20 страниц V « < 12 13 14 15 > »
Linux Ming (jffs2 11R - firmware), Прошивка с rw на базе 11R. Версия от 16.12.2009
marcolnx
сообщение 12.11.2009, 17:31 Закрепленное сообщение!
Пользователь №: 201 733
JFFS2 11R (a1200e e a1200r)
English description is under spoiler
First: I wanted to thank tmp_do and tmr for creating a jffs2 firmware (and therefore the possibility of writing the whole system).
Second: I wanted to thank SergGG Provodnik Silent Bob dvrts and all Motofan ru users for sharing informations and help.
Starting from whiteMING2 of tmp_do (thanks to his help and his answers) I have modified and customized the firmware:
- Replaced all libraries SYStapi SYSqtapp SYSjava SYSdb etc. (11R)
- Flip closed options
- Inserted and placed some missing applications or not fully working (BCR - Sync - Standard Viewer - Photo Editor)
- Added binaries (ldd - showQ - ezxpopup - etc.), so bash3 busybox strace ...
- Added ringtones, pictures, skin, mystuff, etc.
- Radio works without headset
- Calendar in the main screen shows the first appointment in 24 hours
- 2 new skins (red and white)
- Pre-installed applications: ekonsole, Assistant of Amin (reboot, pkg installer, screenshot, swap manager, hacker, mystuff, unrar unzip, ecc.), Skin Installer, Backup Restore Now, SysInfo, ZEditor (can see hidden folder and edit hidden files), PicselEdit (there is also the standard)
- 2 java applications: platinumsudoku - ICQ Jimm
- Language: English - Russian - Ukrainian (VR English - Russian)
- Fixed all profile (Silent, Vibrate, ecc.)
- ext2 ext3 support with modules.dep
- Screen3 works
- Support autorun.txt under SD (/mmc/mmca1/)
- Fingerpad white and foxalarm (voice russian)
- added Processor (underclock and overclock at 520)
- added pictures
- added skin blue (Sens theme)
- added, replaced for Camera_R541L7_G_11.10.11R
- added, replaced for libezxmime.so.1.0.0 thanks a lot Silent Bob
- added pftpd (pure-ftpd and pure-ftpwho) thanks a lot fordalulz
- added, replaced ro rw
- added new init script (so also startup1.txt, startup.txt for SD and startup2.txt for phone) and a lot of stuff for mount --bind sounds, animation, volume, font, ecc. without write directly for new user)
p.s.: I have attached folder MCleaner and MotoID, extract and install if you want.
Generally if something does not like (you can write in the whole) you can edit yourself.
Hopefully you'll try it and have fun.
Link:
Link for download
About swap:
If we need 32mb swap just extract the folder .bin from here and put in the root of SD:
http://www.4shared.com/file/84649109/509f6517/Swap_SD.html
You can easy activate - deactivate with Assistant and check with SysInfo or eKonsole
Прикрепленное изображениеПрикрепленное изображение Прикрепленное изображениеПрикрепленное изображение
Перевод на русский dvrts
Прежде всего хотелось бы поблагодарить tmp_do и tmr за создание прошивок на базе jffs2 (и как следствие, возможность модифицирования всей ФС телефона без перепрошивки (read-write:)
Также хотелось бы поблагодарить SergGG, Provodnik, Silent Bob, dvrts и всех пользователей motofan.ru за информацию и помощь
По сравнению с WhiteMING2 (автор tmp_do) прошивка изменена, улучшена и дополнена:
- Заменены все библиотеки SYStapi SYSqtapp SYSjava SYSdb т.д. (11R)
- Расширенное меню при закрытом флипе
- Добавлена и изменены некоторые приложения, отсутствующие или некорректно работающие ( BCR - Синхронизация - Стандартный Viewer - Photo Editor)
- Добавлены бинарники (ldd - showQ - ezxpopup - и т.д.), so, bash3, BusyBox, strace ...
- Добавлены рингтоны, картинки, скины, изменен mystuff и т.д.
- Радио работает без гарнитуры
- Календарь на главном экране отображает первое задание в 24 часа
- 2 скина (красный и белый)
- Предустановленные приложения: ekonsole, Amin Assistant (перезагрузка, установщик pkg, swap, javahacker, mystuff, распаковщики архивов, и т.д.), Skin Installer, Backup Restore, SysInfo, ZEditor (можно увидеть скрытые папки и править скрытые файлы), PicselEdit (есть стандартный)
- Язык: английский - русский - украинский (VR английский - русский)
- Исправлены все звуковые профили (бесшумный, вибро, и т.д.)
- Screen3 работает
- Поддержка autorun.txt (/mmc/mmca1/autorun.txt)
- Фингерпад с кириллицей
- Foxalarm взамен стандартного будульника
- Куча мелких изменений
- Добавлено приложение для разгона процессора (до 520 MHz)
- Добавлены изображения
- Синий скин (Sens)
- Бинарники для камеры от _R541L7_G_11.10.11R
- Изменен libezxmime.so.1.0.0
- Добавлено приложение для ftp
- Изменены бинарники для ro rw
- Дополнен авторан (startup1.txt, startup.txt для карты памяти и startup2.txt для памяти телефона) и дополнительные папки для mount --bind (звуки, анимация, volumetable, шрифты, и т.д. без необходимости переходить в read-write ФС)
Ссылка
Для установки свапа - скачать файл и положить в корень карты памяти
Для изменения режимов ro - rw - в консоли выполнить
CODE
rw
CODE
ro
Сообщение отредактировал marcolnx - 10.1.2010, 9:33
Прикрепленный файл Howto_jffs2_new_firmware_save_data.txt   ( 1.17 килобайт ) Кол-во скачиваний: 948
Прикрепленный файл MCleaner_MotoID.zip   ( 337.61 килобайт ) Кол-во скачиваний: 666
Прикрепленный файл jffs2_kernel_sdhc.zip   ( 3.91 мегабайт ) Кол-во скачиваний: 1308
paradisV
сообщение 10.1.2010, 10:31
Пользователь №: 207 508
Модель телефона: motorola a1200e
Прошивка: White_diamond
я обычный пользователь,так что не обессудьте за вопрос:что измениться если я пропишу в консоли ro или rw?
OFN
сообщение 10.1.2010, 10:38
Из: zp.ua
Пользователь №: 182 112
Модель телефона: XT 1585
Прошивка: 6.0
Цитата(traubenbah @ 10.1.2010, 10:57) *
По русски можно? smile.gif В синем скине верхние софткнопки рабочего стола чёрные от чёрно-красного скина- так задумано или мой глюк(хотя прошилось нормально).
так у всех. верхние софт кнопки при нажатии красно-черные и в синем скине тоже
Добавлено позже (10.1.2010, 12:47):
когда ты командуешь в консоли rw ты тем самым меняешь права всему корню, Т .е - всей файловой системе телефона и делаешь ее доступной для записи. То есть ты можешь вносить любые изменения в ФС, как на любом компе.
Во всех прошивках кроме этой и ее прототипа (U3 и White Ming) ФС телефона защищена от записи, кроме Home ( ezxlocal и ezx_uaser), потому что упакована в формат cramfs, который - "только для чтения".
SergGG
сообщение 10.1.2010, 11:06
Мингофан
Из: Дніпро
Пользователь №: 85 418
Модель телефона: Droid Turbo
Прошивка: 6.0
Капітан Збройних сил України
В теме скинов выложен исправленый синий, где этот баг пофикшен.
Вот он
Сообщение отредактировал SergGG - 10.1.2010, 11:10
Garm
сообщение 10.1.2010, 11:57
Из: Морозовск
Пользователь №: 48 276
Прошивка: Black Ming 3b
У меня перестал работать Soft Manager. Говорит "Segmentation fault"
strace ао вложении
Помогите разобраться...
Сообщение отредактировал Garm - 10.1.2010, 11:58
OFN
сообщение 10.1.2010, 13:00
Из: zp.ua
Прошивка: 6.0
strace ао вложении
а после чего он перестал работать?( у меня он так и не заработал на этой прошивке, ни разу ни на одной из версий,я уже без него и привык smile.gif как то , поэтому мне удивительно. что он здесь вообще у кого то работал)
traubenbah
сообщение 10.1.2010, 14:20
Пользователь №: 91 264
Модель телефона: а1200е_MING
Прошивка: Antarex MOD 14R
Вот он
Спасибо- есть у меня хайнань smile.gif Обращался к авторам темы дабы пофиксили в самом моде cool.gif
OFN
сообщение 10.1.2010, 16:31
Из: zp.ua
Прошивка: 6.0
Добавлено позже (10.1.2010, 19:10):
Только что разобрал синий скин от SergGG, извлек оттуда те иконки , которые отвечают за то, чтобы кнопки на верхней панели пр нажатии были черно синими, добавил их к икноресу от default3 ( синего скина из стандартного трехцветного набора ), и упаковал в иконрес ( в стандартном варианте єтого "єффекта посинения верхних кнопок" в синем скине изначально предусмотрено не было, и в стандартніх набдорах его и нет, когда SergGG выкладывал этот скин отделдьно, он это туда добаавил. кто пользуется- не забывает ставить плюсик SergGG
Иконрес выкладываю ( распаковать, эт о действительно RAR).
Почему этоого "эффекта посинения верхних софт кнопок при нажати " в синем скине не было предусмотрено изначально?
Цена вопроса:
- без эффекта посинения кнопок панели глобальной навигации иконрес от синего скина ( по пути /usr/data_resource/skin/default3) весиТ 16Кб ,
- с ДОБАВЛЕННЫМ эффектом посинения верхних кнопок при нажатии он весит уже 219 Кб
Зы: не увидел сразу реплику "по русски можно?" Можно, разработчик прошивки и автор темы Marcolnx - итальянец, и по русски он не понимает вообще.
Сообщение отредактировал OFN - 10.1.2010, 17:18
Garm
сообщение 10.1.2010, 18:02
Из: Морозовск
Цитата(OFN @ Сегодня, 16:00)
а после чего он перестал работать?( у меня он так и не заработал на этой прошивке, ни разу ни на одной из версий,я уже без него и привык как то , поэтому мне удивительно. что он здесь вообще у кого то работал)
После чего я так и не понял. Но он работал.
Я не представляю без него работу...
marcolnx
сообщение 10.1.2010, 18:16
Hi OFN,
thanks for your work.
I can not translate well, there are problems?
Skins,...?
I am now trying soundmanager 14R.
OFN
сообщение 10.1.2010, 19:00
Из: zp.ua
Прошивка: 6.0
Цитата(marcolnx @ 10.1.2010, 20:16) *
Hi OFN,
Skins,...?
Hi,Marco!
user made a remark to me about the fact that in our selection of skins with blue skin when you press the button global navigation, they do not become black and blue, and black and red. I explained to him, this is not our bug, this collection of skins and conceived: iconres blue skin in default3 greatly reduced.
For the user, and other similar I redid iconres from blue skin for default3, icons added there needed to ensure that when you press the button of the global navigation of their color changed to blue (at the time of this trouble SergGG). But I warned you. that by adding icons iсonres default 3 increased in volume over this and 10 times, instead of 16 kb it now occupies 219 Kb ...smile.gif
Ps: And why did you have to put saundmanager of 14 r? you think he is better? Silent Bob argues that saundmanager from 11R better. At least, he praised the оne in the latest Epinter's firmware
Сообщение отредактировал OFN - 10.1.2010, 20:41
diodoman
сообщение 10.1.2010, 19:28
Пользователь №: 211 991
Модель телефона: ming A1200E
I was trying to flas full FW but always say Fail at 95%, i dont know why.
marcolnx
сообщение 11.1.2010, 12:28
Hi OFN,
I'm testing soundmanager from 14R because this was inside original tmp_do whiteming1.
(but I think it's similar...)
Hi diodoman,
95% fail. With error?
I flashed several times (a1200e and a1200i-C2tracks) always without error.
Сообщение отредактировал marcolnx - 11.1.2010, 12:29
traubenbah
сообщение 11.1.2010, 16:32
Ещё сегодня всплыла неприятная фича, но я склонен что это у меня так: если редактировать контакты из телефона(изменять/удалять) то через некоторое время в процессе редактирования телефон просто перестаёт видеть контакты-проверяю ёмкость- ноль контактов и свободная симка(хотя частично занята). Пмогает перезагруз. Проделал несколько раз с одинаковым результатом- пропадание контактов и появление после перезагруза stink.gif
diodoman
сообщение 11.1.2010, 19:45
Only say error with full FW BP and AP, and 1 time say (in the phone) USB BP bypass mode.
marcolnx
сообщение 12.1.2010, 6:26
diodoman,
I do not understand.
Have you successfully changed BP?
This firmware it's only AP.
Your problem with this firmware, or in general when you do the flash?
diodoman
сообщение 12.1.2010, 19:01
with other firmwares, not with this one, with full AP BP Firmwares say error at 95%.
marcolnx
сообщение 12.1.2010, 20:58
diodoman,
I'm sorry but I do not understand why.
However the firmware it's AP.
At all,
I do not use VR and I have removed the Russian language in my version.
Can you please check if it works with VR Russian with flip closed and also command lists, adding ezx_system.cfg (/usr/setup/ and /ezx_user/download/appwrite/setup/):Inside [SYS_SYSTEM_SET]
VREnableFlipClosedLaunch = 1
VRShowCommandList = 1
I tested in VR english and works also showing Command Liist.Thanks smile.gif
Not working for VR russian (sorry)
Сообщение отредактировал marcolnx - 13.1.2010, 8:16
OFN
сообщение 12.1.2010, 23:19
Из: zp.ua
Прошивка: 6.0
на этой прошивке этот и некотрые другие аналогичные фичи иногда имеют место, когда в момент совершения подобных действий ФС телефона rw
Проверь: у тебя ro пашет?
Сообщение отредактировал OFN - 12.1.2010, 23:24
Garm
сообщение 14.1.2010, 6:41
Из: Морозовск
OFN, я починил Soft Manager.
В *.desktop файле вместо "Exec=softman.lin" прописал "Exec=SoftManage" и переустановил программу с этим файлом. Все заработало...
Сообщение отредактировал Garm - 14.1.2010, 6:41
severny
сообщение 14.1.2010, 9:50
Пользователь №: 211 004
Модель телефона: Zine,Ming
Прошивка: Z-mod,Antarex
Мой моторола твой яблоко труба шатал
Пытаюсь с этой прошивки перейти на вариант от Сайлент Боба, вот такая картина
Всё по мануалу из закрепленной темы
Какая должна быть последовательность действий?
OFN
сообщение 14.1.2010, 11:14
Из: zp.ua
Прошивка: 6.0
По картинке получается, что телефон не опознан программой.
шаг первый: обнови и переставь дрова
severny
сообщение 14.1.2010, 19:34
RSD телефон находит.
События развиваются так:
Сам RSD в флэш-мод не переводит.
Когда перевожу вручную-тот же результат.
FlashErrorLog
07:46:40,  January 14, 2010
Line: 891
ERROR: The file selected is an invalid superfile.
Please enter in a valid superfile.
File: Z:\test_dev_usb\flash\code\flashdll\PST_FP_FlashFileIO.cpp
Эй, эверебади, кто-нибудь с этой прошивки на другую переходил? Поделитесь опытом, будьте добры smile.gif
P.S. Опля, на Silent_Bob's FW 2.0.sbf перешёл. Че меня встретил лозунгами на испанском smile.gif Viva el nuevo software!
Сообщение отредактировал severny - 14.1.2010, 20:46
traubenbah
сообщение 18.1.2010, 7:02
Возвращаясь на Antarex также столкнулся с тем что RSD не переводит тел во флеш: перевел вручную.Прошился вроде нормально.
marcolnx
сообщение 18.1.2010, 21:55
Sorry I cannot well translate.
For me flash and go back (if you wish) working perfect (the same for standard and sdhc kernel).
diodoman
сообщение 18.1.2010, 21:58
Marcolnx i dont know why but your FW latin version dont have the worldclock problem.
Silent_Bob i have a question, there is a english version of Ope working?
Сообщение отредактировал diodoman - 18.1.2010, 22:03
Silent_Bob
сообщение 19.1.2010, 1:00
Городской партизан
Пользователь №: 162 603
Прошивка: Готичная
Just change language:
1) Enter the settings Изображение
2) Change languauge Изображение
diodoman
сообщение 19.1.2010, 2:21
Thank you Silent_Bob. i Will tryit soon im flashing the 2.6.30 based FW. I know is only test but i want to look.
OFN
сообщение 20.1.2010, 9:31
Из: zp.ua
Прошивка: 6.0
сегодня поймал глюк: после хардресета перестал запускаться скрин3 и исчезли все контакты из телефонной книги, даже из раздела "сим-карта"
что это было?
Silent_Bob
сообщение 20.1.2010, 14:54
Городской партизан
Прошивка: Готичная
Это JFFS2 ...
OFN
сообщение 20.1.2010, 15:08
Из: zp.ua
Прошивка: 6.0
Цитата(Silent_Bob @ 20.1.2010, 16:54) *
Это JFFS2 ...
зва счет чего это здесь?
Silent_Bob
сообщение 20.1.2010, 15:18
Городской партизан
Прошивка: Готичная
Да на всех прошах, построенных по данному принципу есть подобные глюки (лично у меня на вайтминге неоднократно пропадали все приложения из меню, даже SMS и список контактов с верхних кнопок переставали запускаться) ...
Garm
сообщение 20.1.2010, 17:38
Из: Морозовск
У меня в очередной раз перестал запускаться Soft Manager.
Третий способ запуска - двойной клик по softman.lin в File Explorer и выбрать "Run"
OFN
сообщение 20.1.2010, 18:42
Из: zp.ua
Прошивка: 6.0
у меня сегодня так сисинфо висело, пока я в файлэксплорере сответствующий sh не пнул напрямую
marcolnx
сообщение 20.1.2010, 20:12
After 2 month all ok for me (no bug)
Don't make master reset or master clear
Look in the script and you will see why.
I never used also in standard firmware (useless).
These scripts will delete /ezxlocal
This firmware it's different so don't run.
Сообщение отредактировал marcolnx - 20.1.2010, 20:13
Каплан
сообщение 21.1.2010, 19:05
БлиZZнеЦ
Из: Краснодар- Горячий Ключ
Пользователь №: 112 256
So, after almost the one year using Bobs 16R v1.75, I flashing this FW. I'll try. I think new version of KDE4 skin will be fine :)
Добавлено позже (21.1.2010, 23:05):
Eroor. Faild:(
Добавлено позже (21.1.2010, 23:08):
Trying again
marcolnx
сообщение 21.1.2010, 19:16
Hi smile.gif thanks for testing.
error rsd 3.8?
Каплан
сообщение 21.1.2010, 19:36
БлиZZнеЦ
I did it. it' flashed.
ferst view/ i like standart wallpapers. some of them will look good with new skin:)
Menu tree. i like more standart.
i want standart russian keyboard, not that, that is with qwerty on falg.:(
i can't open ZEditior from task manager after Red button :(
Добавлено позже (22.1.2010, 0:00):
marcolnx,
no, i used rsd 4.4.1
hmm... menu with closed flip is not like on 16r( there is no bluetooth menu.:(
Добавлено позже (22.1.2010, 0:03):
o, sorry. here it is. my antenna was offed:)
Добавлено позже (22.1.2010, 2:03):
Hm...
i can't change start up sound in phone. :(
i chaynged it. i think their was no free space:)
and i can't chenge alert stuyles on my oune. I made them fo bobs 1.75 fw. In settings there are standart settings wryted, but if i editing on phone alert style, there are my settings with my sounds :(
also i tryed to put application Help (from gizmoto) in phone, i wryted it in menu tree. in sysregisrty, but i don't see it in menu. :( i don't use it, but i want to have it:)
Сообщение отредактировал Каплан - 21.1.2010, 22:42
marcolnx
сообщение 22.1.2010, 12:15
1- for keyboard you can try make new keyboard (for iTap you can copy russian for english)
2- can you explain for ZEditor the problem?
3-for change sound you can also make a folder MY_FAVOR inside the "phone" and place your fonts,animations..., please open ezx_boot.cfg(animations,sounds,fonts,ecc.). For free space after rw command check with df -ah, but you can always make symbolik link if free space problem.
4- if you need add preload application you need edit also UserMenuTree (please download and read in thread attachment OFN_add_apps.zip), don't edit directly but before copy inside you PC, edit, copy inside SD and replace.
Please let me know if problem.
Thanks
Garm
сообщение 22.1.2010, 13:55
Из: Морозовск
If Zeditor is minimized it can't be restored by Task Manager. This bug in app "Notepad" too
OFN
сообщение 22.1.2010, 14:22
Из: zp.ua
Прошивка: 6.0
Цитата(marcolnx @ 22.1.2010, 14:15) *
4- if you need add preload application you need edit also UserMenuTree don't edit directly but before copy inside you PC, edit, copy inside SD and replace.
Hi Marco,
that is directly to the phone UserMenuTree can not edit it?
Linux Ming (jffs2 11R - firmware), Прошивка с rw на базе 11R. Версия от 16.12.2009 · Motorola ROKR E6, E6e, E6tv, MING A1200, A1200i, A1200e, A1200r, A1200w, A1600 · Forum
Текстовая версия Сейчас: 29.7.2025, 21:10
