croccio
сообщение 30.1.2009, 17:11
Пользователь №: 161 521
Модель телефона: L7 Slvr, c350
can u give me the elf's patch and all elf for my v3x?
i've heartless@v3x
Dark Beat
сообщение 30.1.2009, 18:05
moto>inside
Пользователь №: 149 866
Модель телефона: .
croccio,
this nice topic Rainbow POG PortKit & SDK - all can I find on motofan...
croccio
сообщение 30.1.2009, 18:21
i don't understand russians language, can u post it here please?
Dark Beat
сообщение 30.1.2009, 19:34
moto>inside
Модель телефона: .
__________
FlexEditor, config. file to /a/ (root)
https://forum.motofan.ru/index.php?act=Attach&type=post&id=175867
__________
I made some CRITICAL changes.
Fixed alignment of symbol's values and removed multiple relocations.
LOADER
Almost forgot. You need to recompile all elfs to work with new version of elfloader, because structure ElfLoaderApp was changed (added pointer and var for .bss), so elf's which wewr compiled before will reboot phone at exit.
__________
HexEditor v3x
https://forum.motofan.ru/index.php?act=Attach&type=post&id=180006
__________
Light v3x (config to b\elf\)
https://forum.motofan.ru/index.php?act=Attach&type=post&id=180652
__________
Elfs for e770 (or v3x???)
https://forum.motofan.ru/index.php?act=Attach&type=post&id=177844
__________
Ones more pack for e770
https://forum.motofan.ru/index.php?act=Attach&type=post&id=184915
__________
BTSaver (need this patch PATCH. It is for E6P v3x.)
How to. Setup patch, set saving all files to flash-card, and create in the root of it folder recieved. Launch elf. All unknown files recieved in BT save to that folder. From browser - all there.
__________
Blacklist. Need to update library.def (in archive exists def for E6P). Works as similar patch "5th group" ("Blacklist").
https://forum.motofan.ru/index.php?act=Attach&type=post&id=192520
__________
croccio
сообщение 31.1.2009, 15:02
thank u very much! but where is the patc?
Dark Beat
сообщение 31.1.2009, 15:35
moto>inside
Модель телефона: .
Which patch??? For BTSaver? E6P https://forum.motofan.ru/index.php?act=Attach&type=post&id=191397
croccio
сообщение 31.1.2009, 15:46
i would the elf's loader's patch
Dark Beat
сообщение 31.1.2009, 16:19
moto>inside
Модель телефона: .
RainbowElfLoader_V3x_e6p_rev77_01.08.2008
croccio
сообщение 1.2.2009, 15:39
thank u very much i try it now
uwie
сообщение 3.2.2009, 10:26
Пользователь №: 183 590
Модель телефона: v3x
can you give me explanation about blacklist elf.. how does it work?
(3.2.2009, 10:28):
Dark Beat
сообщение 3.2.2009, 13:23
moto>inside
Модель телефона: .
Цитата(Chik_v @ 21.1.2009, 22:49)
Он должен блокировать вызовы от номеров, которые находятся в пятой группе справочника.
It must to brake calls from tel. numbers, which are in 5th group of contact list (4 main - general, etc.) - your first added manually group.
uwie
сообщение 4.2.2009, 2:33
dark beat.. thanks very much.. i'll remember your name..
btw u mean that i must create catagories until 5.. and the 5th catagory is the list of blacklist.. okey i got it.. but why now anyone can't call me.. huhu..
darkbeat.. how about the recent patch for v3x.. after heap division 3 1...
thanks darkbeat..
about patch bt saver why it always show error integer value..i cant add patch..
Dark Beat
сообщение 2.3.2009, 8:42
moto>inside
Модель телефона: .
uwie,
sorry I just now had saw your post. tomato.gif If you still waiting for answer
Go to menu "Security" then "Restrict Calls". There are Incoming and Outgoing calls menus.
In Incoming:
ALL - all calls are receiving.
Phonebook - all, but from 5th category - no.
NO - all calls are ignoring.
But after that in Incoming menu
ALL - all numbers are allowed.
Phonebook - uses the "Incoming menu" mode.
NO - all numbers are forbidden.
Сообщение отредактировал Dark Beat - 2.3.2009, 8:44
elfs in v3x · For English speaking members · Forum
Текстовая версия Сейчас: 17.9.2025, 21:58
