20 страниц V « < 6 7 8 9 > »
Linux Ming (jffs2 11R - firmware), Прошивка с rw на базе 11R. Версия от 16.12.2009
marcolnx
сообщение 12.11.2009, 17:31 Закрепленное сообщение!
Пользователь №: 201 733
JFFS2 11R (a1200e e a1200r)
English description is under spoiler
First: I wanted to thank tmp_do and tmr for creating a jffs2 firmware (and therefore the possibility of writing the whole system).
Second: I wanted to thank SergGG Provodnik Silent Bob dvrts and all Motofan ru users for sharing informations and help.
Starting from whiteMING2 of tmp_do (thanks to his help and his answers) I have modified and customized the firmware:
- Replaced all libraries SYStapi SYSqtapp SYSjava SYSdb etc. (11R)
- Flip closed options
- Inserted and placed some missing applications or not fully working (BCR - Sync - Standard Viewer - Photo Editor)
- Added binaries (ldd - showQ - ezxpopup - etc.), so bash3 busybox strace ...
- Added ringtones, pictures, skin, mystuff, etc.
- Radio works without headset
- Calendar in the main screen shows the first appointment in 24 hours
- 2 new skins (red and white)
- Pre-installed applications: ekonsole, Assistant of Amin (reboot, pkg installer, screenshot, swap manager, hacker, mystuff, unrar unzip, ecc.), Skin Installer, Backup Restore Now, SysInfo, ZEditor (can see hidden folder and edit hidden files), PicselEdit (there is also the standard)
- 2 java applications: platinumsudoku - ICQ Jimm
- Language: English - Russian - Ukrainian (VR English - Russian)
- Fixed all profile (Silent, Vibrate, ecc.)
- ext2 ext3 support with modules.dep
- Screen3 works
- Support autorun.txt under SD (/mmc/mmca1/)
- Fingerpad white and foxalarm (voice russian)
- added Processor (underclock and overclock at 520)
- added pictures
- added skin blue (Sens theme)
- added, replaced for Camera_R541L7_G_11.10.11R
- added, replaced for libezxmime.so.1.0.0 thanks a lot Silent Bob
- added pftpd (pure-ftpd and pure-ftpwho) thanks a lot fordalulz
- added, replaced ro rw
- added new init script (so also startup1.txt, startup.txt for SD and startup2.txt for phone) and a lot of stuff for mount --bind sounds, animation, volume, font, ecc. without write directly for new user)
p.s.: I have attached folder MCleaner and MotoID, extract and install if you want.
Generally if something does not like (you can write in the whole) you can edit yourself.
Hopefully you'll try it and have fun.
Link:
Link for download
About swap:
If we need 32mb swap just extract the folder .bin from here and put in the root of SD:
http://www.4shared.com/file/84649109/509f6517/Swap_SD.html
You can easy activate - deactivate with Assistant and check with SysInfo or eKonsole
Прикрепленное изображениеПрикрепленное изображение Прикрепленное изображениеПрикрепленное изображение
Перевод на русский dvrts
Прежде всего хотелось бы поблагодарить tmp_do и tmr за создание прошивок на базе jffs2 (и как следствие, возможность модифицирования всей ФС телефона без перепрошивки (read-write:)
Также хотелось бы поблагодарить SergGG, Provodnik, Silent Bob, dvrts и всех пользователей motofan.ru за информацию и помощь
По сравнению с WhiteMING2 (автор tmp_do) прошивка изменена, улучшена и дополнена:
- Заменены все библиотеки SYStapi SYSqtapp SYSjava SYSdb т.д. (11R)
- Расширенное меню при закрытом флипе
- Добавлена и изменены некоторые приложения, отсутствующие или некорректно работающие ( BCR - Синхронизация - Стандартный Viewer - Photo Editor)
- Добавлены бинарники (ldd - showQ - ezxpopup - и т.д.), so, bash3, BusyBox, strace ...
- Добавлены рингтоны, картинки, скины, изменен mystuff и т.д.
- Радио работает без гарнитуры
- Календарь на главном экране отображает первое задание в 24 часа
- 2 скина (красный и белый)
- Предустановленные приложения: ekonsole, Amin Assistant (перезагрузка, установщик pkg, swap, javahacker, mystuff, распаковщики архивов, и т.д.), Skin Installer, Backup Restore, SysInfo, ZEditor (можно увидеть скрытые папки и править скрытые файлы), PicselEdit (есть стандартный)
- Язык: английский - русский - украинский (VR английский - русский)
- Исправлены все звуковые профили (бесшумный, вибро, и т.д.)
- Screen3 работает
- Поддержка autorun.txt (/mmc/mmca1/autorun.txt)
- Фингерпад с кириллицей
- Foxalarm взамен стандартного будульника
- Куча мелких изменений
- Добавлено приложение для разгона процессора (до 520 MHz)
- Добавлены изображения
- Синий скин (Sens)
- Бинарники для камеры от _R541L7_G_11.10.11R
- Изменен libezxmime.so.1.0.0
- Добавлено приложение для ftp
- Изменены бинарники для ro rw
- Дополнен авторан (startup1.txt, startup.txt для карты памяти и startup2.txt для памяти телефона) и дополнительные папки для mount --bind (звуки, анимация, volumetable, шрифты, и т.д. без необходимости переходить в read-write ФС)
Ссылка
Для установки свапа - скачать файл и положить в корень карты памяти
Для изменения режимов ro - rw - в консоли выполнить
CODE
rw
CODE
ro
Сообщение отредактировал marcolnx - 10.1.2010, 9:33
Прикрепленный файл Howto_jffs2_new_firmware_save_data.txt   ( 1.17 килобайт ) Кол-во скачиваний: 948
Прикрепленный файл MCleaner_MotoID.zip   ( 337.61 килобайт ) Кол-во скачиваний: 666
Прикрепленный файл jffs2_kernel_sdhc.zip   ( 3.91 мегабайт ) Кол-во скачиваний: 1308
Hanggard
сообщение 8.12.2009, 10:23
Пианист
Из: Riga
Пользователь №: 92 516
Прошивка: iOS 14.1
Прост-рок))
OFN, согласен, я седня уже пофотал рассвет в своем северном краю:). Получился уг, против света он все освещает по самое "немогу", там где солнце было малиновым, стало оранжевым, движение было смазанным (я фотал за рулем, на скорости 100км/ч. На F6 фото было в разы лучше, на 16R - так же, как сейчас, или еще чуть хуже.) Короче, фотка у меня в профайле - сделана мингом на 16R. Качество судите сами. На 14R.F6 было немного лучше, тут - могу выложить. Если честно, не поверил, сфоткал 3 раза. Никогда еще телефон так сильно не размывал изображение...
marcolnx
сообщение 8.12.2009, 20:21
If you want to try to replace and see if it works better.
I will attach bin and libs from R541L7_G_11.10.11R.
p.s.: I replaced without problem (I need to test about quality). With this firmware it's easy make test.
Let me know if work better.
Прикрепленный файл Camera_R541L7_G_11.10.11R.zip   ( 587.46 килобайт ) Кол-во скачиваний: 86
linuxoid200
сообщение 9.12.2009, 0:23
Из: Kiev
Пользователь №: 78 226
Модель телефона: a1200e, sgh i-200
Прошивка: jffs2 11R
Прошил версией от 02/12/2009
Группы (категории) в контактах пишет на русском, а не квадратами.
Календарь даты пишет правильно. Я доволен.
Спасибо marcolnx!
RSD Lite 4.0.1 отказался с предыдущей версей переводить телефон во флеш режим. Пришлось делать вручную.
Сообщение отредактировал linuxoid200 - 9.12.2009, 0:26
dvrts
сообщение 9.12.2009, 0:38
Из: Lviv
Пользователь №: 162 099
QUOTE
OK, I tested. It might be greater, than earlier one
(9.12.2009, 2:41):
QUOTE
OFN
сообщение 9.12.2009, 14:54
Из: zp.ua
Пользователь №: 182 112
Модель телефона: XT 1585
Прошивка: 6.0
Доброго! Я поменял библиотеки и бинарник камеры на ВОТ ЭТИ https://forum.motofan.ru/style_images/madmo...p.gif(выковырял собственноручно из выложенной здесь новой бразильской прошивки A1200e_Especial_Edition_widgets_perfect_wagner, насколько я понял, в BlackDiamond , Iris и MooTaNT используются именно эти библиотеки и бинарник )
Докладываю: стало значительно лучше.
И отклик, и чувствительность. Исчезла проблема с выдержкой - этот "псевдоавтофокус".
Снимал в очень пасмурную погоду -получилось лучше. чем раньше на F6 и много лучше, чем прежде на этой прошивке.
Заодно: Зы: Ув. опытные линуксоиды и проф. юниксисты, еслит это вас не затруднит, не будете ли вы так любезны объяснить мне, какие функции в системе выполняет /dev/camerai2c, который, насколько я понял после того, как разобрал несколько прошивок с помощью ezxcodec, является линком ?
linuxoid200
сообщение 9.12.2009, 19:28
Из: Kiev
Прошивка: jffs2 11R
Цитата(ax192 @ 9.12.2009, 21:42) *
Что они дают,эти команды
"Эти команды" позволяют вносить изменения в самом телефоне, без "подстав" на mmca1.
Данная прошивка - "продолжение" (или почти продолжение) U-серии.
Можно убить телефон, если неосторожно вносить изменения.
Походу, похоже, что это не "твоя" прошивка.
2 dvrts
Цитата(dvrts @ 9.12.2009, 3:38) *
"RSD Lite 4.0.1 отказался с предыдущей версей переводить телефон во флеш режим. Пришлось делать вручную."
"Так и следует вообще-то"
Можно с этого момента поподробнее?
OFN
сообщение 10.12.2009, 9:04
Из: zp.ua
Прошивка: 6.0
Доброго всем!
Раньше выкладывал здесь синий скин из11R. Марко совершенно справедливо заметил тогда. что в нем не хватает части русских клавиатур.
Исправился. Всего хватает, даже с избытком.
Кто захочет изменить на этой прошивке скины на стандартные с 11R (как на картинке) не перепрошивась по новому , а используя возможности jffs2 , пожалуйста.
Вот два уже готовые набора скинов :
- красный(основной)+белый,
и
-синий (основной)+белый.
Все переправлено и разложено туда, где оно должно быть в /usr/data_resource. Файлы конфигурации цветовой палитры и темы исправлены с учетом того того, что в одном варианте в качестве "скина -хозяина" HAINAN_01 у нас будет синий скин bluepro(дополненный недостающими элементами из красного скина и с полным набором русских и прочих клавиатур из Onyx Black от Марко) а в другом- красный скин newburnsred. В принципе, могу выложить полный набор, со всеми тремя скинами (красным, белым, синими) как в "бразильянке" , но ИМХО это избыточный объем.
Чтобы заменить скины,распаковываем архив с предпочитаемой Вами комбинацией скинов в корень флешки ( я лично завел там себе для этих целей специальный директорий(папку) working_dir, туда все ремкомплекты и складываю), и меняем директории(папки) в /usr/data_resource на те, что в архивах, начиная с icon, потом skin потом все остальное а потом перезагружаемся.
Зы: спасибо Марко и SergGG за то, что объяснили, что редактировать иконрес целесообразнее с помощью ezxcodec. Старый kview не всегда корректно работает.
Сообщение отредактировал OFN - 10.12.2009, 11:16
Прикрепленный файл red_and_white_skin_11r.rar   ( 3.23 мегабайт ) Кол-во скачиваний: 61
Прикрепленный файл blue_and_white_skin_11r.rar   ( 3.28 мегабайт ) Кол-во скачиваний: 67
dvrts
сообщение 10.12.2009, 9:34
Из: Lviv
QUOTE
и
QUOTE
По сути не рекомендуется давать программам волю если что-то можно сделать своими руками. Особенно по части прошивки
OFN
сообщение 10.12.2009, 11:26
Из: zp.ua
Прошивка: 6.0
Цитата(dvrts @ 10.12.2009, 11:34) *
ОК
поскольку синий скин по комплектации очень мало отличается от красного,
меньше, чем белый, при использовании его в качестве дополнительного он будет занимать очень маленький объем.
Эта комбинация самая экономичная в плане места.
Впрочем, если оптимизировать состав iconres.ezx так, как это сделали создатели "бразильского" набора скинов от 11 R , полный набор всех трех скинов- красного белого и синего - будет занимать ненамного больше места ,чем стандартная комбинация двух скинов- Onyx Black и Оnyx White.
Сообщение отредактировал OFN - 10.12.2009, 11:32
Прикрепленный файл red_and_blue_skin_11r.rar   ( 2.9 мегабайт ) Кол-во скачиваний: 81
Прикрепленный файл red_white_blue_skin_11r.rar   ( 3.2 мегабайт ) Кол-во скачиваний: 80
linuxoid200
сообщение 10.12.2009, 12:14
Из: Kiev
Прошивка: jffs2 11R
2 marcolnx & advanced members
English:
How could i make overclocking on this firmware?
Russian:
Как разогнать проц на данной прошивке?
2 OFN
Спасибо за скины. Очень кстати.
Сообщение отредактировал linuxoid200 - 10.12.2009, 12:18
marcolnx
сообщение 10.12.2009, 13:55
linuxoid200
Hi smile.gif problem it's ps (inside the firmware it's symbolik link to busybox), but if you run ./name.lin with ekonsole you can find why don't start.
I edit and maked .pkg and work fine. Make a try (extract and install).
By (ciao)
p.s: after installed ckeck with ekonsole (BogoMIPS)
#cat /proc/cpuinfo (press enter)
Сообщение отредактировал marcolnx - 10.12.2009, 13:59
Прикрепленный файл ClockManager.zip   ( 53.93 килобайт ) Кол-во скачиваний: 78
Garm
сообщение 11.12.2009, 9:02
Из: Морозовск
Пользователь №: 48 276
Прошивка: Black Ming 3b
marcolnx, in firmware doesn't work /ezx_user/download/appwrite/setup/ezx_autorun.cfg...
OFN
сообщение 11.12.2009, 12:13
Из: zp.ua
Прошивка: 6.0
По поводу оптимизации авторана ИМХО целесообразно обратить внимание на интересную наработку Hanggard'а изложенную в посте № 226
(он у себя организовал порядок запуска приложений не по "линуксоидному". а по " фрибиэсдишному", так, как это имеет место в МакОС Х, например).
marcolnx
сообщение 11.12.2009, 12:40
Hi Garm OFN and all,
If we wish more (/mmc/mmca1/startup1.txt, /mmc/mmca1/startup.txt, /ezxlocal/download/mystuff/startup2.txt and a lot of stuff about mount --bind), just look inside ezx_boot.cfg, extract the folder Boot.zip and place inside SD and with few command (look for this history.txt) we will have this.
Also inside a folder with a different startup and shutdown animation (for testing), just place under "phone".
We can also edit ezx_boot.cfg for your preferences.
Sorry bad english.
OFN
сообщение 11.12.2009, 12:53
Из: zp.ua
Прошивка: 6.0
И снова подрубрика "сам себе мотодизайнер" .
В "бразильских" скинах от 11R есть ИМХО одно неудобство- красная или синяя полоска фона статус -бара, режущая экран и откровенно диссонирующая с подавляющим большинством всех возможных обоев, начиная с наших любительских фото. Тем. кому, как в свое время мне, это кажется "неаккуратненьким" - пожалуйста,4-й скин от 11R- "бразильский черный" - или "pele".
ИзображениеИзображениеhttp://Изображение
"Черного" мы делаем из "синего" (почему то синего здесь никто не любит) следующим образом.
Скачиваете этот файл HAINAN_03.skn в корень флешки,разархивируете, а потом любым доступным Вам способом ( хоть с консоли, хоть расширенным файл-менеджером) копируете его в /usr/data_resource/skin/default3, заменяя им существующий
И ВСЕ.
Если Вам больше НЕ нравится красный скин, можете сделать черным его. В этом случае переименуйте этот скачанный Вами HAINAN_03.skn в HAINAN_01.skn, перейдите на время в меню Прочее>Настройки >Цветовая схема на белую или синюю, а после этого скопируйте Ваш новый HAINAN_01.skn в /usr/data_resource/skin/default1 , заменив им существующий.
После этого Вам даже не придется перезагружать телефон.
Зы: Выложенный здесь мною файл- это на самом деле просто файл .skn от скина BlackMing. кто не знает: информация про основные рамочек и стрелочки , их цвет и дизайн содержатся именно в .skn
Как видите. его достаточно просто переименовать и подложить в нужное место.
Сообщение отредактировал OFN - 11.12.2009, 12:54
dvrts
сообщение 11.12.2009, 19:35
Из: Lviv
New SysMenutree
Try to use this one
PS. I also added changelog of previous versions for a top message
Сообщение отредактировал dvrts - 12.12.2009, 3:33
Garm
сообщение 12.12.2009, 8:26
Из: Морозовск
Вчера с удивлением заметил, что после команды "ro" я по прежнему могу изменять системные файлы (!)
Проблему решил использованием
mount / -o remount,ro
вместо
mount - o remount ro /
в /bin/ro
==== English ========
Yesterday was surprised to see that after the command "ro" I still can modify system files (!)
I solve this problem by using
instead
in /bin/ro
Сообщение отредактировал Garm - 12.12.2009, 8:26
linuxoid200
сообщение 12.12.2009, 12:06
Из: Kiev
Прошивка: jffs2 11R
Есть проблемы при разгоне программой ClockManager от marcolnx :
1) разгон на 612 MHz происходит, но вернуть назад не получаеться -только выключить и включить телефон, который жутко греется (были случаи, когда проц сгорал от перегрева??? у меня печальный опыт - сгорел при разгоне mpx200);
2) не предлагает выбора на сколько разогнать, а в скрипте (я тут не силен) есть варианты.
Разгон A1200/ROKR E6
ОФИЦИАЛЬНЫЙ Максимальный порог 520 мегагерц
Кто-нибудь может помочь ?
Hi marcolnx.
I have some problems with ClockManager.
It's works quickly without any window with choices 108Mhz, 312MHz, 612Mhz. Is it planned so?
Why i can't reset the cpu down to standart frequency by using ClockManager?
I resolve this by switching phone off/on.
Could i ask you to make changes? ( & 612 -->520)
Сообщение отредактировал linuxoid200 - 12.12.2009, 12:24
marcolnx
сообщение 12.12.2009, 15:33
Hi linuxoid200,
Processor application will show this image, and from here you can select what you wish.
dvrts
сообщение 12.12.2009, 18:45
Из: Lviv
а ro в консоли не поможет?
OFN
сообщение 12.12.2009, 23:55
Из: zp.ua
Прошивка: 6.0
мне пока помогает.
тьфу тьфу тьфу
linuxoid200
сообщение 13.12.2009, 0:41
Из: Kiev
Прошивка: jffs2 11R
Hi marcolnx, thanks.
It's really show me the window ::))
When i started it in first time, it didn't show this window. Maybe it was a bug of the unit, but now it's works well! )
Can you show me the way - how can i change frequency from 612 to 520?
Because, i'm afraid to damage the AP-cpu by Overheating & Overclocking it on this high value.
Реально был какой-то глюк с телом, запустил один раз для проверки работоспособности плэеров по воспроизведению видео без конвертации под Минг, и прога не отсветила возможные варианты перевода ЦПУ по частоте. Повторный запуск, в надежде, что можно будет убрать разгон, тоже не дал результата - тело пахало на 612 МГц. Понятно, что пришлось перезапускать. Отсюда и вопросы были.
Сейчас всё - ОК !
Я доволен.
Вот бы ещё понизить с 612 до 520 ... программа, что редактирует (eapmd ver.2.1) открывает ampd_over & ampd_under, как для E2, а не как для a1200! Отсюди и данный вопрос - какой файл редактировать и той ли программой пользуюсь?
Garm
сообщение 13.12.2009, 8:39
Из: Морозовск
Ну я же написал, что у меня оно не работало, пока я не изменмл команду...
marcolnx
сообщение 13.12.2009, 8:41
Uninstall Processor application, and install this .pkg for 520 (just the same but overclock for 520).
Прикрепленный файл ClockManager.zip   ( 54.26 килобайт ) Кол-во скачиваний: 78
runtime
сообщение 13.12.2009, 10:59
Из: Омск
Пользователь №: 168 421
Модель телефона: A1200e
Прошивка: JFFS2
действительно ro не работало, пока не поменял команду
Сообщение отредактировал runtime - 13.12.2009, 10:59
OFN
сообщение 13.12.2009, 16:04
Из: zp.ua
Прошивка: 6.0
Интересно.
У меня ro работает.
У кого еще работает?
У кого еще не работает?
Должна быть какая то закономерность
runtime
сообщение 13.12.2009, 16:27
Из: Омск
Прошивка: JFFS2
не скажу на 100%, но ro перестало работать на последней версии прошивки, до этого, по-моему, работало.
dvrts
сообщение 13.12.2009, 17:12
Из: Lviv
у меня ro работает
linuxoid200
сообщение 13.12.2009, 17:31
Из: Kiev
Прошивка: jffs2 11R
Hi marcolnx, thanks! )
Can you add ClockManager520MHz.pkg to First(Locked) Post?
It will be great, i think so. )
Have a question.
ClockManager520MHz switch AP at 166 MHz and 'cat /proc/cpuinfo' show 207.52 BogoMIPS ! (207.52, 103.76, 518.80)
Where is the joke? :)
When testing ClockManager612MHz, 'cat /proc/cpuinfo' show 51.88, 103.76, 622.56 BogoMIPS.
Сообщение отредактировал linuxoid200 - 13.12.2009, 22:19
fordalulz
сообщение 14.12.2009, 0:03
Пользователь №: 203 255
Модель телефона: nokia3300
Built Pure-FTPd 1.0.27 today
I guess it will come in handy to this firmware, since there is no need to reflash phone to install it.
The features are
- Different codepages for file names. I worked with cyrillic, must work with others too.
- Chmod works fine, for all files
- Options work, for example allowing to see system files (with .)
- Built an optional pure-ftpwho, just for fun. It allows to see current sessions from console
- Runs good, all feedback is in english so it is international (instead of gibberish i found at others)
To install untar archive somethere, put pure-ftpd and pure-ftpwho to /usr/sbin Then add
ftp stream tcp nowait root /usr/sbin/tcpd /usr/sbin/pure-ftpd
into inetd.conf and comment all other ftps by #
Do not forget to set +x for all!
There are an example in archive presenting this, and options
Readme is original, see it for options and conf.log is to show parameters to built it yourself.
After being sure all works fine you could delete all other ftpds, but that is your point
Tested on previous firmvare version (with had an mms glitch back there).
Собрал сегодня Pure-FTPd версии 1.0.27
Думаю для прошивок с перезаписью будет интересно так как не надо перешиваться чтобы установить все это.
Что интересного
- Разные кодировки для имен файлов, кириллица работает, должны и другие
- Работает смена разрешений
- Опции, позволяют делать всякие плюшки типа видимых системных папок (те что с .)
- Собрал необязательную pure-ftpwho, из консоли или телнета позволяет видеть кто пользуется фтп
- Все что должно работает, все системные соощения на английском и читаемы а не кракозябры как я иногда видел
- Ну и сам собрал
Установка: распаковать архив, положить pure-ftpd и pure-ftpwho в /usr/sbin, добавить в inetd.conf
и закомментить диезами все другие ftp
Не забудьте выдать разрешения на запуск!
В архиве мой конфиг как пример добавления и опций
Так же оригинальный ридми на английском про опции почитать и начало лога сборки чтоб каждый мог сам собрать.
Как все будет проверено можно удалять остальные серверы чтобы места не занимали
Пользуюсь прошлой версией прошивки (та, что была с глюком ммс), но думаю пойдет и на других
OFN
сообщение 14.12.2009, 5:17
Из: zp.ua
Прошивка: 6.0
Цитата(dvrts @ 13.12.2009, 19:12) *
у меня ro работает
насчет ro вырисовался интересный прикол: у меня ro , работает везде. кроме /usr . Для /usr действительно не работатет.
Марко писал о чем то подобном, кстати.
Что это такое?
Это действительно началось на последней версии прошивки, с родными скинами от 11 R!
Шайтан!
marcolnx
сообщение 14.12.2009, 11:09
fordalulz - Hi and thanks very much for pure-ftpd (works fine), I added. smile.gif
About the command ro and rw (only echo > ... to save time by typing the command), I had never checked on ro and I always left the command to WM1 or WM2 (tmp_do).
Just change how in first post howto save data (mtd).
ro -> mount / -o remount,ro
rw -> mount / -o remount,rw
But I suggest after rw (when we need edit or add), always -> reboot
linuxoid200 hi,
ClockManager520MHz.pkg it's 51.88 (underclock), 103.76 (standard), 518.80 (overclock)
But if you run application like Real Player (underclock and standard) will change for 207.52, when you start application, but then returns to normal values.
Сообщение отредактировал marcolnx - 14.12.2009, 12:27
Garm
сообщение 14.12.2009, 17:46
Из: Морозовск
I changed /bin/rw and /bin/ro with this scripts and all works properly
marcolnx
сообщение 14.12.2009, 19:54
but always better reboot after writing (check for this df -ah after restoring ro, you cannot write but...).
OFN, have you placed the icons with the Russian flag?
Also check screen3 pics (some .g instead .gif), I have not tested.
Also missing some icon for gprs
Thanks
Cored
сообщение 14.12.2009, 22:28
Из: UA
Пользователь №: 172 163
Прошивка: Silent Bob 2.0
Thenk yoyr for the firmware.
One question.
How to add Russian code groups Win-1251,KOI8R to the e-mail client?
Как добавить русские кодировки в e-mail клиент?
dvrts
сообщение 15.12.2009, 0:17
Из: Lviv
Link updated
try to check
Silent_Bob
сообщение 15.12.2009, 12:18
Городской партизан
Пользователь №: 162 603
Прошивка: Готичная
QUOTE
libezxmime ...
Прикрепленный файл libezxmime.so.1.0.0.gz   ( 60.94 килобайт ) Кол-во скачиваний: 252
Сообщение отредактировал dvrts - 17.12.2009, 0:08
Garm
сообщение 15.12.2009, 17:15
Из: Морозовск
marcolnx, I cam't modify files inside of /usr/language/<langname>/ (or /ezxlocal/.system/vui/<langname>/) but folder is renamed normal. Why?
Я не могу изменять содержимое /usr/language/<название языка>/ (or /ezxlocal/.system/vui/<название языка>, хотя сама папка переименовывается без проблем. Почему?
Естественно в RW-режиме (off course in RW-mode)
marcolnx
сообщение 15.12.2009, 17:55
Hi Garm,
are you sure? inside /ezxlocal/.system/vui/ you can also create (touch), edit without "rw".
p.s.: check with df -ah for free space.
Silent Bob, thanks a lot posting libezxmime (also lib VR it's RuMing...)
Сообщение отредактировал marcolnx - 15.12.2009, 21:34
OFN
сообщение 15.12.2009, 23:57
Из: zp.ua
Прошивка: 6.0
Hi, Marco,
advice,please, as possible to ensure that the preset standard file manager open the entire file system of your phone?
Linux Ming (jffs2 11R - firmware), Прошивка с rw на базе 11R. Версия от 16.12.2009 · Motorola ROKR E6, E6e, E6tv, MING A1200, A1200i, A1200e, A1200r, A1200w, A1600 · Forum
Текстовая версия Сейчас: 26.7.2025, 2:15
