20 страниц V « < 16 17 18 19 > »
Linux Ming (jffs2 11R - firmware), Прошивка с rw на базе 11R. Версия от 16.12.2009
marcolnx
сообщение 12.11.2009, 17:31 Закрепленное сообщение!
Пользователь №: 201 733
JFFS2 11R (a1200e e a1200r)
English description is under spoiler
First: I wanted to thank tmp_do and tmr for creating a jffs2 firmware (and therefore the possibility of writing the whole system).
Second: I wanted to thank SergGG Provodnik Silent Bob dvrts and all Motofan ru users for sharing informations and help.
Starting from whiteMING2 of tmp_do (thanks to his help and his answers) I have modified and customized the firmware:
- Replaced all libraries SYStapi SYSqtapp SYSjava SYSdb etc. (11R)
- Flip closed options
- Inserted and placed some missing applications or not fully working (BCR - Sync - Standard Viewer - Photo Editor)
- Added binaries (ldd - showQ - ezxpopup - etc.), so bash3 busybox strace ...
- Added ringtones, pictures, skin, mystuff, etc.
- Radio works without headset
- Calendar in the main screen shows the first appointment in 24 hours
- 2 new skins (red and white)
- Pre-installed applications: ekonsole, Assistant of Amin (reboot, pkg installer, screenshot, swap manager, hacker, mystuff, unrar unzip, ecc.), Skin Installer, Backup Restore Now, SysInfo, ZEditor (can see hidden folder and edit hidden files), PicselEdit (there is also the standard)
- 2 java applications: platinumsudoku - ICQ Jimm
- Language: English - Russian - Ukrainian (VR English - Russian)
- Fixed all profile (Silent, Vibrate, ecc.)
- ext2 ext3 support with modules.dep
- Screen3 works
- Support autorun.txt under SD (/mmc/mmca1/)
- Fingerpad white and foxalarm (voice russian)
- added Processor (underclock and overclock at 520)
- added pictures
- added skin blue (Sens theme)
- added, replaced for Camera_R541L7_G_11.10.11R
- added, replaced for libezxmime.so.1.0.0 thanks a lot Silent Bob
- added pftpd (pure-ftpd and pure-ftpwho) thanks a lot fordalulz
- added, replaced ro rw
- added new init script (so also startup1.txt, startup.txt for SD and startup2.txt for phone) and a lot of stuff for mount --bind sounds, animation, volume, font, ecc. without write directly for new user)
p.s.: I have attached folder MCleaner and MotoID, extract and install if you want.
Generally if something does not like (you can write in the whole) you can edit yourself.
Hopefully you'll try it and have fun.
Link:
Link for download
About swap:
If we need 32mb swap just extract the folder .bin from here and put in the root of SD:
http://www.4shared.com/file/84649109/509f6517/Swap_SD.html
You can easy activate - deactivate with Assistant and check with SysInfo or eKonsole
Прикрепленное изображениеПрикрепленное изображение Прикрепленное изображениеПрикрепленное изображение
Перевод на русский dvrts
Прежде всего хотелось бы поблагодарить tmp_do и tmr за создание прошивок на базе jffs2 (и как следствие, возможность модифицирования всей ФС телефона без перепрошивки (read-write:)
Также хотелось бы поблагодарить SergGG, Provodnik, Silent Bob, dvrts и всех пользователей motofan.ru за информацию и помощь
По сравнению с WhiteMING2 (автор tmp_do) прошивка изменена, улучшена и дополнена:
- Заменены все библиотеки SYStapi SYSqtapp SYSjava SYSdb т.д. (11R)
- Расширенное меню при закрытом флипе
- Добавлена и изменены некоторые приложения, отсутствующие или некорректно работающие ( BCR - Синхронизация - Стандартный Viewer - Photo Editor)
- Добавлены бинарники (ldd - showQ - ezxpopup - и т.д.), so, bash3, BusyBox, strace ...
- Добавлены рингтоны, картинки, скины, изменен mystuff и т.д.
- Радио работает без гарнитуры
- Календарь на главном экране отображает первое задание в 24 часа
- 2 скина (красный и белый)
- Предустановленные приложения: ekonsole, Amin Assistant (перезагрузка, установщик pkg, swap, javahacker, mystuff, распаковщики архивов, и т.д.), Skin Installer, Backup Restore, SysInfo, ZEditor (можно увидеть скрытые папки и править скрытые файлы), PicselEdit (есть стандартный)
- Язык: английский - русский - украинский (VR английский - русский)
- Исправлены все звуковые профили (бесшумный, вибро, и т.д.)
- Screen3 работает
- Поддержка autorun.txt (/mmc/mmca1/autorun.txt)
- Фингерпад с кириллицей
- Foxalarm взамен стандартного будульника
- Куча мелких изменений
- Добавлено приложение для разгона процессора (до 520 MHz)
- Добавлены изображения
- Синий скин (Sens)
- Бинарники для камеры от _R541L7_G_11.10.11R
- Изменен libezxmime.so.1.0.0
- Добавлено приложение для ftp
- Изменены бинарники для ro rw
- Дополнен авторан (startup1.txt, startup.txt для карты памяти и startup2.txt для памяти телефона) и дополнительные папки для mount --bind (звуки, анимация, volumetable, шрифты, и т.д. без необходимости переходить в read-write ФС)
Ссылка
Для установки свапа - скачать файл и положить в корень карты памяти
Для изменения режимов ro - rw - в консоли выполнить
CODE
rw
CODE
ro
Сообщение отредактировал marcolnx - 10.1.2010, 9:33
Прикрепленный файл Howto_jffs2_new_firmware_save_data.txt   ( 1.17 килобайт ) Кол-во скачиваний: 948
Прикрепленный файл MCleaner_MotoID.zip   ( 337.61 килобайт ) Кол-во скачиваний: 666
Прикрепленный файл jffs2_kernel_sdhc.zip   ( 3.91 мегабайт ) Кол-во скачиваний: 1308
Garm
сообщение 30.3.2010, 16:36
Из: Морозовск
Пользователь №: 48 276
Прошивка: Black Ming 3b
Цитата(severny @ 16.3.2010, 22:24)
Реально. Уже существует Стабильная & функциональная 16R прошивка
А как вы это сделали? Я библиотеку от Black Ming II ставил, но отрубается определитель номеров...
Добавлено позже (30.3.2010, 19:43):
И почему MMS я не могу принять и отправить?
Why I can't to send and receive MMS?
Silent_Bob
сообщение 30.3.2010, 19:19
Городской партизан
Пользователь №: 162 603
Прошивка: Готичная
Несовместимость форматов баз данных ...
marcolnx
сообщение 30.3.2010, 19:29
Garm,
I can send and receive MMS
linuxoid200
сообщение 31.3.2010, 9:18
Из: Kiev
Пользователь №: 78 226
Модель телефона: a1200e, sgh i-200
Прошивка: jffs2 11R
i can send and receive MMS on this FW ! )))
Сообщение отредактировал linuxoid200 - 31.3.2010, 9:20
Patlatuj
сообщение 31.3.2010, 10:55
Пользователь №: 69 256
Модель телефона: A1200E
Прошивка: Linux Ming
Привет всем,
Скажите пожалуйста, нормально ли это, что аккум держит меньше одного дня при стандартном использовании(несколько звонков и СМС)?
С прошивкой Gizmoto La Verne моя батарея держала около 2-3 дней при таком же использовании...
Спасибо за ответ
Hi all,
Could you please tell me if it is okay that battery life is less than 1 day with standard usage(only few calls and few SMS)?
With Gizmoto La Verne FW my battery worked about 2-3 days with the same usage...
Thanks for the answer
marcolnx
сообщение 31.3.2010, 11:08
Hi,
battery life for me it's 2 days (also surfing a lot with operamini), so this is not normal.
p.s.: maybe I forget (I will update 1st post)
SDHC support:
You must flash jffs2_kernel_sdhc.sbf if you wish (tested with 4gb and 8gb).
(I use GParted for resize and make swap partition)
When you will insert your SDHC with ekonsole or telnet session:
fdisk /dev/mmca (enter)
p (enter)
t (enter) and select first partition
6 (enter)
w (enter)
reboot
Сообщение отредактировал marcolnx - 31.3.2010, 11:13
diodoman
сообщение 1.4.2010, 13:39
Пользователь №: 211 991
Модель телефона: ming A1200E
Marco i have 4gb sdhc (fat32-swap-ext3), what i need to do in the phone to mount 3rd partition in mystuff, there is only mmca1 and mmca2. Thanks.
Edit: Solved Thanks.
Сообщение отредактировал diodoman - 1.4.2010, 18:17
marcolnx
сообщение 1.4.2010, 19:33
diodomam,
happy you solved (autorun was in the clip - attachment). Only edit and make mmca2 folder under phone.
waiting your good news ...
dvrts
сообщение 23.4.2010, 2:00
Из: Lviv
Пользователь №: 162 099
So, what may you recommend for me for longer battery life. Only ampd rechanging?
OFN
сообщение 24.4.2010, 0:47
Из: zp.ua
Пользователь №: 182 112
Модель телефона: XT 1585
Прошивка: 6.0
Замена аpmd существенно удлиняет жизнь батарейки только в режиме ожидания.
При активном использовании плеера и веб серфинге прирост незаметен.
При активном использовании телефонной части - тоже.
Ps : сегодня пришлось перепрошиваться (снова на Linux Ming, н мне нравится)))
При отправке по email фото, сделанного нашей камерой, телефон мне дажды ответил: "Невозможно найти файл или каталог", а потом повис.
После хард ресета он включился и заработал, но исчезли дефолтный браузер и встроенная программа разгона процессора ( я заходил в usr/data_resource/preloadapps/QTapps - полностью исчезли их каталоги)
Просто исчезли.
А также исчез main.db.
Контакты восстановил с помощью бекапа, но заморачиваться с оперой и процессором не стал, перешился.
Сообщение отредактировал OFN - 24.4.2010, 0:55
marcolnx
сообщение 24.4.2010, 21:13
Hi OFN dvrts,
for me battery life it's 2-3 days.
and we cannot make more...
OFN, never make master reset... (look for sym links).
Never used (master reset and master clean. and I removed these scripts.
OFN
сообщение 25.4.2010, 2:16
Из: zp.ua
Прошивка: 6.0
Hi Marco,
And how did you do it?
Garm
сообщение 25.4.2010, 9:30
Из: Морозовск
Из /.backup/
На модифицированных прошивках вроде не работает стандартные мастер-сброс и мастер очистка. Поэтому на обычных прошивках в /.backup/ лежат master_clear.sh и master_reset.sh. На этой прошивке их нет
OFN
сообщение 25.4.2010, 12:48
Из: zp.ua
Прошивка: 6.0
Цитата(Garm @ 25.4.2010, 12:30) *
Из /.backup/
а этот глюк с исчезновением приложений после хард ресета , он откуда?
ИМХО, напомнает то, что произошло бы. если бы я выдернул флешку с неотмонтированным свап - разделом
Hoodys
сообщение 4.5.2010, 14:51
Из: Україна, Тернопіль
Пользователь №: 28 068
Модель телефона: Ming A1200e
Прошивка: JFFS2_11R_RU_UA
В целом прошивка супер, есть 2 вопроса новичка:
1) В телефонной книжке не работает поиск абонентов, раньше писал букву и с этой буквы начинались контакты. Час пишешь русскую или англ. букву, контакты как были с буквы «А» так и стоят. Или есть тонкая настройка о которой я не знаю?
2) У всех так, когда пишешь sms, не работает перенос слов, тоесть, если написать слово и оно не умещается в одном рядке, тел его разрывает на две части. Когда читаешь, также. Раньше слово переносилось в новом рядке. В настройках все нужные опции включены.
OFN
сообщение 4.5.2010, 17:52
Из: zp.ua
Прошивка: 6.0
поиск работает, он 1)регистрозависимый ( если контакты с большой буквы. набирай большую букву), 2) по дефолту искать будет в той категории. которая была открыта последней. если ты пользуешься категориями.
Хочешь юзать только поиск по буквам. держи открытой категорию "все"
velesiK
сообщение 5.5.2010, 9:13
Пользователь №: 185 761
Прошивка: jffs2 11R
а трудно добавить либы, как сделать сделать его, регистро не зависимым?
Silent_Bob
сообщение 5.5.2010, 11:46
Городской партизан
Прошивка: Готичная
libezxaddrbkeng.so.1.0.0
ps.gif Переводишь в RW и заменяешь (старую сохрани на всякий случай) ...
Добавлено позже (5.5.2010, 15:47):
Зеркало: http://slil.ru/29084994 ...
velesiK
сообщение 7.5.2010, 4:17
Прошивка: jffs2 11R
После замены либы, при звонке показываться номер, а не ФИО :(
Даже с номера внесенного в справочник по принятому ввызову
Сообщение отредактировал velesiK - 7.5.2010, 9:14
velesiK
сообщение 7.5.2010, 9:14
Прошивка: jffs2 11R
Проблема (при закрытом флипе время ИНОГДА не обновляеться) была давно но после того как на mcleaner поставил планировщик с временем 7-00 многие в 9-00 не дозваниваются, а в лог пишет что звонок был в 5-30 например (лечиться открытием флипа и время корректируется).
Silent_Bob
сообщение 7.5.2010, 12:22
Городской партизан
Прошивка: Готичная
Несовместимость баз данных (main.db) ...
Garm
сообщение 7.5.2010, 12:31
Из: Морозовск
Проходили - телефон при выключенной подсветке не обновляет экран (слип). При нажатии кнопки просто может не успеть обновить экран.
Однако, судя по твоему посту, время также не передается в другие программы... То есть демон часиков спит полностью...
velesiK
сообщение 11.5.2010, 4:55
Прошивка: jffs2 11R
А как сделать чтоб main.db стала совместимой, востановление контактов после записи это либы ничего не дало :(
Garm
сообщение 11.5.2010, 7:07
Из: Морозовск
Меня удивляет другое...
main.db у меня еще ч первой 14R_F6. Я его ставил и на прошивку SIlent_Bob'а и на Linux Ming. Везде все было нормально.
libezxaddrbkeng спокойно работает на прошивке от SIlent_Bob'а, а здесь вызывает глюк определителя. При том, что main.db используется и там и тут ОДИН И ТОТ ЖЕ.
Вопрос: Так что с чем несовместимо???
SergGG
сообщение 11.5.2010, 8:52
Мингофан
Из: Дніпро
Пользователь №: 85 418
Модель телефона: Droid Turbo
Прошивка: 6.0
Капітан Збройних сил України
У меня тоже на этих трех прошивках был один и тот же main.db от Ф6. Были небольшие проблемы на прошивке SIlent_Bob'а кажется 1.7 или 2.0 - какой-то из контактов "блокировался", то есть ни изменить ни удалить его не получалось. На Linux Ming я пробыл буквально несколько дней, за это время глюков с контактами не возникало.
velesiK
сообщение 12.5.2010, 4:31
Прошивка: jffs2 11R
После всех манипуляций перестал работать определить с обоями либами :(
velesiK
сообщение 12.5.2010, 10:23
Прошивка: jffs2 11R
Разница между main.DB действительно есть, та что создаеться при удалении не работает с отпеределением номеров, а вот взятая от Silent_Bob's FW 2.0 (beta) определяеться, но с "регистронезависимой" либой все равно не дружит :(
Книгу востанавливаю спомощью Backup Tools.
Сообщение отредактировал velesiK - 12.5.2010, 10:24
OFN
сообщение 13.5.2010, 22:29
Из: zp.ua
Прошивка: 6.0
Доброго!
Вчера вдруг взял и сам собой отмонтировался swap (примонтированный как блочное устройство).
А SysInfo стало видеть изменения использованной памяти флешки только после перезагрузки. А раньше видела сразу.
А все потому, что внезапно дематериализовался autorun.txt на флешке
без всяких видимых причин и без всякого моего вмешательства
Исчез
Сообщение отредактировал OFN - 15.5.2010, 0:45
OFN
сообщение 18.5.2010, 14:47
Из: zp.ua
Прошивка: 6.0
help!
перестал работать email клиент!
Настройки правильные.
При получении почты виснет , при попытке отправить хоть простое письмо, хоть письмо с вложением пишет: "Нет такого файла или каталога"
java приложения Gmail и Mail Ru Agent работают нормально.
Но мне нужен почтовый клиент, поддерживающий вложения, прежде всего офисные.
Эта функция для меня очень важная, критичная.
На cramfs прошивках такого ни разу не было
Сообщение отредактировал OFN - 18.5.2010, 14:50
W.G. Gates III
сообщение 18.5.2010, 16:51
Из: Псков
Пользователь №: 94 294
Модель телефона: Lumia 920
Прошивка: jffs2
OFN,
мне помогало удаление учетки и создание ее заново.
OFN
сообщение 18.5.2010, 19:02
Из: zp.ua
Прошивка: 6.0
Цитата(W.G. Gates III @ 18.5.2010, 19:51) *
OFN,
Спасибо,,, помогло!
IlluminatI
сообщение 18.5.2010, 20:03
Из: Украина, г.Харьков
Пользователь №: 204 570
marcolnx, когда выйдет Iris jffs-версия?
Garm
сообщение 19.5.2010, 13:25
Из: Морозовск
Не спешил бы... Проводник еще свяжется с ним насчет x7
JackiLL
сообщение 30.5.2010, 12:14
Из: Днепропетровск
Пользователь №: 120 056
Модель телефона: Atrix 2, Moto G
Twitter: @jackill_
сори за нубский вопрос, но это чудо на R451_G_11.52.14R встанет? И вообще, какую сейчас прошивку лучше всего прошить? helpsmilie.gif
OFN
сообщение 30.5.2010, 13:33
Из: zp.ua
Прошивка: 6.0
У меня она после 14R , у Garm кажется тоже
из jffs2 прошивок ИМХо эта - самая проверенная, допиленная м стабильная.
Из cramfs- последняя от Сайлент Боба
Garm
сообщение 30.5.2010, 13:46
Из: Морозовск
До нее что только не было... Встанет, конечно.
Я уже перешел на Iris jffs2
JackiLL
сообщение 30.5.2010, 17:46
Из: Днепропетровск
Twitter: @jackill_
прошил, все ок. Только в инет почему-то не выходит, хотя настроил...
Добавлено позже (30.5.2010, 21:52):
как добавить профиль по умолчанию в скрин 3? А то там только 3 (пчелайн, мтс и мегафон).
Silent_Bob
сообщение 30.5.2010, 18:56
Городской партизан
Прошивка: Готичная
Ничо туда добавлять не надо ...
Screen3 - виджет на рабочем столе
JackiLL
сообщение 30.5.2010, 19:38
Из: Днепропетровск
Twitter: @jackill_
Как на Linux Ming (jffs2 11R - firmware) посмотреть какие приложения запущены в данный момент и закрыть ненужные (только разбираюсь, не пинайте, если что)?
Garm
сообщение 31.5.2010, 5:00
Из: Морозовск
Меню приложений - Меню (слева внизу) - Диспетчер задач?
Linux Ming (jffs2 11R - firmware), Прошивка с rw на базе 11R. Версия от 16.12.2009 · Motorola ROKR E6, E6e, E6tv, MING A1200, A1200i, A1200e, A1200r, A1200w, A1600 · Forum
Текстовая версия Сейчас: 1.8.2025, 23:06
