8 страниц V « < 6 7 8
[MP] Freedom Features Update [SWAP + CIF + MPKGBOX]
OCM770
сообщение 10.7.2009, 7:33 Закрепленное сообщение!
Пользователь №: 196 171
By OCM770 in cooperation with Kidscracker and Skrilax_CZ
Based on R6637_G_81.00.7FR + R6637_G_81.11.2CR Fixes & Kernel
Credits
For this MP I would specially like to thank my friend Kidscracker, for helping me out on some things, backing me up on this project, and of course developing Mpkgbox, he is a great person and an awesome developer wink.gif
Second I would like to thank Skrilax_CZ for giving me great suggestions for this MP and of course patching the camera libs and mediaplayer lib. Also thanks to fldodger for fixing the Alkali skin and Skrilax for perfecting it.
Also thanks to Ant-ON for developing zTaskMan, AnarH and Tim_22R for making the main menu svg files
Then I would like to thank the Motorola modding communities on the net, especially ModMyMoto which is where I grew up and MMUS for taking me in as part of their team. Both communities very friendly and helpful, keep it up guys :D
Change log:
So I wasn’t satisfied with Freedom 7FR. I was convinced it was possible to run a custom kernel and have everything else working correctly. At last I figured out how to do so and took the opportunity to change more things, adding more features and some tweaks and bugfixes. So I present to you this MP which in my opinion excels over my previous one. As more mods come out and more developers obtain a ZN5 I will continue making more MP’s. I hope you like this MP wink.gif
Kernel Mods:
  • SWAP Support
  • Squashfs 3.4 Support. Now this is a real handy feature for developers. Using this kernel in another firmware you can use Squashfs 3.4 to squash the code groups using a block size of up to 1MB for a greater compression. It uses default block size of 128kb. Compared to Squashfs 2.2 with a max block size of 64kb.
  • EXT2, EXT3, NTFS Support
  • IPv6 support (needs to be tested)
CG36 Mods:
  • Bash (as a replacement for busybox ash)
  • busybox version 11.14.1 with many more features than standard busybox (as /bin/busybox_full)
  • EasyThemes by ilove3d (drop skin folders in /ezxlocal/download/mystuff/skins/) with SVG support.
  • Mediaplayer can play CIF videos.
  • zTaskMan included under Office Tools and Main Menu (in CG52)
  • Modification of some SVG files to edit softkey size in main menu and make main menu 15 icons
  • SWAP file gets turned off when connected in memory card mode and automatically re-enabled when disconnected from PC. This to avoid the phone crashing.
  • Mpkgbox (by kidscracker, original by ilove3d)
  • RAW and Binned RAW Pictures with fixed remaining picture estimate and red icons in iconres.ezx
  • CIF Recording 15FPS
  • Telnet&FTP (Modem&Tools)
  • Run Scripts from File Manager
  • Unrar and Unzip from File Manager
  • Show* Modules
  • Removal of certain modules to increase firmware speed
Extras:
  • Optional Features (read below)
  • Custom Bootscreen
  • Custom Startup/Shutdown Animations
  • 15 icon main menu (animated with optional features)
  • Skins: Alkali (fixed), Kodak, Indium
Optional Features & SWAP
Right after flashing this firmware the phone will prompt to install Optional Features. What these do is install the medl and medld.conf folder along with some GUI tweaks (changed font, main menu animation, etc). You can chose to install these in Phone Memory or Memory Card (I HIGHLY recommend installing them to phone memory). Either choosing to install these or to not install them the phone will only prompt once. (To make the script run again delete /ezxlocal/medl or if you chose not to install them delete /ezxlocal/delete_to_run_initial_script).
Even if you chose not to install Optional Features the phone will still prompt if you want to install and enable SWAP. Once again, you can install this feature to phone memory or memory card ( I still recommend to install to phone memory). You can chose a swap file size of 32mb or 64mb ( I recommend 64mb for 062A users and 32mb for 062DP users). This part of the script will also only run once (to make it run again remove /ezxlocal/delete_to_run_initial_swap and /ezxlocal/download/mystuff/swapfile (for internal memory) or /mmc/mmca1/swapfile (for external memory))
Instructions
  1. Use RSD Lite 4.x for all flashing
  2. Download the version that corresponds to your bootloader (062DP is also for 062B users)
  3. Flash noRSA bootloader that corresponds to your bootloader
  4. Flash the version of Freedom Features Update that corresponds to your bootloader
  5. Follow Optional Features Instructions and wait for it to reboot (if by any chance it doesn’t reboot wait 3-5 minutes then remove/reinsert battery)
Download Link: Known Bugs:
  • Volume for mediaplayer can’t be modified from homescreen
ПЕРЕВОД:
От OCM770, совместно с Kidscracker и Skrilax_CZ
Основан на R6637_G_81.00.7FR + R6637_G_81.11.2CR Испрвлениях & Ядре
Благодарности
За этот монстрпак я должен особенно поблагодарить моего друга Kidscracker-а, за помощь мне в нескольких вещах, за то что вернул меня в этот проект и, конечно, за разработку Mpkgbox. Он великий человек и офигенный разработчик.
Во-вторых я хочу поблагодарить Skrilax_CZ за большие предложения для этого MP и, конечно, за патчинг либ камеры и медиаплеера. Также спасибо fldodger-у за исправления скина Alkali и Skrilax за доведение его до ума.
Также спасибо Ant-ON-у за разработку zTaskMan-а, AnarH-у and Tim_22R за переделку svg файлов для главного меню.
Далее я хочу поблагодарить сообщества моддеров телефонов Motorola в сети, особенно ModMyMoto, где я вырос, и MMUS за то что взяли меня как часть своей команды. Оба этих сообщества очень дружелюбны и готовы помочь, будьте такими всегда, ребята.
Изменения:
Итак, я не удовлетворился Freedom 7FR. Я был убежден, что возможно запустить свое ядро и все будет работать правильно. Наконец, я понял как это можно сделать и воспользовался этой возможностью, чтобы изменить больше вещей, добавить больше возможностей и некоторое количество фишек и исправлений ошибок. Итак, я представляю вам этот MP, который, по моему мнению превосходит предыдущий. По мере появления новых модов и новых разработчиков, имеющих ZN5 я продолжу делать больше монстрепаков. Я надеюсь вам понравится этот MP.
Моды ядра:
  • Поддержка swap.
  • Поддержка Squashfs 3.4. Это действительно удобная функция для разработчиков. Используя это ядро в других прошивках вы можете использовать Squashfs 3.4 для сборки кодовых групп с размером блока до 1 мегабайта для большего сжатия. По умолчанию используется размер блока 128 килобайт. По сравнению с Squashfs 2.2 с максимальным размером блока 64 килобайта.
  • Поддержка EXT2, EXT3, NTFS
  • Поддержка Ipv6 (необходимо тестирование)
Моды в CG36:
  • Bash (как замена для busybox ash)
  • busybox версии 11.14.1 с намного большим количеством функций чем стандартный busybox (как /bin/busybox_full)
  • EasyThemes от ilove3d (кидайте скины в папку skin в /ezxlocal/download/mystuff/skins/) с поддержкой SVG.
  • Mediaplayer теперь может проигрывать CIF видео.
  • ZtaskMan, включенный в меню Органайзер и Главное меню (в CG52)
  • Модификация нескольких SVG файлов для изменения размера подписей к софт-клавишам и 15 иконок в галвном меню
  • Swap файл выключается, когда телефон подключается в режиме карты памяти и автоматически включается при отключении от ПК. Это позволяет избежать зависание телефона.
  • Mpkgbox (от kidscracker-а, изначально от ilove3d)
  • RAW и Binned RAW режимы фото с исправленными рамкой и иконками в iconres.ezx
  • CIF запись видео 15FPS
  • Запуск скриптов из файл-менеджера
  • Распаковка rar и zip из файл-менеджера
  • Show* модули
  • Удалены определенные модули для увеличения скорости работы прошивки
Дополнительно:
  • Дополнительные возможности (читайте ниже)
  • Измененная загрузочная картинка
  • Измененная анимация на включение/выключение
  • Главное меню с 15 иконками (анимированное с дополнительными возможностями)
  • Скины: Alkali (исправленный), Kodak, Indium
Дополнительные возможности & SWAP
Сразу после прошивки телефон спросит, устанавливать ли дополнительные возможности. Что при этом делается — устанавливается папка medl и medld.conf вместе с несколькими настройками GUI (измененный шрифт, главное меню, анимация и т.д.). Вы можете выбрать куда устанавливать, в память телефона или на карту памяти (я НАСТОЙЧИВО рекомендую устанавливать мод в память телефона). Неважно, выберите вы установку или отмену установки, телефон больше об этом не спросит. (Чтобы запустить скрипт снова удалите /ezxlocal/medl или, если вы выбрали не устанавливать, удалите файл /ezxlocal/delete_to_run_initial_script). Даже если вы выбрали не устанавливать дополнительные возможности телефон спросит, хотите ли вы установить и включить Swap. И снова, вы можете установить его в память телефона или на карту памяти ( я снова рекомендую устанавливать в память телефона). Вы можете выбрать размер swap-файла, 32 или 64 мегабайта (я рекомендую 64 мегабайта для пользователей с бутом 062A и 32 для пользователей с бутом 062DP). Эта часть скрипта также запускается только один раз (чтобы запустить его снова удалите /ezxlocal/delete_to_run_initial_swap и /ezxlocal/download/mystuff/swapfile (для памяти телефона) или /mmc/mmca1/swapfile (для карты памяти)).
Инструкции.
  1. Используйте RSD Lite 4.x для всех прошиваний
  2. Скачайте версию, которая соответсвует вашему бутлоадеру (062DP также подходит и для пользователей с 062B)
  3. Прошейте noRSA бут, который соответствует вашему буту.
  4. Прошейте версию Freedom Features Update, которая соответствует вашему буту.
  5. Следуйте инструкции установки дополнительных возможностей и ждите, пока телефон перезагрузится (если он не перезагрузится, подождите 3-5 минут и вытащите/вставьте батарею)
Ссылка для скачивания:Известные проблемы:
Громкость в медиаплеере нельзя изменить пока плеер свернут на главном экране.
Senx Lukas K. and Neomoto for translate on Russian
перевод на РУССКИЙ
Сообщение отредактировал EXL - 25.11.2010, 7:47
Max75
сообщение 6.12.2009, 23:34
Из: Austria, Wien
Пользователь №: 47 985
Модель телефона: V8 Luxury /xt925 /X-Style
Чудное)
на карточке есть папка mpkgbox, кидаю туда.. эффекта ноль. в телефоне в mpkgbox ниче не появляется sad.gif.
и еще, какой файл нужно удалить чтобы эскизы картинок обновились?
Сообщение отредактировал Max75 - 6.12.2009, 23:36
Илья Дорошенко
сообщение 9.12.2009, 3:21
Из: под славным Тольятти
Пользователь №: 149 988
Прошивка: Самопал
Fgfnbz
не пойму про какие ты картинки... а вот про MPKGBOX я не помню... сами пакеты кидают в папку инсталлерс, потов в мпкгбоксе переходят во вкладку установки и ставят... а вот устанавливает она куда-то в .систем, ибо просто в папке мпгбокс у мну ниче не появлялось... а вообще в теме про мпкгбокс все описано...
Slim_Shady
сообщение 9.12.2009, 8:24
Пользователь №: 114 349
Модель телефона: Zine 5
А у меня процесс идет так:кидаю в любую папку на флэшке файлы .mgx через mgxbox устанавливаю и в папке mgxbox появляются папки с программами
Илья Дорошенко
сообщение 9.12.2009, 15:21
Прошивка: Самопал
Fgfnbz
Ты темой не ошибся?:)
причем тут mgxbox:) в этой прошивке по умолчанию его нет...
mus13
сообщение 14.12.2009, 6:19
Из: РД
Пользователь №: 44 644
Модель телефона: Mpx220+Zn5
Прошивка: outlaw1313 v1.0 FFE
FAN_TV, ты наверное настроил свой фридом по-человечески, ну там всякие боксы и менеджеры...конфиги и прочую белиберду.... может скинешь сюда... и я тоже установлю .... shuffle.gif
Neomoto
сообщение 14.12.2009, 6:56
Из: Белгород
Пользователь №: 72 604
Модель телефона: MotoZINE ZN5
Прошивка: sym X beta
mus13, ВОПРОС-ОТВЕТ
mus13
сообщение 14.12.2009, 7:17
Из: РД
Цитата(Neomoto @ 14.12.2009, 9:56) *
качаю, счас будем пробовать... просто вчера вернулся из москвы, хотел пару фоток сделать.... одна фотка и камера занята.... прошивка симбиозис .... обидно... фридом хоть и через переключение на видео, но всегда уверенно....
установил.... интересный скин....только вот цифры часов немного налазиют на дату, но это не особо существенно, со скоростью работы пока не разобрался - в течении дня посмотрию .... сенкс ...
Сообщение отредактировал mus13 - 14.12.2009, 9:12
swansea
сообщение 21.12.2009, 18:59
Пользователь №: 202 918
Модель телефона: motorola Zn5
Прошивка: Всякая
Всем привет...тут говорили как-то что Нэомото делал дополнение shuffle.gif (или как то так:) для Freedom
Можно ссылочку плиз, если возможно..
сообщение 21.12.2009, 22:52
Ссылка выше через пост
mus13
сообщение 22.12.2009, 6:05
Из: РД
Друзья мои! отличное дополнение от Неомото! всем советую! в отличии от стандартного фридама немного тормозит, но не так страшно. скин также очень понравился... вобщем все очень удобно и без лагов, по крайней мере пока... вот только такие пара неприятных минусов часы налазиют немного на дату, ну и стандартно в режиме блокировки пропадают часы....
Stray39
сообщение 23.12.2009, 13:07
Пользователь №: 198 407
Модель телефона: MOTOZINE ZN5
Прошивка: пока не определился
Да может и отличное....но телефон перестал видеть карту памяти...отформатировал карту посмотрим как дальше будет...
Сообщение отредактировал Stray39 - 23.12.2009, 16:26
mus13
сообщение 24.12.2009, 6:07
Из: РД
Stray39, у меня все нормально видится....
Mebius3912
сообщение 2.1.2010, 8:09
Пользователь №: 107 024
Модель телефона: Motorola DROID3
Прошивка: 5.7.906.ht862
поставил Symbiosis IV. удалил.
поставил Evolution. удалил
поставил Freedom + swap + 0003 лэнг + cpu + mplayer
все летает, кроме мплеера. на симбиозисе hd играл без проблем, а щас 320х240 тормозит. в чем беда?
вернул заводскую 05R + правленую группу от 0ER. работает быстро, камера хорошо, а то что нет мплеера - хрен с ним, всеравно по человечески не работает
Сообщение отредактировал Mebius3912 - 2.1.2010, 11:18
D-1c3
сообщение 26.10.2010, 14:31
Пользователь №: 150 086
Прошивка: свежая
у кого-нибудь осталась эта прошивка?? если да- залейте куда-нибудь пожалуйста! все старые ссылки не работают
Entom
сообщение 27.10.2010, 6:14
Из: Крыма!
Пользователь №: 159 951
Модель телефона: iPhone 4s
Прошивка: iOS 7
Люблю Apple, уважаю Motorola.
И мне бы хотелось поставить эту прошу. Залейте кто-нибудь.
MotoDr
сообщение 27.10.2010, 11:22
Пользователь №: 197 783
Модель телефона: Atrix HD
Прошивка: пока что труп
залил на рапидшару , но без регистрации там http://rapidshare.com/files/427414585/Free..._Update_062A.7z
Entom
сообщение 27.10.2010, 11:54
Из: Крыма!
Прошивка: iOS 7
Спасибо огромное.
FdasweL
сообщение 27.10.2010, 14:29
Пользователь №: 214 903
Модель телефона: ZN5
А для чего нужен файл CG31.sbf ?
сообщение 27.10.2010, 16:58
а как фото на этой прошивке? отстой? видео сиф норм пишет?
MotoDr
сообщение 28.10.2010, 2:53
уже точно не помню именно про Фридом, может и на нем тоже, не прошивался нестандартный лэнг без правленной цг31
Добавлено позже (28.10.2010, 13:57):
для тех, кто на качество фото внимание обращает - отстой smile.gif видео для Зины - очень даже норм
Entom
сообщение 28.10.2010, 5:53
Из: Крыма!
Прошивка: iOS 7
Вообще то ни одна проша не снимает с таким разрешением.
Фото - да, отстой.
Скорость реально порадовала.
Лэнг прошился и без CG31.
Stray39
сообщение 28.10.2010, 6:18
интересно а если поставить Штурм камеры Zn5 ... качество лучше будет.?
Сообщение отредактировал Stray39 - 28.10.2010, 6:21
сообщение 28.10.2010, 12:45
у кого есть возможность выложить пару фоток и пример видео, буду очень признателен.
Programmer-tm(Мотофан.)
сообщение 24.11.2010, 17:44
Из: Из мира сего
Пользователь №: 215 291
Модель телефона: Moto X Play
Прошивка: Модифицированная...
Перезалейте монстра. Хочется поюзать
EXL: Я перезалил монстра и обновил ссылки в первом посте, пользуйтесь!
Сообщение отредактировал EXL - 25.11.2010, 7:58
Stray39
сообщение 24.11.2010, 19:35
http://www.fayloobmennik.net/215888
сообщение 24.11.2010, 19:39
Из: Из мира сего
Stray39,
Благодарю)
Там ленг уже русский включает или свой зашивать придется?
Сообщение отредактировал Programmer-tm(Мотофан.) - 24.11.2010, 19:48
Stray39
сообщение 24.11.2010, 19:54
сообщение 24.11.2010, 20:37
есть только это походу: Freedom_Features_Update_062A
http://depositfiles.com/files/w1hi6ejqy
сообщение 29.12.2010, 19:34
прошивка хорошая, быстрая, видео снимает неплохо, фото тоже, чуть хуже может но не так что б плакать прям. вот только ленг русский где найти)
mus13
сообщение 30.12.2010, 5:54
Из: РД
Claus398, попробуй турболэнг. я уже и не помню, какой использовал. еще у меня стояло обновление от неомото - очень интересное скажу я тебе. у меня был такой косяк, что через несколько дней тел начинал моросить и выключаться... подождем новый мод от санчо, и может тоже на него откачусь...
сообщение 30.12.2010, 7:51
да я тоже катанулся на прошу зорга. Но эта проша меня порадовала скоростью. Видео неплохо пишется. Но фото немного страдает но не так плачевно. Совместить пару фишек от других прош и будет супер.
mus13
сообщение 30.12.2010, 8:10
Из: РД
вот эта совместимость и была реализована у неомото
Neomoto
сообщение 30.12.2010, 22:32
Из: Белгород
если кому еще интересно, вот тот мой пост - ВОПРОС-ОТВЕТ
эх, как давно это было..
Сообщение отредактировал Neomoto - 30.12.2010, 22:33
sidno
сообщение 31.12.2010, 9:50
Из: Томск
Пользователь №: 204 629
Прошивка: Symbiosis X.1Final
Эх, Neomoto, взял бы да замутил монстра.. нам всем на радость clapping.gif Тем более что Ден отошел от проекта..
FdasweL
сообщение 2.1.2011, 18:18
Neomoto
Залил я в exlocal твой архив, но Pemanager не установился, иконка его в меню видна, но не запускается. Можешь объяснить как его установить? Или ссылку дать, где рассказано как это делается.
mus13
сообщение 7.1.2011, 6:23
Из: РД
FdasweL не знаю, что ты и как устанавливал, у меня все работает, правда есть несколько косяков:
1. с блокировки выходит медленно.
2. на блокировке может пропадать индикатор времени.
3. аккум держит меньше, чем на других прошах.
4. во время съемки видео, если отсчет времени остановился - снимать аккум.
dimonka_pavlov
сообщение 21.4.2011, 14:29
Пользователь №: 192 535
Модель телефона: ZN 5
плиз зелейте кто-нибудь...все ссылки умерли..хочетсья попробывать...для 0.62A
сообщение 22.4.2011, 10:42
Freedom Features Update 062A - ДЛЯ ПРОСТЫХ ЗН5 64 МЕТРОВЫХ.
https://mega.nz/#!XgJEGawL!-UK0091N...DJcM1oNQthtrv8I
Freedom Features Update 062DP-ДЛЯ T-MOBILE, 128 МЕТРОВЫХ ЗН5.
https://mega.nz/#!ntBWjKzK!7wyo-O1e...HaP6DgD9hE1QPRU
Сообщение отредактировал Claus398 - 13.12.2018, 7:23
[MP] Freedom Features Update [SWAP + CIF + MPKGBOX] · Motorola ZINE ZN5, ZN5 T-Mobile · Forum
Текстовая версия Сейчас: 10.9.2025, 11:01
