4 страниц V < 1 2 3 4 >
Прошивка Evolution 3, V8
abelenki
сообщение 22.1.2009, 9:07 Закрепленное сообщение!
Из: Russia, Perm
Пользователь №: 94 097
This is the NO_RSA Evolution 3 firmware, which is an updated version of Evolution 2 with Snesx.
The changes are:
new "System Management" submenu under Tweaks which includes
- Swap Memory, so you can add extra physical memory to your V8, so the V8 does not have to unload stuff and load new stuff into RAM memory, it can now use a certain size of the User Memory (512MB V8) or the 2GB memory (2GB V8) to store memory loaded stuff. It should make the V8 perform faster under heavy multi tasking. Just click the menu, select the swap memory size you want to use and wait, then press the menu again and it will offer the option to activate the swap memory, do that. Once the swap memory is setup it will be always there, unless you delete it of course, but it needs to be activated after every reboot. You can check the status of this swap memory with
-System Info, which will display the currently used memory and swap memory with adjustable refresh circles.
-Phone Firewall is an application that can be used to block certain phone numbers and there is the option to block unkown numbers as well, perfect if you want to setup the phone for your kids.
In the "Utilities" submenu there are 3 new menus
- Arcman, looks like zLauncher, but is for archiving file and folders as well as unpacking compressed files, the MPlayer.rar file that is included unpacks perfectly, which brings me to another point. MPlayer had to be removed from automatic installation because it just took too much space. Now 2GB V8 should already have it in place as the 2GB memory does not get wiped when flashing a complete firmware. The 512MB V8 however needs to have the MPlayer.rar file copied into /ezxlocal/download/mystuff/Programms (note the 2m's!! in Programms as there is another Programs folder), then use Arcman to Extract->Extract Here and reboot, now MPlayer will be working on the 512MB V8. 2GB V8's that do not have a "Programms" folder in /mmc/mmca1, have to create one and use the same method.
-Cronometer is like a stopwatch, but you also can take times for certain stages (Mark button)
-V8 Screenshots lets you take screenshots of any menu and store them on the V8, you can adjust the number of screenshots to be taken, the timing when they will be taken and where you want to store them, User Memory (512MB V8 and 2GB V8) and 2GB memory (2GB V8 only). Once you have taken some screenshots, you have to rename the screenshot files with zLauncher or they will be overwritten the next time you take screenshots again. you can find them in /ezxlocal/download/mystuff/snapshot and /mmc/mmca1/snapshot.
The zLauncher got updated as well and works now as a TextViewer as well, but you also can edit existing and opened text files, but you also can edit scripts, sh files, and save them. Because of the much more powerfull potential that zLauncher posses, it has been password protected (password: 1234), you can of course change that password to whatever you like. This way only the person/persons that know the password can have total access to the filesystem. For example you can create a new folder in the User Memory or the 2GB memory and call it .whatever, now if you add the "dot" in front of the name then File Manager will not be able to see this folder, but zLauncher will be. So you can have a "hidden" folder in which you can save/store stuff that is not meant to be seen by everybody and because zLauncher is password protected you are the only one that has access to it. I tried the ZHidenFolder mod, which basically does the same, but because zLauncher still can see those "hidden" folders there was not much point in using that HiddenFolder mod. Also FTP programs like FileZilla can see those "dot"name folders.
You can change the language of Cronometer and Phone Firewall, but not through the app menu, that somehow does not work. But if you look at /ezxlocal/download/mystuff/apps/language/English, open that with wordpad and change the words of the right hand side to the words of your language and save it as "Italian" or whatever, then you can change the cfg files for Cronometer and Phone Firewall to use your language.
A very big THANK YOU has to go to all those people that made those Z6 mods, without their work our V8 would be less interesting, also I have to thank DaRk_dOg for his tireless help to get this up and running and his help in testing the 512MB version, this thanks also has to go to Protector who tested the 2GB version.
This typical, I just have decided to release Evo 3 and along comes a very useful mod (thanks to DaRk_dOg) which really would finish off the Evo 3 firmware. This Mod can be found under the System Management and is called CPU Frequency. Well as the name says you can adjust the MHz frequency of the CPU.
Автор:
rasputin007
Оригинальный топик:
modmymoto.com
Порядок прошивания:
1. Bootloader A3.CF (если у вас какой-либо другой бутлоадер).
2. Bootloader A3.CF No RSA.
3. Прошивка Evolution 3 (прошивайте версию прошивки, соответствующую вашей модели телефона - 512MB или 2GB. Для Luxury Edition прошивайте версию 2GB).
4. Чтобы установить русский лэнгпак, копируем содержимое архива с LP002EE в /ezxlocal/download/mystuff/apps/language/.
Файлы:
Bootloader A3.CF
512MB Evolution 3, 512MB Evolution 3 Video Update (исправлена функция Reset и добавлена съёмка видео в 288x352)
2GB Evolution 3, 2GB Evolution 3 Video Update (исправлена функция Reset и добавлена съёмка видео в 288x352)
LP002EE - UK English, German, Russian, Ukrainian, French, Spanish, Portuguese; Russian voice commands only
MPlayer
Evolution 3 User Guide
Language Guide
V8 Modding Guide
Сообщение отредактировал abelenki - 25.8.2009, 8:51
Pechinka
сообщение 2.4.2009, 13:51
Пользователь №: 106 969
Модель телефона: SE k750i+moto v8 2GB
Прошивка: Evolution 3
Цитата(Антоха-ха-ха @ 1.4.2009, 7:55) *
Как тока начал прошивать экран не загорелся вроди все работало ошибку не выдовал
Дошол до 100% итут у меня села батарея поставил на зарядку.
после повторения операции опять вылетела ошибочка таже самая и в этот раз экран включается и выдается ошибка mad.gif
И сразу спрошу а какой ФТП лучше использовать
Батарейка сейчас не зарядится! тебе нужно найти гдето заряженую, потом прошейся и можешь старую юзать.
Антоха-ха-ха
сообщение 2.4.2009, 15:14
Пользователь №: 53 930
Модель телефона: V8 512mb
Прошивка: LM5_SP1_LP0039B
Pechinka,
Я сделал так взял батарею от самсунга заряженную и просто поцепил ее к телу. cool.gif
Вот теперь нужно еще рас шить а это опять заливать скины игрушки музыку и тд и тп
пока неохота, как руки дойдут поставлю заново
Frezerovshik
сообщение 4.4.2009, 4:37
Пользователь №: 179 253
У меня такая проблема: Юзаю тему Кристал карбон, но пазмер шрифта мне в ней радикльно не нравится. Поэтому приходится делать так: включаю тему стандартную с этой прошивки, перезагружаю телефон, включаю тему карбон и не перезагружаю телефон- шрифты маленькие, как мне надр. Только перезагружу телефон сразу шрифты увеличиваются до обычно здоровых. Что можете постоветовать???
-POSHIK-
сообщение 4.4.2009, 11:04
Из: Днепропетровск
Пользователь №: 137 121
Модель телефона: Z6
Frezerovshik, жесть, тебе надо редактировать ini файлы. Читай .ini файлы скинов и Описание скинов для Z6/V8
Frezerovshik
сообщение 4.4.2009, 14:32
Этож [вырезан мат] скольки нужно менять инишников sad.gif Может лучше попробовать решить проблему? И вообше правда странно получается- в стандартном скине большие шрифты, в кристал карбон большие, а если включать второй после первого без перезагрузки то шрифты маленькие.
мб просто через изменение шрифтов пароканает?
зы: кстати а где можно эти шрифты взять для русского?)
ciber-demon
сообщение 4.4.2009, 16:40
Из: г. Каменск-Шахтинский
Пользователь №: 117 495
Модель телефона: RAZR2 V8 \ XT720 \ Z6
Прошивка: XT720 - RUSMOD 1.17
Прошивка хорошая но
1- Нет ни одного встроенного нормального плеера с поддержкой плейлистов
2- даже в стандартном просмоторщике нет перелистывания песен (вправо и влево)
Пожалуйста соберите прошивку со встроенным хотябы (KD playr) или любой другой с интерфейсом
и доделайте родной просмоторщик
чтобы непрешлось каждый раз долбатся и давать прова доступа к ФС
Добавлено позже (4.4.2009, 20:42):
Ну когдаже выйдет следующий релиз с исправленными багами?
Сообщение отредактировал abelenki - 4.4.2009, 18:15
abelenki
сообщение 4.4.2009, 18:07
Из: Russia, Perm
новых версий больше не будет, пересобирать прошивку тоже никто не будет.
музыку надо слушать на встроенном мотороловском плеере, а видео смотреть через mplayer.
Сообщение отредактировал abelenki - 4.4.2009, 18:21
ciber-demon
сообщение 5.4.2009, 11:11
ну а как же быть с перелистыванием песен?
или есть какаето замарочка с перелистыванием песен в родном плеере? unsure.gif
подскажите пожалуйста.
maximych
сообщение 8.4.2009, 6:48
Из: Химки
Пользователь №: 162 486
Модель телефона: v8 2gb
Всё есть и всё работает.
Ты просто сначала плеер запусти и через него открывай музыку.
OlgaJah
сообщение 12.4.2009, 14:24
Пользователь №: 147 866
Модель телефона: RAZR2 Luxury Edition
Прошивка: MPKG Basic
Скажите,как у вас воспроизводится видео через MPlayer? У меня стал тормозить в формате avi.
miccca
сообщение 29.4.2009, 18:10
Пользователь №: 146 928
Модель телефона: Motorola V8 2Gb
Прошивка: R601_G_80.56.15R
не могу понять как из инструкции ставить русский ленг?
сначала надо идти /usr/local/cg46 у меня там пусто... имею в в иду папки cg46 нету.что неправильно делаю?
Сообщение отредактировал miccca - 29.4.2009, 18:11
NosFire
сообщение 29.4.2009, 19:01
Из: Санкт - Петербург
Пользователь №: 198 449
Модель телефона: е398\v8 2Gb\Atrix
Прошивка: .42r\.1br\CM7.1
miccca копируешь из архива все кроме хелпа и тхт файла в /ezxlocal/download/mystuff/language и ребутишься
Сообщение отредактировал NosFire - 1.5.2009, 10:04
kazak13
сообщение 5.6.2009, 17:43
Пользователь №: 200 692
Модель телефона: motorola razr2 v8
Порядок прошивания:
1. Bootloader A3.CF (если у вас какой-либо другой бутлоадер). --> вышло
2. Bootloader A3.CF No RSA. --> вышло
3. Прошивка Evolution 3 (прошивайте версию прошивки, соответствующую вашей модели телефона - 2GB.)
при выборе прошивки не поевялется в РСД лайт кнопка "СТАРТ". Получается не подходит что то...
Подскажите в чем дело?
ОС виста.
рсд лайт 4,2.
Legis
сообщение 5.6.2009, 17:48
Из: Питер
Пользователь №: 62 183
Модель телефона: Atrix 4G
Прошивка: Home Base
ОС виста.
рсд лайт 4,2.
постоянно мучаюсь с этим...
помогает когда как:
или
1. перенос файла в корень диска, а не кучу подпапок.
или
2. переименование файла до короткого имени в виде версии прошивки, напр. R601_G_80.44.2BR
Martein
сообщение 16.6.2009, 12:59
Пользователь №: 112 635
Модель телефона: Razr2 V8
Прошивка: R601_G_80.56.1BR
Давно не занимался своим любимым телефоном, сегодня уделил время - прочитал всю ветку, прошился с успехом clap.gif , одно только интересует - SnesX это я так понял эмулятор Ниндендо? А вопрос как им пользоваться, куда помещать файлы с играми, и кто в какие игры уже играл. unsure.gif
NosFire
сообщение 16.6.2009, 14:15
Кидаешь игры сюда: /ezxlocal/download/mystuff/v8snesX/Snes. это Супер Нинтендо, аналог СМД 16битной.
Если не хватает места то снимаешь ограничения маунта кидаешь на флешку в папку Snes (ну или любое другое название, с учетом регистра, не забыв поменять скрипт).
Насчет снятие ограничения, можешь почитать ЗДЕСЬ.
Сообщение отредактировал NosFire - 16.6.2009, 14:20
Martein
сообщение 17.6.2009, 10:01
NosFire, Поместил в папку /ezxlocal/download/mystuff/v8snesX игру - файл Aladdin (Beta) [f1].smc. Дальше запускаю SnesX, там написано "текущее состояние свободно". А дальше как указать путь к файлу с игрой, каким пунктом меню, все перенажимал ничего не порисходит... unsure.gif
NosFire
сообщение 17.6.2009, 16:39
Сразу при входе в СнеС, жмешь центровую, выбираешь Алладина, предварительно настроив клаву)) Через опшен - настройка клавиатуры, в настройках так же указываешь пропуск кадров, оптимально 3-4. Потом жмешь запуск и радуешься)
Martein
сообщение 18.6.2009, 9:02
NosFire, нажимаю на центральную клавишу ничего не происходит... unsure.gif Может еще что то нужно сделать...
Извеняюсь был не прав shuffle.gif , проблему решил, по ошибке записал игры в папку /ezxlocal/download/mystuff/v8snesX
Сообщение отредактировал Martein - 19.6.2009, 6:58
abelenki
сообщение 29.6.2009, 4:10
Из: Russia, Perm
в закреплённом сообщении обновлено V8 Modding Guide в соответствии со следующим заявлением rasputin007:
Yesterday I found out that the previously mksquashfs command line
mksquashfs /path to CG folder/* /path to where to put CG.smg -le
does NOT include any "hidden" folder like .backup (dot in front of folder name).
This missing of .backup folder in CG36 brings the Reset function to hang the V8.
The correct mksquashfs command line should be without the /*, like
mksquashfs /path to CG folder /path to where to put CG.smg -le
Now hidden folder are included.
Evo 3, Basic Plus and MPKG Basic have this faulty Reset function.
I have updated the V8 Modding Guide and MPKG Basic.
You can just make a CG36 reflash to keep your current setup.
I thought you should know about this and possibly pass this on as this could affect other Motomagx firmwares, when using the "old" style mksquashfs command.
Ras
Сообщение отредактировал abelenki - 29.6.2009, 4:48
Scorpion4ic
сообщение 23.7.2009, 11:36
Пользователь №: 164 273
Прошивка: 324
Ребята,у меня такая проблема... Не работает ни одна из утилит,и вообще ничего из Твиксов не возможно запустить! Подскажите в чем беда,а то даже MPlayer через Arcman не возможно установить sad.gif
Vermin
сообщение 24.7.2009, 0:06
Пользователь №: 64 122
Модель телефона: V635; V8
Прошивка: Своя; Basic Plus
Попробу прошиться еще раз. Чудес не бывает, у всех все работает.
Scorpion4ic
сообщение 24.7.2009, 9:53
Прошивка: 324
Vermin, ничего.... Вобще в папках с утилитами всего по одному файлу "settings" .... sad.gif
Может я как-то не так шью?.. Хотя вроде как всегда,через RSD...
Partvein
сообщение 7.8.2009, 6:24
Пользователь №: 204 120
Модель телефона: RAZR2,V8-2Gb Luxory
Прошивка: Elysseum+ Edition
Есть глюк с изменением чистоты процессора...Когда выставляю 532Mhz в свойствах показывает 353.88.У всех так?
Vermin
сообщение 7.8.2009, 6:39
353.88 это не Mhz, a MIPS
DYX123456
сообщение 7.8.2009, 21:18
Пользователь №: 172 689
Модель телефона: RAZR2 V8 2GB + V3i
Ребята, плз, нужна помощь. Прошила тело нормально. Не могу установить русский лэнгпак. Куда помещать файлы - поняла в /ezxlocal/download/mystuff/language. Но какой программой лэнгпак туда перемещать? Пыталась подключить через P2kCommander-V5.0.6-MR и через P2KToolsVS 3.0.9.947 Beta. Телефона своего в этих прогах не видно, ни одного диска, ни одной папки. Разъясните по-шагово. Спасибо. unsure.gif
Vermin
сообщение 10.8.2009, 0:10
Подключить телефон по FTP. Для работы FTP установите след. настройки в вашем FTP-клиенте (будь то FileZilla, Total Commander, Far Manager и др.) :
ftp-server = 192.168.16.2
port = 21
username = root
password = root
Затем в начтройках телефона устанавливаем тип соединения Tools. Подключаем кабель и заходим на FTP телефона. Заходим на /ezxlocal/download/mystuff/apps/language/ и копируем туда содержимое архива с лэнгпаком. Перезагружаемся.
Partvein
сообщение 10.8.2009, 10:11
Скажите как устанавливать скины на этой прошивке?Пробывал кидать в папку /ezxlocal/download/mystuff/Skins/Skin1,ноль эфекта... unsure.gif
Matorist
сообщение 10.8.2009, 12:27
Пользователь №: 105 413
Модель телефона: IPhone XR
Прошивка: iOS 13
/ezxlocal/download/mystuff/skins/0
Сообщение отредактировал abelenki - 20.8.2009, 7:35
Chepurnoff
сообщение 10.8.2009, 13:48
Из: Тюмень - Пенза - Саратов
Пользователь №: 157 192
Прошивка: zMod
Ту бир ор нот ту бир?
port = 21
username = root
password = root
Или проще: ставим на телефоне соединение Tools, подключаем тел к компу, открываем любую папку на компе и в адресной строке пишем: ftp://root:root@192.168.16.2/ezxlocal/download/mystuff/apps/language/ жмем Enter (или Переход) и кидаем сюда содержимое архива.
abelenki
сообщение 25.8.2009, 8:53
Из: Russia, Perm
rasputin007 пишет:
I don't know if this matters, as Evo 3 is quite old, but people still use it. So I fixed the Reset function and added 288x352 video recording. So it is a CG36 and CG43 reflash, which means all personal data should remain on the V8.
в закреплённое сообщение добавлены 512MB Evolution 3 Video Update и 2GB Evolution 3 Video Update. этот рефлеш исправляет функцию Reset, а также добавляет съёмку видео в разрешении 288x352. шить можно поверх существующей прошивки - персональные данные не должны быть затронуты.
Edikhans
сообщение 10.9.2009, 17:47
Из: Украина, Донецк
Пользователь №: 202 342
Модель телефона: Moto X XT1055 (1st gen)
Прошивка: Android 4.4.2
куда кидать скины? игры?
и почему у мня видео всеравно 174х148?
и куда кидать мплеер?
Сообщение отредактировал Edikhans - 10.9.2009, 17:48
abelenki
сообщение 11.9.2009, 2:23
Из: Russia, Perm
потому что после прошивки нужно прошить Evolution 3 Video Update.
по остальным вопросам - внимательно перечитай весь топик от начала до конца.
Сообщение отредактировал abelenki - 11.9.2009, 2:27
Edikhans
сообщение 11.9.2009, 3:30
Из: Украина, Донецк
abelenki, я так и сделал, сначало оюычную ево потом видео апдейт, и все равно видео разрешение не поменялось
мплеер там так и не написано куда сувать, плюс если делать так как там написано о скиннах, то скины вместо своих 1мб весят 700кб, ну и т.д.
тоесть их как кидать распакованными? но если так то приходится их создавать в телефоне самим?
Сообщение отредактировал Edikhans - 12.9.2009, 5:20
Menelai
сообщение 23.9.2009, 12:48
Из: Казахстан
Пользователь №: 109 924
Модель телефона: e398 + V8 512
Прошивка: Каждый день новая
Читай внимательнее.
В папке Skins есть папки Skin1......Skin10, каждый скин распаковывай в любую из этих папок.
Serger75
сообщение 11.10.2009, 18:50
Пользователь №: 69 755
Вечер добрый, прошил Evolution 3 Video Update. Тело выдало:
Bootloader
A3.CF
Err:A5,694E,24
Battery OK
OK to Program
Connect USB
Data Cable
попробовал препрошить 2GB_Evo3_CPU, т.ж. самое
с бута невыходит.
Прошил LinuxМod 5 - пашет.
Но всё-же в чём причина?
sEVANS:Ещё раз читаем:
Порядок прошивания:
Спасибо, невнимателен, пропустил 2. Bootloader A3.CF No RSA.
Сообщение отредактировал sEVANS - 12.10.2009, 6:51
ХАОС
сообщение 17.10.2009, 22:44
Пользователь №: 208 071
Модель телефона: V3 V8 A1200
Хой. Всем Хой. Я недавно прошил свой V8 прошивкой - Evolution 3, V8 и теперь мой тел не хочет конектиться с компом, хотя до этого было все нормально. Кстати, эт не первый раз я его прошивал. Перед этим стояла - Elysseum Plus Edition, V8. У мя мало опыта в прошивках(до этого прошивал А1200 и он и сча работает) может кто че подскажет. Заранее благодарен.
Serger75
сообщение 20.10.2009, 10:03
День добрый, перепрошился сначала прошивкой-перегрузил, затем обновлением-перегрузил, но видео в разрешении 288x352 - не появилось ни в настройках видео, ни в tweaks? sad.gif
Как ни странно но, установка языка, путь: /ezxlocal/download/mystuff/language/ и копируем туда содержимое архива с лэнгпаком. Перезагружаемся (У меня так работает, путь без папки apps).
Сообщение отредактировал Serger75 - 20.10.2009, 10:25
Serger75
сообщение 21.10.2009, 17:46
Неужели никто не подскажет, где находятся настройки камеры 288x352? Т.к. повторно прошил обновление и перегрузил. sad.gif
Мдя, вот добавьте в "шапку":
Ok Guys I found it;
just reset the phone,
Settings/phone settings/Reset
and medium size resolution changed from 176x144 to ---> 352x288
Сообщение отредактировал Serger75 - 21.10.2009, 19:09
KoJIoBASS
сообщение 17.11.2009, 6:20
Пользователь №: 174 352
Модель телефона: RAZR 2 V8 2Gb
Прошивка: Fusion 3
У кого-нибудь были проблемы с будильником на этой прошивке?
Вчера прошился, сегодня с утра будильник не зазвонил, на рабочем столе уведомление о будильнике осталось.
Сообщение отредактировал KoJIoBASS - 17.11.2009, 8:46
Прошивка Evolution 3, V8 · Motorola ROKR Z6, RIZR Z6, Z6w, RAZR² V8 · Forum
Текстовая версия Сейчас: 5.8.2025, 0:46
