23 страниц V < 1 2 3 > »
Elektro255 V0.4 alpha 4 mod (4xR), 44R,46R,49R,79R
elektro255
сообщение 23.9.2006, 12:06 Закрепленное сообщение!
Из: Poland, Siedlce
Пользователь №: 53 130
09-04-2007
V0.4a4 Alpha: http://elektro255.ovh.org
08-04-2007
V0.4a3 Alpha: http://elektro255.ovh.org
07-04-2007
V0.4a2 44R Alpha: http://elektro255.ovh.org
20-12-2006
V0.3 79R Final mod: http://elektro255.ovh.org
27-11-2006
v0.3 for 49R Final mod http://elektro255.ovh.org/
26-11-2006
V0.3 46R Final mod: http://elektro255.ovh.org
НА Е1 Rokr с бутом 0А02 (оригинальный) НЕ ПОСТАВИТЕ БЕЗ Т.П.!
V0.4 alpha 4
Changes:
- Fixed problem with display timeout (fullscreen clock) when SMS/CALL received
Features:
- 4xR and 7xR MIX (use with 4xR flex)
- unlimited Video recording
- keypad automatic lock
- low battery alarm can be turned off or depend on ring style.
- Scheduled Ring Styles (ring style and funlight style can change automatically on given time and week day)
- flashlight shortcut (##)
- extra menu (shortcut *1 [shortcut is only for testing later will be changed])
- automatic menu enter, without sim card (emergency calls working too)
- new Java methods
- settings are stored on files
- no simlock checking
- Volume-bar sound can be turned off
- multiple menus (every skin can have one mma_ucp)
- Ported patches:
o SMS report significantly turned ON
o more folders in OBEX via BT
o removed unused folders from TransFlash
o Java have access to system files
o increased iTap user dictionary size
o no delete incall on SIM replace
o Bluetooth time changed to 3 minutes
o reordered camera store menu (store only is first)
o SMS alert is using default ringtone
OLD versions(V0.1-0.3):
Firmware changes:
- firmware based on 46R from StarterXP MP
- FULL SW access from Java
- LUMA&CHROMA tables moved to memory - now you can change JPEG compresion from Java
- StarterXP flex
- added dualboot
Flasher changes:
- if you have PDS_4013 flasher will no recreate this
Personalization tool changes:
- first version for 0.3_46R SW mod
- changing splash screen
- changing font (you can use *.fnt or *.smg CG4 files)
- you can turn on, turn off menu access without sim cart
- changing my shortcuts
Новая версия V0.4 alpha 4
Изменения:
- Устранена проблема с таймаутом дисплея(полноэкранные часы) при приеме смс/звонка
Новое:
- Прошивка создана как микс 4xR и 7xR (флекс 4xR ) В 44R она переименована для совместимости! Она близко не лежит к 44R на самом деле!
- Безлимитная запись видео (64мб макс как в 6х7х)
- Автоблок клавиатуры
- Звук разряженой батареи можно выключать или задать стилем оповещения(?).
- Расписание стилей оповещения (стиль оповещения и фанлайтмогут менятся автоматически по времени и дням недели)
- Фонарик по (##)
- Дополнительное меню (метка *1 [только для теста, после может изменится])
- Автоматический вход в меню без сим-карты (аварийные звонки работают)
- Новые методы в Яве (не от 79R, а новые)
- Настройки хранятся в файлах
- Не проверяется лоченость ПДС на симку (работает с лоченым пдс)
- Звук изменения громкости можно отключить
- Мультименю (каждый скин может иметь собственный мма_уцп)
- Портированы патчи:
o Оповещение о доставке SMS всегда вкл.
o больше папок доступно по OBEX из блютуза
o удалены неиспользуемые папки с флешки
o Полный доступ к системным файлам из явы
o увеличен размер пользовательского словаря iTap
o не удалыются последние вызовы при смене сим
o Время обнаружения блютуза - 3 минуты
o Меню сохранения видеозаписи (просто сохранить - первым пунктом)
o при приходе SMS играет "мелодия на смс", а не установленная на этого пользователя
Для версий 0.1-0.3
Изменения в прошивке:
- Создана на базе монстра StarterXP 46R
- Полный доступ к прошивке (симы, озу) из явы
- Таблицы сжатия фотографий перенесены в озу - теперь из явы можно управлять качеством фотографий (сжатием)
- флекс StarterXP
- добавлен дуалбут
Изменения флешера:
-Если ПДС версии 4013 (373 платформа), ПДС не пересоздается.
Изменения персонализации (Personalization tool):
- впервые для мода использована 46 прошивка
- замена заставки (на включение?)
- замена шрифта (лангпак, CG4)
- можно вкл. и выкл. доступ к меню без сим-карты
- изменен ярлык (копирайт?)
Для работы Personalization tool требуется положить в папку программы несжатый бинарный бэкап (32 мегабайта) под именем SW.bin
Прекращаем флудить, типа а когда выйдет новая версия, и.т.д.и.т.п, или придётся наказывать!
тему почистил, архив по 1 декабря тут:
Прикрепленный файл MotoFan_ru_electro.zip   ( 66.56 килобайт ) Кол-во скачиваний: 3903
Сообщение отредактировал elektro255 - 9.4.2007, 12:21
bigserg555
сообщение 24.9.2006, 13:57
MotoSportsMen
Из: Рязань
Пользователь №: 53 831
Модель телефона: LG
Прошивка: Меняю как перчатки)
abatsk, автоматическую блокировку клавиатуры включай в ява приложении,которое идёт в комплекте.
elektro255
сообщение 24.9.2006, 19:49
Из: Poland, Siedlce
do you use MotoSymbian 1.5?
if you contact with Archy and together create monsterpack, it well be best of the best!!!
what you say about it?
I used motosymbian 1.4, about flex first i must make full stable final version :)
Алекс75, my CG1 can work without any other code groups, for fully working SW you need my CG1, and set some SEEM'S:
Keypad autoblock:
SEEM 004A_0001 adres 0x91 bit 1 (1-autolock enabled 0-autolock disabled)
Low Battery Sound:
SEEM 004A_0001 adres 0x91 bit 0 (1-sound enabled 0-sound disabled)
FlashLight [##]:
SEEM 0032_0001 address 0xE bit 0 (1-flashligh avaible 0-flashligh unavaible)
Заране спасибо если сделаешь патчи, хотябы на автоблокировку клавы!
This is very hard to make patches because for example keypad autoblock need to edited in 10 places of firmware (my compiled ASM code+edited some functions in SW and added jumps to my code)
later i will upload ARM Branch calculator what can help to insert your ASM code
SharkExE
сообщение 27.9.2006, 9:28
Из: Пермь
Пользователь №: 46 933
Модель телефона: SE w810i
Прошивка: R4DB005
Ну что можно сказать, все патчи (корелеты, мидлеты, удаление системных файлов, блок\разблокб доступ по блютуз) подходят как миленькие!!! вот мой набор патчей, не все я делал.
Прикрепленный файл 49r_patches__for_elektro_.rar   ( 1.58 килобайт ) Кол-во скачиваний: 941
Алекс75
сообщение 28.9.2006, 19:02
Мото-реаниматор
Пользователь №: 30 882
Модель телефона: XT502
Прошивка: Android 2.2
Вы вот тут завели разговор подойдут или нет патчи от 49R для данной прошивы.Естественно да!!!!Любые рабочие патчи для 49 прокатят и на этой.В данной прошиве лишь частично изменен код,е более того,а так же дописан код в конце CG1 но ссылки в прошиве при этом меняться не должны иначе все рухнет.Т.е. все что "нарыто" на 49R подойдет и для данной прошивы все находится по одним и тем же смещениям.Вопрос возникает только по новым фичам-фонарик и автоблок.Просто изменений в прошиве достаточно много и перебирать все в поиске нужной не очень удобное да и не очень приятное занятие.Проще спросить у автора где находится автоблок и где фонарик.
elektro255
Where in CG1 there is an automatic lock-out and as access to a small lamp by pressing on # # .Какие НЕХ is necessary for writing down values in CG1 and where?
Алекс75
сообщение 8.10.2006, 11:57
Мото-реаниматор
scool,
народ скажите этот монстр для е398 или на оригенальный е1 можно тоже зошить?
Все зависит от того какой у тебя бут в телефоне.Если 0А02 то НЕЛЬЗЯ!!!Телефон умрет!
Насчет 2 полезных фич в монстре....К сожалению у меня не было оригинальной CG1 для Е1 поэтому сравнивал с прошивами с польз монстров но больно геморно либо все патчи откатывать а потом сравнивать либо при сравнении учитывать каждое изменение в пользовательской прошиве короче долго и геморно...Значит так обе эти фичи сделаны именно в CG1 причем включение фонарика активируется-деактивируется в симах(в каком еще не определил) но после прошивки CG1 и CG3 с данного монстра фонарик не работал а после заливки EEPROM с него же все стало ок.Сейчас качаю оригинального монстра для Е1 на базе 49R для сравнения
CG1 всетаки хочу найти где именно изменения касающиеся фонарика и автоблока.Если их будет много(изменений),а их достаточно много то сделаю скрины по каким смещениям что изменено и выложу в теме если у кого то будет желание помочь в поисках этих 2 фич помогайте.Сегодня уже 3 патча протестил в поисках изменений касающихся автоблока и фонарика пока что результат нулевой... :(
abatsk
сообщение 8.10.2006, 12:08
Пользователь №: 77 083
Модель телефона: Samsung i9003
Прошивка: Android
А когда я прошил CG1 и CG3 так у меня фонарик работал без проблемм и автоблокировка тоже!
elektro255
сообщение 11.10.2006, 5:20
Из: Poland, Siedlce
Thank for new version МР, but question remains....
Where in CG1 there is an automatic lock-out and as access to a small lamp by pressing on # # .What НЕХ is necessary for writing down values in CG1 and where?
you don't understand, there is no one address in CG1 and addresses changinging in new version, becouse this is not normal patch. Code for this feauters is linked with exists procedures in flash and to make patches you need recalculate some jumps.
And for flashlight ## SEEM was changed to SEEM32 byte 16h bit 1
For menu access *# is SEEM32 byte 0Eh bit 0
lv333
сообщение 11.10.2006, 6:57
Из: Украина, Киев
Пользователь №: 45 916
Прошивка: СМ 10
Цитата(Stranger @ Среда, 11 Октября 2006, 9:47)
А вообще хоть кто-нибудь смог скачать с рапиды? У меня ничего не выходит. Если не трудно, перезалейте еще куда-нибудь
http://www.avservice.com.ua/moto/elektro25...d_v0.2b_49R.rar
Украинский трафик ;)
Bent
сообщение 11.10.2006, 9:40
MoTo Marvellous
Пользователь №: 63 874
Stranger, расскажу :) Берёшь FlashBackup 2.62---Создание прошивок---Ставишь модель телефона Е790/Е1 ROKR--Полная прошивка(FullFlash)---выбираешь этот файл SW(bin)--Пишешь название прошивки :)--Галочка должна стоять на "Умное отсечение пустот...."---Создать.
Прошиваешь спокойно PST(если будешь шить им то в конце прошивки выйдет ОШИБКА не чего страшного) или FlashBackup 3.
Удачи.А насчёт Flasher у меня он вообще не работает ошибка приложения пишет...мне то собственно и пофиг я всегда PST прошиваю,но хотел для новизны попробовать :)
Теперь к автору.Очень радует тот факт то что автор держит слово!Сказал после 10 октября будет продолжение и выполнил обещание это очень хорошо!
По монстру...Что за белая полоска вверху где батарейка,антена и т.д.? :) Не одно ява приложение не работает(я думаю дело в скине.Забыл наверно автор убрать "Лёгкий скин" поскольку скин стоит новый)
Про мелодии,картинки и т.д. говоришь не уместно :) Самое главное! Функции работают исправно,перезагрузки пропали
elektro255 Well done the Main thing you have constrained the promise and have laid out updating after October, 10th! I respect with such people!
Reload have disappeared, functions work on hurrah.
Question - That for a white strip on above there where a battery. network, etc.??? Appendices Java do not work (likely you when skin put has forgotten to clean a tick with " Easy skin ")
Sorry for English I use the translator:)
P.S. блин только что перевёл PROMT то что он сам же и написал такая фигня получается bigsmile; буду надеятся что автор поймёт о чём я...
elektro255
сообщение 11.10.2006, 10:49
Из: Poland, Siedlce
java not woking because file J2MEST is broken and white bar on top depends from skin, but SW now is stable and you can start making monsters with this CG1 because i don't have time to make FLEX DRM etc. :)
Stalker.mg
сообщение 11.10.2006, 10:57
Evil
Пользователь №: 57 954
Модель телефона: iPhone 5
CG3
http://www.webfile.ru/1145828
http://www.rapidshare.ru/67098
CG1
http://slil.ru/23235148
Сообщение отредактировал Stalker.mg - 11.10.2006, 14:27
Stalker.mg
сообщение 11.10.2006, 14:30
Evil
ORA,
Можно, но лучше еще и cg3 заменить
CG3
CG1
на всякий случай еще разок :)
Алекс75
сообщение 11.10.2006, 16:59
Мото-реаниматор
elektro255,
At me one more question... It Is possible to put skins from a disk "b"??? It considerably will save an empty seat in CG2. For example on V635 the disk for loading java simply varied in all references with "a" on "b" but with skins such it is impossible :(
Bent
сообщение 12.10.2006, 8:25
MoTo Marvellous
SharkExE, Вот пожалуйста :) MV целиком и полностью.
Прикрепленный файл MV_electro_0.2b.rar   ( 213.62 килобайт ) Кол-во скачиваний: 684
abatsk
сообщение 12.10.2006, 8:44
Прошивка: Android
Цитата(vip.sergey @ Четверг, 12 Октября 2006, 12:36)
Люди, помогите. Чем можно прошить CG1 и CG3?
Лично я сделал так: Взял монстр, разобрал. Заменил CG1 и CG3. собрал. Включил прогу FlashBackup 3.0. Поставил галочки на этих файлах. Что бы он только их прошил .И все.
ORA
сообщение 12.10.2006, 11:55
Из: Ижевск
Пользователь №: 91 715
Прошивка: R373_0.2b(49R)
Bezumniy,
Установи яву от электро и включи в ней Автоблок клавы, у меня так получилось.
Bezumniy,
Прикрепленный файл Synerj_by_Elektro255.rar   ( 8.94 килобайт ) Кол-во скачиваний: 392
Прикрепленный файл Synerj_by_Elektro255.rar   ( 8.94 килобайт ) Кол-во скачиваний: 326
Archy
сообщение 13.10.2006, 19:45
Пользователь №: 40 468
Модель телефона: E1-L6-L7e-U9, iPhone
Прошивка: M-S1.5RC3 L7e_01.0AR
Не ругаемся и стараемся быть повежливее друг с другом.
Автору по-любому респект!
Кому-то может нравится, кому-то нет, но следующий наехавший на автора получит бан на неделю минимум.
elektro255:
Thank a lot for your work, eager to see your next projects, and thanks for taking my Symba as source :)
elektro255
сообщение 15.10.2006, 8:00
Из: Poland, Siedlce
кто-нить знает, когда выйде доработанная версия?
Final version will be In his week ;) now i’m testing final version, making flex, website etc. ;)
So I also wanted to learn what exactly it is necessary to change in CG1 that worked automatic lock-out and a small lamp. I have checked up 20 % CG1 and have counted 23 changes in comparison with standard CG1....
For automatic lock-keyapad I’m found where is code of DisplayTimeot and then injected code what read feturestarte like java and if readed state is =1 then sending event to lock keypad (like senttoos in java)
btw, have you changed Tim2005's Synerj Plugin? As you have already said you have changed Low battery sound and auto keypad lock settings from 004a (or 004e - I do not remember) seem to 0032 seem. I think now Synerj plugin doesn't work properly in changing auto lock and low battery sound settings.
I’m not changed offsets to his features, but tchis plugin hale some bugs and i will make New plugin
This will be very dangerous, when you replaced TF phone will not start without skins
Я вот звук не могу заменить потому что видите ли места нет в CG1...так теперь ещё ко всему добавилось то что не могу картинку boot заменить статичную Hellomoto,суть в том что картинка стоит фирмачная автора,НО ни программа moto_boot_scrn_repl(правильно у меня смещения) ни в ручную(ISE208,SamsungFlashImager6.10) не меняет,а показывает там обычную hellomoto хотя должен показывать эту фирмачную картинку...кто что скажет по этому поводу?
We can’t replace boot splash screen and SW name, because I’m hard protected this , after replace phone will not power on (and if first protection not working, second will crash calls from phone), because this is my signature in SW :) we can make yours signatures in flex ;)
когда пишеш на разных языках (переключаешся с символов на анг и рус или числовой) быстро то включается этот "светильник"
there is a problem with flashlight while MV is working. When I press ## while some music is playing flashlight begins to blink. Since that moment I haven't any opportunity to do anything
I will change his In final version (maybe to *0 ? )
Elektro255 имхо, 10 октября кончилось ты где там? Релиз на 10е намечал и пропал, имхо!!!
Sometimes I don’t have time to reply on forum :)
P.S.Насчет поиска в ручную необходимых изменений....времени нет но на 20% прошивы имеется 23 изменения я бегло просмотрел во всей наберется более 50 что то меня не вдохновляет каждое изменение тестить в отдельности....А вдруг тот же автоблок активируется по нескольким смещениям возможно что пустая трата времени.Надо автора раскручивать пусть инфой делится!!!
Maybe later when i have some free time i will make website about asembler for ARM7TDMI, tell how to compile patches inject In exists code and i will give some offset wher we can inject his code
2. What asm/debugger(?)/emulator(?) are you use ? (I know DevKitARM for that, or smth from "gameboy" developing like HAM)
To disassemble SW – IDA PRO 5.0
To assemble my code – ADS 1.2 (ARM Developer Suite)
To inject code – Hex Workshop and my branch calculator elektro255.webpark.pl/Branch_calc.rar
4. Maybe you know addr of ringtone volume, or addr of current ring style - it will useful for regulate it from java apps. (For example, to make changig of volume/ring stlye in selected time)
To change ring stule in java use setfeaturestate(2038,xx) where xx=0 for loud xx=2 for vibra xx=4 for silent etc.
SORRY - не зная английского. Кому не лень, переведите мое сообщение для Elektro255.
я немного понимаю по-русски :) итак вы можете писать по-русски
P.S. Quote on this forum not working so i used code tags
elektro255
сообщение 19.10.2006, 7:45
Из: Poland, Siedlce
final version will be in next week because in this weekend i have bicycle race very far from home
v0.2 (not beta) will be at http://elektro255.ovh.org/
elektro255
сообщение 26.10.2006, 17:50
Из: Poland, Siedlce
21:09:16 BOOT verion: 8C5C (bad boot)
Thats mean your phone SW is broken or memory map is blank, first you must restore backup and then send flash
Sometimes flasher will not work if you don't have 7.D0 BOOT
22:23:03 Erasing flash. It can take 5 minutes.
то значит что тебе надо ждать 5 минуты
Stalker.mg
сообщение 26.10.2006, 18:06
Evil
~Gangs2er~, перевод приблизительный, не дословный
fixed bug with mainmenu access in java aplets
убран баг с доступом к рабочему столу из явы(вроде так)
now kyeypad autolock working full stable
автоблокировка стабильная
fast menu access without SIM card by pressing *5
если нет симки, то включи телефон и нажми * 5 и вызовется главное меню
fixed bug with flashlight (when writing SMS flashalight will no turn on)
убран баг с фонариком(при наборе текста и т.п.)
- new java plugin in MV to change extra feauters settings
новый плагин для МВ с крутыми настройками
new flex (updated MV, only stable skins, 178 SMS storage, unlimited calls history...)
новый флекс(МВ, стабильный скин, сохраняется 178 смс, безлимитный список истории вызовов)
SW now is tested and it is FULL STABLE
проша тестирована и полностью стабильна
fixed bugs in Flasher.exe, removed all files from program dir, and decreased size of exe file to 247kB
убраны баги в проге для прошивания
ORA
сообщение 26.10.2006, 18:10
Из: Ижевск
Список изменений:
-Исправлен глюк с выходом в главное меню из явы (я не поянл что ето)
-Автоболок клавиатуры полностью стабилен
-Быстрый доступ к меню без вставленой симкарты по нажатию *5
-Исправлен глюк с фанариком (при наборе смс не включается)
- Новый ява плагин в Медиа Вивере для изменения "особых" настроек :)
- Новый флекс (обновлённый MV, только стабильные скины, память смс 178 штук, безлимитное количество вход\исход звонков)
- Прошивка протестирована и ПОЛНОСТЬЮ СТАБИЛЬНА
-Исправлены глюки во Flasher`e (прошивальщике) удалены лишние директории и уменьшен ехе фаил до 247kв
elektro255
сообщение 26.10.2006, 18:22
Из: Poland, Siedlce
А скин MOTO удалять можно?
я не знаю
выложите плиз "new java plugin in MV to change extra feauters settings" плюс дам.... :)
проверь приложение
BackgaMan
сообщение 26.10.2006, 18:40
Мотоумелец
Пользователь №: 61 651
Модель телефона: E-398 Htc-p3300
Удалил ни чего не произошло!
elektro255
сообщение 26.10.2006, 19:27
Из: Poland, Siedlce
Цитата(X3MAL @ Четверг, 26 Октября 2006, 21:59)
Переведите кто нибудь пожалуйста для elektro255:
elektro255, скажи пожалуйста можно ли ставить на твою прошивку патчи, такие как передача файлов по блутус, изменение системных звуков, доступ к файловой системе,изменение блокировки, т.п. Слышал что у тебя на прошивке защита какая-то от изменений стоит, и карта другая (не так ли?), вот потому и спрашиваю, уж больно привык к любимым патчам...
you can use any patch for 49R
protected is only my signature (sw name & boot splash)
BackgaMan
сообщение 26.10.2006, 19:34
Мотоумелец
Цитата(krotE398. @ Четверг, 26 Октября 2006, 23:07)
Плизз, кто скачал можно ли залить в другое место? С сайта автора (респект ему) обе ссылки с мини оперой не дружат!
Вот кому ещё надо скачиваем здесь!
elektro255
сообщение 26.10.2006, 20:25
Из: Poland, Siedlce
постоянно включённый отчёт о доставке не всем нужен. (((
if i add this option i will make settings for turn on turn of this feature
Если это реально, пожалуйста, увеличь количество SMS, которые могут храниться в телефоне.
make more than 178 SMS can be difictual, but maybe possible to make 255 but more than 255 can be impossible to do :)
Ага, понял, просто нельзя изменять цыфровую подпись, тогда второй вопрос - а дуал-бут присутствует? Всем спасибо за ответы.
is not dual-boot in my SW, but you can install this
elektro255
сообщение 27.10.2006, 14:57
Из: Poland, Siedlce
я добавил на стороне cсылки к файлам SHX (fulfalsh,reflash)
elektro255
сообщение 27.10.2006, 19:34
Из: Poland, Siedlce
Парни у меня вопрос...Как включить что бы постоянно был отчёт о доставке(как я понял он тут присутствует,но,я отправляю смс,а отчёт не приходит)
it wil be in future SW versions. This SW is stable version of v0.2b so doesn't have nothing new
elektro255
сообщение 28.10.2006, 8:39
Из: Poland, Siedlce
elektro255, when I made full reset with this SW my phone did not start any more...
So it's a bug obviously...
And also I got some trobbles with external GPRS internet - it doesn't work at all...
all this bugs depends on flex, i don't have time to make flex, so i making only CG1 and adding my flex :) If you will you can use any flex for 4xR (motosymbian MPX398 ... ), or you can make monsterpacks based on my CG1, so please give me only bugs from CG1 not flex
about 178 sms storage:
just fill seem 0144 by FF and fill all records of seem 007D by FF, then phone should store 178 SMS (if one SMS is not longer than one record of SEEM 007D)
about *#06# and *#9999# codes
i'm replaced code of this functions by my code because this functions is useless for normal user
For another feauters in yours flex use plugin for MV or my Java app
Сообщение отредактировал BackgaMan - 28.11.2006, 19:24
Monty
сообщение 29.10.2006, 8:33
Пользователь №: 62 436
Модель телефона: v3x и htc gene
я так понимаю очередной релиз ?!
Elektro255_baby_mod
http://202.44.71.148/eoffice/e398/ipb/inde...?showtopic=5198
Monty
сообщение 30.10.2006, 6:55
я тоже сначала поставил 1 и 3 части, и тоже все работало, и так же не было MV...
После каких-то манипуляций пропала автоблокировка, и ничего нельзя было сделать. Вообщем перепрошил полностью, кроме ленга, и теперь наслаждаюсь, все прекрасно работает....!!!
elektro255
сообщение 30.10.2006, 10:29
Из: Poland, Siedlce
http://elektro255.ovh.org/ website upadate
Archy
сообщение 30.10.2006, 11:02
Archy, так в том ДРМ что автор с прошей выложил ведь тоже не отображаются буквы в точке доступа...только цыфры. Хотя у меня давно готов файл вебсессий и я просто его заливаю - но дело ведь в этом глюке, который буду устранять...
Так у него как раз ДРМ от 70-й серии. Проверь - зашей мой дрм от симбы 1.5бета :) Споришь ещё зачем-то...
Tim2005, неужели с лэнгом от 42 точно не глючит - просто как-то залил от 48-заводской лэнг на 42 - так итап русс и не работал... Об этом подробно писал в теме о создании укр итапа. И флекс, говоришь...это тогда хорошо...А как насчет общего сброса? - гибнет тело или заводится потом?Тоже 42 сейчас у меня - вот и интересуюсь.
Любой монстр гибнет при общем сбросе. Не забывайте форум читать!
Итапп отлично работает на НОРМАЛЬНОМ лэнге к 48-49 прошивке (опять-таки, проверь на симбовом)
Вопрос. При прошивании только cg1,3 сколько смсов влазит? 178? И как дела обстоят с "безлимитным вход-исход списком"?
Всё это есть или надо-таки какие-то симы править?
shayah
сообщение 30.10.2006, 16:07
Из: Казань
Пользователь №: 55 722
Модель телефона: Nokia N82
X3MAL, значит так: заходишь в плагин synergy, ставишь курсор на "Автоблок клавы", нажимаешь джойстик, затем джойстик вверх (вот тут то и должна появиться галочка на пункте "Автоблок"), затем снова наводишь выделение на пункт "автоблок" и жмешь отправить (кнопка "отправить" должна залипнуть), через секунду другую снова жмешь джойстик вверх. Все можешь выходить из плагина, автоблок работает.
elektro255
сообщение 30.10.2006, 20:07
Из: Poland, Siedlce
Elektro255,какие еще функции/особенности ты намереваешься добавить в следующии версии своей прошивки если они будут?
I don't know time will show
Алекс75
сообщение 31.10.2006, 19:03
Мото-реаниматор
Кстати может кто в курсе,просто если честно лениво сидеть сравнивать 0032_0001 с моим родным симом работает только автоблок(фонарик не работает) с 0032_0001 от elektro255 обе функции доступны.Собственно вопрос где активируетсядеактивируется) фонарик в seem 0032_0001? <_<
elektro255
сообщение 1.11.2006, 12:32
Из: Poland, Siedlce
Тема превращается в тему про флекс, я думаю elektro255, не для того старался, что бы его напрягали вопросами которые уже были неоднократно обсуждены на форуме, я считаю такие вопросы флудом (про время съёмки видео и т.п) давайте не засорять тему.
я есть за
~Gangs2er~
сообщение 7.11.2006, 16:48
MotoSkinner
Пользователь №: 93 787
Модель телефона: (M) E398
Прошивка: У вас такой нету))
Вот перевёл на досуге, на русский, ява приложение Sinergi от Electro255.
Скачать Sinerj на русском
elektro255
сообщение 8.11.2006, 17:30
Из: Poland, Siedlce
undo patches for *#06#
Текстовая версия Сейчас: 2.8.2025, 10:25
