20 страниц V « < 17 18 19 20 >
Linux Ming (jffs2 11R - firmware), Прошивка с rw на базе 11R. Версия от 16.12.2009
marcolnx
сообщение 12.11.2009, 17:31 Закрепленное сообщение!
Пользователь №: 201 733
JFFS2 11R (a1200e e a1200r)
English description is under spoiler
First: I wanted to thank tmp_do and tmr for creating a jffs2 firmware (and therefore the possibility of writing the whole system).
Second: I wanted to thank SergGG Provodnik Silent Bob dvrts and all Motofan ru users for sharing informations and help.
Starting from whiteMING2 of tmp_do (thanks to his help and his answers) I have modified and customized the firmware:
- Replaced all libraries SYStapi SYSqtapp SYSjava SYSdb etc. (11R)
- Flip closed options
- Inserted and placed some missing applications or not fully working (BCR - Sync - Standard Viewer - Photo Editor)
- Added binaries (ldd - showQ - ezxpopup - etc.), so bash3 busybox strace ...
- Added ringtones, pictures, skin, mystuff, etc.
- Radio works without headset
- Calendar in the main screen shows the first appointment in 24 hours
- 2 new skins (red and white)
- Pre-installed applications: ekonsole, Assistant of Amin (reboot, pkg installer, screenshot, swap manager, hacker, mystuff, unrar unzip, ecc.), Skin Installer, Backup Restore Now, SysInfo, ZEditor (can see hidden folder and edit hidden files), PicselEdit (there is also the standard)
- 2 java applications: platinumsudoku - ICQ Jimm
- Language: English - Russian - Ukrainian (VR English - Russian)
- Fixed all profile (Silent, Vibrate, ecc.)
- ext2 ext3 support with modules.dep
- Screen3 works
- Support autorun.txt under SD (/mmc/mmca1/)
- Fingerpad white and foxalarm (voice russian)
- added Processor (underclock and overclock at 520)
- added pictures
- added skin blue (Sens theme)
- added, replaced for Camera_R541L7_G_11.10.11R
- added, replaced for libezxmime.so.1.0.0 thanks a lot Silent Bob
- added pftpd (pure-ftpd and pure-ftpwho) thanks a lot fordalulz
- added, replaced ro rw
- added new init script (so also startup1.txt, startup.txt for SD and startup2.txt for phone) and a lot of stuff for mount --bind sounds, animation, volume, font, ecc. without write directly for new user)
p.s.: I have attached folder MCleaner and MotoID, extract and install if you want.
Generally if something does not like (you can write in the whole) you can edit yourself.
Hopefully you'll try it and have fun.
Link:
Link for download
About swap:
If we need 32mb swap just extract the folder .bin from here and put in the root of SD:
http://www.4shared.com/file/84649109/509f6517/Swap_SD.html
You can easy activate - deactivate with Assistant and check with SysInfo or eKonsole
Прикрепленное изображениеПрикрепленное изображение Прикрепленное изображениеПрикрепленное изображение
Перевод на русский dvrts
Прежде всего хотелось бы поблагодарить tmp_do и tmr за создание прошивок на базе jffs2 (и как следствие, возможность модифицирования всей ФС телефона без перепрошивки (read-write:)
Также хотелось бы поблагодарить SergGG, Provodnik, Silent Bob, dvrts и всех пользователей motofan.ru за информацию и помощь
По сравнению с WhiteMING2 (автор tmp_do) прошивка изменена, улучшена и дополнена:
- Заменены все библиотеки SYStapi SYSqtapp SYSjava SYSdb т.д. (11R)
- Расширенное меню при закрытом флипе
- Добавлена и изменены некоторые приложения, отсутствующие или некорректно работающие ( BCR - Синхронизация - Стандартный Viewer - Photo Editor)
- Добавлены бинарники (ldd - showQ - ezxpopup - и т.д.), so, bash3, BusyBox, strace ...
- Добавлены рингтоны, картинки, скины, изменен mystuff и т.д.
- Радио работает без гарнитуры
- Календарь на главном экране отображает первое задание в 24 часа
- 2 скина (красный и белый)
- Предустановленные приложения: ekonsole, Amin Assistant (перезагрузка, установщик pkg, swap, javahacker, mystuff, распаковщики архивов, и т.д.), Skin Installer, Backup Restore, SysInfo, ZEditor (можно увидеть скрытые папки и править скрытые файлы), PicselEdit (есть стандартный)
- Язык: английский - русский - украинский (VR английский - русский)
- Исправлены все звуковые профили (бесшумный, вибро, и т.д.)
- Screen3 работает
- Поддержка autorun.txt (/mmc/mmca1/autorun.txt)
- Фингерпад с кириллицей
- Foxalarm взамен стандартного будульника
- Куча мелких изменений
- Добавлено приложение для разгона процессора (до 520 MHz)
- Добавлены изображения
- Синий скин (Sens)
- Бинарники для камеры от _R541L7_G_11.10.11R
- Изменен libezxmime.so.1.0.0
- Добавлено приложение для ftp
- Изменены бинарники для ro rw
- Дополнен авторан (startup1.txt, startup.txt для карты памяти и startup2.txt для памяти телефона) и дополнительные папки для mount --bind (звуки, анимация, volumetable, шрифты, и т.д. без необходимости переходить в read-write ФС)
Ссылка
Для установки свапа - скачать файл и положить в корень карты памяти
Для изменения режимов ro - rw - в консоли выполнить
CODE
rw
CODE
ro
Сообщение отредактировал marcolnx - 10.1.2010, 9:33
Прикрепленный файл Howto_jffs2_new_firmware_save_data.txt   ( 1.17 килобайт ) Кол-во скачиваний: 948
Прикрепленный файл MCleaner_MotoID.zip   ( 337.61 килобайт ) Кол-во скачиваний: 665
Прикрепленный файл jffs2_kernel_sdhc.zip   ( 3.91 мегабайт ) Кол-во скачиваний: 1308
linuxoid200
сообщение 3.6.2010, 13:24
Из: Kiev
Пользователь №: 78 226
Модель телефона: a1200e, sgh i-200
Прошивка: jffs2 11R
Цитата(Silent_Bob @ 3.6.2010, 14:39) *
А там много контактов ???
400 контактов по 3-4 номера телефона на каждом (примерно) + по 1-2 почтовых ящика + заметки на контакт + имена начальников или помошников. Это так, типа основное.
Сейчас качаю с ОРАКЛА, типа проги, авось помогут раскрыть main.db и невзначай починят! )))
скрипт на питоне нашел на форуме Манипуляции с базой PIM (main.db) но мне это ничего не дает, я на винде. (а ник - так это просто так, типа 200 не хватает, чтобы стать полноценным линуксоидом)
Silent_Bob
сообщение 3.6.2010, 14:05
Городской партизан
Пользователь №: 162 603
Прошивка: Готичная
Python для windows ...
linuxoid200
сообщение 3.6.2010, 14:46
Из: Kiev
Прошивка: jffs2 11R
Цитата(Silent_Bob @ 3.6.2010, 17:05) *
и осталась совсем ерунда - вЫучить Питон! ггг))) Прогресс тянет за собой знание! ПОльзуешься продвинутыми девайсами - учи близлежащие науки! ггг blind.gif ))) к томе же не хватает модуля bsddb3 (уже в поиске)
Выкаченая db-5.0.21.msi требует С++ установленнй на ПиСюк.
Выкаченый je-4.0.103 требует jre-6u20-windows-i586 установленный на Вынь.
А как это всё запустить даже понятия не имею.
_Bolik_
сообщение 3.6.2010, 14:57
Motolancer
Из: UA Львів
Пользователь №: 111 986
Модель телефона: Razr XT910
Прошивка: 4.1.2 JB
а во...
Silent_Bob
сообщение 3.6.2010, 14:59
Городской партизан
Прошивка: Готичная
Backup Tools тоже потрошит main.db ...
linuxoid200
сообщение 3.6.2010, 15:20
Из: Kiev
Прошивка: jffs2 11R
дык,он же на теле запусается. Расскажи по-подробнее, плз. Думаю, интересно не только мне будет!
Silent_Bob
сообщение 3.6.2010, 15:30
Городской партизан
Прошивка: Готичная
Установи и запусти =) ...
Garm
сообщение 3.6.2010, 16:30
Из: Морозовск
Пользователь №: 48 276
Прошивка: Black Ming 3b
Инсталлируешь (M)PKG-пакет.
Запускаешь, нажимаешь Export Contacts, выбираешь куда сохранить файл и ждешь.
На новом main.db нажимаешь Import Contacts и выбираешь ранее сохраненный бэкап
Каплан
сообщение 3.6.2010, 17:46
БлиZZнеЦ
Из: Краснодар- Горячий Ключ
Пользователь №: 112 256
Нужна помощь.
решил "облегчить" жизнь, закинуть в авторан шрифт, свап и прогу СТАРТМЕНЮ, но ничего из вышеперечисленного нестартует.
файл autorun.txt. в нем прописано
#!/bin/bash
if [ -f/mmc/mmca1/autorun/Calibri.ttf
then
cp /mmc/mmca1/autorun/Calibri.ttf /tmp/Calibri.ttf
mount -bind /ram/tmp/Calibri.ttf /usr/language/fonts/AMCSL.TTF
fi
#!/bin/bash
swapon /mmc/mmca1/.binswapfile.bin
fi
#!/bin/bash
/mmc/mmca1/.system/QTDownLoad/startmenue61/startmenu
fi
кодировка утф8. прописываю через ноутпад++.
Что не так??? можно ли что-то прописывать через телефон? последним зЭдитором например?
Сообщение отредактировал Каплан - 3.6.2010, 17:48
linuxoid200
сообщение 3.6.2010, 18:23
Из: Kiev
Прошивка: jffs2 11R
Спсб, а то я уже совсем децыл!!! Никогда б не догадался)
Ладно, проблема в другом: Этот Бэкап не видит ничего на моем main.db ( уже залитом на тело)
До залития на тело - показывает, а после - показывает, что всё по-нулям (и контакты, и СМС, и ММС).
Сам файл main.db 1.3 MB, и при просмотре в редакторе видны и телефоны, и фамилии, и СМС!
Пока не знаю как по-простому починить этот файл.
Добавлено позже (3.6.2010, 21:30):
Цитата(Каплан @ 3.6.2010, 20:46) *
Нужна помощь.
#!/bin/bash
then
fi
#!/bin/bash
fi
#!/bin/bash
fi
чего-то не понял: 1) зачем повторять #!/bin/bash; 2) зачем fi;
"остальное не смотрел" )))
Silent_Bob
сообщение 3.6.2010, 19:07
Городской партизан
Прошивка: Готичная
Насчёт шрифта - это же jffs прошивка, зачем его монтировать (можно просто заменить) ???
Хочешь монтировать: скопируй его, например, в /ezxlocal (это лучше чем каждый раз засорять им оперативку и делать время загрузки дольше) ...
Тогда авторан будет выглядеть так:
#!/bin/bash
mount --bind /ezxlocal/Calibri.ttf /usr/language/fonts/AMCSL.TTF
ps.gif У --bind две черточки ...
marcolnx
сообщение 3.6.2010, 21:00
Hi,
for mount --bind you can also create My_FAVOR folder under "phone" and place there fonts (rename font for myfont.ttf), animations, etc.
Look for this or edit like you prefear ezx_boot.cfg
linuxoid200
сообщение 4.6.2010, 7:35
Из: Kiev
Прошивка: jffs2 11R
Вообщем, тот скрипт требует import bsddb3 (уже нашел, но пока не понял как его туда впихнуть) и отсанавливается. (((
Каплан
сообщение 4.6.2010, 10:59
БлиZZнеЦ
Спасибо всем. Шрифт закинул в папку My_FAVOR, авторан свапа тоже заработал. осталось только научиться вписывать программы в авторан...
Garm
сообщение 4.6.2010, 16:41
Из: Морозовск
Soft Manager? Правильный способ, хотя он тут может не работать...
dvrts
сообщение 4.6.2010, 16:59
Из: Lviv
Пользователь №: 162 099
работает
Timonok
сообщение 7.6.2010, 16:00
Пользователь №: 197 617
Прошивка: Qtopia
Итак, создан primary linux swap раздел в конце флешки, вывод команд:
>cat /proc/partitions
major minor  #blocks  name
243     0    1920768 mmca
243     1    1847443 mmca1
243     2      72292 mmca2
>ls -l /dev/mmca2
brwxrwx-wx    1 root     root     243,   2 Jun  7 12:30 /dev/mmca2
>cat /etc/fstab
# /etc/fstab: static file system information.
# <file system> <mount point>   <type>  <options>                              <dump>  <pass>
/dev/root       /               jffs2   defaults,sync,ro,noatime,errors=remount-ro      0 0
devpts          /dev/pts        devpts  defaults                               0 0
proc            /proc           proc    defaults                               0 0
ramfs           /ram            ramfs   defaults                               0 0
/dev/mtdblock8  /home           jffs2   defaults,sync,noatime                  0 0
/dev/mmca1      /mmc/mmca1      vfat uid=2000,gid=233,iocharset=utf8,shortname=mixed,umask=002,noatime       0 0
/dev/mmca2      swap    swap    sw        0 0
> mount /dev/mmca2
mount: mounting /dev/mmca2 on swap failed: No such file or directory
Также пробовал проделать следующее:
>mount / -o remount,rw
>mv /dev/mmca2 /dev/mmca2.bak
>mknod -m 660 /dev/mmca2 b 243 2
>mount / -o remount,ro
Но swap не заводится. Я знаю что можно сделать через swapon, но задался целью подрубать свап именно через fstab. Есть предложения? Что не так?
Сообщение отредактировал Timonok - 7.6.2010, 16:01
marcolnx
сообщение 8.6.2010, 13:13
Timonok,
You can not mount a swap partition using the mount command.
fstab:
/dev/mmca2 none swap sw 0 0
After this you can make a new init script or maybe edit S82autorun.sh (/etc/rc.d/rc2.d/) and insert at the end:
swapon -a
But i prefear autorun.txt or startup1.txt or startup.txt or startup2.txt for enable swap.
#!/bin/bash
swapon /dev/mmca2
Каплан
сообщение 29.6.2010, 18:49
БлиZZнеЦ
возникла проблеммка. устанавливал mpkg игру open turnament. и тел написал нет места в телефоне, хотя память вся свободная была. не нашел временную папку установки. не могу очистить память. как освободить место?
Silent_Bob
сообщение 30.6.2010, 1:42
Городской партизан
Прошивка: Готичная
Распакуй архив на компе, потом в консоли телефона:
find / -name какой_-_нибудь_файл_из.игры
Найдёшь, где он хранится (видимо где-то в /ezxlocal) и удалишь там всё от игры ...
ps.gif / - это папка, с которой find начнёт искать (можно заменить на /ezxlocal, /ezx_user, /mmc - вряд ли ezx мог куда-то ещё распаковать) ...
Каплан
сообщение 30.6.2010, 7:26
БлиZZнеЦ
эм. возникло еще больше проблемм. ввел в консоли find /openttd, чтоб он нашел. тел начал искать все везде. закрыл консоль, выключил, вынул флешку, чтоб процесс шел быстрее и понеслось.
включаю, а у меня буд-то нет в скине .скн файла. забил, начал искать через консоль, не находит. поставил флешку, глюк со скином не пропал. но и консоль ничего не нашла. случаянно сам нашел. начал удалять. удалилось все кроме папки дата и всех файлов в ней и они не удаляются (. тел ночью стоял на бесшумном. начал менять стиль, пропал стиль Громкий вызов. забил и на него. восстановил все со скином, благо было с чего. но одно но, прозрачность очень темная, и изменить не могу. захожу в справочник, а там пусто, в сообщениях читает базу данных. и только. пытаюсь восстановить справочник бекап тулсом, он мне пишет невозможно заменить контакт, продолжить восстановление? жму да, и тоже самое.
как это все понимать?
Garm
сообщение 30.6.2010, 7:34
Из: Морозовск
Цитата(Каплан @ Сегодня, 11:26)
find /openttd
find / -name openttd
У тебя системного ничего на карте не было?
Каплан
сообщение 30.6.2010, 8:45
БлиZZнеЦ
только свап. больше вроде ничего. раньше нормально работал без карты памяти. таких проблемм небыло, когда вытаскивал ее
_Bolik_
сообщение 30.6.2010, 8:52
Motolancer
Из: UA Львів
Прошивка: 4.1.2 JB
jffs2
Silent_Bob
сообщение 30.6.2010, 9:35
Городской партизан
Прошивка: Готичная
jffs2
Эт точно ...
OFN
сообщение 1.7.2010, 10:03
Из: zp.ua
Пользователь №: 182 112
Модель телефона: XT 1585
Прошивка: 6.0
Пользователям linux ming, особенно тем. кто пользовал также и другие прошивки с камерой от 11R улучшенной ( блекдаймонд. ирис, последний єпинтеровский монстр):
улучшенная в плане фото камера от 11 R везде на порядок хуже. чем неулучшенная не от 11 R снимает видео , или только на jffs2 прошивках? или это только у меня? ( что тоже вариант)?
Кто нибудь еще замечал ухудшение качества съемки видео?
имеется в виду - на макисмальном разрешении, естественно
linuxoid200
сообщение 19.7.2010, 8:56
Из: Kiev
Прошивка: jffs2 11R
Тоже обратил внимание на ухудшение качества по сравнению со стоковой!
OFN
сообщение 22.7.2010, 14:59
Из: zp.ua
Прошивка: 6.0
Значит, мне таки не показалось
Что сделать для того, чтобы вернуть качество съемки видео на уровень стоковой прошивки? (хотя бы ее)))
По аналогии с Zn5 боюсь, что тут или или : или качество фото, или качество видео
Garm
сообщение 22.7.2010, 16:27
Из: Морозовск
Взять libezxcamera.so.1.0.0 и сам бинарник камеры из стоковой прошивки и засунуть сюда. RW ведь...
OFN
сообщение 22.7.2010, 18:21
Из: zp.ua
Прошивка: 6.0
Речь не об этом.
В свое время мы поменяли и libezxcamera.so.1.0.0 и бинарник от камеры на либу и бинарник от бразильской 11R , потому что камера в бразильской 11R лучше ФОТОГРАФИРУЕТ, действительно лучше (Проводник по этому поводу в шапке от предыдущей версии Ириски написал дословно: "Камера: она прекрасна"))) она действительно прекрасна. камера от бразильской 11 R, бинарник и либу от которой ставил и СерГГ в Блекдаймонд, и Эпинтер в своего последнего монстра. и Болек в МутанТа, и Сайлент Боб в последнюю версию Блекминга. и Марко по просьбе трудящихся во все последние релизы jffs2 ( вначале он не придавал этому значения. и бинарник и либу от бразильской 11R те, кто хотел. в том числе и я , ставили руками, Я еще тогда инициировал дискуссию по поводу того, что не во всех версиях 11R прошивки камера одинаково хорошая, и СерГГ разїяснил, что имеется в виду камера от бразильской 11 R). Но теперь, в процессе эксплуатации камеры от бразильской 11 R в течении достаточного времени, чтобы делать выводы. выясняется. что она действительно значительно лучше чем стоковая снимает ФОТО, но, к сожалению, заметно ( не сказать- значительно) хуже. чем стоковая. снимает ВИДЕО. Когда я это обнаружил, я поднял здесь этот вопрос, потому что допускал. что это косяк торлько на моем телефоне ( хотя и непонятно, с чего бы, если бинарник и либа у меня такие же как и у другимх пользователей), Оказывается - и другие тоже заметили, что камера от бразильской 11R снимает видео хуже стоковой. Я вспомнил, что аналогичная проблема была у людей на Zn5, когда они пытались заставить ее снимать видео с разрешением 352Х288, или хотя бs 320Х240.Заставили, но в результате ухудшилось качество фото. Кому интересно, может посмотреть ветку про "зину", для нее сейчас есть прошивки с улушенным видео, но с ухудшенным фото, и прошивки с хорошим фото,но с ужасным видео. Мне вот это обстоятельство напомнило то, что мы имеем место здесь, и я заинтересовался причиной этого явления.
Как говорил Жванецкий :"Выбирай,но осторожно" )
А хочется и фото ка кна бразильской 11R, и видео хотя бы как на стоковой.
И кто меня за это осудит)
Сообщение отредактировал OFN - 22.7.2010, 18:23
SergGG
сообщение 23.7.2010, 6:23
Мингофан
Из: Дніпро
Пользователь №: 85 418
Модель телефона: Droid Turbo
Прошивка: 6.0
Капітан Збройних сил України
Решение на первый взляд есть и несложное. Когда-то так портировали Real плеер с эквалайзером. Просто запихнули бинарник, либы и скрипт для запуска в pkg пакет и при необходимости запускали его. Можно бинарник для видео запихнуть туда. Еще вариант - видел в какой-то прошивке скрипт-переключение между классическим будильником и FoxAlarm. В пришивке есть и тот и другой, а скрипт просто по выбору пользователя монтирует нужную прогу.
OFN
сообщение 23.7.2010, 17:17
Из: zp.ua
Прошивка: 6.0
Кстати, и тот и тот варианты вполне жизненные )
Спасибо, буду пробовать
Каплан
сообщение 13.8.2010, 3:13
БлиZZнеЦ
Вчера откорректировал себе размер ммс до 512 кб (ezx_sms.cfg) , решил отправить, но оно не отправилось. так и мигало уведомление что не может быть отправлено. захотел удалить а тел виснет при нажаиии любого пункта в Сообщениях. думал прошить, а телефон виснет при выборе пункта Режим Усби. Перевел в бут сам. раза с 5 прошил. вроде все настроил. а потом захотел зайти в нет через стандартный браузер, а он не загружается. вроде грузится а потом выкидывает. может есть что-то что можно просто скопировать в телефон. не хочу шиться снова. (. и как правильно увеличить размер отправляемого ммс?
Celeron
сообщение 18.8.2010, 12:34
Пользователь №: 212 304
ребят, подскажите как отключить или хотя бы настроить говорящие часы? я не устанавливал никаких подобных прог. телефон когда ему захочется объявляет время. если где писали, покажите нет возможности искать, я с телефона. заранее спасибо.
Garm
сообщение 18.8.2010, 12:36
Из: Морозовск
Будильник - (Меню) - Говорить время (там встроен FoxAlarm)
Lex7777
сообщение 24.8.2010, 16:15
Пользователь №: 219 521
Модель телефона: E398,A1200E
Прошивка: Antarex Reborn 14R
Люди помогите !!! Как с это прошивке вернуться на 14R ??? Начинаю шить он мне что-то про батарею говорит и подскажите чем лучше прошивать А1200Е
Egomot
сообщение 24.8.2010, 20:13
Из: Краснодар
Пользователь №: 194 627
Модель телефона: Motorola Quench XT5
Прошивка: 2.1
Lex7777,
а батарея точно полностью заряжена?
шить программой RSD Lite
Lex7777
сообщение 25.8.2010, 9:14
Цитата(Egomot @ 24.8.2010, 20:13) *
Lex7777,
Nitrogradient
сообщение 25.8.2010, 9:47
Пользователь №: 206 819
Модель телефона: A1200
Прошивка: BlackMingII
Народ помогите, у меня поиск в контактах теперь зависит от размера буквы, раньше в других прошивках вводишь например "м" и он выдает все контакты начинающиеся с такой буквы, а теперь введшь маленькую м - ищет только контакты начинающиеся на маленькую и тоже самое с большой... как это исправить?
Garm
сообщение 26.8.2010, 16:11
Из: Морозовск
libezxaddrbkeng.so.1.0.0 с регистрозависимым поиском здесь. Решения не нашел (если ставить библиотеку с регистронезависимым поиском перестает работать определитель номеров)
Сообщение отредактировал Garm - 26.8.2010, 16:12
Linux Ming (jffs2 11R - firmware), Прошивка с rw на базе 11R. Версия от 16.12.2009 · Motorola ROKR E6, E6e, E6tv, MING A1200, A1200i, A1200e, A1200r, A1200w, A1600 · Forum
Текстовая версия Сейчас: 22.7.2025, 4:18
