C / мобильного / MIB / печенье /
5. Удаления файла кэша проблема не будет решена, удалить cfi_le_num 200 предопределенных файлов и 20 и 20 B_file_num F_file_num файл был очищен для удовлетворения потребностей нескольких.
6. Увеличение тон файл, названный AutoClearIE.mp3, релиз программы под той же директории
7.R4515_D3R тестирование, другие на свой страх и тестирования.
Прикрепленный файл AutoClearIE.rar   ( 28.53 килобайт ) Кол-во скачиваний: 113
Прикрепленный файл AutoClearIE____.rar   ( 2.34 килобайт ) Кол-во скачиваний: 112
ClearTool
CostQuery V1.1
1.根据运营商提供端口查询,不会扣取任何费用
2.各地查询指令有可能不一致,如系统返回“系统查无此功能”之类短信则当地不支持该指令方式查询
3.查询结果短信返回时间跟网络情况有关,久没返回结果请耐心等待
4.没用联通卡,联通的查询没有测试
2010/05/06
CostQuery V1.1
修正之前的某些Bug
增加配置文件,方便修改查询指令
配置文件格式如下:
1. По запросу портовых операторов, не взимаем никакой комиссии
2. Проверить по инструкции, могут быть несовместимы, например, система возвращается "нет такой функции проверки системы", как сообщение местных не поддерживает распоряжения, запросы
3. Результат запроса, сообщение на время с сетью ситуациях, долго не возвращает результат, будьте терпеливы
4. Бесполезный Unicom карты, запрос в Unicom не проверяли
2010/05/06
CostQuery V1.1
До поправки к некоторым Отчеты об ошибках
Повышение профиля, изменить запрос, чтобы облегчать обучение
Конфигурация формат выглядит следующим образом:
各查询指令间用";"分号分隔
CM1,CM2,CM3,CM4为移动查询指令
CU1,CU2为联通查询指令
没联通卡 联通查询指令是乱写的,用联通的机友请自行修改
关于查询端口: 移动用户发送10086到10086查询
联通用户不清楚,那位机友知道请转告声
Между запроса команду "," точка с запятой отделен
CM1, см2, см3, CM4 на мобильном телефоне команду запрос
CU1, CU2 команду запроса Unicom
Unicom Unicom карты не проверить инструкция почерком, с машиной Unicom, пожалуйста, измените Друзья
Порт по запросу: мобильным пользователям отправить 10086 до 10086 запросов
Unicom пользователи не знают, человек Вы знаете, пожалуйста, сообщите исправная машина
Прикрепленный файл CostQuery_V1.1.rar   ( 4.48 килобайт ) Кол-во скачиваний: 120
Прикрепленный файл CostQuery____.rar   ( 4.7 килобайт ) Кол-во скачиваний: 111
Elfs by motoedy[China], new:more elfs 05.09.2009 · Эльфы, их разработка и портирование · Forum
Текстовая версия Сейчас: 26.7.2025, 17:22
