20 страниц V « < 5 6 7 8 > »
Linux Ming (jffs2 11R - firmware), Прошивка с rw на базе 11R. Версия от 16.12.2009
marcolnx
сообщение 12.11.2009, 17:31 Закрепленное сообщение!
Пользователь №: 201 733
JFFS2 11R (a1200e e a1200r)
English description is under spoiler
First: I wanted to thank tmp_do and tmr for creating a jffs2 firmware (and therefore the possibility of writing the whole system).
Second: I wanted to thank SergGG Provodnik Silent Bob dvrts and all Motofan ru users for sharing informations and help.
Starting from whiteMING2 of tmp_do (thanks to his help and his answers) I have modified and customized the firmware:
- Replaced all libraries SYStapi SYSqtapp SYSjava SYSdb etc. (11R)
- Flip closed options
- Inserted and placed some missing applications or not fully working (BCR - Sync - Standard Viewer - Photo Editor)
- Added binaries (ldd - showQ - ezxpopup - etc.), so bash3 busybox strace ...
- Added ringtones, pictures, skin, mystuff, etc.
- Radio works without headset
- Calendar in the main screen shows the first appointment in 24 hours
- 2 new skins (red and white)
- Pre-installed applications: ekonsole, Assistant of Amin (reboot, pkg installer, screenshot, swap manager, hacker, mystuff, unrar unzip, ecc.), Skin Installer, Backup Restore Now, SysInfo, ZEditor (can see hidden folder and edit hidden files), PicselEdit (there is also the standard)
- 2 java applications: platinumsudoku - ICQ Jimm
- Language: English - Russian - Ukrainian (VR English - Russian)
- Fixed all profile (Silent, Vibrate, ecc.)
- ext2 ext3 support with modules.dep
- Screen3 works
- Support autorun.txt under SD (/mmc/mmca1/)
- Fingerpad white and foxalarm (voice russian)
- added Processor (underclock and overclock at 520)
- added pictures
- added skin blue (Sens theme)
- added, replaced for Camera_R541L7_G_11.10.11R
- added, replaced for libezxmime.so.1.0.0 thanks a lot Silent Bob
- added pftpd (pure-ftpd and pure-ftpwho) thanks a lot fordalulz
- added, replaced ro rw
- added new init script (so also startup1.txt, startup.txt for SD and startup2.txt for phone) and a lot of stuff for mount --bind sounds, animation, volume, font, ecc. without write directly for new user)
p.s.: I have attached folder MCleaner and MotoID, extract and install if you want.
Generally if something does not like (you can write in the whole) you can edit yourself.
Hopefully you'll try it and have fun.
Link:
Link for download
About swap:
If we need 32mb swap just extract the folder .bin from here and put in the root of SD:
http://www.4shared.com/file/84649109/509f6517/Swap_SD.html
You can easy activate - deactivate with Assistant and check with SysInfo or eKonsole
Прикрепленное изображениеПрикрепленное изображение Прикрепленное изображениеПрикрепленное изображение
Перевод на русский dvrts
Прежде всего хотелось бы поблагодарить tmp_do и tmr за создание прошивок на базе jffs2 (и как следствие, возможность модифицирования всей ФС телефона без перепрошивки (read-write:)
Также хотелось бы поблагодарить SergGG, Provodnik, Silent Bob, dvrts и всех пользователей motofan.ru за информацию и помощь
По сравнению с WhiteMING2 (автор tmp_do) прошивка изменена, улучшена и дополнена:
- Заменены все библиотеки SYStapi SYSqtapp SYSjava SYSdb т.д. (11R)
- Расширенное меню при закрытом флипе
- Добавлена и изменены некоторые приложения, отсутствующие или некорректно работающие ( BCR - Синхронизация - Стандартный Viewer - Photo Editor)
- Добавлены бинарники (ldd - showQ - ezxpopup - и т.д.), so, bash3, BusyBox, strace ...
- Добавлены рингтоны, картинки, скины, изменен mystuff и т.д.
- Радио работает без гарнитуры
- Календарь на главном экране отображает первое задание в 24 часа
- 2 скина (красный и белый)
- Предустановленные приложения: ekonsole, Amin Assistant (перезагрузка, установщик pkg, swap, javahacker, mystuff, распаковщики архивов, и т.д.), Skin Installer, Backup Restore, SysInfo, ZEditor (можно увидеть скрытые папки и править скрытые файлы), PicselEdit (есть стандартный)
- Язык: английский - русский - украинский (VR английский - русский)
- Исправлены все звуковые профили (бесшумный, вибро, и т.д.)
- Screen3 работает
- Поддержка autorun.txt (/mmc/mmca1/autorun.txt)
- Фингерпад с кириллицей
- Foxalarm взамен стандартного будульника
- Куча мелких изменений
- Добавлено приложение для разгона процессора (до 520 MHz)
- Добавлены изображения
- Синий скин (Sens)
- Бинарники для камеры от _R541L7_G_11.10.11R
- Изменен libezxmime.so.1.0.0
- Добавлено приложение для ftp
- Изменены бинарники для ro rw
- Дополнен авторан (startup1.txt, startup.txt для карты памяти и startup2.txt для памяти телефона) и дополнительные папки для mount --bind (звуки, анимация, volumetable, шрифты, и т.д. без необходимости переходить в read-write ФС)
Ссылка
Для установки свапа - скачать файл и положить в корень карты памяти
Для изменения режимов ro - rw - в консоли выполнить
CODE
rw
CODE
ro
Сообщение отредактировал marcolnx - 10.1.2010, 9:33
Прикрепленный файл Howto_jffs2_new_firmware_save_data.txt   ( 1.17 килобайт ) Кол-во скачиваний: 948
Прикрепленный файл MCleaner_MotoID.zip   ( 337.61 килобайт ) Кол-во скачиваний: 666
Прикрепленный файл jffs2_kernel_sdhc.zip   ( 3.91 мегабайт ) Кол-во скачиваний: 1308
marcolnx
сообщение 2.12.2009, 17:24
Hi Garm, (sorry maybe bad translation)
your custom internet profile?
Look inside /ezxlocal/download/appwrite/NetProfile/ or copy here.
Garm
сообщение 2.12.2009, 18:01
Из: Морозовск
Пользователь №: 48 276
Прошивка: Black Ming 3b
I have files in /ezxlocal/download/appwrite/NetProfile/ (and my and standart) but when I launch Internet Settings, phone write "No profiles". And I can't create new profiles
dvrts
Из: Lviv
Пользователь №: 162 099
Garm asks how to create new profile if he backuped that, what he used earlier
marcolnx
сообщение 2.12.2009, 18:45
I just reflashed the firmware (with new skin white and red):
http://www.4shared.com/file/164127103/453e...p_fox_skin.html
p.s.: reflash only few minutes
so I show the pics about internet (I can create or edit), please check if the same:
p.s.:OFN in your skin missing russian flag smile.gif
@dvrts thanks again for your great support and work. I only posted these pics because just reflashed with upgrade firmware (only added new skin), for showing that I can make new internet profile or edit. If you can update the post or make better screenshot thanks.
Сообщение отредактировал marcolnx - 2.12.2009, 20:27
linuxoid200
сообщение 2.12.2009, 19:03
Из: Kiev
Пользователь №: 78 226
Модель телефона: a1200e, sgh i-200
Прошивка: jffs2 11R
Цитата(linuxoid200 @ 30.11.2009, 13:43) *
Залил последнюю прошивку от 28.11.2009 обновил до предпоследней MPT (но 5.0.7а в 76 мегабайт обломало выкачивать), из 567 контактов проглотило 66 контактов.
А остальные????
Выдало окно с :
"The contact 'Lenovo' does not have any synchronisable information. Maybe some information is not supported by your mobile phone. The contact will not be added."
А в контакте забит номер мобильного телефона
Вместо названия категрии на русском языке в контактной книге на телефоне отобразило квадраты.
Да и хотелось бы в раскладке (keyboard) языков иметь украинскую раскладку (keyboard) в дополнение к fingerpad, набирать текст быстрее в keyboard.
ПО СИНХРОНИЗАЦИИ ПРОБЛЕМА СНЯТА
Ошибка, которую делал - сливал на компьютер одной версией MPT, разрешал обновиться МРТ, шил прошивку, и теперь МРТ отказывалась заливать их назад в телефон.
Снес МРТ и установил ту, которой бэкапил контакты на компьютер и после этого все получилось!
Еще бы в названиях категорий был бы русский, а не квадратики, да и кол-во категорий на 1 меньше.
Сообщение отредактировал linuxoid200 - 2.12.2009, 19:06
dvrts
сообщение 2.12.2009, 20:34
Из: Lviv
Marco, Garm also asked about creating new profile after backup. He restored past backup, and after this action creating of new profile is unavailable
Garm, я б рекомендовал вручную восстанавливать бэкап из файла (это архив типа tar, со своим расширением) и оттуда брать необходимые файлы и папки во избежание недоразумений
marcolnx
сообщение 2.12.2009, 20:51
maybe a different main.db (I restored with backuprestorenow with different firmware).
Restored with MPT or manually?
dvrts
сообщение 2.12.2009, 21:12
Из: Lviv
marcolnx,
As I know, main.db doesn't contain profile info. This file is being used for Sms and Contact info
marcolnx
сообщение 2.12.2009, 21:48
When you add new internet profile change devdetail.wbxml (/ezx_user/download/appwrite/setup).
So not sure about restore or applications process (some script when you restore backup replace all /ezxlocal and /ezx_user).
If you can make a test adding new profile.
I attach default devdetail.wbxml (just remove .zip) ezx:ezx a+rw
Сообщение отредактировал marcolnx - 3.12.2009, 6:34
Прикрепленный файл devdetail.wbxml.zip   ( 9.64 килобайт ) Кол-во скачиваний: 131
OFN
сообщение 3.12.2009, 6:34
Из: zp.ua
Пользователь №: 182 112
Модель телефона: XT 1585
Прошивка: 6.0
ПРивет всем.
Я перепрошивался этой прошивкой ( первой и третьей версиями) трижды. и каждый раз профили интернета сохранялись.)бекап я делал с помощью предустановленного СмартАссистента ( специально чтобы проверить его возможности).
Насчет скина bluepro и того, что у меня на клавиатуре отсутствует русский флажок: клавиатуру я брал из предустановленного HAINAN_01 . буду возле компа с Виндой, проверю и переделаю.
Насчет того, какой скин лучше - красный иили синий - это дело вкуса, но ИМХО к синему скину легче подбирать обои так. чтобы экран зрительно казался больше. И собственные фотогорафии родных и близких в качестве обоев на синем скине за счет синей переходной полоски, а не красной, зрительно в меньшей степени режутся. А так ведь эти два скина совешенно одинаковы, кроме переходной полоски...
Но это ИМХО, разумеется.
Сообщение отредактировал OFN - 3.12.2009, 14:42
Garm
сообщение 3.12.2009, 10:21
Из: Морозовск
marcolnx, Hangs in the calibration screen. And when start the "E-Mail" message "This message has been removed" and "E-Mail" is close
I reflash it.
P.S. OFN, я делал восстановление путем копирования файлов прогой с правами рута
Сообщение отредактировал Garm - 3.12.2009, 10:39
marcolnx
сообщение 3.12.2009, 12:13
Garm,
Email problem after restoring your backup?
Can you try open Email icon first of restoring your backup.
Also try calibration screen.
Your BP? with 13R work fine.
Please let me know. Thanks.
Garm
сообщение 3.12.2009, 17:30
Из: Морозовск
No, problem by default
In second time I not restoring backup (only restore addressbook)
Normally now. Strange...
YARICHEK
сообщение 3.12.2009, 20:34
Из: Донецк
Пользователь №: 208 179
Модель телефона: Z8
Прошивка: 54G
после перепрошивки не могу установить темы?!:(
OFN
сообщение 3.12.2009, 21:56
Из: zp.ua
Прошивка: 6.0
сегодня почему то внезапно исчезли бинарник syhsinfo и исполняемый файл sysinfo.sh из usr/data_resource/preloadapps/qtapps/sysinfo.
Перестало запускаться sysinfo, иконка сохранилась, но программа не запускалась, зашел в файловую систему - обнаружил исчезновение вышеуказанных файлов. Файловая система телефона была в ro.
Шайтан!
Зато теперь я держу на флешке "ремкомплект"- все предустановленные проги в архивированном виде. Что нибудь исчезнет- разархивирую, переведу файловую систему телефона в rw и заброшу недостающее в usr/data_resource/preloadapps/qtapps.
Зы: Может быть, Марко прав и BP должно быть именно от 13R ? Сперва надо прошиться 13 R f5, а потом уже - этой прошивкой?
Рациональных доводов за таке решение нет, но - шайтан?
Сообщение отредактировал OFN - 3.12.2009, 22:04
dvrts
Из: Lviv
Как пытаешься установить?
marcolnx
сообщение 3.12.2009, 22:32
YARICHEK,
just install skin with skininstaller (work fine)
OFN,
I keep this firmware also with my a1200i (BP C2 track).
Maybe you maked some error (you deleted some folder) you are root so be careful.
p.s.: inside /usr/data_resource/preloadapps/qtapps/ you can delete or add files and folders also without "rw", so...
You can edit for example fpad folder without rw command.
Сообщение отредактировал marcolnx - 3.12.2009, 22:56
Garm
сообщение 4.12.2009, 6:05
Из: Морозовск
marcolnx,
I think, I understand trouble with e-mail
If in main.db exists e-mail accounts it works normally else message "This message has been removed"
Перевод на русский / Translation into Russian:
Внутри /usr/data_resource/preloadapps/qtapps/ можно удалять или добавлять файлы и папки без команды rw
Например редактировать папку fpad без команды rw
marcolnx
сообщение 4.12.2009, 6:32
Thank you for testing and help Garm.
Now I tested again my a1200i about Email (first open Email icon after flash and after restoring old backup PIM.brn, work both).
I also tested yesterday internet connection with MPT like modem (work fine... 1 euro in italy for this...).
This is screenshot about my a1200i with C2 track BP
RoboKot
сообщение 4.12.2009, 10:08
Из: Новочеркасск <-> Красный Сулин
Пользователь №: 90 741
Модель телефона: Moto A1200e
Прошивка: CustomFirmWare
Прошивка хорошая. Всё сразу завелось и поехало. С установкой тем проблем нет. Но напрягает то что в телефонной книге при выборе контакта джойстиком вызывается следующий контакт. Такая проблема когда на прошивке от Сайлент Боба была. Подскажите, как починить?
marcolnx
сообщение 4.12.2009, 12:09
RoboKot,
problem with contact?
make a test checking if the name and phone number it's correct (maybe restoring process).
Also try copy contact inside SIM and after inside phone.
So make some tests if this is your problem.
offtopic: how can I thank users?
Сообщение отредактировал marcolnx - 4.12.2009, 12:39
Garm
сообщение 4.12.2009, 12:44
Из: Морозовск
У меня все нормально. Может потому что переходил с Silent_Bob 16R 2.0? И нигде такого не наблюдалось.
dvrts
сообщение 4.12.2009, 13:00
Из: Lviv
Глюк с контактами? Перепрошить заново
dvrts
сообщение 4.12.2009, 23:53
Из: Lviv
marcolnx,
OFN
сообщение 5.12.2009, 13:12
Из: zp.ua
Прошивка: 6.0
у меня тоже. а я переходил с 14R f6
Добавлено позже (5.12.2009, 15:22):
Цитата(marcolnx @ 4.12.2009, 22:57) *
Marco,and how to edit the skin? sequence replacing its elements (iconrez_ezx,. skn,. pskn) important?
Garm
сообщение 5.12.2009, 16:16
Из: Морозовск
I still use Mototheme because my skin (iconres.ezx 3,4 мб unfull) does not fit the size of / usr/data_resource/skin/default2
Also, stop working for caller identification. Worked well and stopped. How do I fix? Reboot not helped. Create new contact - don't worked (tried +7 and 8)
Rus: Также перестал работать определитель номера. Работал нормально и перестал. Как починить? Перезагрузка не помогает/ Создал новый контакт - не работает (пробовал +7 и 8)
Сообщение отредактировал Garm - 5.12.2009, 16:24
ZezeZ
сообщение 5.12.2009, 17:59
Пользователь №: 201 619
Подобная канитель на Ириске. И курсором и на таче выбирает тремя пунктами ниже.
З.Ы. перепрошивка не помогает
marcolnx
сообщение 5.12.2009, 21:24
Garm,
hi smile.gif now stay out for 3 days so I cannot translate.
For skin use skininstaller (work perfect, and you can check before and after installing with df -ah ).
If you write directly use telnet or ekonsole. I changed several times skin without problem. default3 it's free, if you wish add another skin.
Sorry bad english. (dvrst can help).
p.s.:wm2 keep only 1 skin (different), I replaced and also added default2, now replaced again with a1200r red and white skin (never problem with contact,ecc.).
(5.12.2009, 23:08):
hi joe30,
hungarian user are welcome :-)
Be free ask, great user like dvrts, Silent Bob, SergGG, Garm, ecc. can help :-), so welcome in Motofan ru.
Сообщение отредактировал dvrts - 8.12.2009, 0:37
YARICHEK
сообщение 6.12.2009, 8:24
Из: Донецк
Модель телефона: Z8
Прошивка: 54G
Help please! On this insertion it is impossible to start any fitter that sad.gif!!! How to solve this problem or explain as to use program Skins which was already in an insertion!!! In advance thanks!!!
marcolnx
сообщение 6.12.2009, 10:26
YARYCHEK
For skininstaller, hold and press file.pskn inside the folder of theme, open with -> select Skins (I don't select always open...). When installation finished restart the mobile, and after change wallpaper.
For restore and change theme before this, I install default1_skin.pskn (already posted here). Easy,
YARICHEK
сообщение 6.12.2009, 17:23
Из: Донецк
Модель телефона: Z8
Прошивка: 54G
Thanks! And if skin it is established crookedly?
marcolnx
сообщение 6.12.2009, 18:59
Hi,
I installed a lot of theme with skininstaller (no problem), some times before installing a theme I remove some .gif from iconres.ezx with ezxcodec (motoskin) for wrong keyboard or save space. For restoring use default1_skin.pskn (now I cannot attach again from my mobile ).
YARICHEK
сообщение 6.12.2009, 19:51
Из: Донецк
Модель телефона: Z8
Прошивка: 54G
Well then tell to me please why are not started Ultratheme, Wondermoto?
OFN
сообщение 6.12.2009, 20:14
Из: zp.ua
Прошивка: 6.0
Sorry, Marco, my question for you. I was a little
iconrez.ezx modified the basic skin, replacing it a few icons. and I want to put it in usr / data_resource / icon instead of the existing means phone: uploading a new iconrez.ezx in mmc/mmca1 and writing the appropriate commands in the console, but at the end of the session reboot the phone. So can?
marcolnx
сообщение 6.12.2009, 22:02
YARICHEK,
I don't know wondermoto,ecc. I prefear skininstaller or edit directly. (If you wish I will check when go back home).
OFN,hi :-)
yes, if you wish edit copy iconres.ezx in your desktop, edit with ezxcodec (motoskin), so open extract and edit, when finished recompile and place your new iconres.ezx inside SD.
Now with ekonsole or telnet session copy inside /usr/data_resource/icon/ and reboot.
Maybe you wish edit realplayer animation or what you prefear.
Now writing with mobile, but when I come back home I can show all this with images.
By
(6.12.2009, 22:26):
p.s.: no sorry :-) I'm happy if I can help. Only I'm sorry for my bad english.
Garm
сообщение 7.12.2009, 8:36
Из: Морозовск
Problem not solved. Identification of subscribers don't work.
1) When I dial number from addressbook, on dialing window shown only number (not Name of Contact)
2) In Calls Records only numbers (no names)
I delete main.db and log* from sysDatabase/ (phone create it again) - don't solved
Hanggard
сообщение 7.12.2009, 9:08
Пианист
Из: Riga
Пользователь №: 92 516
Прошивка: iOS 14.1
Прост-рок))
Garm, reflash you phone, this mystery can't be resolved...
runtime
сообщение 7.12.2009, 9:39
Из: Омск
Пользователь №: 168 421
Модель телефона: A1200e
Прошивка: JFFS2
@Garm На 20 странице в 200 посте (пост #200) marcolnx дает ответ как это исправить. Miroschnikу помогло. Там не просто надо удалить main.db, а скопировать из вложения.
Сообщение отредактировал runtime - 7.12.2009, 9:41
Garm
сообщение 7.12.2009, 11:00
Из: Морозовск
Не помогло. Придется перешиваться.
Don't helped. I think need to reflash
Сообщение отредактировал Garm - 7.12.2009, 11:00
OFN
сообщение 7.12.2009, 14:31
Из: zp.ua
Прошивка: 6.0
Камрады, у кого какие впечатления от фото- и видеокамеры ?
Linux Ming (jffs2 11R - firmware), Прошивка с rw на базе 11R. Версия от 16.12.2009 · Motorola ROKR E6, E6e, E6tv, MING A1200, A1200i, A1200e, A1200r, A1200w, A1600 · Forum
Текстовая версия Сейчас: 26.7.2025, 23:32
