20 страниц V « < 18 19 20
Linux Ming (jffs2 11R - firmware), Прошивка с rw на базе 11R. Версия от 16.12.2009
marcolnx
сообщение 12.11.2009, 17:31 Закрепленное сообщение!
Пользователь №: 201 733
JFFS2 11R (a1200e e a1200r)
English description is under spoiler
First: I wanted to thank tmp_do and tmr for creating a jffs2 firmware (and therefore the possibility of writing the whole system).
Second: I wanted to thank SergGG Provodnik Silent Bob dvrts and all Motofan ru users for sharing informations and help.
Starting from whiteMING2 of tmp_do (thanks to his help and his answers) I have modified and customized the firmware:
- Replaced all libraries SYStapi SYSqtapp SYSjava SYSdb etc. (11R)
- Flip closed options
- Inserted and placed some missing applications or not fully working (BCR - Sync - Standard Viewer - Photo Editor)
- Added binaries (ldd - showQ - ezxpopup - etc.), so bash3 busybox strace ...
- Added ringtones, pictures, skin, mystuff, etc.
- Radio works without headset
- Calendar in the main screen shows the first appointment in 24 hours
- 2 new skins (red and white)
- Pre-installed applications: ekonsole, Assistant of Amin (reboot, pkg installer, screenshot, swap manager, hacker, mystuff, unrar unzip, ecc.), Skin Installer, Backup Restore Now, SysInfo, ZEditor (can see hidden folder and edit hidden files), PicselEdit (there is also the standard)
- 2 java applications: platinumsudoku - ICQ Jimm
- Language: English - Russian - Ukrainian (VR English - Russian)
- Fixed all profile (Silent, Vibrate, ecc.)
- ext2 ext3 support with modules.dep
- Screen3 works
- Support autorun.txt under SD (/mmc/mmca1/)
- Fingerpad white and foxalarm (voice russian)
- added Processor (underclock and overclock at 520)
- added pictures
- added skin blue (Sens theme)
- added, replaced for Camera_R541L7_G_11.10.11R
- added, replaced for libezxmime.so.1.0.0 thanks a lot Silent Bob
- added pftpd (pure-ftpd and pure-ftpwho) thanks a lot fordalulz
- added, replaced ro rw
- added new init script (so also startup1.txt, startup.txt for SD and startup2.txt for phone) and a lot of stuff for mount --bind sounds, animation, volume, font, ecc. without write directly for new user)
p.s.: I have attached folder MCleaner and MotoID, extract and install if you want.
Generally if something does not like (you can write in the whole) you can edit yourself.
Hopefully you'll try it and have fun.
Link:
Link for download
About swap:
If we need 32mb swap just extract the folder .bin from here and put in the root of SD:
http://www.4shared.com/file/84649109/509f6517/Swap_SD.html
You can easy activate - deactivate with Assistant and check with SysInfo or eKonsole
Прикрепленное изображениеПрикрепленное изображение Прикрепленное изображениеПрикрепленное изображение
Перевод на русский dvrts
Прежде всего хотелось бы поблагодарить tmp_do и tmr за создание прошивок на базе jffs2 (и как следствие, возможность модифицирования всей ФС телефона без перепрошивки (read-write:)
Также хотелось бы поблагодарить SergGG, Provodnik, Silent Bob, dvrts и всех пользователей motofan.ru за информацию и помощь
По сравнению с WhiteMING2 (автор tmp_do) прошивка изменена, улучшена и дополнена:
- Заменены все библиотеки SYStapi SYSqtapp SYSjava SYSdb т.д. (11R)
- Расширенное меню при закрытом флипе
- Добавлена и изменены некоторые приложения, отсутствующие или некорректно работающие ( BCR - Синхронизация - Стандартный Viewer - Photo Editor)
- Добавлены бинарники (ldd - showQ - ezxpopup - и т.д.), so, bash3, BusyBox, strace ...
- Добавлены рингтоны, картинки, скины, изменен mystuff и т.д.
- Радио работает без гарнитуры
- Календарь на главном экране отображает первое задание в 24 часа
- 2 скина (красный и белый)
- Предустановленные приложения: ekonsole, Amin Assistant (перезагрузка, установщик pkg, swap, javahacker, mystuff, распаковщики архивов, и т.д.), Skin Installer, Backup Restore, SysInfo, ZEditor (можно увидеть скрытые папки и править скрытые файлы), PicselEdit (есть стандартный)
- Язык: английский - русский - украинский (VR английский - русский)
- Исправлены все звуковые профили (бесшумный, вибро, и т.д.)
- Screen3 работает
- Поддержка autorun.txt (/mmc/mmca1/autorun.txt)
- Фингерпад с кириллицей
- Foxalarm взамен стандартного будульника
- Куча мелких изменений
- Добавлено приложение для разгона процессора (до 520 MHz)
- Добавлены изображения
- Синий скин (Sens)
- Бинарники для камеры от _R541L7_G_11.10.11R
- Изменен libezxmime.so.1.0.0
- Добавлено приложение для ftp
- Изменены бинарники для ro rw
- Дополнен авторан (startup1.txt, startup.txt для карты памяти и startup2.txt для памяти телефона) и дополнительные папки для mount --bind (звуки, анимация, volumetable, шрифты, и т.д. без необходимости переходить в read-write ФС)
Ссылка
Для установки свапа - скачать файл и положить в корень карты памяти
Для изменения режимов ro - rw - в консоли выполнить
CODE
rw
CODE
ro
Сообщение отредактировал marcolnx - 10.1.2010, 9:33
Прикрепленный файл Howto_jffs2_new_firmware_save_data.txt   ( 1.17 килобайт ) Кол-во скачиваний: 948
Прикрепленный файл MCleaner_MotoID.zip   ( 337.61 килобайт ) Кол-во скачиваний: 665
Прикрепленный файл jffs2_kernel_sdhc.zip   ( 3.91 мегабайт ) Кол-во скачиваний: 1308
Каплан
сообщение 2.9.2010, 19:07
БлиZZнеЦ
Из: Краснодар- Горячий Ключ
Пользователь №: 112 256
Глюкнул справочник и смс. Была постоянна загрузка б.д.. удалил main.db и другой файл из папки ezxuzer/sysDatabase ezxlokal/sysDatabase. восстановил справочник. стал заходить в сообщения и в справочник. все работает. но во время входящих вызовов пишется просто номер а не имя, как было раньше до глюка. как это можно исправить?
Garm
сообщение 3.9.2010, 16:00
Из: Морозовск
Пользователь №: 48 276
Прошивка: Black Ming 3b
Нужен пустой файл main.db от этой прошивки. Там по умолчанию создается файл main.db, немного отличающийся от "формата прошивки"
Сообщение отредактировал Garm - 3.9.2010, 16:01
Каплан
сообщение 3.9.2010, 20:27
БлиZZнеЦ
тот который в папке usr подойдет? или обязательно из тех папок откуда поудалял?
если из тех, которые поудалял, киньте оригинал кто-то.
Silent_Bob
сообщение 3.9.2010, 20:38
Городской партизан
Пользователь №: 162 603
Прошивка: Готичная
Тот, который пустой, лежит в папке /.backup …
Каплан
сообщение 26.9.2010, 7:58
БлиZZнеЦ
В какой папке находится файл МОЕГО порядка меню? просто хочу перешить телефон, и сохранить этот файл, чтобы потом не париться с упорядочиванием как мне надо.
Добавлено позже (26.9.2010, 14:40):
Silent_Bob
сообщение 26.9.2010, 12:49
Городской партизан
Прошивка: Готичная
\ezx_user\download\appwrite\am\UserMenuTree и иже с ним ...
BulDoug
сообщение 13.12.2010, 21:30
Пользователь №: 216 492
Модель телефона: a1200e
Я не знаю как это объяснить, но на этой прошивке на моем вхлам китайском зверьке (a1200e) заработал Edge как у МТС так и у Beeline. До этого редактировал Seem - отключал EDGe тут значок активен,скорость в разы шустрее.
Charles Manson
сообщение 14.12.2010, 15:40
Пользователь №: 100 147
Модель телефона: Samsung i9190
BulDoug, Дык, на А1200е априори должен работать ёж, на то он и Е. Это на простых А1200/A1200r/A1200i непашет.
Сообщение отредактировал Charles Manson - 14.12.2010, 15:41
smetanidze
сообщение 28.12.2010, 16:33
Пользователь №: 221 397
Модель телефона: A1600e
Подскажите плиз, как прикрутить SDHC, на уровне нюба.
Зарание спасибо)
Charles Manson
сообщение 28.12.2010, 17:53
smetanidze,
ядро для этой прошивки (jffs2_kernel_sdhc) берёшь в закреплённом сообщении, полная инструкция по использованию есть в специальном топике по картам памяти
Сообщение отредактировал Charles Manson - 28.12.2010, 17:54
ХАОС
сообщение 31.12.2010, 22:55
Пользователь №: 208 071
Модель телефона: V3 V8 A1200
Глючная прошивка
уже 2 раза слетали контакты и смс без повода
dvrts
сообщение 4.1.2011, 6:07
Из: Lviv
Пользователь №: 162 099
а ты не балуйся часто rw
Garm
сообщение 7.1.2011, 10:38
Из: Морозовск
Дополнение: И не забывайте заодно переводить в RO когда не нужен RW
Сообщение отредактировал Garm - 7.1.2011, 10:38
Linux Ming (jffs2 11R - firmware), Прошивка с rw на базе 11R. Версия от 16.12.2009 · Motorola ROKR E6, E6e, E6tv, MING A1200, A1200i, A1200e, A1200r, A1200w, A1600 · Forum
Текстовая версия Сейчас: 21.7.2025, 22:53
