5 страниц V « < 2 3 4 5 >
Прошивка Basic Plus, V8
abelenki
сообщение 13.4.2009, 2:44 Закрепленное сообщение!
Из: Russia, Perm
Пользователь №: 94 097
What is Basic Plus?
It is a basic unbranded NO_RSA firmware based on 80.46.1BR for 512MB V8 and 80.56.1BR for 2GB V8 with added 5 customization menus
(Change Bootlogo, Font Changer, Startup-/Shutdown Sound, Alarm Clock Timer and Reminder Sound), USB-Lan and Swap memory by default. That's it!
Now this space saving allowed to return to the old system of changing the language by flashing the CG46.
That is the Basic part!
The Plus part includes a Package Manager and you can install what you want and leave out what you don't want. There are 18 packages supplied, which would include the complete Evo 3 range, some have been upgraded, like zLauncher is version 2.1, pictureflow is upgraded and SlideShow is a development of pictureflow made by DeJe. You just have to copy the packages (*.tar.gz files) into /ezxlocal/download/mystuff/package. The Package Manager (you find it in the Package folder in the Main Menu) will install and uninstall packages. During installation you have to enter a menu name, for example you install zLauncher then you can call the menu whatever you want (e.g My Filesystem or Mein Dateienfresser), which is nice if you do not use english as your language. Secondly during installation you can associate file extentions, which most packages do not need. Also, because most Mods now come with a selection of languages and the packages are installed in /ezxlocal/download/mystuff/packages/apps, which is read/write filesystem, you can change the menus to your language. All packages menus will be installed in the Package folder below Package Manager, you either leave them there or you move them to somewhere else, your choice.
USB-Lan and Swap Memory are in the Settings menu, USB-Lan at the beginning and Swap Memory at the end, as you need to use Swap Memory only once to set up the swap file and activate it. After each reboot the swap file gets automatically activated. I have not included the Java HEAP Setting package as I have set the the default HEAP size to the maximum of 4096KB by default.
If you really MUST use Windows Explorer instead of FTP then shutdown the swap file first then change to USB Setting Memory Card and connect with USB cable to PC, the V8 will not hang itself.
MPlayer, because of its /mmc/mmca1/Programms path requirement has been not supplied as a package. However the MPlayer menu exists under Multimedia and all you have to do is copy the included MPlayer folder into /ezxlocal/download/mystuff/Programms on the 512MB V8 or into /mmc/mmca1/Programms on the 2GB V8, that's all.
Another change is that the ezx_flexbit.cfg is now under /ezxlocal/download/appwrite/flexbit, this allows to change the flexbit without the need to flash a CG43 every time you edited the ezx_flexbit.cfg. Just copy your new ezx_flexbit.cfg file into this folder and reboot.
I have tried to make this firmware as simple as possible, as from the comments about Evo 3 saw that a lot just could not get the hang of the different language system and how to handle it.
The need for a Package Manager was always high on the list, also the result of comments and requests like "we do not need this, but can we have that..." and then "we do not need that, but can we have this...", so now everybody can decide themselves what they want and what not.
There are already 2 package management system around (PEP and mpkg), so why creating a new one? Well, I was hoping that there would be a PEP for V8, but that project got put on hold and by request of the PEP creators I could not port it to V8, so that left only mpkg. Now mpkg might be fine for the Z6, but it is not good enough for the V8 and the reasons are that mpkg packages are installed from and onto the Z6 SD card (/mmc/mmca1) this path exists only on 2GB V8, but not on 512MB V8, secondly mpkg packages for Z6 do not work on V8, they need modification in order to work on the V8 (huge potential for future post " I installed mpkg package, but it does not work ."). Thirdly the icon management of mpkg produces only black exclamation marks on yellow background (mpkg uses one icon for std and ani icons, no small icon). which honestly does not look nice to have on your phone. Fourthly the AppID creation is rather simple and the V8 always has been quite fuzzy with "home made" AppID's. So, I either rewrite mpkg to fit V8 and change Z6 mpkg packages into V8 mpkg packages, which still leaves the door wide open for people to install Z6 mpkg packages on V8 and wonder why they do not work. So I decided against that option and created my own package management. Anyway Linux is all about choice, so there you go!
You might find that the Customize menu looks a bit different, this was done on purpose.
OK, I could not have done this without the help, inspiration and testing from DeJe (faq4mobiles.de) and DaRk_dOg (MMUS et al.), their work, ideas and contribution helped to shape this firmware. THANKS!
But a big thank you has to go out to all the other unnamed modders, who's work, modified or not, found their way also into this firmware. THANK YOU!
As with all my work, this firmware is also free for everybody to change, use parts of it or simply print out the code and wallpaper your room with it.
Автор:
rasputin007
Оригинальный топик:
modmymoto.com
Описание:
1. Прошивка No RSA.
2. Лэнгпак шьётся по-старому, через RSDLite.
3. Теперь дополнительные программы устанавливаются пакетами, аналогично PEP, только они имеют свой формат. (т.е. теперь можно выборочно ставить то, что тебе нужно). Пакеты нужно копировать в /ezxlocal/download/mystuff/package, а потом инсталлировать или дизинсталлировать через Package Manager. В процессе инсталляции пакета, вы можете присвоить ему любое имя, а также ассоциировать с ним любые расширения (для большинства пакетов это не нужно).
4. USB-Lan и Swap Memory находятся в меню Settings. Swap Memory нужно запустить и настроить всего лишь один раз. Он активируется автоматически после ребута или включения телефона.
5. Если не активировать файл подкачки (Swap Memory), телефон теперь можно подключать в режиме мемори-карты, и при этом он зависать не будет.
6. Java HEAP автоматически установлен на максимальное значение - 4096KB.
7. MPlayer не включен в виде пакета, а устанавливается по-старому. Т.е. просто скопируйте его в /ezxlocal/download/mystuff/Programms на V8 512MB или в /mmc/mmca1/Programms на V8 2GB. Ярлык на него уже установлен в прошивке и находятся в Multimedia.
8. Файл ezx_flexbit.cfg теперь находится по этому пути - /ezxlocal/download/appwrite/flexbit. Теперь его можно спокойно редактировать, перезаливать в телефон и перезагружаться, чтобы изменения вступили в силу (разборка, редактирование, сборка и прошивка CG43 больше не требуется).
9. Видео-камера теперь снимает в разрешении 352x288.
Порядок прошивания:
1. Bootloader A3.CF (если у вас какой-либо другой бутлоадер).
2. Bootloader A3.CF No RSA.
3. Прошивка Basic Plus Update (прошивайте версию прошивки, соответствующую вашей модели телефона - 512MB или 2GB. Для Luxury Edition прошивайте версию 2GB).
4. Лэнгпак LP002EE.
Файлы:
Bootloader A3.CF
512MB Basic Plus Update
2GB Basic Plus Update
LP002EE - UK English, German, Russian, Ukrainian, French, Spanish & Portuguese; Russian voice commands only
Basic Plus Update Packages
MPlayer
V8 Modding Guide
Сообщение отредактировал XXX_S_B - 20.2.2013, 16:09
Vermin
сообщение 28.10.2009, 12:57
Пользователь №: 64 122
Модель телефона: V635; V8
Прошивка: Своя; Basic Plus
Цитата(pirsn @ 26.10.2009, 17:21) *
Устал бороться, откатился на стандартую R601 G 80.56.15R. Пакеты не ставились, почему-то не работала клавиша плеера, подтормаживал иногда в контактах и , с чем не смог справиться - упорно отказывался звонить поставленным рингтоном, первый раз такое видел.
Ты единственный столкнувшийся с такими проблеммами на этой прошивке. Может стоило прошиться еще раз?
prSapphire
сообщение 31.10.2009, 17:46
Из: Владивосток
Пользователь №: 56 874
Модель телефона: Atrix 4G/Milestone
Прошивка: MIUI v4/MIUI GB
в ожидании чуда ))
Возникло несколько вопросов. Очень рад буду любой помощи, сам я понять как-то не в силах.
Итак, первое, не могу назначить на архивные файлы ассоциации. И проблема даже не в этом, хоть и пишет что архив распакован, но на самом деле ничего похожего. Почему?
Второе, ява адаптер файлы не хочет переделывать, точнее превращает их в 22 кб файлы, которые естественно не работает.
Третье, софтбокс не дает права приложениям. Точнее дает, но они после этого не работают, пишут ошибку проверки сертификата.
Это как бы основное, но еще появился странный глюк. Если пакеты устанавливать и удалять, сначала идет смещение по меню, потом телефон на мертво виснет и может помочь только прошивка заново. Уже дважды за двое суток.
Кстати, телефон 512 версии.
Жду помощи. Спасибо заранее.
Mоторчег
сообщение 1.11.2009, 5:52
Пользователь №: 132 481
Модель телефона:
присоединяюсь, софтбокс корежит яву
prSapphire
сообщение 3.11.2009, 6:02
Из: Владивосток
в ожидании чуда ))
Раньше на форуме народ был активнее, как-то старался помочь другим.
Или видимо решения этих проблем нет и она не только у меня.
Не понимаю тогда в чем смысл этих всех пакетов, если они не работают должным образом. Архиватор не распаковывает, адаптер не переделывает нормально яву и прочее. Короче, они и есть (пакеты) и толку от них нет.
любопытнный
сообщение 3.11.2009, 10:39
Пользователь №: 183 849
Модель телефона: Motorola Accompli 008
Прошивка: ОЧЕРЕДНАЯ
prSapphire, https://forum.motofan.ru/index.php?act=Attach&type=post&id=204269 У меня такое было после установки этого обновления.Выход простой:сначала всё установил или удалил
потом обновился,но тел на 2Гб.
ГлюЧный_МоторчеГ-Л7,
Переустанавливал раз 10-сейчас работает:наверное прижился...
prSapphire, Раньше на форуме народ был активнее, как-то старался помочь другим
Культ Зэт6 к сожалению
prSapphire
сообщение 3.11.2009, 10:50
Из: Владивосток
в ожидании чуда ))
любопытнный,
Насчет этого обновления я тоже догадался что всё дело с зависанием из-за него. Но это не объясняет почему пакеты нормально не работают, я всё про тот же софтбокс, адаптер и архиватор. Они ни до, ни после обновления не работали sad.gif
это обидно, хотелось бы права яве и её адаптацию проводить сразу на лету через телефон, а не каждый раз бежать к ноутбуку.
prSapphire
сообщение 6.11.2009, 10:51
Из: Владивосток
в ожидании чуда ))
Итак, небольшие выводы которые успел сделать.
Минусы: iTap быстро забывает слова, причем везде. Arcman справляется только с форматом tar.gz, всё остальное ему не по силам. Javaadapter не корректно работает, точнее совсем не работает. SoftBox после некоторой раскачки дает права яве, с этим наконец проблем нет, но вот иконки приходиться возвращать самому. К остальным пакетам особых притензий нет. Либо не нужны, либо работают. Зато, после обновления, удалять пакеты лучше не стоит, грозит полным зависом телефона, спасает только прошивка сначала. У MPlayer меню вызываться не хочет.
Плюсы: работает быстро, и почти все возможное может выполнить.
Vermin
сообщение 7.11.2009, 11:57
На счет удаления пакетов. Если удалять пакеты установленные после установки удаления, то все нормально удаляется. Еще не стоит рассортировывать установленные программы по папкам. Иначе после удаления какого либо пакета исчезают все ярлыки.
prSapphire
сообщение 8.11.2009, 4:59
Из: Владивосток
в ожидании чуда ))
Не факт. Пакеты у меня лежат без папок, а вот ява разбросанна по папкам. Результат один, удалять нельзя. Слетают ярлыки и телефон просто уходит в постоянный вис. Риск большой, но яву удалять можно, проблем не возникает. Пакеты лучше не трогать
Vermin
сообщение 8.11.2009, 11:34
Видимо зависит от конкретного телефона. Ставил и удалял уже кучу прог.
любопытнный
сообщение 10.11.2009, 9:47
Прошивка: ОЧЕРЕДНАЯ
Vermin, Случаем duke nukem под Бейсик+ нет? Или напиши как адаптировать pep или MPKG. я делал так:распаковывал MPKG,создавал папку apps.укладывал в неё файлы дальше всё запаковывал в tar.gz -не работает.Таким же способом пробовал перепаковывать пакет от А1200/Е6 не запускается вообще.Описания принципа адаптации на форуме есть.но нет частностей по В8.Поделись секретом ,если не тяжело.
Vermin
сообщение 10.11.2009, 12:42
Все собираюсь собрать. Даже начал, но не успел. Завтра постараюсь сделать. Там не только собрать надо, но еще пути править надо. Еще я собираюсь либы отдельно сделать, чтоб не шли одни и теже с каждым пакетом.
miccca
сообщение 11.11.2009, 18:36
Пользователь №: 146 928
Модель телефона: Motorola V8 2Gb
Прошивка: R601_G_80.56.15R
а почему после прошивки у меня шрифт квадратиками?
Добавлено позже (11.11.2009, 18:49):
и ещё при прошивке bootloader пишет Err:A5.694E.24
Добавлено позже (11.11.2009, 20:21):
о ! заработало только теперь у меня нет папки package что с этим делать?
Vermin
сообщение 12.11.2009, 0:23
Прошить еще раз.
prSapphire
сообщение 12.11.2009, 4:20
Из: Владивосток
в ожидании чуда ))
При шрифте квадратиками ищи Customise, переходи на вторую вкладку ищи в ней Change Font и заменяй его на Default. Квадраты превращаются в привычные буквы. smile.gif
Насчет ошибки с бутом, убедись что прошиваешь верный, со снятым RSA.
А вот про исчезазание папки, сказать ничего не могу. Такого у меня не было 0_0
Vermin
сообщение 12.11.2009, 7:30
Выбрал время и предоставляю вашему вниманию DukeNuken 3D. Сначала нужно установить либы.
Внимание! либы запускать НЕ НУЖНО! После установки пакет можно удалить чтоб ярлык не болтался в меню. Не забываем, что после установки
Прикрепленный файл eduke32.tar.gz   ( 970.94 килобайт ) Кол-во скачиваний: 294
в папку с приложением нужно скопировать GRP файл. Подробнее об этом тут.
З.Ы. На 512M скорее всего не пойдет, так как либам нужен путь /mmc/mmca1/.system/ для файла конфигурации, которого на данных телефонах просто нет.
любопытнный
сообщение 12.11.2009, 14:09
Прошивка: ОЧЕРЕДНАЯ
Vermin, Сбылась мечта идиота!!!! Установил без проблем- тестирую,просто в восторге.Как переназначить выход на красную кнопку?
Vermin
сообщение 13.11.2009, 0:37
Цитата(любопытнный @ 12.11.2009, 22:09) *
VerminКак переназначить выход на красную кнопку?
Сейчас сам над этим бьюсь.
Разобрался. Надеюсь к вечеру выложу обновление. Кнопки можно будет переназначить. Кстати на 512M версии Duke работать должен, но без переназначения кнопок
Сообщение отредактировал Vermin - 13.11.2009, 3:10
Sufy
сообщение 15.11.2009, 11:52
Из: Ближнее Замкадье
Пользователь №: 27 061
Прошивка: MIUI
abelenki,
поправьте в описании: на 2-х гиговой версии пакеты надо кидать в корень папки mmc/mmca1/package/
по указанному в описании адресу не работает. да и папки package по умолчанию там нет
любопытнный
сообщение 17.11.2009, 8:03
Прошивка: ОЧЕРЕДНАЯ
Vermin, Шансов нет?
Vermin
сообщение 18.11.2009, 8:33
Цитата(любопытнный @ 17.11.2009, 16:03) *
Vermin, Шансов нет?
Шансы есть, времени нет.
Готово! Обновленный Duke:
Прикрепленный файл eduke32.tar.gz   ( 972.11 килобайт ) Кол-во скачиваний: 248
Для тех, кто скачал ранее выложенный, предлагаю патч.
Патч установить и запустить один раз, затем его можно удалить.
Клавиши переназначаем в файле mySDL.cfg (Внимание! на версиях 512M клавиши переназначить нельзя!)
Сообщение отредактировал Vermin - 20.11.2009, 14:20
kirpich6900
сообщение 19.11.2009, 13:05
Пользователь №: 188 920
Модель телефона: Motorola XT720
Прошивка: RUS MOD 2.10
Прошился basic plus'ом много глюков половил вначале... и квадратики вместо текста и папка с package исчезла сама по себе разок... стоит внимательно почитать посты и все проблемы решаются достаточно просто. Пока особых нареканий на прошивку нету, есть только один вопрос при попытке залить музыку файлы которые были обозваны русскими буквами превращаются в... вобщем от названий остаются только дефисы, как с этим бороться? unsure.gif
Добавлено позже (19.11.2009, 16:09):
я просто вручную создал папку и всё норм
Vermin
сообщение 20.11.2009, 5:11
Через что закидываешь? Не все ftp клиенты корректно передают русские имена. Можно выбрать подключение Tools. открыть проводник Windows и в адресной строке набрать ftp://root:root@192.168.16.2/mmc/mmca1/Music/ и кидать музыку.
KoJIoBASS
сообщение 20.11.2009, 19:54
Пользователь №: 174 352
Модель телефона: RAZR 2 V8 2Gb
Прошивка: Fusion 3
Прошивка пока что радует, даже и работает как-то побыстрее чем Evolution три.
...что-то меня на игры понесло, как-нибудь можно портировать quake2 на эту прошивку?
Добавлено позже (20.11.2009, 21:14):
Решается только перепрошивкой, или можно накатить какой-нибудь апдейт?
Сообщение отредактировал KoJIoBASS - 20.11.2009, 20:53
dvrts
сообщение 21.11.2009, 5:21
Из: Lviv
Пользователь №: 162 099
Попробуй общий сброс/очистку
Vermin
сообщение 21.11.2009, 7:19
Можно. Попробую.
Не понимаю. Ты какой апдейт ставил? Телефон перезагружал?
KoJIoBASS
сообщение 21.11.2009, 8:19
Прошивка: Fusion 3
Общий сброс(который factory reset) не работает.
Если правильно нашёл ответ то:
Цитата(abelenki @ 29.6.2009, 10:36) *
смысл в том, что rasputin007 неправильно указывал синтаксис комманды mksquashfs, из-за этого не включались скрытые папки типа .backup. как следствие - в этих прошивках не работает Reset (ведёт к зависанию прошивки).
Прошивка чистая. Ставил пакеты, разкидал их по главному меню. Потом решил некоторым программам назначить имена. Удалил их, начал ставить заного и... фига, в меню они больше не появляются..никакие не появляются laugh.gif
Пока что единственное быстрое решение принял- перешить ещё раз.
Добавлено позже (21.11.2009, 10:45):
Vermin, не подскажешь как переделывать приложения? Инструкцию по переделке не найти, а руки чешуться smile.gif
Пробывал сам переделать Quake 2, устанавливается, папка появляется.. а не работает sad.gif
Видимо что-то неправильно прописал, непонимая...
Сообщение отредактировал KoJIoBASS - 21.11.2009, 10:46
KoJIoBASS
сообщение 22.11.2009, 9:08
Прошивка: Fusion 3
Нашёл глюк с профилями вызова, а точнее с профилем "Мелодия и вибрация". Как
переключаюсь на него, у телефона пропадают звуки в меню, бывает мелодия вызова слетает на стандартную.
Иногда смена профеля боковыми клавишами не применяется .(меняю на профиль"Только мелодия" с профиля "Вибро & Звонок", нажимаю применить и остаётся прежний профиль вызова)
Сообщение отредактировал KoJIoBASS - 22.11.2009, 9:09
Vermin
сообщение 22.11.2009, 11:03
В этом и проблема. Я же писал, что нельзя перемещать ярлыки. Либо после перемещения эти проги не удалять.
Мне переделать то времени нет, а ты говоришь рассказать. Поковыряйся, разберешься.
KoJIoBASS
сообщение 22.11.2009, 11:08
Прошивка: Fusion 3
Пути подправил, но видимо пречина в lib-ах. Поэтому и решил узнать..
Vermin
сообщение 23.11.2009, 0:33
Выложи то что ты сделал на обменник и мне ссылочку в личку. Я посмотрю.
KoJIoBASS
сообщение 24.11.2009, 16:28
Прошивка: Fusion 3
В общем, ссылка на Quake 2 мною правленный, не рабочий. А то в ЛС у меня папка отправленные пустая(и неотправленные тоже smile.gif)
Vermin
сообщение 26.11.2009, 0:30
Ну вот и долгожданный QuakeII!
Не забываем про pak0.pak Смотрим тут. который кидаем в /.quake2/baseq2/ в каталоге программы (либо создаем сами, либо пытаемся запустить игру и он создается сам). Также не забывем, что должны стоять LibSDL.
Большое спасибо KoJIoBASS, который разжег во мне интерес к адаптации данной игры. smile.gif
Работа на версии 512М возможна, но не гарантируется!
Сообщение отредактировал Vermin - 26.11.2009, 11:23
KoJIoBASS
сообщение 26.11.2009, 7:19
Прошивка: Fusion 3
Спасибо огромное!! Работает! Только со свапом, без него вылетает.
Класс!
Ещё, Vermin, версия будет работать скорее всего только с 2gb версиями, пути же на mmc/mmc1?
Добавлено позже (26.11.2009, 9:24):
Ну что же, встречайте мною переделанную первую игру Heretic
Так же не забываем про LibSDL и WAD файл смотрим тут кидаем в /mmc/mmca1/package/apps/heretic/
После установки перезапускал телефон, иначе не запускалась.
Версия будет работать только на 2gb, с 512 просим переделать Vermin
Отписывайте у кого как работает.
ссылка для скачивания Heretic
Сообщение отредактировал KoJIoBASS - 26.11.2009, 11:27
любопытнный
сообщение 26.11.2009, 10:25
Прошивка: ОЧЕРЕДНАЯ
Поставил себе,без swapа не хочет работать,но Дюк запускается и работает.swap у меня был раньше включен,теперь через Меню-Настройки-Swap Memory не могу активировать.Sysinfo пишет Swap Memory 0,но Дюк работает и не тормозит.Как мне включить Swap?Или изменить на 64,тк при первом запуске ставил 32?
Добавлено позже (26.11.2009, 12:30):
Quake 2 и либы не нужно ставить на каждую игру?
Vermin
сообщение 26.11.2009, 11:21
Даже не знаю чем помочь... Ты случаем не удалял папку .swap на карте?
Либы нужно поставить ОДИН раз. И просьба ко всем, кто будет адаптировать игры и проги под эту прошивку использовать путь к либам: /usr/local/lib/ Либы в папке с приложениям удалять, дабы не плодить копии файлов и не занимать место.
Работать скорее всего будет и на 512М, просто не везде можно будет переназначить клавиши управления.
KoJIoBASS
сообщение 26.11.2009, 11:28
Прошивка: Fusion 3
любопытнный
сообщение 26.11.2009, 19:54
Прошивка: ОЧЕРЕДНАЯ
Похоже случайно удалил,её просто создать? Или что в ней должно быть?
Vermin
сообщение 27.11.2009, 1:16
Там скрипты и бинарники. Держи мою папку. Только точку впереди не забудь поставить.
любопытнный
сообщение 27.11.2009, 9:35
Прошивка: ОЧЕРЕДНАЯ
Vermin, Спасибо,поставил всё работает.
Прошивка Basic Plus, V8 · Motorola ROKR Z6, RIZR Z6, Z6w, RAZR² V8 · Forum
Текстовая версия Сейчас: 18.7.2025, 6:24
