20 страниц V « < 5 6 7 8 9 > »
Linux Ming (jffs2 11R - firmware), Прошивка с rw на базе 11R. Версия от 16.12.2009
marcolnx
сообщение 12.11.2009, 17:31 Закрепленное сообщение!
Пользователь №: 201 733
JFFS2 11R (a1200e e a1200r)
English description is under spoiler
First: I wanted to thank tmp_do and tmr for creating a jffs2 firmware (and therefore the possibility of writing the whole system).
Second: I wanted to thank SergGG Provodnik Silent Bob dvrts and all Motofan ru users for sharing informations and help.
Starting from whiteMING2 of tmp_do (thanks to his help and his answers) I have modified and customized the firmware:
- Replaced all libraries SYStapi SYSqtapp SYSjava SYSdb etc. (11R)
- Flip closed options
- Inserted and placed some missing applications or not fully working (BCR - Sync - Standard Viewer - Photo Editor)
- Added binaries (ldd - showQ - ezxpopup - etc.), so bash3 busybox strace ...
- Added ringtones, pictures, skin, mystuff, etc.
- Radio works without headset
- Calendar in the main screen shows the first appointment in 24 hours
- 2 new skins (red and white)
- Pre-installed applications: ekonsole, Assistant of Amin (reboot, pkg installer, screenshot, swap manager, hacker, mystuff, unrar unzip, ecc.), Skin Installer, Backup Restore Now, SysInfo, ZEditor (can see hidden folder and edit hidden files), PicselEdit (there is also the standard)
- 2 java applications: platinumsudoku - ICQ Jimm
- Language: English - Russian - Ukrainian (VR English - Russian)
- Fixed all profile (Silent, Vibrate, ecc.)
- ext2 ext3 support with modules.dep
- Screen3 works
- Support autorun.txt under SD (/mmc/mmca1/)
- Fingerpad white and foxalarm (voice russian)
- added Processor (underclock and overclock at 520)
- added pictures
- added skin blue (Sens theme)
- added, replaced for Camera_R541L7_G_11.10.11R
- added, replaced for libezxmime.so.1.0.0 thanks a lot Silent Bob
- added pftpd (pure-ftpd and pure-ftpwho) thanks a lot fordalulz
- added, replaced ro rw
- added new init script (so also startup1.txt, startup.txt for SD and startup2.txt for phone) and a lot of stuff for mount --bind sounds, animation, volume, font, ecc. without write directly for new user)
p.s.: I have attached folder MCleaner and MotoID, extract and install if you want.
Generally if something does not like (you can write in the whole) you can edit yourself.
Hopefully you'll try it and have fun.
Link:
Link for download
About swap:
If we need 32mb swap just extract the folder .bin from here and put in the root of SD:
http://www.4shared.com/file/84649109/509f6517/Swap_SD.html
You can easy activate - deactivate with Assistant and check with SysInfo or eKonsole
Прикрепленное изображениеПрикрепленное изображение Прикрепленное изображениеПрикрепленное изображение
Перевод на русский dvrts
Прежде всего хотелось бы поблагодарить tmp_do и tmr за создание прошивок на базе jffs2 (и как следствие, возможность модифицирования всей ФС телефона без перепрошивки (read-write:)
Также хотелось бы поблагодарить SergGG, Provodnik, Silent Bob, dvrts и всех пользователей motofan.ru за информацию и помощь
По сравнению с WhiteMING2 (автор tmp_do) прошивка изменена, улучшена и дополнена:
- Заменены все библиотеки SYStapi SYSqtapp SYSjava SYSdb т.д. (11R)
- Расширенное меню при закрытом флипе
- Добавлена и изменены некоторые приложения, отсутствующие или некорректно работающие ( BCR - Синхронизация - Стандартный Viewer - Photo Editor)
- Добавлены бинарники (ldd - showQ - ezxpopup - и т.д.), so, bash3, BusyBox, strace ...
- Добавлены рингтоны, картинки, скины, изменен mystuff и т.д.
- Радио работает без гарнитуры
- Календарь на главном экране отображает первое задание в 24 часа
- 2 скина (красный и белый)
- Предустановленные приложения: ekonsole, Amin Assistant (перезагрузка, установщик pkg, swap, javahacker, mystuff, распаковщики архивов, и т.д.), Skin Installer, Backup Restore, SysInfo, ZEditor (можно увидеть скрытые папки и править скрытые файлы), PicselEdit (есть стандартный)
- Язык: английский - русский - украинский (VR английский - русский)
- Исправлены все звуковые профили (бесшумный, вибро, и т.д.)
- Screen3 работает
- Поддержка autorun.txt (/mmc/mmca1/autorun.txt)
- Фингерпад с кириллицей
- Foxalarm взамен стандартного будульника
- Куча мелких изменений
- Добавлено приложение для разгона процессора (до 520 MHz)
- Добавлены изображения
- Синий скин (Sens)
- Бинарники для камеры от _R541L7_G_11.10.11R
- Изменен libezxmime.so.1.0.0
- Добавлено приложение для ftp
- Изменены бинарники для ro rw
- Дополнен авторан (startup1.txt, startup.txt для карты памяти и startup2.txt для памяти телефона) и дополнительные папки для mount --bind (звуки, анимация, volumetable, шрифты, и т.д. без необходимости переходить в read-write ФС)
Ссылка
Для установки свапа - скачать файл и положить в корень карты памяти
Для изменения режимов ro - rw - в консоли выполнить
CODE
rw
CODE
ro
Сообщение отредактировал marcolnx - 10.1.2010, 9:33
Прикрепленный файл Howto_jffs2_new_firmware_save_data.txt   ( 1.17 килобайт ) Кол-во скачиваний: 948
Прикрепленный файл MCleaner_MotoID.zip   ( 337.61 килобайт ) Кол-во скачиваний: 666
Прикрепленный файл jffs2_kernel_sdhc.zip   ( 3.91 мегабайт ) Кол-во скачиваний: 1308
marcolnx
сообщение 4.12.2009, 12:09
RoboKot,
problem with contact?
make a test checking if the name and phone number it's correct (maybe restoring process).
Also try copy contact inside SIM and after inside phone.
So make some tests if this is your problem.
offtopic: how can I thank users?
Сообщение отредактировал marcolnx - 4.12.2009, 12:39
Garm
сообщение 4.12.2009, 12:44
Из: Морозовск
Пользователь №: 48 276
Прошивка: Black Ming 3b
Цитата(RoboKot @ Сегодня, 13:08)
Но напрягает то что в телефонной книге при выборе контакта джойстиком вызывается следующий контакт.
У меня все нормально. Может потому что переходил с Silent_Bob 16R 2.0? И нигде такого не наблюдалось.
dvrts
сообщение 4.12.2009, 13:00
Из: Lviv
Пользователь №: 162 099
Глюк с контактами? Перепрошить заново
dvrts
сообщение 4.12.2009, 23:53
Из: Lviv
marcolnx,
OFN
сообщение 5.12.2009, 13:12
Из: zp.ua
Пользователь №: 182 112
Модель телефона: XT 1585
Прошивка: 6.0
у меня тоже. а я переходил с 14R f6
Добавлено позже (5.12.2009, 15:22):
Цитата(marcolnx @ 4.12.2009, 22:57) *
Marco,and how to edit the skin? sequence replacing its elements (iconrez_ezx,. skn,. pskn) important?
Garm
сообщение 5.12.2009, 16:16
Из: Морозовск
I still use Mototheme because my skin (iconres.ezx 3,4 мб unfull) does not fit the size of / usr/data_resource/skin/default2
Also, stop working for caller identification. Worked well and stopped. How do I fix? Reboot not helped. Create new contact - don't worked (tried +7 and 8)
Rus: Также перестал работать определитель номера. Работал нормально и перестал. Как починить? Перезагрузка не помогает/ Создал новый контакт - не работает (пробовал +7 и 8)
Сообщение отредактировал Garm - 5.12.2009, 16:24
ZezeZ
сообщение 5.12.2009, 17:59
Пользователь №: 201 619
Модель телефона: a1200e
Подобная канитель на Ириске. И курсором и на таче выбирает тремя пунктами ниже.
З.Ы. перепрошивка не помогает
marcolnx
сообщение 5.12.2009, 21:24
Garm,
hi smile.gif now stay out for 3 days so I cannot translate.
For skin use skininstaller (work perfect, and you can check before and after installing with df -ah ).
If you write directly use telnet or ekonsole. I changed several times skin without problem. default3 it's free, if you wish add another skin.
Sorry bad english. (dvrst can help).
p.s.:wm2 keep only 1 skin (different), I replaced and also added default2, now replaced again with a1200r red and white skin (never problem with contact,ecc.).
(5.12.2009, 23:08):
hi joe30,
hungarian user are welcome :-)
Be free ask, great user like dvrts, Silent Bob, SergGG, Garm, ecc. can help :-), so welcome in Motofan ru.
Сообщение отредактировал dvrts - 8.12.2009, 0:37
YARICHEK
сообщение 6.12.2009, 8:24
Из: Донецк
Пользователь №: 208 179
Модель телефона: Z8
Прошивка: 54G
Help please! On this insertion it is impossible to start any fitter that sad.gif!!! How to solve this problem or explain as to use program Skins which was already in an insertion!!! In advance thanks!!!
marcolnx
сообщение 6.12.2009, 10:26
YARYCHEK
For skininstaller, hold and press file.pskn inside the folder of theme, open with -> select Skins (I don't select always open...). When installation finished restart the mobile, and after change wallpaper.
For restore and change theme before this, I install default1_skin.pskn (already posted here). Easy,
YARICHEK
сообщение 6.12.2009, 17:23
Из: Донецк
Модель телефона: Z8
Прошивка: 54G
Thanks! And if skin it is established crookedly?
marcolnx
сообщение 6.12.2009, 18:59
Hi,
I installed a lot of theme with skininstaller (no problem), some times before installing a theme I remove some .gif from iconres.ezx with ezxcodec (motoskin) for wrong keyboard or save space. For restoring use default1_skin.pskn (now I cannot attach again from my mobile ).
YARICHEK
сообщение 6.12.2009, 19:51
Из: Донецк
Модель телефона: Z8
Прошивка: 54G
Well then tell to me please why are not started Ultratheme, Wondermoto?
OFN
сообщение 6.12.2009, 20:14
Из: zp.ua
Прошивка: 6.0
Sorry, Marco, my question for you. I was a little
iconrez.ezx modified the basic skin, replacing it a few icons. and I want to put it in usr / data_resource / icon instead of the existing means phone: uploading a new iconrez.ezx in mmc/mmca1 and writing the appropriate commands in the console, but at the end of the session reboot the phone. So can?
marcolnx
сообщение 6.12.2009, 22:02
YARICHEK,
I don't know wondermoto,ecc. I prefear skininstaller or edit directly. (If you wish I will check when go back home).
OFN,hi :-)
yes, if you wish edit copy iconres.ezx in your desktop, edit with ezxcodec (motoskin), so open extract and edit, when finished recompile and place your new iconres.ezx inside SD.
Now with ekonsole or telnet session copy inside /usr/data_resource/icon/ and reboot.
Maybe you wish edit realplayer animation or what you prefear.
Now writing with mobile, but when I come back home I can show all this with images.
By
(6.12.2009, 22:26):
p.s.: no sorry :-) I'm happy if I can help. Only I'm sorry for my bad english.
Garm
сообщение 7.12.2009, 8:36
Из: Морозовск
Problem not solved. Identification of subscribers don't work.
1) When I dial number from addressbook, on dialing window shown only number (not Name of Contact)
2) In Calls Records only numbers (no names)
I delete main.db and log* from sysDatabase/ (phone create it again) - don't solved
Hanggard
сообщение 7.12.2009, 9:08
Пианист
Из: Riga
Пользователь №: 92 516
Прошивка: iOS 14.1
Прост-рок))
Garm, reflash you phone, this mystery can't be resolved...
runtime
сообщение 7.12.2009, 9:39
Из: Омск
Пользователь №: 168 421
Модель телефона: A1200e
Прошивка: JFFS2
@Garm На 20 странице в 200 посте (пост #200) marcolnx дает ответ как это исправить. Miroschnikу помогло. Там не просто надо удалить main.db, а скопировать из вложения.
Сообщение отредактировал runtime - 7.12.2009, 9:41
Garm
сообщение 7.12.2009, 11:00
Из: Морозовск
Не помогло. Придется перешиваться.
Don't helped. I think need to reflash
Сообщение отредактировал Garm - 7.12.2009, 11:00
OFN
сообщение 7.12.2009, 14:31
Из: zp.ua
Прошивка: 6.0
Камрады, у кого какие впечатления от фото- и видеокамеры ?
Garm
сообщение 7.12.2009, 17:19
Из: Морозовск
How to make a case-insensitive search in address book in this FW?
Как сделать регистронезависимый поиск в адресной книге в этой прошивке?
dvrts
сообщение 8.12.2009, 0:23
Из: Lviv
QUOTE
100% стандарт. мне нравится)
Garm
сообщение 8.12.2009, 7:48
Из: Морозовск
Цитата(OFN @ Вчера, 21:01)
+1. Хороший вопрос. очень интересно
Сразу скажу - библиотека от 16R не подходит. Поиск регистронезависимый с ней, но напросчь отрубается определитель номеров (именно та проблема что у меня была)
OFN
сообщение 8.12.2009, 8:23
Из: zp.ua
Прошивка: 6.0
в смысле - как на стандартных прошивках? А не как на 11R?
Hanggard
сообщение 8.12.2009, 8:33
Пианист
Из: Riga
Прошивка: iOS 14.1
Прост-рок))
OFN
сообщение 8.12.2009, 8:45
Из: zp.ua
Прошивка: 6.0
а как еще реально сделать поиск регистрнезависимым ? (жесткая регистрозависимость поиска несколько убивает радость от наличия фингерпада ИМХО. потому что сразу же появляются новые ожидания и новые потребности- в опережающем режиме. smile.gif)
Добавлено позже (8.12.2009, 10:53):
Цитата(Hanggard @ 8.12.2009, 10:33) *
Ну, тут столько было написано про то, что на 11R камера работает лучше. чем на 14-1 и на 16- й....Возникло движение по улучшению камеры (за счет замены библиотек, насколько я понял).
При описании новых прошивок выражение "камера от 11 R" стало неотъемлемой частью рекламного контента.
Вот я и спрашиваю...
А если камера здесь НЕ от 11R - может, ее надо довести до этого уровня, библиотеки заменить? все таки это открытая прошивка
SergGG
сообщение 8.12.2009, 10:00
Мингофан
Из: Дніпро
Пользователь №: 85 418
Модель телефона: Droid Turbo
Прошивка: 6.0
Капітан Збройних сил України
Тут есть определенная путанница - Есть прошлогодняя прошивка 11R для А1200, которая мало чем отличается от 16R - она выпущена примерно в то же время, большинство бибилотек полностью идентично. Камера полностью как на 16R. По-моему именно от нее либы тут. И есть 11R до A1200R этого года с поддержкой виджетов и камерой, которая вроде бы лучше снимает, особенно при ухудшении освещенности.
Hanggard
сообщение 8.12.2009, 10:07
Пианист
Из: Riga
Прошивка: iOS 14.1
Прост-рок))
кароче, у нас 11R новой ревизии с камерой от старой ревизии?
OFN
сообщение 8.12.2009, 10:12
Из: zp.ua
Прошивка: 6.0
по впечатлениям от камеры - именно так.
Значит, надо менять либы. А где их брать?
А бинарники менять надо?
Сообщение отредактировал OFN - 8.12.2009, 10:21
SergGG
сообщение 8.12.2009, 10:21
Мингофан
Из: Дніпро
Прошивка: 6.0
В теме "Устройство прошивки" описано какие библиотеки и бинарники надо перенести для камеры. Берите из 11R новой ревизии и пробуйте их заменить. Если качество фото улучшится - то видимо в этом было дело.
Hanggard
сообщение 8.12.2009, 10:23
Пианист
Из: Riga
Прошивка: iOS 14.1
Прост-рок))
OFN, согласен, я седня уже пофотал рассвет в своем северном краю:). Получился уг, против света он все освещает по самое "немогу", там где солнце было малиновым, стало оранжевым, движение было смазанным (я фотал за рулем, на скорости 100км/ч. На F6 фото было в разы лучше, на 16R - так же, как сейчас, или еще чуть хуже.) Короче, фотка у меня в профайле - сделана мингом на 16R. Качество судите сами. На 14R.F6 было немного лучше, тут - могу выложить. Если честно, не поверил, сфоткал 3 раза. Никогда еще телефон так сильно не размывал изображение...
marcolnx
сообщение 8.12.2009, 20:21
If you want to try to replace and see if it works better.
I will attach bin and libs from R541L7_G_11.10.11R.
p.s.: I replaced without problem (I need to test about quality). With this firmware it's easy make test.
Let me know if work better.
Прикрепленный файл Camera_R541L7_G_11.10.11R.zip   ( 587.46 килобайт ) Кол-во скачиваний: 85
linuxoid200
сообщение 9.12.2009, 0:23
Из: Kiev
Пользователь №: 78 226
Модель телефона: a1200e, sgh i-200
Прошивка: jffs2 11R
Прошил версией от 02/12/2009
Группы (категории) в контактах пишет на русском, а не квадратами.
Календарь даты пишет правильно. Я доволен.
Спасибо marcolnx!
RSD Lite 4.0.1 отказался с предыдущей версей переводить телефон во флеш режим. Пришлось делать вручную.
Сообщение отредактировал linuxoid200 - 9.12.2009, 0:26
dvrts
сообщение 9.12.2009, 0:38
Из: Lviv
QUOTE
OK, I tested. It might be greater, than earlier one
(9.12.2009, 2:41):
QUOTE
OFN
сообщение 9.12.2009, 14:54
Из: zp.ua
Прошивка: 6.0
Доброго! Я поменял библиотеки и бинарник камеры на ВОТ ЭТИ https://forum.motofan.ru/style_images/madmo...p.gif(выковырял собственноручно из выложенной здесь новой бразильской прошивки A1200e_Especial_Edition_widgets_perfect_wagner, насколько я понял, в BlackDiamond , Iris и MooTaNT используются именно эти библиотеки и бинарник )
Докладываю: стало значительно лучше.
И отклик, и чувствительность. Исчезла проблема с выдержкой - этот "псевдоавтофокус".
Снимал в очень пасмурную погоду -получилось лучше. чем раньше на F6 и много лучше, чем прежде на этой прошивке.
Заодно: Зы: Ув. опытные линуксоиды и проф. юниксисты, еслит это вас не затруднит, не будете ли вы так любезны объяснить мне, какие функции в системе выполняет /dev/camerai2c, который, насколько я понял после того, как разобрал несколько прошивок с помощью ezxcodec, является линком ?
linuxoid200
сообщение 9.12.2009, 19:28
Из: Kiev
Прошивка: jffs2 11R
Цитата(ax192 @ 9.12.2009, 21:42) *
Что они дают,эти команды
"Эти команды" позволяют вносить изменения в самом телефоне, без "подстав" на mmca1.
Данная прошивка - "продолжение" (или почти продолжение) U-серии.
Можно убить телефон, если неосторожно вносить изменения.
Походу, похоже, что это не "твоя" прошивка.
2 dvrts
Цитата(dvrts @ 9.12.2009, 3:38) *
"RSD Lite 4.0.1 отказался с предыдущей версей переводить телефон во флеш режим. Пришлось делать вручную."
"Так и следует вообще-то"
Можно с этого момента поподробнее?
OFN
сообщение 10.12.2009, 9:04
Из: zp.ua
Прошивка: 6.0
Доброго всем!
Раньше выкладывал здесь синий скин из11R. Марко совершенно справедливо заметил тогда. что в нем не хватает части русских клавиатур.
Исправился. Всего хватает, даже с избытком.
Кто захочет изменить на этой прошивке скины на стандартные с 11R (как на картинке) не перепрошивась по новому , а используя возможности jffs2 , пожалуйста.
Вот два уже готовые набора скинов :
- красный(основной)+белый,
и
-синий (основной)+белый.
Все переправлено и разложено туда, где оно должно быть в /usr/data_resource. Файлы конфигурации цветовой палитры и темы исправлены с учетом того того, что в одном варианте в качестве "скина -хозяина" HAINAN_01 у нас будет синий скин bluepro(дополненный недостающими элементами из красного скина и с полным набором русских и прочих клавиатур из Onyx Black от Марко) а в другом- красный скин newburnsred. В принципе, могу выложить полный набор, со всеми тремя скинами (красным, белым, синими) как в "бразильянке" , но ИМХО это избыточный объем.
Чтобы заменить скины,распаковываем архив с предпочитаемой Вами комбинацией скинов в корень флешки ( я лично завел там себе для этих целей специальный директорий(папку) working_dir, туда все ремкомплекты и складываю), и меняем директории(папки) в /usr/data_resource на те, что в архивах, начиная с icon, потом skin потом все остальное а потом перезагружаемся.
Зы: спасибо Марко и SergGG за то, что объяснили, что редактировать иконрес целесообразнее с помощью ezxcodec. Старый kview не всегда корректно работает.
Сообщение отредактировал OFN - 10.12.2009, 11:16
Прикрепленный файл red_and_white_skin_11r.rar   ( 3.23 мегабайт ) Кол-во скачиваний: 60
Прикрепленный файл blue_and_white_skin_11r.rar   ( 3.28 мегабайт ) Кол-во скачиваний: 66
dvrts
сообщение 10.12.2009, 9:34
Из: Lviv
QUOTE
и
QUOTE
По сути не рекомендуется давать программам волю если что-то можно сделать своими руками. Особенно по части прошивки
OFN
сообщение 10.12.2009, 11:26
Из: zp.ua
Прошивка: 6.0
Цитата(dvrts @ 10.12.2009, 11:34) *
ОК
поскольку синий скин по комплектации очень мало отличается от красного,
меньше, чем белый, при использовании его в качестве дополнительного он будет занимать очень маленький объем.
Эта комбинация самая экономичная в плане места.
Впрочем, если оптимизировать состав iconres.ezx так, как это сделали создатели "бразильского" набора скинов от 11 R , полный набор всех трех скинов- красного белого и синего - будет занимать ненамного больше места ,чем стандартная комбинация двух скинов- Onyx Black и Оnyx White.
Сообщение отредактировал OFN - 10.12.2009, 11:32
Прикрепленный файл red_and_blue_skin_11r.rar   ( 2.9 мегабайт ) Кол-во скачиваний: 80
Прикрепленный файл red_white_blue_skin_11r.rar   ( 3.2 мегабайт ) Кол-во скачиваний: 79
linuxoid200
сообщение 10.12.2009, 12:14
Из: Kiev
Прошивка: jffs2 11R
2 marcolnx & advanced members
English:
How could i make overclocking on this firmware?
Russian:
Как разогнать проц на данной прошивке?
2 OFN
Спасибо за скины. Очень кстати.
Сообщение отредактировал linuxoid200 - 10.12.2009, 12:18
Linux Ming (jffs2 11R - firmware), Прошивка с rw на базе 11R. Версия от 16.12.2009 · Motorola ROKR E6, E6e, E6tv, MING A1200, A1200i, A1200e, A1200r, A1200w, A1600 · Forum
Текстовая версия Сейчас: 23.7.2025, 9:35
