20 страниц V « < 8 9 10 11 > »
Linux Ming (jffs2 11R - firmware), Прошивка с rw на базе 11R. Версия от 16.12.2009
marcolnx
сообщение 12.11.2009, 17:31 Закрепленное сообщение!
Пользователь №: 201 733
JFFS2 11R (a1200e e a1200r)
English description is under spoiler
First: I wanted to thank tmp_do and tmr for creating a jffs2 firmware (and therefore the possibility of writing the whole system).
Second: I wanted to thank SergGG Provodnik Silent Bob dvrts and all Motofan ru users for sharing informations and help.
Starting from whiteMING2 of tmp_do (thanks to his help and his answers) I have modified and customized the firmware:
- Replaced all libraries SYStapi SYSqtapp SYSjava SYSdb etc. (11R)
- Flip closed options
- Inserted and placed some missing applications or not fully working (BCR - Sync - Standard Viewer - Photo Editor)
- Added binaries (ldd - showQ - ezxpopup - etc.), so bash3 busybox strace ...
- Added ringtones, pictures, skin, mystuff, etc.
- Radio works without headset
- Calendar in the main screen shows the first appointment in 24 hours
- 2 new skins (red and white)
- Pre-installed applications: ekonsole, Assistant of Amin (reboot, pkg installer, screenshot, swap manager, hacker, mystuff, unrar unzip, ecc.), Skin Installer, Backup Restore Now, SysInfo, ZEditor (can see hidden folder and edit hidden files), PicselEdit (there is also the standard)
- 2 java applications: platinumsudoku - ICQ Jimm
- Language: English - Russian - Ukrainian (VR English - Russian)
- Fixed all profile (Silent, Vibrate, ecc.)
- ext2 ext3 support with modules.dep
- Screen3 works
- Support autorun.txt under SD (/mmc/mmca1/)
- Fingerpad white and foxalarm (voice russian)
- added Processor (underclock and overclock at 520)
- added pictures
- added skin blue (Sens theme)
- added, replaced for Camera_R541L7_G_11.10.11R
- added, replaced for libezxmime.so.1.0.0 thanks a lot Silent Bob
- added pftpd (pure-ftpd and pure-ftpwho) thanks a lot fordalulz
- added, replaced ro rw
- added new init script (so also startup1.txt, startup.txt for SD and startup2.txt for phone) and a lot of stuff for mount --bind sounds, animation, volume, font, ecc. without write directly for new user)
p.s.: I have attached folder MCleaner and MotoID, extract and install if you want.
Generally if something does not like (you can write in the whole) you can edit yourself.
Hopefully you'll try it and have fun.
Link:
Link for download
About swap:
If we need 32mb swap just extract the folder .bin from here and put in the root of SD:
http://www.4shared.com/file/84649109/509f6517/Swap_SD.html
You can easy activate - deactivate with Assistant and check with SysInfo or eKonsole
Прикрепленное изображениеПрикрепленное изображение Прикрепленное изображениеПрикрепленное изображение
Перевод на русский dvrts
Прежде всего хотелось бы поблагодарить tmp_do и tmr за создание прошивок на базе jffs2 (и как следствие, возможность модифицирования всей ФС телефона без перепрошивки (read-write:)
Также хотелось бы поблагодарить SergGG, Provodnik, Silent Bob, dvrts и всех пользователей motofan.ru за информацию и помощь
По сравнению с WhiteMING2 (автор tmp_do) прошивка изменена, улучшена и дополнена:
- Заменены все библиотеки SYStapi SYSqtapp SYSjava SYSdb т.д. (11R)
- Расширенное меню при закрытом флипе
- Добавлена и изменены некоторые приложения, отсутствующие или некорректно работающие ( BCR - Синхронизация - Стандартный Viewer - Photo Editor)
- Добавлены бинарники (ldd - showQ - ezxpopup - и т.д.), so, bash3, BusyBox, strace ...
- Добавлены рингтоны, картинки, скины, изменен mystuff и т.д.
- Радио работает без гарнитуры
- Календарь на главном экране отображает первое задание в 24 часа
- 2 скина (красный и белый)
- Предустановленные приложения: ekonsole, Amin Assistant (перезагрузка, установщик pkg, swap, javahacker, mystuff, распаковщики архивов, и т.д.), Skin Installer, Backup Restore, SysInfo, ZEditor (можно увидеть скрытые папки и править скрытые файлы), PicselEdit (есть стандартный)
- Язык: английский - русский - украинский (VR английский - русский)
- Исправлены все звуковые профили (бесшумный, вибро, и т.д.)
- Screen3 работает
- Поддержка autorun.txt (/mmc/mmca1/autorun.txt)
- Фингерпад с кириллицей
- Foxalarm взамен стандартного будульника
- Куча мелких изменений
- Добавлено приложение для разгона процессора (до 520 MHz)
- Добавлены изображения
- Синий скин (Sens)
- Бинарники для камеры от _R541L7_G_11.10.11R
- Изменен libezxmime.so.1.0.0
- Добавлено приложение для ftp
- Изменены бинарники для ro rw
- Дополнен авторан (startup1.txt, startup.txt для карты памяти и startup2.txt для памяти телефона) и дополнительные папки для mount --bind (звуки, анимация, volumetable, шрифты, и т.д. без необходимости переходить в read-write ФС)
Ссылка
Для установки свапа - скачать файл и положить в корень карты памяти
Для изменения режимов ro - rw - в консоли выполнить
CODE
rw
CODE
ro
Сообщение отредактировал marcolnx - 10.1.2010, 9:33
Прикрепленный файл Howto_jffs2_new_firmware_save_data.txt   ( 1.17 килобайт ) Кол-во скачиваний: 948
Прикрепленный файл MCleaner_MotoID.zip   ( 337.61 килобайт ) Кол-во скачиваний: 666
Прикрепленный файл jffs2_kernel_sdhc.zip   ( 3.91 мегабайт ) Кол-во скачиваний: 1308
Hanggard
сообщение 18.12.2009, 9:57
Пианист
Из: Riga
Пользователь №: 92 516
Прошивка: iOS 14.1
Прост-рок))
Marcolnx, hi.
Цитата(marcolnx @ Сегодня, 15:47)
in the image I showed for the size of .wav
What a pity... And do you know how to change it? Greatest thanx for bash!
Добавлено позже (18.12.2009, 16:14):
Marcolnx, I just used your new bash. Files have same size.
root@(none):~# telnet
-bash: telnet: command not found
Сообщение отредактировал Hanggard - 18.12.2009, 10:14
OFN
сообщение 18.12.2009, 10:18
Из: zp.ua
Пользователь №: 182 112
Модель телефона: XT 1585
Прошивка: 6.0
Цитата(Hanggard @ 18.12.2009, 11:57) *
Marcolnx, hi.
ИМХО, Марко не совсем понял твой вопрос
Комментируя скриншот с выводом консоли, он объяснил нам, что он делал в /usr/data_resource/phone
, а не то, почему приглашение командной строки у него выглядит phone#
Hanggard
сообщение 18.12.2009, 10:28
Пианист
Из: Riga
Прошивка: iOS 14.1
Прост-рок))
OFN, я это как раз и понял. просто спросил, что "даже если у тебя этого нет - мейби ты знаешь, как это сделать?"
OFN
сообщение 18.12.2009, 10:33
Из: zp.ua
Прошивка: 6.0
ИМХО, у него это таки есть
Добавлено позже (18.12.2009, 13:08):
Вопрос пользователяим этой прошивки: кто нибудь менял содержимое предустановленного screen3 на screen3 от Сайлент Боба?
marcolnx
сообщение 18.12.2009, 11:14
Hanggard sorry, I forget...
#busybox telnet
OFN
сообщение 18.12.2009, 11:19
Из: zp.ua
Прошивка: 6.0
Marco, in the penultimate version of your firmware bash is new, the way you laid out now?
Hanggard
сообщение 18.12.2009, 11:24
Пианист
Из: Riga
Прошивка: iOS 14.1
Прост-рок))
marcolnx, mmm. Busybox works, I have tried it... just I want not patch, but full application... Or do you suggest for me to use aliases? I need to think before use aliases...
marcolnx
сообщение 18.12.2009, 12:28
OFN, no just the same (bash3), Hanggard already telnet inside the mobile.
Hanggard, I don't know about telnet bin. If busybox work...
Do you wish change the name (hostname), permanent?
If yes, I can explain (now I maked for test).
For this firmware only a little edit for init script.
About ssh, there is Dropbear SSH (never used)
Сообщение отредактировал marcolnx - 18.12.2009, 13:37
Hanggard
сообщение 18.12.2009, 13:53
Пианист
Из: Riga
Прошивка: iOS 14.1
Прост-рок))
Thanx, I already asked Silent Bob how to do this, and I changed hostname:).
(never used)
I have used - it works.
If busybox work...
probably I have to do this...
Garm
сообщение 18.12.2009, 14:13
Из: Морозовск
Пользователь №: 48 276
Прошивка: Black Ming 3b
marcolnx, I understand! I just do operations without root-rights (through File Explorer)
I forgot to give root to File Explorer...
OFN
сообщение 18.12.2009, 14:49
Из: zp.ua
Прошивка: 6.0
but how?..
marcolnx
сообщение 18.12.2009, 15:33
OFN,
I maked so (look attachment, also history for command), for hostname LinuxMing (you can change like you prefear, just edit hostname). This will change hostname for telnet session. (Be careful).
Place hostname and S40hostname.sh in the SD and run the commands after telnet:
cd /etc/rc.d/rc2.d/ (enter)
ls -al (enter)
rw (enter)
ln -s ../init.d/tapid S45tapid (enter)
ls -al (enter)
rm S40tapid (enter)
cp /mmc/mmca1/S40hostname.sh /etc/rc.d/rc2.d/ (enter)
chmod a+w S40hostname.sh (enter)
cp /mmc/mmca1/hostname /etc/ (enter)
reboot
Garm
сообщение 18.12.2009, 17:45
Из: Морозовск
Цитата(marcolnx @ Сегодня, 18:33)
Garm, I prefear telnet
marcolnx
сообщение 18.12.2009, 20:29
but you cannot edit or set permission.
Garm
сообщение 19.12.2009, 8:43
Из: Морозовск
SanchoMutant
сообщение 19.12.2009, 9:15
Пользователь №: 202 933
Модель телефона: a1200e
Прошивка: 16R
:офтоп: пол темы состоит из англоязычных слов sad.gif нет возможности использовать транслит.ру
____________
общении с иностранцами - по аськам, скайпам и форумам - это самый простой способ подтянуть иностранный язык, пользуйся smile.gif
Сообщение отредактировал Provodnik - 19.12.2009, 9:50
Hanggard
сообщение 19.12.2009, 9:49
Пианист
Из: Riga
Прошивка: iOS 14.1
Прост-рок))
SanchoMutant, юзай translate.google.ru biggrin.gif или в личку (или аську) пиши, что непонятно, мир не без добрых людей - подскажут. Просто Марко - итальянец и паруске у него как-то не очень получается говорить...
marcolnx
сообщение 19.12.2009, 10:33
make also symbolik link? (ln -s)
Now I'm trying to make a new kernel with SDHC support.
Yersterday my first compile (about a1200), and boot kernel with usbboot for testing.
Hanggard
сообщение 19.12.2009, 10:39
Пианист
Из: Riga
Прошивка: iOS 14.1
Прост-рок))
Цитата(marcolnx @ Сегодня, 16:33)
I always hope grat tmp_do can share costom source and config.
And did you asked him for that?
OFN
сообщение 19.12.2009, 11:22
Из: zp.ua
Прошивка: 6.0
Цитата(Garm @ 19.12.2009, 10:43) *
одно другого не исключает.
На твоем примере:
1. Чтобы это меню работало корректно, самому приложению FileExplorer сперва надо chmod 777
2. По умолчанию он запускается и работает не от имени root, а от имени ezx ( я об этом уже спрашивал здесь: см. регистрационную запись на FileExplorer в SysRegistry)
Добавлено позже (19.12.2009, 13:27):
Цитата(Hanggard @ 19.12.2009, 11:49) *
но за ними глаз да глаз - а то они как ПЕРЕВЕДУТ smile.gif:)
marcolnx
сообщение 19.12.2009, 13:42
Hanggard hi,
Yes, I asked tmp_do in motorolafans and also here.
tmp_do told me to use qtopia kernel and read U3 topic (no good translation for me).
tmp_do has always helped me and I always thank you for this (but I will not bother again).
But precompiled kernel qtopia do not work.
No response for custom config and sources.
But epinter is helping me, from LATAM kernel.
And I will share with us.
Hanggard
сообщение 19.12.2009, 13:59
Пианист
Из: Riga
Прошивка: iOS 14.1
Прост-рок))
Marcolnx, give us link and we will translate it readable for you =)
Сообщение отредактировал Hanggard - 19.12.2009, 14:00
dvrts
сообщение 19.12.2009, 14:57
Из: Lviv
Пользователь №: 162 099
forum.motofan.ru/index.php?showtopic=140881
Garm
сообщение 19.12.2009, 15:29
Из: Морозовск
Цитата(marcolnx @ Сегодня, 13:33)
Hi, Garm great
Hi, Marco. For this exist eKonsole
Alternative: creating with File Explorer new file and editing of it as script
Его я ставлю его из mpkg-пакета
Через Soft Manager даю нужные права
Сообщение отредактировал Garm - 19.12.2009, 15:29
OFN
сообщение 19.12.2009, 15:34
Из: zp.ua
Прошивка: 6.0
Потом иногда все таки не мешает продублировать это вручную
по крайней мере, здесь, на этой прошивке
Сообщение отредактировал OFN - 19.12.2009, 15:35
Garm
сообщение 20.12.2009, 7:39
Из: Морозовск
Что продублировать? Все работает...
Кто-нибудь скиньте мне файлик /usr/language/vui/russian/command.rus пожалуйста, а то я свой случайно уничтожил...
OFN
сообщение 20.12.2009, 13:02
Из: zp.ua
Прошивка: 6.0
держи (просто убрать расширение zip)
Прикрепленный файл command.rus.zip   ( 12.12 килобайт ) Кол-во скачиваний: 193
danger86
сообщение 21.12.2009, 13:09
Пользователь №: 72 895
Модель телефона: E1
So this FW is only AP interface?
marcolnx
сообщение 21.12.2009, 14:42
danger86 hi,
Yes only AP.
I maked flash also with another ming a1200i (C2 track), and working fine.
About my a1200e, I keep BP 13R
Last
сообщение 21.12.2009, 17:38
X squad : media
Из: Украина, Мариуполь
Пользователь №: 34 099
Модель телефона: Atrix 4G
Прошивка: CM WB 20/02/12
Привет! Как идут дела с портом патча на 4 гига?
Hi. How things are going with porting the patch to 4 GB?
Сообщение отредактировал Last - 21.12.2009, 17:38
marcolnx
сообщение 21.12.2009, 20:11
Hi Last,
I downloaded the source and I'm doing some tests.
LATEM source and 38P_clean are different.
I hope with the help of epinter (much experience).
The kernel precompiled qtopia give error file system corrupt, but show sdhc.
I also hope in the help of tmp_do.
Hanggard
сообщение 22.12.2009, 3:25
Пианист
Из: Riga
Прошивка: iOS 14.1
Прост-рок))
Цитата(marcolnx @ Сегодня, 2:11)
file system corrupt
I had the same error, and I had to reflash my phone =(
marcolnx
сообщение 22.12.2009, 6:03
Hi Hanggard
I hope you did not reflash all (not necesary).
First time me too after epinter kernel (don't boot mobile).
I did reflash only original CG33 and RDL3 (maked this with sbf codec opening the firmware and deleting others CG and saving like jffs_standard_kernel.sbf).
If you need I can upload.
Hanggard
сообщение 22.12.2009, 6:19
Пианист
Из: Riga
Прошивка: iOS 14.1
Прост-рок))
I did reflash all =). It happened more than two weeks ago. I did reflash other kernels over this, but unfortunately. In the end I reflashed phone 14R_F6 FW, charged it and flashed your FW again.
Сообщение отредактировал Hanggard - 25.12.2009, 8:20
Витюля
сообщение 22.12.2009, 13:22
Из: Тверь
Пользователь №: 208 896
Модель телефона: A1200e
53-54 % состояния памяти это нормально при не запущенных программах? Просто помню в каких-то прошивках наблюдалось 49-50 ..
danger86
сообщение 22.12.2009, 14:27
Модель телефона: E1
Витюля
это не критично. Можешь пару процессов убить, будет тебе 49...
OFN
сообщение 22.12.2009, 16:10
Из: zp.ua
Прошивка: 6.0
just save and name Jffs_standard_kernel.sbf?
marcolnx
сообщение 22.12.2009, 17:16
Yes OFN,
the name you prefear.
I attach here if we need.
We can please translate tmp_do post #135 here:
R541_G_11.52.14R_U3
There was config? and... (now is no longer available)
Сообщение отредактировал marcolnx - 22.12.2009, 17:25
Прикрепленный файл jffs2_kernel_std.zip   ( 3.91 мегабайт ) Кол-во скачиваний: 68
OFN
сообщение 22.12.2009, 17:44
Из: zp.ua
Прошивка: 6.0
Цитата(marcolnx @ 22.12.2009, 19:16) *
Yes OFN,
R541_G_11.52.14R_U3
"Here I have laid out our joint with tmr patches, unloads debug from the kernel, beautiful bootlog with a beautiful text, unlocking mtd5 and 7"
"Here is my kernel config on A1200, it is tested, included in WhiteMING"
just in depository this kernel config file is no longer, apparently his term of registration ended
paradisV
сообщение 23.12.2009, 11:21
Пользователь №: 207 508
Модель телефона: motorola a1200e
Прошивка: White_diamond
народ,а я смогу безболезненно перепрошиться с R541_G_11.25.14R на нее?
Linux Ming (jffs2 11R - firmware), Прошивка с rw на базе 11R. Версия от 16.12.2009 · Motorola ROKR E6, E6e, E6tv, MING A1200, A1200i, A1200e, A1200r, A1200w, A1600 · Forum
Текстовая версия Сейчас: 26.7.2025, 22:23
