11 страниц V « < 6 7 8 9 10 > »
Модинг , Тюнинг и прочие ковыряния е8., выкладываем и описываем тут
Zorge.R
сообщение 11.3.2010, 17:50
Group Icon
Группа: System Administrators
Из: рук в руки
Пользователь №: 101 800
Прошивка: 1CR
croccio,
watch this.
catTIME, catMinute, etc, it's all value.
if you need do some operation with it, you can use $catMinute or $catTIME , etc.
for example:
if you need "AND", do this:
catMinute=`busybox uptime | awk '{print $1}' | sed 's,^...,,' | sed '1,$s/...$//'`
halftime="30"
fulltime="00"
if [ $catMinute -eq $halftime ] && [ $catMinute -eq $fulltime ]
then
        showQ "" "Bingo Bongo" 2
else
        showQ "" "Ooopss" 2
fi
or this:
catMinute=`date +%M`
halftime="30"
fulltime="00"
then
else
        showQ "" "Ooopss" 2
fi
and if You need "OR", do this:
halftime="30"
fulltime="00"
if [ $catMinute -eq $halftime ] || [ $catMinute -eq $fulltime ]
then
else
        showQ "" "Ooopss" 2
fi
or this:
halftime="30"
fulltime="00"
then
else
        showQ "" "Ooopss" 2
fi
p.s.: "AND" do double check the value (first and second need to match, for show Bingo Bongo), "OR" do single check (first or second match, for show Bingo Bongo)
p.p.s.: also you can date --help to see variable output format of data. (for example date +%d - day of the month, and other)
Сообщение отредактировал Zorge.R - 11.3.2010, 18:04
croccio
сообщение 11.3.2010, 18:32
Пользователь №: 161 521
Модель телефона: L7 Slvr, c350
thank u Zorge! =) i know how work and, or etc, but i don't know i use && for and i think only & =) thanks =) how can i auto.run file???
(11.3.2010, 20:12):
and how can do operations after 1 minutes???
Сообщение отредактировал croccio - 11.3.2010, 19:21
Zorge.R
сообщение 11.3.2010, 19:21
Group Icon
Из: рук в руки
Прошивка: 1CR
add it to unKnow
cp /your/path/to/script /mmc/movinand1/unKnown/S01zSOMENAME.txt
or write it from script
echo -ne "#!/bin/sh
# YOU AUTORUN CODE HERE
" > /mmc/movinand1/unKnown/S01zSOMENAME.txt
all operation with SH code will be suspend, when Backlight is OFF.
to prevent it you can use zShRunEx_E8 by Ant-ON. (ask here for more info)
croccio
сообщение 11.3.2010, 20:26
where i ask for it???
i've done this
CODE
mypath=${0%/*}
export PATH=${0%/*}:$PATH
cp -f $mypath/S01cshut.txt /mmc/movinand1/unKnown
ores=`date +%k`
minutis=`date +%M`
ore=`showTextEntry "Impostare l'ora" "Ora sono le: $ores:$minutis"`
minuti=`showTextEntry "Impostare i minuti" "Ora sono le: $ores:$minutis"`
showNotify "cShut" "Applicazione avviata" 1 1
showQ "$cShut" "Il telefono si spegnera' alle $ore:$minuti" 2
while [ $ore -eq $ore ]
do
ores=`date +%k`
minutis=`date +%M`
if [ $minutis -eq $minuti ] && [ $ores -eq $ore ]
then
    /usr/SYSqtapp/phone/vibrateprocess
    /usr/SYSqtapp/phone/vibrateprocess &
    mot_shutdown
fi
done
my phone i very slow! is there any way to speed it???
Zorge.R
сообщение 11.3.2010, 21:22
Group Icon
Из: рук в руки
Прошивка: 1CR
do
ores=`date +%k`
minutis=`date +%M`
then
mot_shutdown
fi
done
you can add sleep in cycle, to reduce the number of repetitions and the load on your phone.
- sleep 55s (required s) , to do the work every minute (1 times per minute).
for example:
do
sleep 55s
ores=`date +%k`
minutis=`date +%M`
then
    mot_shutdown
fi
done
also if you autorun script with "sleep", you need do it in background like this:
($mypath/S01cshut.txt content)
#!/bin/sh
/any/path/startimer.sh&
& must be in end of string.
croccio
сообщение 12.3.2010, 9:47
thank u bro!!!!!!!!!!! =) u're great!!!!!!!!! =) i tried sleep but it doesn't work because i forgot s =)
(12.3.2010, 10:57):
how can i use showpicknumber??? it doesn't work! i copy shiwpicknumber file in app folder but it doesn' work!
(12.3.2010, 11:27):
how can i do global variables???
(12.3.2010, 11:30):
how can i take value for variables from file???
(12.3.2010, 12:50):
how can i see what profile is active??
for example
if silent then
else
if vibration then
fi
fi
Сообщение отредактировал croccio - 12.3.2010, 11:36
Zorge.R
сообщение 12.3.2010, 12:32
Group Icon
Из: рук в руки
Прошивка: 1CR
Цитата(croccio @ Сегодня, 12:47)
(12.3.2010, 10:57):
file names are case-sensitive, showNumPicker not equal shownumpicker
check this:
youapptpath=${0%/*}
$youapptpath/showNumPickerNAME
if it don't work, use showSlider.
for example:
GETHOUR=`showSlider "TEXTHEADER" "ANYTEXT" "0" "23" "12"`
GETMINUTE=`showSlider "TEXTHEADER" "ANYTEXT" "0" "59" "30"`
first number, is start of range, second is a end of range, last number is position at which the slider will be when showSlider start.
or do this
ores=`date +%k`
minutis=`date +%M`
GETHOUR=`showSlider "TEXTHEADER" "ANYTEXT" "0" "23" "$ores"`
GETMINUTE=`showSlider "TEXTHEADER" "ANYTEXT" "0" "59" "$minutis"`
in this example, when show start, slider will be on current time position.
give an example, for what they need you.
to grab profile id you need do:
grabcurprofile=`grep "^ActiveProfileID = " "/ezxlocal/download/appwrite/setup/ezx_alert.cfg" | sed "s,^ActiveProfileID = ,,"`
or
if [ $grabcurprofile -eq 1 ]
then profileis="Normal"
elif [ $grabcurprofile -eq 2 ]
then profileis="Vibrate"
elif [ $grabcurprofile -eq 3 ]
then profileis="Silent"
elif [ $grabcurprofile -eq 4 ]
then profileis="Meeting"
elif [ $grabcurprofile -eq 5 ]
then profileis="Airplane"
elif [ $grabcurprofile -eq 6 ]
then profileis="Sleeping"
elif [ $grabcurprofile -eq 7 ]
then profileis="Active"
elif [ $grabcurprofile -eq 8 ]
then profileis="Car"
else
showQ "WTF" "this unreal profile Bro! Are you phone alien?" 2
fi
echo $profileis
in second example, profile id will be converted to its text name.
echo in the end (example) to show current profile for testing this code.
Сообщение отредактировал Zorge.R - 12.3.2010, 12:36
croccio
сообщение 12.3.2010, 14:03
how can i do that in bold?
cshut.sh
mypath=${0%/*}
ores=`date +%k`
minutis=`date +%M`
echo -ne $ore > /ore.txt
echo -ne $minuti > /minuti.txt
2.sh
done
2.sh
ore=ore.txt value
minuti=minuti.txt value
do
sleep 55s
ores=`date +%k`
minutis=`date +%M`
then
mot_shutdown
fi
(12.3.2010, 15:56):
how can i show name of mgx app in ztask??? it show sh for all mgx
(12.3.2010, 16:03):
numshow picker doesn't work, i use slider
Сообщение отредактировал croccio - 12.3.2010, 14:33
Zorge.R
сообщение 12.3.2010, 17:16
Group Icon
Из: рук в руки
Прошивка: 1CR
Цитата(croccio @ Сегодня, 17:03)
ore=ore.txt value
use CAT for grab value from file
anyname=`cat /path/to/file/with/value`
for example:
write value to the file
echo -ne $ore > /mmc/mmca1/ore.txt
echo -ne $minuti > /mmc/mmca1/minuti.txt
grab this value
ore=`cat /mmc/mmca1/ore.txt`
minuti=`cat /mmc/mmca1/minuti.txt`
if mgx start from script, it will show SH.
if start from binary, it will show name of binary.
Ask Ant-ON for more information.
croccio
сообщение 12.3.2010, 17:25
thank u very much! u're are super great zorge!!!!!!!!! u are a wizard!!!!!!!!!!
(12.3.2010, 20:52):
zorge in your MP when light is off mgx doesn't work, why???
(12.3.2010, 22:07):
i return to nik_envy, why the app that i do doesn't work??? =(
Zorge.R
сообщение 13.3.2010, 10:04
Group Icon
Из: рук в руки
Прошивка: 1CR
mgx it's just format of package. it may content binary file and shell script too. binary file can work in background. shell script will suspend, when phone backlight is off. it's phone feature, not z-mod.
shell code performed only when phone active.
to prevent suspend script operation you can use zShRunEx_E8. it can take from Ant-ON.
croccio
сообщение 13.3.2010, 15:29
how can i control key press??? and the time of key press??? for example if key * for 3 second then...
(13.3.2010, 16:33):
zorge can u give me that program??? ant-on doesn't answer =(
Ant-ON
сообщение 14.3.2010, 6:43
Пользователь №: 49 304
Прошивка: CM12 / CM10 / PM2
For me it is not realistic.
Program include in app zSleepWithMusic and zNight. Download it and extract.
croccio
сообщение 14.3.2010, 11:05
where i put it ant-on??? in the folder of mgx??? i should edit it??? give me more info ant-on please!!! so i can't assign event when i press any key???
(14.3.2010, 12:07):
where i put it ant-on??? in the folder of mgx??? i should edit it??? and i add it to auto.run??? give me more info ant-on please!!! so i can't assign event when i press any key???
(14.3.2010, 14:04):
how can i make bin app??? is there any programa taht conveert sh to bin???
(14.3.2010, 14:36):
i do this:
cShut.lin
CODE
#!/bin/sh
mypath=${0%/*}
showRadio "cShut" "Seleziona opzione" "Avvia" "Aggiungi all'avvio" "Rimuovi dall'avvio"
case "$?" in
1)
    ores=`date +%k`
    minutis=`date +%M`
    ore=`showSlider "Impostare l'ora" "Ora sono le: $ores:$minutis" "0" "23" "$ores"`
    echo -ne $ore > ./ore.txt
    minuti=`showSlider "Impostare i minuti" "Ora sono le: $ores:$minutis" "0" "59" "$minutis"`
    echo -ne $minuti > ./minuti.txt
    showQ ""  "Programma avviato!" 2
    $mypath/zShRunEx -f $mypath/avvio.sh -c 1 -t 1
2)
    # Aggiungi
    cp -f ./S01cshut.txt /mmc/movinand1/unKnown
    showNotify "cShut" "Aggiunto all'avvio" 1 1
3)
    # Rimuovi
    rm -f /mmc/movinand1/unKnown/S01cshut.txt
    showNotify "cShut" "Rimosso dall'avvio" 1 1
exit 0
esac
avvio.sh
CODE
ore=`cat /mmc/movinand1/mpkgbox/cshut/ore.txt`
minuti=`cat /mmc/movinand1/mpkgbox/cshut/minuti.txt`
do
sleep 55s
ores=`date +%k`
minutis=`date +%M`
    then
              showNotify "" "le ore e i minuti sono uguali
fi
done
it doesn't work.
Zorge.R
сообщение 14.3.2010, 15:51
Group Icon
Из: рук в руки
Прошивка: 1CR
do this
  $mypath/zShRunEx -f $mypath/avvio.sh -c 1 -t 1 &
-t 1
it will start after 1 minute.
Добавлено позже (14.3.2010, 18:54):
2)
# Aggiungi
3)
# Rimuovi
to optimization this code you can do
if [ -f /mmc/movinand1/unKnown/S01cshut.txt ]
then
else
fi
croccio
сообщение 14.3.2010, 16:21
it doesn't work zorge! is there any program that convert sh to bin file??
Zorge.R
сообщение 14.3.2010, 16:35
Group Icon
Из: рук в руки
Прошивка: 1CR
no.
croccio
сообщение 14.3.2010, 16:51
so i can't do it =( how can i do to work it???
Zorge.R
сообщение 14.3.2010, 17:23
Group Icon
Из: рук в руки
Прошивка: 1CR
croccio, write binary.
or watch "cron" by roik-sv.
but, script do it work when back-light ON, only.
croccio
сообщение 14.3.2010, 17:39
how can i write binary??? can u give me th program??? i should use c+ and toolchain??? can u give me all the info?
ok zorge i see! thank u for all!
(14.3.2010, 18:42):
can u send me some link??? if i search in forum cron roik-sv it give me error
Сообщение отредактировал croccio - 14.3.2010, 17:48
Zorge.R
сообщение 14.3.2010, 18:48
Group Icon
Из: рук в руки
Прошивка: 1CR
croccio, roik-sv useful scripts
croccio
сообщение 15.3.2010, 16:41
i understand nothing =( however thank u for all your time =(
K()t
сообщение 18.3.2010, 18:51
Из: Niko City, Ukraine
Пользователь №: 202 229
Прошивка: CM
Что здесь не правильно почему не создаётся папка?
#!/bin/sh
mypath=${0%/*}
mkdir -p /mmc/movinand1/.skin
cp $mypath/colors.css /mmc/movinand1/.skin/colors.css
cp $mypath/hsa_p.ini /mmc/movinand1/.skin/hsa_p.ini
cp $mypath/main_view.svg /mmc/movinand1/.skin/main_view.svg
mount -o bind /mmc/movinand1/.skin/colors.css /usr/data_resource/skin/default1/colors.css
mount -o bind /mmc/movinand1/.skin/hsa_p.ini /usr/data_resource/skin/default1/hsa_p.ini
mount -o bind /mmc/movinand1/.skin/main_view.svg /usr/SYSqtapp/xe/resource/skins/default/view/main_view.svg
echo "mount -o bind /mmc/movinand1/.sub/mainmenufolder.js /usr/SYSqtapp/xe/flows/mainmenu/mainmenufolder.js
          mount -o bind /mmc/movinand1/.sub/MainmenuFolder.xml /usr/SYSqtapp/xe/flows/mainmenu/MainmenuFolder.xml
          mount -o bind /mmc/movinand1/.sub/mainmenu.css /usr/SYSqtapp/xe/resource/skins/default/mainmenu/mainmenu.css" > /ezxlocal/download/mystuff/unknown/S10sub
kill `pidof am`
kill `pidof flowplayer`
showQ "zMod" "Выполнено" 2
Кирич
сообщение 18.3.2010, 20:45
Пользователь №: 215 200
Модель телефона: rokr E8
А как-нибудь вообще можно увеличить фото при звонке исходящем и входящем???
Sereg_k:
нельзя
Сообщение отредактировал Sereg_K - 18.3.2010, 22:14
Zorge.R
сообщение 18.3.2010, 23:06
Group Icon
Из: рук в руки
Прошивка: 1CR
зачем это в твоем скрипте?
а как ты проверял, создается или нет? может она скрытая, а ты не заметил pardon.gif
p.s.: есть чудо вещь, называется Вывод. При помощи вывода можно смотреть какие ошибки происходят в процессе выполнения кода. Если пишешь скрипты, имей привычку всегда смотреть вывод. особенно при первом запуске.
и еще:
оператор -p тут излишний, т.к. папка /mmc/movinand1 существует.
на z6 подбирали такой размер картинки, чтобы она занимала максимальную площадь.
214хнасколькототам.
у нас соотношение другое.
Zorge.R
сообщение 25.3.2010, 23:39
Group Icon
Из: рук в руки
Прошивка: 1CR
веб сервер и веб камера на Е8 -> подробней.
p.s.: знаю что не все пользователи ветки, заходят в подветку. поэтому решил опубликовать ссылку тут.
VoiD
сообщение 29.3.2010, 10:05
Пользователь №: 167 152
Модель телефона: EM30
Прошивка: 04.06e
Возможно ли уменьшить тайминги кнопок? Для более быстрого стирания текста, например.
K()t
сообщение 30.3.2010, 8:56
Прошивка: CM
А кaк то можно скриптом открывaть пaпки мeню нaпримeр игры или нaстройки?
Сообщение отредактировал K()t - 30.3.2010, 14:04
Zorge.R
сообщение 1.4.2010, 7:22
Group Icon
Из: рук в руки
Прошивка: 1CR
у меня есть извращенный способ для открытия папок в ФС.
для открытия папок меню, не знаю, даже не пробовал. скорее всего никак, особенно скриптом.
croccio
сообщение 1.4.2010, 9:37
how can i have continue vibration???
Сообщение отредактировал croccio - 1.4.2010, 10:52
Goin13
сообщение 2.4.2010, 21:33
Из: Червоноград
Пользователь №: 210 124
Модель телефона: Em30, a1200
K()t,
незнаю насколько полезный мой совет но, некоторые подпункты меню идут как приложение, их скриптом можно открыть(на крайняк, прописать в скрипте все подпункты скажем настроек) если заинтересовался смотри в sysRegistry, execID= (кажется)
Zorge.R,
а можешь поделится этим извращенным способом, если это конечо не секрет?
K()t
сообщение 8.4.2010, 11:20
Прошивка: CM
Кто-то пробывaл рeaльно встaвить в e8/eм30 BK70, или eто всё только чисто тeорeтичeски?
И eслe у когото стоит, сфоткaйтe кaк зaкрывaeтся зaдняя крышкa.
Сообщение отредактировал K()t - 8.4.2010, 11:38
Zorge.R
сообщение 8.4.2010, 12:04
Group Icon
Из: рук в руки
Прошивка: 1CR
Цитата(Goin13 @ 3.4.2010, 1:33)
можешь поделится
можешь. на следующей неделе.
execID=
это не подпункты и не меню и не папки, это приложения или скрипты.
Goin13
сообщение 10.4.2010, 7:00
Из: Червоноград
Zorge.R,
да, я неверно выразился. Но вот в чем суть: можно же создать скрипт скажем для пункта настройки и добавить туда все приложения из этого пункта. Получается какое ни какое а всетаки решение.
Zorge.R
сообщение 10.4.2010, 10:00
Group Icon
Из: рук в руки
Прошивка: 1CR
Goin13, можно. смотри zMod-Config из сборки 2.4.5.
но к папкам отношения не имеет, это скрипты. думаю вопрос был о папках "органайзер", Настройки, Игры, Мультимедиа.
по поводу папок в фс, надо монтировать фейковый майстаф.кфг (смотрите zroot), затем запускать файл менеджер (mystuff), он будет открыт в папке указаной в фейковом конфиге, после закрытия файл мена, конфиг надо отмонтировать. (опять смотреть zroot)
K()t
сообщение 10.4.2010, 11:07
Прошивка: CM
Goin13, я спрашивал в основном за игры, чтоб можно было повесить на кнопку вызова скрипт с возможностью запуска зТаскМена и папки Игры
Goin13
сообщение 10.4.2010, 15:18
Из: Червоноград
K()t,
просто добавь в таскМан яву.Или faultline main menu(откроет меню).
Zorge.R,
спасибо, вроде разобрался.
Diag
сообщение 10.4.2010, 15:28
Из: г. Краснодар
Пользователь №: 171 112
Прошивка: R6716_G_71.04.06R_C
Ребят, скажите, нужно написать скрипт, который скрывал! определенный процесс. Это возможно? Какая команда для этого нужна?
K()t
сообщение 10.4.2010, 15:31
Прошивка: CM
Goin13, А меня все около 50ява приложений и игр которые лежат в четырех папках а добавлять их в зТаскМен не удобно и долго искать нужное приложение во всем списке.
Добавлено позже (10.4.2010, 18:33):
Diag, а зачем тебе скрывать процессы, а главное от кого ты их хочешь скрыть?
Diag
сообщение 10.4.2010, 16:00
Из: г. Краснодар
Ну чтоб понятнее было: свернуть процесс. Ладно, забудем. Вот предложение: при новых библиотеках, управление rockbox'a меня устраивает, а не устраивает его сворачивание, когда тебе позвонят. Можно было бы написать в скрипте (который висит на зеленой кнопке и запускает ztaskman), перед "запуском" диспетчера написать команду, к примеру, свернуть процесс rockboxui, и по длительному нажатию на зеленую кнопку можно было свернуть плеер. Товарищи, не знаю, прокатит оно, или я бред пишу. Можно так сделать?
Модинг , Тюнинг и прочие ковыряния е8., выкладываем и описываем тут · Motorola ROKR E8, EM30 · Forum
Текстовая версия Сейчас: 10.9.2025, 6:46
