20 страниц V « < 17 18 19 20 >
Linux Ming (jffs2 11R - firmware), Прошивка с rw на базе 11R. Версия от 16.12.2009
marcolnx
сообщение 12.11.2009, 17:31 Закрепленное сообщение!
Пользователь №: 201 733
JFFS2 11R (a1200e e a1200r)
English description is under spoiler
First: I wanted to thank tmp_do and tmr for creating a jffs2 firmware (and therefore the possibility of writing the whole system).
Second: I wanted to thank SergGG Provodnik Silent Bob dvrts and all Motofan ru users for sharing informations and help.
Starting from whiteMING2 of tmp_do (thanks to his help and his answers) I have modified and customized the firmware:
- Replaced all libraries SYStapi SYSqtapp SYSjava SYSdb etc. (11R)
- Flip closed options
- Inserted and placed some missing applications or not fully working (BCR - Sync - Standard Viewer - Photo Editor)
- Added binaries (ldd - showQ - ezxpopup - etc.), so bash3 busybox strace ...
- Added ringtones, pictures, skin, mystuff, etc.
- Radio works without headset
- Calendar in the main screen shows the first appointment in 24 hours
- 2 new skins (red and white)
- Pre-installed applications: ekonsole, Assistant of Amin (reboot, pkg installer, screenshot, swap manager, hacker, mystuff, unrar unzip, ecc.), Skin Installer, Backup Restore Now, SysInfo, ZEditor (can see hidden folder and edit hidden files), PicselEdit (there is also the standard)
- 2 java applications: platinumsudoku - ICQ Jimm
- Language: English - Russian - Ukrainian (VR English - Russian)
- Fixed all profile (Silent, Vibrate, ecc.)
- ext2 ext3 support with modules.dep
- Screen3 works
- Support autorun.txt under SD (/mmc/mmca1/)
- Fingerpad white and foxalarm (voice russian)
- added Processor (underclock and overclock at 520)
- added pictures
- added skin blue (Sens theme)
- added, replaced for Camera_R541L7_G_11.10.11R
- added, replaced for libezxmime.so.1.0.0 thanks a lot Silent Bob
- added pftpd (pure-ftpd and pure-ftpwho) thanks a lot fordalulz
- added, replaced ro rw
- added new init script (so also startup1.txt, startup.txt for SD and startup2.txt for phone) and a lot of stuff for mount --bind sounds, animation, volume, font, ecc. without write directly for new user)
p.s.: I have attached folder MCleaner and MotoID, extract and install if you want.
Generally if something does not like (you can write in the whole) you can edit yourself.
Hopefully you'll try it and have fun.
Link:
Link for download
About swap:
If we need 32mb swap just extract the folder .bin from here and put in the root of SD:
http://www.4shared.com/file/84649109/509f6517/Swap_SD.html
You can easy activate - deactivate with Assistant and check with SysInfo or eKonsole
Прикрепленное изображениеПрикрепленное изображение Прикрепленное изображениеПрикрепленное изображение
Перевод на русский dvrts
Прежде всего хотелось бы поблагодарить tmp_do и tmr за создание прошивок на базе jffs2 (и как следствие, возможность модифицирования всей ФС телефона без перепрошивки (read-write:)
Также хотелось бы поблагодарить SergGG, Provodnik, Silent Bob, dvrts и всех пользователей motofan.ru за информацию и помощь
По сравнению с WhiteMING2 (автор tmp_do) прошивка изменена, улучшена и дополнена:
- Заменены все библиотеки SYStapi SYSqtapp SYSjava SYSdb т.д. (11R)
- Расширенное меню при закрытом флипе
- Добавлена и изменены некоторые приложения, отсутствующие или некорректно работающие ( BCR - Синхронизация - Стандартный Viewer - Photo Editor)
- Добавлены бинарники (ldd - showQ - ezxpopup - и т.д.), so, bash3, BusyBox, strace ...
- Добавлены рингтоны, картинки, скины, изменен mystuff и т.д.
- Радио работает без гарнитуры
- Календарь на главном экране отображает первое задание в 24 часа
- 2 скина (красный и белый)
- Предустановленные приложения: ekonsole, Amin Assistant (перезагрузка, установщик pkg, swap, javahacker, mystuff, распаковщики архивов, и т.д.), Skin Installer, Backup Restore, SysInfo, ZEditor (можно увидеть скрытые папки и править скрытые файлы), PicselEdit (есть стандартный)
- Язык: английский - русский - украинский (VR английский - русский)
- Исправлены все звуковые профили (бесшумный, вибро, и т.д.)
- Screen3 работает
- Поддержка autorun.txt (/mmc/mmca1/autorun.txt)
- Фингерпад с кириллицей
- Foxalarm взамен стандартного будульника
- Куча мелких изменений
- Добавлено приложение для разгона процессора (до 520 MHz)
- Добавлены изображения
- Синий скин (Sens)
- Бинарники для камеры от _R541L7_G_11.10.11R
- Изменен libezxmime.so.1.0.0
- Добавлено приложение для ftp
- Изменены бинарники для ro rw
- Дополнен авторан (startup1.txt, startup.txt для карты памяти и startup2.txt для памяти телефона) и дополнительные папки для mount --bind (звуки, анимация, volumetable, шрифты, и т.д. без необходимости переходить в read-write ФС)
Ссылка
Для установки свапа - скачать файл и положить в корень карты памяти
Для изменения режимов ro - rw - в консоли выполнить
CODE
rw
CODE
ro
Сообщение отредактировал marcolnx - 10.1.2010, 9:33
Прикрепленный файл Howto_jffs2_new_firmware_save_data.txt   ( 1.17 килобайт ) Кол-во скачиваний: 948
Прикрепленный файл MCleaner_MotoID.zip   ( 337.61 килобайт ) Кол-во скачиваний: 665
Прикрепленный файл jffs2_kernel_sdhc.zip   ( 3.91 мегабайт ) Кол-во скачиваний: 1308
OFN
сообщение 18.5.2010, 19:02
Из: zp.ua
Пользователь №: 182 112
Модель телефона: XT 1585
Прошивка: 6.0
Цитата(W.G. Gates III @ 18.5.2010, 19:51) *
OFN,
мне помогало удаление учетки и создание ее заново.
Спасибо,,, помогло!
IlluminatI
сообщение 18.5.2010, 20:03
Из: Украина, г.Харьков
Пользователь №: 204 570
marcolnx, когда выйдет Iris jffs-версия?
Garm
сообщение 19.5.2010, 13:25
Из: Морозовск
Пользователь №: 48 276
Прошивка: Black Ming 3b
Не спешил бы... Проводник еще свяжется с ним насчет x7
JackiLL
сообщение 30.5.2010, 12:14
Из: Днепропетровск
Пользователь №: 120 056
Модель телефона: Atrix 2, Moto G
Twitter: @jackill_
сори за нубский вопрос, но это чудо на R451_G_11.52.14R встанет? И вообще, какую сейчас прошивку лучше всего прошить? helpsmilie.gif
OFN
сообщение 30.5.2010, 13:33
Из: zp.ua
Прошивка: 6.0
У меня она после 14R , у Garm кажется тоже
из jffs2 прошивок ИМХо эта - самая проверенная, допиленная м стабильная.
Из cramfs- последняя от Сайлент Боба
Garm
сообщение 30.5.2010, 13:46
Из: Морозовск
До нее что только не было... Встанет, конечно.
Я уже перешел на Iris jffs2
JackiLL
сообщение 30.5.2010, 17:46
Из: Днепропетровск
Twitter: @jackill_
прошил, все ок. Только в инет почему-то не выходит, хотя настроил...
Добавлено позже (30.5.2010, 21:52):
как добавить профиль по умолчанию в скрин 3? А то там только 3 (пчелайн, мтс и мегафон).
Silent_Bob
сообщение 30.5.2010, 18:56
Городской партизан
Пользователь №: 162 603
Прошивка: Готичная
Ничо туда добавлять не надо ...
Screen3 - виджет на рабочем столе
JackiLL
сообщение 30.5.2010, 19:38
Из: Днепропетровск
Twitter: @jackill_
Как на Linux Ming (jffs2 11R - firmware) посмотреть какие приложения запущены в данный момент и закрыть ненужные (только разбираюсь, не пинайте, если что)?
Garm
сообщение 31.5.2010, 5:00
Из: Морозовск
Меню приложений - Меню (слева внизу) - Диспетчер задач?
linuxoid200
сообщение 31.5.2010, 18:48
Из: Kiev
Пользователь №: 78 226
Модель телефона: a1200e, sgh i-200
Прошивка: jffs2 11R
Пропали контакты! main.db похоже целый (1.3 MB)! Но телефон перестал отображать список контактов и SMS/MMS. На SMS/MMS пишет, что читает базу и так по циклу! Последних 2 месяца не синхронизировал с компьютером, а backup на телефон не настраивал. Перешивать и hardreset делать не очень хочеться! Телефон просто перестал отображать все контакты с группами и с SIM-card тоже. Последовательность действий, которая предшествовала такой беде: 1) записал на телефон ringtone 400 KB; 2) сделал reset; 3) вытащил micro-sd; 4) вставил micro-sd in card-reader - записал несколько файлов; 5) "собрал" телефон и запустил! И ЭТО ВСЕ!!! Срочно нужна помощь!
Silent_Bob
сообщение 31.5.2010, 21:23
Городской партизан
Прошивка: Готичная
1) Удали рингтон из телефона pardon.gif ...
2) Попробуй выдрать контакты с помошью Backup Tools ...
Сообщение отредактировал Silent_Bob - 31.5.2010, 21:23
marcolnx
сообщение 31.5.2010, 21:44
linuxoid200,
I have not well understood what you maked.
But I hope you maked a backup with backup_restore_now (just 2 click, this application come with the firmware).
linuxoid200
сообщение 2.6.2010, 12:15
Из: Kiev
Прошивка: jffs2 11R
Backup уже не помогает! ((( Укажите пальцем что почитать, чтобы руками установить main.db и остальные какие есть файлы после прошивки!
Я так понял, что main.db это и база с контактами и SMS-MMS ! Правильно я понял?
Не надо будет еще какие-то файлы править руками или сохранять перед прошивкой???
Garm
сообщение 2.6.2010, 16:14
Из: Морозовск
Да.
Перед прошивкой ничего править не надо
linuxoid200
сообщение 3.6.2010, 8:59
Из: Kiev
Прошивка: jffs2 11R
сделанный бэкап асистентом после трабла привел тело, даже после прошивки, в тоже состояние трабла!
Перешил опять и буду майн_ДБ-ровать!!! Отпишусь.
перезалил старую и нужную main.db в /exz_user/sysDatabase и ( всё таже проблема: не отображаются контакты с памяти и с SIM, SMS-MMS показывается прогресс линия на чтение базы и так по циклу. (
Есть утилиты, которыми можно починить ЭТОТ main.db ? Повторюсь ещё раз: выключал и включал телефон корректно!!! Прошивка, типа последняя, от Марко с украинской локалью которую предлагают тут на форуме! )
Сообщение отредактировал linuxoid200 - 3.6.2010, 9:36
credoff
сообщение 3.6.2010, 9:58
Пользователь №: 15 146
Модель телефона: E1 & A1200
linuxoid200, скопируй сам файл main.db на комп, поставь на телефон прошивку которая стояла перед этой. Через usb-net залей базу в телефон, перезагрузись, если будеть всё норм, то ставь бэкаптулс и бэкапь с сохранением на флэхе, после чего можешь шиться на другие прошивки и восстанавливать бэкаптулсом.
Добавлено позже (3.6.2010, 10:04):
linuxoid200, забыл добавить main.db кинь сначала в /exzlocal/sysDatabase и перезагрузись, и посмотри что будет.
Silent_Bob
сообщение 3.6.2010, 11:29
Городской партизан
Прошивка: Готичная
Выдрать из него данные можно с помощью Backup Tools ...
linuxoid200
сообщение 3.6.2010, 11:38
Из: Kiev
Прошивка: jffs2 11R
Вообщем, нет успеха при копировании файла, что в /ezx_user/sysDatabase , что в /ezxlocal/sysDatabase (это вроде симлинк). Проблема в самом файле. Как его починить??? (((
Silent_Bob
сообщение 3.6.2010, 11:39
Городской партизан
Прошивка: Готичная
А там много контактов ???
linuxoid200
сообщение 3.6.2010, 13:24
Из: Kiev
Прошивка: jffs2 11R
400 контактов по 3-4 номера телефона на каждом (примерно) + по 1-2 почтовых ящика + заметки на контакт + имена начальников или помошников. Это так, типа основное.
Сейчас качаю с ОРАКЛА, типа проги, авось помогут раскрыть main.db и невзначай починят! )))
скрипт на питоне нашел на форуме Манипуляции с базой PIM (main.db) но мне это ничего не дает, я на винде. (а ник - так это просто так, типа 200 не хватает, чтобы стать полноценным линуксоидом)
Silent_Bob
сообщение 3.6.2010, 14:05
Городской партизан
Прошивка: Готичная
Python для windows ...
linuxoid200
сообщение 3.6.2010, 14:46
Из: Kiev
Прошивка: jffs2 11R
Цитата(Silent_Bob @ 3.6.2010, 17:05) *
и осталась совсем ерунда - вЫучить Питон! ггг))) Прогресс тянет за собой знание! ПОльзуешься продвинутыми девайсами - учи близлежащие науки! ггг blind.gif ))) к томе же не хватает модуля bsddb3 (уже в поиске)
Выкаченая db-5.0.21.msi требует С++ установленнй на ПиСюк.
Выкаченый je-4.0.103 требует jre-6u20-windows-i586 установленный на Вынь.
А как это всё запустить даже понятия не имею.
_Bolik_
сообщение 3.6.2010, 14:57
Motolancer
Из: UA Львів
Пользователь №: 111 986
Модель телефона: Razr XT910
Прошивка: 4.1.2 JB
а во...
Silent_Bob
сообщение 3.6.2010, 14:59
Городской партизан
Прошивка: Готичная
Backup Tools тоже потрошит main.db ...
linuxoid200
сообщение 3.6.2010, 15:20
Из: Kiev
Прошивка: jffs2 11R
дык,он же на теле запусается. Расскажи по-подробнее, плз. Думаю, интересно не только мне будет!
Silent_Bob
сообщение 3.6.2010, 15:30
Городской партизан
Прошивка: Готичная
Установи и запусти =) ...
Garm
сообщение 3.6.2010, 16:30
Из: Морозовск
Инсталлируешь (M)PKG-пакет.
Запускаешь, нажимаешь Export Contacts, выбираешь куда сохранить файл и ждешь.
На новом main.db нажимаешь Import Contacts и выбираешь ранее сохраненный бэкап
Каплан
сообщение 3.6.2010, 17:46
БлиZZнеЦ
Из: Краснодар- Горячий Ключ
Пользователь №: 112 256
Нужна помощь.
решил "облегчить" жизнь, закинуть в авторан шрифт, свап и прогу СТАРТМЕНЮ, но ничего из вышеперечисленного нестартует.
файл autorun.txt. в нем прописано
#!/bin/bash
if [ -f/mmc/mmca1/autorun/Calibri.ttf
then
cp /mmc/mmca1/autorun/Calibri.ttf /tmp/Calibri.ttf
mount -bind /ram/tmp/Calibri.ttf /usr/language/fonts/AMCSL.TTF
fi
#!/bin/bash
swapon /mmc/mmca1/.binswapfile.bin
fi
#!/bin/bash
/mmc/mmca1/.system/QTDownLoad/startmenue61/startmenu
fi
кодировка утф8. прописываю через ноутпад++.
Что не так??? можно ли что-то прописывать через телефон? последним зЭдитором например?
Сообщение отредактировал Каплан - 3.6.2010, 17:48
linuxoid200
сообщение 3.6.2010, 18:23
Из: Kiev
Прошивка: jffs2 11R
Спсб, а то я уже совсем децыл!!! Никогда б не догадался)
Ладно, проблема в другом: Этот Бэкап не видит ничего на моем main.db ( уже залитом на тело)
До залития на тело - показывает, а после - показывает, что всё по-нулям (и контакты, и СМС, и ММС).
Сам файл main.db 1.3 MB, и при просмотре в редакторе видны и телефоны, и фамилии, и СМС!
Пока не знаю как по-простому починить этот файл.
Добавлено позже (3.6.2010, 21:30):
Цитата(Каплан @ 3.6.2010, 20:46) *
Нужна помощь.
#!/bin/bash
then
fi
#!/bin/bash
fi
#!/bin/bash
fi
чего-то не понял: 1) зачем повторять #!/bin/bash; 2) зачем fi;
"остальное не смотрел" )))
Silent_Bob
сообщение 3.6.2010, 19:07
Городской партизан
Прошивка: Готичная
Насчёт шрифта - это же jffs прошивка, зачем его монтировать (можно просто заменить) ???
Хочешь монтировать: скопируй его, например, в /ezxlocal (это лучше чем каждый раз засорять им оперативку и делать время загрузки дольше) ...
Тогда авторан будет выглядеть так:
#!/bin/bash
mount --bind /ezxlocal/Calibri.ttf /usr/language/fonts/AMCSL.TTF
ps.gif У --bind две черточки ...
marcolnx
сообщение 3.6.2010, 21:00
Hi,
for mount --bind you can also create My_FAVOR folder under "phone" and place there fonts (rename font for myfont.ttf), animations, etc.
Look for this or edit like you prefear ezx_boot.cfg
linuxoid200
сообщение 4.6.2010, 7:35
Из: Kiev
Прошивка: jffs2 11R
Вообщем, тот скрипт требует import bsddb3 (уже нашел, но пока не понял как его туда впихнуть) и отсанавливается. (((
Каплан
сообщение 4.6.2010, 10:59
БлиZZнеЦ
Спасибо всем. Шрифт закинул в папку My_FAVOR, авторан свапа тоже заработал. осталось только научиться вписывать программы в авторан...
Garm
сообщение 4.6.2010, 16:41
Из: Морозовск
Soft Manager? Правильный способ, хотя он тут может не работать...
dvrts
сообщение 4.6.2010, 16:59
Из: Lviv
Пользователь №: 162 099
работает
Timonok
сообщение 7.6.2010, 16:00
Пользователь №: 197 617
Прошивка: Qtopia
Итак, создан primary linux swap раздел в конце флешки, вывод команд:
>cat /proc/partitions
major minor  #blocks  name
243     0    1920768 mmca
243     1    1847443 mmca1
243     2      72292 mmca2
>ls -l /dev/mmca2
brwxrwx-wx    1 root     root     243,   2 Jun  7 12:30 /dev/mmca2
>cat /etc/fstab
# /etc/fstab: static file system information.
# <file system> <mount point>   <type>  <options>                              <dump>  <pass>
/dev/root       /               jffs2   defaults,sync,ro,noatime,errors=remount-ro      0 0
devpts          /dev/pts        devpts  defaults                               0 0
proc            /proc           proc    defaults                               0 0
ramfs           /ram            ramfs   defaults                               0 0
/dev/mtdblock8  /home           jffs2   defaults,sync,noatime                  0 0
/dev/mmca1      /mmc/mmca1      vfat uid=2000,gid=233,iocharset=utf8,shortname=mixed,umask=002,noatime       0 0
/dev/mmca2      swap    swap    sw        0 0
> mount /dev/mmca2
mount: mounting /dev/mmca2 on swap failed: No such file or directory
Также пробовал проделать следующее:
>mount / -o remount,rw
>mv /dev/mmca2 /dev/mmca2.bak
>mknod -m 660 /dev/mmca2 b 243 2
>mount / -o remount,ro
Но swap не заводится. Я знаю что можно сделать через swapon, но задался целью подрубать свап именно через fstab. Есть предложения? Что не так?
Сообщение отредактировал Timonok - 7.6.2010, 16:01
marcolnx
сообщение 8.6.2010, 13:13
Timonok,
You can not mount a swap partition using the mount command.
fstab:
/dev/mmca2 none swap sw 0 0
After this you can make a new init script or maybe edit S82autorun.sh (/etc/rc.d/rc2.d/) and insert at the end:
swapon -a
But i prefear autorun.txt or startup1.txt or startup.txt or startup2.txt for enable swap.
#!/bin/bash
swapon /dev/mmca2
Каплан
сообщение 29.6.2010, 18:49
БлиZZнеЦ
возникла проблеммка. устанавливал mpkg игру open turnament. и тел написал нет места в телефоне, хотя память вся свободная была. не нашел временную папку установки. не могу очистить память. как освободить место?
Silent_Bob
сообщение 30.6.2010, 1:42
Городской партизан
Прошивка: Готичная
Распакуй архив на компе, потом в консоли телефона:
find / -name какой_-_нибудь_файл_из.игры
Найдёшь, где он хранится (видимо где-то в /ezxlocal) и удалишь там всё от игры ...
ps.gif / - это папка, с которой find начнёт искать (можно заменить на /ezxlocal, /ezx_user, /mmc - вряд ли ezx мог куда-то ещё распаковать) ...
Linux Ming (jffs2 11R - firmware), Прошивка с rw на базе 11R. Версия от 16.12.2009 · Motorola ROKR E6, E6e, E6tv, MING A1200, A1200i, A1200e, A1200r, A1200w, A1600 · Forum
Текстовая версия Сейчас: 22.7.2025, 4:21
