20 страниц V « < 11 12 13 14 15 > »
Linux Ming (jffs2 11R - firmware), Прошивка с rw на базе 11R. Версия от 16.12.2009
marcolnx
сообщение 12.11.2009, 17:31 Закрепленное сообщение!
Пользователь №: 201 733
JFFS2 11R (a1200e e a1200r)
English description is under spoiler
First: I wanted to thank tmp_do and tmr for creating a jffs2 firmware (and therefore the possibility of writing the whole system).
Second: I wanted to thank SergGG Provodnik Silent Bob dvrts and all Motofan ru users for sharing informations and help.
Starting from whiteMING2 of tmp_do (thanks to his help and his answers) I have modified and customized the firmware:
- Replaced all libraries SYStapi SYSqtapp SYSjava SYSdb etc. (11R)
- Flip closed options
- Inserted and placed some missing applications or not fully working (BCR - Sync - Standard Viewer - Photo Editor)
- Added binaries (ldd - showQ - ezxpopup - etc.), so bash3 busybox strace ...
- Added ringtones, pictures, skin, mystuff, etc.
- Radio works without headset
- Calendar in the main screen shows the first appointment in 24 hours
- 2 new skins (red and white)
- Pre-installed applications: ekonsole, Assistant of Amin (reboot, pkg installer, screenshot, swap manager, hacker, mystuff, unrar unzip, ecc.), Skin Installer, Backup Restore Now, SysInfo, ZEditor (can see hidden folder and edit hidden files), PicselEdit (there is also the standard)
- 2 java applications: platinumsudoku - ICQ Jimm
- Language: English - Russian - Ukrainian (VR English - Russian)
- Fixed all profile (Silent, Vibrate, ecc.)
- ext2 ext3 support with modules.dep
- Screen3 works
- Support autorun.txt under SD (/mmc/mmca1/)
- Fingerpad white and foxalarm (voice russian)
- added Processor (underclock and overclock at 520)
- added pictures
- added skin blue (Sens theme)
- added, replaced for Camera_R541L7_G_11.10.11R
- added, replaced for libezxmime.so.1.0.0 thanks a lot Silent Bob
- added pftpd (pure-ftpd and pure-ftpwho) thanks a lot fordalulz
- added, replaced ro rw
- added new init script (so also startup1.txt, startup.txt for SD and startup2.txt for phone) and a lot of stuff for mount --bind sounds, animation, volume, font, ecc. without write directly for new user)
p.s.: I have attached folder MCleaner and MotoID, extract and install if you want.
Generally if something does not like (you can write in the whole) you can edit yourself.
Hopefully you'll try it and have fun.
Link:
Link for download
About swap:
If we need 32mb swap just extract the folder .bin from here and put in the root of SD:
http://www.4shared.com/file/84649109/509f6517/Swap_SD.html
You can easy activate - deactivate with Assistant and check with SysInfo or eKonsole
Прикрепленное изображениеПрикрепленное изображение Прикрепленное изображениеПрикрепленное изображение
Перевод на русский dvrts
Прежде всего хотелось бы поблагодарить tmp_do и tmr за создание прошивок на базе jffs2 (и как следствие, возможность модифицирования всей ФС телефона без перепрошивки (read-write:)
Также хотелось бы поблагодарить SergGG, Provodnik, Silent Bob, dvrts и всех пользователей motofan.ru за информацию и помощь
По сравнению с WhiteMING2 (автор tmp_do) прошивка изменена, улучшена и дополнена:
- Заменены все библиотеки SYStapi SYSqtapp SYSjava SYSdb т.д. (11R)
- Расширенное меню при закрытом флипе
- Добавлена и изменены некоторые приложения, отсутствующие или некорректно работающие ( BCR - Синхронизация - Стандартный Viewer - Photo Editor)
- Добавлены бинарники (ldd - showQ - ezxpopup - и т.д.), so, bash3, BusyBox, strace ...
- Добавлены рингтоны, картинки, скины, изменен mystuff и т.д.
- Радио работает без гарнитуры
- Календарь на главном экране отображает первое задание в 24 часа
- 2 скина (красный и белый)
- Предустановленные приложения: ekonsole, Amin Assistant (перезагрузка, установщик pkg, swap, javahacker, mystuff, распаковщики архивов, и т.д.), Skin Installer, Backup Restore, SysInfo, ZEditor (можно увидеть скрытые папки и править скрытые файлы), PicselEdit (есть стандартный)
- Язык: английский - русский - украинский (VR английский - русский)
- Исправлены все звуковые профили (бесшумный, вибро, и т.д.)
- Screen3 работает
- Поддержка autorun.txt (/mmc/mmca1/autorun.txt)
- Фингерпад с кириллицей
- Foxalarm взамен стандартного будульника
- Куча мелких изменений
- Добавлено приложение для разгона процессора (до 520 MHz)
- Добавлены изображения
- Синий скин (Sens)
- Бинарники для камеры от _R541L7_G_11.10.11R
- Изменен libezxmime.so.1.0.0
- Добавлено приложение для ftp
- Изменены бинарники для ro rw
- Дополнен авторан (startup1.txt, startup.txt для карты памяти и startup2.txt для памяти телефона) и дополнительные папки для mount --bind (звуки, анимация, volumetable, шрифты, и т.д. без необходимости переходить в read-write ФС)
Ссылка
Для установки свапа - скачать файл и положить в корень карты памяти
Для изменения режимов ro - rw - в консоли выполнить
CODE
rw
CODE
ro
Сообщение отредактировал marcolnx - 10.1.2010, 9:33
Прикрепленный файл Howto_jffs2_new_firmware_save_data.txt   ( 1.17 килобайт ) Кол-во скачиваний: 948
Прикрепленный файл MCleaner_MotoID.zip   ( 337.61 килобайт ) Кол-во скачиваний: 665
Прикрепленный файл jffs2_kernel_sdhc.zip   ( 3.91 мегабайт ) Кол-во скачиваний: 1308
Miroschnik
сообщение 5.1.2010, 18:32
Пользователь №: 65 070
Модель телефона: Nokia 5800+LGP500
Шрифт не менялся. С консоли запустить не могу т.к. не знаю исполняемого файла в мидлетах. Но дело мне кажется не в этом.
Скачал Оперу мини 5 и 4.2, установил, незапускаются. Но Джимм и бомбус запускаются и работают.
danger86
сообщение 5.1.2010, 19:30
Пользователь №: 72 895
Модель телефона: E1
Перестала загружаться Opera-mini(mod).
После чего, ты говоришь, она перестала загружаться?
diodoman
сообщение 5.1.2010, 20:26
Пользователь №: 211 991
Модель телефона: ming A1200E
I returned to the sd partition with gparted, 1.9 Gb Fat16 1.9 Ext3 and Swap 135Mb and not working, how can I change the bp of the phone? is dangerorus? i will wait your answer marcolnx.
Miroschnik
сообщение 5.1.2010, 20:53
Приехал из командировки, поменял симку и понеслось! Назад переставлять симки пробовал, результат не меняется. Поставил тел на зарядку, завтра буду шить. Посмотрим.....
diodoman
сообщение 5.1.2010, 22:59
marcolnx i have a question, do you know how i can use a 4Gb sdhc in qtopia i try it and i cant use it and cant connect to the computer.
marcolnx
сообщение 5.1.2010, 23:04
Hi diodoman,
You don't make primary partition. your image (with mobile) show extended.
And why ext3? For example I maked so for my 4gb sdhc.
But if you wish ext2 or ext3 or fat32 not problem.
(6.1.2010, 0:12):
I don't know R541L7_G_11.00.16R, my a1200e keep 13R BP (if you wish I can post the link).
Novin for example in motorolafans posted a full firmware (so also BP) writing for all ming (when I tested I removed BP).
Flash BP maybe dangerous (it's not my ming).
Maybe Silent_Bob or SergGG or ... can help
For worldclock you can make some try with other lib (libezxworldcity.so.1.0.0)
Сообщение отредактировал marcolnx - 5.1.2010, 23:33
diodoman
сообщение 6.1.2010, 6:13
i try another lib but now say libezxworldcity.so.1 is wrong, and i not have this, in other fw ther are only simbolinc links.
marcolnx
сообщение 6.1.2010, 8:36
diodoman,
I attach original libezxworldcity.so.1.0.0 and worldclock of R541L7_G_11.00.16R (keep the same size, I don't know if this will solve your problem). Only remove .zip extension.
So place inside your SD (/mmc/mmca1) and with telnet or ekonsole:
rw (enter)
cp /mmc/mmca1/worldclock /usr/SYSqtapp/worldclock/ (enter)
cp /mmc/mmca1/libezxworldcity.so.1.0.0 /usr/lib/ezx/lib/ (enter)
reboot
Check if works
p.s.: ask Silent_Bob for change BP (Silent_Bob firmware it's full firmware and I think you can flash).
Have you solved partition? With fdisk you can also edit, ecc.
Прикрепленный файл worldclock.zip   ( 113.55 килобайт ) Кол-во скачиваний: 154
Прикрепленный файл libezxworldcity.so.1.0.0.zip   ( 89.45 килобайт ) Кол-во скачиваний: 156
Garm
сообщение 6.1.2010, 10:45
Из: Морозовск
Пользователь №: 48 276
Прошивка: Black Ming 3b
/usr/SYSjava/kvm -launch Midlet20XXX (где XXX - номер мидлета)
Если не перепутал регистр...
Miroschnik
сообщение 6.1.2010, 17:44
Спасибо!
Прошил и все встало на свои места.
Дело в том что щУпальцАми я не ни где ни чего не делал, а оно (оперы-мини) слетело, почему?
Сообщение отредактировал Miroschnik - 6.1.2010, 17:45
diodoman
сообщение 6.1.2010, 21:50
it dont work sad.gif, marcolnx how can i connect ming to qtopia desktop using latest FW with sdhc support, and how i need to format the sdhc.
marcolnx
сообщение 6.1.2010, 22:08
For format your sdhc you can use gparted or fdisk.
You can make 3 primary partitions:
fat16 1,9gb
ext3 or fat32 2gb
100mb swap
You can consider flash your BP.
Have you asked Silent_Bob?
I wish solve your problem.
diodoman
сообщение 6.1.2010, 22:13
i send a message to silent_bob but no response, i wat to try qtopia-ezx but i have a 4gb SDHC and dont work in qtopia, and i cant comunnicate to PC.
I try blackmingII but rsd say fail at 95%.
Сообщение отредактировал diodoman - 6.1.2010, 22:15
Zetko
сообщение 7.1.2010, 16:12
Из: Царевококшайск
Пользователь №: 153 554
Модель телефона: Defy
Прошивка: CM 10.2
Частично воплотил в жизнь мои пожелания с клавиатурами. В стандартной клавиатуре получилось выставить русский язык в начало (путем пересобирания файла /usr/data_resource/icon/iconres.ezx и правки файла по пути /usr/language/inputmethods/english_emea.kbd). Файлы прикладываю (убрать .txt в конце). А вот как поставить фингерпад по дефолту - пока не разобрался. Причем при поиске по справочнику и вводе в ЦИФРОВЫЕ поля - появляется именно фингерпад, а не клавиатура. Постараюсь это допилить или спросить у знающих людей.
Сообщение отредактировал Zetko - 7.1.2010, 16:51
Прикрепленный файл english_emea.kbd.txt   ( 1.7 килобайт ) Кол-во скачиваний: 89
Garm
сообщение 7.1.2010, 18:34
Из: Морозовск
В теме про фингерпад написано как это сделать...
Zetko
сообщение 7.1.2010, 18:41
Из: Царевококшайск
Прошивка: CM 10.2
Я видел способ от eug: подмена libezxappbase.so. Пробовал, после перезапуска windowsserver'a телефон вис наглухо (после бутлого). Еще есть варианты?
Сообщение отредактировал Zetko - 7.1.2010, 18:44
OFN
сообщение 7.1.2010, 19:49
Из: zp.ua
Пользователь №: 182 112
Модель телефона: XT 1585
Прошивка: 6.0
по поводу подмены эьтой либы как раз сейчас шла дискуссия в разделе "лаборатория скинов". эта либа очень капризная в плане совместимости
diodoman
сообщение 8.1.2010, 2:30
marcolnx i need your help, im usin qtopia but i cant connect to gprs to install software, do you know how can i acces to internet using my pc, like usblan, thanks in advance.
Finally i do it, thanks.
Сообщение отредактировал diodoman - 8.1.2010, 3:46
marcolnx
сообщение 8.1.2010, 6:25
diodoman,
under win MPT works fine.
Miroschnik
сообщение 8.1.2010, 8:47
Всем привет!
Screen3 уже вторую неделю не обновляется. Как его отключить? В настройках поле "Вкл" "Откл " не активно. Какие есть варианты?
OFN
сообщение 8.1.2010, 9:15
Из: zp.ua
Прошивка: 6.0
Цитата(Miroschnik @ 8.1.2010, 10:47) *
Всем привет!
а в стандартном таск-менеджере?
Зы: оно не "не активно", поле в "настройках", оно иногда здесь оно глючит
Garm
сообщение 8.1.2010, 10:08
Из: Морозовск
Цитата(marcolnx @ Сегодня, 9:25)
diodoman,
If I understand right, this question about Qtopia... MPT doesn't work with Qtopia.
Цитата(Miroschnik @ Сегодня, 11:47)
Всем привет!
У меня все активно...
marcolnx
сообщение 8.1.2010, 12:21
Sorry Garm,
I think I misunderstood the question.
qtopia on SD?
diodoman
сообщение 8.1.2010, 17:21
No Qtopia as FW complete, but is ok all is working now thanks.
OFN
сообщение 8.1.2010, 22:10
Из: zp.ua
Прошивка: 6.0
And it is ready bluetooth stack, java, camera?
diodoman
сообщение 8.1.2010, 22:51
well BT is ok, camera low resolution and java dont work, but is cool new os, i will use it and search for bugs, im using the 06/03/09 release with the sdhc patch, the last release dont have BT support i think. I hope i can help to the developers.
Zetko
сообщение 9.1.2010, 9:00
Из: Царевококшайск
Прошивка: CM 10.2
Цитата(Miroschnik @ 8.1.2010, 11:47) *
Всем привет!
Чтобы отключить, попробуй сделать так, как написано в топике SergGG Black diamond R541G-11.52.14R...:
Цитата(SergGG @ 16.6.2009, 23:19) *
Правим \ezx_user\download\appwrite\setup\ezx_idle.cfg в строке dinamicIdle = и \ezx_user\download\appwrite\setup\ezx_screen3.cfg в строке s3DefaultMode = и там и там меняем 1 на 0
marcolnx
сообщение 9.1.2010, 11:35
Hi,
I wanted to ask if you have tried the kernel SDHC.
I tried with 1gb 2gb SD and SDHC 4gb 8gb.
All are recognized.
diodoman
сообщение 10.1.2010, 1:37
yes i try sdhc kernel and it work for my 4gb sdhc.
traubenbah
сообщение 10.1.2010, 8:57
Пользователь №: 91 264
Модель телефона: а1200е_MING
Прошивка: Antarex MOD 14R
По русски можно? smile.gif В синем скине верхние софткнопки рабочего стола чёрные от чёрно-красного скина- так задумано или мой глюк(хотя прошилось нормально). С закрытым флипом в меню пункт контакты как contaсts- по русски никак?А так в целом понравилось thumbsup.gif
paradisV
сообщение 10.1.2010, 10:31
Пользователь №: 207 508
Модель телефона: motorola a1200e
Прошивка: White_diamond
я обычный пользователь,так что не обессудьте за вопрос:что измениться если я пропишу в консоли ro или rw?
OFN
сообщение 10.1.2010, 10:38
Из: zp.ua
Прошивка: 6.0
так у всех. верхние софт кнопки при нажатии красно-черные и в синем скине тоже
Добавлено позже (10.1.2010, 12:47):
когда ты командуешь в консоли rw ты тем самым меняешь права всему корню, Т .е - всей файловой системе телефона и делаешь ее доступной для записи. То есть ты можешь вносить любые изменения в ФС, как на любом компе.
Во всех прошивках кроме этой и ее прототипа (U3 и White Ming) ФС телефона защищена от записи, кроме Home ( ezxlocal и ezx_uaser), потому что упакована в формат cramfs, который - "только для чтения".
SergGG
сообщение 10.1.2010, 11:06
Мингофан
Из: Дніпро
Пользователь №: 85 418
Модель телефона: Droid Turbo
Прошивка: 6.0
Капітан Збройних сил України
В теме скинов выложен исправленый синий, где этот баг пофикшен.
Вот он
Сообщение отредактировал SergGG - 10.1.2010, 11:10
Garm
сообщение 10.1.2010, 11:57
Из: Морозовск
У меня перестал работать Soft Manager. Говорит "Segmentation fault"
strace ао вложении
Помогите разобраться...
Сообщение отредактировал Garm - 10.1.2010, 11:58
OFN
сообщение 10.1.2010, 13:00
Из: zp.ua
Прошивка: 6.0
strace ао вложении
а после чего он перестал работать?( у меня он так и не заработал на этой прошивке, ни разу ни на одной из версий,я уже без него и привык smile.gif как то , поэтому мне удивительно. что он здесь вообще у кого то работал)
traubenbah
сообщение 10.1.2010, 14:20
Вот он
Спасибо- есть у меня хайнань smile.gif Обращался к авторам темы дабы пофиксили в самом моде cool.gif
OFN
сообщение 10.1.2010, 16:31
Из: zp.ua
Прошивка: 6.0
Добавлено позже (10.1.2010, 19:10):
Только что разобрал синий скин от SergGG, извлек оттуда те иконки , которые отвечают за то, чтобы кнопки на верхней панели пр нажатии были черно синими, добавил их к икноресу от default3 ( синего скина из стандартного трехцветного набора ), и упаковал в иконрес ( в стандартном варианте єтого "єффекта посинения верхних кнопок" в синем скине изначально предусмотрено не было, и в стандартніх набдорах его и нет, когда SergGG выкладывал этот скин отделдьно, он это туда добаавил. кто пользуется- не забывает ставить плюсик SergGG
Иконрес выкладываю ( распаковать, эт о действительно RAR).
Почему этоого "эффекта посинения верхних софт кнопок при нажати " в синем скине не было предусмотрено изначально?
Цена вопроса:
- без эффекта посинения кнопок панели глобальной навигации иконрес от синего скина ( по пути /usr/data_resource/skin/default3) весиТ 16Кб ,
- с ДОБАВЛЕННЫМ эффектом посинения верхних кнопок при нажатии он весит уже 219 Кб
Зы: не увидел сразу реплику "по русски можно?" Можно, разработчик прошивки и автор темы Marcolnx - итальянец, и по русски он не понимает вообще.
Сообщение отредактировал OFN - 10.1.2010, 17:18
Garm
сообщение 10.1.2010, 18:02
Из: Морозовск
Цитата(OFN @ Сегодня, 16:00)
а после чего он перестал работать?( у меня он так и не заработал на этой прошивке, ни разу ни на одной из версий,я уже без него и привык как то , поэтому мне удивительно. что он здесь вообще у кого то работал)
После чего я так и не понял. Но он работал.
Я не представляю без него работу...
marcolnx
сообщение 10.1.2010, 18:16
Hi OFN,
thanks for your work.
I can not translate well, there are problems?
Skins,...?
I am now trying soundmanager 14R.
OFN
сообщение 10.1.2010, 19:00
Из: zp.ua
Прошивка: 6.0
Цитата(marcolnx @ 10.1.2010, 20:16) *
Hi OFN,
Skins,...?
Hi,Marco!
user made a remark to me about the fact that in our selection of skins with blue skin when you press the button global navigation, they do not become black and blue, and black and red. I explained to him, this is not our bug, this collection of skins and conceived: iconres blue skin in default3 greatly reduced.
For the user, and other similar I redid iconres from blue skin for default3, icons added there needed to ensure that when you press the button of the global navigation of their color changed to blue (at the time of this trouble SergGG). But I warned you. that by adding icons iсonres default 3 increased in volume over this and 10 times, instead of 16 kb it now occupies 219 Kb ...smile.gif
Ps: And why did you have to put saundmanager of 14 r? you think he is better? Silent Bob argues that saundmanager from 11R better. At least, he praised the оne in the latest Epinter's firmware
Сообщение отредактировал OFN - 10.1.2010, 20:41
Linux Ming (jffs2 11R - firmware), Прошивка с rw на базе 11R. Версия от 16.12.2009 · Motorola ROKR E6, E6e, E6tv, MING A1200, A1200i, A1200e, A1200r, A1200w, A1600 · Forum
Текстовая версия Сейчас: 22.7.2025, 4:18
