20 страниц V « < 2 3 4 5 6 > »
Linux Ming (jffs2 11R - firmware), Прошивка с rw на базе 11R. Версия от 16.12.2009
marcolnx
сообщение 12.11.2009, 17:31 Закрепленное сообщение!
Пользователь №: 201 733
JFFS2 11R (a1200e e a1200r)
English description is under spoiler
First: I wanted to thank tmp_do and tmr for creating a jffs2 firmware (and therefore the possibility of writing the whole system).
Second: I wanted to thank SergGG Provodnik Silent Bob dvrts and all Motofan ru users for sharing informations and help.
Starting from whiteMING2 of tmp_do (thanks to his help and his answers) I have modified and customized the firmware:
- Replaced all libraries SYStapi SYSqtapp SYSjava SYSdb etc. (11R)
- Flip closed options
- Inserted and placed some missing applications or not fully working (BCR - Sync - Standard Viewer - Photo Editor)
- Added binaries (ldd - showQ - ezxpopup - etc.), so bash3 busybox strace ...
- Added ringtones, pictures, skin, mystuff, etc.
- Radio works without headset
- Calendar in the main screen shows the first appointment in 24 hours
- 2 new skins (red and white)
- Pre-installed applications: ekonsole, Assistant of Amin (reboot, pkg installer, screenshot, swap manager, hacker, mystuff, unrar unzip, ecc.), Skin Installer, Backup Restore Now, SysInfo, ZEditor (can see hidden folder and edit hidden files), PicselEdit (there is also the standard)
- 2 java applications: platinumsudoku - ICQ Jimm
- Language: English - Russian - Ukrainian (VR English - Russian)
- Fixed all profile (Silent, Vibrate, ecc.)
- ext2 ext3 support with modules.dep
- Screen3 works
- Support autorun.txt under SD (/mmc/mmca1/)
- Fingerpad white and foxalarm (voice russian)
- added Processor (underclock and overclock at 520)
- added pictures
- added skin blue (Sens theme)
- added, replaced for Camera_R541L7_G_11.10.11R
- added, replaced for libezxmime.so.1.0.0 thanks a lot Silent Bob
- added pftpd (pure-ftpd and pure-ftpwho) thanks a lot fordalulz
- added, replaced ro rw
- added new init script (so also startup1.txt, startup.txt for SD and startup2.txt for phone) and a lot of stuff for mount --bind sounds, animation, volume, font, ecc. without write directly for new user)
p.s.: I have attached folder MCleaner and MotoID, extract and install if you want.
Generally if something does not like (you can write in the whole) you can edit yourself.
Hopefully you'll try it and have fun.
Link:
Link for download
About swap:
If we need 32mb swap just extract the folder .bin from here and put in the root of SD:
http://www.4shared.com/file/84649109/509f6517/Swap_SD.html
You can easy activate - deactivate with Assistant and check with SysInfo or eKonsole
Прикрепленное изображениеПрикрепленное изображение Прикрепленное изображениеПрикрепленное изображение
Перевод на русский dvrts
Прежде всего хотелось бы поблагодарить tmp_do и tmr за создание прошивок на базе jffs2 (и как следствие, возможность модифицирования всей ФС телефона без перепрошивки (read-write:)
Также хотелось бы поблагодарить SergGG, Provodnik, Silent Bob, dvrts и всех пользователей motofan.ru за информацию и помощь
По сравнению с WhiteMING2 (автор tmp_do) прошивка изменена, улучшена и дополнена:
- Заменены все библиотеки SYStapi SYSqtapp SYSjava SYSdb т.д. (11R)
- Расширенное меню при закрытом флипе
- Добавлена и изменены некоторые приложения, отсутствующие или некорректно работающие ( BCR - Синхронизация - Стандартный Viewer - Photo Editor)
- Добавлены бинарники (ldd - showQ - ezxpopup - и т.д.), so, bash3, BusyBox, strace ...
- Добавлены рингтоны, картинки, скины, изменен mystuff и т.д.
- Радио работает без гарнитуры
- Календарь на главном экране отображает первое задание в 24 часа
- 2 скина (красный и белый)
- Предустановленные приложения: ekonsole, Amin Assistant (перезагрузка, установщик pkg, swap, javahacker, mystuff, распаковщики архивов, и т.д.), Skin Installer, Backup Restore, SysInfo, ZEditor (можно увидеть скрытые папки и править скрытые файлы), PicselEdit (есть стандартный)
- Язык: английский - русский - украинский (VR английский - русский)
- Исправлены все звуковые профили (бесшумный, вибро, и т.д.)
- Screen3 работает
- Поддержка autorun.txt (/mmc/mmca1/autorun.txt)
- Фингерпад с кириллицей
- Foxalarm взамен стандартного будульника
- Куча мелких изменений
- Добавлено приложение для разгона процессора (до 520 MHz)
- Добавлены изображения
- Синий скин (Sens)
- Бинарники для камеры от _R541L7_G_11.10.11R
- Изменен libezxmime.so.1.0.0
- Добавлено приложение для ftp
- Изменены бинарники для ro rw
- Дополнен авторан (startup1.txt, startup.txt для карты памяти и startup2.txt для памяти телефона) и дополнительные папки для mount --bind (звуки, анимация, volumetable, шрифты, и т.д. без необходимости переходить в read-write ФС)
Ссылка
Для установки свапа - скачать файл и положить в корень карты памяти
Для изменения режимов ro - rw - в консоли выполнить
CODE
rw
CODE
ro
Сообщение отредактировал marcolnx - 10.1.2010, 9:33
Прикрепленный файл Howto_jffs2_new_firmware_save_data.txt   ( 1.17 килобайт ) Кол-во скачиваний: 948
Прикрепленный файл MCleaner_MotoID.zip   ( 337.61 килобайт ) Кол-во скачиваний: 666
Прикрепленный файл jffs2_kernel_sdhc.zip   ( 3.91 мегабайт ) Кол-во скачиваний: 1308
dvrts
сообщение 22.11.2009, 19:56
Из: Lviv
Пользователь №: 162 099
QUOTE
сначала убедись для себя, что rw / действует и после перезагрузки.
а ведь не действует. после ребута всегда ro
Miroschnik
сообщение 22.11.2009, 20:08
Пользователь №: 65 070
Модель телефона: Nokia 5800+LGP500
Убедился. После ребута, всегда "RO". А может как то можно после ребута автоматически запускать режим "RW"?
Добавлено позже (22.11.2009, 23:13):
При запуске встроенного email клиента, выскакивает "Сообщение было удалено" и все, жмем "OK" программа закрывается
dvrts
сообщение 22.11.2009, 22:12
Из: Lviv
В авторан mount -o remount rw/
только зачем? Потеря важных файлов может убить телефон
marcolnx
сообщение 22.11.2009, 23:00
Hi my friend dvrts,
Thanks again for your thread and your work (a lot of things I can not translate or bad).
Here I also added foxalarm (if someone has problems):
http://www.4shared.com/file/157535733/d901..._UA_fp_fox.html
Hanggard
сообщение 23.11.2009, 2:41
Пианист
Из: Riga
Пользователь №: 92 516
Прошивка: iOS 14.1
Прост-рок))
Косяк main.db...
dvrts
сообщение 23.11.2009, 3:13
Из: Lviv
По поводу e-mail - выложите скриншот, кто сталкивался
Miroschnik
сообщение 23.11.2009, 5:56
Все что Бог делает,оно все к лучшему.
Стал делать скриншот "По поводу e-mail". Прога "е-Caps" его не сделала-белая полоса, вдоль экрана. Встроенный в прошивку "Asistant" пропикал положенные три раза и повесил телефон намертво!!!! Вынул батарею, вставил, пошла загрузка, и все!!! Телефон, дальше заставки с пингвинчиком и надписью "Loader"(без бегущих, белых точек) не идет. В boot заходит, вроде, поставил аккум заряжаться, будем шить!!!
прописывал В авторан "mount -o remount rw/" не работает!
Добавлено позже (23.11.2009, 9:05):
Качаю последнюю версию, с Foxom:)
Добавлено позже (23.11.2009, 10:39):
Прошился. "По поводу e-mail": Прямоугольник в центре экрана, в нем круглый значек с восклицательным знаком и надпись "Это сообщение было удалено", в нижней части прямоугольника кнопка с надписью "ОК". Скрин делать боюсь:(
marcolnx
Be sure to check the program (SoftManager) on your version, but she knows how much, but does not work
Прикрепленный файл SoftManager.zip   ( 104.85 килобайт ) Кол-во скачиваний: 85
Сообщение отредактировал Miroschnik - 23.11.2009, 7:56
runtime
сообщение 23.11.2009, 8:07
Из: Омск
Пользователь №: 168 421
Модель телефона: A1200e
Прошивка: JFFS2
@Miroschnik У меня никаких проблем с e-mail не возникает. Дело в том что эта прошивка шьет не все группы. Попробуй сперва прошиться чем-нибудь типа прошивки от Silent_Bob. А потом прошей эту. Я пробовал шить эту прошивку после ГизМото, в результате поимел несколько проблем типа: не выводились имена контактов из телефонной книге при звонках. Прошился как описал тебе и все стало нормально. Assistant встроенный в последние две версии прошивки работает нормально.
Сообщение отредактировал runtime - 23.11.2009, 8:09
dvrts
сообщение 23.11.2009, 8:19
Из: Lviv
QUOTE
it absolutely doesn't work, or there are troubles with translate?
try to change font - it helped me
Miroschnik
сообщение 23.11.2009, 8:29
Эта версия SoftManager умеет:
- Устанавливать PKG
- Удалять PKG
- Ставить приложения в автозагрузку
- Перемещать приложения по категориям
- Делать бэкап приложений
- Создавать, скрывать и редактировать катугории меню
У меня она совсем не запускается!
dvrts
сообщение 23.11.2009, 8:31
Из: Lviv
Miroschnik,
в авторан
mount -o remount rw /
с пробелом между rw и /
сорри, опечатался когда давал совет выше
(23.11.2009, 10:37):
Softmanager этот работает
Прикрепленный файл SoftManage.mpkg.gz   ( 104.4 килобайт ) Кол-во скачиваний: 159
Miroschnik
сообщение 23.11.2009, 9:10
Цитата(dvrts @ 23.11.2009, 11:31) *
Miroschnik,
в авторан
Скачал Softmanager. поставил-не работает! Даже не запускается!
mount -o remount rw / прописал-работает!
Прошил прошивку от Silent_Bob, Softmanager работает.
Вернулся на JFFS2 11R (a1200e e a1200r), ситуация с Email не поменялась!!
И ! О чудо!!! Softmanager заработал!! Но как только я изменил, в настройках телефона, язык на русский, все вернулось на круги своя! Softmanager не работает. Какие то проблеммы с ленгом?
Сообщение отредактировал Miroschnik - 23.11.2009, 10:51
Hanggard
сообщение 23.11.2009, 10:21
Пианист
Из: Riga
Прошивка: iOS 14.1
Прост-рок))
Miroschnik, вообще-то можно не выпендриваться и написать просто
rw
без всего. Сделай
cat /bin/rw
и убедись, что такой бинарник существует. Так что просто rw и все.
Сообщение отредактировал Hanggard - 23.11.2009, 10:23
Miroschnik
сообщение 23.11.2009, 11:20
rw
без всего. Сделай
cat /bin/rw
просто rw - не работает
dvrts
сообщение 23.11.2009, 11:45
Из: Lviv
Полный маунт - для всего универсален. rw - алиас. Для скриптов не катит
runtime
сообщение 23.11.2009, 11:59
Из: Омск
Прошивка: JFFS2
@Miroschnik Ты пробовал включать телефон без флэшки?
Miroschnik
сообщение 23.11.2009, 12:04
Да, а что? Если про Email? То не работает в любом случае, а если про что другое? То, пока, все нормально! Всем доволен!,
Сообщение отредактировал Miroschnik - 23.11.2009, 12:14
dvrts
сообщение 23.11.2009, 14:00
Из: Lviv
Объясни, зачем тебе вечный rw?
Miroschnik
сообщение 23.11.2009, 14:04
Сейчас, уже, вроде и незачем, т.к. Фокс работает нормально. А вааще, чем это чревато? При условии что в системные директории я не лазаю и необдуманных действий постараюсь не совершать.
dvrts
сообщение 23.11.2009, 14:30
Из: Lviv
чревато может быть чем угодно
ты же не оставляешь квартиру открытой несмотря на то, что всех соседей ты знаешь 10 лет?
Miroschnik
сообщение 23.11.2009, 15:13
Заменил файл шрифта. Но почему то, в меню, шрифт остался прежним, а в некоторых приложениях поменялся. Почему? И скрин я снять ни чем не могу.
Softmanager так же работает! При русском ленге! Чудеса!
Шрифт как раз поменялся в нем и в FBRidere
Сообщение отредактировал Miroschnik - 23.11.2009, 15:16
dvrts
сообщение 23.11.2009, 16:11
Из: Lviv
менял по пути /usr/language/fonts наверняка
а еще стоит тут /usr/lib/ezx/lib/fonts/
(23.11.2009, 18:15):
Miroschnik,
да, и скинь, будь добр, тот шрифт, который ты пихал
Miroschnik
сообщение 23.11.2009, 16:47
Заменил и здесь всё встало на свои места, огромное СПАСИБО!
Miroschnik,
Обнаружилась еще одна проблемма. RSS отображает только новости с Lenta.ru. Остальное (гороскоп, валюта, погода) не отображается. Почему?
Брал рабочий RSS c другого тела, запаковывал с помощью Soft Manag... , устанавливал на свой, результат не менялся. Пробовал скачивать и переустанавливать- все тож самое. У кого есть мысли по этому поводу?
Сообщение отредактировал Miroschnik - 23.11.2009, 17:02
marcolnx
сообщение 23.11.2009, 17:12
Hi OFN,
I did a test about swap (partition).
I bought a new SD 2gb, in my laptop I had an old backup of a 1GB SD.
I copied all the content through usb SD reader on the new SD.
Using gparted, I use sidux (you can just download a LiveCD and do the same without having linux on your computer), connecting via usb SD reader I did:
- Resized fat partition to 1.4gb
- Created an ext3 partition 340mb
- Created an swap partition 110mb
Then I checked by putting the SD into the mobile phone (clearly saw only the fat partition of 1.4gb).
I created a folder in the phone: mmca2.
I created a simple script to activate the swap partition (mmca3) and mount the ext3 partition (mmca2) through autorun.txt
Works :-)
Reference to gparted:
http://manual.sidux.com/en/part-gparted-en.htm
@Miroschnik
Screen3? If I well understand.
maybe you need change some settings (defaultpkg.xml, ezx_screen3.cfg)
ask dvrts, Silent Bob, SergGG
Сообщение отредактировал marcolnx - 23.11.2009, 18:34
dvrts
сообщение 23.11.2009, 23:42
Из: Lviv
By the way, swap partition works great (using gparted)
Miroschnik,
Дело не в конфиге проши, а в самом рсс. Видать сервера не дают нужную инфу smile.gif
Hanggard
сообщение 24.11.2009, 2:58
Пианист
Из: Riga
Прошивка: iOS 14.1
Прост-рок))
Цитата(dvrts @ Вчера, 17:45)
rw - алиас
Цитата(Hanggard @ Вчера, 16:21)
Сделай
cat /bin/rw  и убедись, что такой бинарник существует.
Так что бегом в ванну язык мылом мылить - это полноценный скрипт, а не алиас, и находится он в $PATH - /bin - значит, работает всегда и везде из любого скрипта.
dvrts
сообщение 24.11.2009, 3:57
Из: Lviv
Да ты что?
А выхлоп смотрел когда cat /bin/rw в консоль вводишь?
Hanggard
сообщение 24.11.2009, 4:56
Пианист
Из: Riga
Прошивка: iOS 14.1
Прост-рок))
root@(none):~# cat /bin/rw
Именно об этом я и говорю... Алиас - немного другое, как бы вам пояснить...
root@unicron:/usr/home/hanggard# man alias
Formatting page, please wait...Done.
BUILTIN(1)              FreeBSD General Commands Manual             BUILTIN(1)
NAME
     builtin, !, %, ., :, @, {, }, alias, alloc, bg, bind, bindkey, break,
     breaksw, builtins, case, cd, chdir, command, complete, continue, default,
     dirs, do, done, echo, echotc, elif, else, end, endif, endsw, esac, eval,
     exec, exit, export, false, fc, fg, filetest, fi, for, foreach, getopts,
     glob, goto, hash, hashstat, history, hup, if, jobid, jobs, kill, limit,
     local, log, login, logout, ls-F, nice, nohup, notify, onintr, popd,
     printenv, pushd, pwd, read, readonly, rehash, repeat, return, sched, set,
     setenv, settc, setty, setvar, shift, source, stop, suspend, switch,
     telltc, test, then, time, times, trap, true, type, ulimit, umask,
     unalias, uncomplete, unhash, unlimit, unset, unsetenv, until, wait,
     where, which, while -- shell built-in commands
SYNOPSIS
     See the built-in command description in the appropriate shell manual
     page.
DESCRIPTION
     Shell builtin commands are commands that can be executed within the run-
     ning shell's process.  Note that, in the case of csh(1) builtin commands,
     the command is executed in a subshell if it occurs as any component of a
     pipeline except the last.
Главная твоя ошибка - что алиас работает ОБЫЧНО до перезагрузки, а скрипт, который выполняет что-то с другими бинарниками, но не является при этом бинарником, а лишь выполняемым скриптом - ЭТО ТАК И НАЗЫВАЕТСЯ - скрипт на шелле (bash'e, ash'e, etc...) НО НЕ АЛИАСОМ. Список алиасов ты можешь увидеть, например, тут (показано для интерпритатора csh):
# $FreeBSD: src/etc/root/dot.cshrc,v 1.30 2007/05/29 06:37:58 dougb Exp $
# .cshrc - csh resource script, read at beginning of execution by each shell
# see also csh(1), environ(7).
alias h         history 25
alias j         jobs -l
alias la        ls -a
alias lf        ls -FA
alias ll        ls -lA
alias pci       pciconf -lv
alias mce       mcedit
alias com       "sudo cu -l /dev/cuad0"
alias zyxel     "telnet 10.0.0.254"
alias scshrc    sudo mcedit .cshrc
alias reinstall "sudo make && make reinstall clean"
alias flash     "sudo mount_msdosfs -L ru_RU.CP1251 -o longnames /dev/da0s1 /mnt/removable"
alias fire      "tcpdump -n -e -ttt -r /var/log/pf.log"
Поэтому, если там (в скрипте авторана) написать /bin/rw - это будет равносильно, если написать /sbin/mount -o remount rw /.
Сообщение отредактировал Hanggard - 24.11.2009, 4:59
dvrts
сообщение 24.11.2009, 4:59
Из: Lviv
тогда почему же rw не работает в авторане, а mount -o remount rw / работает?
Hanggard
сообщение 24.11.2009, 5:00
Пианист
Из: Riga
Прошивка: iOS 14.1
Прост-рок))
dvrts, потому что надо писать либо /bin/rw, а не просто rw, либо sh /bin/rw. Либо потому, что в начале скрипта не написано
#!/bin/sh
dvrts
сообщение 24.11.2009, 5:05
Из: Lviv
CODE
работает в авторане просто так
Miroschnik
сообщение 24.11.2009, 5:38
Ребята! Не спорьте, пожалуйста! Разве так принципиально что прописывать в скрипте? Главное чтоб оно работало.
А вот предположение о том, что не отвечают сервера при запросе RSS, неподтвердилось. На другом теле, но с другой прошивкой, RSS обновляет все пункты, а у меня только новости. Что делать?
Hanggard
сообщение 24.11.2009, 7:42
Пианист
Из: Riga
Прошивка: iOS 14.1
Прост-рок))
Miroschnik, сравни сеттинги от и до. Сравни конфиги программ.
Miroschnik
сообщение 24.11.2009, 8:41
eXMMS при закрытом флипе не работает.
Добавлено позже (24.11.2009, 12:18):
Переустановил-заработало!
Miroschnik
сообщение 24.11.2009, 18:40
Цитата(Silent_Bob @ 24.11.2009, 21:18) *
Глюк в 11R ...
ps.gif Видимо считает, что слишком много сообщений ...
dvrts
Это про отоброжениие в Screen3 информации
передайте пожалуйста marcolnx
Добавлено позже (24.11.2009, 23:05):
Softmanage перестал запускаться из меню, только из консоли или при помощи File Exp.., но только при английском ленге.
marcolnx
сообщение 24.11.2009, 23:46
@Miroschnik
I cannot well translate your problem about Screen3.
If problem try replacing some files.
I attach a folder with inside ezx_screen3.cfg (replace under /usr/setup/ and /ezx_user/download/appwrite/setup).
Also a folder screen3 (replace /usr/data_resource/screen3/).
For me screen3 it's just a bookmark.
After this try installing .mpkg of Silent Bob.
Strace can help.
Sorry for my problem translating.
dvrts
сообщение 25.11.2009, 0:08
Из: Lviv
QUOTE
Глюк в 11R ...
Bob tells us that S3 in 11R thoughts that is too much info... What does it mean, I don't know ph34r.gif
It seems to be a bug/feature of platform
OFN
сообщение 25.11.2009, 1:35
Из: zp.ua
Пользователь №: 182 112
Модель телефона: XT 1585
Прошивка: 6.0
+1 . Тотальный rw по умолчанию прекрасен как идея. Но в целях безопасности, если использовать расширеннй файловый менеджер, постоянно лучше держать ro а на rw переходить когда хочешь осуществить изменения в ФС за пределами Home. Ведь может ,например, нечаянно стилус соскользнуть и нажмется не та кнопка в меню, например. Но даже если не использовать XPTools, есть риск, например, совершить в консоли известную классическую описку, после которой уничтожается весь корень.... Лучше не рисковать.
Мини баг-рипорт:.
-Mpkg средствами телефона на этой прошивке упорно устанавливаться не хотят.
или это только у меня? Потому что я после 14 R ?
-Я разобрался. почему вначале у меня не было русской клавиатуры . Дело было действительно в скине Black Ming , который я установил на карту памяти с помощью MotoTheme - у есть него серьезное несовпадение с предустановленным Onyx Black. С помощью Марко ( он выложил здесь необходимую часть иконок из скина Black Russian , они идеально подходят к Black MNing, как натуральные) я доделаю скин Black Ming чтобы он подходил именно к этой прошивке.
имейте в виду: далеко не все скины на этой прошивке будут работать корректно.
Хочу обсудить два вопроса:
1.Как осуществить замену предустановленных скинов на свои средствами телефона?
Не так все тут и понятно на самом деле.
Начиная с того, как в usr/ data_resource расположены файлы скинов. Под скины задействованы три директория:
icon : здесь находится основной iconres_ezx размером более 2 Мб,
skin : здесь рсположены файлы .pskn для обоих предустановленных скинов, конфиг цветовой палитры скинов, и два директория default 1 и default 2. В default 1 находится файл .skn педустановленного скина HAINAN_01, то есть - Onyx Black, и файл .jpg стандартных обоев Onyx Black) , а в default2 находится файл .skn
предустановленного скина HAINAN_02 ( то есть Onyx White ), файл его обоев .jpg и файл iconres_ezx размером порядка 600 Кб , Я разобрал его с помощью Kwiev - он содержит те иконки, которые отличаются у Onyx White по сравнению с Onyx Black.
theme : тут расположены два файла : theme 1.phm и theme 2.phm
Eсли откіть их с помощью блокнота, будет заголовок [THEME_CONFIG_TABLE] и конфиг с описанием анимации на включение выключение и установленных в данный момент обоев.
Очевидно, этот файл образует система.
Открыл и почитал что указано в обоих файлах .pskn . Ни в одном из них не указано, где должен быть расположени файл iconres_ezx ( когда мы адаптируем скины для MotoTheme и для Ultratheme , мы путь к iconres_ezx всегда прописываем, для каждого из этих двух способов этот путь отличается. А здесь в .pskn вообще нет упоминания об iconres_ezx.
НЕПРИВЫЧНО.
Как поступать в случае замены предустановленного скина на свой?
В usr/data_resource/icon скопировать свой iconres_ezx, в usr/data_resource/skin - свой файл.pskn, отредактированный по образцу предустановленного, в usr/data_resource/skin/default1 скопировать свой файл.skn и свои обои по умолчанию. а содержимое каталога usr/data_resource/theme -удалить . так?
2.Вопрос к тем, кто пользовался SoftManager : эта программа спрашивает Вас, куда ей установить pkg - на карту памяти или на телефон, перед тем как установить? Я этот момент забыл.
Сообщение отредактировал OFN - 28.11.2009, 1:14
Miroschnik
сообщение 25.11.2009, 6:29
Цитата(marcolnx @ 25.11.2009, 2:46) *
@Miroschnik
Strace can help.
Удалил RSS
Скачал файл , распаковал, скопировал в указанные директории.
Установил RSS. запустил, обновление не произошло. Перезагрузил телефон, опять запустил RSS.
Урааа! Теперь все отображается! Новости! Курсы валют! Погода! Гороскоп!
marcolnx, Большое спасибо!
В SoftManager можно выбирать директорию установки pkg, но он, у меня, ни чего не устанавливает. Выскакивают сообщения с квадратиками и ничего не устанавливается
Foxalarm остаётся работоспособным и после подключения, отключения ЗУ. Это очень радует!
Радио не запоминает найденные вручную станции. Поля ввода остаются неактивными.
Сообщение отредактировал Miroschnik - 25.11.2009, 6:51
marcolnx
сообщение 25.11.2009, 6:37
@dvrts
about screen3:
when I replaced the whole taking from 11R novin firmware there was only libnewsreader.so.1.0.0 (so missing dpagent and newsreader inside /usr/SYSqtapp/dynamicidle/di/pluginlib/newsreader).
If I well remember I keep libnewsreader.so.1.0.0 and add missing bins (I need to check if from 16R or 14R).
So if problem try replacing inside /usr/SYSqtapp/dynamicidle/di/pluginlib/newsreader
For me I only check thath show screen3 in main screen and if I click this open internet connection. (so for me it's ok).
Also strace can help (epinter told me some time ago about check the pid):
Run strace -s 400 -e write -f -p <pid_of_process>. The "-s 400" show 400 characters per line, the "-e write" filters only write syscall, so you can see some messages(possibly errors). The "-f" follows all child processes spawned by <pid_of_process>.
With this firmware you can easy try, and for sure find a solution.
By
(25.11.2009, 9:15):
@Miroschnik
"В SoftManager можно выбирать директорию установки pkg, но он, у меня, ни чего не устанавливает. Выскакивают сообщения с квадратиками и ничего не устанавливается
Радио не запоминает найденные вручную станции. Поля ввода остаются неактивными."
Can you translate?
Radiofm? Working properly. You just have to save channels to store them.
Linux Ming (jffs2 11R - firmware), Прошивка с rw на базе 11R. Версия от 16.12.2009 · Motorola ROKR E6, E6e, E6tv, MING A1200, A1200i, A1200e, A1200r, A1200w, A1600 · Forum
Текстовая версия Сейчас: 22.7.2025, 16:18
